Van de uitvoering BR6004+ staat een complete handleinding op Edimax site.
ff gesopt +4Mb pdf file.
stond bij driver downloads
http://www.edimax.com.tw/Drivers/BroadBand/BR6004+.PDF
BR6004+
Your Broadband Router box should contain the items listed below
1 Broadband Router
1 AC Adapter, AC 9V 1A
1 RS-232 serial cable with DB-9 (9 pin) male connector and RJ45 plug to connect the Broadband Router Console/COM port and external ISDN TA/Analog Modem
1 female to female 9 pin adaptor to connect the Broadband Router Console port to a PC COM port.
1 CAT5 UTP cross-over LAN cable to connect the Broadband Router EWAN port to an external ADSL or Cable Modem
de BR6004 heeft alleen maar een UTP straight en een UTP cross kabel. Zit wel een com poort op om modem enz aan te sluiten.
De plus heeft zo te zien VEEL meer instel mogelijkheden dan de BR6004, profiel instellingen enzo. Zie ook dingen staan als call-back en dial-in mogelijkheid via telefoonlijn.
BR6004+
A Specifications
Internet Access via Cable or xDSL
Accessing Servers from the Public Network
Supporting Inter-office Communication
Supporting Dial-In Access to your Network
Supporting Multimedia Applications
Creating Virtual Private Network
Features
Internet Access, Multimedia Applications and Virtual Server
Multiple users to share Internet Access
IP routing and NAT/PAT support
Supporting PPPoE client function for xDSL connection
Supporting Mac clone for cable modem connection
Supporting Multimedia application(ICQ, Netmeeting, CUSeeMe, Quick Time,
etc)
Supporting Virtual Server
Protocol Support
PPP
PPPoE
IP routing, RIP-1/2
NAT/PAT
IPX
Transparent bridging
L2TP
Management
Cisco-like Command Line Interface(CLI)
Embedded Telnet server for remote Console management
Customized Web-based GUI
Firmware upgrade via Web-based GUI/Console port
Configuration data upload and download via TFTP
Internet Access time restriction feature
Support DHCP server/client
SNMP MIB support, easily for MIS staff
Multiple connection profile
Monitoring
Runtime traffic monitoring
Connection log
Syslog
Security
Natural firewall, private IP addresses not accessible from the Internet
IP Packet filtering (IP address/ Protocol/Port number)
IPX Packet filtering( Network number/Node number/Socket number)
PPP PAP/CHAP/MS-CHAP authentication
DES Encryption with L2TP protocol support
RAS and WAN Port Redundancy
COM port interface for connecting an external modem or ISDN TA for remote
dial-in and WAN-port redundancy
Virtual server feature to setup public Server
VPN
L2TP with DES Encryption
? weet jij wat.
