• ThaGuus
  • Registratie: Mei 2018
  • Laatst online: 18-11 21:28
SMSfreakie schreef op dinsdag 6 april 2021 @ 18:30:
hmm en bij mij is die nu kapot :/
van inloggen met 06nr + PW naar email + PW gegaan in de My Tmobile omgeving..
script aangepast.. 06nr er uit email er voor terug.. en nou is die stuk :(
zal het zelf wel weer ergens verprutst hebben :P
04-06 20:38:30.501 I 17@1: Flow beginning
04-06 20:38:30.502 I 17@2: Variable set
04-06 20:38:30.502 I 17@3: Variable set
04-06 20:38:30.502 I 17@22: Atomic load
04-06 20:38:30.504 I 17@25: Atomic load
04-06 20:38:30.505 I 17@27: SMS received
04-06 20:41:40.780 I 17@28: Expression true?
04-06 20:41:40.780 U 17@29: Received message containing the keyword "verbruikt"
04-06 20:41:40.781 I 17@26: Expression true?
04-06 20:41:40.781 I 17@4: HTTP request
04-06 20:41:43.102 I 17@6: Variable set
04-06 20:41:43.102 U 17@11: null: HTTP/1.1 202 Accepted, Accesstoken: xxxx, Cache-Control: no-cache, no-store, must-revalidate, Connection: close, Content-Length: 0, Date: Tue, 06 Apr 2021 18:41:42 GMT, ErrorCode: 50, ErrorText: Password is not correct, Expires: -1, Pragma: no-cache, Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tmobile-capi-t-mobile-nl-main-httpsCORS=92bdd4d151e35b17818964c9f25a867a; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tmobile-capi-t-mobile-nl-main-https=92bdd4d151e35b17818964c9f25a867a; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1617734503094, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1617734502530, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n8, X-Tmnl-PSVary: Accept,Authorization,Content-Type
04-06 20:41:43.103 U 17@5: Your refresh token is:
04-06 20:41:43.103 I 17@7: HTTP request
04-06 20:41:45.365 I 17@9: Variable set
04-06 20:41:45.366 U 17@10: null: HTTP/1.1 202 Accepted, Accesstoken: , Cache-Control: private, Connection: close, Content-Length: 0, Date: Tue, 06 Apr 2021 18:41:44 GMT, ErrorCode: invalid_request, ErrorText: The request is missing the required code parameter., Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tmobile-capi-t-mobile-nl-main-httpsCORS=8b9e34c5a5373b271f3c2e4fc726c171; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tmobile-capi-t-mobile-nl-main-https=8b9e34c5a5373b271f3c2e4fc726c171; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1617734505351, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1617734504603, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n6, X-Tmnl-PSVary: Accept,Authorization,Content-Type
04-06 20:41:45.367 U 17@8: Your access token is:
04-06 20:41:45.367 I 17@12: HTTP request
04-06 20:41:48.773 I 17@13: Variable set
04-06 20:41:48.773 U 17@15: {"ErrorCode":"401 - Unauthorized.","ErrorMessage":"Invalid authorization header.","ApiErrorCode":1101,"Content":null}
04-06 20:41:48.774 U 17@14: Your subscription API url:
04-06 20:41:48.774 I 17@23: Atomic store
04-06 20:41:48.775 I 17@24: Atomic store
04-06 20:41:48.775 I 17@16: HTTP request
04-06 20:41:48.783 F 17@16: android.system.GaiException: android_getaddrinfo failed: EAI_NODATA (No address associated with hostname)
04-06 20:41:48.787 I 17@16: Stopped by failure
en JA mn username en Pass staan wel goed ingevuld..
kan t zijn dat die struikelt over de @ ? in de username? :>
Heb het zelf net ook geprobeerd en het ziet ernaar uit dat hij meteen werkte (zelfs met mijn email als gebruikersnaam). (wist niet eens dat je je gebruikersnaam kon veranderen dus thx want had een tijdelijk nummer als gebruikersnaam)
Maar weet je 100% zeker dat de gegevens 100% kloppen (probeer ze eens op de officiële t-mobile app uit) want het script doet eigenlijk de t-mobile app na.
  • SMSfreakie
ThaGuus schreef op dinsdag 6 april 2021 @ 23:07:
Ja klopt exact... Daarom snap ik hem niet ;(
404 Signature not found
  • thomvh
SMSfreakie schreef op woensdag 7 april 2021 @ 06:38:
Als je haakjes "" om het wachtwoord heen zet, heb je dan hetzelfde probleem? Een @ kan namelijk wel problemen veroorzaken als die niet goed afgehandeld wordt.
  • SMSfreakie
Die heb ik er altijd al omheen gehad..
Enige wat veranderd is.. Username is van 't 06 maar m'n mail gegaan.. User@domein.nl bv
06 en ww stonden in het script tussen "."
06 heeft plaats gemaakt voor de mail en l 't werkt niet
  • Lennart221998
  • Laatst online: 30-08-2025
Nu Tele2 volledig is overgestapt op het T-Mobile netwerk.
Werkt dit script dan ook met een Tele2 abonnement? of dient het request dan alsnog naar Tele2 servers gestuurd te worden?
  • ThaGuus
Lennart221998 schreef op donderdag 15 april 2021 @ 15:18:
Het is mogelijk met wat kleine aanpassingen (andere token en tele2.nl in plaats van t-mobile.nl), maar volgens mij is het bij Tele2 makkelijker om het gewoon via de nog 1gb sms te doen. (Tenminste dat was vroeger)
  • Lennart221998
ThaGuus schreef op donderdag 15 april 2021 @ 17:07:
Zie inderdaad dat de NOG 1GB sms nog steeds werkt bij Tele2.
Net na de overgang van Tele2->t-mobile hadden ze deze code uitgeschakeld, nu blijkbaar weer ingeschakeld.
Viel me wel op dat na een X aantal keer je een SMS terug krijg met dat de SMS bundelbooster niet meer beschikbaar is. Hierna dien je alsnog via de app een bundel te activeren.
  • ThaGuus
Lennart221998 schreef op zaterdag 17 april 2021 @ 20:40:
Ik heb net even de flow maar geport naar Tele2 als het goed is zou het moeten werken. Het gebruikt de api net zoals bij T-Mobile. Hierdoor zit je niet aan de limiet van 6 vast.
https://llamalab.com/automate/community/flows/39202
[ Voor 11% gewijzigd door ThaGuus op 18-04-2021 16:51 ]
  • SMSfreakie
ik moet het voorlopig maar zonder script doen.. ik krijg het gewoon niet meer werkend.. ook kijken wat er gebeurt door de app wil me niet lukken..
maar das meer bij gebrek aan root toegang denk ik...
ook in een emulator krijg ik dingen ook niet aan de gang.. (t-mobile app werkt feilloos) maar verkeer sniffen etc wil niet lukken..
  • Lennart221998
ThaGuus schreef op zondag 18 april 2021 @ 16:50:
Heel erg bedankt Guus! even snel getest en het werkt goed! :)
  • Legobas
  • Registratie: Februari 2021
  • Laatst online: 28-02 17:44
Omdat ik 4G thuis heb kan ik het Automate script van Guus niet gebruiken.
Daarom heb ik de scriptje gemaakt op basis van cUrl.
Voor de liefhebbers, dit zijn de stappen die doorlopen worden:
(De cUrl optie -L staat voor Location - Follow Redirects)
Stap 1: Login
curl -XPOST
"https://capi.t-mobile.nl/login?response_type=code"
 -d "{\"Username\": \"<Username>\", \"Password\": \"<Password>\", \"ClientId\": \"9havvat6hm0b962i\", \"Scope\": \"usage+readfinancial+readsubscription+readpersonal+readloyalty+changesubscription+weblogin\"}"
 -H "Content-Type: application/vnd.capi.tmobile.nl.login.v1+json; charset=utf-8"
 -H "User-Agent: T-Mobile 5.3.28 (Android 10; 10)"
 -H "Authorization: Basic OWhhdnZhdDZobTBiOTYyaTo="
Bewaar AuthorizationCode
Stap 2: Maak Token aan
curl -XPOST
"https://capi.t-mobile.nl/createtoken"
 -d "{\"AuthorizationCode\": \"<AuthorizationCode>\"}"
 -H "Content-Type: application/json"
Bewaar accesstoken (Bearer)
Stap 3: Haal de URL op, deze kan hergebruikt worden! Stap 1 en Stap 2 hoeven dus niet elke keer opnieuw uitgevoerd te worden
curl -L -XGET
"https://capi.t-mobile.nl/account/current?resourcelabel=Customer&resourcelabel=Connection&resourcelabel=Subscription&resourcelabel=PushNotificationRegistrationStatus&resourcelabel=PushNotificationRegistration"
 -H "Accept: application/json"
 -H "Authorization: Bearer <accesstoken>"
Response:
    "Username": "<Username>",
    "Type": "Subscriber",
    "Brand": "TMNL",
    "VisitorKeyForExternals": "xxxx",
    "IsEligibleForMigration": false,
    "IsCompanyAdmin": false,
    "IsTwoFactorAuthenticationEnabled": false,
    "Resources": [
            "Label": "Customer",
            "Url": "https://capi.t-mobile.nl/<Code1>/customer/<Code2>",
            "Availability": "Available"
Stap 4: Haal beschikbare bundels op
curl -L -XGET
"https://capi.t-mobile.nl/<Code1>/customer/<Code2>/subscription/<Username>/AvailableRoamingBundles"
 -H "Accept: application/vnd.capi.tmobile.nl.availableroamingbundles.V3+json"
Stap 5: Aanvullen (als AvailableRoamingBundles niet leeg is)
curl -XPOST
"https://capi.t-mobile.nl/<Code1>/customer/<Code2>/subscription/<Username>/RoamingBundles"
 -d "{\"Bundles\":[{\"BuyingCode\":\"A0DAY01\"}]}"
 -H "Accept: application/vnd.capi.tmobile.nl.roamingbundles.V3+json"
  • ThaGuus
Legobas schreef op vrijdag 23 april 2021 @ 23:18:
Intressant ik dacht dat T-Mobile thuis gebruik maakte van de V2 login en ook een aparte bundel code hadden.
BTW hier mijn postman collections die ik gebruik om te testen met dezelfde request als die van Legobas
T-Mobile: https://www.postman.com/collections/3b5917c9c6fd91f2751d
Tele2: https://www.postman.com/collections/ba01116b9f511558ebf2
  • SkyStreaker
  • Laatst online: 08:04
SkyStreaker
Move on up!
Kan het zijn dat het script niet meer werkt vanwege de nieuwe app vna t-mobile? Voorheen werkte het gewoon, nu helaas niet meer, moet manueel bevestigen in de app.
StabilityMatrix Discord -> (persistent invite linkje)
  • SMSfreakie
SkyStreaker schreef op zaterdag 24 april 2021 @ 17:16:
V2 login gok ik?
Zouden stiekem mensen aan het migreren zijn. Naar V2?
  • SkyStreaker
SkyStreaker
Move on up!
Hoe kan ik daar achter komen en voor jou bevestigen?
  • ThaGuus
SkyStreaker schreef op zaterdag 24 april 2021 @ 17:23:
Als je verbruikt naar jezelf sms't krijg je in de automate flow logs te zien of hij een refresh token kan maken & een subscription API url kan krijgen. Is dit niet het geval dan zit je op het "nieuwe" systeem.
In dit nieuwe systeem zijn wat aanpassingen die ik nog niet weet.
Had al wel een begin gemaakt waarbij inloggen al wel werkt alleen ik heb geen idee wat er vederest mis gaat (omdat ik zelf nog op het V1 systeem zit)
Wat mogelijk is dat de volgoorde van de api urls is veranderd (stap 3) dit is eigenlijk best simpel op te lossen door alleen te vragen naar resourcelabel=Subscription
Er zou natuurlijk veel meer veranderd kunnen zijn maar ik heb hier geen idee nog van
https://www.postman.com/collections/0bd547e8ac430e8c58ab
  • SMSfreakie
Zal er straks nog even een keer naar kijken..
Zag wel dat er eerst 't V2 in een URL stond.. En later verwijst die naar een v1 URL.. Welke die denk ik krijgt vanuit een response.. Maar kon het nog niet achterhalen met m'n duffe kop vanmorgen :+
  • ThaGuus
Het blijkt dat ze de structuur van een account aan het veranderen zijn. Hierdoor heeft een account nu een lijst met abonnementen. In plaats van dat een account gelinkt is aan een abonnement. Hierdoor werkt het niet meer voor accounts die al op dit systeem overgezet zijn (het lijkt dat ze wekelijks een x aantal accounts overzetten).
Samen met @SMSfreakie hebben we de aanpassingen van de api kunnen uitvogelen :)
https://llamalab.com/automate/community/flows/39244
[ Voor 3% gewijzigd door ThaGuus op 25-04-2021 18:37 ]
  • SkyStreaker
SkyStreaker
Move on up!
ThaGuus schreef op zondag 25 april 2021 @ 18:32:
Mooi werk, ik zal straks even kijken hoe het gaat :)
  • SMSfreakie
t koste wat tijd en moeite :X maar goed alle lof gaat naar @ThaGuus.. :)
  • SkyStreaker
SkyStreaker
Move on up!
Helaas... @SMSfreakie @ThaGuus ;(
04-25 19:43:00.361 I 10@1: Flow beginning
04-25 19:43:00.362 I 10@2: Variable set
04-25 19:43:00.363 I 10@3: Variable set
04-25 19:43:00.364 I 10@22: Atomic load
04-25 19:43:00.366 I 10@25: Atomic load
04-25 19:43:00.370 I 10@27: SMS received
04-25 19:43:01.056 I 10@28: Expression true?
04-25 19:43:01.057 U 10@29: Received message containing the keyword "verbruikt"
04-25 19:43:01.058 I 10@26: Expression true?
04-25 19:43:01.058 I 10@4: HTTP request
04-25 19:43:03.047 I 10@6: Variable set
04-25 19:43:03.049 U 10@5: Your refresh token is:
04-25 19:43:03.049 I 10@7: HTTP request
04-25 19:43:21.152 I 10@9: Variable set
04-25 19:43:21.153 U 10@8: Your access token is:
04-25 19:43:21.153 I 10@12: HTTP request
04-25 19:43:29.483 I 10@13: Variable set
04-25 19:43:29.486 U 10@14: Your linkedsubscription API url:
04-25 19:43:29.488 I 10@31: HTTP request
04-25 19:43:29.492 F 10@31: com.llamalab.automate.RequiredArgumentNullException: uri
04-25 19:43:29.493 I 10@31: Stopped by failure
[ Voor 32% gewijzigd door SkyStreaker op 25-04-2021 19:53 ]
  • SMSfreakie
je tokens komen al niet door als ik het met mijn "werkende" log vergelijk..
  • TweakerPas
Heeft iemand dit ook al werkend voor KPN?
Heb helaas geen root rechten op mijn telefoon
  • ThaGuus
TweakerPas schreef op woensdag 19 mei 2021 @ 09:10:
Bij kpn werkt het nog gewoon via een simpele sms en iemand heeft hier al een flow voor gemaakt blijkbaar :)
https://llamalab.com/automate/community/flows/39436
  • danda
  • Laatst online: 17-11 21:48
Alleen nu nog voor een iPhone ☺️
Zeer interessant alles….heb net voor het eerst Automate installeert en zie daar ook de flow/code.
Echter wordt de afvraag op een SMS gezet. Ben van plan een extra Data Unlimited SIM only te kopen en deze dan in een Mifi te zetten. De SMS komt dan natuurlijk niet op mijn mobieltje aan ☹…of?
1) is het mogelijk de flow ook op de Tmobile-App te laten triggeren?
2) of kan men een ook een SMS forward instellen direct bij Tmobile…want de SIM kaart is dan in de Mifi…?
3) of zien jullie nog een andere oplossing als de kaart in de Mifi zit? Kan mijn laptop of mijn mobieltje iets in de trend doen, als zij op de Wifi-net ingelogged zijn van de Mifi?
  • robbinonline
  • Laatst online: 00:35
Verwijderd schreef op zondag 23 mei 2021 @ 08:41:
Ik denk dat je in jou geval beter kan kijken naar 4G voor thuis. https://www.t-mobile.nl/4g-voor-thuis
kan niet, want
- vaak onderweg met Mifi in NL en EU
- TMobile checkt bij 4G thuis jouw locatie...en dan mag je niet in een Mifi waaranders zijn in NL
  • ThaGuus
Verwijderd schreef op zondag 23 mei 2021 @ 09:54:
kan niet, want
Zelf dan zou ik in dit geval gewoon een mobiel aan een router koppelen door middel van usb tethering (ik weet dat Asus routers dit ondersteunt uit ervaring). Volgens mij staat er namelijk in de voorwaarde dat het niet in een 4g router mag doen en helaas verstuur je toch nog device info mee zodra je verbind.
(NVM zie net dat T-Mobile tegenwoordig ook mifi routers verkoopt met unlimited)
Maar on topic hiervoor moet je toch denk ik zelf even aan de slag. Je kan in principe dezelfde basis gebruiken van wat er nu staat alleen moet je in plaats van de sms een delay toevoegen en een request doen naar {subscriptionurl}/AvailableRoamingBundles
En dan bekijken of de teruggestuurde string je bundel code bevat.
[ Voor 4% gewijzigd door ThaGuus op 23-05-2021 13:16 ]
Dank je Guus,
Gezien ik een TPLink heb, heb ik net gezien, dat ik de TPMifi-App kan installeren, waardoor daar dan de SMSen inkomen….https://www.tp-link.com/en/support/faq/1131/
Ik vermoed toch wel, dat ik dit in de automate script kan aanpassen i.p.v. de SMS check.
Begrijp ik het goed, dat de aanvuller via een webpage gebeurt en niet via de Tmobile-App (ben nieuw met automate)…en als ik dan een Sim Only Unlimited afsluit, dan moet ik waarschijnlijk opletten, dat deze niet in mijn account bij Tmobile komt, maar een eigen login/paswrd nodig heeft/krijgt? Of werkt het ook als ik het in mijn account als extra Card/nummer laat mee opnemen...wil natuurlijk niet mijn 06 in GB verhogen..?
Hartelijke bedankt alvast,
Groeten MRO
  • ThaGuus
Verwijderd schreef op zondag 23 mei 2021 @ 13:14:
Dank je Guus,
Groeten MRO
Het automate scriptje bootst de T-Mobile app na, het logt in en daarna vraagt hij een "extra" bundel aan standaard code "A0DAY01" dit bundel is alleen te verkrijgen als je een unlimited abbonement hebt. Je kan dus nooit extra kosten maken of je eigen 06 verhogen. Behalve als je de bundelcode aanpast naar iets wat je wel kan bestellen.
Ook als het account gekoppelt wordt is het wel iets lastiger maar nog steeds mogelijk, je moet dan de v2 versie van het script gebruiken en dan in het blokje "Set Variable APIUrl" [0] aanpassen naar [1]
  • SMSfreakie
Een router die je kan flashen met openwrt en usb heeft is voldoende om vanaf je mobiel te tetheren
  • Sua
  • Laatst online: 27-12-2025
Sua
lichtelijk nieuw
SkyStreaker schreef op zondag 25 april 2021 @ 19:52:
Ik krijg dezelfde fout, enige vooruitgang gemaakt?
hoi
  • Mar.tin
  • Laatst online: 18-11 20:39
[verwijderd]
[ Voor 103% gewijzigd door Mar.tin op 28-07-2022 09:49 ]
  • SkyStreaker
SkyStreaker
Move on up!
Mar.tin schreef op donderdag 27 mei 2021 @ 21:42:
Bij mij was de fout dat ik nog niet de V2 API heb.
@Sua <--- :)
  • XXOODD
  • Laatst online: 07:01
Sua schreef op donderdag 27 mei 2021 @ 21:30:
Ik had deze fout eerst ook omdat ik mijn 06 had gebruikt, terwijl mijn username mijn e-mail is. Misschien heb jij dit ook?
  • Sua
Sua
lichtelijk nieuw
XXOODD schreef op vrijdag 28 mei 2021 @ 09:40:
Dank voor de input allen, ik ga het nog even uitzoeken. De oude versie werkte ook niet meer dus ik nam aan dat ik ook naar v2 was. Heb het idee dat er sowieso iets vreemds met mijn account is door nummerbehoud komende van andere provider.
XXOODD, kon jij nog wel op de website inloggen met je 06?
hoi
  • XXOODD
Ik heb T-Mobile Unlimited nog niet heel lang en heb vanaf het begin al een account met email als username.
Net even gecheckt, maar ik kan niet inloggen met mijn 06.
  • Sua
Sua
lichtelijk nieuw
XXOODD schreef op vrijdag 28 mei 2021 @ 15:39:
Bedankt! Ging ook even testen, en denk dat ik de verklaring heb. Ben wel naar V2 overgezet, maar je moet dan kennelijk inloggen op de website om je accountnaam om te zetten van nummer naar een emailadres. Nu wachten om door het dagelijks tegoed te gaan...
hoi
  • Mar.tin
[verwijderd]
[ Voor 95% gewijzigd door Mar.tin op 28-07-2022 09:49 ]
  • Roy Tollenaar
  • Laatst online: 18-11 17:25
heeft T-mobile dit niet door? Het zou voor mij best handig zijn omdat elke maand tussen de 900 en 1200GB verbruik. Hoe kom ik aan zo’n hoog verbruik? Nou video’s uploaden en kijken via me hotspot.
  • Sua
Sua
lichtelijk nieuw
Roy Tollenaar schreef op vrijdag 28 mei 2021 @ 16:35:
Ze lijken het de laatste tijd wel iets te ontmoedigen? Captcha en een schuifbalkje, iemand anders opgevallen?
hoi
  • XXOODD
Sua schreef op vrijdag 28 mei 2021 @ 16:04:
Nou top. Hopen dat het nu werkt!
  • SMSfreakie
Ik doe altijd fast.com
Gewoon op 300 seconden min / max gooien en 8/8 connecties geloof ik
  • ThaGuus
Sua schreef op vrijdag 28 mei 2021 @ 16:58:
De captcha is er al tijden op de website (daarom gebruiken we de app api), weet het niet zeker maar volgens mij was het schuifbalkje er ook al eerder. Maar ik denk als je het niet te gek maakt dat ze het voor hun niet zoveel uitmaakt. (als je blijft betalen teminste)
  • Sifax
  • Registratie: Mei 2021
  • Laatst online: 22-09-2023
Bij mij werkt het V1 sinds vorige week niet meer. ik krijg foutmelding V2: com.llamalab.automate.RequiredArgumentNullException: uri
V1:
05-31 02:16:33.245 I 7@12: HTTP request
05-31 02:16:34.380 I 7@13: Variable set
05-31 02:16:34.380 U 7@15: {"ErrorCode":"401 - Unauthorized.","ErrorMessage":"Invalid authorization header.","ApiErrorCode":1101,"Content":null}
05-31 02:16:34.381 U 7@14: Your subscription API url:
05-31 02:16:34.440 I 7@23: Atomic store
05-31 02:16:34.442 I 7@24: Atomic store
05-31 02:16:34.442 I 7@16: HTTP request
05-31 02:16:34.558 F 7@16: android.system.GaiException: android_getaddrinfo failed: EAI_NODATA (No address associated with hostname)
05-31 02:16:34.561 I 7@16: Stopped by failure
Ik bekijk dit post dagelijks en ik heb alles geprobeerd, maar nothing helps
  • SMSfreakie
je auth gaat al ergens de mist in.. waardoor de rest ook al niet door komt..
  • Sifax
SMSfreakie schreef op maandag 31 mei 2021 @ 19:18:
Yes dat weet ik, ik heb ook geprobeerd in te loggen op de T-Mobile website, maar de pagina refresh gwn zonder me een foutmelding te geven, alleen automatisch inloggen werkt. Ik denk dat T-Mobile stiekem probeert te zijn
Heb zelf ook volgens mij het zelfde probleem melding als Sifax, heb de output even niet meer zo paraat. Tot aan het vinden van de tokens gaat het goed, daarna kan ik niet duidelijk vinden welke tokens ik moet hebben, waar deze moeten staan en hoe de formatting ervan uit zou moeten zien.
En dan is er blijkbaar ook nog een APIv1 en v2 wat kan spelen?
Niet zo thuis in deze materie. :+ Op dit moment is mijn internet thuis door de overstap afgesloten en zit ik nu zonder internet, sindsdien allerlei manieren bekeken hoe ik de aanvullers kan automatiseren.
Misschien moet ik gewoon bottoms up werken, het v2 scriptje werkt perfect met username + password. :P
@ThaGuus Held!
[ Voor 108% gewijzigd door Verwijderd op 01-06-2021 13:07 ]
  • SMSfreakie
Is dat nog tees 't V2 script wat @ThaGuus gefabriekt heeft destijds omdat het oude bij mij niet meer werkte?
Nog steeds een held
  • SMSfreakie
En der is denk ik weer iets wat veranderd...
Soms doet die het perfect.. En soms crasht die op een java.net met een time-out
Weet iemand of zoiets ook werkt met vodafone?
  • Roy Tollenaar
Verwijderd schreef op woensdag 18 augustus 2021 @ 12:07:
Vodafone kan met SMS worden aangevuld dus op Android zal een app als automate dit kunnen doen. Op Apple zou het wel kunnen met opdrachten maar dan moet je nog steeds een knop in klikken.
  • SMSfreakie
Stuurt VF dan een SMS dat t aanvultijd is? :) en als je dat met een SMS mag beantwoorden is het ongeveer de meest makkelijke manier die er is
  • Legobas
Omdat mijn 4G thuis abonnement is vernieuwd zit ik nu ook op V2.
Hierbij de stappen van mijn vernieuwd cUrl scriptje:
Stap 1: Login
curl -XPOST
 -H "Content-Type: application/vnd.capi.tmobile.nl.login.v2+json; charset=utf-8"
curl -XPOST
Stap 3: Haal LinkedSubscriptions op (alleen de eerste keer nodig)
curl -L -XGET
"https://capi.t-mobile.nl/account/current?resourcelabel=LinkedSubscriptions"
Bewaar URL eindigend met /linkedsubscriptions
Stap 4: Haal SubscriptionURL op (alleen de eerste keer nodig)
curl -L -XGET
"<linkedsubscriptions URL>"
Bewaar SubscriptionURL
Stap 5: Haal RoamingBundles op
curl -L -XGET
"<SubscriptionURL>/roamingbundles"
Controleer of '5 GB-aanvuller NL' aanwezig is, remaining 0 MB is en bewaar de BuyingCode (A0DAY03)
Stap 6: Aanvullen (als 'Remaining' van '150000 MB NL','Dagtegoed NL' en '5 GB-aanvuller NL' 0 MB zijn)
curl -XPOST
 -d "{\"Bundles\":[{\"BuyingCode\":\"A0DAY03\"}]}"
 -H "Accept: application/vnd.capi.tmobile.nl.roamingbundles.V4+json"
[ Voor 3% gewijzigd door Legobas op 17-09-2021 00:59 ]
  • danda
De tmobile app geeft een update aan dat je je telefoonnummer moet wijzigen naar je email als gebruiksnaam. Werkt automate dan nog steeds (of moet je hierin ook iets aanpassen?)
  • SMSfreakie
Dan heb je afaik het V2 script nodig? En log je idd met je. Mail in ook in automate
  • ThaGuus
Jup kwam er vorige week ook achter, inderdaad na het inloggen op de website wordt je verzoekt om je account te migreren van een gebruikersnaam (telefoonnr) naar een email.
Nadat je dit gedaan hebt wordt ook je account gemigreerd naar de V2 api en moet je de V2 script op automate gebruiken.
[ Voor 8% gewijzigd door ThaGuus op 18-09-2021 19:58 ]
  • SMSfreakie
Ja denk dat iedereen naar de V2 geduwt wordt... Op termijn
  • Mar.tin
[verwijderd]
[ Voor 144% gewijzigd door Mar.tin op 28-07-2022 11:18 ]
  • Sifax
Goedenavond allemaal,
Hebben jullie een alternatief voor automate voor IPhone?
  • SkyStreaker
SkyStreaker
Move on up!
Is er ook bekend of dit zou werken voor 4G Buitengebied van T-Mobile? Ik weet niet of de 5GB aanvullers ook werken via SMS.
  • ThaGuus
SkyStreaker schreef op zaterdag 23 oktober 2021 @ 15:12:
In het geval van 4g in het buitengebied zou ik als ik u was gewoon een scriptje maken die elke x seconde de api bekijkt en dit draaien op bijvoorbeeld een pi. Bijvoorbeeld het scriptje van Legobas die 3 posten hierboven is geplaatst.
[ Voor 8% gewijzigd door ThaGuus op 27-10-2021 14:53 ]
  • Ercan02
  • Laatst online: 09-08-2022
Kan iemand mij helpen met het implementeren van de V2 API, ik heb heel wat reactie's gelezen maar kon er niet uit halen hoe ik dit voor elkaar kan krijgen. Alvast bedankt voor de hulp
  • SMSfreakie
Waar loop je dan tegen aan?
  • HellStorm666
  • Laatst online: 18-11 10:07
HellStorm666
BMW S1000XR / Audi S6 Avant C7
Is er ook een script welke bijv via powershell werkt?
Wij "misbruiken" een mobiel simmetje als 4g backup als de WAN plat ligt.
We gaan de sim vervangen door een 4g-thuis sim met een start van 150GB en 5GB per aanvulling.
Alsnog zou ik wel graag een script hebben draaien op windows (of Linux of docker) welke automatisch aanvult als t op is.
Iemand die me kan helpen?
[ Voor 49% gewijzigd door HellStorm666 op 28-10-2021 20:46 ]
Scientia Potentia Est
Xbox-Live GamerTag: H3llStorm666
19x Q.Cell G5 325wp op APsystems QS1
  • thomvh
HellStorm666 schreef op donderdag 28 oktober 2021 @ 20:17:
Paar Posts terug staan de API calls. Plak die samen in een bash scriptje en je bent done!
  • Skamba
  • Laatst online: 05:51
Ik heb op basis van de informatie van @Legobas een simpel programmatje geschreven voor de Tmobile Unlimited 8+2 GB bundels (A0DAY01).
Hij werkt door periodiek de app-API te pollen, en wanneer je minder dan 400 MB over hebt activeert hij een nieuwe bundel.
Source code en executables zijn hier te vinden. Er zijn executables voor Windows, Linux (x64+ARM) en MacOS. Je hebt wel het .NET Core 3.1 framework nodig.
Disclaimer:
Gebruik op eigen risico. Kan in strijd zijn met de algemene voorwaarden van T-mobile.
Ik heb dit vooral voor mijzelf gemaakt. Voor mij werkt het. Als het niet voor jou werkt, voel je vrij om een pull request in te dienen of een fork te maken.
  • SMSfreakie
Hmm leuk voor als de sms weer eens staakt :)
  • Blind0007
  • Registratie: November 2021
  • Laatst online: 15-05-2022
@Skamba Super dat je zo'n programmaatje hebt geschreven! Ik krijg helaas alleen elke keer de melding dat ik mijn gebruikersnaam en wachtwoord moet controleren na de parameters meegegeven te hebben in de command line (op Windows). Kan het zijn dat dit bij mij niet werkt omdat ik een zakelijk Unlimited account heb? Ik moet inloggen met het 06-nummer en wachtwoord. Verder werken mijn bundels op exact dezelfde manier (8GB dagelijks + 2GB aanvullers). Het zou geweldig zijn als ik dit werkend kon krijgen, ben er al een hele tijd naar op zoek. Heb jij suggesties? Alvast bedankt!
  • ThaGuus
Blind0007 schreef op donderdag 4 november 2021 @ 16:22:
Volgens mij support hij op het moment alleen maar de V2 api en op het moment zit jij nog op de V1 (geen idee of dat is omdat je een zakelijk abbonement hebt of omdat je nooit meer ingelogt hebt op t-mobile.nl).
Wat ik je aan kan raden is om even in te loggen online om te kijken of hij vraagt om je login te veranderen naar email+password. Als hij dat niet vraagt zou het script inderdaad aangepast moeten worden worden om te zorgen dat hij werkt. (er is wel een automate script btw die op de v1 werkt)
  • Blind0007
@ThaGuus Ah dat verklaart het ja, dan zit zakelijk blijkbaar nog op V1. Ik heb meerdere keren op de website ingelogd, ook zeer recent nog. Er is mij toen nergens om gevraagd qua e-mailadres of iets dergelijke. @Skamba is jouw programma eenvouding aan te passen naar de V1 versie of komt daar nogal wat bij kijken? Ik waardeer je werk enorm 👍🏻
  • jesper1994
  • Laatst online: 04-07 19:04
Ik ga binnenkort verhuizen naar een huis waar maar 44mbit VDSL mogelijk is. Als ik Windows op een raspberry pi laat draaien met de exe van skamba kan ik als ik het goed begrijp waarschijnlijk hogere snelheden halen en onbeperkt. 2 vragen:
Kan ik de simkaart gebruiken in een LTE router? Zo ja, welke router zouden jullie aanbevelen?
https://www.internetcreators.nl/aanbieding/ biedt snelheden aan tot 600mbps. Weet iemand of een aangepast script ook bij dit systeem kan werken?
  • SkyStreaker
SkyStreaker
Move on up!
Legobas schreef op vrijdag 17 september 2021 @ 00:44:
Hoe zou ik dit kunnen laten lopen op een Pi? Kan iemand mij op weg helpen?
  • Skamba
Blind0007 schreef op vrijdag 5 november 2021 @ 20:52:
Als je een beetje handig bent, kun je het project forken en met visual studio aanpassen. Ik heb zelf helaas niet de tijd om dat op te pakken!
SkyStreaker schreef op zondag 14 november 2021 @ 16:32:
Ik heb hier een linux arm build van m'n tooltje staan. Microsoft heeft hier een uitleg staan van hoe je .NET core op een raspberry pi gebruikt.
  • huliz
  • Laatst online: 19-05-2025
the script works really well when you add 2GB, however, when I run out of 8GB for the first time, it is not working. normally json file includes 3 bundles (normal 8GB, topping 2GB and EU roaming) but while I haven't added 2GB for the first time of the day, the bundle of 2GB is missing, so the top-up code doesn't work.
anyone got around it?
  • Romkabouter430
  • Laatst online: 21-11-2022
Mocht iemand het handig vinden, dit python script gebruik in in Home Assistant en AppDeamon als app.
Opslaan als tmobile.py
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
import appdaemon.plugins.hass.hassapi as hass
import requests
import json
from datetime import datetime
class TMobile(hass.Hass):
  def initialize(self):
    now = datetime.now()
    interval = int(self.args["interval"])
    self.run_every(self.updateState, now, interval)
    self.updateState()
  def updateState(self, kwargs=None):
    #basic header
    headers = {"Authorization": "Basic OWhhdnZhdDZobTBiOTYyaTo=", "User-Agent": "T-Mobile 5.3.28 (Android 10; 10)"}
    #user data for login
    data =  {"Username":"<email>", "Password": "<password>", "ClientId":"9havvat6hm0b962i", "Scope": "usage+readfinancial+readsubscription+readpersonal+readloyalty+changesubscription+weblogin"}
    response = requests.post("https://capi.t-mobile.nl/login?response_type=code", headers=headers, json=data)
    #get AuthorizationCode
    authorizationcode = response.headers["AuthorizationCode"]
    #self.log(authorizationcode)
    data =  {"AuthorizationCode": authorizationcode}
    response = requests.post("https://capi.t-mobile.nl/createtoken", headers=headers, json=data)
    #get AccessToken
    accesstoken = response.headers["AccessToken"]
    #Create new header with Authorization
    headers = {"Authorization": "Bearer "+accesstoken, "User-Agent": "T-Mobile 5.3.28 (Android 10; 10)", "Accept" : "application/json"}
    response = requests.get("https://capi.t-mobile.nl/account/current?resourcelabel=LinkedSubscriptions", headers=headers)
    dict = json.loads(response.content)
    #call the Resources Url
    response = requests.get(dict['Resources'][0]['Url'], headers=headers)
    subscriptionUrl = dict["subscriptions"][0]['SubscriptionURL']
    response = requests.get(subscriptionUrl + "/roamingbundles", headers=headers)
    data = {"Bundles":[{"BuyingCode":"A0DAY01"}]}
    totalRemaining = 0
    for bundle in dict['Bundles']:
      if (bundle['ZoneColor'] == 'NL') :
          remaining = bundle['Remaining']
          totalRemaining += remaining['Value']
    if (round(totalRemaining / 1024,0) < 1500) :
      self.interval = 600
    if (round(totalRemaining / 1024,0) < 1000) :
      post_resp = requests.post(subscriptionUrl + "/roamingbundles", json=data, headers=headers)
      self.log(post_resp)
      self.log ("2000MB aangevuld")
      self.interval = int(self.args["interval"])
    else :
      self.log ("There is " + str(round(totalRemaining / 1024,0)) + " MB remaining, no need to update")
In apps.yaml:
tmobile:
  module: tmobile
  class: TMobile
  interval: 3600
De app checkt eens per uur (interval 3600) en onder de 1500MB elke 10 minuten. Onder de 1000MB wordt het tegoed aangevuld. Kun je natuurlijk snel zelf aanpassen.
Er zijn geen error check op of dingen wel goed gaan, dat zou een leuk idee zijn nog maar tot nu geen problemen.
  • danda
staat deze tweak al in cydia of flex?
  • SkyStreaker
SkyStreaker
Move on up!
Ik heb al mijn t-mobile abonnementen onder 1 email-adres, iets zegt mij dat dit niet gaat werken denk ik?
Zal het beter zijn als ik voor mijn 4G@Home een apart account gebruik en niet een verzamelaccount voor deze tool?
  • Skamba
SkyStreaker schreef op vrijdag 31 december 2021 @ 19:06:
De code is vast aan te passen om de juiste te pakken, maar omdat ikzelf maar één abonnement heb kan ik daar zelf niet zo goed bij helpen. De vraag is dus hoe handig je bent met C# als je het onder één emailadres zou willen doen. Als je daar geen zin in hebt is het inderdaad misschien handig om het onder een andere te zetten :)
  • SMSfreakie
denk dat je met 1 account en meerde abbos toch nog een stap krijgt in de zin van welk abo wil je hem voor upgraden ?
  • ThaGuus
Om 4G@home te gebruiken met die tool moet je het volgens mij het toch opnieuw compilen dus dan maakt het niet veel uit of het op een andere email is.
Je moet een van deze twee lijnen aanpassen (een van de twee nullen moet op 1 staan als je het op een account hebt. Ik weet niet meer welke van de twee het is dus je zou dat gewoon even moeten proberen.
https://github.com/Skamba...1de3cc9cd/Program.cs#L104
https://github.com/Skamba...1de3cc9cd/Program.cs#L112
  • SkyStreaker
SkyStreaker
Move on up!
Ervan uitgaande dat ook die static string klopt voor 4G@Home?
Compilen is onbekend terrein voor mij, dus dat zal ik dan ook even uit moeten vogelen :D
  • Tim.C
  • Laatst online: 25-09 13:45
Ik loop tegen een probleem aan, als ik nu een aanvuller aanvraag middels de Automate script v2 stuurt t-mobile mij een SMS met een 2FA code en sluit de script zich af. Ik maak hier slechts incidenteel gebruik van dus wellicht hebben de twee niks met elkaar te maken maar dat lijkt me sterk. Anderen die hier tegenaan lopen?
02-19 13:18:27.629 I 10@1: Flow beginning
02-19 13:18:27.630 I 10@2: Variable set
02-19 13:18:27.630 I 10@3: Variable set
02-19 13:18:27.632 I 10@22: Atomic load
02-19 13:18:27.636 I 10@25: Atomic load
02-19 13:18:27.637 I 10@27: SMS received
02-19 13:18:41.650 I 10@28: Expression true?
02-19 13:18:41.650 U 10@30: Received message without the keyword "verbruikt"
02-19 13:18:41.650 I 10@27: SMS received
02-19 13:19:41.798 I 10@28: Expression true?
02-19 13:19:41.799 U 10@29: Received message containing the keyword "verbruikt"
02-19 13:19:41.799 I 10@26: Expression true?
02-19 13:19:41.799 I 10@4: HTTP request
02-19 13:19:43.160 I 10@6: Variable set
02-19 13:19:43.161 U 10@5: Your refresh token is:
02-19 13:19:43.161 I 10@7: HTTP request
02-19 13:19:44.126 I 10@9: Variable set
02-19 13:19:44.126 U 10@8: Your access token is:
02-19 13:19:44.126 I 10@12: HTTP request
02-19 13:19:44.830 I 10@13: Variable set
02-19 13:19:44.831 U 10@14: Your linkedsubscription API url:
02-19 13:19:44.831 I 10@31: HTTP request
02-19 13:19:44.838 F 10@31: com.llamalab.automate.RequiredArgumentNullException: url
02-19 13:19:44.838 I 10@31: Stopped by failure
  • FooLsKi
  • Laatst online: 18-11 20:14
FooLsKi
Prutz0r 4 Life
Tim.C schreef op dinsdag 22 februari 2022 @ 14:30:
Toevallig 2FA aan staan in je My T-Mobile account?
Hoezo, ik zit je raar aan te kijken? Zo kijk ik altijd! Slijpen is niet nodig, ik prefereer de botte bijl.
  • Tim.C
FooLsKi schreef op dinsdag 22 februari 2022 @ 14:32:
Ja dit was dus het probleem. Kan me niet herinneren dat ik die ooit aan heb gezet. 8)7
Hartstikke bedankt!
  • Jagvir
  • Registratie: Mei 2015
  • Laatst online: 26-03 19:52
Klopt het dat daar het nieuwe login systeem met een email address het automate scriptje niet meer werkt? Is hier een geupdate versie van?
Ik heb altijd de v1 versie hiervan gebruikt.
@Romkabouter430 Is het mogelijke het pyhton script op een raspberry pi te runnen of op windows?
Als iemand een idee heeft over of dat zou kunnen en hoe hoor ik het graag.
Alvast bedankt.
Edit: De v2 script lijkt wel te werken.
[ Voor 40% gewijzigd door Jagvir op 22-02-2022 19:34 . Reden: update ]
  • deathnotedej
  • Laatst online: 21-09-2024
Heeft iemand een werkend scriptje om de bundelbooster aan te vragen via de Tele2 API?
Heb deze geprobeerd, maar hij geeft een foutmelding:
Hier is het logje:
03-22 20:37:36.856 I 10@1: Flow beginning
03-22 20:37:36.857 I 10@2: Variable set
03-22 20:37:36.858 I 10@3: Variable set
03-22 20:37:36.859 I 10@22: Atomic load
03-22 20:37:36.860 I 10@25: Atomic load
03-22 20:37:36.862 I 10@27: SMS received
03-22 20:39:29.086 I 10@27: Stopped by user
03-22 20:39:32.923 I 11@1: Flow beginning
03-22 20:39:32.924 I 11@2: Variable set
03-22 20:39:32.925 I 11@3: Variable set
03-22 20:39:32.925 I 11@22: Atomic load
03-22 20:39:32.927 I 11@25: Atomic load
03-22 20:39:32.928 I 11@27: SMS received
03-22 20:41:50.447 I 11@28: Expression true?
03-22 20:41:50.448 U 11@30: Received message without the keyword "verbruikt"
03-22 20:41:50.448 I 11@27: SMS received
03-22 20:44:50.532 I 11@28: Expression true?
03-22 20:44:50.534 U 11@29: Received message containing the keyword "verbruikt"
03-22 20:44:50.534 I 11@26: Expression true?
03-22 20:44:50.546 I 11@4: HTTP request
03-22 20:44:52.113 I 11@6: Variable set
03-22 20:44:52.115 U 11@11: null: HTTP/1.1 202 Accepted, Accesstoken: , Cache-Control: no-cache, no-store, must-revalidate, Connection: close, Content-Length: 0, Date: Tue, 22 Mar 2022 19:44:52 GMT, ErrorCode: 50, ErrorText: Password is not correct, Expires: -1, Pragma: no-cache, Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-httpsCORS=83c5dda7f98183933f9e340166882760; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-https=83c5dda7f98183933f9e340166882760; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1647978292097, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1647978291490, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n5, X-Tmnl-PSVary: Accept,Authorization,Content-Type
03-22 20:44:52.115 U 11@5: Your refresh token is:
03-22 20:44:52.115 I 11@7: HTTP request
03-22 20:44:52.945 I 11@9: Variable set
03-22 20:44:52.946 U 11@10: null: HTTP/1.1 202 Accepted, Accesstoken: , Cache-Control: private, Connection: close, Content-Length: 0, Date: Tue, 22 Mar 2022 19:44:53 GMT, ErrorCode: invalid_request, ErrorText: The request is missing the required code parameter., Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-httpsCORS=3f601fd936e472d4ff8173204fbd5208; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-https=3f601fd936e472d4ff8173204fbd5208; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1647978292937, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1647978292801, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n2, X-Tmnl-PSVary: Accept,Authorization,Content-Type
03-22 20:44:52.946 U 11@8: Your access token is:
03-22 20:44:52.947 I 11@12: HTTP request
03-22 20:44:53.977 I 11@13: Variable set
03-22 20:44:53.982 U 11@15: {"ErrorCode":"401 - Unauthorized.","ErrorMessage":"Invalid authorization header.","ApiErrorCode":1101,"Content":null}
03-22 20:44:53.982 U 11@14: Your subscription API url:
03-22 20:44:53.983 I 11@23: Atomic store
03-22 20:44:53.986 I 11@24: Atomic store
03-22 20:44:53.987 I 11@16: HTTP request
03-22 20:44:54.369 F 11@16: android.system.GaiException: android_getaddrinfo failed: EAI_NODATA (No address associated with hostname)
03-22 20:44:54.374 I 11@16: Stopped by failure
  • SMSfreakie
Password is not correct, springt me er direct uit :?
daardoor komt de rest ook niet goed :o
[ Voor 27% gewijzigd door SMSfreakie op 22-03-2022 20:54 ]
  • deathnotedej
SMSfreakie schreef op dinsdag 22 maart 2022 @ 20:53:
Heb dat al gecontroleerd, het wachtwoord is juist.
Zou een nieuw wachtwoord kunnen instellen en het dan opnieuw proberen.
  • SMSfreakie
gebruikersnaam / wachtwoord zet ik voor nu even de pijlen op in :)
  • deathnotedej
SMSfreakie schreef op dinsdag 22 maart 2022 @ 20:57:
Krijg nog steeds dezelfde melding met een nieuw wachtwoord. De gebruikersnaam klopt ook.
Edit: zou misschien het T-Mobile V2-scriptje omgezet moeten worden naar Tele2 aangezien ik met mijn e-mail inlog?
Logje:
03-22 20:58:15.097 I 14@1: Flow beginning
03-22 20:58:15.098 I 14@2: Variable set
03-22 20:58:15.098 I 14@3: Variable set
03-22 20:58:15.098 I 14@22: Atomic load
03-22 20:58:15.099 I 14@25: Atomic load
03-22 20:58:15.099 I 14@27: SMS received
03-22 20:59:10.625 I 14@28: Expression true?
03-22 20:59:10.625 U 14@30: Received message without the keyword "verbruikt"
03-22 20:59:10.638 I 14@27: SMS received
03-22 21:02:25.498 I 14@28: Expression true?
03-22 21:02:25.501 U 14@29: Received message containing the keyword "verbruikt"
03-22 21:02:25.502 I 14@26: Expression true?
03-22 21:02:25.509 I 14@4: HTTP request
03-22 21:02:28.965 I 14@6: Variable set
03-22 21:02:28.967 U 14@11: null: HTTP/1.1 202 Accepted, Accesstoken: , Cache-Control: no-cache, no-store, must-revalidate, Connection: close, Content-Length: 0, Date: Tue, 22 Mar 2022 20:02:29 GMT, ErrorCode: 50, ErrorText: Password is not correct, Expires: -1, Pragma: no-cache, Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-httpsCORS=e245861a5e0bdc3de15c9885adef6782; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-https=e245861a5e0bdc3de15c9885adef6782; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1647979348957, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1647979348408, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n7, X-Tmnl-PSVary: Accept,Authorization,Content-Type
03-22 21:02:28.967 U 14@5: Your refresh token is:
03-22 21:02:28.968 I 14@7: HTTP request
03-22 21:02:29.766 I 14@9: Variable set
03-22 21:02:29.767 U 14@10: null: HTTP/1.1 202 Accepted, Accesstoken: , Cache-Control: private, Connection: close, Content-Length: 0, Date: Tue, 22 Mar 2022 20:02:30 GMT, ErrorCode: invalid_request, ErrorText: The request is missing the required code parameter., Server: Microsoft-IIS/10.0, Set-Cookie: afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-httpsCORS=f06f1a52b58087ae00dfc786b133db07; Path=/; SameSite=None; Secure, afck-httpsetting-backendpool-tele2-capi-t-mobile-nl-main-https=f06f1a52b58087ae00dfc786b133db07; Path=/, Vary: Accept,Authorization,Content-Type, X-Android-Received-Millis: 1647979349763, X-Android-Response-Source: NETWORK 202, X-Android-Selected-Protocol: http/1.1, X-Android-Sent-Millis: 1647979349403, X-AspNet-Version: 4.0.30319, X-Powered-By: ASP.NET, X-Tmnl-Osn: p1n4, X-Tmnl-PSVary: Accept,Authorization,Content-Type
03-22 21:02:29.767 U 14@8: Your access token is:
03-22 21:02:29.767 I 14@12: HTTP request
03-22 21:02:31.153 I 14@13: Variable set
03-22 21:02:31.156 U 14@15: {"ErrorCode":"401 - Unauthorized.","ErrorMessage":"Invalid authorization header.","ApiErrorCode":1101,"Content":null}
03-22 21:02:31.161 U 14@14: Your subscription API url:
03-22 21:02:31.161 I 14@23: Atomic store
03-22 21:02:31.164 I 14@24: Atomic store
03-22 21:02:31.165 I 14@16: HTTP request
03-22 21:02:31.180 F 14@16: android.system.GaiException: android_getaddrinfo failed: EAI_NODATA (No address associated with hostname)
03-22 21:02:31.183 I 14@16: Stopped by failure
  • ThaGuus
deathnotedej schreef op dinsdag 22 maart 2022 @ 20:49:
Hier is het logje:
Ik heb de tele2 bundle boost nooit geupdate naar de V2 api en ik denk dat Tele2 die nu ook gebruikt.
De reden hiervoor is eigenlijk omdat je bij Tele2 nog steeds een bundel aan kan vragen dmv een sms (en hier zijn ook automate scripts voor)
Zelf heb ik ook geen Tele2 abbonnement meer in huis dus kan het niet dubbelchecken, maar wat je kan proberen is de T-mobile flow downloaden en dan bij alle Requests de "Request Url" veranderen naar tele2.nl. Ook moet je de Clientid & User Agent header, Authorization header veranderen en daarna zou het in theorie moeten werken. (Dit is wel echt een kut werkje)
  • deathnotedej
ThaGuus schreef op dinsdag 22 maart 2022 @ 21:40:
Ja, Tele2 heeft nu een limiet op het aantal keer dat je kunt bijvullen met sms'jes. Dan ga ik morgen proberen om het scriptje aan te passen zodat het werkt met Tele2.
Bedankt voor je werk (en de tip om het laten werken)!
Is er ook een compatible app/script voor ios? Want automate is er zag ik alleen voor android.
  • deathnotedej
Verwijderd schreef op zondag 27 maart 2022 @ 15:27:
Nee, zonder een Jailbreak is het niet mogelijk.
Je kan wel met Shortcuts een sms'je laten sturen om bij te vullen, alleen is dit niet automatisch omdat je de shortcut zelf moet openen.
Ok, scheelt dat ik een android toestel heb. Nu nog even zoeken waar ik de melding en geluid uit kan zetten
  • deathnotedej
Verwijderd schreef op zondag 27 maart 2022 @ 21:40:
Je kan in de berichten app Tele2/T-Mobile blokkeren en je kan ook de meldingen uitzetten (voor specifiek dat nummer), dan krijg je geen berichten van dat je bundel bijna op is of bijgevuld is.
  • TWeaKLeGeND
  • Laatst online: 05-09 00:17
Werkt dit nog bij een nieuw tmo abbo? Sta op het punt tmo te nemen maar als dit niet meer werkt blijf ik wel bij tele2
Pagina: 1 2 3 4 Laatste
