Game pc for 400-500 euro
I'd like to buy a medium game pc that will run games (examples below) smoothly on lets say medium graphics, maybe with some settings to high (not ultra). Some examples of games I like to play: World of Tanks, DayZ, Assassins Creed.
400-500 euro
I believe I got everything except the pc.
Id rather have an intel cpu but if not, thats OK.
As said in the first reply, id like to be able run those games smooth on medium-high. If even possible ;)
Wat verwacht je van ons?[i]
Honest opinions :)
Since I simply can't afford a more expensive one, I'd like it to be under 500 euro and I know its not a lot.
I found this system for around 450 euros:
-CPU: AMD FX-4300 QuadCore 3.8ghz
-Optical: LG Dual Layer DVD/CD 24x RAM sata
-VGA: Nvidia Geforce GTX750-Ti-2Gb DDR5 -1x DVi-i, 1x VGA, 1x HDMI PCI-E
-PSU: Silent 12Cm Silence 500W power supply
-ATX: Sharkoon Blueled gaming tower with window
-HDD: Sata3 1000Gb 32Mb 7200Rpm harddisk
-RAM: Crucial 8Gb DDR3 1600mhz
-Mobo: ASROCK AM3+ Nforce 630A FX chipset with: 2x USB2.0, 2xUSB3.0 (2x USB2.0 front with audio)
Lan Gbit 10/100/1000, 5.1 Digital Sound HD audio / 4x Sata300 (raid)
1x PCiE 16x 2.0, 1XPCiE X1, 2x PCi, 1x Com, 2x PS2,
Case: D 44.5 xB 20 xH 43 cm.
+ additional card reader
(no OS, but thats not a problem)
I also don't know whether the power supply is enough.
And the CPU isn’t that great. but is it bad?
Sorry for English, my Dutch aint good yet. Commenting in dutch is fine, i can understand it quite allright
Thank you, lovely Dutchies :)F
  • mitsumark
  • Laatst online: 09:10
#ProductPrijsSubtotaal
1Intel Core i3-4170 Boxed€ 113,95€ 113,95
1ASRock H81M-HDS€ 48,95€ 48,95
1Club 3D Radeon R9 270 royalQueen€ 147,-€ 147,-
1Fractal Design Core 1000 USB 3.0€ 32,95€ 32,95
1Crucial Ballistix BLS2CP4G3D1609DS1S00CEU€ 40,-€ 40,-
1be quiet! System Power 7 350W€ 37,95€ 37,95
1Crucial BX100 250GB€ 79,95€ 79,95
Bekijk collectie
Importeer producten
Totaal€ 500,75
Net iets te duur, je zou de SSD kunnen vervangen door een HDD (ook als je meer opslag nodig hebt).
Je zou dan ook zelfs kunnen kijken naar een 270X of 950.
Eventueel kun je kijken naar een tweedehands videokaart voor 100-125 euro (7950/7970/280/280X), denk dan wel aan een 400-450W voeding.
  • JoepD
  • Laatst online: 07-10 18:20
It is very convenient if you add all of the components to a "wishlist" (Dutch: wenslijst) and put that list in your topic post. It shows prices and also where you should buy everything, which will save you some money. Please see this small guide about that: Handleiding Pricewatch.
About your components: Given a 500 euro budget, I can advise to look for a second-hand graphics card. It really is a good option to get a lot of computing power at a good price. The Tweakers market place (http://tweakers.net/aanbod/) is good place to start and you're likely going to find what you need.
Usually a AMD build is suited for this kind of money, but I'd rather advise a Intel i3 build (based on this information). This allows you to upgrade to a much faster cpu in a couple of years, for a relatively low amount of money. The drawback is that it only is a dual core cpu, but it should work just fine for you. It also consumes less power and dissipates less heat. Let's wait and see what other forum members have to say on this. ;)
This is what I came up with. This allows for a second-hand HD 7950 or 7970, which leaves you with a very powerful pc (and very upgradable) for the money. Also, you should think about storage. If you can do with 250GB, you really should get the Crucial ssd that I suggest below. It makes everything so much faster. Cheap traditional hdd's are just considered to be very slow.
1ASRock B85M Pro4€ 61,95€ 61,95
1Cooler Master N300 (KKN1, closed)€ 37,95€ 37,95
1Antec VPF Series 450W€ 49,95€ 49,95
Bekijk collectie
Importeer producten
Totaal€ 383,75
[ Voor 3% gewijzigd door JoepD op 21-09-2015 02:18 ]
  • Tribits
  • Laatst online: 12-10 02:20
Tribits
Onkruid vergaat niet
JoepD schreef op maandag 21 september 2015 @ 02:10:
Linkjes op Tom's hardware bevatten een komma en werken daarom alleen op Tweakers als je er aanhalingstekens omheen zet: Toms hardware: Best Gaming CPUs For The Money: June 2015.
Door te kiezen voor een H81 kan je nog iets besparen, maar de prijsverschillen zijn klein en je levert er sowieso altijd twee memory slots voor in. Verdere besparingen zijn eigenlijk lastig. Een lichtere voeding maakt dat je wellicht te weinig vermogen hebt voor een wat oudere en minder zuinige videokaart. Een kleinere SSD bespaart wel iets maar biedt relatief weinig waar voor zijn geld.
De keuze voor CPU is in deze prijsklasse altijd lastig, zeker als je de laatste games wilt spelen die volgens spec een quad core nodig hebben. Daarmee kom je in principe automatisch bij AMD uit, maar in de praktijk is dat een weinig populaire keuze omdat die processoren juist single core weer matig presteren en dus nog al eens tegenvallende prestaties leveren bij wat oudere games. De i3 heeft als voordeel dat de software vier cores ziet (twee cores met hyperthreading) en voor zover ik weet alles wat volgens spec vier cores nodig heeft er ook wel op draait. Puntje blijft echter wel dat het een dual core is en de rekenkracht daarmee achter blijft bij een echte quad core als de i5-4460 en zijn snellere soortgenoten. Maar goed, als je die er in zet houdt je met dit budget ongeveer nul euro over voor een videokaart, en in die prijsklasse is er doorgaans niet zoveel te vinden 8). Upgraden naar een i5 kan met dit moederbord inderdaad, maar dan zal je alsnog een 180 euro extra moeten investeren plus dat het de vraag is wat de prijs van socket 1150 processoren in de toekomst gaat doen. Het is nu in principe al de vorige generatie en over een paar jaar zullen ze wel grotendeels van de markt verdwenen zijn.
Master of questionable victories and sheer glorious defeats
Thank you all for your comments. Was able to understand all Dutch.
Thanks Joep, for the wishlist feature. will use in the future :)
Mitsumark's setup looks good, with the R9 270. Although it will end up slightly above my budget (I like it to be more near to 400 than 500, but maybe i'll just have to drop that)
Did some research on the R9 270 vs the 950ti and the R9 270 came out best. (Is this correct?)
I'd rather not buy a GPU via Marktplaats or any secondhand site to be honest since I don't know if the previous owner treated it with care. Plus it will take a more powerful PSU.
Speaking about the PSU; I'm afraid i could fry my pc components with a cheap, low power PSU. (happened to a friend of mine in the past). Mitsumark selected a 350W PSU which costs 38 euro, will this be enough? (and safe?).
The 250GB SSD will do I guess, knowing I could always upgrade (right?) or connect an external HDD.
I'd rather have more, but I know a SSD is much faster and I don't want to spend more on that particular component.
And do I need to spend more money on a better case? I know bigger ones have better airflow.
Im not familiar with building my own PC's, yet I think tutorials will do just fine to make it work.
Once again, hartstikke bedankt for your time and knowledge _/-\o_
(BTW, what do you think of the PC i mentioned?)
  • Ardjee
  • Laatst online: 12-10 11:06
I wouldn't go with the system you showed in your opening post. The problem with pre build systems is that you have no influence on the quality of the used components in the system.
Also, day Z is very dependand on single thread performance: something intel cpu's beat the AMD ones by miles.
If you want to get closer to the 400 euro mark instead of the 500, i would recommend mitsumark's sytem, can the SSD and relace that with an HDD. That way you save around 40 euro's.
If you want to be able to upgrade more in the near future i would replace the PSU mitsumark recommended with an antec vpf 450: that PSU has enough 6+2 pci-e molexes to power pretty much any high end gpu withouth issues.
So the 38 euro 350W will not kill my pc? (with solely those components, no upgrades)
If I would like to upgrade, I'd have to upgrade the PSU as well.
What will go faster if I'd buy the SSD instead of the HDD? Like, copying things from folder to folder or more than that? (Like ingame features)
And besides all the things Mitsumark mentioned, is there anything else I could need?
- Zo veel vragen, sorry. Im not that much of a knowitall when it comes down to computers. I do know the basic hardware things but thats all.
  • JoepD
Tribits schreef op maandag 21 september 2015 @ 02:40:
Bedankt voor de tip. :)
Ik denk dat die Pro4 zijn 1-2 tientjes extra geld wel waard is. Betere audiochip, PCI-e x16 3.0, CrossFire en ik vermoed allround ook wat hogere kwaliteit. En inderdaad ook 4 geheugenslots, al is dat geen probleem (gewoon 1x8GB nemen in het geval van 2 slots).
Als je ziet dat i5-2xxx en i5-3xxx nog heel hard gaan op Marktplaats/V&A, dan kun je denk ik wel concluderen dat over een paar jaar de i5/i7-4xxx cpu's voor een lekkere prijs van eigenaar wisselen en nog steeds een goede keuze zijn voor een game pc. Afhankelijk van de ontwikkelingen in de gameindustrie uiteraard.
Verwijderd schreef op maandag 21 september 2015 @ 13:25:
That 350W psu should do just fine if you get a R9 270. Please keep in mind that if you are upgrading to a more powerful graphics card in the future, chances are that you're not going to cut it with 350W. I recommend to get at least a 450W psu, like the pricewatch: Antec VPF Series 450W.
In my opinion, you should reconsider buying a second-hand graphics card. Maybe it's not a good idea to get it from Marktplaats, but you could say that it is reliable to get one from a Tweakers seller with a high seller rating. A good example at this moment: V&A aangeboden: Sapphire Radeon HD 7950 3GB GDDR5 With Boost.
JoepD schreef op maandag 21 september 2015 @ 13:52:
Dankjewel. So this GPU's performance is a lot better compared to the R9 270? And will it still be in 2-3 years?
I don't want to buy a second-hand gpu that breaks or loses its performance power within a year(or 2) so thats why i'd like a new one.
However, if its completely safe and durable as a new one its better to buy that second-hand indeed. (With the 450W)
  • JoepD
You can check here to see if you think the extra power is worth it. Second-hand buying unfortunately is never completely safe, but I think it's worth a shot. I guess that highly rated members of Tweakers take good care of the hardware that they are selling. :)
[ Voor 4% gewijzigd door JoepD op 21-09-2015 14:49 ]
JoepD schreef op maandag 21 september 2015 @ 14:49:
Okay, thanks.
I just don't want to end up buying a new GPU in a year or so because it broke. (I'm always sceptical about these things). The one you provided a link of looks good by the way, is it that much better than the R9 270?
It gets higher framerates but it also gets hotter, which could be affecting the durability since its a second-hand.
[ Voor 8% gewijzigd door Verwijderd op 21-09-2015 15:00 ]
  • Ardjee
The bequiet! 350 watt PSU is an allright PSU for what you pay, but it lacks the cables for upgrading the GPU to something fancy (like a r9 380 or 390) If you don't plan to upgrade anytime soon it's a safe bet, if you are willing to upgrade in a short while, it's worthwhile spending the extra 10 euros for the VPF 450.
SSD's are faster than HDD's. Especially when reading/writing small files. In practice: this means if windows in installed on your SSD you will boot your pc significantly faster. Also: some games will load a lot faster when installed on a SSD instead of an HDD. Other games don't profit as much from an SSD.
Personally i see an SSD as a luxury part of an pc: if there is budget free for an SSD it's worth it. but if you want to play some games on a pc on a budget below 700 euro's, i would scrap the SSD first. (my personal recommendation, not everyone is going to agree with me on this point)
If you are scared to buy any second hand parts i can understand, and the r9 270 isn't going to dissapoint.
Ardjee schreef op maandag 21 september 2015 @ 14:58:
Im agreeing with you on this one. Rather have a cheaper build (or more memory) than faster loading. a HDD will do.
The higher framerates on the Radeon card Joep mentioned are tempting, yet I'm still not sure.
I don't expect a high-end pc with a budget of less than 500 euro. I just want something I can enjoy gaming on in a nice, decent quality. Say World of Tanks with settings up to high, maybe some to medium. Ofcourse with the ability to upgrade in the future.
Im closer to choosing the R9 270 over the second-hand Sapphire Radeon HD 7950 3GB GDDR5 With Boost.
  • Tribits
Tribits
Vanwaar overigens de R9 270? Zo te zien gaat die zo langzaam aan richting EOL en de R7 370 kost ongeveer hetzelfde. Veel zullen ze elkaar niet ontlopen maar de R7 370 is toch net iets sneller.
En ik ga lekker door in Nederlands want dat schijnt TS prima te begrijpen en zo biedt het een mooie kans om wat te oefenen. Just let me know if you prefer English after all.
[ Voor 0% gewijzigd door Tribits op 21-09-2015 16:12 . Reden: R7 270=R9 270 ]
Tribits schreef op maandag 21 september 2015 @ 15:51:
Vanwaar overigens de R7 270? Zo te zien gaat die zo langzaam aan richting EOL en de R7 370 kost ongeveer hetzelfde. Veel zullen ze elkaar niet ontlopen maar de R7 370 is toch net iets sneller.
My Dutch reading is fine, I can understand most of it and if you got some parts of a sentence, it pretty much fills in the rest. Things I really don't know I ask others or look it up. Just when it comes down to making up the sentences myself it takes a long time, so I prefer talking in English. Gonna do a cursus soon!
Ik zie multiple people mentioning de R9 270 als de beste choice voor low budget computers.
(Otherwise you get this^, took me some time).
If however you got other ideas about setups, please do share!! :D
-edit- Budget is around 450, without the OS. And im not buying before im 1000% sure about the setup (+ I still got about a month before I can buy)
[ Voor 6% gewijzigd door Verwijderd op 21-09-2015 16:05 ]
I see you referred the R7 270, I don't know whether you misread it but I meant the R9 270 :)
BTW, wat is EOL?
  • Tribits
Tribits
Het is in principe dezelfde kaart als de R9 270, alleen heeft AMD de gewoonte om zijn kaarten af en toe een beetje te tweaken en dan gelijk een ander naampje te geven (rebranden dus). Dat hebben ze nu dus ook weer gedaan en zo is de R7 370 de opvolger van de R9 270 geworden. Geen schokkende verschillen, maar als de prijzen gelijk zijn dan heeft de R7 370 wat mij betreft de voorkeur. pricewatch: MSI R7 370 2GD5T OC
EOL=End Of Life (in goed Nederlands :P), en verder: foutje van mijn kant, het was dus de R9 270 en wordt de R7 370.
[ Voor 18% gewijzigd door Tribits op 21-09-2015 16:11 ]
Tribits schreef op maandag 21 september 2015 @ 16:07:
Dankjewel voor de link.
I was searching it myself already and noticed all kinds of R7 370's, whats up with that?
Club 3D Radeon R7 370 royalQueen
Asus Strix Radeon R7 370 DC2
Sapphire Radeon R7 370
And the MSI R7 370 2GD5T OC you mentioned.
Looking at the pictures, they differ a lot ;)
  • Koen179
  • Laatst online: 12-10 21:50
They are from different brands, but the videochip is in all of them the same. What you have to look for is if they are quiet and still can cool the card well (read reviews about the different cards). In general, MSI is a brand that produces quiet coolers, so in my opinion that would me my choice (unless you are about to overclock a lot ;)).
Good luck with making your choices!
Koen179 schreef op maandag 21 september 2015 @ 16:30:
Thanks Koen! Im not planning on overclocking so I'll go for the MSI if im chosing the R7 370 (Like Tribits suggested already) :)
Will the be quiet! 350W PSU be enough to power the R7 370?
So all the items add up to this
1MSI R7 370 2GD5T OC€ 152,95€ 152,95
1Seagate Desktop HDD ST1000DM003, 1TB€ 46,95€ 46,95
Bekijk collectie
Importeer producten
Totaal€ 473,70
Yet I'm not sure about the case.
[ Voor 95% gewijzigd door Verwijderd op 21-09-2015 16:55 ]
  • RobinHood
RobinHood
Ja, moet genoeg zijn. Neem anders de iets duurdere 400w, om het op safe te spelen.
  • Baloes
  • Laatst online: 10-10 16:45
Dit zou anders ook nog kunnen :
1Gigabyte GA-H81M-S2H€ 45,95€ 45,95
1MSI Radeon R9 270X HAWK€ 169,-€ 169,-
1BitFenix Neos Zwart/Zwart€ 32,95€ 32,95
1Crucial CT102464BA160B€ 38,95€ 38,95
1be quiet! System Power 7 400W€ 41,95€ 41,95
Bekijk collectie
Importeer producten
Totaal€ 489,70
De 270x is stuk sterker dan de r7 370 en de Neos behuizing is een prima budgetkast die voorzien is van stoffilters op alle intake-lokaties.
1 reepje RAM om uitbreiden later makkelijker te maken.
Prima voeding van 400 watt met 2 PCI-E aansluitingen..
Incl. verzendkosten kom je dan op 499,55 euro :)
Wat trouwens ook nog een optie is is dit : http://www.marktplaats.nl...e656940d2&previousPage=lr
Dit is gewoon een prima winkel die kaarten die niet voldeden aan de verwachting van de klant, opnieuw verkoopt.
Kaarten zijn getest en goed bevonden door de shop.
Hier win je 31 euro mee waardoor je geld overhoudt voor andere dingen..
Volgens mij wanneer je dan bv. toch de SSD neemt kom je op 501,55 euro...
[ Voor 9% gewijzigd door Baloes op 21-09-2015 18:37 ]
  • DanielWillems
  • Registratie: Maart 2014
  • Laatst online: 06-06-2024
Waarom gaan we eigenlijk niet met een Pentium G3258? Ook een prima chip en als je hem gaat overklokken, wat nu op bijna elk B85 kan met een bios update houdt hij de I3 zeker weten bij. Dat spaart ook weer +/- 30 euro
  • Baloes
Omdat je met de i3, die door z'n hyperthreading herkent wordt als quad core, je iig zeker weet dat je alle games zult kunnen spelen terwijl dat met de pentium niet het geval is..
Baloes schreef op maandag 21 september 2015 @ 17:21:
Bekijk collectie
Importeer producten
Totaal€ 489,70
Thank you a lot for this setup!
The MSI Radeon R9 270X HAWK will be the GPU of my choice :D
Also, the Neos case seems allright as well.
I see you chose another motherboard, can you explain why?
  • Baloes
Goedkoper en toch een betere geluidschip. Verder dezelfde specs. Heeft een iets betere layout. Bij de Asrock staat tegenwoordig in de specificaties toch deze waarschuwing : "Let op: bij dual-slot videokaarten langer dan +/- 18 centimeter kan de frontpanel header in de weg zitten."
Maarreh, niet geinteresseerd in die aanbieding van coolblue op marktplaats?
Scheelt je 30 euro en Coolblue geeft er op 3 maanden na volledige garantie op.
Well, I'm not completely comfortable with a product someone sent back. It also says in the description 'No direct damage visible' which concerns me a bit.
  • Baloes
Gewoon doen waar je jezelf het fijnste bij voelt en op zich is die MSI een prima kaartje. Mijn zoon heeft dezelfde en speelt alles wat los en vast zit zonder problemen :)
En hoe weet ik dat everything will fit in the case and the motherboard?
It would be a bummer if I'd buy it all and stuff won't fit in.
Is this the best <40 euro case available?
Looking at reviews, people have problem with its cable management.
Since Im not a computergenius and i'll have to install this all by tutorials and this might become a problem.
  • RobinHood
RobinHood
Er is idd niet veel ruimte voor kabels, maar geen enkele kast onder de 50 euro heeft echte kabelruimte. Ik heb nu 2x een systeem met die kast gebouwd, en het is naar mijn mening de beste kast van rond die prijs, en al je componenten moeten er prima in passen.
  • Baloes
RobinHood is me al voor :)
Van kasten in dit prijssegment moet je van kabelmanagement idd niet te veel verwachten.. Ik hecht dan meer waarde aan de stoffilters dan aan het feit of de kabels allemaal netjes achter het mobo zitten :)
RobinHood schreef op maandag 21 september 2015 @ 19:42:
Baloes schreef op maandag 21 september 2015 @ 19:46:
Thanks a lot! :)
You think I'll be okay installing everything myself with tutorials?
-edit-:
This is completely optional, but is the BitFenix Comrade Window Zwart the same on the inside, (airflow etc) as the Neon? It has a window which I find good-looking :)
pricewatch: BitFenix Comrade Window Zwart
[ Voor 15% gewijzigd door Verwijderd op 21-09-2015 19:56 ]
  • Terrie
  • Laatst online: 11:39
Terrie
Titelspecialist Tweakers Partners
De n300 is een uiterst degelijke kast met prima cable management.. En de bitfenix is ook prima case, en de kabels heb je echt geen last van als je het een beetje slim aanpakt.
[ Voor 45% gewijzigd door Terrie op 21-09-2015 20:00 ]
  • RobinHood
RobinHood
Verwijderd schreef op maandag 21 september 2015 @ 19:49:
Thanks a lot! :)
-edit-:
Ik denk het wel, anders staan er ook nog genoeg filmpjes op youtube.
De Comrade is gewoon de Neos, maar dan met een ander frontje erop, je kan ook kijken aar de pricewatch: Sharkoon VS4-W Window welke wat goedkoper is.
De N300 is opzich niet beter of slechter dan een Neos of Comrade, da's gewoon smaak.
RobinHood schreef op maandag 21 september 2015 @ 20:07:
Okay erg bedankt. Then it'll be the Comrade or the Neon
Don't I need an CDdrive for installing drivers and such? :9
  • RobinHood
RobinHood
Ik heb ze bij de installatie van W10 in ieder geval niet nodig gehad, en volgens mij download W8 ook automagisch alle benodigde drivers, en drivers van je LAN poort zitten dan gewoon inbegrepen in het OS.
En anders is het vaak makkelijker om een stickie te gebruiken, ik heb al bijna 2 jaar geen DVD speler meer in mijn pc, en ik heb 'm geen seconde gemist.
'automagisch' I like what you did there :)
I recently received a free Win10 Education serial code via the education im doing now.
Got a few questions about that one that I havent been able to figure out.
Will that limit me to anything? Like is it worse than Home or Pro?
Or will it add annoying stuff to my OS? Cause I'd like to use it for everything BUT Educational purposes :)
I also received the Win10 update on my old win7 pc, but I don't think i can just install that on a new pc, can I?
Bedankt voor alle je hulp
-Edit-
Plus, The Neos and Comrade cases come with only 1 of 3 120mm fans, should i get another one (in the front) to improve airflow and coolness?
[ Voor 12% gewijzigd door Verwijderd op 21-09-2015 22:00 ]
  • RobinHood
RobinHood
Volgens mij is W10 Education gewoon Pro met een andere naam, het zou nogal apart zijn als je opeens geen Steam meer kon installeren :+ Ik heb her en der wel gelezen dat hij maar 1 jaar geldig is, ik denk dat in het W10 topic daar wel ergens wat over te vinden is: [Windows 10] Ervaringen & Discussie - Deel 2 of [Windows 10] Installatie en Upgrade Uitdagingen, ik denk als je daarin zoekt op "education" het vast wel te vinden is.
De update op jouw oude pc is maar een update, wel kun je, tenzij je een OEM licentie hebt, je oude W7 licentie op je nieuwe PC gebruiken, en dan gebruik maken van de gratis update, mits je je oude pc dan niet meer gebruikt met die licentie.
Een extra fan, tja, het hoeft niet met een systeem als dit, maar als het budget het toelaat, is een van de volgende fans een prima keuze:
pricewatch: Fractal Design Silent Series R3, 120mm
pricewatch: Thermalright X-Silent, 120mm
pricewatch: Scythe Slip Stream 800rpm, 120mm
pricewatch: Gelid Solutions Silent 12 PWM, 120mm
pricewatch: Enermax T.B.Silence Fan UCTB12 - 120mm, 120mm
Qua prestaties zullen ze niet voor elkaar onder doen, gezien je een kast met raampje neemt, kies de mooiste uit, en je zit gebeiteld.
  • mitsumark
R7 370 is een 7850 met iets hogere kloksnelheid.
R9 270 is een 7870 met iets lagere kloksnelheid, ik denk toch dat ie iets sneller is dan de R7 370, en daar bovenop sowieso veel beter overklokbaar.
(R9 270X is een 7870 met iets hogere kloksnelheid)
Allemaal prima kaarten voor een 500 euro game pc overigens.
[ Voor 3% gewijzigd door mitsumark op 21-09-2015 22:36 ]
  • Tribits
Tribits
Zie ik toch anders:
7850/R9 270/R7 370=Pitcairn PRO/Curaçao PRO/Trinidad PRO
7870/R9 270X=Pitcairn XT/Curaçao XT
Maar goed, echt spectaculair zijn de verschillen inderdaad niet.
  • mitsumark
Wat heeft Pro/XT ermee te maken?
Een R5 235, 7670, 7970 en 290X zijn ook allemaal XT (en vast nog wel meer), maar die hebben absoluut geen relatie met elkaar.
7850: 1024 stream processors @ 800MHz.
265: 1024 stream processors @ 900MHz.
370: 1024 stream processors @ 975MHz.
7870: 1280 stream processors @ 1000MHz.
270: 1280 stream processors @ 900MHz.
270X: 1280 stream processors @ 1000MHz.
370X: 1280 stream processors @ 1100MHz?
Allemaal GCN1.0 architectuur, verschillen binnen de groep zit hem in de kloksnelheid (en evt geheugen).
Uiteraard zijn er merken die hem standaard overklokken (vanuit de fabriek).
De R7 370 is geen rebrand van de R9 270(X)/7870, wel komt hij qua prestaties redelijk mee met een 270@900 vanwege zn iets hogere kloksnelheid.
Klok voor klok zijn de 1280 stream processors simpelweg 15% sneller.
[ Voor 37% gewijzigd door mitsumark op 22-09-2015 01:56 ]
Dat gaat mij de pet te boven (googled that)
1BitFenix Comrade Window Zwart€ 36,51€ 36,51
Bekijk collectie
Importeer producten
Totaal€ 493,26
So this is what its probably gonna be, unless I should reconsider some other components?
It'll end up slightly above 500 but I guess i'll have to deal with that.
  • Xthemes.us
  • Laatst online: 11-10 23:48
Videokaarten gaan niet zo snel kapot. Als ze vanaf de fabriek af het goed doen (geen artifacts etc) dan is het enige probleem dat ik gezien heb die zich tijdens gebruik kan voordoen dat de capicators opblazen. Als je zorgt dat je een videokaart kies met goede kwaliteit capicators (zijn ze vrijwel allemaal tegenwoordig zover ik wet) kan je je er geen build aan vallen. Zeker niet als je gewoon een tweede handse kaart haalt waar nog (voor een lange tijd) garantie opzit.
Ik zie bijvoorbeeld een Club3D R9 280 in Vraag & Aanbod staan voor €130.
Een aardige stop vooruit ten opzichte van de 270x in je post en nog goedkoper ook. Misschien dan wel voor een net iets krachtigere voeding gaan aangezien volgens hardware.info een R9 280 wel tot 322 watt kan trekken.
Ik zou aanraden die vraag in het voeding advies topic te stellen als de videokaart je interessant lijkt.
MSI GX640 - 8GB RAM, Radeon 5970, 80GB SSD
  • RobinHood
RobinHood
Dat stroomverbruik is van het hele systeem, maar, een VPF450 is dan idd wel aan te raden, wat beter dan de BQ, neem je een 270/370, dan is die BQ prima.
Xthemes.us schreef op dinsdag 22 september 2015 @ 12:43:
Dankjewel voor je reply.
Im just not that comfortable with buying a second-hand graphics card. This could be just me but I'm always sceptical about those things. I wouldn't feel as comfortable with it as with a new one.
RobinHood schreef op dinsdag 22 september 2015 @ 12:45:
Is the BQ good enough for the 270x as well?
  • RobinHood
RobinHood
Jep, moet goed gaan. Verschil in verbruik is niet denderend.
RobinHood schreef op dinsdag 22 september 2015 @ 12:55:
Okay, thanks.
Will I be needing anything else but these components in my wishlist? for ex. are all the cables included? (like the psu cable). Sorry if this sounds dumb but im 100% new to building a pc myself.
  • RobinHood
RobinHood
Bij alle voedingen die ik gekocht heb zat de kabel er gewoon bij, zowel bij "dure" seasonics als bij de goedkope 300w versie van die BQ, dus dat moet wel snor zitten.
Bij het moederbord krijg je waarschijnlijk 2 SATA kabels, en bij de kast zitten natuurlijk alle schroefjes, en op de koeler zit al wat koelpasta.
Moet goedkomen.
Hold up, koelpasta? I have never heard of that one before. Thought I misread it at first :)
- Just googled it. You mean it's already placed on the cooler for the CPU?
I don't think I'll need more of it, do I?
-edit-
http://pad2.whstatic.com/...aste-Step-1-Version-2.jpg
Stumbled upon this picture as I searched what thermal paste is. It made my day. :+
[ Voor 34% gewijzigd door Verwijderd op 22-09-2015 13:16 ]
  • RobinHood
RobinHood
ja, er zit gewoon al voldoende op. Extra bijkopen is niet nodig.
En koelpasta/koelprut is Thermal Paste, wat een pasta is, en koelt, dus koelpasta :+
  • Xthemes.us
Ik heb het zelf vaak ook niet zo op tweedehandse dingen maar bij videokaarten (en smartphones trouwens ook) dan juist weer wel. Mensen willen daar graag altijd het nieuwste hebben waardoor ze perfect werkende videokaarten (of smartphones) verkopen die nog een lange garantie periode hebben.
Maar goed, als het jezelf een beter gevoel geeft dan gewoon de boel nieuw halen. Bij een geheel nieuw systeem weet je dan in ieder geval zeker dat eventuele vervanging voor een DOA snel geregeld is.
Koelpasta = Thermal Compound, or Thermal Paste. Breng je aan op de CPU maar in dit geval zal het al van te voren op de boxed CPU koeler zijn aangebracht. Hoef je je dus geen zorgen over te maken. Volgens de manual van gigabyte zitten er 2 SATA kabels in de doos dus het enige wat je nodig hebt is een kruiskopschroevendraaier (phillips screwdriver).
[edit]
Als het de eerste keer is dat je een PC bouwt dan heeft hardware.info wel een handig guide voor je. Zowel in geschrifte als in video.
[ Voor 11% gewijzigd door Xthemes.us op 22-09-2015 13:23 ]
RobinHood schreef op dinsdag 22 september 2015 @ 13:16:
Thanks.
Hopefully this is one my final questions, as we reach the 3rd page on this topic already.. :$
When checking the Win10 serial key eligibility on the Microsoft website, the 3rd step to downloading your Windows file said something like Kies 32-of 64-bit versie van Windows. It's something with the CPU isnt it?
  • RobinHood
RobinHood
Ja, zoiets, het gaat erom of je een 32btis systeem of een 64 bits systeem hebt, maar het is al jaren allemaal 64bit, 32bit komt nog uit het Pentium 4 tijdperk.
Xthemes.us schreef op dinsdag 22 september 2015 @ 13:20:
Thank you a lot for that, will bookmark!
-BTW, DOA is Dead On Arrival right?
  • Xthemes.us
DOA is inderdaad Dead On Arrival, hopelijk krijg je daar niet mee te maken anders moet je een RMA aanvragen ;) (Return Merchandise Authorisation).
En wat RobinHood al zegt, inderdaad 64 bits kiezen, vrijwel alle CPUs ondersteunen dat tegenwoordig (en die welke je hebt gekozen is ook een 64-bits CPU) en het zorgt ervoor dat je meer dan 4GB RAM kan gebruiken als ook een kleine performancewinst in sommige gevallen.
[ Voor 6% gewijzigd door Xthemes.us op 22-09-2015 13:31 ]
Xthemes.us schreef op dinsdag 22 september 2015 @ 13:29:
En wat RobinHood al zegt, inderdaad 64 bits kiezen, vrijwel alle CPUs ondersteunen dat tegenwoordig en het zorgt ervoor dat je meer dan 4GB RAM kan gebruiken als ook een kleine performancewinst in sommige gevallen.
Allright, dankjewel.
Just looked into the hardware.info site, great detailed explanation. That'll work out :)
-edit-
Stap 7 Processorkoeler monteren
CPU's don't come with a cooler when you ordered them, do they?
[ Voor 8% gewijzigd door Verwijderd op 22-09-2015 13:44 ]
  • Johan9711
  • Laatst online: 10:33
Johan9711
Verslaaft aan Tweakers
Verwijderd schreef op dinsdag 22 september 2015 @ 13:32:
-edit-
Boxed processors hebben bijna altijd een koeler, alleen bij sommige skylake processors niet, maar dat is hier niet van toepassing.
Koeler zit er dus bij
Mijn tweakblog: http://johan9711.tweakblogs.net/
Johan9711 schreef op dinsdag 22 september 2015 @ 13:53:
Thanks Johan!
-edit-
I was looking up the benefits of having a 3rd party CPUcooler (Which I don't think I need with this CPU)
Stumbled upon this bit here
Ter referentie Hoogte Geluid Low Speed High Speed
Intel standaard Boxed koeler 57mm 32 / 46 dB(A) 95+ / 95+ °C 63,2 / 75,7 °C
Wait... 95 graden? :|
Isn't that like.. a lot..
Or does it get much hotter without one?
[ Voor 41% gewijzigd door Verwijderd op 22-09-2015 15:06 ]
  • Koen179
In normal use, a CPU would never get to 95 degrees celcius. Only if you are going to overclock to the extreme maximum it is possible (definitely not recommended!). It's true that Intel stock coolers become hotter quicklier, but it stays far below 95 degrees celcius (most of the time between 30-50, which is a acceptable temperature).
So to sum it up: the Intel stock cooler is good enough if you dont mind a little bit more noise and you are not going to overclock the CPU :).
Koen179 schreef op dinsdag 22 september 2015 @ 15:29:
Dankjewel Koen. I won't be overclocking it, so I guess thats safe.
How comes this information says 95 degrees? Perhaps I misread something about the CPU they are using.
As long as the cooler doesnt make the CPU hotter (but that would be strange, wouldnt it :+ )
  • Koen179
Haha, you did not misread it! But I think in the test they have stressed the CPU (maximal performance, the CPU gets hotter then normal), which complains the extremely high temperature. As I said before, this is not in normal use the case, so you don't have to worry about this ;).
And yes, a CPU cooler is there to keep the CPU cool. Without a CPU cooler the computer will not start (to prevent damage to the CPU).
Gelukkig! :)
I'm getting close to buying it all, will be in the next few days.
Now it comes down to selecting a bedrijf voor mijn order
Following are my options:
I don't know if you can open and view this: http://tweakers.net/pricewatch/bestelkosten/787370
otherwise, here's an image.
Looking at Megekko's shop reviews, not too excited about that one.
Bad klantenservice and some cases of DOA.
Have you guys got a better idea, or good experiences with other shops?
Wouldn't want it to be getting too expensive..
  • Ketho
  • Laatst online: 03:47
I personally would vouch for Azerty, and then Afuture and Alternate in that order, from personal experience.
No idea about Megekko and 4AllShop.
Ketho schreef op dinsdag 22 september 2015 @ 20:29:
Afuture looks good indeed.
Can you open the bestelkosten link I provided?
When you click Afuture, I see they also need to get a few things from SiComputers (The case, PSU and HDD). How does that work?
  • br00ky
  • Laatst online: 07:50
br00ky
Just manually add everything to your winkelmandje in the respective stores, nothing too complicated ;).
  • Ketho
Yes, we can open the (bestelkosten) link you provided.
If you meant you'd rather not order from e.g. SiComputers, you can ignore (negeer) webshops in the filters.
  • Koen179
Grappig om te zien hoe Engels en Nederlands hier met elkaar vermengt wordt :P.
Koen179 schreef op dinsdag 22 september 2015 @ 20:48:
Haha, I'm not that good speaking Dutch, yet understanding it is fine.
With 500 euro on the line I'd rather speak English in which im able to express myself better. ;)
br00ky schreef op dinsdag 22 september 2015 @ 20:34:
Thank you. I just like to be sure of everything before spending such amount of money.
Ketho schreef op dinsdag 22 september 2015 @ 20:44:
Gotta check out SiComputers first, but im considering solely Afuture and Alternate.nl
  • RobinHood
RobinHood
Het is soms ook gewoon een kwestie van geluk of pech. heb bijv. meerdere keren bij Pixmania besteld zonder problemen, Ook SI ging vroeger prima, en juist altijd als ik bij Azerty bestel is het heibel ["ja, we zijn dat scherm vergeten op de Post-NL kar te doen, misschien dat hij maandag erop kan" en andere lulligheden]
Mijn favoriete shops zijn toch wel Afuture en Megekko, Inmiddels is er al heel wat geld naar allebei die shops gegaan, en het is altijd zonder problemen, op tijd, geleverd.
RobinHood schreef op dinsdag 22 september 2015 @ 22:02:
They forgot? thats unfortunate..
Yeah, Megekko? I read reviews that said if somethings not right, the customer support could be a pain in the err.. behind.
Ofcourse I'd like the cheapest, yet I also want quality service.
It's 508 at Megekko, Afuture and SI.
515 at Afuture and SI. < So this is also a good option.
Going to check out SI and it's reviews right now.
  • TomGroenewegen
  • Laatst online: 04-10-2025
Imo megekko is a great shop, I order my pc at Megekko, no complaints at all
SI looks fine to me, as long as the quality of the product and the customer service are okay.
Which are both good as I'm seeing right now.
TomGroenewegen schreef op dinsdag 22 september 2015 @ 22:22:
When I see a shop that sneakily wants you to pay for a DOA product shipment cost which is against the law im not ordering anything. And when you mention that law they suddenly cover the costs.
They're just trying to make you pay for it.
However, this is 1 review. Some are good, some aren't.
-edit-
Plus, I understood they don't have a phone. Alle moet via mail. Not a big fan of that one.
[ Voor 7% gewijzigd door Verwijderd op 22-09-2015 22:28 ]
  • TomGroenewegen
Jep, Just do what you think is best, good luck with building your pc :)
Dankjewel Tom! Looking forward to it :)
I think Afuture and Sicomputers are going to be it.
Which brings the total to 515 euro.
Guess I'll be ordering tomorrow :)
Just ordered everything and I'm super excited about it. oOo
Big thanks to everyone here who helped me out. :Y
Guess now comes.. wachten! :7
After that, assembling everything and praying it all works.
^subject koelpasta.
Is that thermal paste good quality? My mate says it probably won't be that good and I can better buy some myself.
  • mitsumark
It is OK to use for non overclocked systems, of course it could be better but you don't need it.
In the end it will be probably less then 5 degrees difference in load between stock and good paste.
Thanks everybody who helped me out on this setup & my questions.
Building it wasn't too complicated, everything fitted well and worked out fine :)
I got World of Tanks running @ 55-70 with almost everything maxed out.
CPU temp at 50-60c playing with those settings.
GPU is about 60-65c at that (full) load.
I'm super happy with this pc, being a very good game pc for just 500 euro.
Thanks everybody <3
Ik zoek een?
CPUcooler for my i3-4170
Wat is je budget?
15-20eu
Specificeer het systeem en de omgeving waarin je het product gaat gebruiken.?
1Intel Core i3-4170 Boxed€ 116,20€ 116,20
1Seagate Desktop HDD ST1000DM003, 1TB€ 46,50€ 46,50
1Crucial CT102464BA160B€ 37,95€ 37,95
1be quiet! System Power 7 400W€ 43,-€ 43,-
Bekijk collectie
Importeer producten
Totaal€ 495,11
The case(mid tower i think) got one 120mm fan on the back (mobo only got 1 sys fan input)
Currently got the stock cpu cooler in it, which cools it to about 55-70c when playing games.
^ link above isn't 100% the one I got, I don't have the copper backplate
I'm not very sure if 70c at load is OK but I like it to be cooler. I also don't think thats at full load.
So anyway, does anybody know a good cpu cooler, which fits the case?
I'd like one that just clicks in like the stock cooler, since I don't really want to get my motherboard out again
I'm not Dutch, however commenting in Dutch is fine :)F
  • loki504
  • Laatst online: 11:57
20 euro is not alot. And are you going to buy from a Dutch store? And is second hand a problem?
V&A aangeboden: Gelid Solutions Tranquillo Rev.2
Inc shipping with postnl 2 euro above your budget. You can also ask him to send it with kiala then its only 4 euro shipping.
Ofc you can always try to lower the price a bit.
[ Voor 62% gewijzigd door loki504 op 04-10-2015 08:05 ]
  • br00ky
br00ky
Dit kan prima in Game pc for 400-500 euro. Merge.
loki504 schreef op zondag 04 oktober 2015 @ 08:00:
I'd rather not buy second hand. And my budget can bend ;) New that cooler costs 25eu, I would pay that extra 10 euro for it since the secondhand one has operated for 1,5 years.
There probably isn't a decent one that just clicks in like the stock cooler right? Had some bad experiences with cable management and getting my motherboard out twice :/
BTW; ik woon in Nederland, Dutch isn't good yet.
  • br00ky
br00ky
Dan heb je een koeler nodig zonder back-plate, zoals de pricewatch: Cooler Master Hyper TX3 Evo. Zoals je in deze video kan zien, is het een kwestie van aandraaien en klaar. Het moederbord in het filmpje is dan wel uit de case gehaald, maar dit kan ook prima als die er in zit.
br00ky schreef op zondag 04 oktober 2015 @ 09:36:
Thanks, the one you mentioned does look good.
I'm going to try and find some more without the need of a backplate.
Just checking; 70c for a CPU under load isn't bad right? (it idles at 30)
  • mitsumark
Normaal gesproken kun je een koeler met backplate monteren zonder het moederbord uit de behuizing te halen. Er zit namelijk een gat waar de backplate moet komen.
http://content.hwigroup.n...itfenix-comrade-black.jpg
70 graden is nog prima overigens, pas bij continu 90 graden zou ik me lichtelijk zorgen gaan maken.
mitsumark schreef op zondag 04 oktober 2015 @ 15:06:
Oh wow, I'm being a donkey 8)7
Was wondering what that hole was when I was building it.
Thanks again, mitsumark :)
What CPU coolers do you guys use?
