Windows 10 reserveren-knop verschijnt niet in Windows 7 Pro
Ik wil graag Windows 10 reserveren, maar het windows-icoontje die zou moeten verschijnen op mijn taakbalk, om Windows 10 te reserveren, veschijnt niet. Ik heb al verschillende methoden geprobeerd, alle windows updates geinstalleerd, maar niks werkt.
http://www.cnet.com/how-t...rade-icon-if-its-missing/ < geprobeerd
If you don’t see the Get Windows 10 app (the small Windows icon in your system tray), it might be because:
Your device isn’t up-to-date with at least Windows 7 SP1 or Windows 8.1 Update
Windows Update is turned off or is not set to received updates automatically
You’ve blocked or uninstalled the necessary Windows Update functionality.
Your device is not running genuine Windows
Your device is running Windows 7 Enterprise, Windows 8/8.1 Enterprise, or Windows RT/RT 8.1, which are excluded from this reservation offer.
Your device is managed as part of a school or business network. (Check with your IT administrator.)
PCs that we determine cannot run Windows 10 will not see the Get Windows 10 app before July 29th. After July 29th, we’ll enable the icon in the system tray. This is to help ensure that you can easily check your PC’s compatibility if you choose.
Running Windows Update and installing any available updates will fix the first 3 issues.
If you don’t think any of these conditions apply to you, and you’re still not seeing the icon, you can also try running the solution below, which will verify your device meets all the prerequisites and then turn on the Get Windows 10 app:
Open Notepad
Copy the following text and paste it into Notepad:
REG QUERY "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\UpgradeExperienceIndicators" /v UpgEx | findstr UpgEx
if "%errorlevel%" == "0" GOTO RunGWX
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Appraiser" /v UtcOnetimeSend /t REG_DWORD /d 1 /f
schtasks /run /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser"
:CompatCheckRunning
schtasks /query /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser"
schtasks /query /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" | findstr Ready
if NOT "%errorlevel%" == "0" ping localhost >nul &goto :CompatCheckRunning
:RunGWX
schtasks /run /TN "\Microsoft\Windows\Setup\gwx\refreshgwxconfig"
Click File, and then Save As
In the File name box, change the file name to ReserveWin10.cmd
Then click the dropdown next to Save as type, and select All files (*.*)
Select the folder you would like to save the file to. For this example, let’s choose to save the file to the C:/Temp folder. Then click Save.
Open an elevated command prompt. (From the Start screen or Start menu, type Command Prompt in the search box, and then in the list of results, right-click Command Prompt, and select Run as administrator.)
Finally, run the file from the location you saved to in Step 6. In this example, you would type the following in the Command Prompt window and hit Enter:
C:/Temp/ReserveWin10.cmd
The Microsoft Compatibility Appraiser can take 10 – 30 minutes to run, during which the script will continuously provide status reports that it is running. Please be patient.
If the script is failing in an infinite loop, then you don’t have the necessary prerequisite Windows Updates. Besides requiring Windows 7 SP1 or Windows 8.1 Update, you must also have installed:
For Windows 7 SP1:
KB3035583
KB2952664
dat heb ik ook al geprobeerd, en ik voldoe volgens mij aan alle eisen?
Ik heb W7 Professional 64-bit SP1
Ik weet niet of het veel uitmaakt, maar mijn CPU is een i5 4670K, en ik heb 16GB ram
Ik hoop dat jullie me kunnen helpen, ik ben echt radeloos. Hopelijk heb ik een beetje goed uitgelegd, ik ben een beetje nieuw bij de software topics dus ga niet haten.
Mvg
  • Raven
Raven
Marion Raven fan
[Windows10] Ervaringen & Discussie -> topic warning ->
Als je problemen hebt met het verschijnen van de Windows 10 Update Knop in Windows 7 of 8.1, plaats je vragen/opmerkingen dan hier.
-> Geen Windows 10 update knop op bestaande Windows 7 of 8* ;)
Je bent dus niet de enige met dit probleem.
[ Voor 5% gewijzigd door Raven op 13-07-2015 11:59 ]
Oscar Wilde
  • DFS
  • Laatst online: 01-10 20:33
DFS
Ik zag de knop ook niet, kwam door mijn Comodo firewall. Toen ik appraiser.dll en een .exe uit de /Windows/System32/GWX map toegang tot internet had gegeven kreeg ik de volgende dag na een reboot wel het icoontje.
DFS schreef op maandag 13 juli 2015 @ 12:14:
welke exe dan
  • Raven
Raven
Marion Raven fan
Waarschijnlijk GWX.exe, dat proces zie ik nog wel eens genoemd worden als het over die W10-notificator gaat.
Oscar Wilde
  • NeFoRcE
  • Laatst online: 01-10 14:19
NeFoRcE
Hallo? Bent u daar?
M'n broer heeft een patch programma oid gebruikt om 'm tevoorschijn te krijgen. Misschien kun je daar eens naar zoeken :)
  • Umbrah
  • Laatst online: 19:20
Umbrah
The Incredible MapMan
Kregen Pro en Enterprise hem uberhaubt wel? Geloof dat de zakelijke tak juist op andere manieren aangeboden zou krijgen...
Umbrah schreef op maandag 13 juli 2015 @ 12:37:
Pro kreeg het toch wel?
NeFoRcE schreef op maandag 13 juli 2015 @ 12:35:
Laat je broer dat programma dan pls sturen?
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
Verwijderd schreef op maandag 13 juli 2015 @ 12:42:
heb 'm geappt :) als ik meer weet reageer ik hier weer.
Mijn windows 8 pro gebruikt een MSDN key en krijgt ook geen aanbod. Even nagevraagd op de facebook groep van Microsoft en zijn beweren dat MSDN keys geen upgrade krijgen: Wil je win10, haal dan een nieuwe key van MSDN.
Als je zoals ik geen MSDN abo meer hebt is dat best wel vervelend :|
NeFoRcE schreef op maandag 13 juli 2015 @ 12:43:
thanks alvast!
  • belrpr
  • Laatst online: 27-09 22:48
Verwijderd schreef op maandag 13 juli 2015 @ 12:58:
Als je geen abonnement meer hebt dan is uw versie niet meer legaal.
belrpr schreef op maandag 13 juli 2015 @ 14:07:
Nonsens. Je kan geen nieuwe keys meer claimen als je er nog tegoed had voor de expiration, maar je geclaimed keys blijven voor onbepaalde duur geldig.
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
  • belrpr
Verwijderd schreef op maandag 13 juli 2015 @ 14:26:
De geldigheid heeft niet met de legaliteit van de sleutel te maken. Je kan perfect een Windows oem sleutel op een nieuwe computer installeren maar officieel mag het niet.
MSDN sleutels mogen gebruikt worden tot zolang je een abonnement hebt. Er zijn wel een aantal uitzonderingen.
Zelfde met studenten licenties. Je mag deze gebruiken tot zolang je studeert erna niet meer. Toch werken er gewoon verder.
Bij office 365 zijn ze naar een nieuw systeem overgestapt juist om dit soort misbruik tegen te gaan.
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
verschilt per situatie i guess, zou ze gewoon proberen :)
