Hier de bugtracking list van Punikaweb, schijnbaar is Nvidia behoorlijk de mist in gegaan want het web staat er vol mee:
Update 31 (January 15, 2022)
12:20 pm (IST): NVIDIA Shield TV devices have recently been updated to Android. But, this brought some serious issues to its users. Now, Plex server and other apps are reportedly not working.
It should be noted that there is a potential workaround that could help resolve the above. However, there are other issues without workarounds such as broken integration between Android TV and Home Assistant, and broken CEC.
06:35 pm (IST): Some users are now reporting (1, 2, 3, 4) issue with volume control. Users say that the volume up and volume down buttons are not working properly.
Update 31 (January 17, 2022)
11:12 am (IST): Users have been reporting various issues with Nvidia Shield after the Android 12 update. This includes issues such as a Black screen bug, frame rate matching broken, and Bluetooth getting disconnected when the device goes to sleep.
Also, there are issues where users can’t see any previous files and folders, the one where Shield is automatically waking, and the storage mapping issue.
Additionally, there is an issue with CEC not working where users can shut off tv and Shield with remote but the remote only turns on the shield, not the TV. And lastly, some users are not able to create new Network mapped Folders.
12:14 pm (IST): There is a method to downgrade the NVIDIA Shield TV to Android 9 (the previous version where everything worked fine). There is also a method to prevent the TV box from updating automatically.
Update 32 (January 17, 2022)
03:18 pm (IST): Some users reporting that the YouTube TV app is not working for them on Nividia Shield TVs. Luckily, TeamYouTube acknowledged the issue and said that they are investigating the issue.
Update 33 (January 18, 2022)
11:44 am (IST): Nvidia has listed all the issues caused by the latest update on Shield TV. And while we have listed some of them previously, here’s the list of all the bugs including known issues and user-reported bugs.
Known Issues:
– File browsing apps may require permissions be manually set to modify/delete files or directories. Set permission under “Settings -> apps -> [file browser app name] -> Permissions -> Files and media” and set to “Allow while using this app”
– After performing the first step on file permissions, some apps will show folders but there are no files listed. To Fix this for now, you will need to uninstall and reinstall affected apps.
– AI upscaling does not work when streaming GeForce NOW 1080p HDR content
– SHIELD TV mobile app and some 3rd party controllers do not work properly on Kodi
– Resolution is capped at 1080p when using ADB for screen capture
– Connecting to SHIELD over local network does not show content in adopted storage
– [2019 SHIELD all models] When toggling “Dolby audio processing” audio may be lost until SHIELD is rebooted
– Corruption briefly observed when watching YouTube TV
– [SHIELD 2019 base model] SD card occasionally does not get detected after reboot
– Unable to log into Google or Netflix accounts when using restricted profile
– Audio stutter issues with aptX-HD compatible headsets
– VUDU does not cast in UHD
– XBOX controllers may not automatically reconnect after disconnecting on SHIELD sleep
– Plex server android 11 permission and USB storage issues
– CEC volume control sometimes increments and decrements by 2
– Issues with interlaced content playback at 50hz
– SHIELD screen gets rotated 90 degrees. (Fix using adb or scrcpy/adb with scrcpy.adb shell wm set-user-rotation lock 0 followed by scrcpy.adb shell wm set-user-rotation free 0
– Long press menu button and menu button push to Kodi not working
– IR volume control is disabled when USB DACs are in use
– Chrome cast audio latency issues
– Long press select in Kodi doesn’t trigger voice search as it should
– Default Android Phone type folders (Ringtones, Downlods, Photos, Movies, etc) added to USB portable storage
– When Kodi is running in the background, refresh rate changes on apps in the foreground somtimes
Reported Issues:
– While using bluetooh headphones, audio is routed to HDMI instead of headphones only when audio formats is set to Manual. For now, set audio formats to auto (reboot after making this change) or disable surround sound to prevent the issue from happening.
– Change in mapping (Sterteched vs black bars) of 16:9 content to 16:10 display behavior from 8.2.3
– Reports of 5ghz wifi disconnects that did not happen in same setups on 8.2.3. Generally 5ghz is working fine and reports seem to be limited and corner cases
– When refresh rate switcher is enabled with the network debugging feature popups asking for device authorization to the network debugger appear randomly (Source)
Xiaomi 14 Ultra 16GB\512GB EEA Global OS3.0.1.0.WNAEUXM + Nvidia Shield TV Pro 2019
