En even de Changelog erbij.
History
374.43_2 (7-June-2
014)
- FIXED: NTFS disks couldn't be mounted (Paragon driver not
loading due to a kernel change) (AC56, AC68)
374.43 (6-June-2
014)
- NEW: User-configurable refresh period to trigger a DDNS
update after a certain number of days.
- CHANGED: dnsmasq option 252 now defaults to an empty string,
to silence broken clients such as Win7.
Important: if you were previously using a customized
252 reply (to use with a valid wpad/pac file), you
will need to use a postconf script to change the
default config instead of appending your own
config.
If you use DNS-based WPAD setting, you will need
to remove the 252 option using postconf, as IE will
not query for the DNS entry if there is a 252
option through DHCP, even if it fails to connect to it.
- CHANGED: Updated miniupnpd to 1.8.2
014
0523.
- CHANGED: Updated openssl to 1.
0.
0m.
- CHANGED: More backports from OpenSSL 1.
0.2, improving SHA
performance on ARM routers.
- CHANGED: The JFFS2 partition is now disabled by default after
a factory default reset.
- FIXED: Media server page wouldn't let you enable the iTunes
server unless you also enabled DLNA (Asus bug)
- FIXED: Restricted guests still had access to the router (Asus
bug introduced in GPL 4
887)
- FIXED: 6in4 traffic wasn't bypassing CTF if dualwan mode was
either disabled or set to failover mode (AC56/AC68)
- FIXED: Single character workgroups were rejected as invalid
(Asus bug)
- FIXED: Networks with SSIDs containing single quotes
would break the client list (Asus bug)
- FIXED: Traffic Monitor results are wrong on PPPoE connections
(Asus bug) (Patch by pinwing, additional debugging
by fantom1)
- FIXED: Crash if entering close to 64 MACs plus their names on
the MAC filter page.
