• naaitsab
  • Laatst online: 07:06
Mede-auteur:
  • MaXeRs
  • Laatst online: 17-11 23:29
MaXeRs
Afbeeldingslocatie: http://i.imgur.com/OH2Wkkv.jpg
De opvolger van de GF104,06,07 is er eindelijk en is tot de 700 series gedoopt!
Inhoudsopgave
Specificaties
Geforce GTX TITAN:
GTX TITAN GPU Engine Specs:
2688 CUDA Cores
837 Base Clock (MHz)
876 Boost Clock (MHz)
187.5 Texture Fill Rate (billion/sec)
GTX Titan Memory Specs:
6008 Memory Speed (Gbps)
6144 MB Standard Memory Config 384-bit GDDR5Memory Interface Width
288.4Memory Bandwidth (GB/sec)
GTX TITAN Support:
OpenGL: 4.3
Bus support: PCI Express 3.0*
Supported technologies: 3D Vision, 3D Vision Surround, CUDA, DirectX 11, PhysX, SLI, TXAA, Adaptive VSync, FXAA, GPU Boost 2.0, SLI-ready
Display support:
Multi monitor: 4 displays
Maximum digital resolution: 4096x2160
Maximum vga resolution: 2048x1536
HDCP: Yes
HDMI: Yes
Standard connectors: One Dual Link DVI-I, One Dual Link DVI-D, One HDMI, One DisplayPort
Audio input for HDMI: Internal
GTX TITAN Graphics Card Dimensions:
Lenght: 27CM
Height: 12CM
Width: Dual-slot
Thermal and Power Specs:
GPU Tempurature (in C): 95 C
Maximum Graphics Card Power (W): 250 W
Minimum System Power Requirement (W): 600 W
Supplementary Power Connectors: one 8-pin and one 6-pin
Geforce GTX 780:
GTX 780 GPU Engine Specs:
2304 CUDA Cores
863 Base Clock (MHz)
900 Boost Clock (MHz)
160.5 Texture Fill Rate (billion/sec)
GTX 780 Memory Specs:
3072 MB Standard Memory Config 384-bit GDDR5Memory Interface Width
GTX 780 Support:
OpenGL: 4.3
Display support:
HDCP: Yes
HDMI: Yes
GTX 780 Graphics Card Dimensions:
Lenght: 27CM
Height: 12CM
Width: Dual-slot
[Rebrand] Geforce GTX 770:
GPU Engine Specs:
1536 CUDA Cores
1046 Graphics Clock (MHz)
1085 Processor Clock (MHz)
143 Texture Fill Rate (billion/sec)
Memory Specs:
7.0 Memory Clock (MHz)
2048 GDDR5 Memory Interface
256-bit Memory Interface Width
224.3 Memory Bandwidth (GB/sec)
Feature Support:
OpenGL: 4.3
Bus Support: PCI Express 3.0
Supported Technologies: GPU Boost 2.0, 3D Vision, CUDA, DirectX 11, PhysX, TXAA,
AdaptiveV-Sync, FXAA, 3D Vision Surround, SLI-Ready, SHIELD-Ready
Display Support:
Multi Monitor: 4 displays
Maximum Digital Resolution: 4096x2160
Maximum VGA Resolution: 2048x1536
HDCP: Yes
HDMI: Yes
Standard Display Connectors: One Dual Link DVI-I, One Dual Link DVI-D, One HDMI, One DisplayPort
Audio Input for HDMI: Internal
Lenght: 27CM
Height: 12CM
Width: Dual slot
Maximum GPU Temperature (in C): 98C
Maximum Graphics Card Power (W): 230 W
[Rebrand] Geforce GTX 760:
GPU Engine Specs:
1152 CUDA Cores
980 Graphics Clock (MHz)
1033 Boost Clock (MHz)
94.1 Texture Fill Rate (billion/sec)
Memory Specs:
6.0 Memory Clock (MHz)
192.2 Memory Bandwidth (GB/sec)
Feature Support:
OpenGL: 4.3
Supported Technologies: DirectX 11, 3D Vision, 3D Vision Surround, CUDA, TXAA, Adaptive VSync, FXAA, SLI-ready
Display Support:
HDCP: Yes
HDMI: Yes
Lenght: 25CM
Height: 12CM
Width: Dual slot
Maximum GPU Temperature (in C): 97C
Maximum Graphics Card Power (W): 170 W
Minimum System Power Requirement (W): 500 W
Supplementary Power Connectors: Two 6-pin
Ga terug naar de inhoudsopgave
Reviews
Reviews kunnen natuurlijk makkelijk gegoogeled worden. maar hier toch een paar voorbeelden
TW.net - GTX Titan vs Ares II: titanenstrijd
HW.info - Nvidia GeForce GTX 760 review: boost voor de midrange
HW.info - Nvidia GeForce GTX 770 review incl. 3-way SLI en frametimes
HW.info - Nvidia GeForce GTX 780 review: Titan Light
HardOCP - NVIDIA GeForce GTX TITAN Video Card Review
Guru3D - GeForce GTX 760 review
GTX TITAN 4-Way SLI
Prijzen
Tweakers PriceWatch GTX 700 series
Drivers en Software
Drivers
  • De standaard drivers zijn te vinden op de site van Nvidia
  • Voor de tweakers zijn er natuurlijk alternatieven deze zijn er in de vorm van aangepaste drivers, dit wordt gedaan door de driver files aan te passen en weer omzetten in een installer deze zijn niet WHQL en je krijgt dus ook een waarschuwing hierover. Gebruik is op eigen risico en over de resultaten zijn de meningen verdeeld.
    Aangepaste drivers zijn hier te vinden Guru3D
Software:
  • GPU-Z - Dit programma kan precies vertellen welke grafische kaart in de pc zit. Zo meldt het programma onder meer fabrikant, model, type, revisie en snelheid van de grafische processor, en de hoeveelheid, het type en de snelheid van het geheugen. Hoewel de naam en het uiterlijk doen denken aan CPU-Z, een vergelijkbaar programma voor processors, is GPU-Z niet van dezelfde maker. Het is overigens mogelijk dat McAfee een valse positieve geeft met dit programma.
  • RivaTuner - RivaTuner werd enkele jaren geleden ontwikkeld om Nvidia Riva TNT-videokaarten te tweaken, zoals het aanpassen van (verborgen) DirectX- en OpenGL-instelling en het overklokken van de geheugen snelheid en de gpu. In de loop der tijd zijn er diverse nieuwe tweakmogelijkheden bijgekomen
  • Msi Afterburner - MSI Afterburner is een programma waarmee je makkelijk mee kan overklokken en je temperatuur voltage e.d. kan monitoren.
  • Furmark - Een videokaart stress programma om te kijken of je videokaart stabiel draait en geen artifacts vertoond.
  • Unigine Heaven - Een DirectX 11 benchmark welke vooral de Tesselation performance test.
  • Stone Giant DirectX 11 Benchmarker – Een DX11 benchmark
Regels
  • Dit is een GTX7xx discussie topic ga dus niet offtopic hier zijn andere topics voor, een beetje OT mag uiteraard maar hou het binnen de perken. Voordat je wat gaat vragen gebruik de zoek functie voor GoT of kijk op Google.
  • Gebruik voor speciefieke vragen zoals "Kan mijn voeding dit wel aan" of "Hoeveel krijg ik nog voor mijn oude Nvidia kaart terug" de bijbehorende topics. Dit voorkomt onnodige mod ingrepen en ergernissen.
  • Lopen Flamen met ATI en Nvidia in welke vorm dan ook is zeker not done, vind je ATI beter prima maar geef je mening ergens anders dit is een Nvidia GTX7XX topic, dit soort posts worden dan ook direct gemeld.
    Ga dus niet lukraak ATI info/reviews plaatsen, Nvidia vs ATI in de zelfde prijsklasse mag uiteraard maar hou het relevant.
  • Last maar zeker not least hou het netjes, op de man spelen en mensen voor van alles uitmaken doe je maar op het schoolplein hier gaan we normaal met elkaar om, zie je iets wat niet door de beugel kan gebruik de mod knop, ik zal ook zeker niet twijfelen om deze zelf te gebruiken.
if (!coffee) {
Work = false; }
  • naaitsab
Gereserveerd
if (!coffee) {
Work = false; }
  • MaXeRs
Vandaag maar eens aan de slag gegaan met EVGA's precision X voor mijn GTX 780.
Iemand hier al wat meer/langer ervaring mee ? Als ik probeer het voltage te verhogen dan wordt mijn scherm zwart en komt dan niet meer terug naar de desktop.
power target staat op 106
temp target staat op 90
Gpu clock offset +140mhz
Mem clock offset +175mhz
  • Paprika
  • Laatst online: 23:11
Paprika
Voeg deze even toe svp,
http://www.coolenjoy.net/...rd=&qa=0&ga=&cat=0&vote=0
puur omdat het kan...
Verder wil ik mij beklagen, Gpu-z vs GPU-Z, Rivatuner vs RivaTuner, Msi Afterburner vs MSI Afterburner en Gtx7xx vs GTX7xx ;)... Al was dit in get 6-topic ook zo zie ik nu pas. De naam naast de link klopt wel altijd overigens. :p
[ Voor 42% gewijzigd door Paprika op 09-07-2013 20:11 ]
Ik heb een Asus GTX 760 Gekocht maar bij elke game die ik speel krijg ik lag
Mijn PC:
- Asus GTX 760 DirectCU II OC
- AMD FX-4100 @ 3.6Ghz (Meegeleverde Koeler)
- 8 GB Ram
- Cooler Master 500W iGreen Power
- MSI 760GM-P23 FX
- Driver 320.18 (320.49 Geprobeerd maar teruggegaan naar 320.18)
  • HarmoniousVibe
  • Laatst online: 05-11 11:43
Je CPU gaat wel vaak de bottleneck zijn maar dit mag niet in elk spel leiden tot lag. Is je FPS oké of is er iets anders aan de hand?
Zelf heb ik recentlijk de MSI 770 Gaming gekocht. So far so good!
SolarEdge SE5K-RWB + 17 × AIKO Neostar N-Type type ABC | WeHeat Blackbird P80 | 3 × MHI Diamond 2kW
FPS is juist het probleem
Ik heb hier een asus laptop met gtx 770m.
5000 punten in 3dmark 2011.
  • MaXeRs
Verwijderd schreef op dinsdag 09 juli 2013 @ 20:10:
Mijn PC:
- 8 GB Ram
- MSI 760GM-P23 FX
Verwacht je misschien iets te veel van je GTX 760 ?
Op wat voor resolutie speel je en met welke games ?
Graag wat meer info. :)
''hardwareInfo'':De kaart blijkt in de praktijk zeer geschikt voor gamen op een enkel Full HD scherm. Medium settings gaat altijd goed, en hoogste settings bijna altijd. Alleen in de nieuwste, meest complexe games zul je van Ultra of Highest settings af moeten blijven, of toch moeten investeren in een duurdere videokaart. Dat moet je ook wanneer je op drie schermen of op een hogere resolutie dan Full HD wil gaan gamen. Medium gaat dan meestal nog wel goed, veel meer ook niet.
[ Voor 31% gewijzigd door MaXeRs op 10-07-2013 15:33 ]
1920x1080 Ultra (1 Monitor)
- Battlefield 3
- Saints Row the Third
- Far Cry 3
- Assassins creed Brotherhood
- Arma II (DayZ Mod)
- Team Fortress 2
Mijn Unigine Heaven 4.0 score
DirectX 11 Ultra x8 (1920x1080)
29.7 FPS (Met drops tot 10 FPS)
  • Q
  • Laatst online: 02:22
Q
Au Revoir Mon Capitan! 😭
Ik heb in mijn computer 2x Palit GTX 770 gestopt in SLI en dat geeft mij continue ~60 FPS @ 2560x1440 met drops naar 40 FPS in Crysis 3 op very high settings. Ben daar erg tevreden over.
Ik heb de 4 GB kaarten genomen, was niet heel veel duurder en Crysis 3 zit al tegen de 1800 MB aan, dus in de toekomst zullen games wel over die 2 GB grens gaan.
770 SLI werkt prima, het ligt vaak aan de game of je last heb van microsutters enzo. Crysis heeft daar geen last van, Farcry 3 wel. Dat lijkt een brakke engine.
  • Jorick
  • Laatst online: 09:08
Verwijderd schreef op woensdag 10 juli 2013 @ 17:10:
- Battlefield 3
- Far Cry 3
- Team Fortress 2
Als ik je Heaven Benchmark score bekijk ligt die wel redelijk in de lijn van mijn score. Ik haal een score van 944 met een FPS van 37.5 in Heaven Benchmark 4.0. De minimale FPS is 11.3 en de max is 76.2. De settings waren 1920x1080 8xAA, DX11, Ultra Quality en Tessellation op normal. Zonder tessellation behaal ik een score van 1071 met 42.5 FPS.
Mijn specs:
  • Intel Core i5 2500K @ 3.3 GHz
  • 8GB DDR3 @ 1333 MHz
  • Asus P8Z77-I Deluxe
  • Palit GTX 760 JetStream @ 1072 MHz GPU (Boost is 1137 MHz) en 1550 MHz voor het videogeheugen
  • Corsair TX550M 550 Watt voeding
  • Driver 320.49
Ik heb BF3, Max Payne 3 en CS:GO op de hoogste instellingen @1920x1080 getest en deze spellen draaien hier zonder lag en zijn prima speelbaar. Als je MSAA gebruikt dan kun je eens proberen dit lager of uit te zetten (of desnoods FXAA gebruiken) want dit kost nogal wat performance en heeft naar mijn mening vrij weinig nut als je op native resolutie van je monitor speelt. Wat je ook nog kan doen is tijdens het spelen GPU-Z op de achtergrond draaien en dan kijken hoe stabiel je sensorwaarden zijn, als er erg veel vreemde schommelingen in de waarden zitten die overeen komen met je lag dan kan het zijn dat je voeding of videokaart niet helemaal stabiel is.
Jorick schreef op woensdag 10 juli 2013 @ 20:53:
Mijn specs:
  • Driver 320.49
Mijn Videokaart geeft Drops in Usage (98 naar 10 tot 40) en voltage (1200 naar 850) veder gaan de fans nog op %80 draaien msaa stond al uit bij alle games
  • Jorick
Vertonen de grafieken in GPU-Z spikes of gaan de drops geleidelijk? Ik krijg de volgende grafieken na een run van de Heaven benchmark:
Afbeeldingslocatie: http://gpuz.techpowerup.com/13/07/11/hek.png
De sensorwaarden zijn praktisch constant en dus zonder extreme pieken. De PerfCap Reason is tijdens de benchmark VRel en niet Util. Kun je misschien ter vergelijking ook een screenshot van GPU-Z posten na het draaien van de Heaven benchmark?
Mijn Fps met de Tesellestion is 898 met een FPS van 35.7 (de ASUS kaart heeft een lagere clock snelheid) vreemd dat hij bij Unigne Heaven geen drops geeft maar bij mijn games wel hier is de grafiek van unigne heaven tijdens de benchmarking:
Afbeeldingslocatie: http://s14.postimg.org/60xin4ext/Unigne_Heaven_4_0.gif
En deze is van Battlefield 3 (1920x1080 Ultra 0x MSAA)
Afbeeldingslocatie: http://s12.postimg.org/wwtdmcvn1/Battlefield_3.gif
[ Voor 8% gewijzigd door Verwijderd op 11-07-2013 14:45 ]
  • Joe_P
  • Laatst online: 14-11 21:32
Net ook even een bench gedraaid met Unigine Heaven (MSI TF GTX 760).
Met clocks gelijk aan die van Jorick (core1070, mem1530) krijg ik icm. 965BE @ 3,8 Ghz:
FPS 36,8
Score 928
Min. 16,0
Max. 74,4
Hier is een screen van m'n GPU-Z. Ik krijg overigens geen 'PerfCap reason' te zien, terwijl ik dezelfde versie van GPU-Z gebruik en de laatste NVIDIA drivers heb.
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/10631980/GPUZ%20Heaven%20bench.gif
BF3 is nu aan het updaten (9gig...) dus daar kan ik zo ook een bench mee draaien om te kijken of ik een CPU bottleneck heb.
SteamID: PistolenPaultje - WoWS: General_Lack_of_Interest
Mijn Fan speed is 40% hoger (vreemd)
  • Jorick
Verwijderd schreef op donderdag 11 juli 2013 @ 14:30:
Ik denk dat er niet zo veel mis is met je videokaart als ik naar je score en GPU-Z screenshot van de Heaven benchmark kijk. Je screenshot van BF3 laten duidelijk een ander beeld zien en de drops in je GPU load doen vermoeden dat je CPU de bottleneck vormt. Bij mij ziet de grafiek er namelijk zo uit tijdens een potje BF3 online op Metro met 64 spelers (1920x1080, Ultra, 0xMSAA, vsync uit):
Afbeeldingslocatie: http://gpuz.techpowerup.com/13/07/11/gv2.pngAfbeeldingslocatie: http://gpuz.techpowerup.com/13/07/11/c82.png
Om uit te vogelen of je CPU of GPU het probleem is kun je proberen om de resolutie van 1920x1080 te verlagen naar 1280x720 terwijl je de overige instellingen gelijkt houdt. Als je dan, in dezelfde map op dezelfde plek(ken), ongeveer vergelijkbare FPS en FPS drops hebt dan is je CPU het probleem. Heb je echter een aanzienlijke hogere en stabielere FPS dan vormt je GPU de bottleneck.
Omdat BF3 online nogal een CPU-intensief spel is mag je er haast wel van uit gaan dat je CPU te kort schiet. Dat verklaard ook wel waarom je met de Heaven benchmark wel een normale score behaald omdat die benchmark je CPU veel minder belast (geen physics, AI of andere belastende berekeningen). In een eerdere post noemde je een aantal spellen waarvan Team Fortress 2 ook CPU gebonden is (net zoals andere spellen die zijn gebaseerd op de Source Engine). Van die overige spellen zou ik zo niet weten hoe CPU-intensief die zijn.
Wat betreft je hogere fan speed, ik denk dat dit komt omdat je ventilatoren op je koeler relatief klein zijn en dus sneller moeten draaien om je GPU op een gelijke temperatuur te houden. Je videokaart wordt niet uitzonderlijk warm bij volle belasting dus de koeling zat het probleem niet zijn.
Ook bij Low geeft hij hetzelfde probleem ik denk dat het een bottleneck van de CPU is. is dit een goed alternatief voor 100 euro:
pricewatch: AMD FX-6300 Black Edition
  • naaitsab
Paprika schreef op dinsdag 09 juli 2013 @ 19:49:
Is aangepast :p
if (!coffee) {
Work = false; }
  • Paprika
Paprika
  • calsonic
Verwijderd schreef op vrijdag 12 juli 2013 @ 06:43:
Zet in het Nvidia Control Panel -Vertical Sync- eens op -Use the 3D application setting-
Ik had hetzelfde probleem en nu is het compleet verdwenen.
calsonic schreef op vrijdag 12 juli 2013 @ 15:18:
in welke tab zit dat?
  • naaitsab
Afbeeldingslocatie: http://i.imgur.com/iLjBeO0.jpg
Locatie in de Engelse versie is identiek meen ik.
if (!coffee) {
Work = false; }
  • calsonic
naaitsab schreef op vrijdag 12 juli 2013 @ 16:49:
Ja klopt.
  • Vinze
  • Laatst online: 17-11 10:22
Heb al even zitten zoeken op Google en op GoT, maar die gaven geen resultaten terug.
Ik heb een OCZ ModXStream Pro voeding van 500W (deze dus), is dat voldoende voor een GTX760? Er staat overal wel dat hij minimaal 500W nodig heeft, maar ik weet verder niet waar ik op moet letten.. Hoeveel ampere bijvoorbeeld op de 12V lijn?
Mijn verdere setup voor zover van toepassing:
Intel Core i5 2500k
8 GB ram
1 SSD, 1 HDD en een DVD speler
  • naaitsab
Indien de voeding gewoon stabiel 500W kan leveren voorzie ik geen problemen. Ben verder niet bekend met de kwaliteit van die voedingen maar gezien de wat karige uitrusting gok ik dat deze binnen het budget+ genre valt.
Gewoon proberen, als de boel vast loopt of vreemde kuren vertoont zet je er toch gewoon een zwaardere/betere PSU in ? :p
if (!coffee) {
Work = false; }
  • Snippertje
  • Laatst online: 08:41
Snippertje
Light up your life
Meer mensen die hier Tomb Raider spelen? Bij mij crasht hij om de haverklap, heb het al met verschillende settings geprobeerd, maar dat lijkt niet uit te maken. Gebruik de laatste drivers en heb een GTX760. Andere games heb ik helemaal geen problemen mee en ook even naar de temperatuur gekeken met furmark stresstest en die wordt niet meer dan 75 graden.
Op internet lees ik over meer mensen met deze problemen, maar niemand lijkt een oplossing te hebben :(
Discord kanaal: https://discord.gg/X3CqdTKd
  • calsonic
Snippertje schreef op zaterdag 13 juli 2013 @ 21:07:
Toen hij net uit was had iedereen daar last van - maar na de patch/update draaide hij prima.
  • MaXeRs
Ik heb het spel gisteren gekocht en direkt na het intro filmpje liep de game vast.
Daarna Nvidia Geforce experience de instellingen laten veranderen en nu loopt ie als een zonnetje.
Drivers 320.49
GTX 780
  • Snippertje
Snippertje
Light up your life
calsonic schreef op zondag 14 juli 2013 @ 10:56:
Heb het weten op te lossen door exclusive full screen uit te zetten. Zie ook geen verschil in kwaliteit, dus wel prima.
  • Jorick
Ik ben gisteren ook begonnen met Tomb Raider en heb tot op heden nog geen enkel probleem gehad na een uurtje of vier spelen (gebruik een GTX 760 i.c.m. de laatste driver 320.49). Ik zie alleen na het opstarten vlak voor het menu verschijnt even artifacten maar misschien dat die er bewust inzitten.
[ Voor 4% gewijzigd door Jorick op 15-07-2013 11:43 ]
  • Chester
Vandaag een MSI GTX780 Twin Frozr gehaald. Heb er nog niet heel veel mee gespeeld, maar tot nu toe ben ik erg onder de indruk. Erg stille koeler, en het koelt ook nog eens erg goed (bij Unigine Heaven bleef het onder de 80 graden).
Had ook even de gaming app van MSI geprobeerd. Getest op 2560x1600, met quality op ultra en tesselation op extreme. Stock haalt ie een score van 1067 en in 'OC Mode' haalt ie 1128. Waarschijnlijk kan ie een veel hogere klok hebben als je met Afterburner ofzo gaat overclocken, want zover ik kon zien werd je geheugensnelheid niet aangepast door de gaming app.
"The test of a work of art is, in the end, our affection for it, not our ability to explain why it is good." - Stanley Kubrick | Trakt
  • hydrargyrum
  • Laatst online: 24-08 08:39
Ik kan mij hier melden met een gtx 770. Dit beestje komt uit de gigabyte-stal en draait netjes op stock. Het enige moment dat ik lag gehad heb is nadat ik 30 nukes tegelijk liet ontploffen in tekkit, maar dat is alles. Het enige nadeel van de kaart is het gebrek aan vga/een missende dvi-vga adapter, maar welke idioot gebruikt nou nog vga? (ik)
  • yinx84
  • Laatst online: 30-08 23:19
Hier nog iemand. Bij mij was de oplossing alle overclockwaardes terug te zetten naar default. Draait nu als een zonnetje om m'n GTX780. Dit terwijl ik elk willekeurige andere game/benchmark 100% stabiel draai.
[ Voor 4% gewijzigd door yinx84 op 25-07-2013 10:37 ]
  • Sn0wblind
  • Laatst online: 27-08 14:34
Jorick schreef op maandag 15 juli 2013 @ 11:41:
Speel je de cracked versie zonder patches? :P
  • Jorick
Nope, ik heb hem gekocht tijdens de Steam Summer Sale ;)
  • millman
  • Laatst online: 26-09 18:57
millman
6708Mhz @ -185c
Nogmaals, even 'exclusive full screen' uitzetten en je hebt daar geen last meer van.
'Heb ik eindelijk mn kamer opgeruimd, is de wereld een puinhoop'
  • Ribozyme
Ik heb nu ongeveer2 weken de MSI TF gtx760 gaming en hij bevalt me heel erg. Qua prestaties merk ik geen verschil tegenover mijn asus direct cu 2 670. MAAR de MSI is stiller dan de asus under load wat ongelooflijk is. De koeler op de MSI is echt top. Echt een aanrader dus. Tomb raider ermee doorgespeeld op ultra AA x 2 en goede framerate. Wat een leuke game trouwens.
Welk merk GTX 780 kunnen jullie mij aanraden? De Gigabyte is het goedkoopst, van de Asus hoorde ik dat ie het hoogst kan worden overgeklokt en de Inno3D is standaard het meest overgeklokt en het geheugen als enige ook. Dan heb je ook nog MSI, Palit, EVGA en nog meer. Voor welke kan ik het beste gaan?
  • naaitsab
Verwijderd schreef op vrijdag 26 juli 2013 @ 19:34:
Ligt eraan wat je zoekt, reference voor SLI, custom koeler, merk voorkeur enz.
Bij de 6xx series waren bij Asus veel klachten dus daar zou ik persoonlijk wat afstand van houden tot er wat meer bekend is over de nieuwe 7xx koeler/kaart.
MSI en Gigabyte doen het altijd wel goed, EVGA nemen als je een reference/radiale koeler zoekt voor een SLI setup. Het prestatie verschil is marginaal dus daar zou ik me keuze niet op baseren. Meer op de koeler (temp en geluid), prijs en garantie van de kaart.
[ Voor 8% gewijzigd door naaitsab op 26-07-2013 19:45 ]
if (!coffee) {
Work = false; }
Ik ga niet beginnen aan een SLI-opstelling dus dan blijven alleen MSI en Gigabyte over. Het is jammer dat ik over de Gigabyte versie bijna niets kan vinden qua reviews.
Edit: Is Inno3D nog iets?
[ Voor 7% gewijzigd door Verwijderd op 26-07-2013 19:49 ]
  • Chester
Verwijderd schreef op vrijdag 26 juli 2013 @ 19:47:
Ik heb zelf laatst een MSI GTX780 Twin Frozr gehaald, en ben zelf heel erg te spreken over hoe stil ie is. Echt ongelofelijk hoe stil een high end kaart kan zijn.
  • naaitsab
MSI heeft bij de 5xx series gebruik gemaakt van (erg) goedkope fans, geen idee of ze daar vanaf gestapt zijn, verder leuke kaartjes. Gigabyte heeft wel goeie koelers en ik heb zelf goeie ervaringen met de RMA van Gigabyte, op mijn werk leveren we enkel Gigabyte moederborden en dat gaat altijd prima als er wat loos is.
Ziet er vrij amateuristisch uit, zou het zelf niet kopen.
if (!coffee) {
Work = false; }
  • MaXeRs
ik heb zelf de goedkoopste genomen in mijn geval was dat de Gigabyte GV-N780D5-3GD-B met de fabrieks [reference] koeler.
http://www.gigabyte.co.nl...uct-page.aspx?pid=4622#ov
Loopt als een trein en overklock als de beste ,en over het geluid hoor je mij niet klagen.
  • calsonic
  • MrPompidom
  • Laatst online: 29-10 10:49
Heb kortgeleden mijn asus HD7970 ingeruild voor een ASUS GTX780, en heb inmiddels al diverse B.S.O.D's achter de rug. Welke driver versie adviseren jullie?
Draai momenteel 320.49.
Pc:
ASUS Rampage 4 Extreme
I7 3960x
16 GB g-skill 2133
Samsung 830 256 Gb
Dell 2713h 2560x1440 & LG e2370 1920x1080
Had bijvoorbeeld al 2 x nvlddmkm.sys errors ...
Verder reageert de pc soms helemaal niet meer of heel traag, als ik even niks doe.
Tijdens spelen van Farcry 3 al een aantal freezes achter de rug.
Had ik nooit last van met de 7970..
Graag advies.
[ Voor 0% gewijzigd door MrPompidom op 02-08-2013 08:07 . Reden: typo ]
  • Chester
MrPompidom schreef op vrijdag 02 augustus 2013 @ 08:05:
Pc:
I7 3960x
16 GB g-skill 2133
Samsung 830 256 Gb
Graag advies.
Had je je ATI drivers verwijderd? Probeer anders eens 320.49 opnieuw te installeren, maar kies dit keer voor een custom install en vink aan dat je een clean install wilt.
  • MrPompidom
Uiteraard reeds gedaan. Sterker nog, ik heb zelfs de pc even opnieuw voorzien van windows 7 pro.
Met alle recente drivers, bios updates, enz.
Liep net wel keurig door 3dmark heen, maar zojuist weer een freeze tijdens het afspelen van een 1080p filmpje.
  • Chester
Als je je PC ook opnieuw hebt geinstalleerd, vrees ik dat je kaart misschien kapot is. Ik heb zelf ook een GTX780 en een triple monitor setup (2560x1600 & 2x1920x1080) en heb zelf nergens last van met 320.49.
  • job115
  • Laatst online: 18-11 12:41
Pc:
I7 3960x
16 GB g-skill 2133
Samsung 830 256 Gb
Graag advies.
Je leest hier op het forum redelijk veel problemen met de 7xx serie, de meeste hebben er geen last meer van na een BIOS update van het moederbord, je kan is kijken of er een nieuwe versie is en of deze het probleem oplossen.
Xbox: Baloutje07 | PSN: AudiWanderer
  • MrPompidom
Ik draai reeds met de meest recente versie (4206) voor mijn rampage 4 extreme.
Bios updates doe ik met grote regelmaat..
  • knoffy
  • Laatst online: 18-11 22:10
die hele 7 serie is stuk ofsow heb mijn gtx 770 ook al weer terug gestuurd voor de 2e keer, 1e keer na paar dagen allemaal blokken en gekke dingen. 2e keer werd hij na een half uur niet meer herkent en allemaal crashes.... had beter me gtx 680 kunnen houden.
  • MrPompidom
Hmja, ik had de MSI, maar die heb ik al omgeruild voor de ASUS na artifacts.
Heb al 3 jaar alleen de nieuwste ATI/AMD kaarten, maar wilde nu nvidia maar weer eens proberen, maar begin langzaam spijt te krijgen.
Ik heb een Asus laptop met een GTX 770M.
Hier maak ik al een maand intensief gebruik van.
Maar tot nu toe geen problemen.
  • WllmZ
  • Laatst online: 09-09 17:45
knoffy schreef op vrijdag 02 augustus 2013 @ 15:56:
De GTX770 is dezelfde chip als de GTX680 (GK104) Alleen de GTX 780 in de GTX 7xx serie heeft geloof ik een andere chip (GK110). Dus het had even goed je GTX 680 kunnen zijn die dat deed... Je hebt gewoon pech helaas. Wel zijn de GTX 770's hoger geclockt dan de GTX 680's wat nooit beter kan zijn voor de levensduur van de chips.
Ik zelf draai namelijk 2x Gigabyte GV-N780D5-3GD-B in SLI en heb nog nooi problemen gehad. Daarvoor 2x GTX 680 van msi, ook niks mis mee. GTX 580 wel veel gedoe mee gehad. GTX 480's weer niet enzovoorts.
  • Moglie38
  • Laatst online: 01-01 12:38
Heren,
Als je een SLI opstelling wilt. Hoe zwaar moet je voeding minimaal zijn?
Bijvoorbeeld 2x GTX 760 van Nvidia.
Grtz,
Mike :)
  • calsonic
Moglie38 schreef op vrijdag 18 oktober 2013 @ 15:28:
Heren,
Grtz,
Mike :)
http://www.enermax.outervision.com/index.jsp
  • hidde212
  • Laatst online: 18-11 22:19
hidde212
Free your mind...
Heren,
Als je een SLI opstelling wilt, hoe zwaar moet je voeding minimaal zijn?
Grtz,
Mike :)
Niet bepaald een accurate psu calculator, zoals die er uberhaupt niet echt bestaan.
Een goede 600W is voldoende voor 2 GTX760's als je niet overclockt, echter zit je dan vaak met de connectors te kloten. Hierom raad ik je een pricewatch: Seasonic G-Serie 650Watt aan.
...and your ass will follow
  • 3clectic
  • Laatst online: 17-10 23:32
Ben onlangs van 2x670 naar 2x780 overgestapt en ik moet zeggen dat het lekker loopt.
Huidige setup
i5 3570K @ 4.5
16 GB Ripjaw 1600
2x Asus GTX 780 OC
Asrock Xtreme 4 mobo
Cooler Master V850 gold psu
Ik wilde voor het komende jaar niks meer eraan hoeven te doen, en met de pricedrop van de 780 kaarten maar gelijk twee aangeschaft. Daarnaast speel ik op 2560x1440 en dat loopt nu heerlijk soepel. Tot nu toe ook geen problemen gehad met de kaarten. Ook met mijn oude gtx kaarten niet.
Ryzen 9 5900x | RTX 3080 FE | ASUS B550M PLUS | G.Skill Neo 32 GB CL16 @ 3600 MHz | Corsair 280x | Samsung 980 500 GB NVMe | Samsung 870 1 TB SSD
  • Tom. C
  • Laatst online: 08:54
Ik heb een GTX 770 met daaraan twee monitoren. Zoals al een tijdje het geval is bij nVidia gaan de GPU clocks bij twee monitoren niet terug naar de 2D-modus. Mijn minimale GPU clock met twee monitoren is 692mhz terwijl het met eentje maar 135 is. Bij mijn GTX 570 had ik deze fix toegepast. (http://www.overclock.net/...king-fix-for-nvidia-cards)
Ik las echter een tijdje terug ergens dat de nieuwe GTX 700 series en de Titan dit probleem niet meer zouden hebben. Ik heb het dus nog wel. Is er hier iemand anders met een GTX 700 series, Titan en meerdere monitoren die hun ervaringen wat betreft dit onderwerp kunnen delen? Als het niet hoeft laat ik die fix liever voor wat het is.
9800X3D | X870e Nova | Corsair Dominator 32GB 6000mhz | TUF RTX 5080 | Corsair 6500X | MSI MP341CQPX OLED | Simagic Evo Pro | ClubSport Pedals V3 | Megane Renault Sport RS 250
  • novalite
  • Laatst online: 24-12-2025
Tom. C schreef op zaterdag 09 november 2013 @ 18:00:
Ik draai een Asus 770 OC en heb hier geen problemen mee met dual monitor setup.
Schakelt gewoon netjes terug naar 135~200mhz als ik aan het browsen ben.
Mijn speeltje
  • Tom. C
novalite schreef op zondag 10 november 2013 @ 17:27:
Raar dat de mijne het niet doet. Hier een screenshotje. Heb even geen idee hoe ik dit aan moet pakken.
Afbeeldingslocatie: http://i40.tinypic.com/16ibjh1.png
  • Tom. C
Heb de oorzaak inmiddels gevonden.
Een van mijn monitoren draait op 144hz, wanneer ik deze op 60hz zet gaat de kaart wel terug naar 135mhz.
135mhz is dus niet voldoende voor 144hz en 60hz naast elkaar.
  • lampekap06
  • Laatst online: 10:14
Valt me op dat mijn nieuwe 780 ook niet terug klokt naar de idle clock snelheden. Blijkt aan windows 8 metro apps te liggen. Ik moet ze echt met task manager uit zetten om de kaart weer rustig te krijgen. Geloof niet dat mijn vorig 670 dit deed.
Meer mensen last van, of meer over bekend? Ben benieuwd of ik het nu bij de kaart, de drivers of bij windows moet zoeken.
Is er al nieuws over een nieuwere driver dan de 331.65?
Zo ja link aub.
  • Zanac-ex
  • Laatst online: 18-11 12:00
2 * Gigabyte Titan OC Windforce3's onderweg die mijn GTX690's gaan vervangen.
(FYI voor de prijs van twee reguliere GTX780's :) )
Iemand ervaring met Windforce3 coolers in SLI? Ik bijn er vrij zeker van dat in een SLI setup de standaard koelers de betere oplossing is.
  • naaitsab
Zanac-ex schreef op maandag 18 november 2013 @ 13:21:
Heb zelf 2 GTX670 WF3 in SLI dat bevalt me prima, je moet dan wel voldoende case ventilatie hebben maar dat mag voor zich spreken in een gaming PC.
De 780 TI is voor games beter dan de Titan maar als je ze voor 780 non-TI prijs kan overnemen is dat geen slechte deal natuurlijk :p
if (!coffee) {
Work = false; }
  • Help!!!!
  • Registratie: Juli 1999
Help!!!!
Mr Majestic
Dat hangt er vooral van af wat voor mobo je hebt (hoever staan de pci-e sloten uitelkaar) en hoe breed de kaarten zijn.. Ik heb ook 670SLI WF3 en daar zit ongeveer 1.5 vinger ruimte tussen de kaarten wat imo meer dan voldoende is.
Ik heb echter geen case maar een benchmarktable dus dat kan nog wat verschil maken.
PC Specs
  • Zanac-ex
Help!!!! schreef op maandag 18 november 2013 @ 18:38:
Asus Maximus V Extreme , nu GTX690 in Quad SLI, met flink wat vrije ruimte tussen de kaarten.
naaitsab schreef op maandag 18 november 2013 @ 17:06:
Zeer te spreken hoe de standaard GTX690 koelers hun werk doen, meeste warmte word netjes naar buiten geleid.
Kast is een antieke Lite-On FS020, zeer stil zolang je de warmte kwiit kan, 3 * GTX680 op elkaar gepakt was iets te veel van het goede
De Gigabyte WF3 Titans hebben trouwens standaard al een leuke overclock, Base 928 met een Boost naar 980.
Mischien dat ik er de WindForce koelers opzet en anders kan ik er vast wel een GTX780 gebruiker blij mee maken.
[ Voor 35% gewijzigd door Zanac-ex op 18-11-2013 20:39 ]
  • Tom. C
Verwijderd schreef op maandag 18 november 2013 @ 08:36:
Zo ja link aub.
http://forums.guru3d.com/showthread.php?t=383725
Geinstalleerd , en wanneer kan Shadowplay ook met laptop GPU's gebruikt worden?
Verwijderd schreef op dinsdag 19 november 2013 @ 15:33:
Ja het kan wel op je laptop maar daar moet je dan wel wat voor doen helaas.
Hier word het één en ander uitgelegd
http://thespawnpointblog.com/nvidia-shadowplay-laptop/
700 series
Tijd geleden dat ik hier ben geweest. Ondertussen is mijn systeem ook helemaal aangepast waaronder natuurlijk ook de videokaarten. Ik ben maar voor 2 gtx780's reference gegaan en dat was voor bijna een jaar geleden de beste keuze die er was voor de iets hogere resolutie van 2560x1080@75hz ;)
Ik kom er voor van 2 Asus dc2 gtx680's af maar dat was niet te doen ,zelfs niet met ruimte tussen de kaarten, de kaarten klokken terug met een bak herrie er bij. Dat was zonder van mijn aankoop dus maar ik wou het gewoon eens zelf meemaken of dat ook werken.
Toen kwamen er 2 gtx780's refenrece kaarten in en wat was dat een opluchting, koel stil een aanzienlijk sneller sneller op mijn resolutie want de 2 gtx680's hadden een memory bottlenek dus 2 gb was soms net wat te weinig.
Ik ik neem verder ook vaak games op. Bijna alle programma's waar mee ik op neem werken niet lekker, kost veel van je fps als je goede kwaliteit wil. En toen kwam shadowplay 'wat was dat een verademing zeg' het kost je namelijk weinig tot geen extra performance en de kwaliteit is gewoon goed.
Ik het begin toen shadowplay uit kwam werkte het nog niet goed vanwege mijn aspect ratio verhouding van het scherm maar dat heeft nvidia snel opgelost door wat hoogte in te leveren want de bestanden worden 1920x810. Hier een filmpjes met shadowplay.
ACM
[YouTube: http://www.youtube.com/watch?v=gBLqh0ZmLqE]
COD ghost met widescreen fixer
[YouTube: http://www.youtube.com/watch?v=4XJQH3kJUFs]
NFS Rivals met fps op 60.
[YouTube: http://www.youtube.com/watch?v=kwydnYbaWjU&feature=youtu.be]
Voor de rest werken deze kaarten goed met gamen want in sli kan ik iedere game op max instellingen afspelen wat weer niet wil met 1 gtx780 want dan moet ik aan de AA rommelen en dat wil ik niet, het is alles of niets >:)
Hier een paar plaatjes om te pimpen.
Afbeeldingslocatie: https://scontent-b-ams.xx.fbcdn.net/hphotos-frc3/t1/1476561_10201886072806225_179702918_n.jpg
[ Voor 8% gewijzigd door Verwijderd op 16-01-2014 10:52 ]
Ben vandaag de eerste game tegengekomen die al mijn video memory gebruikt, BioShock INF. Maar ondanks dat hoge verbruik blijft de game erg soepel draaien. Ik had verwacht dat je bij max video memory gebruik juist hickups zou krijgen.
  • Weemism
Weemism
Es el Pollo Diablo!
Heb twee weken geleden de MSI GTX770 Gaming gehaald, maar heb zelf tot dusver geen van de in deze thread genoemde problemen gehad. Moederbord is de Gigabyte Z77X D3H, revision 1.0 met de F18i beta bios, driverversie voor de GTX770 is 332.21.
Een beetje aan het overclocken geslagen, en ik krijg de fabrieksklok van 1.085 Mhz op GPU en 1.753 Mhz op Memory min of meer stabiel tot respectievelijk 1.170 en 1.928 Mhz. Die stabiliteit varieert een beetje afhankelijk van de gebruikte benchmarks en games.
Op verschillende sites worden nog hogere clocks genoemd van resp. 1.200 en 2.000 Mhz voor deze kaart, maar hoe ze dat stabiel voor elkaar krijgen is me een raadsel. Hoewel niet het juist draadje ben ik wel benieuwd of een van jullie stabiel op hogere kloksnelheden hebben kunnen overklokken voor deze MSI, of überhaupt de GTX770.
Overclocked met genoemde frequenties haal ik 45.656 GPU-punten in 3DMark Vantage, en een graphics score van 8.680 punten in de Firestrike benchmark van de nieuwe 3DMark. Stock is dat respectievelijk 37.872 en punten 8.077. Beide benchmarks op default settings.
Op stocksnelheid sowieso geen problemen met stabiliteit of artifacts, maar overclocked wil het nog wel eens gebeuren dat er ineens 'dosachtige' blokjes verschijnen en de game/benchmark crashed naar desktop.
Ben op termijn, als de prijzen gaan zakken, nog van plan er een tweede kaart bij te kopen voor een SLI opstelling, kan ik cheap weer wat jaartjes vooruit ook.
[edit] Overclockdiscussie voor de GTX 770 werd hier al gevoerd.
[ Voor 10% gewijzigd door Weemism op 16-02-2014 21:29 ]
Er is weer een leuke nieuwe game uit Thief en om jullie een idee te geven hoe de game draait heb ik wat benchmarks gedraaid.
2560x1080 Max settings exclusive full screen mode 1gtx780 i7 3820 4cores 8 threads AVG 50,5fps.
2560x1080 Max settings exclusive full screen mode 2gtx780 i7 3820 4cores 8 threads AVG 78,4fps
Nu is de sli schaling nog niet zo heel goed maar word vast nog beter met nieuwere drivers?
Ik heb verder ook nog een filmpje ven de benchmark toegevoegd maar helaas houd de opname toch wat performance tegen dus daar moet je niet vanuit gaan, het laat enkel het beeld zien hoe het er uit ziet, geheugen gebruik en dergelijke.
[YouTube: http://www.youtube.com/watch?v=zgwNnlr5jt8&feature=youtu.be]
[ Voor 5% gewijzigd door Verwijderd op 28-02-2014 15:12 ]
De nieuwe WHQL 335 drivers is in ieder geval aan te raden voor Thief want in die game haal ik met sli in eens 4.1 fps meer AVG. SLI. En SLI uit maar 1,4 fps meer.
Jejking schreef op dinsdag 11 maart 2014 @ 23:49:
Ik twijfel als ik de laatste Crossfire-reviews lees mbt R9 290, frametimes laten nog steeds wat te wensen over vergeleken met nVidia... twee maanden terug. Is er veel veranderd? Ze poepen genoeg FPS uit maar verdeeld over 2 UHD-schermen wil ik toch zo min mogelijk framelag (microstuttering) zien. Wie wil hier iets over kwijt? AMD heeft z'n maandelijkse driverupdate laten vallen, daarom vraag ik dat.
Ik vind persoonlijk dat nvidia dit net allemaal wat beter heeft. Ik wissel zelf ook wel eens tussen de fabrikanten maar om verschillende redenen heb ik toch liever nvidia.
Vaak vanaf het begin betere drivers voor een game, minder MS in sli, betere frametimes, makkelijker zonder bijkomende problemen drivers installeren in de meeste gevallen enzv.
Je betaald dan wel wat meer voor de zelfde prestaties maar daar voor krijg je ook een betere gameplay er voor terug en makkelijkere drivers die in de meeste gevallen gelijk goed willen installeren.
  • Metalbuster
Een GTX760 heeft 1x 6 pins en 1x 6+2 pins aansluiting nodig van de voeding.
Mijn voeding (OCZ StealhXtream(600w) heeft alleen 2x 6pins, gaat dit wel werken op een GTX760, of kan ik dit oplossen op een andere manier?
  • Gmount
  • Laatst online: 13-11 18:45
Gmount
Ecorunner lid
@lupp:
dat Physx> gpu of cpu linksboven in beeld heb ik ook wel eens, soms is het een poosje weg, dan komt het weer terug. Weet jij waar het door komt en of je het weg kunt halen?
1900Km/L! || i7 6700K @ 4,6 GHz | NZXT Kraken X61 | MSI GTX 970 @ 1,48 GHz | 8 GB DDR4| Bitfenix Aegis yellow
  • Frozen
  • Laatst online: 01-11 15:16
Frozen
2e Reviewer van het Jaar
Verwijderd schreef op zaterdag 15 maart 2014 @ 13:38:
Ik vind wat je schrijft onzin. Van het begin af aan betere drivers klopt wel, er zijn gewoon meer grote spellen "meant to play with nvidia."
Minder ms in sli, al eens 2x r9 280x geprobeerd?
Betere frametimes? Je bedoelt fps? Dat is absoluut onzin als je kijkt naar de prijzen van de kaarten.
Makkelijker drivers installeren die dan gelijk werken? Dat heeft amd ook en die drivers werken net zo vaak als de nvidia drivers.
Er zijn genoeg nvidia mensen die boos zijn omdat ze een bepaalde game niet kunnen spelen omdat hun kaart niet meer upgedate wordt (check maar eens de reacties op een post van een nieuwe driver van nvidia op hun facebookpagina). Bij amd heb ik dit nog nooit gezien.
Amd kaarten hebben meer raw power, betere opengl ondersteuning en zijn goedkoper met betere prestatie.
Voeg me gewoon toe op LinkedIn, iedereen is welkom!
  • Zanac-ex
Frozen schreef op dinsdag 01 april 2014 @ 22:06:
Ooit eens een AMD ATI AGP hotfix Driver geinstalleerd? (pun)
Persoonlijk vind ik beide kampen momenteel zeer aan elkaar gewaagd.
Ik lees de laatste tijd vaak over het merk gddr5 geheugen, consumenten vragen naar goede chips. Nu vraag ik me af wat je kan met een goede chip, is dat meer oc potentie of gaan ze langer mee? Gebruikt nvidia ook goede geheugen chips voor de Titan en andere Geforce producten? Nu gebruikt Nvidia op mijn Titans Samsung chips, maar ik lees alleen maar positieve ervaringen met hynix, hoe zit dat met samsung?
Mss een domme vraag. Wil grafisch wat verbeteren.
Ik heb een i7 2600k met z68 -moederbord , 8gb 1600 ddr3 en ssd schijven.
Videokaart is een asus 760gtx op 1 23"-scherm.
De ddr3 ga ik uitbreiden naar 16gb.
Is het interessant om naar een 2e gtx 760 in sli te plaatsen? (Op 1 monitor)
Maakt dit veel onderscheid??
  • naaitsab
Denk dat je die vraag simpel zelf kan beantwoorden.
Heb je het nodig omdat je, A meer FPS wil en/of B hogere settings/kwaliteit dan ja.
Heb je nou al alles op max en 60FPS (er van uitgaande dat je een 60hz scherm hebt) dan nee vandaag de dag zal je er weinig mee opschieten.
Ik zou zeggen zoek wat SLI benchmarks en bepaal zelf of je daarvoor de knip wil trekken.
Overigens zal 8 of 16GB RAM je niks merkbaars opleveren qua gaming.
if (!coffee) {
Work = false; }
naaitsab schreef op maandag 02 juni 2014 @ 20:34:
Ja is een 60hz (samsung-syncmaster xl2370).
Dus ik ga niet veel kunnen doen? Of lees ik het verkeerd?? 8)7
  • naaitsab
Verwijderd schreef op maandag 02 juni 2014 @ 20:39:
Dat denk ik ook.
Die 2 punten die ik beschrijf, heb je daar behoefte aan?
if (!coffee) {
Work = false; }
naaitsab schreef op maandag 02 juni 2014 @ 20:51:
Dat denk ik ook.
Ja. Dat was de bedoeling. Betere grafics en fps.
  • naaitsab
Verwijderd schreef op maandag 02 juni 2014 @ 20:53:
Dan zal je het wel gaan merken.
Zie: http://www.guru3d.com/art...gtx_760_sli_review,1.html
if (!coffee) {
Work = false; }
Thx!
Dan enkel de voeding ook nog veranderen. Zit met een xfc 550w
  • naaitsab
Verwijderd schreef op maandag 02 juni 2014 @ 21:08:
Thx!
Als je een upgrade wil uitvoeren en wat meer info wil zou ik bij Componenten Aankoopadvies eens rondneuzen. Daar is dit topic niet echt voor geschikt ;)
if (!coffee) {
Work = false; }
  • HarmoniousVibe
Metalbuster schreef op dinsdag 01 april 2014 @ 16:46:
Dan moet je een 6->8-pins verloopje hebben.
Of zou ik naar een gtx 770 of 780 gaan?
  • TunefulDJ_Mike
  • Laatst online: 10-08 16:17
Zo sinds de update naar 340.25 is krijg ik geen 60hz meer op me UHD scherm (pricewatch: Philips P-line 288P6LJEB Zwart). Iemand hier ervaring mee, ik heb de laatste week gewoon op 60hz kunnen draaien, sta nu weer terug op 30hz en wordt er lichtelijk gestoord van.
Today me will live in the moment unless it's unpleasant in which case me will eat a cookie
  • Thomg
  • Laatst online: 16-11 16:03
Thomg
Aww yiss
TunefulDJ_Mike schreef op vrijdag 01 augustus 2014 @ 14:20:
Dan downgrade je toch?
  • TunefulDJ_Mike
Zojuist gedaan krijg hem niet meer terug op 60hz... Ga even clean install van de nieuwe Nvidia drivers doen.
Viel me overigens op dat ik bij Change Resolution in Nvidia Control Panel alleen 4k kan kiezen bij Ultra HD, HD, SD en niet meer bij PC.
Update 1
Na herinstallatie van me drivers, en 2 reboots (?) kan ik nu eindelijk weer met 3840*2160 selecteren onder pc en hem op 60hz zetten.
Update 2
Zojuist na het aanzetten van me computer toch weer terug op 30hz, na reboot is het probleem opgelost, iemand enige idee wat er fout gaat ?
[ Voor 49% gewijzigd door TunefulDJ_Mike op 01-08-2014 21:18 ]
  • Daniel.
  • Laatst online: 09:45
Jeuj, nooit geweten dat DSR voor de 7xx serie uit zou komen.
http://www.nvidia.co.uk/d...rResults.aspx/78903/en-uk
Leuk dat dat nu ook kan met de oudere serie!
<GoTHC>Daniel#23781 | Mijn PC
