Configuring Achieva Shimian QHD270 with X Windows and nvidia Driver
The Achieva Schimian QHD270 (a.k.a. Catleap and Crossover QH270) may not auto-configure with nvidia driver under X Windows. It appears that the EDID response is not quite correct or compatible with the nvidia driver and so the driver fallsback to a very low resolution default. The following xorg.conf can be used to force the correct resolution of 2560x1440@60.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41Section "Monitor" Identifier "Monitor0" VendorName "Shimian" ModelName "QHD270" HorizSync 88.8 VertRefresh 59.5 Option "DPMS" Modeline "2560x1440" 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync DisplaySize 597 336 EndSection Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "GeForce GTX 460" EndSection Section "Screen" Identifier "Screen0" Device "Device0" Monitor "Monitor0" DefaultDepth 24 Option "NoLogo" "True" Option "TwinView" "1" Option "TwinViewXineramaInfoOrder" "DFP-0" Option "UseEDID" "False" Option "UseEDIDDPI" "False" Option "UseEDIDFreqs" "False" Option "ExactModeTimingsDVI" "True" Option "metamodes" "2560x1440_60 +0 +0, 2560x1440_60 +2560+0" SubSection "Display" Depth 24 EndSubSection EndSection Section "ServerLayout" Identifier "Layout0" Screen 0 "Screen0" 0 0 Option "Xinerama" "0" EndSection
Note that this example configuration actually uses dual Shimian monitors via NVidia's TwinView feature. The two TwinView lines can be commented out or removed and the metamode option can be edited to remove the second monitor resolution and offset.
Ik heb de ACHIEVA QH270-LITE van green-sum. De prijs was €238,28,- incl verzenden en voor het invoeren moest ik €90,30 betalen.
Ik heb 3 dode pixels, waarvan er 2 niet zichtbaar zijn op op 40 a 50 cm afstand en 1 wel zichtbaar, gelukkig zitten de dode pixels aan de rand en heb er geen last van.
Linkje
Voor de diegene die (Archi)CAD gebruiken een screenshot wat je kan verwachten qua werkruimte
Linkje
[ Voor 17% gewijzigd door reinier.sr op 09-10-2012 22:39 ]
3 oktober betaald en 10 oktober is die nog steeds verzonden, enige reactie is dat die een "perfect" monitor wil sturen...
Het is een scheur in het glas
Wat zou ik het beste kunnen doen?
vandaag eindelijk opgestuurd!trekker22 schreef op woensdag 10 oktober 2012 @ 14:35:
dream-seller is ook niet een van de rapste...
♥ Klik hier ! | Mijn V&A advertenties | Join het DPC Whatpulse team♥
173,88 voor import van 3x crossover!BabyXL schreef op woensdag 03 oktober 2012 @ 16:50:
Leg ook ff geld opzij voor invoerheffing. Zal ook wel een kleine 200 zijn denk.
Sinned123 schreef op donderdag 04 oktober 2012 @ 22:38:
Sinds kort ook op dit topic gestuit en twijfel nu zelf ook zo'n monitor aan te schaffen.
Ik merk vooral dat de meeste hem zonder HDMI en dus scaler kopen.
Hij is echter voor boven en wil er niet nog eens een tv naast hebben.
Nu ben ik op de Wecube-ST2770W gestuit, met import heffingen komt ik uit op 380euro.
Correctie / toevoeging op mijn eigen reactie:joopv schreef op vrijdag 05 oktober 2012 @ 10:08:
[...] Voor die eisen en prijs zou ik niet twijfelen en zonder meer 200 euro meer afschuiven voor een Dell U2711, met de zekerheid van 3 jaar onsite garantie, een lokale leverancier en een degelijke fabrikant.
Van deze koreaanse dingen is het maar afwachten wat de failure rate gaat worden de komende 3 jaar. Ik heb daar geen goed gevoel over. Zijn er ergens hires foto's van het binnenwerk?
Een Dell U2713 heb je al voor 520, dus dat is geen 200 maar 140 euro duurder.
pricewatch: Dell Ultrasharp U2713HM Zilver, Zwart
Wel apart om te zien dat het geheel breukvrij aankomt alleen in de monitor doos verpakt...
De douane kosten vielen met 44 euro heel erg mee via EMS/TNT
[ Voor 17% gewijzigd door HeyDude op 21-10-2012 16:43 ]
je kan hem hardware matig iets omlaag zetten, maar het is nog steeds wat vermoeiend voor de ogen...
tips?
Maar ik heb een laptop met een VGA poort en HDMI kan ik dan me laptop erop aansluiten
na een paar dagen lijkt de sterkte iets te zijn afgenomen en/of zijn mijn ogen er meer aangewend....trekker22 schreef op vrijdag 26 oktober 2012 @ 15:46:
heb 3x 27" crossover q hier staan.... erg mooie monitors echter de brightness is wel echt insane...
tips?
Een desktop van 7680 x 1440 is wel even wennen, maar als je goed efficiënt indeelt heeft het wel voordelen!
Volgens mij kan f.lux er iets aan doen?trekker22 schreef op vrijdag 26 oktober 2012 @ 15:46:
tips?
Nee. Volgens Darkstone (de laptop-expert) is dat alleen mogelijk met een Alienware m17x met 7970m (zonder IGP-wissel dus) en een Nixeus Vue (een 1440p-monitor die het volledige signaal over HDMI kan ontvangen). Dus _waarschijnlijk_ niet.Verwijderd schreef op zondag 28 oktober 2012 @ 15:11:
Hallo, Ik ben nieuw hier en wil ook graag z'on QHD scherm kopen voor rond de max van 250 euro
Je enige optie zal een regulier 1080p-scherm zijn als je 27 inch wil.
(De Nixeus Vue is duurder dan de monitoren uit dit topic, dacht iets rond de 400 euro)
P.S. f.lux is echt awesome, mijn scherm vind ik nu véél te blauw zonder. Het verandert alleen de kleur, de warmte, van je beeld, niet de helderheid. s'Nachts heel warm, overdag minder, snapje?
[ Voor 12% gewijzigd door deraco96 op 28-10-2012 15:36 ]
01101000 01100001 01100100 00100000 01101010 01100101 00100000 01101110 01101001 01101011 01110011 00100000 01100010 01100101 01110100 01100101 01110010 01110011 00100000 01110100 01100101 00100000 01100100 01101111 01100101 01101110
getest snel maar vond het niet echt veel doen...?
Je moet volgens mij wat in de instellingen prutsen. Het zorgt er standaard voor dat het beeld wat gelig wordt in de avond, om wat rustiger te zijn voor de ogen. Volgens mij kon je dit echter ook uitzetten en vervangen door een permanente lagere helderheidtrekker22 schreef op zondag 28 oktober 2012 @ 15:42:
Ow jammer ik had graag genoten van een hoge resolutie heb nu een 13 inch sony vaio met een GT640mderaco96 schreef op zondag 28 oktober 2012 @ 15:35:
Naja dan maar kijken naar eentje met hdmi
En hoe stuur je e.e.a aan? Qua GPU's bedoel ik..trekker22 schreef op zondag 28 oktober 2012 @ 15:16:
En uiteraard zijn foto's van dit soort mooie setups altijd welkom
Als het niet voor gamen is voldoet 3x actieve dp naar dvi of als de schermen dp hebben dp naar dp.DRAFTER86 schreef op zondag 28 oktober 2012 @ 16:24:
Elke kaart die het bovenstaande heeft kan dat.
Als je wel wilt gamen heb je bovenstaande + veel vram nodig 2GB+
het is niet voor gamen, puur office; aangestuurd met 2x GTX 460 in SLI....DRAFTER86 schreef op zondag 28 oktober 2012 @ 16:24:
zal binnenkort eens pic plaatsen als iemand een echte mooie 7680x1440 wallpaper kan aanwijzen!
Verder komt er nog een mount uit de USA om de 3x 27" op kwijt te kunnen, staat nu bij de douane!
Zoek eens op Google Images naar 7680x1440.trekker22 schreef op zondag 28 oktober 2012 @ 23:38:
Voorbeeld: http://kops.nu/Bakgrunder...7680x1440%20Wallpaper.jpg
Voor zover ik weet krijg je juist bij FedEx de rekening pas achteraf, bij DHL moet je het gelijk bij aflevering aftikken. Ik heb mijn Catleap met DHL laten verzenden en had geluk, hoefde niets bij te betalen.Intru schreef op zondag 25 november 2012 @ 12:11:
Zit er nu toch ook serieus aan te denken om zo'n scherm te bestellen, waarschijnlijk wordt het de Crossover. DHL verzending lijkt niet zo handig, gezien de negatieve verhalen hier over veel bijbetalen achteraf.
Hoe heb je dat voor elkaar gekregen? Als gift of lage bedrag opgegeven?MiBe schreef op dinsdag 27 november 2012 @ 00:41:
Helaas heb ik wel 60€ moeten betalen voor het invoeren, maar het is dan nog steeds met een totaal van 400€ een stuk goedkoper dan het alternatief van Dell of Apple
Op de monitor is geen schade te bekennen en ook nog geen dead/stuck/bright pixels gezien. Alleen de meegeleverde DVI kabel was aan de korte kant dus heb me bureau wat moeten verbouwen. De beeld kwaliteit is geweldig en kan iedereen aanbevelen om zo'n ding te kopen.
Ik heb nergens om gevraagd maar ze hadden het zelf al 150 dollar als waarde opgegeven terwijl hij in het echt natuurlijk het dubbele kostte. Volgens mij moet je over 150 dollar normaalgesproken ook invoerrechten betalen maar als je geluk hebt bij DHL glip je erdoor schijnbaar. Bij FedEx controleren ze volgens mij een stuk beter en krijg je altijd een rekening.Progeny schreef op zondag 02 december 2012 @ 09:28:
Voor de goede orde, ik heb een achieva Q270 Lite.
Kunnen nl winkels nog wat van leren.
Ik heb net mijn zeer goed ingepakte Crossover uitgepakt en aangezet. Wow was zo'n beetje het eerste wat ik kon zeggen.
Ik heb in ieder geval een voorraad bubblewrap voor een jaar
Maar wat een scherm zeg, ik moet wel even wennen aan de hoeveelheid licht dat het scherm afgeeft, maar waarschijnlijk kan daar nog wel het nodige aan getweaked worden. Als iemand daar tips over heeft, dan hoor ik dat graag.
Verder heb ik geen dead pixels of stuck pixels, dus daar ben ik heel blij mee.
Enige minpuntje op dit moment is de backlight bleeding.
In ieder geval kan ik AccessoriesWhole ondanks de maffe naam aan iedereen aanraden.
Als ik naar zijn feedback kijk zit het wel snor met deze verkoper. Nog een paar dagen wachten.Intru schreef op vrijdag 07 december 2012 @ 11:40:
Ik vrees toch dat ik contact met Paypal op moet gaan nemen, Astrobile reageert nog steeds niks, ik heb nog steeds geen tracking nummer, en dus ook nog geen monitor. Iemand nog andere tips?
Was ook mijn idee ja. Maar het blijft raar dat een verkoper een week lang niet reageert, je geen tracking nummer hebt, en 2 weken na de bestelling ook nog steeds geen scherm.joopv schreef op zaterdag 08 december 2012 @ 07:09:
Ik heb iig via eBay contact opgenomen (via de 'he, ik heb nog steeds niks ontvangen'-optie), hopelijk hoor ik gewoon wat van hem en heb ik m'n scherm volgende week binnen.
Kan van het weer / decemberdrukte afhangen. Als FedEx bezorgt is het ook vaak genoeg 'Vandaag besteld, overmorgen in huis' (vanuit HongKong)Intru schreef op donderdag 13 december 2012 @ 09:56:
Sinds 8 december staat m'n scherm nu in GuangZhou (China). Iedere dag komt er weer een FedEx update, maar hij blijft daar maar hangen. Zal vast iets met customs te maken hebben, maar toch jammer dat 't zo lang duurt.
Het is voor mij een behoorlijke upgrade, ik had 2 x 19" (1280x1024) staan, en heb 1 van deze schermen nu vervangen door een Crossover. Wow, wat een verschil! M'n andere scherm lijkt nu ineens enorm flets en pixelig.
Natuurlijk heb ik direct even foto's gemaakt:
Hoe zit het met de invoer kosten? Ik koop nog wel eens aardig wat dingen uit china (legaal en illegaal spul). Maar heb nooit wat hoeven te betalen.
Heeft iedereen hier moeten betalen of niet:p?
[ Voor 98% gewijzigd door Brazos op 25-11-2021 22:57 ]
Zijn ze er misschien ook nog zonder speakers en met lift pivot swing? Want het lijkt mij dat ze dan zonder speakers weer goedkoper zijn.
Er staan een aantal op http://stores.ebay.nl/Acc.../_i.html?_fsub=5015903015 , ik heb ze zelf ook overwogen maar ben uiteindelijk toch voor de 27Q gegaan (1440 hoog). De prijs schiet omhoog van 27->30 inch.Hatsieflatsie schreef op zaterdag 22 december 2012 @ 20:11:
Die zoek ik dan ook, hoe groter, hoe beter.
[ Voor 20% gewijzigd door C0rnelis op 22-12-2012 20:53 ]
Kijk hé, 2560x1440 kun je voor dat prijs krijgen.
Wil je vervolgens één pietluttige 160 pixels verticaal erbij, dan betaal je een prijs waar je 3 KEER 2560x1440 pixels voor kunt krijgen
[ Voor 55% gewijzigd door Hatsieflatsie op 22-12-2012 23:54 ]
Vrijdag 21 december verzonden om 06:40 in Seoul.
Maandag 24 december ontvangen om 11:10 in Oudenbosch.
Wat een snelle service
Moest net wel 48,72 belasting/import betalen helaas. Direct aan de deur met DHL.
Laat hem nog even in de verpakking tot 2e kerstdag
[ Voor 25% gewijzigd door ralph0603 op 24-12-2012 11:35 ]
Dat is dan best snel! Mijn Crossover met FedEx doet er 10 dagen over. Niet echt een reden tot klagen, maar traag vergeleken met anderen.ralph0603 schreef op maandag 24 december 2012 @ 11:34:
Mijn monitor is net geleverd door DHL. Achieva Shimian 27Q-Lite.
Wat een snelle service![]()
Iemand misschien nog suggestie's van wat ik kan proberen? Tot mijn kabeltje binnengekomen is en ik dit kan uitproberen?
EDIT:
Is er niet bijv een reset knop ergens op de catleap?
[ Voor 4% gewijzigd door volton10 op 26-12-2012 17:57 ]
Ziehier de reden waarom zulke monitoren zo goedkoop zijn.4everfun schreef op woensdag 26 december 2012 @ 17:31:
Nu al ruim +- 100 dagen een Yamakasi catleap in bezit en opeens houdt het scherm ermee op. Tenminste, alles werkt pc herkent hem alleen geeft hij nu zwart beeld. Driver's geupdated, af laten koelen, klooien met pc instellingen maar niks hielp. Nu een nieuwe DVI-D (dual) kabeltje besteld want ik gebruikte voorheen de standaard (niet zo'n hele goeie) die erbij werd geleverd. Plotseling deed hij het niet meer. Ik liet hem letterlijk staan zoals ie was en na een korte wandeling was het scherm zwart en bleef hij dit ook.
EDIT:
Op andere fora's schijnt dat dit soort monitoren vaker met dit soort problemen kampen. Het is dan echt einde oefening, vrees ik...
Eventueel kun je bij de leverancier nog enige coulance proberen eruit te peuteren.
Ik weet niet of je er iets van af weet, maar ik zou zeggen kijk de condensatoren eens na. Zou kunnen dat het daar aan ligt. Als die wat 'bol' staan weet je voldoende en kan je ze eens vervangen door nieuwe.4everfun schreef op woensdag 26 december 2012 @ 17:31:
EDIT:
Maar probeer eerst die andere kabel, wie weet is het voldoende.
Nu wachten op mijn nieuwe kabel en als dat het probleem niet oplost maar proberen terug te sturen.
Iemand enig idee of hier nog garantie op zit na ongeveer 100 dagen?
Laat ik hem maar niet open maken want van monitoren weet ik vrij weinig.
Het wordt sowieso een duur grapje
Erg balen dit.
Volume. Er worden VEEL meer 16:9 monitors gemaakt dan 16:10.Hatsieflatsie schreef op zaterdag 22 december 2012 @ 23:51:
Tering... zoveel prijsverschil. Soms zelfs het driedubbele.
Een Dell U2713HM heeft nu volgens de PW een bodemprijs van 513 euro. Is dat "ruim goedkoper" of gaat de vergelijking mank?
Nope, zie intru reactie. Had 0 verzendkosten en gevraagd of hij een bon erop wilde plakken dat de waarde 200$ betrof.joopv schreef op vrijdag 28 december 2012 @ 10:23:
Crossover 27Q LED-P bij accessorieswhole kost nu 350 dollar, daar komt nog 100 shipping en 50 garantie bij. 500 dollar is 378 euro, inclusief die 88 euro wordt dat 466 euro.
Mijn naheffing voor import was toen 48 euro
Tel uit je winst. (al met al 380 betaald oid)
Ik heb ook lang getwijfeld om een Crossover te kopen of een tweedehands U2711, het is het laatste geworden en ik ben er zeer blij mee (bovendien heb je bij Dell standaard premium garantie 3 jaar).
Het is mij nog allemaal te tricky wat betreft garantie afhandeling etc. met de Koreaanse import producten.
Tja, internetaankopen zitten altijd risico's aan. Maar sinds deze schermen niet anders te verkrijgen zijn en de sellers het allemaal via eBay doen, zijn ze ook aan reputatie daar gebonden. Slechte reviews kunnen ze niet gebruiken, dus zijn ze (de grotere) over het algemeen heel coulant en oplossingsgericht als er iets niet in orde blijkt te zijn.t!n0 schreef op maandag 31 december 2012 @ 12:32:
Kun je dus, wat mij betreft, beter kijken voor een nette tweede hands U2711 of U2713 voor ~400-450euro.
Zo kwam mijn doos ook gebutst aan, heb hem voor het openen gelijk gemailed en daarna pas foto's gemaakt voor & tijdens het openmaken + Scherm aan.
Scherm functioneerde prima, dus leek daarmee afgedaan te zijn. 's Avonds vond ik toch dat er een vreemde backlight bleeding in zat. Gelijk weer foto's gemaakt maar bij het schuiven van mijn scherm op m'n bureau zag ik het verdwijnen. Voorzichtig wat de randen naar achteren gedrukt en het was weg. Misschien toch nog een naslag van het stuiteren in de doos oid.
Inmiddels staat hij al trots bijna 5 maanden in huis.
[ Voor 24% gewijzigd door LinuX-TUX op 31-12-2012 14:48 ]
De feedback wordt onmiddelijk na de transactie gegeven, en gaat voornamelijk over de afhandeling van de transactie. Daar heb je dus maar weinig aan voor beoordeling van de kwaliteit van de verkochte items.
Niet helemaal mee eens. Jij impliceert nu dat mensen geen verhaal zouden gaan halen als een product na een jaar ermee kapt. Overigens haal je nu 2 dingen door elkaar, product vs reseller.joopv schreef op dinsdag 01 januari 2013 @ 13:50:
Een goede reputatie van de verkoper beschermd je nauwelijks tegen producten met een inferieure kwaliteit, die het na een veel te korte levensduur voor gezien houden.
Een gedegen reseller zal je wel tegemoet komen. En daarbij (even afkloppen) werkt mijn scherm nog steeds prima. Geen (extreme) backlight bleeding en geen grauwe vlekken/verkleuringen.
Overigens kunnen defecten bij gerenomeerde merken net zo goed voorkomen. Wat is dan het verschil? Kijk naar apple's antennagate t/m niet werkende microfoons heden ten dage. Duur en top kwaliteit spul (als het werkt)
Bottomline, dit zijn goedkope monitoren met als enige pluspunt dat het paneel wat erin zit hetzelfde is als die van Apple's Cinema Displays icm de prijs. En als het prijsverschil idd dusdanig klein wordt om een Dell versie te kopen, dan zullen toekomstige kopers dit echt wel meenemen in hun overweging ( we zitten immers op tweakers
PS: ..die het na een veel te korte levensduur voor gezien houden. Is dat ergens op gebaseerd. Niet op "ja er zijn er een paar op internet ...." maar meer van getallen in uitval/problemen tegenover getallen van uitval tov Dell monitoren?
[ Voor 99% gewijzigd door Brazos op 25-11-2021 23:02 ]
Ben wel tegen een klein probleempje aangelopen bij de Crossover. De veer voor de hoogte-instelling lijkt wat te sterk te zijn in mijn uitvoering, waardoor hij de neiging heeft om constant naar hoogste stand te springen. Misschien moet ik er maar een baksteen op leggen...
Zijn er nog mensen die positieve of negative dingen kunnen zeggen over dit model?
Ik ben er tot nu toe erg tevreden over. Mijne is pixel perfect (maar niet zo besteld), en heeft een klein beetje backlight blead aan de onderkant. Enige probleem tot nu toe: de veer voor de hoogte-instelling is te sterk, waardoor hij soms ineens terugschiet naar de hoogste stand...deathsniper schreef op maandag 21 januari 2013 @ 14:55:
Hey ik ben van plan om de Crossover 27Q LED-P Perfect Pixel van accessorieswhole te kopen (beste ervaringen bij die persoon volgens meeste forums) .
De laptop die ik heb is een clevo w860cu met een amd 6970m (gebaseerd op een desktop 6850).
Met HDMI en DVI-I aansluiting.
[ Voor 14% gewijzigd door Pentiummania op 03-02-2013 19:14 ]
Mja ik zag al ze al vanaf 250 euro voor een 27'' met alleen maar dvi en leek mij die wel interresant.
Maargoed ik zal wel even kijken hoe of wat. Een met meerdere aansluitingen kost al snel 350. Maar voor dat geld haal ik dan liever een vertrouwde dell ultrasharp. (heb daar al 2 van en die doen het nog perfect ookal zijn ze al 7 en 6 jaar oud).
Ik kan wel leven met slechts 1 DVI aansluiting.
Zit serieus na te overwegen om mijn 2 * HannsG 28" te vervangen door 1 * 30".
Heeft mijn 3-way GTX ook iets te doen
Bij laptop is niet dvi-d of dvi-i het probleem, maar of het didgitale gedeelte dual link is. Wat ik begrepen heb zijn er maar heel erg weinig laptops met een dual link dvi-d of dvi-i uitgang en alleen die kunnen deze schermen aansturen.Chaosstorm schreef op zaterdag 02 februari 2013 @ 16:10:
Mij lijkt zo'n beeldscherm ook erg interresant.. maar weet ik niet 100% zeker of dat op mijn laptop DVI-I aansluiting gaat werken aangezien ze op ebay nadrukkelijk zeggen dat het DVI-D moet zijn. Ik weet dat DVI-I ook D ondersteund maar hebben ze het ook over een "bypassboard" en heb ik geen idee hoe of wat..
Dus controleer of je een laptop hebt met dualink dvi, zo niet dan kun je het scherm niet native aansturen.
De mijne heeft dus geen display port
Ik heb een 30q5 gekocht, het beeld bevalt perfeect. Geen dooie pixels. Op overclock heb ik ook wat foto's gepost.Zanac-ex schreef op dinsdag 05 februari 2013 @ 14:50:
Iemand ervaring met de Crossover 30Q5?
Ik heb er verleden week 1 besteld, volgens Fedex nog steeds in transit.Pentiummania schreef op maandag 11 februari 2013 @ 09:46:
Kan je ons vertellen wat je kwijt was aan bijkomende kosten bij de deur ?Pentiummania schreef op maandag 11 februari 2013 @ 09:46:
en bij welke ebay seller
[ Voor 4% gewijzigd door bdevogt op 11-02-2013 12:07 ]
Accessorieswholebdevogt schreef op maandag 11 februari 2013 @ 12:01:
Fedex belde me verleden week of het zakelijk of prive is, het laatste is het geval dus ik verwacht een heffing.
Ik hoop dat de monitor vandaag of morgen aankomt en dat kan ik de vraag beantwoorden.
thnxZanac-ex schreef op maandag 11 februari 2013 @ 12:55:
Accessorieswhole
Keurig verpakt,
De bouw kwaliteit van de monitor valt me 100% mee, alleen de voet had iets stabieler gemogen.
Van het weekend de monitor kalibreren maar wat een verschil tov van mijn oude HannsG 28".
Fedex komt helaas pas later met de heffing........
Kleine update, even aan het spelen met de monitor:
Brightness is gewoon Brutaal, (gelukkig) ook het enige wat is af te stellen afgezien van de aan/uit knop.
Kleuren zijn echter neutraal, kijk hoek is gewoon geweldig en backlight bleeding is minimaal.
Geen dode/Stuck pixels.
Nog niet aan Photoshop toegekomen (maar bezig om de woonkamer na te bouwen in Sketchup en daarna een beetje liefde in PS want de vrouw wil een nieuwe bank en gordijnen) en dat word een goede test.
Metro2033 is een openbaring op deze resolutie op Very High in 2560*1600 geen DOF & AA (3way-SLI GTX680)
Heel blij, een Ferrari voor de prijs van een FIAT met hopelijk de betrouwbaarheid van de zon. (Default Brightness is Tsar Bomba niveau)
[ Voor 54% gewijzigd door Zanac-ex op 15-02-2013 22:12 ]
Ik kreeg een paar maanden geleden ineens een brief van een deurwaarder in naam van FedEx die vond dat ik moest betalen. Natuurlijk even een mailtje gedaan met de betalingsbewijzen en sindsdien niets meer gehoord.
* Cybergamer is nog steeds happy met de Crossover
[ Voor 9% gewijzigd door Cybergamer op 20-02-2013 09:12 ]
Dit was 2,5 maand geleden...
* en ook nog steeds superhappy met de Crossover
[ Voor 15% gewijzigd door ijsco op 22-02-2013 22:52 ]
Zal mij niets verbazen als er ineens een deurwaarder op je stoep staatijsco schreef op vrijdag 22 februari 2013 @ 22:49:
Bij mij is het andersom, ik kreeg een flutblaadje (soort kopie van een printje) als rekening, dus ik had zoiets van ik wacht wel even op de herinnering.
(aankoop + verzending) * 1,14 * 1,21bdevogt schreef op maandag 11 februari 2013 @ 12:01:
14% Importbelasting op LCD monitoren (zie onder "erga omnes")
21% BTW
En dan nog mogelijk een zakcentje voor de moeite van het bekijken van je waren.
2560x1440 monitoren die inclusief verzendkosten zo rond de €360 uit komen voordat ze door de douane zijn, met bijv. DisplayPort of andere geavanceerde fratsen kan je beter in Nederland kopen. Zit je ook met garantie aanvragen ook niet aan hoge verzendkosten.
[ Voor 16% gewijzigd door Henk Poley op 27-02-2013 17:42 ]
De film is hier te koop al is hij tevens via de andere bekende weg te vinden.
Zie foto's:
http://nl.hardware.info/f...nt.php?attachmentid=19064
http://nl.hardware.info/f...nt.php?attachmentid=19063
Bij welke verkoper heb je gekocht en heb je al een berichtje gestuurd/reactie gekregen?
Bij wie heb je die gekocht?Ruudje88 schreef op maandag 18 maart 2013 @ 21:07:
Ik heb mijn Crossover 27Q vandaag binnen gekregen en ben tot de conclusie gekomen dat ik beter een U2713HM had kunnen kopen voor €140 euro meer. Ik heb ongeveer 40/50 dode pixels.
Zie foto's:
