Windows Phone Mango RTM (build 7720) is "uitgelekt" op de website van XDA Developers . Een aantal gebruikers meldden al een succesvolle update procedure.
Voor diegene die ook zijn Windows Phone 7 toestel wil updaten naar Mango, is hieronder te vinden hoe.
De update instructies:
You do the following steps at your own risk. The possibility to brick your device is low but it is there.
What you'll need:
A phone with NoDo (7392), 7661 (Dev Beta) or 7712 (Dev Beta Refresh)
Micro USB cable
At least 20GB free space on C:\
External harddisk or USB-Stick with up to 16GB free space
Around 1,5 to 2 hours time
1. Copy the content to your local PC
2. If your Zune-Software is not Version 4.8.2134.0 deinstall it
3. Install Beta-Zune (4.8.2134.0) from the Zune directory (StartZuneLocal.exe)
4. Install the flashing-tool "updatewp" from Zune\04.08.2134.00\UpdateTool. Install the right Version (x86 or x64)
5. Connect your Phone via USB to your PC
6. Close Zune if it opens
7. If your phone is build 7661 or 7712, continue with Step 18
8. Run "ISV-Provisioning_Live.exe" from the directory "NoDoToRC" as Administrator
9. The provisioning tool starts to back up your phone. This may take some time
10. Your phone will now restart and be configured to use a special update-server. If needed enter your PIN or you won't be unable to continue.
11. Close the tool only, when it says 'Succeeded'.
12. You can find your Backup in "C:\Users\<user>\AppData\Local\Microsoft\Windows Phone Update". Copy the folder with the last creation-date to a safe place (for instance your external harddisk). Without this Backup you will be unable to use your OEM's update later in fall.
Now repeat: "I have backed-up my backup"
13. Start the Zune-Client (with your phone connected) and search for updates.
14. An update (7403) will be found and installed. If needed enter your PIN when your phone restarts. Do NOT
disconnect your phone.
15. Zune will check for more updates and will update your phone to 7712
16. Congratulations: You're now close to RTM ;-)
17. Close Zune
18. Copy the directory "RCTtoRTM" to C:\. Only there!
19. Go to C:\RCToRTM and run ISVTo7720.bat as Administrator (with your phone still connected)
20. Various updates will install now. Your phone might restart a couple of times. Enter your PIN whenever needed.
21. If everything worked you now have a Mango-RTM phone.
22. Make sure your backup is still there
23. Use Mango and show it to your friends :-)
Ondergetekende heeft bovenstaande eveneens succesvol uitgevoerd op mijn HTC HD7. Mijn ervaringen met Mango zal ik later posten in een uitgebreide review.
Meer ervaringen van Tweakers zijn meer dan welkom
What you'll need:
Micro USB cable
17. Close Zune
[ Voor 4% gewijzigd door LCP op 03-09-2011 14:46 . Reden: URL's verwijderd door mod. ]
Microsoft Surface Studio | Asus Z690-A, 16GB Corsair RAM, Intel Core i7-12700, Windows 11 Pro x64
