• Cobesz
  • Laatst online: 16-10 20:26
  • Kortfragje
  • Laatst online: 15-11 22:27
Vandaag is Cyanogen 7.0.2 relaesed, de changelog:
Common: Fix issue with missing built-in themes
Common: Update bundled ROM Manager to latest version
Supersonic: Actually fix GPS
Supersonic: Fix proximity and light sensor
en 7.0.1
7.0.1
Common: Fix fling velocity of status bar and ADW swipe - Sven Dawitz
Common: Fixed webview layout bug (issue 3229) - Zinx
Common: Fix GVoice-opens-twice bug - Zinx
Common: Fix issues on all devices with DNS resolution failure after some time - Zinx, various
Common: RTL improvements - Eran Mizrahi, Eyad Aboulouz
Common: Fix crashes in Arabic locale - Eyad Aboulouz
Common: Add Arabic keylayout - Eyad Aboulouz
Common: Improve ADWLauncher scrolling/zoom performance - Pavel Kucera
Common: Fix excessive memory use when appending to textviews - Cyanogen
Common: New wallpapers from the CM community (CC License, see app for credits)
Common: Option to disable vibration while in-call - Evan Charlton
Common: Add long press option to status bar widgets for settings - Alex Avance
Common: Compact carrier and status bar tweaks - Nihanth Subramanya, rorifree
Sholes: Fix connectivity loss bug - cvpcs
Speedy: Fix keyboard lights - JD Horelick
Glacier: Fix backlights - Zinx
Glacier: fix GPS issues - Zinx/QCom
msm7x30: Fix bugs during video resume - Zinx
qsd8x50: Fix 720p video playback
qsd8x50: Unified 2.6.37 kernel - Cyanogen, toastcfh, slayher
Espresso, Legend: WiFi fix (HTC)
Supersonic: Fix GPS issues (HTC)
msm7227: Fix GPS issues - Alex Hofbauer
Click: Fix recovery kernel and compilation. Now works well with latest code - KalimochoAz
Click: Speed up internet connection - KalimochoAz
Blade: Update kernel to match Gen2 Radio - kallt_kaffe
Blade: Update libaudio to fix SIP audio routing and microphone mute - Tom Giordano
Veel plezier :)
http://www.gjpvanwesten.nl
Heeft er iemand idee waarom de htc dream op CM 6 blijft? :'(
  • Kortfragje
Jah, op het cyanogenmod forum staat het volgende.
As for 1/17/10 CM7 for DS is non-existent.
Cyanogen was the main maintainer for this device, and has ceased development of CM-DS for multiple reasons, including but not limited to:
* Age of hardware
* Lack of personal use of DS
* AOSP lack of support
Now, he has stated publicly (in IRC, XDA, and Twitter) that if a new developer is open to stepping up and taking on the task of fully maintaining the DS branch, he has no qualms about continuing support.
A lot of you are familiar (and have asked) why we don't just have/ask Ezterry and Firerat to take over maintainership. While I like this idea, it would be up to them to decide if they wanted to do so, and, personally, I wouldn't want to feel like CM squashed their creativity and personal efforts. They are doing their own thing right now, and deserve all the props to them for it. If they want to take part in CM, then awesome, we'd welcome it. But thats gotta be a choice they make. Their work can be found on XDA, and is currently your best chance of a 100% Gingerbread install for the DS line.
dus vnml oude hw en geen developpers beschikbaar voor deze variant
  • Dennis_k
  • Laatst online: 24-11 21:37
7.0.2 zonder problmen geinstalleerd. Heerlijke ROm is dit. Batterij duur is nu gegaan naar 1% per uur.
  • anandus
Kan ik 7.0.2 gewoon over 7 final heen installeren?
Via rom manager de zip kiezen en dan geen wipe doen en dan is alle tof? :)
  • Kortfragje
Ik heb zojuist de 7.0.2 geflasht over 7.0.0 heen. (zoals ook op het cyanogen forum wordt aangeraden , stap 1 backup, stap 2 flash google apps worden automatisch meegenomen). ik heb dit via de recovery van clockworkmod gedaan.
Voor zover ik kan zien werkte dit perfect en zit nu op 7.0.2. Voor de changelog van 7.0.1 en 7.0.2 zie het CyanogenMod topic.
dus..... JA :D
  • Dennis_k
Welke launcher gebruiken jullie bij CM7?
Twijfel constant tussen ADW launcher EX of Launcher Pro.
  • krijn1985
  • Laatst online: 13:56
Dennis_k schreef op vrijdag 29 april 2011 @ 12:53:
Ik gebruik Launcher Pro. Vond het meer aan mijn wensen voldoen. Heb na het installeren van Launcher Pro en deze instellen als standaard ADW er ook weer afgegooid.
  • Azaruc
  • Laatst online: 15-11-2025
Ook LauncherPro (plus) hier. Voornamelijk voor het aantal docks eigenlijk :) (Of ik heb een instelling gemist in ADW..)
Moet eigenlijk nog een hele berg standaard apps eraf gooien.
D3 Profile
  • Ultraman
  • Laatst online: 24-11 13:34
Ultraman
Boefje
Go Launcher EX slaat hier doorgaans de klok. Helemaal nu de scroll functionaliteit uit Zeam Launcher gehaald is...
  • Kortfragje
LauncherPro plus hier.. Idd aantal docks ook.. Maar heb wel last van een FC bij boot, weet niet waarom eigenlijk..
  • Eypo
  • Laatst online: 20-11 15:58
ja dat heb ik ook!
En ik heb steeds last van dat mijn SDkaart ontkoppeld is volgens sommige programma's, maar ik kan wel muziek afspelen en de A2SD werkt ook. Maar gallerij dan weer niet. Strange. Ik denk dat ik mijn CM toch maar voor iets simpels ga vervangen.
  • Kortfragje
Hmm, die ontkoppelde SD kaart heb ik dan weer helemaal geen last van... Heb je al op het CyanogenMod forum gekeken voor eventuele hulp daarmee?
  • Azaruc
Kortfragje schreef op zaterdag 30 april 2011 @ 17:08:
Dit heb ik ook. Ook moet ik de niet-LPP widgets vaak na het opstarten opnieuw toevoegen aan m'n homescreens omdat deze niet meer geladen kunnen worden. Zeker bij widgets met veel instellingen (Minimalistic text bijv.) kost dit redelijk veel tijd.
Als iemand hier een oplossing voor weet zou dat zeer welkom zijn :)
D3 Profile
  • Kortfragje
Het vervangen van de widgets is bij mij niet meer nodig als ik gewoon een seconde of 30 acht en dan de force close acknowledge...
  • Eypo
Kortfragje schreef op maandag 02 mei 2011 @ 12:24:
Nou ik ben er achter. Het is absoluut geen ontkoppelde SDkaart oid, maar Gallerij denkt het. Andere fotosoftware vinden de SDkaart wel. Ik ben dus iets te kort door de bocht gevlogen (A)
Ik gebruik LauncherPro, meer omdat ik die m.i. soepeler vind draaien,
beter kan customizen. Buiten dat ben ik zot op die 3D-app-drawer _/-\o_ .
Even andere vraag Cyanogenmod-mensen; Widgetlocker?! Hebben
jullie daar soortgelijken/suggesties voor? Zou Widgetlocker toch echt
een keer graag willen gebruiken weer, maar krijg nog echt steeds FC's.
[ Voor 24% gewijzigd door Verwijderd op 03-05-2011 18:52 ]
  • janvanduschoten
  • Laatst online: 12:41
janvanduschoten
Moderator Mobile
Nr. 346
Er is nu ook CM7 Gingerbread 2.3.4 te krijgen voor de bezitters van een Dropad A8 / Heropad / Haipad .
http://www.slatedroid.com...__pid__166845#entry166845
Het is wel een testversie, maar het begin is er!
Met dank aan Asure van Slatedroid.
[ Voor 15% gewijzigd door janvanduschoten op 06-05-2011 13:54 ]
Post op persoonlijke titel, tenzij in het blauw
De laatste tijd het meeste SPB Shell 3D maar LauncherPro (plus) en ADW Launcher EX gebruik ik ook nog wel eens. Ik raak steeds uitgekeken op een layout en dan wil ik weer wat anders. Het beste bevalt mij SPB, zo lekker snel voelt het aan.
  • boaty
  • Laatst online: 22-11 13:18
Zijn er meer mensen die de tweakers app niet kunnen sluiten met de back knop op CM7 en welke telefoon heb je?
Desktop: Ryzen 5 5600X | HyperX Fury RGB 32 GB @ 3200MT/s| Gigabyte GTX 3070 Eagle OC | Kingston A2000 1TB | Gigabyte B550 Elite V2 | Gigabyte G27Q 2560x1440 144hz
  • Kortfragje
Werkt prima hier (Desire Z)...
edit: Ik begreep dat een hoop nightly builds ondertussen al 2.3.4 zijn... hoop dat er snel een RC of final komt :9~ :9~
[ Voor 67% gewijzigd door Kortfragje op 06-05-2011 16:25 ]
  • Dennis_k
Versie 7.0.3 is uit. 2 fixes, waaronder een security update. Wat voor een security update het is wordt niet verteld
Kortfragje schreef op vrijdag 06 mei 2011 @ 16:18:
Zal voor de Samsung Galaxy S nog wel even duren voordat er een echte RC of final
komt *mompelt iets over de batterij* maar verder ben ik NU AL zwaar blij (eigenlijk
al sinds februari). Heb me gewoon neer gelegd bij die batterij. Camera ed boeien mij
niet zo.
  • Pino112
  • Laatst online: 11:29
Verwijderd schreef op vrijdag 06 mei 2011 @ 17:12:
niet zo.
Camera is gefixed, binnenkort update.
[ Voor 15% gewijzigd door Pino112 op 06-05-2011 17:16 ]
  • Kortfragje
Heb ook net 7.0.3 geflashed, weinig verschil op t oog idd. Ze raden wel aan deze update te installeren, nog niet kunnen vinden wat voor security fix het was.. ? ..
Pino112 schreef op vrijdag 06 mei 2011 @ 17:15:
Dat veranderd niks aan het feit of het mij boeit ;).
In CyanogenMod zit een functie om een screen-off en screen-on animation te tonen. Bij mij (HTC Tattoo, CM7), werkt dit echter niet. Bij andere vrienden, met een HTC Hero en een HTC Wildfire werkt dit ook niet. Dan heb ik nog een vriend met een LG Optimus GT-540 en daarbij lukt dit wel.
Iemand enig idee?
[ Voor 8% gewijzigd door Verwijderd op 13-05-2011 15:56 ]
  • Kortfragje
Heb je deze wel aangezet in de cyanogenmod setting? bij mij stond ie ook default uit...
Ja, die stond default uit, maar zelf na het inschakelen werkt dit niet. Ook niet na rebooten e.d.
  • Brad Pitt
  • Laatst online: 24-11 14:06
Verwijderd schreef op vrijdag 13 mei 2011 @ 16:49:
Komt dat niet door het ontbreken van OpenGL ondersteuning op de bejaarde apparaatjes? Hier Magic, ook niks.
Dat zou inderdaad wel kunnen ja!
  • Pino112
Official support voor de SGS *O*.
Gaat de goede kant op :D.
  • Kortfragje
Nice inderdaad :D
Ik zit alleen wel echt te wachten op CM 7.1.0. Gingerbread 2.3.4 schijnt namelijk een hoop van de power issues (die dus ook in de officiele Nexus roms optraden) gefixxed te hebben...
  • Fire69
  • Laatst online: 12:06
2.3.4 zit toch al in CM7.0 voor de LG 2X? Of is dat al CM7.1? :?
  • Sleehond
  • Laatst online: 12:45
Niet voor alle toestellen in ieder geval. Heb zelf een HTC Desire. En wacht nu ook op CM 7.1
@ Kortfragje, welke power issues zijn er dan precies, wat bedoel je precies en wat schijnt er dan opgelost te worden? Verder hoop ik dat 2.3.4 nog energiezuiniger is, want ik vind het soms echt om te huilen. Volgens mij ben ik echt niet een groot gebruiker, maar mijn batterij is echt om te huilen soms...
  • Squixx
  • Laatst online: 03-11 18:16
Sleehond schreef op donderdag 19 mei 2011 @ 21:33:
pwa t is iig op de desire z wat zuiniger, en de nightlies zitten sowieso op 2.3.4 terwijl de stable nog 2.3.3 is :)
android since G1.
  • thoragz
ik heb na het installeren van CyanogenMod geen Google Apps tot mijn beschikking. Ik heb al meerdere Gapss-zip's geprobeerd te flashen, ik krijg vervolgens wel het scherm om in te loggen met de Google-account te zien, maar omdat ik nog geen internetverbinding heb, moet ik deze annuleren. Er zijn dan geen Google-apps/market te vinden. Ik neem aan dat als ik inlog de apps nog steeds niet tot mijn beschikking zouden zijn?
  • MaximusTG
(overleden)
Jawel, als je inlogt gaat ie juist al die apps downloaden. Even een wifipunt opzoeken dus. Of je mobiele internet natuurlijk.
Zin in pizza? Probeer 'mijn' pizzarecept eens! Laatste versie pizzarecept Blog:KookKompas
  • croontje
  • Laatst online: 23-05 18:04
Ik heb een probleempje waar ik niet uitkom... Ik heb gisteren cyanogenmod 7.0.2 op men wildfire gezet. Als ik op men lockscreen zit te kijken dan gaat men scherm zeer snel terug uit. Na enkele seconden. Dus ik heb gezocht naar 1 of andere time out maar ik vind em dus niet.
Ik vind enkel op internet de volgende time outs:
Instellingen -> CyanogenMod settings -> Lockscreen -> Delay and timeout:
Screen time out delay
Screen turned off delay.
Maar die zijn het niet, ik heb ze voor de zekerheid allebei eens op een minuut gezet maar dat doet niks.
Bestaat hier een setting voor?
  • Kortfragje
Ik bedoel inderdaad de zuinigheid waarmee het ding met de batterij omspringt. Het schijnt dat die in 2.3.4 een stuk beter is, en dat het percentage wat naar 'cell standby' gaat lager is, vandaar.
Ga mezelf niet wagen aan nightlies, wacht wel op stable :Y)
  • Fotogravinnetje
  • Laatst online: 13-11 09:56
Ik draai momenteel wel nightly's op 2.3.4. Weet alleen niet hoeverre het goed te vergelijken is, omdat ik officiele CM gebruik (heb de motorola defy). Is in ieder geval wel lekker vlot en vrij zuinig met de batterij.
Percentage Cell Standby is idd lager dan ik had op 2.1 (stock) en 2.2 (stock)
[ Voor 15% gewijzigd door Fotogravinnetje op 03-06-2011 19:00 ]
  • Deagle
  • Laatst online: 08:44
Brad Pitt schreef op vrijdag 13 mei 2011 @ 16:58:
Hier een Desire Z en het werkt wel, dus dat zou het probleem wel zijn denk ik.
  • ApexAlpha
  • Laatst online: 21-11 10:54
Is er een manier om in het menu van Cyanogenmod in te stellen dat Cyanogenmod de CPU speed NIET aanpast? Ik heb namelijk het idee dat mijn cpu niet goed wordt overgeklokt. Ik heb dus ook liever dat de app SetCPU dit regelt en niet de mod zelf.
Ik heb een Moto Milestone maar gebruik de onofficiele versie van cm7 die zou moeten werken. Als ik echter vanuit een app of menu naar Home wil duurt dat vaak letterlijk 4 volle seconden. Iemand een idee hoe dit kan ? Zelfs op de normale speed zou de cpu niet zó langzaam moeten zijn.
  • Negaiido
  • Laatst online: 20-11 23:31
Weet iemand hoe ik theme chooser uitzet? Ik had gelezen dat widgetlocker een probleem heeft met deze feature. Zou iemand mij alsjeblieft kunne helpen?
  • croontje
kan je die niet gewoon verwijderen??
  • Negaiido
Hoe? Ik heb titanium backup geprobeerd maar die geeft aan dat verification package gefailed is ofzo.(hij blijft vaststaan op Android robotje met pijl.
Negaiido schreef op zaterdag 04 juni 2011 @ 23:10:
Nee hoor, dacht ik / had ik eerst ook, maar totaal geen probleem met de ThemeChooser op CM7.
  • Negaiido
Verwijderd schreef op zaterdag 04 juni 2011 @ 23:37:
Oh nou bedankt voor je informatie :) Ik heb mijn mobiel toch weer geflashed zonder theme chooser ^^ (toch nutteloos) Maar is zeker handig voor mensen met dezelfde gedachte.
nog een vraag, heeft de rest ook last van een groene led bij 90% van battery?
[ Voor 10% gewijzigd door Negaiido op 04-06-2011 23:51 ]
Negaiido schreef op zaterdag 04 juni 2011 @ 23:49:
Voor menig persoon die graag wat themes voor / van XDA wil proberen is de themechooser wel
handig / lekker en totaal geen conflicten meer, aldus mijn ervaringen.
En betreffende je batterijlevel, welke telefoon heb je?
  • Negaiido
Verwijderd schreef op zaterdag 04 juni 2011 @ 23:55:
Mja ook mijn eigen mening, moest ik erbij melden. Mijn excuses daarvoor.
Ik heb een HTC Desire.
  • Gizz
  • Laatst online: 11:40
Gizz
Dunder-Mifflin, Inc.
Bij mijn Desire met stockrom vind ik het heel handig dat de HTC contacts app telefoonnummers en foto's van bijvoorbeeld Facebook afhaalt en aan je contacten toevoegt. Ik wil graag overstappen op een custom rom, maar zou het wel jammer die functionaliteit te verliezen.
Is zoiets standaard ingebouwd in de Cyanogenmod?
Nee, niet standaard, maar daar bestaan wel apps voor. SyncMyPix is zo een voorbeeld :)
  • Cobesz
Als je de facebook app download kan je synchroniseren met je contacten, dit houdt in dat hij fotos toevoegd aan je bestaande contacten ;)
Was ik al bijna vergeten. Je kan zelf instellen als hij enkel met bestaande contacten moet synchroniseren of ook alle andere fb-contacten toe moet voegen.
  • Kaalus
Meerdere mensen last van met Cyanogenmod 7 dat het spelletje SpeedX 3D alles zwart is behalve de powerups?
Dacht eerst dat het iets was met compatibilty optie of met men dpi, maar ook met helemaal schone rom problemen.
Op meerdere apparaten geprobeerd met al die instellingen maar bleef hetzelfde :S
  • Zobat
  • Laatst online: 24-11 14:21
op mijn desire zit sinds afgelopen nacht de mogelijkheid om screenshots te maken en touch to focus in de camera! _/-\o_
edit: ik gebruik dus de nightly build
[ Voor 14% gewijzigd door Zobat op 05-07-2011 16:03 ]
  • Pino112
Zobat schreef op dinsdag 05 juli 2011 @ 16:02:
Jeps; ook op de SGS zo te zien:
  • Generate screenshot intent from global actions menu (android_frameworks_base)
  • cm: Add CMScreenshot to builds (android_vendor_cyanogen)
  • camera: Implement touch-to-focus (android_packages_apps_Camera)
  • Add droid2 maintainers (android_vendor_cyanogen)
  • Zobat
Op mijn desire werkt het :)
de powerknop ff indrukken en dan staat er tussen het shutdown menu ook een take a screenshot optie , touch to focus werkt ook
[ Voor 76% gewijzigd door Zobat op 06-07-2011 02:41 ]
  • Paladin
  • Laatst online: 14:02
Paladin
Play Ball!
Ik draai nu sinds gister ook de CM 7 mod (laatste stable release) en was er in eerste instantie super enthausiast over. Echter toen ik bij mijn auto kwam en probeerde the pairen met mijn parrot was het snel over. Op een of andere manier zegt mijn parrot dat de connectie tot stand is gekomen, maar wordt ie nooit gefinalized (in andere woorden ik kan niet handsfree bellen in de auto) heeft iemand anders dit probleem ook? Is er misschien een oplossing voor, ik heb op inet het een en ander gezocht maar alleen gevonden dat het een mogelijke bug is.
Iemand misschien een work around er voor?
|Yesterday is History, Today is a gift, Tomorrow a Mystery | M3 - LRAWD - Referral-link:https://ts.la/p66085
  • Kortfragje
ApexAlpha schreef op zaterdag 04 juni 2011 @ 13:58:
Hmm als ik setcpu installeer dan houdt Cyanogenmod zich netjes aan het profiel wat ik daar definieer. Heb je wel apply settings on boot aaangezet?
Draai sinds vanochtend nu 7.1.0-RC1. Gaat allemaal weer net even wat soepeler! en GEEN gps problemen. (gebruik de 04.30 radio) :9
  • BaseBoyNL
  • Laatst online: 12-11 13:50
Ik draai al enige CyanogenMod op mijn HTC Desire HD maar hierdoor heb ik problemen met de GPS.
Hij krijgt totaal geen Fix en vind geen enkele satelliet... zelfs niet na een uur zoeken in de open lucht.
Hebben anderen hier ook last van ?
Toestel : HTC Desire HD
Android-versie: 2.3.4
Kernel-versie: 2.6.35.13-cyanogenmod-g87a2eba
Mod-Versie: CyanogenMod-7.1.0-RC1-DesireHD
Build-nummer: GRJ22
Smarthomer | Home Assistant
  • Themperror
  • Laatst online: 23-11 09:58
update de frontpage es
Rig: AMD Ryzen 9950X3D, 96GB DDR5 6000Mhz, MSI Ventus X3 OC RTX5090
  • BaseBoyNL
Wat zou ik dan moeten zien ?
  • Themperror
BaseBoyNL schreef op maandag 05 september 2011 @ 17:36:
jij niks maar tis outdated..
  • glaaj
  • Laatst online: 07-11 19:10
net mn eerste keer een rom geflashed op n HTC legend, was best nog wel wat gedoen aangezien de informatie overal staat verspreid over het internet en het maken van de gold card was ook en gedoe aangezien ik 2 keer een niet werkende gold card had.
loopt superstrak, de animaties zijn geweldig en de customizability is bijna oneindig.
kortom: I am very happy 8)
  • Cobesz
Voor de mensen die dit interessant vinden.
http://dl.dropbox.com/u/14208882/CM7GBStockLauncher.zip
Wat doet dit?
Heel simpel: Het vervangt ADW Launcher in CM7 met de stock Gingerbread launcher!
Hoe installeer je dit? -> Flash met CWM en je bent klaar :)
  • Azaruc
Cobesz schreef op vrijdag 30 september 2011 @ 13:00:
Wat doet dit?
Dit is voor alle telefoons geschikt?
D3 Profile
  • Cobesz
Het was een thread in de thunderbolt sectie van het XDA, ik flashte het met mn SGS2 en het werkt :)
Doe voor de zekerheid even een nandroid backup :)
  • EdwinB
  • Registratie: September 1999
  • Laatst online: 19-11 20:12
Ik heb al een tijdje de Cyanogen mod draaien en nu 7.1 uit is ook meteen die versie geinstalleerd. Werkt allemaal als een speer op mijn HTC Desire, maar ik mis toch wel een aantal dingen die ik wel erg fijn vond met de HTC Sense interface:
- Woordcorrectie tijdens typen
- Naambellen (dus ik typ een deel van een nummer in: 065351 en dan zie ik alle namen wie deze reeks in hun nummer hebben, of ik typ 33946 en zie bijvoorbeeld iedereen die EDWIN in zijn naam heeft)
Iemand enig idee of dit ook te regelen is in de Cyanogen mod?
  • janvanduschoten
janvanduschoten
Moderator Mobile
Nr. 346
EdwinB schreef op dinsdag 11 oktober 2011 @ 14:41:
Kan met diverse alternatieve toetsenborden, SwiftkeyX is op dit moment mijn favoriet. Je kunt voor het flashen van je ROM ook de LatinIME.apk vervangen door een die wel Nederlandse woordcorrectie heeft. Werkt goed op de Desire.
Is ook zeer eenvoudig op te lossen met een dialer app zoals Go DialerEx, Dialer One, etc.
  • pkwarts
  • Laatst online: 24-11 16:09
pkwarts
555433800
Heeft iemand de optie kunnen vinden om de USB storage pop-up uit te schakelen?
  • Kortfragje
Hmm, zal van t weekend is de startpost gaan updaten :) @ BaseBoyNL is dat een aanbod om te helpen, je bent van harte welkom om co-auteur te worden, dan blijft t allemaal wat beter up to date.. :)
Zelf gister 7.1 geinstalleerd, alleen bootlopen bij de eerste boot op HTC Vision. :( na een factory reset en cache wipe werkt t weer als een zonnetje. Eerste indrukken, naast de nieuwe funtionaliteit, veel vlotter en zuiniger! (kom van 7.1.0-RC1.0)
  • monnick
Ik ook gisteren 7.1.0 op mijn HTC Desire Z geïnstalleerd. Alles ging prima :)
Wat voor noemenswaardige nieuwe features heb jij ontdekt dan?
EDIT: Ligt het trouwens aan mij of is de CyanogenMod website gehackt? De site laadt heel langzaam en Nod32 geeft een virusmelding bij het openen van de site (iets met een warlikedisobey.org url)
[ Voor 46% gewijzigd door monnick op 11-10-2011 16:45 ]
  • Cobesz
USB Host :) grote change voor mij ^^
  • graaf404
  • Laatst online: 11:34
Ik heb nog een originele DHD, en hoor/lees zulke positieve berichten over CyanogenMod, dat ik dat eigenlijk ook wel op m'n telefoon wil zetten.
Nu heb ik nog wel een paar vragen waar ik het antwoord niet helemaal op kan vinden (of ik zoek/kijk niet goed)
- kan ik m'n originele Rom nog terugzetten?(moet ik dat backuppen, waarmee kan dat het beste)
- worden alle contacten, whatsApp contacten, Facebook contacten gesyncroniseerd, of alleen de Foto's zoals hierboven vermeld staat? (lijkt me heel lastig om overal 3 of meer contacten te hebben van dezelfde persoon)
Ray...
  • Strider
  • Laatst online: 24-11 19:28
Cobesz schreef op dinsdag 11 oktober 2011 @ 17:30:
Wat is daar dan anders aan ?
BlaBlaBla
  • -Tim-
  • Laatst online: 12:54
-Tim-
Niet geraakt is altijd mis.
Ik heb gister ook Cyanogen op m'n Hero gezet, maar mis nu een feature die ik in mijn vorige rom wel had. Volgens mij was dat deze elelinux. Hier had ik onder andere de mogelijkheid om de dots van m'n unlock-pattern te verbergen zodat je eigenlijk gewoon een leeg vak zag waar je het patroon in moest tekenen. Verder kon ik ook een aantal regels tekst kwijt waar ik m'n adres had staan voor als iemand m'n telefoon vond.
Deze instellingen kon ik vinden in het instellingen-menu van mijn telefoon, en ik dacht zelfs onder de Cyanogen uitbreidingen in die rom. Met 7.10 kan ik het echter nergens (meer) vinden. Kent iemand deze add-on en waar ik die kan vinden?
  • Cobesz
@Strider
Je kan nu bijvoorbeeld een muis of USB stick aan je telefoon hangen :)
  • Minaaj
  • Laatst online: 20-11 20:22
http://forum.cyanogenmod....n-market-update-10092011/
Dit is echt een mooie cm7 theme, ook bijna elke app is redesigned naar kleurenschema.
Hij past ook heel veel widgets aan (bijvoorbeeld news and weather/twitter/google search) en ook market balk word zwart ect.
Aanrader!
[ Voor 26% gewijzigd door Minaaj op 12-10-2011 18:58 ]
  • EdwinB
janvanduschoten schreef op dinsdag 11 oktober 2011 @ 15:00:
Thanx! _/-\o_ Ik heb SwiftKeyX en Dialer One geinstalleerd en op het eerste gezicht gaat me dit erg helpen!
  • Rikkiz0r
@Minaaj
Die is echt mooi, heel erg bedankt. _/-\o_ _/-\o_
  • Deagle
Weet er iemand waarom bluetooth gestart wordt wanneer je de fm radio start? Ik gebruik geen bluetooth headset, gewoon 'normale' oordopjes die bedraad zijn. Wanneer ik bluetooth uit zet dan stopt de fm radio ook meteen. In de opties van de fm radio kun je selecteren dat BT "altijd uit" moet staan maar dat werkt ook niet. Is er een andere manier om BT uit te schakelen? Dit scheelt aardig wat qua accu denk ik.
CM7.1 op DesireZ
  • Maiskneuzer
  • Laatst online: 13-11 11:35
Afgelopen week is de Cyanogenmod officieel uitgekomen voor veel Sony Ericsson telefoons. Met mijn Arc was ik natuurlijk ook erg nieuwsgierig!
Het installeren ging allemaal wel prima (na een klein gevechtje met het fastboot verhaal). Ben tot nu toe tevreden alleen heb ik iets gevonden wat blijkbaar meer mensen hebben:
GPS werkt niet.
Natuurlijk heb ik zelf al even op google gezocht maar kon niet precies vinden wat ik zocht. Het schijnt dat er een of andere 'radio' geinstalleerd moet worden. Kon alleen nergens precies achterhalen wat ik nodig heb voor deze nieuwe CM. Kan iemand mij assisteren?
Verder erg tevreden wat ik nu gezien heb :) vanavond maar eens gaan spelen met thema's en alle extra's ontdekken!
  • Knud
  • Laatst online: 19-11 18:38
Knud
Sandvich
Voor de mensen met CM7.1 --> hebben jullie last van batterij drain? Ik lees hier en daar wat berichten dat men last heeft van batterij drain. (Slechts een paar mensen hoor, wil het gewoon even checken hier)
AMD 3900X | MSI X570 MEG UNIFY | TridenZ 32GB | EVGA GTX 1080 | Samsung 970 Pro 1TB, 860 1TB & 840 EVO 1TB | LianLi O11 XL | Seasonic Prime PX 1300 | Audio set: RME ADI-2 DAC + SMSL DA-9 + 2x Klipsch B2 bookshelf speakers
  • Azaruc
Knud schreef op vrijdag 21 oktober 2011 @ 08:59:
Geen last van battery drain hier. Batterij gaat voor mijn gevoel juist langer mee dan met de Nightly die ik hiervoor draaide.
D3 Profile
  • Elwood Blues
  • Laatst online: 27-09 12:30
Elwood Blues
87167191
Ja, ik had daar wel last van en ben weer terug naar 7.1.0 RC1.
  • Squixx
heb zelf geen battery drain, maar gebruik dan ook weer een variant op CM7.1 dus hoeveel dat zegt...
batterydrain is sowieso een beetje een lastig verhaal, en eigenlijk zegt t alleen maar iets over je batterij verbruik in standby..
android since G1.
  • aldjay
  • Laatst online: 09-11 22:12
Ja absoluut, na 6 a7 uurtjes moet hij alweer aan het infuus, HTC Hero heb ik het over.
Vorige week CM erop gezet en sindsdien is dat, met de standaard HTC Sense ging hij makkelijk 1,5 dag mee.
  • SuperKneus
  • Laatst online: 12:40
Ik draai nu al een paar dagen nightly 89 van CM7 maar ik denk dat ik terug ga naar 83 of helemaal een andere rom ga kiezen. Ik heb met deze rom erg vaak last dat de telefoon naar het bootscherm van cm7 springt. Af en toe komt hij hier uit maar vaak blijft hij er in hangen en kan ik niets anders doen dan de telefoon een reboot te geven. Soms werkt dat en soms moet ik booten in recovery en hem opnieuw flashen of een backup terug zetten.
Ik dacht eerst dat het aan Launcher7 lag maar bovenstaande probleem heb ik nu ook al een keer gehad met de stock launcher van cm7. Het komt vaak voor nadat ik de telefoon weer gelocked heb. Scherm-aan en Scherm-uit animatie heb ik al uit staan, daar ligt het ook niet aan.
Ik wilde gisteren al overgaan naar de laatste MIUI maar die lijkt heel erg veel op cm7 en ik kwam al een reactie van iemand anders tegen die hetzelfde probleem heeft.
Ik baal hier wel van want ik ben erg tevreden over cm7.
  • Fotogravinnetje
Ik ben gisteren overgestapt van de CM7 RC1.5 voor defy (van Quarks) naar de officiele CM7 stable. Wel bij allebei de barebones-versie, omdat ik o.a. ZeamLauncher prettiger vind dan ADWLauncher (sneller, stabieler). Ik hoorde van andere mensen met een defy dat ze last hadden van een stel vervelende bugs in de officiele CM7-rom die ze niet hadden in de onofficiele RC1.5. Daarom zelf behoorlijk geaarzeld of ik zou updaten. Toch gedaan en op dit moment nog geen bugs ontdekt. Ook kan ik op dit moment nog niet goed zeggen of ik last heb van batterij-drain of niet. De stabiliteit van de rom is naar mijn idee hetzelfde gebleven
  • Magua
  • Laatst online: 25-06 17:48
Heb gisteren Cyanogenmod op mijn Desire gezet. Eindelijk van het ruimte probleem af! Maar hjoe krijg ik nou connectie met een (windows) pc? Ik zie geen usb instellingen meer en als ik hem er aan hang laadt hij alleen maar op, en heb ik geen toegang tot het geheugen. Ook zou ik graag mijn nas schijven mounten in de Desire. Met een tablet kon dat wel, maar hier zie ik neit hoe het moet...
  • Themperror
al nieuws over CM9? die ik eigenlijk hier in dit topic had verwacht?
  • Cobesz
Waarom eigenlijk cm9 en niet cm8?
CM8 zou Honeycomb zijn geworden, maar die slaan ze over.
  • Sinedia
  • Laatst online: 21-10 08:28
Gisteren heb ik CM 7.1 (Stable) op mijn telefoon gezet met de hulp van onder andere deze openingspost. Kostte wat moeite, maar is gelukt!
Ben er erg blij mee, CM gaat erg snel en vloeiend... nu maar eens kijken of mijn batterij ook langer leeft :)
  • Cobesz
Weet iemand waar en of het uberhoubt mogelijk is om de stock kernels voor CM7 te downloaden? Of is het simpelste gewoon de rom eroverheen flashen zonder wipe?
  • robvanwalbeek
  • Laatst online: 15-10-2025
Ik gebruik nu ruim 2 maanden Cyanogenmod met veel plezier op mijn HTC Desire van inmiddels bijna 2 jaar oud. Deze rom heeft in combinatie met Data2SD weer nieuw leven in mijn smartphone geblazen. Door nooit meer vrije ruimte te hebben voor apps en continu de melding te krijgen dat het opslaggeheugen vol zit, terwijl ik meer dan genoeg ruimte op mijn SD kaartje had, kreeg ik vaak de neiging de telefoon uit het raam te gooien. Zelfs met de update naar Froyo, waardoor de mogelijkheid om apps naar SD te verplaatsen bood geen oplossing. Nu heb ik, door een aparte partitie op de SD kaart, 1,8GB beschikbaar apps, ipv 100MB. Plus alles werkt beetje vlotter door Cyanogenmod (7.1.0) met Gingerbread.
Afbeeldingslocatie: https://lh3.googleusercontent.com/-MhMQ8Is9j7Q/TtdDoeuW5II/AAAAAAAAAi8/h0-s83LY5oY/s576/screenshot-1322730211333.png
Wel nog een vraagje. Stel dat ik deze Rom ook op een nieuwe telefoon wil installeren, bijvoorbeeld de SGS2, beïnvloed dit dan op enige manier (negatief) de werking van de hardware (mn. fotocamera) van de telefoon? De SGS2 heeft een uitstekende camera aan boord (de beste op de iPhone4s na, volgens test van GSMarena) en ik zou het zonde vinden dat ik die goede eigenschap kwijt zou zijn door het installeren van een andere rom.
  • Squixx
robvanwalbeek schreef op donderdag 01 december 2011 @ 10:12:
ik weet niet in hoeverre samsung de camera app heeft aangepast, als je nml naar sense 3.5 met de amaze camera kijkt zijn hier veel nieuwe features die alleen werken met sense. waardoor CM7 op de sensation minder aantrekkelijk word.
CM7 gebruikt gewoon de standaard foto app, wat qua kwaliteit niet uit zou moeten maken maar wel kan verschillen in features (waar sommige features natuurlijk de kwaliteit kunnen beinvloeden)
android since G1.
Pagina: 1 2 Laatste
