[SETI@Home] hitparade van 18 mei Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 22:22
APClll
FP ProMod
[DPC] Team Grazzie
Aangezien ik gisteren met m'n grote mond riep dat ik graag wilde statsposten, moet ik het natuurlijk ook doen ;)
In dit derde en tevens laatste deel van de serie 'Wat is Astropulse' zijn we aangekomen bij de gebruikte algoritmes. deel 1 deel 2
Astropulse algorithm
Single Pulse Loops
Astropulse has to analyze the whole workunit at nearly 15,000 different DMs (14,208, to be precise.) At each DM, the whole dedispersion algorithm has to be run again for the entire workunit. The lowest DM is 55 pc cm-3, and the highest is 800 pc cm-3. Astropulse examines DMs at regular intervals between those two. Without going into detail about how to examine a piece of a workunit at a given DM, here is the organization with which Astropulse handles the data: it divides the DMs to be covered into large DM chunks of 128 DMs each, and then small DM chunks of 16 DMs each. It divides the data into chunks of 4096 bytes, and processes them one at a time. Once it has dedispersed the data, Astropulse co-adds the dedispersed data at 10 different levels, meaning that it looks for signals of size 0.4 microseconds, then twice that, 4 times, 8 times, and so on. (0.4 microseconds, 0.8, 1.6, 3.2, 6.4, ...) On the lowest level of organization, astropulse looks at individual bins of data. A bin corresponds to 2 bits of the original data, but after dedispersion, it requires a floating point number to represent it. Here's the breakdown of Astropulse's loops:
1 workunit => 111 large DM chunks
1 large DM chunk => 8 small DM chunks
1 small DM chunk => 2048 data chunks
1 data chunk => 16 DMs
1 DM => 10 fold levels
1 fold level => 16384 bins (or less)
1 bin = smallest unit
So each workunit is composed of 111 large DM chunks, each of which is 0.901% of the whole. Each large DM chunk is composed of 8 small DM chunks, each of which is 0.113% of the whole. And so on.
The number of large DM chunks will probably change before the final version of Astropulse is released.
Fast Folding Algorithm
At the end of each small and large DM chunk, Astropulse performs the Fast Folding Algorithm. This algorithm checks for repeating pulses over a certain range of periods. (The period is the length of time after which the pulse repeats.) When the fast folding algorithm is performed after each large DM chunk, it searches over an entire 13 second workunit, and looks for repeating signals with a period of 256 times the sample rate (256 * 0.4 microseconds) or more. When the FFA is performed after each small DM chunk, it searches over a small fraction of the workunit, and looks for repeating signals with a period of 16 times the sample rate or more.
bron
En dan nu natuurlijk het deel waar jullie allemaal voor gekomen zijn ;)
DPC SETI@Home hitparade van 18 mei 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 86 / 999 (8,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)23.230Searchy! Internet Services V.O.F.9.627.827(4)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)15.696[DPC] hansR15.394.380(1)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)15.019[DPC] Switch9.400.623(5)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)14.667Sp@ceNv@der12.022.727(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)13.453[DPC]TeamGrazzie12.863.784(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.275o25o & Dharkon4.978.107(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)7.822F@stmem2.470.299(9)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.642[DPC]NGS73.925(157)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)6.515dr bommel651.736(32)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)6.117Ensign Wildfire3.462.870(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.884dpc_kluizenaar710.934(29)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)3.895Team_Elteor_Borislavj573.110(35)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.822AmeComputers1.902.365(12)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.819ray1.405.567(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)3.701Jox444954.777(24)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)2.881Override990.449(23)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)2.484Racemol21.190(312)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.311Wolfje66681.749(153)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.278Mr Beamer1.958.511(11)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.205muppet99223.716(78)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.914Jan Zandvliet & x-RaY991.839.812(13)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)1.894Tijntje1.383.295(17)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.840Dadoke947.467(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.736apa256.041(71)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.715MaGNeT aka BlueTooth76765.212(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)1.665RonaldS204.532(84)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.580Patty46.631(209)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)1.568Patch30.843(258)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif17)1.504Ignitions408.714(45)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.306holy-shit620.280(34)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.394.380[DPC] hansR15.696(2)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.863.784[DPC]TeamGrazzie13.453(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.022.727Sp@ceNv@der14.667(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.627.827Searchy! Internet Services V.O.F.23.230(1)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.400.623[DPC] Switch15.019(3)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.978.107o25o & Dharkon8.275(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.462.870Ensign Wildfire6.117(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.590.764[DPC]Spinpoint13(86)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.470.299F@stmem7.822(7)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.359.891[DPC]Trancemaus0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.958.511Mr Beamer2.278(19)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.902.365AmeComputers3.822(13)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.839.812Jan Zandvliet & x-RaY991.914(21)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.505.344[DPC]Team Zuid-Holland871(46)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.405.567ray3.819(14)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.383.295Tijntje1.894(22)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.136.997Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.475visvogel0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.060.829Berkie38(81)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)990.449Override2.881(16)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)954.777Jox4443.701(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)947.467Dadoke1.840(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)889.009Quark162(62)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)830.065Rydo1.261(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)765.212MaGNeT aka BlueTooth761.715(25)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)710.934dpc_kluizenaar5.884(11)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.470.388SETI.USA1.056.395.391(1)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)275.781Canada158.690.366(21)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)264.061OcUK - Overclockers UK210.807.607(15)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)262.844The Planetary Society217.626.661(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)224.443BOINC@Poland131.629.173(30)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)212.040U.S.Air Force151.355.639(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)205.488BOINC.Italy152.510.035(23)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)204.920Boone Community School District - Iowa98.081.219(39)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)198.645Dutch Power Cows137.349.482(27)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)189.522Team Art Bell207.859.443(17)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)188.456Team Norway65.407.827(52)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)182.277Amateur Radio Operators151.599.209(24)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)178.041Brasil [SETIBR]61.022.862(57)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)175.284RoEduNet70.151.693(48)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)174.249Ars Technica153.519.094(22)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)172.0402CPU.com84.661.154(43)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.056.395.391SETI.USA1.470.388(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)165.351.677Phoenix Rising339.527(20)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)158.690.366Canada275.781(22)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)153.519.094Ars Technica174.249(35)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)152.510.035BOINC.Italy205.488(27)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.599.209Amateur Radio Operators182.277(32)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.355.639U.S.Air Force212.040(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)148.893.656BOINC@AUSTRALIA352.182(19)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)137.349.482Dutch Power Cows198.645(29)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)135.711.607UK BOINC Team162.181(39)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)134.879.277Universe Examiners158.940(40)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)131.629.173BOINC@Poland224.443(25)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)127.484.961AUSTRIA - NATIONAL - TEAM146.634(42)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)122.518.382BOINC SETI@home RUSSIA143.365(43)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)120.375.574PC Perspective Killer Frogs140.474(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)118.939.070Team NIPPON166.581(38)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
Wolfje66680.000
[DPC]NGS70.000
Doelloos60.000
Patch30.000
Racemol20.000
Expander3.000
Yvo Kleijkers2.000
Herrie250
When do you get them
TeamAverageDays
Team MacNN132.9131.907
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
APCIII bedankt voor de uitleg van het AP gedeelte d:)b
en alle mijlpalen congratz met het behalen er van *O*
  • Bassie1978
  • Laatst online: 10-11 11:53
Bassie1978
Bassie
Dank voor de stats, zal een dezer dagen je verhaal van AP eens helemaal lezen ;)
..::www.pug205.nl::..
APCIII, bedankt voor de interessante Astropulse uitleg.
