[SETI@Home] hitparade van 14 mei Vorige deel Overzicht Volgende deel Laatste deel
  • APClll
  • Laatst online: 20:50
APClll
FP ProMod
[DPC] Team Grazzie
Voor we verder gaan met de beschrijving van het Astropulse gebeuren, kijken we even vlug naar de stats. Het is namelijk onbeleefd om nieuwe leden te laten wachten.
*O* Welkom Sven Decock *O*
*O* Welkom TDDOL *O*
Dan gaan we nu verder met het uitleggen wat het Astropulse-project van Seti precies doet. In de vorige aflevereing hebben we diverse begrippen geintroduceerd. Vandaag gaan we verder in op de verschillende signalen die gevonden kunnen worden.
Sources of pulses
Where would a microsecond transient radio pulse come from? There are several possibilities, including:
  • ET: Previous searches have looked for extraterrestrial communications in the form of narrow-band signals, analogous to our own radio stations. Since we know nothing about how ET might communicate, this might be a bit closed-minded.
  • Pulsars and RRATs: Pulsars are rotating neutron stars that can produce signals as short as 100 microseconds, although typically much longer. 0.4 microseconds seems like a stretch. Astropulse is capable of detecting pulsars, but is unlikely to find any new ones. RRATs are a recently discovered pulsar variant. Perhaps Astropulse will discover a new type of rotating neutron star with a very short duty cycle.
  • Exploding primordial black holes: Martin Rees has theorized that a black hole, exploding via Hawking radiation, might produce a signal that's detectable in the radio. Click here to learn about black holes.
  • Extragalactic pulses: Some scientists recently saw a single transient radio pulse from far outside the Milky Way galaxy. No one knows what caused it, but perhaps there are more of them for Astropulse to find.
    New phenomena: Perhaps the most likely result is that we will discover some unknown astrophysical phenomenon. Any time an astronomer looks at the sky in a new way, he or she may see a new phenomenon, whether it be a type of star, explosion, galaxy, or something else.
Dispersed pulses
As a microsecond transient radio pulse comes to us from a distant source in space, it passes through the interstellar medium (ISM). The ISM is a gas of hydrogen atoms that pervades the whole galaxy. There is one big difference between the ISM and ordinary hydrogen gas. Some of the hydrogen atoms in the ISM are ionized, meaning they have no electron attached to them. For each ionized hydrogen atom in the ISM, a free electron is floating off somewhere nearby. A substance composed of free floating, ionized particles is called a plasma.
The microsecond radio pulse is composed of many different frequencies. As the pulse passes through the ISM plasma, the high frequency radiation goes slightly faster than the lower frequency radiation.When the pulse reaches Earth, we look at the parts of the signal ranging from 1418.75 MHz to 1421.25 MHz. This is a range of 2.5 MHz. The highest frequency radiation arrives about 0.4 milliseconds to 4 milliseconds earlier than the lowest frequency radiation, depending on the distance from which the signal originates. This effect is called dispersion. Click here to see how dispersed and undispersed pulses can be composed of many different frequencies
In order to see the signal's true shape, we have to undo this dispersion. That is, we must dedisperse the signal. Dedispersion is the primary purpose of the Astropulse algorithm.
Not only does dedispersion allow us to see the true shape of the signal, it also reduces the amount of noise that interferes with the signal's visibility. Noise consists of fluctuations that produce a false signal. There could be electrical noise in the telescope, for instance, creating the illusion of a signal where there is none. Because dispersion spreads a signal out to be up to 10,000 times as long, this can cause 10,000 times as much noise to appear with the signal. (There's a square root factor due to the math, so there's really only 100 times as much noise power, but that's still a lot.)
The amount of dispersion depends on the amount of ISM plasma between the Earth and the source of the pulse. The dispersion measure (DM) tells us how much plasma there is. DM is measured in "parsecs per centimeter cubed", which is written pc cm-3. To get the DM, multiply the distance to the source of the signal (in parsecs) by the electron density in electrons per cubic centimeter. A parsec is about 3 light years. So if a source is 2 parsecs away, and the space between the Earth and that source is filled with plasma, with 3 free electrons per cubic centimeter, then that's 6 pc cm-3. The actual density of free electrons in the ISM is about 0.03 per cubic centimeter.
De volgende keer gaan we dieper in op de gebruikte algoritmes. Voor het uitgebreide verhaal is deze startpost wat aan de kleine kant
Wil je nu al het hele verhaal lezen? klik dan hier
14 May 2009 20:40:07 UTC
We are quite preoccupied with anniversary stuff so we've been doing the bare minimum amount of systems administration to get by until after the event. Still, it should be mentioned we continue to have SATA/driver issues on our data recorder at Arecibo, and haven't collected new data for about a month now. While we have a pile of data yet to crunch readily available on disk, I started pulling up unanalyzed data from our offsite archives.
Before doing so I went through the whole data inventory rigamarole this morning. We have 1787 raw multi-beam data files (mostly all 50GB in size) archived, of which 338 haven't been split at all. However, a portion of these files were recorded before 2008, i.e. before we had a hardware radar blanking signal embedded in the data. So until we get my software radar blanker working (a project postponed until post-anniversary) we can't chew on these files without dealing with major radio frequency interference. This isn't a major problem: 1225 of the 1787 archived data files are from 2008 or later, and of these 249 have yet to be split. So we got plenty of numbers to crunch until we get the data recorder working again.
- Matt
DPC SETI@Home hitparade van 14 mei 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 96 / 997 (9,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.522Searchy! Internet Services V.O.F.9.548.605(4)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.182[DPC]TeamGrazzie12.792.968(2)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)19.885[DPC] hansR15.331.285(1)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)15.231Sp@ceNv@der11.955.921(3)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.336[DPC] Switch9.351.095(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)10.775F@stmem2.438.645(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.564o25o & Dharkon4.946.876(6)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.476dr bommel630.508(32)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.712Ensign Wildfire3.435.251(7)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)7.010dpc_kluizenaar682.800(29)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)6.724ray1.387.771(16)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif37)5.559Quark881.057(26)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.819Jan Zandvliet & x-RaY991.830.383(13)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)4.229Override983.942(23)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)4.213apa248.953(71)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)3.990Patty32.189(254)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)3.773Hans vandebos306.282(63)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)3.766Mr Beamer1.947.109(11)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.748ZUID-CHEMIE175.710(95)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.566Rydo826.277(27)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)2.946[DPC]NGS46.271(208)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.596muppet99214.016(81)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.556[DPC] Brainy007650.302(31)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.541Jox444944.765(24)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.496holy-shit615.715(34)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)2.309Asgoroth328.567(62)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)2.187Wolfje66671.586(160)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.975ERBrouwer123.085(115)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.803HellBringer59.784(175)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)1.738seridan499.381(39)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.331.285[DPC] hansR19.885(3)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.792.968[DPC]TeamGrazzie21.182(2)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.955.921Sp@ceNv@der15.231(4)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.548.605Searchy! Internet Services V.O.F.25.522(1)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.351.095[DPC] Switch11.336(5)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.946.876o25o & Dharkon10.564(7)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.435.251Ensign Wildfire8.712(9)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.586.671[DPC]Spinpoint422(64)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.438.645F@stmem10.775(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.358.645[DPC]Trancemaus1.261(40)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.947.109Mr Beamer3.766(18)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.890.961AmeComputers1.288(38)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.830.383Jan Zandvliet & x-RaY994.819(13)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.235[DPC]Team Zuid-Holland715(56)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.387.771ray6.724(11)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.377.527Tijntje962(54)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.135.713Speedy67 & Friends38(91)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.475visvogel35(92)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.060.791Berkie0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)983.942Override4.229(14)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)944.765Jox4442.541(24)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)941.775Dadoke1.495(31)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)881.057Quark5.559(12)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)826.277Rydo3.566(20)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)758.376MaGNeT aka BlueTooth761.364(33)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)682.800dpc_kluizenaar7.010(10)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.969.307SETI.USA1.050.513.196(1)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)378.734The Planetary Society216.486.543(14)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)365.740Elite Games109.186.028(35)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)364.345OcUK - Overclockers UK209.709.098(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.893BOINC@Poland130.709.554(30)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)287.877U.S.Air Force150.529.534(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)260.926Amateur Radio Operators150.838.386(24)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)260.682Brasil [SETIBR]60.267.840(57)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)253.541Dutch Power Cows136.541.140(27)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)251.583BOINC.Italy151.738.018(23)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)246.753Boone Community School District - Iowa97.284.551(39)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)243.870Team Norway64.704.943(53)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)238.922Ars Technica152.814.615(22)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)236.661Team Art Bell207.093.141(17)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)231.202Sweden45.254.600(77)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)222.985SMLUG25.079.007(134)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.050.513.196SETI.USA1.969.307(1)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)163.789.287Phoenix Rising526.580(16)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)157.610.159Canada379.472(21)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)152.814.615Ars Technica238.922(33)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.738.018BOINC.Italy251.583(30)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.838.386Amateur Radio Operators260.926(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.529.534U.S.Air Force287.877(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)147.564.180BOINC@AUSTRALIA436.633(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)136.541.140Dutch Power Cows253.541(29)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)135.043.662UK BOINC Team220.852(37)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)134.206.697Universe Examiners204.973(43)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)130.709.554BOINC@Poland311.893(25)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)126.907.313AUSTRIA - NATIONAL - TEAM181.584(47)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.895.647BOINC SETI@home RUSSIA213.873(39)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)119.764.900PC Perspective Killer Frogs207.986(42)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)118.225.696Team NIPPON220.347(38)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
Mijlpalen
ZUID-CHEMIE175.000
Wolfje66670.000
Dutchy50.000
Patty30.000
KILLERkraan10.000
[DPC]LightLuke6.000
Kick @sz3.000
[DPC]heladepela1.000
yorde1.000
Rene1970250
Nieuwe Leden
Sven Decock0
TDDOL1.250
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
Welkom Sven Decock
Welkom TDDOL
TG komt op stoom na de stampede!
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
beetje laat
maar alsnog welkom Sven Decock en TDDOL *O*
en APCIII bedankt voor de uitleg ;)
  • Black Piet
Verwijderd schreef op vrijdag 15 mei 2009 @ 22:38:
Welkom Sven Decock
Welkom TDDOL
Ik had niet anders verwacht......
Dank voor de stats....Ik ga nu het song festival boycotten en lekker film kijken... :+
Mooooooeeeee......
  • Bassie1978
  • Laatst online: 10-11 11:53
Bassie1978
Bassie
Ik ben ook weer even overgestapt op Seti met me quadkoe :D
..::www.pug205.nl::..
Bassie1978 schreef op zondag 17 mei 2009 @ 12:15:
Eej dat zijn goeie berichten Pug.
Welkom Sven Decock en Welkom TDDOL and have fun!
:w (naar m'n vrienden :P )
[ Voor 5% gewijzigd door Verwijderd op 17-05-2009 13:18 ]
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
:w terug! :*)
En natuurlijk jij ook welkom, pug205!
  • Bassie1978
Bassie1978
Bassie
Danku ;)
:w terug naar me vrienden
