[SETI@Home] hitparade van 18 april Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
[SETI@Home] geen hitparade van 18 april
Server Status
Our BOINC database server crashed for the second day in a row. It is in the middle of recovery now. We expect the project to be back up sometime tomorrow.
as quoted from seti@home
Helaas daardoor geen stats beschikbaar :'(
  • Black Piet
grass460 schreef op zondag 19 april 2009 @ 09:54:
Server Status
Ik was er gister ook al achter gekomen. Heb toen maar een bericht geplaatst in het vorige topic... :|
Mooooooeeeee......
  • APClll
  • Laatst online: 00:11
APClll
FP ProMod
[DPC] Team Grazzie
Tja, het zat er natuurlijk dik aan te komen...
Ik bedoel, hoe lang geleden was de vorige storing? Juist, erg lang geleden (voor Seti begrippen) :P
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • grass460
grass460
al 3 dagen geen stats das jammer :'( ook vandaag geen mogelijkheid om de stasts te posten vanwege de gecrashte server :? :?
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
De stats liggen nogsteeds plat :(
20 Apr 2009 23:04:44 UTC
The mysql database crashed on Friday, then again on Saturday. The reasons are mysterious, though we've had similar crashes in the past - just not two in immediate succession like that. Most of the large, important tables (user, host, workunit, result) are using the innodb engine, while the many others (including team, forum preferences, posts, etc.) are using mysql's standard myisam engine. There's worry we may have lost a few rows in some of the myisam tables, though they seem to check out okay. The replica database, though, is in a confused state so we just shut it off for the time being. We're going to save any remaining cleanup for tomorrow's usual outage. As stated elsewhere, Jeff and I have adopted a policy of no-system-changes (except for emergencies) until after the anniversary. So as long as mysql continues to run well, we're not going to worry about this so much.
I know I write all these missives and therefore I get the brunt of the accolades (or otherwise) but Jeff/Bob pretty much took care of the entire mess above. I did log in on Sunday and cleaned up the server status page and the validators (which for some reason *have* to start on the command line, as opposed to the usual cron job which restarts stopped processes), but that's the usual drill (we're always logging in on nights/weekends to kick one process or another).
- Matt
21 Apr 2009 22:16:04 UTC
Tuesday means weekly outage day for mysql database backup/compression. Since the replica got messed up during the duet of crashes over the weekend, we are using this backup today to recover the entire replica database from scratch right now. Should be ready to go in a few hours or so. I think the regular boinc stats xml dumps also broke over the weekend but those should be generating normally again now.
The secondary science database is also suffering some kind of malaise. Not sure what the deal is, but it's slowing down my NTPCkr web site development. I thought it was excess disk activity on the system (caused by writing a primary database backup image to one of its spare drives) wreaking havoc, so I waited for that to end, but still no dice. Had to stop/restart the engine and even then it went through some phase of vague recovery before I could access it again.
Finally got that replacement sata card for the datarecorder down at Arecibo. Jeff and I tested it in a system up here (mostly to make sure we didn't need to update its firmware) and I just put it in a box heading to Puerto Rico (along with a set of blank data drives). Hopefully it'll be a quick swap and we'll be back to recording data again.
Jeff and I are really getting into the mode of programming/development. I think we found a way to speed up the NTPCkr a little bit more this morning, which is always a good thing. I'm still mostly working on internal visualization tools (with some simultaneous thought to what the first rev of the publicly available pages may look like). Don't get too excited yet - it's mostly just a table of numbers.
- Matt
[ Voor 36% gewijzigd door APClll op 22-04-2009 09:27 ]
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
En ook vandaag is er geen
DPC SETI@Home hitparade van 21 april 2009
En ook geen verhaal. Want wat moet je vertellen over stats die er niet zijn? Je kunt uitleggen waarom ze er niet zijn, maar dat staat al een post hierboven. En dát ze er niet zijn, dat is ook wel duidelijk. Dus: geen verhaalte vandaag.
En ook geen nieuw topic ;)
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 0 / 981 (0,0 %)
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.156.323[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.543.723[DPC]TeamGrazzie0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.496.948Sp@ceNv@der0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.058.648Searchy! Internet Services V.O.F.0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.021.564[DPC] Switch0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.814.160o25o & Dharkon0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.234.049Ensign Wildfire0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.569.152[DPC]Spinpoint0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.316.063[DPC]Trancemaus0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.252.415F@stmem0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.874.967Mr Beamer0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.799.706AmeComputers0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.722.489Jan Zandvliet & x-RaY990(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.483.537[DPC]Team Zuid-Holland0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.349.169Tijntje0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.282.663ray0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.134.326Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.121.415visvogel0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.048.227Berkie0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)940.510Override0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)909.515Dadoke0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)880.749Jox4440(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)790.791Rydo0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)630.270MaGNeT aka BlueTooth760(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)626.692MaNDaRK0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)618.313[DPC] Brainy0070(-)
More...
Teams Daily Top 15
posdailyteamtotal
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.017.816.364SETI.USA0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)155.845.176Phoenix Rising0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)151.679.643Canada0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)148.700.366Ars Technica0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)147.640.914BOINC.Italy0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)146.963.867Amateur Radio Operators0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)145.895.877U.S.Air Force0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)140.282.161BOINC@AUSTRALIA0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)132.204.067Dutch Power Cows0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)130.992.183UK BOINC Team0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)130.032.451Universe Examiners0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)125.590.221BOINC@Poland0(-)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)123.592.329AUSTRIA - NATIONAL - TEAM0(-)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)118.176.661BOINC SETI@home RUSSIA0(-)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)116.388.807PC Perspective Killer Frogs0(-)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)113.733.512Team NIPPON0(-)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • grass460
grass460
ik zag het vannacht al ja, dit is gewoon jammer voor ons DPC'rs
knip nieuws zie APCIII |:(
ships niet verder gekeken dan me neus lang is |:(
[ Voor 180% gewijzigd door grass460 op 22-04-2009 18:41 . Reden: nieuws update ]
  • RetroTycoon
  • Laatst online: 00:55
Dat er geen nieuw topic is, vind ik wel handig eigenlijk... dat maakt het makkelijker F@H (waar ik zelf ook aan deelneem) in de gaten te houden. Is er een reden dat er dagelijks een nieuwe wordt aangemaakt, of is dit zomaar ontstaan? Want als dat zo is, dan stel ik voor dat er een centraal topic wordt geopend :D
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
RetroTycoon schreef op woensdag 22 april 2009 @ 18:42:
Er is ooit vastgesteld dat de "drukbezochte" projecten dag-topics krijgen en de "rustige" in weektopics gezet worden. Hier wordt periodiek naar gekeken en indien nodig wordt dat aangepast.
Lees onder andere dit: Dagtopics versus weektopics
  • RetroTycoon
Mmm, waarom kan dat dan wel bij WhatPulse (just for my info) ;)
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
RetroTycoon schreef op woensdag 22 april 2009 @ 19:06:
Geen idee, ik ga daar niet over ;)
Voor op/aanmerkingen en/of klachten wendt u zicht tot de dienstdoend moderator :P
Ik dacht dat WP van oudsher één lang topic was (ook toen het nog niet in /5 te vinden was)
Verwijderd in "[DPC] Discussie Whatpulse"
  • RetroTycoon
Die conclusie trek je wel na het lezen van dat topic... Nou iig, bedankt voor de duidelijkheid :)
