[SETI@Home] hitparade van 23 februari Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
weinig te vertellen vandaag
geen leden en geen mijlpaal vandaag :?
dan maar wat nieuws van seti
23 Feb 2009 21:06:51 UTC
Our outbound traffic has been pegged since Friday. This may seem like only a download problem, but it even affects uploads, as the basic syn/ack handshaking packets on the upload server get dropped along with the rest of the download packets that can't make it through the dam.
After discussions with Eric and Jeff, here's what we gather is happening. We use coral cache to reduce our bandwidth needs. Coral cache is an easy-to-use, free, third-party system which does some nice distributed caching just by redirecting the right apache requests to their servers. For example, somebody wants to download the latest astropulse client, they go to our download server, and then they redirected automatically to the coral cache server. The redirect is of the form such that, if the coral cache server hasn't done so already, it downloads the latest astropulse client from us, caches it, and then sends it to the requester. Once cached, it doesn't need to contact our servers again. So, in essence, all but one of the client download requests hit originate from sources outside our lab, thus saving us lots of bandwidth.
That brings us to problem 1. Many ISPs don't like redirects to third-party IPs. This is understandable. What happens in this case is a client downloads a new application, but instead of getting the actual executable they get a blob of HTML saying "this ISP doesn't like third party redirects," etc. Obviously the checksum of this HTML blob won't match the executable checksum, resulting in an application download checksum error. This has been a known problem. So we've been only using coral cache during the first couple of weeks after a new application is made available to reduce the pain of the download rush. A small fraction of our users will be inconvenienced by those redirect errors, but they'll get their clients in due time when coral cache is turned off after the initial "wave."
But then there's problem 2. An application download checksum error (a) doesn't cause exponential backoff and (b) causes all workunits also requested by this particular client to be errored out and resent. This is at least the behavior is older, yet still commonly used, boinc clients. Dave said most of that has been addressed, but if they're still bugs they'll be fixed.
In any case, what we saw this weekend was a confluence of these two problems. This may not have been an issue before due to lighter traffic patterns, but we sure fell off the deep end this time. Maybe there was a small set of heavily active clients this time around causing most of the pain. And once the network gets pegged, all hell breaks loose, and it takes a while to heal itself.
Eric actually had most of this figured out before we arrived today, and already turned off coral cache. At least the broken redirects spiraling out of control would stop happening. He also adjusted the tcp settings on the upload server to help get those partially working again (instead of only 2% uploads getting through, now it's about 50%).
The plan is to let this current state of indigestion pass on its own, and if needed change some BOINC settings (if not also BOINC code) so that future coral cache attempts will be direct links as opposed to apache redirects.
- Matt
gaat dus over het upload en download probleem
wat we dus ook aan de stats kunnen zien man wat een lage output |:(
i say tada :w
DPC SETI@Home hitparade van 23 februari 2009
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 64 / 962 (6,7 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)4.723[DPC] hansR14.498.103(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.888Searchy! Internet Services V.O.F.8.036.637(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.268[DPC]TeamGrazzie11.989.418(2)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.796[DPC] Switch8.326.360(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.932F@stmem1.901.889(10)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)1.255ray1.145.097(17)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.074Sp@ceNv@der10.405.082(3)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)1.024[DPC] Brainy007537.895(31)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)897o25o & Dharkon4.621.239(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif40)894Jox444769.525(25)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)852Teun Leijten135.079(102)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)839Ensign Wildfire2.885.554(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)798Dadoke849.595(24)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif80)770Shuwi99.965(125)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)541dpc_kluizenaar206.880(74)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)514Bram35.332(224)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)496dr bommel342.143(54)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)437Sylvester132.817(104)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)302Herby347.717(51)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)290Jan Zandvliet & x-RaY991.625.052(12)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)272Robin Ovaere315.187(57)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)270Joey van den Berge182.891(83)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)270Mr Beamer1.752.893(11)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)242BlueTooth76244.763(66)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)221seridan401.441(40)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)170Tijntje1.284.196(16)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)170trout168.234(86)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)131grass46094.397(128)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif35)130Toaby40.576(207)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)129ozzo74.001(143)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.498.103[DPC] hansR4.723(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.989.418[DPC]TeamGrazzie3.268(3)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.405.082Sp@ceNv@der1.074(7)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.326.360[DPC] Switch2.796(4)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.036.637Searchy! Internet Services V.O.F.3.888(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.621.239o25o & Dharkon897(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.885.554Ensign Wildfire839(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.537.723[DPC]Spinpoint0(-)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.197.833[DPC]Trancemaus85(37)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.901.889F@stmem1.932(5)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.752.893Mr Beamer270(23)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.625.052Jan Zandvliet & x-RaY99290(20)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.618.781AmeComputers72(40)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.502.870MAX34000(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.463.564[DPC]Team Zuid-Holland48(43)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.284.196Tijntje170(26)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.145.097ray1.255(6)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.129.217Speedy67 & Friends0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.115.935visvogel0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.069.176[DPC] Anticimex & Lock Metaaldetectie0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.049.597[DPC]SjoQing0(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.033.087Berkie54(41)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)852.862Override17(63)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)849.595Dadoke798(13)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)769.525Jox444894(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)747.082Rydo0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)673.789Psyed0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)626.692MaNDaRK0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)563.965holy-shit0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)557.899sebastiaan0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.263SETI.Germany757.168.993(2)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)42.533OcUK - Overclockers UK191.959.294(16)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)42.453Elite Games94.221.472(37)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)40.506UK BOINC Team121.689.065(29)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)40.477Ars Technica140.751.649(20)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)34.698AUSTRIA - NATIONAL - TEAM116.815.461(30)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)34.375Team NIPPON105.130.456(34)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)34.041Universe Examiners122.130.321(28)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)32.744Dutch Power Cows122.796.907(27)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)32.111BOINC SETI@home RUSSIA111.003.701(32)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)27.567BOINC.Italy140.408.938(21)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)27.114Team Norway54.125.016(57)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)26.985RoEduNet58.491.038(51)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)25.981Planet 3DNow!89.210.850(38)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)24.554Hungary94.694.972(36)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)24.275Microsoft58.456.669(52)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)963.141.916SETI.USA222.819(2)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)140.751.649Ars Technica40.477(29)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)140.408.938BOINC.Italy27.567(35)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)139.815.178Canada49.471(21)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)139.771.737Phoenix Rising42.757(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)135.338.953U.S.Air Force44.797(23)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)133.985.779Amateur Radio Operators53.495(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)126.765.825BOINC@AUSTRALIA62.618(16)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)122.796.907Dutch Power Cows32.744(33)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)122.130.321Universe Examiners34.041(32)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.689.065UK BOINC Team40.506(28)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)116.815.461AUSTRIA - NATIONAL - TEAM34.698(30)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)113.233.285BOINC@Poland74.097(14)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)111.003.701BOINC SETI@home RUSSIA32.111(34)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)110.470.463PC Perspective Killer Frogs19.913(48)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)105.130.456Team NIPPON34.375(31)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]TeamGrazzie553.05604-01-2008
2.chelloo.com261.22709-01-2008
3.[DPC]Spinpoint174.42314-06-2007
4.hansR170.40917-08-2008
5.REISinformatiegroep165.30718-04-2007
More...
When do you get them
TeamAverageDays
BOINC.Italy129.902385
Ars Technica137.366469
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
Ach heb vanmorgen nog over de 600 WU's kunnen inleveren, dus ik klaag even niet :X
Maar wel lastig ja dat up en download probleem.
  • Keiichi
  • Laatst online: 22-11 21:25
Ahhhh!! :o Ik heb per ongeluk al m'n clients van seti@home gedetached :'(
nu wel weer terug gezet via bam *O*
-edit-
Nu moet ik al mijn optimized clients weer installeren :'( :'(
[ Voor 24% gewijzigd door Keiichi op 24-02-2009 13:57 ]
Penpal International: https://www.penpalinternational.net/ - Mijn solar: https://frankdebot.nl/solar/
Keiichi schreef op dinsdag 24 februari 2009 @ 13:51:
OMG, dat was niet zo slim, maar welkom terug *O* *O* *O*
  • Keiichi
Ik merk net dat eigenlijk weer niets het doet bij seti.
Even een ander project bijschakelen maar weer.
Keiichi schreef op dinsdag 24 februari 2009 @ 15:42:
24/02/2009 19:56:52|SETI@home|Message from server: Project is temporarily shut down for maintenance
  • Keiichi
Verwijderd schreef op dinsdag 24 februari 2009 @ 19:57:
Dat is gewoon de wekelijkse maintenance. Maar het uploaden en downloaden van bestanden werkt sowieso nog niet 100%. (Zie startpost)
  • grass460
grass460
heb er nu ook een 2e project bij genomen als backup :? :)
  • Keiichi
grass460 schreef op dinsdag 24 februari 2009 @ 20:17:
Zolang je maar niet zoals mij heel seti@home detached :P
  • APClll
  • Laatst online: 23-11 22:22
APClll
FP ProMod
[DPC] Team Grazzie
Keiichi schreef op dinsdag 24 februari 2009 @ 20:20:
Hoe lang loop je hier nu al? Nou dan...
Prutser!
Ach, dan heb je tenminste geleerd dat je in 't vervolg niet meer op dat knopje moet drukken ;)
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • Keiichi
APClll schreef op dinsdag 24 februari 2009 @ 20:34:
Prutser!
Die bam manager is ook niet echt de overzichtelijkste.
Ik heb plannen om een programmatje te maken dat naast boinc draait dat ik vanaf een centraal punt alle client kan controleren alsof lokale clients zijn. :Y) Ik heb het al helemaal uitgedacht, maar nog geen tijd voor gehad om uberhaupt een start er mee te maken ;(
Het up en downloaden gaat nu weer goed bij me. Alleen kan nog niet valideren door die maintenance.
Net ook even al mijn post nagelopen, wel leuk om te lezen hoeveel moeite we hebben moeten doen voor de eerste 100k. Althans in mijn geval dan :$
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Keiichi schreef op dinsdag 24 februari 2009 @ 20:46:
Daar heeft iemand anders ook ooit een begin mee gemaakt geloof ik.
zie hier: \[BOINC/Rosetta] Monitoring-tool : BAM
Dit is, voor zover ik weet, niet dezelfde BAM als die aangeboden wordt via boinc-stats ( http://nl.boincstats.com/bam/ )
  • grass460
grass460
hell no
draai em er gewoon naast en dan tijdelijk suspenden en uiteraard deadline in de gaten houden ;)
btw denken jullie aan de stampede
Heb al gestemd, jammer genoeg zal SETI nooit gekozen worden als stampede :'(
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Verwijderd schreef op dinsdag 24 februari 2009 @ 22:30:
Zeg nooit nooit :P
Ieder jaar komt er een project aan de beurt --> dat project mag in het vervolg niet meer meedoen.
Zolang er niet elk jaar een nieuw officieel DPC-project bij komt, zit de kans er in dat we ooit aan de beurt komen.
Ooit... ;)
  • Rone
Rone
Moderator Tweaking
Ben zelf nieuw in het SETI@Home-onderdeel. Heb inmiddels vijftien afgeronde opdrachten, maar slechts vijf daarvan zijn daadwerkelijk doorgevoerd. Ik ga ervan uit dat het met hun serverproblemen te maken heeft dat er zoveel succesvol afgeronde opdrachten op 'pending' blijven staan.
Die zullen op een gegeven moment automatisch worden goedgekeurd, lijkt me?
Oeps, ik had iets langer door moeten zoeken. :)
[ Voor 21% gewijzigd door Rone op 25-02-2009 14:07 ]
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
Welkom alvast r00n *O* *O*
  • apa
  • Laatst online: 26-10 14:51
apa
Run Forest, ruuuuuuuuuunnnnn!!
En ik die dacht dat 150000 een mijlpaal waard was?!
Nah... misschien niet voor Belgen dan ;)
PC: Dell Pro Max 16+ (MB16250) | 64GB | 2x 4TB | SD25TB5 | Eizo CX240 | Steinberg UR22MkII | JBL LSR305
