[vraag] is de pc goed?
  • 415 views
  • ErrorNL
  • Laatst online: 01-12-2023
hoi,
ik wil een pc die er de komende jaartjes mee mee kan. ik download nogal veel dus heb altijd de nieuwste spellen als ik dat wil. mijn pc moet ook snel zijn. is dit dan een goede pc:
General Spec:
Brand : ANKERMANN-PC
Series :INTEL Gaming
Model : ANL-82626
Intel Core2Quad Q9550 - (4x 2.83 Ghz)
Model Q9550 Yorkfield (M1 / SLAWE) FSB 1333 64 and 32 Bit Quad-Core Processor
NVIDIA® GeForce® 9800GTX+ 512MB PCi-e
Memory 4GB DDR2-1066 KINGSTON PC8500
500GB Maxtor 7200rpm 32MB cache
LG GSH GH22 LS15 DVD-RW Dual Layer LightScribe
ASUS Mainboard P5Q Pro (GBL/R/F/DDRII) (dual PC2-6400U DDR2)
IEEE1394 FireWire Port
52 in 1 Cardreader for Free
600Watt Power Supply
Case A-DIS - >N8igal< side Window Blue Light
Recommended Usage:
Gaming & Business Desktops & Workstations
CPU:
CPU Type : CPU INTEL S775 Core 2 Quad Q9550 FSB1333
Intel Core 2 Quad Q9550
Model Q9550 Yorkfield M1
FSB 1333 | 4x 2,83 Ghz
L2-Cache (Toatal) : 2x 6144KByte shared Cache
Trusted Execution Technology (TXT)
CPU Main Features : 32 Bit & 64 Bit Dual Core Processor
CPU Cooler:
CoolerMaster (Quiet) So.775 CPU Cooler
Graphics: (16x PCI-E CARD)
GeForce NVIDIA® GeForce® 9800GTX+ Graphics
Windows® Vista Premium H/W and Windows® XP Ready
Graphics Media Accelerator with 512MB Memory
PCI Express x16
NVIDIA GeForce 9800 GTX+
512 MB
DDR3
256 Bit
DirectX 10
Mainboard:
Chipsatz Intel P45 / ICH10R
Sockel LGA 775
Format ATX
Busclock 1600/1333/1066/800 MHz FSB Memory 4x DDRII 1200/1066/800/667 bis max
16GB
Steckplätze 2x PCI
3x PCI-Express 1x
2x PCI-Express 16x
IDE 1x UltraDMA 133
6x SATAII
RAID 0,1,5,10
LAN PCIe GB LAN
Schnittstellen 2x PS/2
12x USB
2x 1394a
Sound :ALC1200-8CH (HD)
Ethernet : Integrated 10/100/1000 BaseT Network
Keyboard : no
Mouse : no
Operating System : not installed
you can order Operating Systems under Software
gerne können Sie Software zur Installation bei uns Bestellen
Memory: (KINGSTON)
Memory Capacity : 4GB DDR2 PC8500 - 1066Mhz Type KINGSTON
Memory Speed : DDR2 PC8500
Form Factor : DIMM 240-pin
Memory Slots (Available/Total) : 2/4
Maximum Memory Supported : 8GB
Hard Drive :
HD SATAII 500GB Maxtor 7200rpm 32MB
HD Capacity : 500GB
HD Interface : SATA-II
HD RPM : 7200rpm / 32MB Cache
Optical Drive:
Optical Drive Type : LG GSH GH22 LS15 DVD-RW Dual Layer LightScribe
Optical Drive Spec : SuperMulti DVD Burner with LightScribe Technology 22x DV
D±R, 8x DVD+RW, 6x DVD-RW, 8x DVD+R DL, 8x DVD-R DL, 12x DVD-RAM, 16x DVD-ROM
40x CDR, 32x CDRW, 40x CD-ROM
Audio:
Audio Chipset : Integrated 8 Channel
Realtek ALC888 7.1
Communications:
Modem 56k modem : no
LAN Chipset : Integrated GB-LAN
LAN Speed : 10/100/1000 - GigaBit LAN
Front Panel Ports:
Front USB : 3
Front Audio Ports : 1 x headphone/line-out, 1 x microphone in
Card Reader : Front panel 23-in-1 memory card reader: supports SmartMedia
XD MultiMedia Card, Secure Digital (SD), Mini Secure Digital, Compact Flash I
Compact Flash II, IBM Microdrive, Memory Stick, Memory Stick Pro
Memory Stick Duo, Memory Stick Pro Duo, RSMMC, MMC Mobile, MMC+
Back Panel Ports:
PS/2 : 2
Video Ports : 0x VGA/2x DVI
Rear USB : 4
RJ45 : 1 port
Rear Audio Ports : 6 ports
Expansion:
External Bays : 3 x 5.25" external
1 x 3.5" external
Internal Bays : 4 x 3.5" internal
PCI Slots (Available/Total) (1/2) PCI slots
(2x) PCI-E x16 Slot
(2x) PCI-E x1 Slot
(3x) PCI Slot
Physical Spec
Dimensions : LxBxH = 45x18,5x43 (all in cm)
Weight 21.25 lbs.
Manufacturer Warranty (Garantie)
Parts 2 Year not limited
b.v.d ErrorNL
PS: is http://ankermann-pc.com/ een veilige site, heeft er iemand hiermee ervaring?
ik wil een pc die er de komende jaartjes mee mee kan. ik download nogal veel dus heb altijd de nieuwste spellen als ik dat wil. :') _O-
ja ik ook , doei , zou zeggen zoek het effe zelf uit ;)
Iets met topic report, een handje (Afbeeldingslocatie: http://tweakimg.net/g/forum/images/icons/icon_hand.gif) en Policy m.b.t. replies in 'slechte' topics ;). Voortaan even op letten.
[ Voor 34% gewijzigd door Thandor op 17-11-2008 20:47 ]
  • Vidra
  • Laatst online: 24-10 09:15
Vidra
Vragen?
Ja hoor,
Zie ook de nieuwe Tweakers.net Best Buy November 2008
Succes!
[ Voor 4% gewijzigd door Vidra op 17-11-2008 20:36 ]
Executive Director | aan mijn uitspraken kunnen geen rechten worden ontleend! | Build: AMD 7800X3D - 32GB - AMD RX 7900XTX
  • Fiber
  • Laatst online: 23:28
Fiber
Beaches are for storming.
  • Vidra
Vidra
Vragen?
Verwijderd schreef op maandag 17 november 2008 @ 20:29:
:X
[ Voor 36% gewijzigd door Thandor op 17-11-2008 20:47 ]
  • Noork
Ik zou de duurste Intel Core i7 nemen, omdat die voor gamers is.
  • kestemodon
  • Laatst online: 31-10 09:15
bha in principe is het een goede pc maar ik zou misschien toch zoeken achter een pc met een ATI 4870. Deze zouden een stuk beter presteren voor dezelfde prijs. Of wacht effe af een neem een i7
[ Voor 9% gewijzigd door kestemodon op 17-11-2008 20:42 ]
  • Thandor
  • Laatst online: 22:32
Thandor
SilverStreak
Aldus het CSL beleid is dit inderdaad niet de bedoeling op GoT :o. Derhalve ga ik het topic sluiten.
Zoals in het beleid aangegeven kun je het beste de Best Buy Guides ter hand nemen. Ook kun je HOWTO: Hoe stel ik een systeem samen? raadplegen. Daar wordt onder andere uitleg gegeven over het zoeken naar hardware, reviews en benchmarks. Zo zijn er speciale websites die hardware testen en hier verslag van uitbrengen. Tweakers.net brengt zelf ook reviews uit en bezoekers van Tweakers.net hebben ook de mogelijkheid om hun woord te doen over iets in de product reviews :).
Al met al zijn er veel bronnen, waaronder ook de productpagina's van fabrikanten, die je kunt raadplegen om te kijken welke producten goed zijn. Zet alle gevonden informatie even op een rij en ga afwegen (prijs, features, prestaties, etc.). Het enige wat je dan nog te doen staat is het bestellen, opbouwen en tweaken van de nieuwe hardware ;).
