• Koldur
  • Laatst online: 08-11 11:09
Zo aangezien er de laatste tijd een explosieve groei is, naar vragen over deze moederborden is er een deel II nodig om verder te posten.
Images
Afbeeldingslocatie: http://tweakers.net/ext/i.dsp/1149676002.jpg
Afbeeldingslocatie: http://tweakers.net/ext/i.dsp/1149628292.gif
Features
Processor
  1. Supports Intel® Core™2 Extreme Quad-Core / Core™2 Duo / Intel® Pentium® Extreme/ Intel® Pentium® D processors
  2. Supports1333/1066/800/533 MHz FSB
Northbridge
  1. Intel® P965 Express Chipset
Memory
  1. Supports DDR2 800/667/533 memory
  2. Dual Channel architecture support up to 8GB by 4 DIMM slots
Form Factor
  1. ATX form factor, 305 x 244mm
Internal I/O Connectors
  1. 1 UDMA ATA 100/66/33 connector
  2. 1 FDD connector
  3. 3 USB 2.0/1.1 connectors (support 6 ports)
  4. 1 audio pin header (support 8-Channel)
  5. 1 S/PDIF In pin header
  6. 1 Chassis Intrusion connector
Rear Panel I/O
  1. 4 USB 2.0/1.1 ports
  2. 1 RJ45 port
  3. 1 COM port
  4. 1 LPT port
  5. 6 audio jacks
  6. 1 SPDIF Out connection (coaxial+optical)
  7. PS/2 Keyboard/Mouse
Bios
  1. 1 4 Mbit flash ROM
  2. Use of licensed AWARD BIOS
  3. Supports Virtual Dual BIOS
  4. PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b.
Verschillen
ModelnaamGA-965P-S3 Rev 3.3GA-965P-DS3 Rev 3.3GA-965P-DS3P Rev 3.3GA-965P-DS4 Rev 3.3GA-965P-DQ6 Rev 3.3
Solid CapsNeeJaJaJaJa
Heat PipesNeeNeeNeeJaJa
Expansion Slots
1 PCI Express X16
3 PCI Express X1
3 PCI
1 PCI Express X16
3 PCI Express X1
3 PCI
2 PCI Express X16 (x16, x4)
3 PCI Express X1
2 PCI
3 PCI Express X1
2 PCI
3 PCI Express X1
2 PCI
Sound ChipRealtek ALC883Realtek ALC888Realtek ALC888Realtek ALC888Realtek ALC888D
Netwerk ChipMarvell 8056 Gigabit LAN ControllerMarvell 8053 Gigabit LAN ControllerMarvell 8056 Gigabit LAN ControllerMarvell 8056 Gigabit LAN ControllerMarvell 8056 Gigabit LAN Controller
FireWireNeeNeeJaJaJa
SouthbridgeIntel® ICH8Intel® ICH8Intel® ICH8RIntel® ICH8RIntel® ICH8R
Sata Poorten66888
BiosF8F10F4F8F9
Cross FlashDS3S3DS4?,DQ6?DQ6,DS3P?DS4,DS3P?
Huidige Prijs101,94105,96135,52148,28192,26
ReviewsAnandtech (Rev ?.?)Hardwarezone (Rev 2.0)Firingsquad (Rev ?.?)
FAQ
Waarom een P965?Op SLI performance na is de 965 chipset momenteel de chipset met de beste performance. Andere populaire chipsets zijn de Intel 975x en Nvidia nForce 650 en 680. Mocht je SLI/CrossFire willen dan is een 965 geen goede keuze. Voor SLI is van de nForce borden de Asus P5N32-E SLI Plus het vermelden waard. Dit bord is identiek aan de 100 euro duurdere Striker Extreme (de Striker Extreme tekst is met een stickertje afgeplakt) met alleen iets andere heatpipes/geen lcd poster/geen leds en switches op het bord/andere chipset uitvoering waarbij het derde PCI-e 16 slot (8x) aan de southbridge zit. Qua performance geen enkel verschil. De Intel 975 chipset is ouder dan 965, duurder en haalt iets minder hoge clocks, maar voor CrossFire een beter keuze. Voor meer informatie over bijna alle Core 2 Duo moederborden, is dit een subliem topic, helaas staat de DS4 er niet bij, dit zou volgens mij #1 bij de P965 geweest zijn, prijs/feature van DS3 met de features van de DQ6.
Waarom een Gigabyte P965?Van de 965 borden zijn de Gigabyte en Asus series het populairste, qua geboden features/prijs is de Gigabyte serie iets goedkoper. Qua kloks maakt het niets uit en zal het meer per exemplaar verschillen.
Welk Gigabyte bord is aan te raden?Prijs technisch valt de S3 af, 4 euro voor een betere soundchip en solidcaps(DS3). De DS3P lijkt prijstechnisch ook geen logische keuze, voor 13 euro meer heb je heatpipes (DS4). Ook de DQ6 lijkt geen 44 euro extra waard voor Virtual 12 Power Phases en Dolby Digital encoding.(DS4) De DS3 en de DS4 zijn de aanraders dus. De vraag is of je 42.50 over hebt voor Matrix raid (DS3P/DS4/DQ6 hebben ICH8R en S3/DS3 niet), Crossfire, Firewire, Heatpipes en nieuwere lan chip.
Wat voor geheugen moet ik halen?De laagste multiplier voor je geheugen is 2. Je zult dus moeten kijken op welke bus je waarschijnlijk gaat draaien. Daarna is het 4 x bus = PCXXXX. Voorbeeld een e4300 heeft een bus van 800, deze wil je overklokken naar een bus van 1333. Het geheugen moet dan op 4 x 1333 = PC5328 kunnen draaien, wat met PC5300 prima moet lukken. Qua merk en type valt het aan te bevelen altijd geheugen te kopen wat in de Memory Support List staat. Geheugen draaien boven 1:1 (2 x bus), geeft nauwelijks extra performance, echter kan dit in specifieke toepassen tot 15% (per snelheidsverdubbeling) snelheidswinst opleveren. Ook cas timings maken weinig verschil, ook dit kan in specifieke gevallen tot 3% (per cas sprong) snelheidswinst opleveren.
Welke CPU moet ik halen?Dit is behoorlijk persoonlijk. Een Core 2 Duo is aan te bevelen en van de Core 2 Duo's zijn vooral de e6600, e6300 en e4300 populair. Iemand die niet gaat overklokken is waarschijnlijk het beste af met een e6600. Iemand die wel gaat overklokken kan voor een e4300 of e6300 kiezen, beide hebben wel 2MB cache en de e6600 4MB. Het voordeel van de 2MB extra cache is gemiddeld vrijwel weg bij een 200 MHz hogere clock. De e4300 heeft als voordeel dat deze een hoge multiplier heeft en dus op minder hoge bussnelheden hoeft te draaien (waar door dus ook goedkoper geheugen gebruikt kan worden), als nadeel heeft de e4300 geen Virtualization Technology, iets wat momenteel alleen vertraging geeft en door de meesten niet gebruikt zal worden.
Passen alle koelers?Nee, van sommige koelers schijnt het plastic bevestigingssysteem niet tussen/over de caps te passen, anderen schijnen de heatsinks (DS4/DQ6) te raken. In de laatste categorie valt i.e.g. de ThermalTake Big Typhoon. Er zijn wel mods voor de Big Typhoon. Veel mensen met een Big Typhoon klagen over een niet vlak heatsink oppervlak. Ook de Scythe Infinity schijnt niet op de normale manier te passen.
Ik wil graag onboard graphics, kan dat ook?Ja, de DS3 en DS4 zijn er ook met de Intel G965 chipset. Overklokken zal aanzienlijk beperkt worden!! 1333 zal al een hele opgave worden! Ga je niet overklokken dan is het een leuke chipset voor de doorsnee persoon, maar ja die verwacht ik hier niet zo snel :D !
Waar kun je de revisie zien?De revisie staat alleen linksonder op het PCB, onder het onderste PCI slot.
Wat zijn de verschillen tussen de revisies?In het kort: andere soundchips, ander lancontrollers, andere PCB layout, officiële FSB support.
In het lang:
Rev 1.0 is de eerste (duh...) versie waarbij er wat probelemen waren met bepaalde geheugen modules en hoge overklok resultaten (D9 chips en hoger dan 420 was erg lastig, met BIOS versie F8 schijnt het beter te gaan maar nog niet optimaal). Deze geheugen problemen deden zich trouwens niet voor bij de DS4 en DQ6 (over het algemeen niet in ieder geval!).
Ook was de PATA connector niet helemaal lekker geplaatst en hoogst waarschijnlijk nog wat kleine dingetjes die ze anders wilden zien.
Hierop volgde de Rev 2.0, hierbij is er een voltage circuit aangepast zodat het D9 probleem verleden tijd moet zijn. Ook zijn de netwerk- en geluidskaart vernieuwd, niet zo erg spannende veranderingen maar dit is wel gebeurd.
In de Rev 3.3 is er één "grote" aanpassing, namelijk de officiële ondersteuning voor 1333 FSB (333 quad pumped dus) toegevoegd. Dit is natuurlijk leuk voor iedereen, maar het mag natuurlijk geen probleem vormen voor een echte tweaker :X , als de andere apparatuur geen probelemen heeft (CPU, mem, voeding) kan 99,9% van deze borden 1333 overgeklokt aan zonder dat dit problemen geeft. Ook zou het geen gevolgen moeten hebben voor geheugen timings aangezien de BIOS voor iedere revisie, binnen dezelfde lijn, identiek is.
Als je nu een bord koopt en je wil per sé een Rev X.X moet je wel van te voren vragen welke je zou krijgen bij de desbetreffende winkel! Het kan heel goed zijn dat je gewoon nog een Rev. 1.0 voorgeschoteld krijgt! Niet dat het mij veel uit zou maken, maar ik ben jou natuurlijk niet ;)
Werkt dit bord ook goed met Windows Vista?Ja, ze zijn "Windows Vista Ready", al hoe wel dit voor een moederbord niets anders zegt dan dat het bord High Definition audio heeft, (ja, zelfs de Vista drivers hoeven er niet te zijn, "Windows Vista Ready" zegt dus niets, zoek liever naar Windows Vista Logo program) werkt dit bord prima en alle Vista drivers zijn beschikbaar, ook voor x64.
Ondersteunt dit bord SLI/Crossfire?SLI/Crossfire kan alleen op de borden met 2 PCI-e 16 poorten (DS3P,DS4,DQ6) en alleen Crossfire wordt officieel ondersteunt, SLI werkt alleen met gehackte drivers. Het probleem met SLI en Crossfire is dat de tweede SLI poort op 4x (de 3 PCI-e x1 worden uitgeschakeld en de link wordt gedeeld met Jmicron IDE/SATA en Marvell Lan) draait en de link (2 GB/s te delen met USB, netwerk, SATA, Firewire en audio) via de southbridge gaat, waardoor je erg veel performance verlies zult hebben. Er is nog geen enkel bord welke de 16 lanes uit de northbridge van een 965 via een bridgechip naar 2 x 8 splitst, volgens Intel moet dit wel mogelijk zijn, maar is dit uit kostenbesparing door geen enkele fabrikant nog gedaan.
Wat zijn MCH, ICH en FSB termination en wat zijn de ideale voltages?MCH (Memory Controller Hub) is de northbridge, ideale voltage is zo laag mogelijk zonder crashes, aanbevolen max 1.55v (+0.3v). ICH (I/O Controller Hub) de southbridge, ideale voltage is zo laag mogelijk zonder crashes, aanbevolen max 1.75v (+0.25v). FSB (Front Side-Bus) termination is een active termination system, welke een weerstand waarde geeft, de ideale stand is in elke situatie weer anders en omdat we de specificaties en berekening niet weten kun je het beste gewoon wat proberen, aanbevolen max 1.45v (+0,25).
Waarom is mijn corevoltage lager dan ik heb ingesteld?Dit verschijnsel staat bekend als vdroop. Stel dat je 1.5v in je bios zet, krijg je 1.44v volt idle en 1.39v bij load. Er is een mod om dit verschijnsel te verminderen. Verschillen van 0,02 zijn normaal en als C1E halt state aanstaat gaat de processor terug naar een lager voltage indien deze idle is, daarom wordt het voltage ook als een bereik aangegeven. Door vdroop is het dus erg belangrijk je overklok/voltage te testen onder full load, het kan namelijk zijn dat je voltage bij full load te weinig is. TAT kan beide cores voor 100% belasten en is dus een mooie test. Vdroop is geen enkel probleem als je niet overklokt, de Core 2 Duo processoren krijgen veel meer voltage dan ze eigenlijk nodig hebben.
Mijn chipset wordt heel erg warm?Dit is normaal, maar kan wel zorgen voor slechtere kloks, vooral de borden zonder heatpipes doen het vaak beter met een fan direct/gericht op de chipset.
Mijn geheugen draait standaard op lage timings/systeem boot niet?Het geheugen staat standaard op 1.8v, veel dimms hebben 2-2.1v nodig, kijk op site van de fabrikant. Sommige dimms hebben fail safe spd instellingen en zullen handmatige op de juiste timings gezet moeten worden.
Ik heb iets gelezen over problemen met een Fasttrack SX4100 en sommige 7600 en 7900 kaarten?Dit is vanaf bios F5 allemaal opgelost.
Ik mis een heleboel opties in mijn bios?Alle geavanceerde opties zijn verborgen tot je in het hoofdscherm van je bios op Ctrl+F1 drukt. Als je een S3 hebt kun je meer opties krijgen door een DS3 bios te flashen.
Wat zit er in de doos?Alle brackets zijn optioneel, het enige wat je er bij krijgt zijn SATA, IDE, een floppy kabel, manual en cd.
Welke powerconnectoren moeten aangesloten worden?Het bord heeft 3 connectoren, een 8 (4 bij S3/DS3) pins (CPU), een 4 pins (PCI-e) en een 24pins connector (Alles). Van de 8 pins zijn er 4 verplicht, van de 24 pins zijn er 20 verplicht. De 4 pins (molex) is eigenlijk alleen nodig bij 2 PCI-e videokaarten en zelfs dan niet verplicht. Er zitten dan ook geen converters bij het bord. Maar vul gewoon alles wat je kunt vullen. ;)
Mijn systeem gaat uit/blijft rebooten bij de eerste boot/bios verandering?Bij de eerste boot vind er een reset plaats. Gigabyte heeft een systeem wat je bussnelheid terug zet als je systeem niet boot, hiervoor gaat je systeem éénmaal uit na elke bus verandering die het geheugen op een andere snelheid dan 533/667/800 MHz zet. Hiernaast zal je systeem bij een overklok als het niet kan starten het een aantal maal herproberen voor het de bus terug zet.
Mijn CPU fan draait niet?De Core 2 Duo's blijven zo erg koel idle dat als Smart Fan/QST aan staat de fan niet hoeft te draaien.
4 pins fan headers?Intel gebruikt op socket 775 4 pins fan headers. AMD doet dit ook op socket AM2. Deze headers zijn compatible met 3 pins, met uitzondering van speed control. Wil je dus temperatuur geregelde fans via je moederbord, dan zul je 4 pins fans moeten hebben. (Let op! Het gaat niet over molex 4 pins!) Op de Gigabyte borden werkt speed control op 3 pins mogelijk ook gezien een compatible instelling in de BIOS.
Wat lees ik toch over IDE controllers?De 965 chipsets hebben geen support voor PATA, alle borden maken daarom gebruik van een one-lane PCI-e chip van JMicron, welke als GIGABYTE GBB36X Controller gebrand is. Hierdoor heb je 1 PATA poort en voegt hij 2 poorten SATA ( eventueel RAID) (0/1/JBOD) toe. Indien je optical drive UDMA ondersteuning heeft zouden er geen problemen op moeten treden, sommigen hebben wel problemen met PIO mode. Om je IDE poort te kunnen gebruiken onder dos kun je het beste de poort op Native zetten (SATA II 3G, NCQ, HotPlug werken dan niet) of deze driver gebruiken. De borden met de ICH hebben nog 4 SATA poorten en de borden met de ICH8R (DS3P/DS4/DQ6) nog 6 SATA RAID (0/1/5/10) poorten. Doordat de JMicron Controller niet in de ICH chip maar via de PCI-e bus verbonden is, zeggen sommigen dat door deze poorten te gebruiken hogere clocks zou halen. Dit lijkt onwaarschijnlijk aangezien de bus voor rekening van de MCH is. Ook schijnen er problemen met RAID op de JMicron controller te zijn, sowieso is de ICH8R sneller in performance!
Wat zijn straps?Door diverse mensen wordt gesproken over straps, dit is ook met Intel besproken op een meeting, dus dit lijkt echt te zijn. Afhankelijk van de bussnelheid, kom je in een andere strap terecht, hoe verder deze van je eigen strap af zit, hoe slechter de overclock zou zijn. Hierdoor doen sommigen een bus mod van de processor. Als je een bus mod doet moet je wel zorgen dat je bord stabiel boot op default voltage, anders zou je na een cmos reset niet kunnen booten, tenzij je ook je cpu voltmod.
Hoe kan ik goed overklokken?Een goed werkende methode is de volgende:
  • Zet je bios naar optimized defaults.
  • Zet je geheugen op multiplier 2.
  • Zet EIST en C1 Halt uit.
  • Probeer eerst de maximale bus te vinden door de multiplier op de laagste stand te zetten.
  • Zet je CPU op 1.55v (max aanbevolen 1.65v), MCH en FSB op +0.2v.
  • Verhoog nu je bus vanaf 333 met grote stappen (360, 390, 420 etc) tot je windows niet meer een paar minuten kan benchen. Probeer hierna met kleinere stapjes je max bus te vinden.
  • Hierna zet je de multiplier in stapjes weer om hoog tot je niet meer een paar minuten kan benchen.
  • Daarna verlaag je het voltage en ga je een beetje spelen met de multiplier/bussnelheid/voltages tot je een ideale mix van snelheden en temperatuur hebt. Denk ook aan je geheugen timings/voltages.
Hoe zit het met de temperaturen van Core 2 Duo processoren?Core 2 Duo's hebben 3 sensoren, één Tcase sensor tussen de cores en twee Tjunction sensoren (één in elke core). In de Core 2 Duo tabel zie je de thermal specification staan, dit is de maximale Tcase temperatuur (E4300 en E6300 61.4c, E6600 60.1c, X6800 60.4c). In de regel is Tjunction 15 graden hoger dan Tcase en 1 tot 3 graden verschil tussen de cores is normaal. Aan te bevelen is onder full load zo'n 10 graden van de thermal specification te blijven, Gigabytes speedfan lijkt te streven naar 5 graden lager. Wordt de processor 5 graden warmer dan de thermal specification dan gaat deze throttle-en, 10 graden warmer zorgt voor een shutdown. Er zijn problemen bekend met de temperatuur weergave van de e4300 in TAT en deze waardes zijn dus niet betrouwbaar.
Processoren
ProcessorIntel® Core™2 Duo Desktop Processor E4300Intel® Core™2 Duo Desktop Processor E6300Intel® Core™2 Duo Desktop Processor E6600Intel® Core™2 Extreme Processor X6800
Boxed Prijzen€151,00€175,09€285,90€910,00
Prijsschatting mei '07€110,00Gaat eruit, wordt 6320 met 4MB Cache €160,00€210,00???
sSpec NumberSL9TBSL9SASL9S8SL9S5
CPU Speed1.80 GHz1.86 GHz2.40 GHz2.93 GHz
PCG06060605B
Bus Speed800 MHz1066 MHz1066 MHz1066 MHz
Bus/Core Ratio9.07.09.011
L2 Cache Size2 MB2 MB4 MB4 MB
L2 Cache Speed1.8 GHz1.86 GHz2.4 GHz2.93 GHz
Package TypeLGA 775LGA 775LGA 775LGA 775
Manufacturing Technology65 nm65 nm65 nm65 nm
Core SteppingL2B2B2B2
CPUID String0F62h06F6h06F6h06F6h
Thermal Design Power65W65W65W75W
Thermal Specification61.4°C61.4°C60.1°C60.4°C
Core Voltage1.225V-1.325V0.850V-1.3525V0.850V-1.3525V0.850V-1.3525V
Box Order CodeBX80557E4300BX80557E6300BX80557E6600BX80557X6800
OEM Order CodeHH80557PG0332MHH80557PH0362MHH80557PH0564MHH80557PH0677M
Supported Features
  • Dual Core
  • Enhanced Halt State (C1E)
  • Enhanced Intel Speedstep® Technology
  • Execute Disable Bit 1
  • Intel® EM64T 2
  • Intel® Thermal Monitor 2
  • Dual Core
  • Intel® EM64T 2
  • Intel® Virtualization Technology
  • Dual Core
  • Intel® EM64T 2
  • Dual Core
  • Intel® EM64T 2
Unsupported FeaturesIntel® Virtualization Technology, vandaar ook geen vPro label.---
Links
Moederbord ModsVdroop, Vmch, Vdimm mod
Processor ModsVoltage Mod Bus Mod
Let op, dit is topic is alleen voor ervaringen! Zie ook.
Als je een probleem hebt waar je niet uit komt, mag je uiteraard een topic in PMG openen.
Probeer het eerst zelf op te lossen. Lees altijd de handleiding en kijk op de support pagina van de fabrikant. Zoek ook eens met google, in de google groups en met de search van het forum. Ook de FAQ's van de diverse fora hebben veel oplossingen. Als een vraag al gesteld is, of hij is makkelijk zelf op te lossen of te vinden, dan is het niet de bedoeling dat deze hier gepost wordt. Wees duidelijk, geef aan wat je al geprobeerd hebt.
Twee zeer leuke links naar een (Engelstalig) :
http://www.xtremesystems.org/forums/showthread.php?t=110460
http://www.xtremesystems.org/forums/showthread.php?t=109719
Met dank aan Swords voor de layout en een groot deel van de info!!
[ Voor 173% gewijzigd door Koldur op 28-03-2007 10:15 ]
i7 12700K,GB WindForce RTX4090,32GB KF436C16RB1K2/32,Gigabyte Z690 UD DDR4,Corsair RM1000x,WD Black SN850 2TB,Phanteks Eclipse P360A,Quest 3 VR Headset,Corsair iCUE H100i RGB Pro XT 240mm
  • |sWORDs|
  • Laatst online: 14-04 12:48
|sWORDs|
vSphere/ESXi
Gereserveerd voor startpost toevoegingen/wijzigingen
[ Voor 255% gewijzigd door |sWORDs| op 27-02-2007 20:24 ]
Te Koop:24 Core Intel Upgradeset
  • bassie
  • Laatst online: 03-11-2025
bassie
Je bent de Vmod's vergeten >:) die mogen niet missen.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
bassie_ schreef op zaterdag 24 februari 2007 @ 11:25:
Lol!!! Check mijn laatste edit, pas na het posten ervan zie ik je post! 8)
Tevens heb ik een tr aangemaakt met het verzoek een waarschuwing aan dit topic toe te voegen, zoals dion_b al had aangegeven.
[ Voor 20% gewijzigd door |sWORDs| op 24-02-2007 11:29 ]
  • DaannO
  • Laatst online: 23-11 21:59
|sWORDs| schreef op zaterdag 24 februari 2007 @ 11:04:
Onderstaande is misschien handig om uit te schrijven in de startpost:
Wat zijn de verschillen tussen de borden?
Verschillen met de S series, wat zijn solid caps?
Wijzen op de G965 serie met onboard graphics.
Stukje over bios uitwisselbaarheid.
ctrl-f1 geeft meer extra opties dan alleen de timings, welke?
Aan te raden max voltages, overclock tips.
Stukje over dividers/multipliers.
Stukje ove SLI/Crossfire, 16x en 4x.
Het is normaal dat er geen brackets bij zitten.
3 Pins/4Pins smartfan etc.
Jmicron controller.
Problemen met sommige koelers door caps en sinks.
Reviews.
Het is normaal dat je systeem een keer uitschakeld na het veranderen van voltages/1e cold boot.
Mods.
Plaatjes missen ook in de TS. Maak er anders een overzichtelijke tabel van. Dus alles binnen lijnen plaatsen. :)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
DaannO schreef op zaterdag 24 februari 2007 @ 11:29:
Ik wil wel weer een opzetje maken, maar het is zonde als er twee mensen tegelijk aan werken, ik wacht wel tot deze een stukje verder is en vul hem dan aan.
  • Koldur
Als jullie mooie stukjes hebben om toe te voegen zal ik dit dan ook doen in de TS, Vmods weet ik zelf niet zo snel links van. Ook gaat het meestal alleen maar om die Vdroop te verbeteren, terwijl dit een stanaard gebeuren is binnen Intel CPU's.
Maar natuurlijk is het iets wat er bij moet voor de tweaker!!
Ik heb nu even geen tijd om een mooie tabel te maken, maar een opzetje is natuurlijk nooit weg!
[ Voor 13% gewijzigd door Koldur op 24-02-2007 11:50 ]
  • KappeNou
  • Laatst online: 22-03 07:09
ik heb een probleem met overclocken op 3,2Ghz met mijn DS3P rev 2.0 en E6600 met 2x1G PC6400 kingston HyperX geheugen
Ik doe als volgt:
Clock ratio [8x]
FSB [400Mhz]
memory draaid dan op 800Mhz 1:1
latency ingesteld op 4.4.4.12
voltages:
DDR2 [+0.200V]
MCH [+0.10V]
FSB [+0.10V]
CPU [1.450V]
Dit draaid vervolgens anderhalf uur met orthos stabiel. Vervolgens nog een aantal divx films gecodeerd en 30uur de pc aangehad.
Als ik dan vervolgens de PC uit doe en opnieuw aan doe krijg ik geen beeld en blijft hij maar uit en aan gaan.. na me voeding even uit gehad te hebben zet die de FSB van 400Mhz weer op ze default waarde en start hij gewoon weer op.. Als ik dan reboot en weer handmatig 400Mhz instel clocked hij gewoon weer op 3,2Ghz :?
Dit probleem blijft zich dus gewoon voordoen als ik mijn PC uit zet en s'ochtends weer aanzet. Mateloos irritant dus
Iemand enig idee wat dit probleem kan zijn?
[ Voor 5% gewijzigd door KappeNou op 24-02-2007 16:07 ]
>PC specs<
  • |sWORDs|
|sWORDs|
vSphere/ESXi
KappeNou schreef op zaterdag 24 februari 2007 @ 16:03:
Ik doe als volgt:
Clock ratio [8x]
FSB [400Mhz]
voltages:
DDR2 [+0.200V]
MCH [+0.10V]
FSB [+0.10V]
CPU [1.450V]
Ja, hij heeft problemen met cold booten. Je zou kunnen proberen je voltages wat te verhogen.
  • KappeNou
gewoon alle voltages?
>PC specs<
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Als test wel, daarna 1 voor 1 weer verlagen tot je het probleem weer hebt.
Geheugen terug zetten naar default timings, EIST en c1 enzo uit schakelen.
MCH [+0.20V]
FSB [+0.20V]
CPU [1.55V]
[ Voor 21% gewijzigd door |sWORDs| op 24-02-2007 16:45 ]
leuk een 2de deel ,blijf ik lekr volgen :D
Vraagje wat is MCH voor functie? Bij mij staat die op auto . . .
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zaterdag 24 februari 2007 @ 18:50:
Heb je het rode stukje gelezen en dion_b's opmerking aan het einde van deel 1? Dit is echt de laatste search vraag die ik ga beantwoorden, dit is je northbridge.
[ Voor 10% gewijzigd door |sWORDs| op 24-02-2007 19:17 ]
  • bassie
bassie
theforce81 schreef op zaterdag 24 februari 2007 @ 11:44:
Tada, onderaan staan de Vdroop, Vmch, Vdimm mod.
|sWORDs| schreef op zaterdag 24 februari 2007 @ 11:28:
Lol, bij jou al enige vorderingen bij de mod's? Ik wacht nog op geld voor multimeter en wat andere nodige troep, tege de tijd dat ik ze heb en de mod gedaan is maak ik wel even wat pic's.
Iemand de Vcore mod al gevonden >:) ? Op XS ben ik em niet tegengekomen, iemand die em ergens gezien heeft?
  • Mars Warrior
  • Laatst online: 12:16
Mars Warrior
Earth, the final frontier
|sWORDs| schreef op zaterdag 24 februari 2007 @ 18:59:
Heb je het rode stukje gelezen en dion_b's opmerking aan het einde van deel 2?
Tijd voor deel 3 dan maar weer? Enne voeg dan meteen in de startpost links toe naar deel 1 & 2 ;)
Material 3 Thema's | Swiss Army Knife card | Flex Horseshoe Card
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Mars Warrior schreef op zaterdag 24 februari 2007 @ 19:12:
Woeps ;)
En zullen we het linkje naar deel 1 de mensen maar niet aandoen? Probeer daar maar eens door te komen. Tevens staan volgens mij alle nuttige stukken uit deel 1 nu in de startpost.
  • KappeNou
|sWORDs| schreef op zaterdag 24 februari 2007 @ 16:44:
MCH [+0.20V]
FSB [+0.20V]
CPU [1.55V]
hij doet het nu al beter met MCH op +0.20, FSB op +0.20 en CPU iets onder de 1.50V
>PC specs<
ik heb zijn stukje gelezen ja . . mag je nu geen vragen meer stellen, beetje kinderachtig . . heb nu voor het eerst een Gigabyte na altijd Asus gehad te hebben, excuse me, dat ik deze bios na 2 dagen nog niet uit me kop ken :X
en ik dacht dat FSB overvoltage de NB was . . geen idee dat ze die MCH noemen, die term ken ik niet gezien ze die niet bij Asus gebruiken :s
anyway ik heb een DS3 rev 1.0 sinds gister en hij doet het prima :)
heb me e4300 nu op 3.3Ghz (wat ook met m'n oude P5N-E sli kon) maar nu hebben we een kleine vdroop :D en dit zelfs met Kingston valueram 667 MHz. . . ben zeer tevreden als er geen gekke onverwachtste probleempjes opduiken, hou ik het voorlopig bij Gigabyte na een x tal slechte ervaringen met Asus :)
[ Voor 56% gewijzigd door Verwijderd op 24-02-2007 19:37 ]
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zaterdag 24 februari 2007 @ 19:33:
Daar gaat het niet om, Memory Controller Hub is een afkorting die al jaren door Intel gebruikt wordt en makkelijk te googlen is. Dit soort vragen mogen niet sinds die waarschuwing niet meer, maar zijn helemaal uit den boze op GOT. Door de topics hiermee te vullen is het straks niet meer te doen om vers het hele topic door te lezen.
edit na onderstaande reactie:
Als je ergens nog nooit van gehoord hebt kun je toch eerst googlen voor je de vraag post? Dit is niet het enige voorbeeld: In deel vraag staan ook vragen of je RAID kan porteren vanaf een nforce4 en of een ds3 raid heeft. Met google heb je het antwoord eerder dan dat iemand hem kan beantwoorden. Ik heb vandaag eigenlijk de hele dag aan een startpost besteed om dit topic wel leesbaar te houden.
[ Voor 26% gewijzigd door |sWORDs| op 24-02-2007 19:45 ]
zoals ik al zei, nooit van gehoord aangezien die niet bij asus gebruikt word en dit is mijn eerste Intel cpu . . dus ik zal nog wel vaker zulk soort dingen tegen komen, aagezien ik amper tot geen ervaringen heb met andere merken dan Asus en AMD. . .ooit moet toch de eerste keer zijn
[ Voor 15% gewijzigd door Verwijderd op 24-02-2007 19:39 ]
  • bassie
bassie
Verwijderd schreef op zaterdag 24 februari 2007 @ 19:39:
Als ik google op wat de betekenis van mch is kom ik dit soort dingen tegen:
Maternal and Child Health
The Memory Controller Hub (MCH) provides the system bus interface, memory controller, AGP interface, and hub interface for I/O.
Definitions have been compiled from popular search engines and multiple results provided for your review.
Het is dus gewoon google werk.
Nu weer ontopic.
KappeNou schreef op zaterdag 24 februari 2007 @ 19:26:
Kijk is of je van die extra Vfsb af kan.
  • DaannO
Ik heb een vraag over het aansluiten van het mobo. Als ik mijn voeding aansluit op de mobo met de plug (de witte) dan blijft er op het mobo nog 4 plugs over in de zelfde aansluiting. Hoort dit of heb ik een verkeerde voeding? Want het past dus wel, alleen is er een gedeelte over!
Afbeeldingslocatie: http://tweakers.net/ext/f/a240e762ce854daaf67c3b2d816ac411/thumb.jpg
Rood is dus gevuld en groen blijft er over!?
[ Voor 27% gewijzigd door DaannO op 24-02-2007 20:11 ]
  • KappeNou
bassie_ schreef op zaterdag 24 februari 2007 @ 19:58:
heb ik geprobeerd, maar dat lukt niet echt. Is het een probleem als het zo hoog staat?
>PC specs<
  • |sWORDs|
|sWORDs|
vSphere/ESXi
DaannO schreef op zaterdag 24 februari 2007 @ 20:08:
Lees pagina 20 van je manual eens goed? Of zoek eens naar 20 en 24 pins?
  • bassie
bassie
Echt zo'n zoek vraag. De 20 pins zijn het belangrijkste, die andere 4 zijn voor extra stroom. Het is dus aan te raden om die er ook in te doen.
Die 8pins stroom aansluiting die bij je I/O poorten zit, daar moet ook een stekker in.
KappeNou schreef op zaterdag 24 februari 2007 @ 20:08:
Denk dat het niet echt een probleem is, maar het kost extra stroom > extra warmte > meer gevaar voor je bord.
Voor jou is het waarschijnlijk niet zo'n probleem, je heb je cpu al op een hoog voltage dus je zal vast wel een beetje airflow hebben. Maar over het algemeen geldt voor dit soort dingen: hoe lager de voltage's hoe beter, zolang het stabiel is natuurlijk.
  • DaannO
Bedankt, ik heb er dan zeker overheen gelezen aangezien ik hem 5 keer doogebladerd heb.!
  • |sWORDs|
|sWORDs|
vSphere/ESXi
bassie_ schreef op zaterdag 24 februari 2007 @ 19:06:
Ik moet eerst een correcte busmod zien uit te voeren, wat met electrolijm niet lijkt te gaan.
[ Voor 3% gewijzigd door |sWORDs| op 25-02-2007 00:57 ]
  • BalusC
BalusC
Carpe diem
Hup, naar Tweaking, Cooling & Overclocking Algemeen ermee. Tweak en Overklok ervaringen horen sowieso daar. De "basic vraagjes" kunnen dan weer in op zichzelf staande topics in PMG gestart worden, zodra de topicstarter dit kent :Y)
Even een korte vraag (trouwens niet voor mij bedoelt),
Kan je met een GA-965P-DS3 een E6600 stabiel op 3,6 laten draaien (met een scythe ninja of infinity ofzo) of kan je dan beter de P5B Dlx/P5W Dlx kant op gaan?
  • KappeNou
Argf ik heb te vroeg gejuigt ;(
Hij boot nog steeds niet met die verhoogde voltage's wanneer ik hem een nacht uit heb gehad.. Is dit een RMA kwestie? wat denken jullie..
>PC specs<
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zondag 25 februari 2007 @ 16:55:
Lees de tweede post ("startpost") eens door, staat het letterlijk in.
Waarom een P965?
Op SLI performance na is de 965 chipset momenteel de chipset met de beste performance. Andere populaire chipsets zijn de Intel 975x en Nvidia Nforce 650 en 680. De Intel 975 chipset is ouder dan 965, duurder en haalt iets minder hoge clocks. De Nforce 650 en 680 zijn erg nieuw en de resultaten met deze chipset zijn nog vrij wisselend, tevens zijn er voltage problemen waar waarschijnlijk een nieuwe revisie voor komt. Mocht je SLI/CrossFire willen dan is een 965 geen goede keuze.
[ Voor 67% gewijzigd door |sWORDs| op 25-02-2007 17:16 ]
mijn koeler zit niet 100% op me cpu . . ik heb em eraf gehaald en een gedeelte van de cpu zat geen koelpasta op . . Dit is met een Scythe Ninja en DS3 . . nu zag ik dat er vaker probleempjes zijn met Scythe koelers en DS3 mobo's . . . men loste dit op met bepaalde mods . . nu heb ik hier geen zin in om bepaalde redenen . . ik ben niet zo handig en het is weer zo'n gedoe . . Nu ben ik van plan een Big Typhoon te bestellen in de hoop dat deze wel gewoon goed zit op dit moederbord . .
Zijn er mensen met een Typhoon die ook vergelijkbare problemen hebben op een DS3?
Ik ben zelf nix kunnen vinden . . maar dacht dat de inifinity ook goed was, maar hier in de C2D topic word gezegt dat het gewoon aan het socket ligt . . maar lijkt mij dat toch niet iedereen ze cpu koeler heeft gemod?
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zondag 25 februari 2007 @ 17:45:
Weet je zeker dat je echt iets raakt met de koeler? De Scythe Ninja moet volgens iedereen juist wel passen. Is je koeler niet scheef? Dit komt wel vaker voor (ook bij de Big Typhoon) en wordt opgelost door hem te lappen.
Uit de DS3 Faq op xtremesystems:
Q] Will my Nina+ fit on DS3?
[A] Yes, there is no need to worry, everything works fine. AFAIK Ninja+ is the best air cooling solution for Core2Duo. People on E6300 fsb 490(x7) 1.5VCore get <70*C load with a low rpm fan. There may be better but they are all louder and more expensive...
Mooi onderwerp, want ik ben net aan de koelersectie van de startpost bezig.
Die Big Typhoon past zeker niet standaard op de borden met heatpipes, zie deze mod guide. Op de borden zonder heatpipes, waarschijnlijk wel.
[ Voor 24% gewijzigd door |sWORDs| op 25-02-2007 18:02 ]
  • bassie
bassie
Het enige voordeel dat ik van LGA775 ken is dat de pinnetjes op het mobo zitten en niet meer op de cpu. De manier van mounten is gewoon brak. Die pushpin manier die intel verzonnen heeft is goed genoeg om je cpu op je mobo te zetten, maar echt goed vast krijg je het daarmee nooit. Als je wilt dat het er goed op zit ontkom je niet aan schroefjes.
Je koeler aan je mobo vast schroeven is nou ook weer niet zo moeilijk hoor. Het enige is dat je mobo wel uit je kast moet zijn maar dat moet toch ook niet al te erg zijn.
Waarom probeer je het niet even, je bent er hoogstens 30 minuten mee bezig en het is goedkoper dan een nieuwe koeler halen. Wat boutjes kost €2-3 en voor een Big Typhoon ben je al snel €30 kwijt.
de ninja zit met klipjes vast .... hoe ga ik die klipjes ooit het moederbord in schroeven, moet ik gaatjes in die klipjes gaan boren???
En de bovenkant van me cpu ziet er gewoon recht uit ... denk dat je at bdoelt met kijken of de IHS recht zit? Ik ga niet me cpu uit elkaar halen, zoals ik al zei .. ik ben echt niet handig als het op knutselen aan komt en ik waag me er ook niet aan.
[ Voor 30% gewijzigd door Verwijderd op 25-02-2007 18:09 ]
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zondag 25 februari 2007 @ 18:07:
Ik bedoel of de heatsink van de koeler wel vlak is.
hmm geen idee . . ik neem aan van wel . . ga nu ff kijken . . anders is dat schuren (lappen als ik me niet vergis) nog wel een mogelijkheid (hij is nu alweer 63c met de 2000 rpm fan, die gaat er weer af dus . . .
[ Voor 20% gewijzigd door Verwijderd op 25-02-2007 18:11 ]
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zondag 25 februari 2007 @ 18:10:
Kijk dan meteen of de koeler echt iets van het bord raakt.
  • Fab1Man
  • Laatst online: 12:05
Fab1Man
Live life to the fullest
Ik wilde eventjes vragen of bij het Gigabyte DS4 moederbord een stekker wordt geleverd om 2 molex stekkers van je voeding te converten naar een 8pins P4 stekker of moet je die apart kopen (ja ik doe het liever goed dan mijn 4pins er half op te zetten). Volgende week bestel ik het bordje en ik wil dan eventjes weten of die stekker erbij moet bestellen.
|sWORDs| schreef op zondag 25 februari 2007 @ 18:11:
de koeler zag er redelijk recht uit . . misschien als je heeeeel precies gaat kijken ze je dat het niet 100% recht is .. maar het is koper, dus lijkt mij normaal of niet??
En hoe bedoel je of de koeler iets van het bord raakt? Hij raakt nix aan ... de NB heatsink zit er wel op 1mm vanaf . .
|sWORDs| schreef op zondag 25 februari 2007 @ 17:08:
Dit klink vast heel dom, maar ik kan het niet vinden. Verlicht me aub.
  • terracide
  • Laatst online: 24-11 23:16
Damn.. das een mooi stukkie typewerk many thanx |sWORDs| en theforce81 ... top!
  • bassie
bassie
Verwijderd schreef op zondag 25 februari 2007 @ 19:40:
Het is ook best wel dom,
Stukje uit de startpost en wat staat er 420fsb 420*9=3.78GHz. Misschien als je wat gezocht had over dit mobo, zoals oc resultaten dat je er dan ook wel achter was gekomen.
klik
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Het staat letterlijk in mijn quote, de p965 klokt beter dan de 975 dus dat Asus bord valt al af, daarna staat de ASUS en Gigabytes p965 borden even goed klokken.
|sWORDs| schreef op zondag 25 februari 2007 @ 20:35:
Ow ok, ik dacht dat dat verschilde per Mobo, dus 3,6 halen gaat even goed (gaat uberhaupt) met de DS3 als de P5B Deluxe? Als dat zo is ga ik nat. voor de DS3!
Edit!!
Sorry ik ben een beetje traag van begrip:
Als de 3,6 maar (stabiel) haalbaar is. Dus als je me kan verzekeren dat de combinatie E6600@3,6 + DS3 (en scythe infinity) haalbaar is, is mijn keuze gemaakt. (voor mn vriend dan)
[ Voor 33% gewijzigd door Verwijderd op 25-02-2007 21:10 ]
  • bassie
bassie
:S Weet je iets van overklokken? De domste vraag die je kan stellen of iemand je kan verzekeren dat je ***GHz haalt. Maar een troost voor jou, ik kan jou verzekeren dat het mogelijk is om 450+ fsb op een ds3 te halen. Gelukkig kan ik jou ook verzekeren dat 5GHz mogelijk is met een e6600.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op zondag 25 februari 2007 @ 21:06:
Edit!!
Begrijpend lezen is volgens mij niet echt je ding. Wat daar staat is dat met een Gigabyte de kans niet groter of kleiner zou moeten zijn dan met een Asus.
  • Illidan
  • Laatst online: 22-11 15:44
Jongens, doet jullie Smartfan het? Je weet wel, optie in Easy Tune 5. Bij mij niet aanklikbaar, vandaar. (in bios alle fan opties al uitgeprobeerd). Zou wel handig zijn aangezien ik geen externe fan controller heb.
Enne, volgens mij heb ik het niet zien staan, maar een zogenaamd voordeel van DS4 rev1@ DQ6 is volgens mij ook het onboard geluid, ALC 883 naar 888 dacht ik (niet dat iemand het verschil ooit echt zal horen :) )
Ryzen 9 9950X3D, ASRock X870E Tachi Lite, Arctic Liquid Freezer III 420, Kingston Fury Beast DDR5 6400, Powercolor Red Devil 9070XT, Crucial T700 2TB, FSP Hydro Ti Pro 1000W, BeQuiet 802
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Illidan schreef op maandag 26 februari 2007 @ 00:37:
Smartfan doet het prima. (DS4@DQ6) Maar ik gebruik wel een 4 pins cpu fan. En zoals je met een mouseover op crossflash kan zien doet flashen niets met geluidschipje.
Of post van mij uit deel1:
theforce81 schreef op donderdag 07 september 2006 @ 17:02:
Ook een tip, flash hem naar de DQ6! De Geluidskaart wordt hierdoor geupdate (wel apart dat je het chippie dus ook gewoon kan updaten!).
Ik heb een DS4 rev1 naar een DQ6 geflashed, maar de soundchip bleef een 883, ipv 888.
Ik heb een DS4 rev3.3 naar een DQ6 geflashed, maar de soundchip bleef een 888, ipv 888D.
theforce81 schreef op donderdag 07 september 2006 @ 21:58:
DS4 naar DQ6 flashen is echt simpel, gewoon met de windows flasher (@bios) de DQ6 flashen. Dan vraagt hij of je het wel echt wil doen vanwege een mismatch (duh!) en daar zeg je ja op. Met versie F3 is het mij in ieder geval zonder problemen opgelost.
Als extra, volgens gigabyte, heb je ondersteuning voor in de toekomst uit te brengen Quad Core CPU's en een betere geluidskaart, maar dat kan je ook vinden op de website www.gigabyte.com.tw
Enige minpunt wat ik tot nu toe heb kunnen ontdekken is dat je geheugen timings als CAS, RAS, e.d. niet zelf de controle over hebt, misschien in een toekomstige BIOS update?! Wel kan je de Ratio naar beneden halen van iedere huidige C2D CPU! Handige feature als je hoge FSB wilt synchen aan bijvoorbeeld DDR2 800 geheugen.
Dit geld bij de laatste biosen voor beide, de biosen zijn wel ietsje anders (sommige dingen op een andere plek, maar echte verschillen heb ik nog niet kunnen vinden.
[ Voor 53% gewijzigd door |sWORDs| op 26-02-2007 07:35 ]
  • Fab1Man
Fab1Man
Fab1Man schreef op zondag 25 februari 2007 @ 18:33:
  • k995
  • Laatst online: 11-04-2025
Edit!!
Wel ik heb de scythe infinity sinds vorige week en kreeg hem niet perfect op een DS3
Ik heb hem 90 ° moeten draaien, met als probleem dat de 120mm fan dan maar blaast over een smaller deel van de koeler (en dus niet optimaal koelt)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Lees de vragen in dit topic/de tweede posts eens.
k995 schreef op maandag 26 februari 2007 @ 08:46:
Kun je daar een fotootje van schieten? Ik wil dit graag beschrijven voor in de startpost.
[ Voor 56% gewijzigd door |sWORDs| op 26-02-2007 08:51 ]
  • Fab1Man
Fab1Man
|sWORDs| schreef op maandag 26 februari 2007 @ 08:50:
Leuk, maar daar heb ik niks aan. Er staat dat het niet verplicht is 8pins aan te sluiten, maar ik mag toch wel van iemand eventjes horen of een convertertje (2molex->8pins) erbij geleverd wordt? Of lees ik er nu steeds overheen, wat ik me niet kan voorstellen.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Fab1Man schreef op maandag 26 februari 2007 @ 09:07:
In de manual staat precies wat er bij het bord zit. (Sata kabels, een IDE en floppy kabel) (nu -> Startpost)
[ Voor 48% gewijzigd door |sWORDs| op 26-02-2007 10:18 ]
  • bassie
bassie
Iemand die memory performance enhance gebruikt? Ik kwam dit er over tegen:
Above you see a Sisoft Sandra Memory Bandwidth benchmark comparision between the Normal Setting and Fast Setting. Only about a 2% boost, but this for some die-hard tweakers is icing on the cake.
Ik heb em nu op turbo gezet maar echt verschil merk ik niet, misschien heb ik vanavond nog tijd om wat benchies te doen. Iemand hier ervaring mee?
  • Ritchie
  • Laatst online: 13:28
Het grote voordeel is volgens mij dat die DQ6 Dolby Digital LIVE en DTS ondersteund.
- NAC Breda -
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Ritchie schreef op maandag 26 februari 2007 @ 14:46:
Maar een DS4@DQ6 dus niet.
Bedankt sWORDs| en theforce81 voor dit mooie duidelijke verhaal, maar toch heb ik nog wat te zeuren.. :P Ik wil graag RAID 0 draaien met twee seagate barracuda 7200.10 schijven en mijn vraag is dus of ik daarvoor de DS4 nodig heb aangezien die Matrix raid heeft en de DS3 iets van jmicron wat niet bijster lekker zou werken? Ik heb de RAID faq gelezen en nog wat gegoogled maar kwam er dus niet uit...
  • Illidan
Uhhh er blijven zo langzamerhand wel erg weinig redenen over om m'n DS4 te flashen naar een DQ6 :?
nog ff een vraagsje ,over de ram die ik wil kopen ,die staat in jz compatible list staat ook bij bios f3 http://gskill.de/product_sp2650.html
mijn vraag is nu ms domme wel :D
zal die meteen out of de box werken of moet ik eerst zien die bios te flashen
  • bassie
bassie
Verwijderd schreef op maandag 26 februari 2007 @ 20:08:
Kan je ook normaal nederlands gebruiken :?
Als je een url wilt plaatsen gebruik je [url] [/url] zie ook de FAQ
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op maandag 26 februari 2007 @ 18:44:
Tnx, en twee stukjes uit dat verhaal (problemen met de Gigabytes controller is verder niets over bekend):
Wat lees ik toch over controllers?
De 965 chipsets hebben geen support voor IDE, veel fabrikanten, waaronder Gigabyte, maken daarom gebruik van een losse controller chip van JMicron. Deze wordt door Windows als een SCSI controller gezien. Alle borden hebben een 2 poorts Gigabyte Sata RAID (0/1/JBOD) controller. De borden met de ICH nog 4 SATA poorten en de borden met de ICHR nog 6 SATA RAID (0/1/5/10) poorten. Doordat de Gigabyte Controller niet in de ICH chip maar via de PCI-e bus verbonden is, zeggen sommigen dat door deze poorten te gebruiken hogere clocks zou halen. Dit lijkt onwaarschijnlijk aangezien de bus voor rekening van de MCH is.
De kans dat je een bios ouder dan f3 krijgt is vrijwel nihil, tevens kun je er wel vanuit gaan dat je zelfs met een oudere bios wel kan booten en je bios flashen.
Illidan schreef op maandag 26 februari 2007 @ 18:56:
Nee die zie ik ook niet echt, quad bios misschien?
[ Voor 17% gewijzigd door |sWORDs| op 27-02-2007 00:14 ]
  • bassie
bassie
Het bord heeft 3 connectoren, een 8 pins (CPU), een 4 pins (PCI-e) en een 24pins connector (Alles). Van de 8 pins zijn er 4 verplicht, van de 24 pins zijn er 20 verplicht. De 4 pins (molex) is eigenlijk alleen nodig bij 2 PCI-e videokaarten en zelfs dan niet verplicht. Er zit dan ook geen converters bij het bord. Maar vul gewoon alles wat je kunt vullen
Een ds3 heeft een 4pins aansluiting ipv een 8. Voordat mensen gaan zoeken naar hun 8pins aansluiting op hun ds3 :+
  • |sWORDs|
|sWORDs|
vSphere/ESXi
bassie_ schreef op dinsdag 27 februari 2007 @ 00:14:
Zie je dat echt in die post staan dan? Ik niet. :+
Het bord heeft 3 connectoren, een 8 (4 bij S3/DS3) pins (CPU), een 4 pins (PCI-e) en een 24pins connector (Alles). Van de 8 pins zijn er 4 verplicht, van de 24 pins zijn er 20 verplicht. De 4 pins (molex) is eigenlijk alleen nodig bij 2 PCI-e videokaarten en zelfs dan niet verplicht. Er zit dan ook geen converters bij het bord. Maar vul gewoon alles wat je kunt vullen.
[ Voor 40% gewijzigd door |sWORDs| op 27-02-2007 00:21 ]
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Dat geheugen zal gewoon werken, daar zul je de bios niet mee hoeven te flashen.
Ik heb dit bordje nu een tijdje draaien en ik moet zeggen dat ik best te spreken ben over de performance. De E4300 doet nu 3,00GHz, wat best lekker is :9 Het geheugen draait nu op 666MHz, als ik verder ga dan ga ik ook het mem overklokken. Dat loopt overigens ook al prima op iets van 750MHz heb ik al getest.
Verder heb ik er nu maar een Arctic freezer 7 opgezet, werkt toch wat fijner dan de stock koeler van de E4300 die er standaard bijzit en de cpu wordt nu heerlijk gekoeld.
Enige wat ik ergerlijk vind is de hitte die de chipset veroorzaakt, maar dat blijkt normaal te zijn (ding is rond de 55C).
  • Koldur
Ik zou het niet proberen op die JMicron. Voor gewoon werk (Non-RAID) werkt deze nu prima, maar met RAID zijn weinig lekkere ervaringen (dit is te vinden op het XtremeSystems forum). Die intel ICH8R werkt hierbij verreweg het stabielst en het snelst.
  • bassie
bassie
|sWORDs| schreef op dinsdag 27 februari 2007 @ 00:19:
8)7 |:( ;) :+
Ik heb net even die memory performance enhance getest. Echt veel winst geeft het niet volgens sisoft sandra.
Turbo 6853MB/s Fast 6637MB/s Normal 6558MB/s
Met een ds3 op 400fsb.
  • bassie
bassie
theforce81 schreef op dinsdag 27 februari 2007 @ 10:44:
Alle borden hebben een 2 poorts GigabyteSata RAID (0/1/JBOD) controller.
  • BalusC
BalusC
Carpe diem
300MB/s is best wel veel hoor :)
  • bassie
bassie
295MB/s is wel redelijk wat ja, maar van turbo had ik wel iets meer verwacht. 7GB/s++ vind ik wat meer bij turbo horen. Zou het nog verschil maken als ik de timings van 5-5-5-12 naar 4-4-4-12 zet? Als het lukt met dit geheugen.
Zijn er nog andere die ook memory performance enhance willen testen op hun bord? Om even een vergelijking te maken (voor in de topic start?).
[ Voor 16% gewijzigd door bassie op 27-02-2007 11:50 ]
  • BalusC
BalusC
Carpe diem
bassie_ schreef op dinsdag 27 februari 2007 @ 11:48:
Het hangt allemaal ook af van merk/type geheugen en de ingestelde bussnelheid. Het verschil van 300MB/s is best wel veel.
Ga gewoon na welke latenties "automatisch" worden opgepakt wanneer je Fast en Turbo gebruikt en ga daar handmatig overheen.
  • -ErikE-
  • Laatst online: 24-11 07:12
bassie_ schreef op dinsdag 27 februari 2007 @ 11:24:
Dit is gewoon een JMicron controller met een gigabyte opdrukje en BIOS. De software en het uiterlijk is dus van Gigabyte maar de hardware blijft van JMicron.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
-ErikE- schreef op dinsdag 27 februari 2007 @ 12:39:
De IDE en 2 SATA RAID poorten lijken i.d.d. van dezelfde chip te komen (zie schema pagina 8 manual). (De GIGABYTE GBB36X CONTROLLER is waarschijnlijk een JMicron JMB366, waar dan maar 1 PATA poort van gebruikt wordt (ik zie er wel 2 in apparaat beheer).
JMB366 is a single chip, one-lane PCI Express to two-port Serial ATA II and two-port PATA Host Controller. The JMB366 is designed to provide two-port SATA II and two-port PATA connectivity. The JMB366 supports AHCI, Legacy IDE and RAID controller to increase system feasibility, including Native Command Queuing (NCQ), Hot Plugging, ATAPI Device Supporting, Port Multiplier with Command-based Switching Supporting, Programmable Output Swing Control to fit SATA II Gen1m and Gen2m (External SATA Connection, eSATA). It features PCI Express bus and Serial ATA II interface to express high performance storage devices.
Ik heb dit in de tweede post als wijziging voor de startpost geplaatst.
Heb je daar een linkje naar? Kunnen we dat ook in de startpost verwerken, ik kan alleen wat mensen vinden die wat problemen met de pio mode van de IDE hebben. En wat mensen die onder dos niet bij de optical drive kunnen komen. (Die moeten m op native zetten of deze driver gebruiken.
[ Voor 27% gewijzigd door |sWORDs| op 27-02-2007 14:58 ]
ik heb dit net ook in het e4300 topic gevraagt omdat ik een e4300 heb op een DS3 Rev 1, maar denk dat dit topic er beter geschikt voor is . . .
Mijn pc boot niet met een FSB van 400, 401 of 410. Ik heb MCH en FSB voltages allebei op +0.3v gezet, maar dit hielp niet . . .
Nu ben ik aan het primen met een FSB van 390 . . . met zowel MCH als FSB op normal of 0.1v (weet het ff niet precies) . .
Dit is een beetje vreemd vind ik . . ik heb op forums gelezen dat sommige mensen vonden dat de F7 bios beter was voor overclocken dan de F10 bios . . Zou het kunnen dat ik met de F7 bios wel 400 Mhz kan halen? of ligt dit niet aan de bios, maar gewoon aan mijn moederbord?
zou ik misschien me geheugen wat meer volt moeten geven ondanks deze nog niet op 800 Mhz is overgeclockt? :?
zou zo graag die 100 Mhz erbij willen O-)
[ Voor 13% gewijzigd door Verwijderd op 27-02-2007 15:02 ]
  • bassie
bassie
Verwijderd schreef op dinsdag 27 februari 2007 @ 14:59:
Mijn pc niet met een FSB van 400, 401 of 410. Ik heb MCH en FSB voltages allebei op +0.3v gezet, maar dit hielp niet . . .
Bios F10 is brak, kom ook niet in de buurt van 400. F9 werkt goed voor mij, F9 heeft ook iets meer functies dan F7.
oke dank u . .
gaan we zo direct ff proberen
  • Vads
  • Laatst online: 00:28
Ik zit met een vraag. Heb vorige week mijn DS4 rev. 3.3 ontvangen, van het weekend mijn systeem in elkaar gebouwd, maar krijg het helaas niet aan de praat.
In het starttopicgedeelte las ik het volgende:
Die 24-pins rechtsboven op het moederbord is gevuld. Linksboven op het moederbord zit ook een 8-pins blokje, waarvan de vier onderste pins waren afgeplakt met een stukje plastic. Volgens de handleiding is dit voor de ATX 12V-stekker. Maakt niet uit of ik de 4- of 8-pins kabel uit de voeding hierop aansluit, alleen de casefans draaien en het scherm blijft zwart. Is het erg als ik hierop de 8-pins stekker op zet (ik heb een Intel E6600)?
Bij de voeding zit ook een 4-pins voedingskabel, gelabeled PCI-E, maar zover ik kan zien zit er op het DS4 moederbord geen speciale videokaartvoedingsingang, behalve rechtsboven de molex (diezelfde als gebruikt wordt op een IDE-HD). Maar deze stekker is alleen voor gebruik bij twee videokaarten.
Ik heb een passief gecoolde XFX 7600 GS, waar geen stekker op zit voor voeding.
Ik ga vanavond nog even de CMOS clearen. Als dat niet helpt, haal ik alle stekkers en kaarten los, behalve cpu, cpu cooler, videokaart, ps2-keyboard en op het moederbord alleen het stekkertje voor de powerswitch. Als ie dan nog niets doet, gaat het terug met RMA.
Hebben jullie nog tips of ideeën?
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Vads schreef op dinsdag 27 februari 2007 @ 15:15:
Met de 4 pins zou het prima moeten werken. De stekker van je voeding is denk ik 6 pins (of zijn er ook 4 pins pci-e stekkers?) en voor een videokaart, maar die je heb je met een 7600 GS niet nodig. CMOS clearen en zo kaal mogelijk booten is de beste oplossing. Weet je zeker dat de videokaart/cpu en geheugen wel goed zijn?
  • bassie
bassie
Die kabel die aan je voeding zit is als het goed is 6pins. De zwaardere grafische kaarten gebruiken een 6pins pci-e omdat ze anders niet genoeg stroom krijgen. De 6pins pci-e stekker bestaat uit 2 rijen met 3 pinnen.
  • Vads
Is het trouwens niet handig om de volgende link naar een overzicht van geheugen compatibiliteit in het starttopicgedeelte te vermelden?:
http://www.jzelectronic.de/jz2/html/ram-liste-p965.htm
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Vads schreef op dinsdag 27 februari 2007 @ 15:34:
Dit topic gaat specifiek over de Gigabyte borden en er staat al een link naar de lijst van Gigabyte. Misschien zou het een toevoeging kunnen zijn, maar de lijst van Gigabyte weet je het echt zeker van.
[ Voor 5% gewijzigd door |sWORDs| op 27-02-2007 15:39 ]
  • Vads
|sWORDs| schreef op dinsdag 27 februari 2007 @ 15:28:
Videokaart heb ik bij een vriend van mij afgelopen zondagavond getest en daar kregen bij opstarten direct beeld. Ik zie niet eens het (BIOS-)opstartscherm.
Andere CPU kan ik helaas niet testen, daar ik niemand anders ken met een socket 775 cpu. Hier op het werk staat wel een pc met daar in een "socket 478, LCG 775"-processor erin, maar ik vraag me af of deze cpu wel kan plaatsen in mijn moederbord.
Ook het geheugen kan ik niet testen of het ergens anders wel werkt. Ik heb het bord ook zonder beide geheugenmodules erin op laten starten en ook toen niks...
Je wordt er zo moedeloos en depressief van. Is namelijk al het tweede moederbord dat ik thuis heb ontvangen (de eerste was rev. 1.0 die ik niet besteld had)...
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Vads schreef op dinsdag 27 februari 2007 @ 15:38:
Sja, als je in de buurt van Apeldoorn/Arnhem/Deventer/Zutphen woont, (ik woon er tussen in) mag je alles komen testen.
edit: Niet echt dus... (profiel)
  • Koldur
Problemen met JMicron en RAID staan in het eerste linkje (FAQ DS3) naar Xtremesystems. Het gaat dan om het niet willen herkennen van RAID arrays in de install terwijl wel de goede F6 drivers geladen zijn, spontane reboots in windows en traaglopende systemen. Voor de rest zijn dit allemaal losse posts in het topic daar en lijkt mij niet echt handig in de startpost te vermelden.
[quote]|sWORDs| schreef op dinsdag 27 februari 2007 @ 14:08:
Die eerste conrtoller is voor je PATA en die tweede voor de JMicron SATA poorten, dus het betreft hier geen tweede optionele PATA poort!
[ Voor 40% gewijzigd door Koldur op 27-02-2007 15:58 ]
  • |sWORDs|
|sWORDs|
vSphere/ESXi
theforce81 schreef op dinsdag 27 februari 2007 @ 15:46:
Ik heb de stukjes aangepast in de 2e post, misschien kun je die even verwerken in de startpost.
hmm heb zowel de F7, F9 en F10 bios geprobeerd en geen van alle laat em boote met een FSB hoger als 390 :(
ach ja . . tis niet anders . . . zit dus aan de max van me moederbord ... jammer, maar ben niet ontevreden, heb zeker wel waar me euro's, alleen beetje jammer :)
  • bassie
bassie
Verwijderd schreef op dinsdag 27 februari 2007 @ 16:39:
Das idd jammer, weet je zeker dat er niet een setting fout staat? Weet je ook zeker dat het je geheugen niet is? Ik heb er nu 2GB corsair xms2 pc6400 5-5-5-12 in zitten, draait op 2.0Vcore maar zit echt minimale rek in. Heb 450 geprobeert lukt niet eens.
Maar 1 voordeel heb je. Tot 400 zit je in de 1066 strap, dat is wat sneller dan de 1333 strap. Staat hier met wat voorbeelden.
[ Voor 9% gewijzigd door bassie op 27-02-2007 16:54 ]
ja i know en ik heb Pc6400 mem OCZ . . zitte niet van Micron chips op . . maar zelfs dan zou die toch minimaal over de 800 Mhz heen kunnen en anders op ze minst wel 800 Mhz halen . .
maar ja tis zo ook wel goed ... 95% o/c zijn we dik tevreden mee, mits die op 95% blijft
[ Voor 4% gewijzigd door Verwijderd op 27-02-2007 17:37 ]
  • bassie
bassie
Verwijderd schreef op dinsdag 27 februari 2007 @ 17:36:
Is je niet je processor?
  • TERW_DAN
TERW_DAN
Iemand een idee of je de voltage van de chipset ook naar beneden bij kunt stellen? In de bios kun je namelijk wel +0.1, 0.2 of 0.3V doen, maar mij lijkt het juist interessanter om het voltage te verlagen.
Ik ben nu namelijk bezig om mijn E4300 @ 3,00GHz op een zo laag mogelijke vcore te zetten, en kijken of hij toch nog stabiel werkt met de overclock. Hoe minder voltage hoe minder hitte en dat kan alleen maar goed zijn (en met wat geluk blijft hij stabiel draaien).
Het voordeel van dit bordje is dat hij toch automatisch reboot bij een te lage vcore, dus dat is gewoon een kwestie van testen :D
Hij lijkt stabiel te draaien bij 1.275V (standaard is 1.325V). Lijkt me op zich nog niet eens zo slecht voor een cpu die op 1200MHz meer draait :D
  • DaannO
Terw_Dan schreef op dinsdag 27 februari 2007 @ 17:49:
Ghehe, heb hem nu op +1000mhz zitten en dat ding wil gewoon niet warm worden. :?
Idle is hij rond de 30 graden:
Afbeeldingslocatie: http://tweakers.net/ext/f/30b0da2bd3baeebf7d1b6fb2b2689bcf/thumb.jpg
En stressed komt hij niet boven de 40c na een tijde draaien:
Afbeeldingslocatie: http://tweakers.net/ext/f/035525e3819fad6a1043ff5fdb88f54d/thumb.jpg
Gaat lkr zo. :)
Heeft iemand overgins nog een leuk prog om de warmte van de mobo uit te lezen?
  • bassie
bassie
Denk niet dat het kan. Misschien een Vmod en dan een hele hoge weerstand, maar ik heb geen idee of je dan onders standaart voltage kan komen.
DaannO schreef op dinsdag 27 februari 2007 @ 17:59:
Gaat lkr zo. :)
EasyTune 5 en dan bij PC healt ofzo daar staat mobo temp.
Welke koeler heb je? 30 grade is wel erg lekker.
  • TERW_DAN
TERW_DAN
Gaat lkr zo. :)
Mijn cpu is nu 33C bij het runnen van een 2M superpi. Dit gemeten met Easytune, op een snelheid van 3,00GHz en 1,300Vcore draaiend onder windows 2000
Overigens is easeytun een beetje rotprog vind ik, maar goed, je moet wat :P
[ Voor 5% gewijzigd door TERW_DAN op 27-02-2007 18:22 ]
  • bassie
bassie
Terw_Dan schreef op dinsdag 27 februari 2007 @ 18:21:
EasyTune leest niet de goede cpu temps af, 15graden erbij is beter als je de coretemps wilt hebben. Probeer coretemp of TAT is.
EasyTune is zeker een brak progje
is dat ook prime stable??
e4300 @ 3.0ghz met 1.3v is uitermate netjes . . mits het prime stable is
Terw_Dan schreef op dinsdag 27 februari 2007 @ 00:24:
ok ,dank u voor de replys beide (sWORDs)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Dat denk ik ook, mijn cpu wilde zowel op mijn rev1 als 3.3 niet boven de 357, van de week krijg ik hopelijk een nforce 680 bord, zal ik m daar ook nog eens op proberen.
ah zou ook nog kunnen . . .
had lagere multiplier geprobeerd . . maar had er geen rekening mee gehouden dat ie mss de totale snelheid wel aan kon, maar de FSB niet . . .
achja, het doet er niet meer toe, want met 390 Fsb, was ie toch niet prime stable, dus zijn we alweer lager . . .
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op dinsdag 27 februari 2007 @ 19:45:
Ach 9*333 lijkt mij nog steeds de beste 24/7 clock. (Hoeft er ook maar 1.4v op, sommige zelfs maar 1.325v. En je bord heeft helemaal geen extra voltage nodig.) En je 24/7 setup is veel belangrijker dan die ene keer hoge benchmark halen.
Ik had het niet over de controllers, maar over de IDE poorten en die chip heeft er toch echt twee, ik denk dat de tweede poort gewoon fysiek niet verbonden is, maar wel ingeschakeld. Of zouden ze een IDE poort voor de SATA gebruiken? Dan zouden er zelf drie IDE poorten in de controller moeten zitten. Eens even de whitepaper in duiken.
[ Voor 52% gewijzigd door |sWORDs| op 27-02-2007 19:53 ]
Pagina: 1 2 ... 12 Laatste
