aka pluim003 - Marstek Venus v1 - UGreen DXP2800
- gratis_vodka
- Registratie: April 2001
- Laatst online: 04-10 21:20
If you love it - shoot it!
Het feit dat 't probleem eenvoudig op te lossen is betekent volgens mij dat het idd een firmware probleem was.DATE: 6 September 2005
Occasional image disruption on Samsung LExxR41/51B range LCD TVs using 60hz or modified input sources
Samsung is aware that a small number of users of its LExxR41/51B range of LCD TVs are experiencing occasional degradation of image quality when using the product with some specialised or modified input sources.
This issue does not affect the vast majority of owners of this range of Samsung LCD TVs, or any other Samsung TV products. Samsung’s technical experts have established that the problem does not arise as a result of a technical fault in the product but rather because the product is being used only in conjunction with certain input sources.
It is, however, of prime importance to Samsung that all of its broad user community is able to enjoy the best possible experience of its products.
Samsung has therefore carried out extensive testing to identify the cause of this phenomenon, and can confirm that it is only experienced when using input sources that output high definition 720p format video at a rate of 60hz or have been modified to do so. Customers using such equipment may experience an occasional and brief disruption of the picture that commonly appears as a moving line in the middle of the screen.
Samsung’s engineers have been able to develop a solution that resolves the issue immediately for any customer that has been affected.
If you have experienced the above issue, Samsung asks owners of models within this range using such inputs, modified or otherwise, to contact its customer support team to enable the matter to be swiftly resolved on: 0870 242 0303 - select Option 5.
Customers that have been in touch with Samsung in regard to this issue will be contacted directly by Samsung customer service shortly.
TVs that may potentially be affected by this issue are as follows:
LE23R51BX/*, LE26R51BX/*, LE32R51BX/*, LE40R51BX/*, LE26R41BX/*, LE32R41BX/*, LE40R41BX/*, LE23R51BXX/XEC, LE23R51BXX/XEU, LE37R41BX/*, LE26R41BDX/XEU, LE32R41BDX/XEU
Zie dit forum topic:
http://gathering.tweakers.net/forum/list_messages/1067411
Even afwachten voor reviews.
Nu kom ik dit scherm tegen maar ik ben een beetje huiverig om weer een samsung tepakken.
Kijk veel dvd en regelmatig een voetbalwedstrijd, dvd lijkt me niet zo'n probleem maar de voetbalwedstrijden heb je met dit scherm geen last van dat ie het niet kan "bijhouden "
En wat is eigenlijk de kwalitieit van analoog signaal ? ( redelijk nieuwe wijk waar ik woon)
Zit erg te twijfelen om de samsung LE26R51B of de JVC LT-26S60
Damm wat moeilijk want ik wil nier weer dezelfde fout maken zoals 3 jaar terug...moeilijk moeilijk moeilijk allemaal..
Use my referral link https://platinum.crypto.com/r/d6feas9zfq to sign up for Crypto.com and we both get $50 USD :)
Maar nu beweerde deze man dat het afhangt van zender tot zender en dat je altijd dit probleem zou hebben. Vooral bij VT4 en kanaal 2 (belgishe zenders). Klopt deze uitspraak? Want ik wil niet voor niets investeren in een nieuwe type van LCD en home cinema.
Je kunt denk ik met allebei niet misgaan, ik heb de Samsung gekozen vanwege de aparte vga-input (die native res van het panel doet) en omdat het beeld in de winkel me beter leek (ook niet alleszeggend natuurlijk). De Samsung is perfect voor voetbalwedstrijden in ieder geval, daar zou ik me niet druk om makenTerrestra schreef op donderdag 08 september 2005 @ 22:14:
Ben ook op zoek naar een nieuwe tv , heb nu ook een samsung ( 2002 breedbeeld ) waar ik absoluut niet kapot van ben. ( gaat eruit )
Ik ben voor de R5 gegaan ipv de M5 omdat ik het uiterlijk van de R5 mooier vindt. Wanneer die M6 serie al verkocht zou zijn dan was ik overigens voor de M6 gegaan.
Samsung heeft een EISA-award ontvangen voor de LCD-TV LE40M61B
http://www.hear.nl/cgi-bi...gi?nieuws_id=2550&LIMIT=0
Maar toch ben ik benieuwd of er toevallig hier iemand is die deze tv ook heeft en aangesloten heeft op een gamecube, xbox of ps2 en wat daar de kwaliteit van is op dit scherm? Dit zal namelijk de main functie worden van het scherm aangezien ik weinig tv kijk
Heb wel een aantal topics gelezen maar die gaan voornamelijk over het tearing probleem eigenlijk en kon niet echt ontzettend veel vinden over de kwaliteit het game gebied.
Nee, de uitspraak dat het aan je home cinema set ligt is totale onzin. Wat er gebeurd is dat de opbouw van het scherm door allerlei beeldverbeteringsprogramma's in de tv, langzamer gebeurd dan dat het geluid wordt uitgezonden. Probeer eens al die functies minimaal of uit te zetten (zoals DIN) en kijk dan eens of het verbeterd. Neem ook goede kabels, geen superoude troep om het oneerbiedig te zeggen, wil ook nog wel eens een verschil maken.Verwijderd schreef op vrijdag 09 september 2005 @ 20:47:
Heb onlanks gebeld met Samsung voor mijn mijn tv omdat mijn home cinema achterloopt op mijn LCD samsungle26a41. Bleek dus normaal te zijn omdat mijn home cinema een pioneer is en deze delay functie niet heeft. Is een 1,5 jaar oud.
Xbox op component aansluiting is ontzettend goed beeld vind ik, maar alleen als je je xbox mod naar de NTSC-standaard kan je de hogere resoluties/refresh rates (480 progessive en 720p voor sommige spellen) gebruiken die dit scherm helemaal top maken. Standaard draait hij dus in 480 interlaced (25 fps ofzo), en dat wil op een goede CRT wel eens beter uitzien. Voor de X360 echter is de output altijd in een hoge resolutie en is deze Samsung een van de beste schermen die je op dit moment kunt kopen.Koffiezuiper schreef op zondag 11 september 2005 @ 21:35:
Deze week of zelfs morgen wil ik de LE26R41B aanschaffen. Deze lcd leek mij zo een beetje eigenlijk de betere keus voor gaming, tv en dvd's op te bekijken voor een degelijke prijs.
Je analyse zou wel kloppen, ware het niet dat hij zegt dat het geluid van de home-cinema set achterloopt op het beeld van de tv (als ik het goed lees). Dus het beeld is sneller dan het geluid, ergo DNI enzo kan er niks mee te maken hebben. Daarnaast heb ik zelf een home-cinema set aangesloten en kan ik je vertellen dat het delay-effect waar kippekop het over heeft (en dat jij wellicht bedoelt) in ieder geval op de LE32R51 niet plaatsvindt...Verwijderd schreef op zondag 11 september 2005 @ 22:00:
Zo is het inderdaad er zit gewoon een vertraging op. Aan de kabels kan het volgens mij niet liggen omdat deze al vernieuwd waren door profigold kabels. En zojuist met die instelling bezig geweest en deze hebben er ook geen effect op.Finwe schreef op zondag 11 september 2005 @ 22:38:
En als je nu eens het geluid via je normale boxen van de tv laat lopen, wat gebeurd er dan met het geluid? Dan kun je meteen zien of het inderdaad aan je home cinema set ligt.
De LE26R51B heb ik in de winkel bekeken, vond het beeld prima maar de glimmende zwarte rand vind ik erg storend.
Alvast bedankt.
Iemand al de nieuwe Sony Bravia's gezien?
Model: KTV-S32
8 ms en alle aansluitingen zoals de Samsungs. Be benieuwd naar het beeld.... en de prijs!
Het geluid loopt prima op de tv.Verwijderd schreef op maandag 12 september 2005 @ 15:38:
Excuus, verkeerd gelezen dan...
Bij somige zenders heb ik er meer last van dan bij andere zenders.
Ze gaan een technieker langs laten komen van Samsung zelf. Hoop dat deze het probleem kan oplossen.
Nope, die heeft geen matte zwarte rand. Vandaag de LE26R41B gehaald en tot nu toe ben ik er tevreden over. Moet alleen even nieuwe kabels halen voor mijn consoles want met de scart is de kwaliteit nogal matig helaas.Sponz schreef op maandag 12 september 2005 @ 15:53:
Zie ik goed dat de LE26R41B een mat zwarte rand heeft? Dat heeft m'n voorkeur.
Alvast bedankt.
Sja op zo'n goed scherm zie je dat het signaal erg slecht is. Met een rgb-scart kabel op de rgb-scart poort van de tv kun je aardige resultaten bereiken, maar het beste is toch om een component kabel te gebruiken en je xbox te modden naar NTSC zodat ie hdtv resoluties ondersteunt. Gta San Andreas ziet er echt fabelachtig uit op mijn scherm zo (zal later eens wat foto's posten).Koffiezuiper schreef op dinsdag 13 september 2005 @ 00:58:
Prima, niks over te klagen...Verwijderd schreef op woensdag 14 september 2005 @ 18:43:
hallo
hoe is het beeld met voetbal of tennis ?
Ik ben ook zeer benieuwd naar deze nieuwe serie. Ik heb er erg hoge verwachtingen van. Echter het verschil tussen de S en V serie is mij niet geheel duidelijk. Ik ben aan het denken aan het 40" model uit de S serie.. Ik heb sony een mailtje gestuurd over adviesprijs etc.. tot op heden nog geen reactie.Verwijderd schreef op maandag 12 september 2005 @ 21:25:
Hoi,
Model: KTV-S32
Ik hoop echter snel wat te horen. Op kieskeurig staat het 40" model voor 2200 euro, maar de winkelprijs zal wel een stuk hoger liggen..ben zeer benieuwd..
Meer geinteresseerde in deze nieuwe serie van sony?
Keep us informed..
ps: bij de Expert winkel verwachtte ze m binnen 2 weken, echter ook nog geen prijs bekend..
Zal verschillen per TV dan, mijn LE32R51B maakt compleet geen geluid, ik moest zelfs ff speciaal zoeken waar die fan zat en of ik iets hoorde. Als je de mogelijkheid hebt kan je misschien eens kijken of hij meer dan 30dB produceerd, op die manier kan je dan kijken of het onder garantie valt.Verwijderd schreef op maandag 19 september 2005 @ 14:06:
Sindskort ben ik de gelukkige eigenaar van de LE23R51B, alles is naar wens behalve... het viel me op dat de fans in de tv toch wel luidruchtig zijn, ik heb al uitgebreidt gezocht naar specificaties om iets te weten te komen over hoeveel dB de fans (fan noise) produceren. ik heb er niets over kunnen vinden... omdat het toch steeds storender werd - je gaat er op letten - heb ik uiteindelijk besloten om SAMSUNG zelf te bellen. hier kwam weinig uit, "ja het is gebruikelijk dat de fans de boel een beetje moeten afkoelen en dat hierbij geluid wordt geproduceerd (fan noise)", "maar de fan noise zal niet meer dan 30dB zijn" een antwoord waar ik opzich wel wat aan heb maar als ik het volume van de tv op 15 heb staan hoor ik fans toch nog vrij goed. mijn vraag luidt dan ook: heeft iemand ervaring met dezelfde tv, zoja heeft hij/zij dan ook last van de geluidsproductie van de fans?
Maar mijn vraag staat nog steeds of er nog iemand de HD850 dvdspeler van samsung heeft aangesloten?
Eens kijken of ik ergens een metertje vandaan kan halen, wat me al wel is opgevallen dat als ik lang tv of films zit te kijken dat hij meer noise produceerd, ook wel logisch, als ik alleen mn brureaublad heb (dual monitoring, tv is de 2e monitor) dan is hij ook vrijwel stil, maar toch niet helemaal. Ik ga hem wel eens aan wat tests onderwerpen nog tips? Zou je er mee terug kunnen als zo'n ding meer noise dan produceerd dan 30dB?aapelite schreef op maandag 19 september 2005 @ 18:17:
ps heb je dan ook geen last van fan noise als je em heel lang hebt aanstaan, veel actieviteit dus meer koeling? of is ie echt "stil", ben namelijk best een beetje teleurgesteld ondangs dat het een topding is maakt ie naar mijn mening te veel kabaal!
Dat je geluid hoort als je achter je bureau zit is redelijk logisch, dat hebben eigenlijk wel alle tv's, de een erger dan de ander, en inderdaad per batch kan er ook nog eens verschil in zitten, dus het kan niet te erg zijn. Maar als je op 2 a 3 meter nog het geluid hoort kun je er wel mee teruggaan...Verwijderd schreef op maandag 19 september 2005 @ 19:29:
Intel Core i7 920 @ 3.6 / 4ghz, MSI X58 Pro-E, AMD Radeon HD 5870, 6GB DDR-3 1066
Ik heb ook veel naar lcd tv gekeken omdat ik voor de 360 klaar wilde staan, en had deze tv dan ook bijna ingepakt in de winkel :-)
Na veel kijken en nadenken ben ik toch tot de conclusie gekomen dat lcd het gewoon nog niet is.
Hebben julie (bezitters van o.a. de samsung) nooit de gedachten gehad ik ga geen 1000€ uitgeven voor iets wat op gebied van de huidige dvd en consoles geen verbetering is van een "gewone" crt tv?
Ik vindt dit best appart, want ik kwam toch echt keer opkeer tot de conclusie in de winkels dat t beeld gewoon niet scherp is. Ook als ik naar een duurdere lcd keek of zelfs een plasma, snapte ik gewoon niet waarom ik regelmatig lees dat het beeld zo haarscherp is
Heb ik van die speciale ogen die ruis ontdekt in t beeld (ja ook van 2meter afstand)? Ik heb ook opstellingen gezien met progressive dvd spelers, en ik begrijp dat de resolutie niet echt op 1280* zit, maar tis gewoon een achteruitgang van me huidge crt tv?!
Ik zelf heb nog ff geduld en laat me neit overhalen door toekomstige consoles en nieuwe video standaarden, ik wil eerst een techniek die 1000€ echt waard is tov de huidige crt.
Ben benieuwd naar julie mening hierover
Heb een decibelmeter kunnen bemachtigen, ik ga nu eens lekker testen, het is overigens wel een stuk minder geworden de laatste tijd, misschien had het te maken met het feit dat hij net nieuw was. aan het begin was het best wel noisy het wordt steeds minder... het blijft een raadsel, de dbmeter is lekker gevoelig ik ga maar eens aan de slag met meten en samsung maar weer eens bellenFinwe schreef op dinsdag 20 september 2005 @ 13:49:
Ik wist niet eens dat dit ding een fan had joh. Lijkt me dat er in jouw geval dus echt iets niet klopt, zelfs als het geluid uit staat hoor ik niks!
Welke LCD tv heb jij dan? ook een LExxR51B?
Ik heb de draad niet helemaal gevolgd, dus het probleem is misschien al aan de orde geweest...
Ik heb een tweetal weken geleden de LE26R51B gekocht. Prijs kwaliteit leek het me gewoon de beste en dat vind ik nog steeds.
Verder ben ik een dikke leek wat betreft techniek, dus naar alle waarschijnlijkheid gaat het hier om iets banaals.
Ik krijg namelijk een viertal bordeuax rode banden door mijn beeld. De ene keer zijn ze breder dan de andere. Soms is heel het scherm dwz. al wat zwart is bordeaux gekleurd. Ik heb nog wel beeld, maar alle zwart tonen krijgen door dit bordeaux een soort negatief-rood-saturatie effect. Ik heb er een technieker over aangesproken en hij beweert dat het waarschijnlijk aan de antennekabel ligt.
(ik heb kabeldistributie en die gaat via de video naar de tv). Iemand die mij hierover meer info kan geven?
Thanks
[ Voor 87% gewijzigd door Verwijderd op 20-09-2005 18:52 ]
Dus je hebt alleen een coax op je tv aangesloten die uit je video recorder komt, want rechtstreeks naar je tv is het hetzelfde (zonder de videorecorder)Verwijderd schreef op dinsdag 20 september 2005 @ 18:28:
Hoi,
Thanks
want dan zou je er is iets anders op aan moetten sluiten, via de scart ofzo (video recorder op de scart)
of ik zou zeggen bekijk is een dvdtje, doormiddel van de scart aansluiting.
Als dan hetzelfde probleem zich nog steeds, voor doet is je tv naar gvd.
Dan ben je in iedergeval een stap verder
[ Voor 8% gewijzigd door Verwijderd op 20-09-2005 18:51 ]
Het gaat mij vooral om het design en een ruimtelijk gevoel, en ik denk dat zowiezo analoge kabel op een lcd/plasma altijd ruk beeld geeft. Daarnaast kan deze LCD's hdtv weergeven, is het makkelijker/mooier met MCE en zon dvdspeler met hdmi moet toch ook een mooi beeld geven. CRT zal voorlopig nog wel betere kleur/contrast weergeven.Verwijderd schreef op dinsdag 20 september 2005 @ 17:27:
Datzefde had ik ook toen ik dat las van die lawaaierige fan. Fan, welke fan?? Tot ik wat geperforeerd plastic onder de kabels aantrof waar een beetje koele lucht vandaan kwam.Finwe schreef op dinsdag 20 september 2005 @ 13:49:
Ik hoop dat de persoon met het lawaai in iedergeval terug kan naar de winkel ermee of anders met samsung iets regelen. Ik denk dat je dan vooral iets kan hebben aan het feit dat ze zeiden dat het niet meer mocht zijn dan 30dB. Anders moet je proberen een monteur langs te laten komen om de fan te vervangen. Wie weet.
Kan wel zijn dat je ze nu niet hoort, maar over een paar jaar zullen de lagertjes wel wat minder soepel zijn vrees ik.
Haha geloof me dit heb ik me zeker ook afgevraagd. De vraag is: wil je in het verleden blijven hangen of ga je naar de toekomst? Ja, een goede CRT geeft nu allicht een beter beeld op de huidige input sources zoals analoge tv en in mindere mate dvd (een upscaling dvd player doet wonderen voor mijn lcd-tv). Maar als jij straks een PC of X360 op je CRT aansluit, dan zul je zien dat je beeld niet eens in de buurt komt van de hoge resoluties (en bijbehorende scherpte) die een LCD kan weergeven. Als je tv 5 jaar mee moet gaan is dat zeker iets om rekening mee te houden!Verwijderd schreef op dinsdag 20 september 2005 @ 17:27:
Het is misschien een klein beetje oftopic, maar goed:
Ik vindt dit best appart, want ik kwam toch echt keer opkeer tot de conclusie in de winkels dat t beeld gewoon niet scherp is. Ook als ik naar een duurdere lcd keek of zelfs een plasma, snapte ik gewoon niet waarom ik regelmatig lees dat het beeld zo haarscherp is![]()
Nu leven we natuurlijk ik het heden en ik vond analoge inputs van lcd-tv's ook te slecht. Deze Samsung gaat voor mij echter over de threshold heen, ik vind het beeld op de analoge input gewoon ook erg goed (beter dan menig CRT). Kijk je soms in de winkels naar de LCD? Daar zitten er vaak splitters op etc.
Maar goed aan jou de keus: Verleden of toekomst
Ik wil er een DVD-HD850 bij bestellen -- de kabel die ik nodig heb, is dat een HDMI->DVI of gewoon HDMI-HDMI?
This space intentionally left blank.
HDMI-HDMIdot.K schreef op woensdag 21 september 2005 @ 11:51:
Kan een bezitter van een Samsung eens een foto posten van de achterkant .. de aansluitingen vooral.
Precies...Finwe schreef op woensdag 21 september 2005 @ 08:12:
In de winkel wordt het betreffende signaal verdeeld over 20 tv's ofzo...
Dus heb je aardig wat verlies op het signaal wat uiteindelijk de tv berijkt..
Eigenlijk zou je kunnen vragen of ze de betreffende tv even willen aansluiten of bv een losse dvd speler en dan het resultaat bekijken...
Dan zie je pas of een tv goed beeld geeft of niet...
Een LE26R41 met een Samsung DVD-HD950 HDMI DVD Player en een Belkin PureAV hdmi/hdmi kabeltje. Samen goed voor 1248 euro btw incl.
Bevindingen volgen binnen enkele dagen
Rechtstreeks bij Techdata. Werken bij een grote reseller is soms handigVerwijderd schreef op woensdag 21 september 2005 @ 14:06:
Mag ik vragen waar jij m hebt besteld?
Cheers
Het kabeltje was niet nodig geweest, er zitten een goeie DVI-HDMI en een HDMI-HDMI kabel bij deze speler geleverd.dot.K schreef op woensdag 21 september 2005 @ 13:39:
Bestelling is inmiddels geplaatst.
Een zojuist gearriveerd nieuwtje, de Samsung LE27T51 en LE32T51. Wel een geinige serie, een compleet zwart basismodel. Helaas alleen DVI.
Het zwart is dofzwart, dus geen glanzend zoals bij de andere serie. Het beeld is prima in orde, maar zoals gezegd, tis een soort basismodel.
[ Voor 8% gewijzigd door Tele op 21-09-2005 19:31 ]
Het beeld ziet er prima uit, winkelprijs van de 27" ligt rond de €950jaguarxj16 schreef op woensdag 21 september 2005 @ 20:13:
interresant, ben benieuwd wat de prijzen zijn, en wat de kwaliteit voor soeps is
Anschlüsse
Digitaler Bildeingang (DVI mit HDCP), Komponenteneingang, 2 SCART-Anschlüsse, S-Video, Video (Ein/Aus), PC-Anschluß (D-Sub), Antennenanschluß, Kopfhöreranschluß"
http://av.samsung.de/arti...4-9EF8DAD44EED&show=specs
@tele waar heb je deze tv bekeken dan? want in NL is ie nog neit leverbaar volgens mij
Ik vrees niet de man die 10.000 trappen heeft beoefend maar de man die 1 trap 10.000 keer heeft geoefend
Ik vind het wel lang duren alvorens ze leveren, dit heeft ongetwijfeld te maken met het feit dat het niet hun eigen voorraden zijn op de site, maar die van leveranciers.
Ik heb maandag de LE32R51B besteld, en als ik geluk heb wordt ik morgen door de koerier gebeld om daarna nog een afspraak te maken voor levering.
Intussen is er een prijsdaling geweest van 1225 naar 1212, daar heb ik contact over gehad en ze zijn bereid het verschil in prijs terug te betalen na levering. Ze konden de prijs niet meer wijzigen. Overigens had ik m liever ergens dezelfde dag opgehaald. Nu heb ik m waarschijnlijk niet eens meer voor het weekend.
Met alleen DVI bedoelde ik eigenlijk te zeggen dat er geen HDMI op zit.jaguarxj16 schreef op donderdag 22 september 2005 @ 11:14:
volgens de duitse site zit er op de 32"versie wel meer aansluitingen dan alleen dvi:
Anschlüsse
In een winkel waar ik parttime werk.
ik heb bijna 5 week gewacht op mijn LE26R51, maar meestal kunnen de winkels en samsung nederland er niks aan doen. Zijn keuzes die gemaakt worden op een veel hoger nivo
Ik werd vandaag om 17:30 nog gebeld door het koeriersbedrijf dat ze m pas maandag kunnen afleveren. Staat ie heel het weekend daar in zon loodsDevilfish schreef op donderdag 22 september 2005 @ 19:21:
vraagje de beeld van de le32r51b is die 82cm beeld scherm of is die totaal 82cm dus met de kast erom zogezegt???
Heb hem overigens bij Progress besteld.
te lezen en hier hebben een aantal mensen nieuwe firmware van samsung gekregen
Ik heb al een kabeltje die schijnt te werken nu alleen nog even de goede firmware zoeken ...
Ik heb alleen 1 vraagje aan de bezitters hiervan:
Ik las in de OP dat de geluidskwaliteit slecht is van de speakers, is dit echt zo of valt het wel mee ?
Ik heb namelijk niet echt ruimte op mn kamer voor een 5.1 setje (en die set van Bose vind ik een beetje aan de dure kant
wat voor kabel moet ik nemen van mij pc naar mij le32r51b tv..?
ik heb een geforce 6600..
bvd
[ Voor 15% gewijzigd door Verwijderd op 26-09-2005 13:06 ]
kan ik deze kabel nemen voor pc naar lcd tv..?
en geen hdmi con voor de pc..
of zie ik wat over het hoofd??
of werkt ie hdmi con die achter de tv zit ook voor pc..?
[ Voor 19% gewijzigd door Verwijderd op 26-09-2005 18:52 ]
Deze heb ik vanmiddag ook besteld. Zaterdag na werk ff ophalenBram schreef op zaterdag 24 september 2005 @ 12:40:
Ik heb 2 weken geleden de 26R51B besteld. Bij de order staat dat hij week 39 (aankomende week) wordt geleverd. Hoop dat ze dat kunnen waarmaken.Omdat ik veel lees over mensen die al maanden wachten op dit type. Ik kan iig niet wachten.
Ik ben benieuwd wat de kwaliteit precies is. Mijn huidige samsung tv zuigt aarsch!
wie zou mij een site of linkje willen mailen waar ik de kabels kan bestellen..
go1kwz@tiscali.nl
bvd
Die HDMI connector die achterop je scherm zit bestaan verloopkabels voor. Het beeld signaal van HDMI is namelijk gelijk aan dat van DVI.Verwijderd schreef op maandag 26 september 2005 @ 18:48:
ja ok maar als ik achter de lcd tv kijk zie ik dat erzo 15 pin's con zit voor de pc..
Ik heb zelfs al kleine verloopstekkertjes gezien.
Ik kan me niet voorstellen dat het niet zo is, maar het staat niet in de manual die ik van de site heb gedownload...
Ik wilde net de Video Mute Time op 4 zetten (is ook gelukt) alleen heb ik per ongeluk iets anders ingesteld in het menu 7. YC delay.
Wil iemand met deze TV (of uiteraard de R41) aub even in zijn/haar service menu kijken en hier doorgeven welk getal er achter RF PAL B/G moet staan in menu 7. YC delay? Alvast hartelijk bedankt!
Ik ben van plan of de Samsung LE40R51 te kopen of the Sony KLV S40
Maar ik wil ze nog wel eerst bekijken.
Weten jullie misschien waar een van deze LCD's in een showroom staat?
Thnxx
Bedankt voor de snelle reactie! Heb je ook enig idee wat voor een instelling dit is? Zoals de naam zegt, heeft het met vertraging te maken, maar wat voor een vertraging?Devilfish schreef op woensdag 28 september 2005 @ 00:06:
alvani: RF PAl-B/G 77H
Het beeld aan de PBook was alleszins schitterend te noemen .. eigenlijk ideaal als monitor op mijn bureau .. hmm
Weet niemand mij iets te vertellen over de geluidskwaliteit van het toestel zelfMartijn85 schreef op maandag 26 september 2005 @ 11:57:
Ik zit er ook over te denken om de LE32R51B te kopen
Ik heb namelijk niet echt ruimte op mn kamer voor een 5.1 setje (en die set van Bose vind ik een beetje aan de dure kant)
Zonder de B zijn de speakers grijs, met de B zwartVerwijderd schreef op woensdag 28 september 2005 @ 16:56:
wat is nu het verschil tussen de LE32R51B en de LE32R51 ?
zonder de B
bedankt..Verwijderd schreef op woensdag 28 september 2005 @ 17:03:
Heeel goed.Denizz schreef op woensdag 28 september 2005 @ 17:40:
Heeft er iemand al HDTV beelden op zijn samsung bekeken? Hoe ziet het eruit? Zeer goed of perfect?
HD DivX samples via mce over analoge vga kabel.
Voor zover DivX HD samples HDTV zijn natuurlijk
Nog meer mensen met dit probleem?
geen ideealvani schreef op woensdag 28 september 2005 @ 09:49:
Ik heb 5 week gewacht, dus ik denk idd dat ie slecht leverbaar isBram schreef op woensdag 28 september 2005 @ 20:37:
Ligt het aan mij of is die LE26R51B gewoon heel slecht leverbaar. Kan verdomme weer een week langer wachten.
Nee je moet zelf een aparte kabel kopen, enige bijgeleverde kabel is de stroom kabel...Denizz schreef op woensdag 28 september 2005 @ 21:39:
Zit er trouwens een kabel bij om hem op je PC aan te sluiten of moet je die apart kopen?
Ahhh...Verwijderd schreef op dinsdag 27 september 2005 @ 16:44:
Kan iemand bevestigen dat deze apparaten PAL60 ondersteunen?
WOAW WAT EEN SERVICE HEEFT SAMSUNGVerwijderd schreef op woensdag 21 september 2005 @ 18:45:
Zo, na wat tests te hebben gedaan blijkt dat mijn tv gerust boven de > 40 dB noise produceerd, tevens maakt de tv - als hij op stand-by staat - een hele hoge piep erg anoying zeker als je wilt slapenMorgen gaan we eens contact openemen met onze geliefde samsung dealer en maar eens kijken wat eruit te slepen valt! Dank voor alle tips etc, ik houd jullie op de hoogte!
Cheers
kan iemand een foto maken van de achterkant en eventueel van de inputs?
ik wil het scherm namelijk aan de muur hangen en een soort van kabelgoot in de muur laten fresen(als ze toch bezig zijn met je huis verbouwen
Ik heb hem sinds gisteren en ik vind het echt fantastisch goed eruit zien. Ik zit nu alleen toch wel over digitale tv te denken. Het beeld is perfect, maar het kan veel scherper
net even Sin City op dvd bekeken, en mijn ogen vielen open! het zwart is perfect, en het wit is ook oogverblindend wit!
Iedereen die aan het twijfelen is, niet doen! KOPEN!
Ik zit te twijfelen tussen de 32R51B en 32M51B voor mezelf. Mn zus heeft de 32R51B en ik vind het een super tv, alleen dat de tv een 16:9 uitzending (talpa) niet volledig uitvult vind ik een minpunt.
Ik heb nog niet bij haar kunnen testen of je 720p gewoon via vga kan doen.
Wat raden jullie mij aan, windows op 720p of gewoon native resolutie van scherm.
Windows gewoon op native resolutie, bij mij staat ie nu op 1360x768, 1366 kreeg ik niet aan de praat, dus er vallen aan weerszijden 3 rijen pixels af.Rainesh schreef op zondag 02 oktober 2005 @ 20:24:
kan je via vga ook 720P activeren of moet dat perse via dvi <=> hdmi?
Ik heb een Samsung HD850 dvdspeler met hdmi en die output 720P. Superbeeld en deze speler speelt ook divx.
Heeft er btw iemand dode pixels? Ik heb er 1tje beetje onderaan zitten. Ik vind het niet waard om het scherm hierover terug te sturen maar wat denken jullie ervan?
Geen enkele, heb toch wel een aantal keer goed gekeken. Ik zou die van jou als je je er niet aan stoort laten zitten. Ik denk ook dat je het niet zomaar omgeruild zal krijgen want volgens mij garandeerd samsung niet een kapotte pixelloze aankoop.Verwijderd schreef op zondag 02 oktober 2005 @ 21:09:
Ik heb nog eens gekeken, en op een blauw scherm (geen vid input) licht ie wel weer gewoon opaapelite schreef op maandag 03 oktober 2005 @ 07:57:
Voor de rest is het gewoon een prachtbeeld voro een lcd
