PCI riser voor VIA Epia board -> GEVONDEN!
Pagina: 1 2 Laatste
  • 847 views sinds 30-01-2008
  • almightyarjen
  • Laatst online: 06-07 21:39
almightyarjen
When does the hurting stop?
Ik heb vrij goed nieuws: ik ben druk bezig geweest naar PCI risers voor het VIA Epia board,
die van de inkoopactie :)
Ennuh, ik denk dat ik het een en ander heb gevonden:
Riser 1:
Fabrikant: Rackmountpro
URL: Rackmountpro
Prijs: $65
Specs: Dit is een riser met controller aan boord, waardoor er dus drie sloten mogelijk zijn. Hij is zelfs
getest door het bedrijf, hier is de email conversatie:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Ik:
Goodday,
I have a question regarding the PCI riser part nr. AC-RISER-2U32BIT-3261.
On a dutch forum, there is a collective buying action going on. We buy
collectively about 100 VIA Epia mainboards. There's only one PCI slot
mounted on this board and a lot of buyers want to use at least 2 PCI slots,
which automatically requirers a PCI riser. The size of the riser doesn't
matter: most people will build their own case. It is important to know for
sure that the AC-RISER-2U32BIT-3261 will work on the VIA Epia board. The
link for information about the VIA board:
http://www.viavpsd.com/products/epia_mini_itx_spec.jsp
If the riser will work,  how is your policy about shipping to The
Netherlands and discount on a large number (about 50) of risers?
I hope you can help me and I am waiting for reply.
Yours sincerely,
Arjen
Thomson Multimedia, Breda
The Netherlands.
zij:
Arjen,
Thank you for your inquiry.
This is very good point. My understand there are three motherboard making
17" x 17" size board which is Shuttle, FreeTech and VIA. I need check with
them when they design the board does they keep the DMA for extra PCI slot.
If the board/bios has remain PCI expension the the riser card you found will
work
otherwise -noway.
I will let you know today. (I will get one board for trying)
Best regards,
Tommy Tang
zij:
Arjen,
I tested it will working fine. Since the Riser card can asign IRQ/DMA from
the mother board.
Tommy
Ze hebben ook wat pics opgestuurd:
K*T :( endoria ligt eraf. Pics krijgen jullie tegoed.
Riser 2:
Fabrikant: Cofan-USA
Prijs: nog niet bekend
Specs: Dit is een veel simpelere riser zonder controller aan boord en met maar twee PCI sloten.
Omdat er geen controller aan boord is, zal deze een stuk goedkoper zijn.
E-mail conversatie:
Ik:
zelfde als boven.
zij:
Hi Arjen,
Finally, I found what the riser card you want.
Please check the picture that's for VIA EPIA mini-ITX main board.
We are waiting the approval from the VIA, I think it will be done by this
week.
We will have the part coming Friday so once I have it I will let you know.
Best regards,
Sam Kim
Cofan USA
Ook hier krijgen jullie de pics later.
Riser 3:
Fabrikant: Space Promotion
Prijs: onbekend
Specs: Weet hier nog niets van. Voordeel is wel dat het een Nederlands bedrijf is.
E-mail conversatie:
Ik:
Goedenmiddag,
Ik ben op zoek naar een speciale PCI-riser. Dit is een riser voor het VIA
Epia ITX mainboard. Door deze riser wordt het mogelijk om ipv 1 twee
PCI-apparaten aan te sluiten op dit bord. Verkoopt u deze risers ook?
Mvgr, Arjen
zij:
Ik heb inmiddels een mogelijke riser gevonden, maar ik moet wat meer
gegevens nodig van de kast. De mogelijke riser is 6,3 cm hoog. Past dit?
Ik:
In dit stadium maakt het niet uit of de riser past, de
meeste mensen zullen hun kast zelf maken.
Het belangrijkste is of deze riser daadwerkelijk werkt op
dit desbetreffende mainboard.
Hier heb ik verder nog geen antwoord op.
Ik zal zo een paar mails de deur uitdoen met de vraag
naar shipping costs en dergelijke. Als jullie nu ff
willen aangeven of jullie interesse hebben en zo ja in welke riser (voor zover je nu al kan beslissen)
dan kan er misschien hiervoor een inkoopactie worden gehouden. Om een inkoopactie heb ik zelf te weinig
tijd, maar er zal best wel een GoTter zijn die tijd overheeft :+
[ Voor 0% gewijzigd door almightyarjen op 22-03-2011 14:28 . Reden: ff naampje wegpoetsen ;) ]
  • eightValve
eightValve
Zegt u toch allemaal???
één woord!! SUPER!! :)
neat :D
  • Bart_Banaan
  • Laatst online: 17-04-2017
Bart_Banaan
CaseJunkies Crew Member!!
Kijk, kijk, zeer positieve ontwikkelingen......
Horizontaal, meerder sloten, dan kan die Via Eden een versnelling hoger, VGA,Sound, ......
maare staat 'ie zo:
of zo:
Bekijk de SpaceCase en de DesignLine Prism www.casejunkies.com
$65 is aardig veel geld niet??
Omgerekend +- 75 pleuro dat vin ik dus wel errug prijzig
  • Bart_Banaan
Bart_Banaan
Ik heb interesse in deze riser, maar alleen als ie 'de goede kant op staat' dwz dat de PCI kaarten boven het MoBo komen, en die niet -zoals vaak bij die dingen voor rack servers- 'de verkeerde kant' op wijzen oftewel niet boven het MoBo zitten
  • Spyro_the_Dragon
  • Laatst online: 22-04-2013
ajj daar gaan we want ik wil liever een die de verkeerde kant opwijst, dus niet boven het mobo maar de andere kant op....
en ik wil ook liefts een 1-1 riser, of een 1-2 die niet te hoog is ivm de hoogte van mijn case.....
Ha! Ha! Ha! That feisty little dragon Spyro thinks he and his pal can stop me? ME? GNASTY GNORC? NEVER!
  • PoweRoy
  • Laatst online: 14:19
PoweRoy
funky!
eeh, wat is een riser? :? :? :? :? :?
[This space is for rent]
  • Jeldert
Jeldert
Rozijntjes
Op dinsdag 21 mei 2002 12:29 schreef PoweRoy het volgende:
Afbeeldingslocatie: http://www.rackmountpro.com/prodimages/2u3p3261.jpg
Dus je steekt een kaartje in een PCI slot, en je hebt dan 2 of 3 PCI sloten.
Duidelijkere pic:
Afbeeldingslocatie: http://www.centralcomputer.com/Features/ProductGuides/Rackmount/Images/AMS3UPCIRiser.jpg[quote]
Riser Cards: In order to mount PCI cards into your 1U and 2U cases, you'll need riser cards that essentially convert vertically-oriented PCI slots into horizontally-oriented ones. For 1U cases, you generally will only have space for a single riser. With 2U cases, you should have room for up to three expansion PCI slots.
[/quote]
Juist
  • PoweRoy
PoweRoy
funky!
oh nu snap iek et
wow, dit is nog eens searchwerk, zeeeer mooi
Nu gaat ik eens even bedenken wat voor soort riser ik kan gebruiken. Je hoort nog van me!
  • almightyarjen
almightyarjen
Op dinsdag 21 mei 2002 12:05 schreef Derranged het volgende:
Dit klopt. Dit komt omdat er op deze riser een "bridge" aanwezig is. Deze bridge zorgt ervoor dat de 3 PCI sloten net echte zijn. Op Riser 2 zit geen bridge, volgens mij zijn hier de PCI-sloten geshared, waardoor deze riser een stuk goedkoper zal zijn. :)
Het schiet niet op met Endoria, dus ik heb zelf de pics maar ff op m'n website gezet:
VIA Risers
Zoals je op de pics kan zien zit Riser 1 zoals Spyro_The_Dragon wilde. Ikzelf voel meer voor de andere, Riser 2. Hoe deze zit kan ik niet zien aan de pic, iemand anders?
Over Riser 3 is nog niets bekend, kan ook nog een paar dagen duren. |:(
  • Stropdas
  • Laatst online: 06-07 20:06
Stropdas
Insert subtitle here
Word het niet erg groot als de kaarten naast het mobo steken? Dan is een flexibel verlengstukje voor PCI erbij ook wel handig voor sommige mensen zodat je het kan draaien en naar boven of zelfs over het moederbord kan laten steken ipv ernaast. Dan heb ik ook misschien wel intresse
[edit] Hulde aan almightyarjen voor het speurwerk. Dat waarderen we allemaal zeer! :)
Honda VFR800fi '99 | Volvo S60 '04
  • Potatoman
  • Laatst online: 04-07 12:37
Potatoman
koniwa
Kan zijn dat jullie dit al weten/niet zoeken, maar op http://viddel.shop.tweakers.net/?action=overzicht&groep=9
(oftewel de t.net shop) staan ook riserkaarten, die ze gewoon onder rembours of vooruitbetaling verzenden :)
The cyclographing developer
Ik wil eigenlijk een AGP riser card, maar die bestaan niet volgens mij :-(
  • iets
  • Laatst online: 08-07 17:48
Doelloos:
1. Wie gebruikt hier nou weer al zijn PCI sloten?
2. Gaat zeker stukken langzamer als alles gesplitst word.
3. Als je deze vastzet kun je PCI poorten onder Riser toch niet meer gebruiken?
Gewoon doelloos
tvw
  • Potatoman
Potatoman
koniwa
Op dinsdag 21 mei 2002 15:28 schreef joshuasioso het volgende:
Doelloos:
Gewoon doelloos
1. Als je een mobo hebt met maar 1 pci slot wordt het natuurlijk moeilijk...
2. Waar slaat dat op?
3. Bij 1 Slot zit er niks onder
En als je wist wat een VIA Epia board was had je deze vraag niet gesteld.
Doelloos:
Gewoon doelloos
ga de draad over het via epia mobo eens lezen voor je dit naar het domein van de doelloosheid verwijst :?
btw. almightyarjen,
het mobo bij die 1e riser is geen via eden :?
(zit namelijk floppycontroller en losse proc op)
  • almightyarjen
almightyarjen
Op dinsdag 21 mei 2002 15:31 schreef _AscII_ het volgende:
btw. almightyarjen,
Inderdaad, je hebt gelijk. D'r zit ook een megacooler op, het gaat hier duidelijk niet om een rustige koele C3 proc. In de email conversatie had diegene het er ook over dat-ie contacten met VIA had. Als je goed kijkt kan je zien dat er een VIA chipset op het bord zit. Ik denk dat dit verder dus geen probleem mag vormen. Misschien is dit het VIA Eden board ofzo.
Email terug van Rackmount Pro. Als hij 25 stuks aan ons kan leveren zal de prijs op $58.99. Ik neem aan dat er bij de import nog BTW overheen moet?
De shop van T.net levert idd risers, maar niet de goede. Alleen risers om een hoek van 90 graden te maken of risers met idd 3 sloten, maar met twee kabels met connectors eraan die je dus in een ander PCI-slot moet drukken. Daar schieten we dus ook niets mee op. Tot zover de update. :P
  • almightyarjen
almightyarjen
Email terug van Rackmount Pro:
29
30
31
32
33
34
35
36
37
38
39
Ik:
Tommy,
Many thanks for the testing! I am really interested in the
riser. On the website the riser costs about $65.
Is this price VAT included? And another question: do you
ship to The Netherlands? If so, what are the shipping costs
when we order about 25 risers?
Your sincerely,
Arjen
Zij:
What is VAT stand for?
For 25pcs card I offer $58.99/each.
I will check the shipping after I get in the office.
And I will e-mail again you later.
Ik:
Thank you for replying. VAT stands for Value Added Tax.
Included VAT will say: total price including taxes.
Waiting for your promised reply,
Zij:
Oh yah, I forgot it.
Tax free for us to ship to oversea but you need pay VAT
when you clear the customs in Europe right?
Ik:
Right, that is correct. That is called in The Netherlands
BTW, same as VAT in the US.
Zij:
If you have an account with Fedex or DHL and we can using
your account number to ship or we can do the freight
collect by your credit card.
Mijn vraag aan jullie is dus: is er een GoTter die een Fedex of een DHL account kan gebruiken? Of makkelijker: iemand met een credit card?
Zo ja, wat zijn de kosten hiervan? Totaal geen verstand van die dingen. ;)
nou nou heb je nooit van dhl gehoord :?
neem contact op met die boys en je kunt er een account krijgen dhl stuurt ook naar particulier..
en anders feddex dan gebruik je toch je pappies visa kaart >:)
maar effe om de centen, ken je geen vrind met een bedrijf, die kan die risers kopen en de btw lekker afschrijven. vindt ie alleen maar leuk >:)
  • SEFje
  • Laatst online: 09-03 11:51
Op dinsdag 21 mei 2002 16:31 schreef dualserver het volgende:
Misschien bart_banaan :? of maraex of hoe ze ook heten.
Staan deze risers nou eigenlijk allebei de verkeerde kant op? zou toch wel jammer zijn imho.
  • DRaakje
ik heb interesse in die met 3 of 2 aansluitingen. belangrijk is dat ie wel de goede kant op staat omdat ik hem al in een bestaande kast wil proppen...!!!
verder goed bezig!!!
  • almightyarjen
almightyarjen
Op dinsdag 21 mei 2002 16:55 schreef SEFje het volgende:
Eh, Riser 1 kan je dus zien op de site, als je dat "de verkeerde kant noemt"...
van Riser 2 en 3 weten we nog niets af. Dit is even afwachten totdat deze contactpersonen contact met mij opnemen. Die gasten van Riser 2 zeiden dat ze eerst ff met VIA gingen lullen en zo'n bordje gingen bestellen. Zij zouden aan het einde van de week meer weten. :)
Ik ben zeer geinteressert!!!!!!!
:9~
  • Bart_Banaan
Bart_Banaan
No Credit Card here! DHL bezorgt gewoon bij iedereen, even melden aan ze dat je een pakketje verwacht/wil versturen, en ze geven je alle info die nodig is.
  • almightyarjen
almightyarjen
Hmz, ff gekeken naar de tarieven van DHL en FedEx, uitgaande van een pakket van 6 kg die naar de VS moet. Ik neem aan dat deze tarieven ongeveer hetzelfde als van de VS naar NL.:
DHL:
123 Euro
FedEx:
111 Euro
Teringjantje duur dus. Als we uitgaan van 25 risers (6 kg), dan zit je op: 111/25 = 4.44 Euro per riser. Dat valt dan dus nog wel mee. :) Als iemand een creditcard heeft is makkelijker...
  • Venkmen
  • Laatst online: 04-08-2025
Venkmen
Gohan becomes Super Saiyan II
HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~ HEBBE! :9~
JE ZIET IK BEN OOK GEINTERESEERT
[Dyslexie is my ID]
Venkmen heeft ff geen inspiratie voor zijn sig.!
|Specs|
  • almightyarjen
almightyarjen
Okee Venkmen, you've made your point... :)
maar als ik het goed zie risen deze dingen van het mobo af en niet eroverheen?
___
   |____
en niet
  ____
 |____
  • LauPro
  • Laatst online: 15:46
LauPro
Prof Mierenneuke®
Leuk, misschien handig om de inkoopactie hier op te gaan zetten?
Inkoopacties - HENK terug! - Megabit
It is a war here, so be a general!
  • Bart_Banaan
Bart_Banaan
Op dinsdag 21 mei 2002 19:03 schreef LauPro het volgende:
Waarom wil jij alle inkoopacties op je site(s)??
Verzamel je soms naam, email en bankrekening gegevens?????
of vergis ik me, en ben je echt ter goede trouw, en heb je een echte inkoopactie-site gemaakt die het leven voor ons makkelijker maakt?
:? :? Koala beertjes??
  • LauPro
LauPro
Prof Mierenneuke®
Op dinsdag 21 mei 2002 19:10 schreef Bart_Banaan het volgende:
Nou dat is niet de bedoeling, het is om het leven makkelijker te maken, er is al Topic over geweest dat meer mensen dit willen.
En over die e-mail en bankgegevens, dat is nou eenmaal nodig voor het succesvol afronden van een inkoopactie.
edit: Die Koala beertjes?? heb ik al lang geblokkeerd! :7
  • Bart_Banaan
Bart_Banaan
Dan heb ik niks gezegd.... iig bedankt voor het maken van de site.
  • LauPro
LauPro
Prof Mierenneuke®
Op dinsdag 21 mei 2002 19:53 schreef Bart_Banaan het volgende:
Maakt niet uit, ik kan het me vorostellen :P. Maar je gaat het dus gebruiken of..?
  • DRaakje
hmmm, ik zou graag een 1>3 riser hebben, maar dan wel dat ie over het moederbord heen komt te hangen. (dat is dus precies omgekeerd aan die van rackmountpro. Is die ook leverbaar??? En anders ga ik inderdaad wel voor die van cofan.
  • Bart_Banaan
Bart_Banaan
Op dinsdag 21 mei 2002 20:40 schreef LauPro het volgende:
Dat moet je aan almightyarjen vragen, ik maak alleen misbruik van deze inkoopactie >:)
  • LauPro
LauPro
Prof Mierenneuke®
Op dinsdag 21 mei 2002 20:46 schreef Bart_Banaan het volgende:
De vraag was ook aan almightyarjen, als hij weer terug kijkt op dit topic dan ziet hij het wel ;)
Was het niet een VIA eden bord? Die EPIA was toch met een 933 Mhz. chipje?
  • SEFje
Ja dat vroeg ik me ook af, of is het hetzelfde?
De C3 zelf heeft ook nogal wat pseudoniemen... Samuel, Joshua... er was ergens een hele lijst van, het ding heeft zeker 7 namen :+
  • almightyarjen
almightyarjen
Okee, daar was ik weer. Sorry, ik kan alleen overdag tijdens mijn stage reageren, woon tijdelijk in Breda en daar heb ik geen internet :( . Vraag me niet hoe ik het overleef. :)
Even over de vraag of het nu een VIA Eden of een VIA Epia is: VIA Eden is een embedded omgeving. Je hebt zowel processors die Eden heten als mainboards. Zie deze link voor meer info. En dan hebben we de VIA Epia. Dit is ons bord. Voor meer info over de Epia, zie deze url. Mocht het nog niet duidelijk zijn, meld dat dan ff. En trouwens: correct me if I'm wrong: ben maar voor 99% zeker. Voor de echte modders onder ons: hier even nog een extra datasheet van de VIA Eden processor, die op het bord zit.
Op dinsdag 21 mei 2002 18:57 schreef Hermanator het volgende:
___
   |____
en niet
  ____
 |____
Eh, Riser 1, die van rackmount pro, rised van het mobo af, zoals te zien is in de pics. zal zo ff kijken of ik ze alweer kan uploaden. Bij riser 2 is dit onduidelijk; het lijkt erop alsof je hem beide kanten op kan leggen. En bij riser 3 is het helemaal onduidelijk omdat we daar verder nog geen mail van hebben. Ik wacht vandaag nog af, krijg ik geen mail van Space Promotion, dan ga ik er zelf even achteraan. Voor de precieze info over riser 2 en 3 is het gewoon dus nog ff wachten op de mail.
Vind ik allemaal best, als de rest het er ook mee eens is. Maar laten we niet te hard van stapel lopen; laten we eerst zeker weten welke we kiezen. En dat kiezen kunnen we nu nog niet doen omdat we nog te weinig info over riser 2 en 3 hebben. :)
En Endoria ligt er nog steeds af :( .
  • almightyarjen
almightyarjen
Nog even terugkomend op de discussie of het nu een Epia of Eden is:
The VIA EPIA Mini-ITX motherboard is available with a choice of two embedded processors. The EPIA-800 features a 800 MHz C3 (Ezra core) with an operating core voltage of 1.35V. VIA says it is suitable for compact systems running more multimedia applications. The EPIA-5000 Mini-ITX is equipped with the Eden ESP 5000, essentially a 533 MHz Samuel 2 core C3 running at 1.2V, which VIA says is suitable for fanless systems with low heat and ulta low-power requirements.
Bron
Wat wij besteld hebben is dus een VIA Epia-800. :)
  • Venkmen
Venkmen
weet iemand hier misschien iets over een riser met Sigma Designs MPEG II decoder ze hebben het hier over in DIT PDF-je. ik heb ook op een site gezien dat ze hem in een EDEN-mobo hadden gepropt zie hier duuuuus. Ik weet het niet meer :? :?
[Dyslexie is my ID]
|Specs|
  • Spyro_the_Dragon
al wat van die cofan gehoord?
Afbeeldingslocatie: http://mimogang.tripod.com/viariser/image6.jpg
[edit] plaatje werkt niet meer... zie de viariser site:
ik wil zeker een verkeerd-om (dus weg van het mobo en niet eroverheen) riser hebben; 1-1 of 1-2. Dit ivm dat ik wel eens wil zien wat de geluidskwaliteit van de VIA Eden is... kan ik er altijd nog een echte geluidskaart instoppen.... en evt een kaartje met COM poorten...
  • almightyarjen
almightyarjen
Die lui van Cofan zouden aan het einde van deze week contact met mij opnemen. Zij zouden eerst zelf het een en ander gaan testen. Je moet dus nog ff geduld hebben. :)
Als je een 1-1 riser wilt kan je gewoon een standaard riser kopen. Die werkt zeker op de Epia. Een 1-1 riser is niets anders dan een doorverbinding en is zeker te verkrijgen in de uitvoering die jij wilt. ;)
  • Spyro_the_Dragon
Op woensdag 22 mei 2002 10:22 schreef almightyarjen het volgende:
ja, heb die op de tweakshop al gezien (van procase) en die zou ik wel kunnen gebruiken idd.... Maar in mijn case die ik aan het bouwen ben heb ik ruimte voor twee.... dus vind ik het een beetje zonde om een 1-1 te kopen (voor 26 euro) als ik later evt een 1-2 kan gebruiken...
Maar ik zal geduld hebben ;)
  • almightyarjen
almightyarjen
Op woensdag 22 mei 2002 10:26 schreef Spyro_the_Dragon het volgende:
Ik zie je punt. Heb nog ff gekeken: vrijdag krijgen die lui meer info, da's dus waarschijnlijk hier donderdagnacht. Dus waarschijnlijk heb ik vrijdag nieuws. If not, dan wordt het waarschijnlijk dus maandag. Ooow, ik heb een hekel aan wachten! :( Maar ff indutten tot vrijdag... :Z :Z :Z
  • Spyro_the_Dragon
Op woensdag 22 mei 2002 10:30 schreef almightyarjen het volgende:
geduld is een schone zaak ;) Ben gelukkig toch nog wel ff bezig met bouwen......
  • Stropdas
Stropdas
http://viddel.shop.tweakers.net/?action=product&nr=146
Is dat wat voor mensen die hun uitbreiding wat flexibel willen gebruiken? Als je deze op het mobo propt en daar een riser voor 2 kaarten opstopt kan je de kaarten wel boven het moederbord stoppen, je hebt dan ook geen last van geheugen oid omdat je men er een eindje boven kan hangen lijkt mij. Dan heb je iig geen langwerpig bakje. GeForce4MX PCI erop en gamen maar :P Een eigen gamecube ;)
[edit] Dat flexibele stuk lijkt me bij nader inzien toch wel erg kort om er voor te zorgen dat er 2 PCIkaarten boven het moederbord kunnen. Dan zou je 2 van deze verlengstukjes moeten kopen, das dan zo'n 100 voor alleen de mogelijkheid om de PCI boven het moederbord te hebben, dat gaat mij wel erg ver
  • almightyarjen
almightyarjen
Op woensdag 22 mei 2002 10:54 schreef Stropdas het volgende:
Wowowo... Ff rustig... Uhm... Die riser die je bij jouw link ziet KAN je idd gebruiken om je PCI-slot te verleggen. Oftewel: dit kan een optie zijn. Als we Riser 2 nemen zal dit niet kunnen. Waarom? Riser 2 is min of meer speciaal ontwikkeld voor de VIA Epia: het VIA Epia board heeft extra aansluitingen op het PCI-slot. (kijk maar op de risersite, zie sig: riser 2 heeft extra aansluitingen.) In dit slot past een PCI-kaart, maar ook een riser. Deze riser gebruikt de extra aansluitingen van dit slot. Als je nu een riser zoals jouw link beschrijft er tussen zet, worden alleen de echt PCI-aansluitingen verlegd, maar de extra aansluitingen niet, waardoor de riser niet zal werken.
Jouw verhaal kan wel als we voor riser 1 gaan. Deze riser heeft een eigen controller en gebruikt alleen de standaard PCI-aansluitingen. Hoe het met riser 3 zit weten we nog niet. :)
  • Spyro_the_Dragon
riser 2...... riser 2....... riser 2 die is OK :)
Zou voor mij ideaal zijn... en ik heb eens ff zitten kijken: je kunt mm denk ik idd twee kanten op gebruiken: over je mobo heen en van je mobo af.....
  • Stropdas
Stropdas
Op woensdag 22 mei 2002 11:49 schreef almightyarjen het volgende:
Je hebt helemaal gelijk :) Ik ben te snel. Als je Riser2 neemt dan kan je dus de PCIkaarten wel boven het mobo hangen, maar past er in de onderste wel wat ivm het geheugen? Het lijkt erg krap namelijk
  • almightyarjen
almightyarjen
Op woensdag 22 mei 2002 11:58 schreef Stropdas het volgende:
You've got a major point there. Ik heb ff gekeken naar de maximale omvang van een DIMM: maximaal 3,8 cm hoog... En als we naar de Epia kijken, zien we dat het DIMM-slot direct naast het PCI-slot zit. Bekijken we nu riser 2: het eerste PCI-slot zit zeer dicht bij de aansluiting. Ennuh, als je de riser in het slot op de Epia stopt, komt het onderste PCI-slot op de riser ongeveer (naar schatting) 2 cm boven het DIMM-slot. Dit is veel te weinig! De meeste, ik denk zelfs 95%, van de DIMMs zullen hoger zijn dan 2 cm. Dit is een major issue. Dit is een vraag die ik die lui van Cofan zeker ga vragen als ik vrijdag reply heb. Damn, da's niet tof. Aan de andere kant: riser 2 is wel min of meer gemaakt voor de Epia, dan zouden ze hier toch wel rekening mee hebben gehouden? Okee, alle gegevens weer op een rijtje:
riser 1:
Kost ongeveer 70 Euro inclusief shippingcosts naar NL, heeft een eigen controller waardoor 3 PCI sloten erop zitten, PCI-kaarten steken van het bord af.
riser 2:
Zal een stuk goedkoper zijn dan riser 1 omdat er geen controller opzit, ik schat zo'n 40 Euro inclusief shippingcosts naar NL. Er zijn 2 PCI sloten beschikbaar, maar het onderste PCI-slot biedt ongeveer maar 2 cm ruimte tot de onderkant van het DIMM-slot. In het onderste slot zou dus alleen een PCI-kaart kunnen die aan de achterkant van de kaart niet meer dan 1 cm verder uitreikt dan de achterste aansluiting. Riser 2 kan wellicht op 2 manieren worden geplaatst; dus ook op een manier dat de kaarten van het bord af steken.
riser 3:
Weten we nog niets van en ik ga die lui nu mailen.
  • Spyro_the_Dragon
Op woensdag 22 mei 2002 13:55 schreef almightyarjen het volgende:
riser 2:
Is dat niet het grote idee van deze riser: dat je m twee kanten op kunt gebruiken???? Omdat er twee van die inkepingen onderin zitten? Als je nog contact hebt met die gasten zou je dit dan kunnen vragen?
  • almightyarjen
almightyarjen
Op woensdag 22 mei 2002 14:56 schreef Spyro_the_Dragon het volgende:
Yep was dat al van plan, thnx anyway voor het melden. :)
  • Kippenijzer
  • Laatst online: 29-06 07:56
Kippenijzer
McFallafel, nu met paardevlees
Als je effe goed naar die riser kijkt zal je opvallen hoe het zit... En "normaal" PCI slot (dwz, 33MHz) heeft de key precies aan de andere kant als een 66MHz slot... Deze riser past ook in 66MHz sloten, maar als je dit dingetje andersom op het bord zet komen de keys van de gerisede PCI sloten op een 66MHz manier uit, waardoor het gros van de kaarten er niet meer in zal passen... Ook deze riser is dus eentje die gewoon van het bord af rised...
  • DRaakje
hmm dus dat zou dan betekenen dat ie niet zou passen op een shuttle f24/sv24. Maar deze heeft ook maar 1 pci slot dus misschien...? waar zou ik dat kunnen vinden???
  • DRaakje
Op woensdag 22 mei 2002 15:13 schreef Kippenijzer het volgende:
inderdaad, als je hem omgedraaid erin zet dan zullen de aansluitingen van die riser naar de verkeerde kant wijzen. Conclusie hij zal wel niet bedoeld zijn om om te draaien maar om 66 mhz te ondersturenen. :'(
  • Spyro_the_Dragon
Maar weet je dan zeker dat ie van het bord af op 33 mhz werkt????
en ff voor de zekerheid: standaard werkt PCI toch op 33mhz? en alleen in servers op 66 mhz
  • almightyarjen
almightyarjen
Standaad PCI werkt op 33 MHz. Alleen de 64-bit PCI werkt op 66 MHz. En de kans is idd groot dat-ie van het bord af rised, omdat anders het onderste slot niet gebruikt kan worden. Als we dit concluderen kunnen we alleen nog maar hopen dat riser 3 (ja, degene waar we nog niets van weten) over het board rised.
/me Arjen vindt dat die klojo's van riser 3 eens moeten terugmailen... :(
  • Spyro_the_Dragon
Op woensdag 22 mei 2002 16:54 schreef almightyarjen het volgende:
hou je voor mij riser 2 ff in de gaten? Die wil ik evt wel hebben nl (als je dat nog niet doorhad ;) ).
  • Venkmen
Venkmen
Op woensdag 22 mei 2002 16:56 schreef Spyro_the_Dragon het volgende:
Ik wil ook riser 2 hebben of een riser met MPEG II decoder opgebouwd. :9~
[Dyslexie is my ID]
|Specs|
  • Spyro_the_Dragon
Op woensdag 22 mei 2002 17:05 schreef Venkmen het volgende:
riser met mpeg2 erop... heb ik idd ook gelezen in die sales presentatie.. maar volgens mij had je dan nog iets extra nodig.... een module ofzow... zou wel cool zijn....
  • almightyarjen
almightyarjen
Ik heb zelf ook veel interesse in riser 2 omdat deze een stuk goedkoper zal zijn dan riser 1 (denk ik). Die met de MPEG-2 erop is ook wel geinig, maar weinig info over te verkrijgen. Zodra ik een mail van die lui heb zal ik dat ook even vragen.
  • almightyarjen
almightyarjen
Okee, ik heb samen met Venkmen (zitten samen op stage en we hebben het over niets anders dan VIA, Epia, CaseMods en risers :) ) nog even gekeken naar dat Epia board en eventuele risers. Onze conclusie is: bij een riser die over het mobo rised moet het onderste PCI-slot minstens op een hoogte van 2U zitten. Ik denk dat dit ondoenbaar is, aangezien het al ondoenbaar is on sowiezo een riser te vinden... Dit denken we om het volgende: mocht je DIMM zo klein zijn dat de PCI-kaar daar overheen valt, dan zit nog altijd de COM-poort, LAN-poort en LPT-poort in de weg. Deze zullen letterlijk "conflicteren" met de slotplaat van je PCI-kaart. Op deze pic is dat duidelijk te zien. (sorry, een URLetje want endoria is nog steeds offline) |:(
  • Venkmen
Venkmen
Op woensdag 22 mei 2002 17:47 schreef almightyarjen het volgende:
HEEE niet zo SIP ALLEMAAL ;( Alle info over riser 3 is nog niet binnen een beetje hoop graag. B-)
[Dyslexie is my ID]
|Specs|
  • almightyarjen
almightyarjen
:Z :Z :Z wachten tot vrijdag... Of misschien tot na het weekend. :Z :Z :Z
  • Venkmen
Venkmen
Samenvatting van alle info die we tot nu toe hebben!!!!!!
Riser 1
Leverancier Rackmount Pro
Land Leverancier USA
Prijs Ongeveer 70 Euro, inclusief verzendkosten naar Nederland (25 stuks).
PCI slots beschikbaar 3
Onboard controller ja
Positie PCI-kaarten t.o.v. VIA Epia board PCI kaarten hangen er naast
Opmerkingen Riser is duur, maar heeft eigen controller en is getest door het bedrijf dus 100% zeker dat-ie werkt. Het probleem dat deze riser van het board afrised is op te lossen door een flexibele riser tussen het PCI slot op het board en riser 1 te plaatsen. Hierdoor kan je riser 1 overal neerplanten in de kast. De bestelling kan elk moment geplaatst worden, we wachten op de outcome van riser 2 en riser 3.
Riser 2
Leverancier Cofan USA
Land Leverancier USA (figures)
Prijs Schatting 40 Euro inclusief verzendkosten naar Nederland.
PCI slots beschikbaar 2
Onboard controller nee
PCI kaarten kunnen waarschijnlijk boven het board maar in ieder geval naast het board hangen (riser kan waarschijnlijk op twee manieren in het Epia board worden gedrukt)
Opmerkingen Als het idd mogelijk is om met deze riser de PCI kaarten boven het board te laten hangen is er nog een probleem: het onderste PCI slot van de riser zal te laag liggen, waardoor de kaart niet past, ivm DIMM, COM- en LPT-poort. Dit probleem is op te lossen om voor dit slot een flexibele riser aan te schaffen, zie de shop van T.net. De flexibele riser past hier NIET tussen het PCI slot van het board en riser 2, omdat riser 2 geen controller heeft. Riser 2 maakt gebruik van extra aansluitingen die op het PCI-slot van het board zitten. Riser 2 is min of meer ontworpen voor de VIA Epia.
Riser 3
Leverancier Space Promotion
Land Leverancier Nederland
Prijs onbekend
PCI slots beschikbaar onbekend
Onboard controller onbekend
Positie PCI-kaartent.o.v. VIA Epia board onbekend
Opmerkingen Tijd dat die lui eens terugmailen! :(
[Dyslexie is my ID]
|Specs|
  • almightyarjen
almightyarjen
Geweldig Venkmen:
mijn tekst, jouw layout. We komen er wel. ;)
Nu de risers nog... :{
  • DRaakje
Nog een opmerking over die riser 2, als je ze over het bord wil laten hangen (als het zou werken) dan krijg je dat je kaarten de verkeerde kant opwijzen. Dit hoeft niet persee een probleem te zijn maar wel handig om erbij te zetten...
  • Bart_Banaan
Bart_Banaan
Misschien moeten jullie ook nog even in de spare parts van HP en Dell neuzen, want ik heb in mijn HP Vectra 400 desktop PC een 3voudige PCI riser kaart zitten, en ik weet dat Dell bij hun GX150 van 2001 ook 2 en 3 voudige PCI risers gebruikte.
Misschien is dit overbodig, maar die HP riser ziet er erg 'normaal' uit, er zit geloof ik een controller op.
Morgen sloop ik die Vectra wel even helemaal open, en post naam en type nummer van die riser die er in zit (kan ik nu niet zien, moet ik 'm echt ff demonteren :( )
  • RedHead
  • Laatst online: 08-07 14:49
Op donderdag 23 mei 2002 23:48 schreef Bart_Banaan het volgende:
Ook in een Dell G1 en Dell GX110 (ook redelijk laag) zitten riser boards (G1 2 x PCI en 2 x ISA, GX110 2x PCI). Ik zal morgen (of is het vandaag) ff meten en kijken naar typenummers.
Verder heb ik natuurlijk ook interesse in een riser... type 2 ziet er op dit moment het beste uit... ivm de prijs.
  • Kippenijzer
Kippenijzer
Op donderdag 23 mei 2002 23:31 schreef DRaakje het volgende:
Denk nou eens na over dat ding mensen! Als je hem verkeerd om doet en dus inderdaad ook je PCI kaarten omgekeerd erin doet, puur omdat ze dan wel passen, gaat alles wel een beetje kaduuk, want alle PCI contacten zitten dan wel gespiegeld aangesloten, en ik kan me niet herinneren dat de
PCI standaard 180 graden draaibaarheid toestaat |:(
  • Spyro_the_Dragon
Op vrijdag 24 mei 2002 11:43 schreef Kippenijzer het volgende:
Je draait alleen de riser tov het mobo. Als het niet zou kunnen zouden ze het ook niet maken denk ik. Denk ook dat er daarom een chipje opzit (op de riser tussen de twee PCI sloten) om dat een beetje aan te sturen.
De kaarten gaan wel op een normale manier in de riser.
  • Venkmen
Venkmen
mooi plaatje van ons bordje gevonden oooooooooooooooooo :9
Afbeeldingslocatie: http://www.watch.impress.co.jp/pc/docs/article/20011106/via1.jpg
GAAAAAAAAF HE
* Venkmen moet naar de WC
[Dyslexie is my ID]
|Specs|
Hmmm, die 2 sleuven in een PCI slot zijn heel normaal, dit zou de nieuwe PCI standaard worden, niet zodat je dan kaarten verkeerdom erop kan zetten (want dan gaan ze kapot) maar zodat je niet per ongeluk 33 mhz kaarten in een 66 mhz slot kon zetten (want dan gaat ook vanalles kapot) Ik heb hier een netwerkkaartje van Edimax en daar zitten ook 2 van die sleuven in, ik zat niet op te letten en douwde em verkeerd om op het moederbord, resultaat: netwerkkaart naar de hell. Die sleuven zijn dus niet zo erg slim geweest.
  • Bart_Banaan
Bart_Banaan
Voor de PCI riser liefhebbers, hier een fototje uit het handboek, met de beschrijving van het PCI slot, en bij behorende header op het MoBo
Afbeeldingslocatie: http://www.endoria.net/upload/index.php/2841527569
  • Venkmen
Venkmen
Op zaterdag 25 mei 2002 10:47 schreef Bart_Banaan het volgende:
dit is heel fijn. met die video-in kun je een MPEG II decoder op aan sluiten die op je riser zit gebouwd en DIE wil ik HEBBE :9~
[Dyslexie is my ID]
|Specs|
  • almightyarjen
almightyarjen
wowowo... Niet te snel... Hier staat dus dat er een extra connector aan die riser moet zitten. Voor meer info vraag bij VIA Inc. Ik ga hier morgen (maandag) maar eens achteraan. Bart banaan: dank je wel voor het inscannen van die zooi. Het zegt veel: waarschijnlijk gaat riser 2 nu niet meer passen. Zal morgen gelijk op mijn stage mijn mail checken (kan ik nu niet bij). Hopelijk meer nieuws over riser 2 en 3. :{
Tja, wachten op nr3. Ik moet namelijk echt een riser over het bord hebben, en zoals het er nu naar uitziet, voldoen 1 en 2 daar niet aan :(
  • almightyarjen
almightyarjen
Nope...
/me Arjen definitely needs a riser for his vidicube... 8-)
Op zondag 26 mei 2002 15:24 schreef almightyarjen het volgende:
Als je toch contact met Via gaat opnemen, kun je dan ook achter de InfraRood connectie aangaan?
  • almightyarjen
almightyarjen
Ir... Wat is daar precies mee? Weet ik veel van, bezig met stage: onderzoek IrDA onder embedded Linux... :)
  • Bart_Banaan
Bart_Banaan
Het bordje heeft twee niet-standaard IR mogelijkheden CIR en FIR :?
Staat ook bij 'please conmsult to Via Technologies etc...'
  • almightyarjen
almightyarjen
SIR en FIR. SIR is langzaam IrDA verkeer: via een seriële dongle meestal. FIR is snel, tot 4 Mbit/s. Met FIR heb je een controller chip nodig, weet zo niet of die op het bord zit... Zal er morgen ff achteraan gaan. :)
  • Bart_Banaan
Bart_Banaan
Weer ff uit de Usermanual, het zijn weer geen standaard FIR en CIR modules, kijk maar:
Afbeeldingslocatie: http://www.endoria.net/upload/index.php/2681571551
  • Hermanvh
  • Laatst online: 17-03 10:14
Hermanvh
webOS fan, hacker, developer
Op dinsdag 21 mei 2002 15:59 schreef almightyarjen het volgende:
29
30
31
32
33
34
35
36
37
38
39
Ik:
Tommy,
Your sincerely,
Arjen
Zij:
Ik:
Zij:
Ik:
Zij:
Als je het pakketje als 'gift'=cadeau laat versturen dan komen er waarschijnlijk geen invoerrechten bij :)
webOS all the way!
  • almightyarjen
almightyarjen
O ja, CIR had je ook nog. CIR is voor TV-afstandsbedieningen enzo. Ik zal daar morgen ook eens het een en ander over vragen. Waarschijnlijk zijn dat speciale modules voor dit bord, die alleen bij VIA te verkrijgen zijn. Tegen een VIA prijs natuurlijk. ;)
  • Bart_Banaan
Bart_Banaan
Op zondag 26 mei 2002 16:26 schreef almightyarjen het volgende:
Als ze te krijgen zijn, zijn ze ook te maken ;)
  • almightyarjen
almightyarjen
that's the spirit! Maar FIR kan je vergeten: dat werkt met IRQ's DMA en al die zooi meer. Controllers hiervoor hebben allemaal meer dan 80 aansluitingen, da's niet leuk meer. CIR is misschien nog wel mogelijk. Ff afwachten wat VIA zegt...
Ziet er allemaal mooi uit. VIA prijs maak ik me ook niet zoveel zorgen over, als ze zoveel shit voor 140 euro verkopen, moet die CIR unit minder kosten dan een kinder bueno
  • Spyro_the_Dragon
Op zondag 26 mei 2002 18:00 schreef Hermanator het volgende:
mmmmmm ik help het je hopen......
Vaak zijn die extra accesoires juist extra duur (vergelijk het met xbox hardware en de spellen ervoor.....) omdat ze
met veel kleinere seriegrootte's werken in productie en distributie
  • almightyarjen
almightyarjen
Had ff een mail gestuurd naar Space Promotion (riser 3), omdat het vrij lang duurde, dit was het antwoord:
Goedenavond,
Ik heb beloofd nog met u contact op te nemen. Ik heb geen precieze info op
dit moment, want ik probeer na te gaan of de riser die ik op het oog heb
volledig compatible is met het VIA Eden IPX mainboard. Ik zal maandag
opnieuw contact met u opnemen over de volledige gegevens (specificaties en
prijs).
ff wachten op maandag dus... Ennuh, het is maandag 8-)
  • almightyarjen
almightyarjen
"we zullen maandag mailen" Hmmz, we zien het! :( Ff wachten dus... :( I want to know! :{
  • almightyarjen
almightyarjen
Ik had maandag een mail gestuurd naar VIA, heb net reply gehad. Dit was dat mailtje waar ik in vroeg over de PCI riser, IrDA en cooling. Komt-ie (het antwoord van VIA is in vet):
Goodday,
I have a few questuions regarding the VIA Epia mainboard
( http://www.viavpsd.com/products/epia_mini_itx_spec.jsp ).
My first question is about expanding the PCI-slot with a PCI Riser Card. The manual of the board explaines that the useage of a PCI Riser Card requires a special kind of PCI Riser Card, in my opinion, probably specifically designed for the VIA Epia board. My question is: is there a (special kindof) PCI Riser Card for sale for the Epia mainboard? And if so, where can I buy these cards and do you know how much they approximately will cost? I also read in the presentation sheet
(http://www.viavpsd.com/products/presentations/EPIA_launch_presentation.pdf ) that there is also a PCI Riser Card available with MPEG-2 decoder. Does this PCI Riser Card fit on the Epia? And if so, where can I buy it?
[Marlo] VPSD decided to build and sell PCI Riser Card separately. PCI Riser Card will be available with in couple weeks and try to ask this information to whom did you bought your EPIA motherboards. We don't have a PCI Riser Card with MPEG II Decoder. What was mentioned in the Presentation is that it will be connected to the Video In Connector.
My second question is about the usage of IrDA on the Epia board. The manual describes there are two connectors for the usage of Infrared: FIR (connector J5) and CIR (connector J6). It also describes that there is a special FIR or CIR module needed to get it work. My questions here are also: are there special modules for FIR and CIR communication for sale? And if so, where can I buy these modules and do you know how much they approximately will cost?
[Marlo] Unfornately we will not build this module our self but there is a third party who will produce it. For the CIR module you can contact; Forward (www.fwd.com.tw) Mr. Joe Chiang, Email: chiangtl@fwd.com.tw, Tel. 886-22673-0411 ext. 264
My third (and final) question is about the passive cooling of the Processor. I have the Epia board with a VIA C3 800 MHz processor. I want to cool it without a fan, but I can't find a proper coolingblock. The processor is built in a EBGA case and is mounted directly onto the mainboard. I have found some passive cooling elements for the C3-800 but they are all designed for usage in combination with a socket A/370 socket. So these elements will not fit on the EBGA case. Here my question (also) is: Are there passive cooling elements for sale for the C3-800 for a EBGA package? If so, which company does manufacture these elements? I have found one myself: http://www.zalman.co.kr/english/product/nb32j.htm I think this element will fit, but I'm not sure it is capable of cooling the C3 sufficiently. Can you tell me that also?
[Marlo]Currently we don't have any approved passive cooler for our EPIA800 motherboard. We try to maintain that the tallest component in the motherboard is the LPT Port so use an active cooler. Aside from that there's some mechanical limitation due to some component close to the CPU. If you want to use passive cooler then we suggest that you consider using our EPIA5000 since that is using a passive cooler.
Even een samenvatting dus: voor de risers moeten we dus contact opnemen met CTW, maar die risers zullen pas over een paar weken te verkrijgen zijn ( :( ) dus ik stel voor om nog even te wachten met het contact opnemen met CTW. En een riser emt MPEG-2 bestaat dus ook niet. Voor het IrDA gebruik worden er dus geen SIR en FIR modules gemaakt, maar CIR wordt wel gemaakt door een ander bedrijf. Er staat dus een contactadres hiervoor bij. Ik heb hier zelf geen belangstelling voor. En ja, wat ze zeggen over de koeler is duidelijk en verwacht: dat wordt dus gewoon tweaken, modden enz. :)
Er is misschien nog een riser 4 in de aantocht, maar daar kan ik op dit moment nog niets over zeggen. Ff wachten op een email... :)
  • Venkmen
Venkmen
E-mail conversatie met huawie voor een heatsink
[e-mail mode]
TO:'huawei@hua-wei.com.tw'
Goodday,
I am interested in a heatsink passive for the VIA C3 800 Mhz
processor wich is built in a EBGA package. This processor
is mounted on the VIA EPIA board. (Click here for the link
to VIA). I would like to know if you can deliver such a
passive heatsink and how I can get it in the Netherlands
(Europe). Waiting for your reply.
Yours sincerely,
alias venkmen
Dear Sir,
Goodday.
We have the heatsink you need. The sink you need have to
combine the fan for passive of VIA C3 800Mhz processor. I
will send you the photo by e-mail tomorrow.
Sincerely yours,
Dear Sir,
Attachment is the photo of ITEM HW-h01 for heatsink you
asked. It's combine by Al. heatsink, copper spring snap
pivot, 40x40x7mm fan/1 ball/6,000RPM, The best pad of X-23-
7762/Bulk Thermal Conductivity more than 4 W/mk.
The price should be USD 2.5(FOB Taiwan) per set.
Please feel free to contact me if you need sample or for
other questions.
Sincerely yours,
zit een plaatje bij maar ja endoria ligt nog steeds plat :( dan maar een link
TO:tseng@hua-wei.com.tw
Goodday,
Thank you for your quick resoponse. Unfortunately, it is
not exactly what I am looking for. I am looking for a
heatsink without a fan, but the mountoints of this heatsink
are correct.Can I use this heatsink also when I remove the
fan for a VIA C3 800 MHz?
Your sincerely,
alias venkmen
Dear Sir,
You can use this item without the fan and I think it's
should be no problem for the VIA C3 800 MHz. But I have
no sample for make photo to you now. So..use same item,
same solution set, the price will be USD 1.5 FOB
Taiwan/minimum order:1,000 pcs.
I think may be you need some samples for test. It's better
to make sure of the performance on your system. Just feel
free to tell me if you need. But due to our company's
regulation. I have to charge you the sample price and
freight but it will be return in formal order.
Thanks,
Goodday,
Thank you for your response, but I do not need a 1000
pieces, I was thinking about an amount of 50 pieces (MAX).
Maby I can buy this in Europe by at a reseller in Europe
(The Netherlands). If so, do you have an adress for me?
Dear Sir,
Good day.
We have no agent in Europe now. So you could not get our
items in your place. But I would like to sell you the item
you need. Only you have to cover the freight so it' s can
deliver by UPS or other express. Just let me know if you
need our item. In addition, because it's the first deal
with you, we hope you can send me the payment by T/T after
we make the sales-contraction if you will deal with us.
Thanks..
Sincerely your,
Martin Tseng
[/e-mail mode]
conclusie: als je de van die nu op de C3 zit af haalt moet hij het ook nog wel houden denk ik wan deze heatsink is niet veel groter. en ik denk dat die zalman helemaal wel wil.!!! ;)
[Dyslexie is my ID]
|Specs|
  • Spyro_the_Dragon
[topic=508935]
  • Venkmen
Venkmen
Op woensdag 29 mei 2002 11:31 schreef Spyro_the_Dragon het volgende:
[topic=508935]
OOOOOOOOOO ik wis niet dat daar al een draatje voor was zal ik deze daar ok ff bij zetten.
[Dyslexie is my ID]
|Specs|
  • Spyro_the_Dragon
Op woensdag 29 mei 2002 11:40 schreef Venkmen het volgende:
Dat draadje is er ook pas 10 minuten :)
  • Venkmen
Venkmen
Op woensdag 29 mei 2002 11:41 schreef Spyro_the_Dragon het volgende:
staat nu ook op andere draatdje
[Dyslexie is my ID]
|Specs|
Pagina: 1 2 Laatste
