@ErikA12
Wil je thema's verwijderen en je ziet ze niet meer bij toepassings beheer staan, volg dan deze stappen.
1. Connect your device to your PC in ‘Mass storage’ mode - or insert your Mini/micro SD card into a card reader and connect it to your PC.
2. Once your PC recognizes your card a new drive will appear under ‘My Computer’. Open it, and browse to \private\10207114\import.
3. Browse through each of the folders in this directory to find the theme you would like to remove. The MBM, MIF, and SKN files in each folder should each be named after the theme - so if you want to remove a theme called “MyTheme”, look for “MyTheme.mbm” etc
*Note that you may see some MBM/MIF/SKN files named simply “themepackage.mbm” etc. In this case, simply open the SKN file in Notepad and you will see the actual theme name in the first few lines of text. Here is an example:
In the example you can see that the actual name of the theme is N80 Simplified v2 (created by teddymustupo).
4. Once you’ve found the folder containing the theme files you’d like to remove, simply delete the contents of the folder (don’t delete the folder itself).
Now put your card back in your phone you’ll notice that the theme is no longer listed under themes and you’ve freed up some space on your memory card.
Note that in newer devices, theme folders/files are located in two different directories: [!:\private\10207114\import] and [!:\resource\skins] - delete the like-named folders from each directory to remove themes.
@Johantjuuh
Heb zelf ff de mapjes vd 2gb kaart overgezet op de 8gb (voor de zekerheid).
Ik ben zeer tevreden over Sygic en Navigon Mobile Navigator.
-Sygic is een nieuwkomer en kan alleen maar beter worden. Soms sneller en precieser (route) dan mijn TT Go 730.
-Met Navigon kun je niet naadloos navigeren. Wel een stukje over de grens (Duitsland en Noord Frankrijk als je de Benelux Map hebt).
-Garmin is grafisch wat minder maar zekers een goede optie.
-R66 vind ik persoonlijk 1 vd mindere nav software ivm de bovenste software.
-Nokia Maps zit er wel eens vaak naast als je bv op een parallelweg rijd.
Anders googel eens op meer en uitgebreide ervaringen vd verschillende Navigatie applicaties.
