Hoofdcategorieën
Reg. datum: 01 januari 2008
quote:
RoD schreef op dinsdag 22 april 2008 @ 16:27:
Linkje zou niet misstaan ;) Zie http://www.anythingbutipod.com/forum/showthread.php?t=28951 voor een directe link + changelog (vertaald). De lijst met fixes en features ziet er goed uit. Lijkt me een nuttige firmware.
Leek me beetje egoistisch om naar mijn eigen post op een andere forum te plaatsen :P
Is via Samsung-site nu te downloaden:
GUI: http://www.samsung.com/nl...u_digitalaudioplayers.sec
3e Firmware: http://www.samsung.com/nl...u_digitalaudioplayers.sec
Wat zegt Samsung over deze firmware:
*YP-P2 3rd WAVE*
YP-P2 firmware Ver 4.13 for MTP (2008.04.23)
1. Touch Games - Three fun games (PowWow, Bubble Smile, and Jigsaw Puzzle) are provided.
2. FM Radio recording support - FM broadcast can be recorded as MP3.
3. Repeat A-B - Select a section of music and play it repeatedly.
4. Play Speed Control - Control the music play speed.
5. File Deletion support - Delete files on your P2 without having to connect to a PC.
6. EmoTure 1.5 - EmoTure is further improved with features like horizontal viewing of text.
[Cautions before FW installaiton]
1. Please backup the important files before FW update. During FW update, the files could be formatted.
In case of DRM files, the backuped DRM files could not be played.
2. If you power off the set during FW update, the problem could be happened.
Please charge fully the battery of the set before FW update.
* 4th Wave (May,08)
1. GUI theme tool on SMS
2. DNSe set to playlist on SMS & file type user DNSe on device
3. Worldwide major 24 city subway maps with simple information
4. Bluetooth 1:1 gaming(P2, T9, S5, T10 compatible)
- Finger shooting game, Chinese Othello
5. Voice Recording
6. Password
Reg. datum: 11 januari 2008
Hee,
Vond hier iets over de YP-PB2
in het engels
Samsung's done pretty well for itself with its YP-P2 PMP, and it now looks to be set to bust out yet another upgrade to the player, although you likely won't be seeing this one outside of Korea. Helping to keep it close to Samsung's home base is the addition of not only a DAB radio tuner but, apparently, a DVB-T mobile TV tuner as well. Other than those two notable additions, however, the device appears to be unchanged from its previous incarnation, with it boasting the same 3-inch WQVGA display, built-in Bluetooth, black or white color options, and 2GB, 4GB, or 8GB capacity as before (no word on a 16GB model). There's also no word on a price or release date, but you can pretty safely expect to pay a tidy premium over the tuner-less models.
http://cfs6.tistory.com/upload_control/download.blog?fhandle=YmxvZzgwOTRAZnM2LnRpc3RvcnkuY29tOi9hdHRhY2gvMC8wNzAwMDAwMDAwMTQuanBn
Samsung YP-PB2
-Capacity : 4/8/16GB
-Color : Black
-Display : 3" WQVGA(16:9) TFT-LCD
-Bluetooth 2.0
-Battery life : Music 35hrs(YP-P2) → 46hrs / Video 5hrs(YP-P2) → 7hrs / DMB 5hrs
-Size : 52 x 100 x 11.95mm(YP-P2 : 52 x 100 x 9.9mm)
-Weight : 97g(YP-P2 : 85g)
-mDNle(new) : mobile Digital Natural Image Engine
-Silver line design(new)
-DMB/DAB(new)
samsung en zijn ideetjes :P
Bron: Engadget
Die zal waarschijnlijk in Korea te kopen zijn ;)
quote:
Huy schreef op woensdag 23 april 2008 @ 15:07:
Yup
Heeft iemand met de nieuwste firmware (3e) ook problemen bij albums? Ik kan niet meer 'scrollen', want hij loopt daar direct vast.
quote:
Huy schreef op woensdag 23 april 2008 @ 19:29:
Hmmm zal even proberen !!!!...........
nope helemaal geen problemen!
misschien eventjes opnieuw updaten ?
Huis, Tuin en Keuken Turk
Nattuurlijk zijn video's ook leuk op zo'n P2, ik heb niet zo'n ding maar ben wel geintresserd, dus is de vraag nu of deze website de video's in een juiste codec convertereerd zodat ik ze op de p2 kan afspelen:
http://vixy.net/
Reg. datum: 08 december 2007
quote:
lasharor schreef op donderdag 24 april 2008 @ 22:42:
http://vixy.net/
nee je zult de videos nog naar svi formaat moeten converteren...
Ik lees ook mee dat als je gewoon de .avi veranderd in .svi het bestand ook werkt? Hoe zit dat nou eigenlijk...
Je moet nog steeds een avi omzetten naar een andere avi met alleen Xvid. Daarna kan je de extensie veranderen in svi.
niet zo moeilijk doen...
gewoon een wmv bestand, open SMS, en die convert hem voor je naar .svi
het is zo simpel
niet zo moeilijk lopen zoeken terwijl het heel makkelijk kan...
SMS is waarschijnlijk niet zo snel als bijv. SUPER
En het is imo handig om gewoon via die website zo youtube filmpjes te kunne ndownloadne
Door: RoD
Moderator PMD / TCM / PowerMod / Nieuwsposter
Reg. datum: 14 september 2004
quote:
lasharor schreef op vrijdag 25 april 2008 @ 07:32:
.svi is afaik een Mpeg4-container, vrij vergelijkbaar met .avi. Hoe het precies zit weet ik overigens niet.
Ik lees trouwens op Dapreview dat er geruchten zijn over een vierde Bluewave firmware..
quote:
Samsungs latest update keeps them firmly on track as one of the most impressive companies as firmware updates go and now that the third Bluewave is out of the way it's time to look forward to the forth one - rumour has it it will add subway maps, voice recording and more games - This is one DAP that thoroughly deserves to be in our top picks.
Dat hun firmware-upgrades goed zijn, staat wel als een paal boven water :)
Heeft iemand een idee hoe ik aan een 16GB-versie moet komen? Hij is officieel alleen verkrijgbaar bij BestBuy Canada, maar er moet toch een manier zijn om een exemplaar naar NL te krijgen?
"I'm not a cynic. I wake up every morning hoping to find an honest man." - [Jack McCoy, Law & Order]
Door: RoD
Dan heb je het over import, aangezien het ding hier nog niet te krijgen is. Dat hoort hier niet thuis, maar eventuele perikelen mag je in het Shopping Forum posten :Y)
Voor degene die afgelopen maand deze MP3-speler heeft gekocht: je kan 20 euro terugkrijgen van Samsung.
http://www.samsung.com/nl/actie/mpfreedom/popup.htm
Ik neem aan dat je de sticker met de streepjescode eraf moet halen? Of moet je een kopie ervan maken?
Reg. datum: 19 februari 2004
quote:
Huy schreef op dinsdag 29 april 2008 @ 19:32:
Volgens mij ook ;).
Bedenk ook dat internetaankopen uitgesloten zijn van deelname op een aantal 'bij samsung aangesloten webshops' na.
Ik heb hem bij mp3shop gekocht, echter in BE. Dus ik vrees dat ik uit de boot val :(.
quote:
Jormungandr schreef op zaterdag 03 mei 2008 @ 17:24:
Deze actie geld ook bij de Belgen ;) Je moet alleen je formuliertje naar een Belgisch adres sturen.
Reg. datum: 31 maart 2008
vraagje, ik hoor iedereen al praten over die nieuwe update met woordenboek en songteksten, maar die functies zitten niet bij mijn update..
Waar zijn die te downloaden? :P
quote:
wouterkuyt schreef op zondag 04 mei 2008 @ 12:01:
Die zijn alleen aanwezig voor de Koreaanse versie. Maar aan het woordenboek heb je toch niets (tenzij je Koreaans wilt gaan leren >:) ). Downloaden.. hier staan wat links.
Door: RoD
Oud.
RoD wijzigde dit bericht 05-05-2008 21:45 (96%)
quote:
RoD schreef op maandag 05 mei 2008 @ 19:32:
Er is nieuws over de 4e Bluewave firmware.
Ik vind het niet erg spannend, maar slecht is het ook zeker niet voor een firmware upgrade.
Allang gepost :P diverse keren zelfs. Mod's lezen niet alle berichten :P
http://gathering.tweakers.net/forum/view_message/29845524
Door: RoD
En ik heb nog wel gezocht om te kijken of dit al gepost was ;(
Reg. datum: 28 maart 2005
Naar heel erg lang wachten.
JAJA
Ik heb em!!
ook direct maar de 16 gb versie, want meer is beter.
Apparaat is echt perfect niks op aan te merken. :9 8)
Alleen vind ik de software nog niet ideaal,
eerst heel wat nummers erop gezet
en nu zie ik dat er artietsen 2/3keer op verschillende manieren op staan
en hoe dit aan te passen is kan ik zo niet zien.
Zodra het nummer erop staat zie je alleen nog de bestandsnaam en word het een grote zooi van bestanden.
Pagina: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 last
VNU Media logo Hosted by True
© 1998 - 2010 Tweakers.net - Alle rechten voorbehouden - Uw Privacy - Algemene Voorwaarden
Uitgever van:
Website van het jaar 2009
