9800SE gemod gekocht of kijk ik verkeerd :S?
  • 144 views sinds 30-01-2008
hey, ik heb de 9800SE gekocht op de computerbeurs vandaag, nu wou ik deze gaan softmodde en wat blijkt.. alle 8 pipelines zijn al geactiveerd?!? :S
$ffffffffff ---------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : Intel i845 Brookdale-G
$0400000001 Vendor ID : 8086 (Intel)
$0400000002 Device ID : 2560
$0400000003 AGP bus : revision 2.0
$0400000004 AGP status : disabled
$ffffffffff Display adapter information
$0000000000 Description : RADEON 9800 PRO
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 4e48
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 2.0
$0000000005 AGP status : disabled
$0000000009 Base address 0 : f0000000 (memory range)
$000000000a Base address 1 : 0000ec00 (I/O range)
$000000000b Base address 2 : ff8f0000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff ATI specific display adapter information
$0900000000 Graphics core : R350 (8x1)
$0900000002 Memory bus : 128-bit
$0900000001 Memory type : DDR SGRAM / SDRAM
$0900000003 Memory amount : 256MB
$0900000004 Core clock : 378.000MHz
$0900000005 Memory clock : 202.500MHz (405.000MHz effective)
$0900000006 Reference clock : 27.000MHz
$ffffffffff Memory timings
$0900000100 WR latency : 1.0
$0900000101 CAS latency : 3
$0900000102 CMD latency : 0.0
$0900000103 STR latency : 1.5
$0900000110 TRCDRD,RAS to CAS read : 7
$0900000111 TRCDWR,RAS to CAS write : 2
$0900000112 TRP ,Row precharge : 7
$0900000113 TRAS ,Row active : 12
$0900000114 TRRD ,Row active to row active command : 2
$0900000115 TR2W ,Read to write turnaround : 6
$0900000116 TWR ,Write recovery : 3
$0900000117 TW2R ,Write to read turnaround : 2
$0900000118 TW2R ,Write to read turnaround/same bnk : 3
$0900000119 TR2R ,Read to read turnaround : 2
kijk ik nou gewoon verkeerd .. volgens mij staat daar toch 8x1 pipelines open?
de videokaart zat nog gewoon 100% verpakt in het plastic gesmolten.. enig idee wat hier aan de hand kan zijn??
  • St!nG
  • Laatst online: 19-09 21:40
draai , 3dmark03/05 dan weet je of je een pro hebt , anders is het wel vet :D
  • Palomar
memory bus staat wel op 128 bit en das geloof ik niet zo goed (je hebt ook SE's met 256 bit).
  • Orion666
  • Laatst online: 17-05 16:35
Dat zijn die nieuwere 9800SE's.
Die hebben 8x1 en 128bit, je kunt hem dus niet modden.
De modbare hebben 4x1 256bit standaard...
  • qrazi
  • Laatst online: 22:48
tsa, enige oplossing: geheugen zo hoog mogelijk klokken.....
AMD Phenom II X2 555@ X4 B55, 4GB DDR3-1333 OCZ Gold, MSI 870A-G54, Radeon HD 7770 512 MB
  • Outerspace
  • Laatst online: 00:52
Outerspace
Admin General Chat
waarom zie ik dit staan:
Device ID : 4e48
Duid het dan al niet op een 9800 pro :)
Ik neem aan dat je dus een 9800 pro hebt gekocht ipv een 9800 SE
Kijk hier
[ Voor 25% gewijzigd door Outerspace op 25-10-2004 09:59 ]
Wauw, een sig!
De clocksnelheid van het geheugen is wel wat laag voor een pro. Die van de core klopt wel redelijk. Ik denk dat het geen pro is. Het geheugen van een pro hoort op ongeveer 340 (680) te lopen
qrazi schreef op 25 oktober 2004 @ 08:49:
zijn daar topics voor?(search geeft weinig bruikbaars , allemaal over softmod en biosflash ) en waarom geeft hij dan inderdaad :
bij de propertys van dat ding..
  • Roamor
Verwijderd schreef op 25 oktober 2004 @ 13:17:
Daarvoor kun je het beste dit doornemen: Frequently Asked Questions DOC (laatste update 2-06-03) :)
[ Voor 6% gewijzigd door Roamor op 25-10-2004 13:20 ]
hm ik bedoelde meer specifiek gericht op de 9800SE :p of het twijfel plankie dat ik hier dan heb :p
srry had iets beter moten kijken in de search :)
VGA overclocking guide, The basics <-- voor geinteresseerde
[ Voor 46% gewijzigd door Verwijderd op 25-10-2004 13:55 ]
  • Roamor
Verwijderd schreef op 25 oktober 2004 @ 13:52:
Heb je gelijk in, maar het principe blijft natuurlijk gelijk; voldoende koeling, kleine stapjes enz ;)
das zeker waar :p de basics zijn dr inderdaag goed uit te halen, maar voor een videokaart apart is het toch een zo goed als compleet ander verhaal :p
bedankt voor jullie replys :), als nog iemand mij met zekerheid kan uitleggen of dit de SE gemod is / pro versie / SE nieuw .. graag :D
  • SH4D3H
  • Laatst online: 04-10-2025
Waarschijnlijk een lite versie van de PRO, en ookal is het een SE klopt het dattie PRO aangeeft, het is niet voor niets een 'gebonden' PRO ...
Wel is je geheugen wat laag geklokt :?
  • makje
  • Laatst online: 22-09 12:10
makje
Professioneel prutser
Orion666 schreef op 24 oktober 2004 @ 23:41:
^^ en Palomar have said it all...
9800x3d
Nu jullie het hier over hebben.
Ik heb thuis een sapphire 9800 pro maar die draait dus niet op 380 / 680 maar op 325 / 580
Nu heb ik in het lijstje gekeken en dit blijkt een 9800 te zijn. Ik heb em al ruim een half jaar heb er eigenlijk nooit bij stil gestaan. De puter gaf aan dat er een pro in zat en alles draaide wel goed. Maar ik heb er een hekel aan als ik genept wordt.
Radeon R350 [Radeon 9800 Pro]
(added pro)
dit is wat http://pciids.sourceforge.net/ weergeeft over mijn type..
pro dus?
tot hoever zou dit maximaal overclockbaar zijn ( ik weet dat het uniek is per stuk ), maar ongeveer?
ook, wat houd het in als je tijdens het laden van spellen als FarCry tijdens het laden een of andere videokaart crash krijgt? beeldscherm valt spontaan uit, en na een tijdje ( misschien na afkoelen?? :S ) slaat die weer aan met groene strepen/blokken.. etc, net een gecrashed dos spel :p.. hijs niet overclocked of whatever, gewoon standaard ingeprikt.. enigste wat er anders is is dat ik hem op de voeding heb aangesloten van het diskette station bij gebrek aan zo'n open molex kabel.
ik wou vanmiddag een format gaan proberen maar zou die uberhaupt effect hebben?
[ Voor 65% gewijzigd door Verwijderd op 26-10-2004 09:47 ]
  • Initial G
  • Laatst online: 22-09 15:41
Verwijderd schreef op 26 oktober 2004 @ 09:37:
(added pro)
pro dus?
kijk eens even hoe erg je voltages m.n. op de 5V en 12V veranderd zijn, misschien is je voeding te zwak. Maar eigenlijk is dit een zoekvraag.
hm sorry nog nooit gechecked hoe het met mijn voeding zat, hoe meet ik de verschilllen op jou genoemde 5/12 V? ( nooit gedaan, newb derin dus :P )
  • Initial G
in het bios kun je dat wel uitlezen, beter is het om dat met een motherboard monitor te doen, tijdens een spel. Die videokaart neemt nogal veel van de 5V, die mag niet meer dan zo'n 5-10% dalen, anders krijg je zulke dingen
  • NoepZor
tis volgens mij ook een lite pro met 128bits mem, die zijn ongeveer 170/180 euro, terwijl een 9800se 140/150 euro doet.
Tis jammer dat 128bit geheugen daar de 256bit se variant vrijwel altijd sneller is.
Tis inderdaad niet echt een se daar de core daar te hoog voor loopt en het memory te laag.
  • Volk
  • Laatst online: 20-09 00:05
Kan aan mij liggen, mar ik wil het tocg even kwijt:
128 bit geheugen voor een Radeon 9800 Pro?
en 256 MB geheugen voor een SE icm een 128bit bus heb ik ook nog niet eerder gezien, dus het lijkt mij dat die test niet helemaal goed is oid.
  • Initial G
rfolkers schreef op 27 oktober 2004 @ 11:12:
Persoonlijk vind ik die 8pipelines helemaal niet zo gek, geeft toch echte power aan zo'n kaart. Dat ie gekreupeld wordt door het geheugen lijkt me duidelijk, alleen dat loopt ook nog eens op 200MHz, dat moet volgens mij zeker minstens 270 kunnen trekken tenzij he meer dan 4ns is. Daarmee komt ie qua performance dicht bij een 9600pro ofzo
NoepZor schreef op 26 oktober 2004 @ 22:54:
was 139 euro..
[ Voor 4% gewijzigd door Verwijderd op 27-10-2004 11:49 ]
hm probleem met spanning opmeten, dell moederbord kan geen Voltages aflezen??
geen van de programma's aangegeven kan de voltages aflezen..?
enig idee hoe dit op te lossen valt?
