welke SDRAM!!
  • 106 views sinds 30-01-2008
heej,
Weet iemand misschien welke ram ik moet nemen heb totaal geen verstand van computers en er zijn er zoveel.
heb wel gelezen dat het een SDRAM moet zijn ik zocht er een van 1 GIG
weet iemand een g0ede die bij mijn moederbord goed werkt uit de pricewatch?
alvast bedankt!! })
specificaties MOEDERBORD! <<
CPU
• Supports Intel® Pentium® 4 processors in the 478 pin package.
• Supports up to 2.6GHz
Chipset
• SIS® 645/650 HMAL/IGUI HMAL Chipset
- High performance host interface (400MHz).
- 64 bit performance DDR333 (SiS 645 only)/DDR266/DDR200 memory controller.
- Integrated A.G.P compliant target/66MHz Host-to-PCI bridge.
- High throughput SiS HyperZip connect to SiS 961 HyperZip Media I/O.
- Dedicated isochronous response queue.
- High performance 2D/3D and video accelerator. (SiS650 only)
- Complete TV-Out/Digital Flat Panel solution and MPEG-2/1 video decoder. (SiS650 only)
• SIS® 961 HyperZip Media I/O Chipset
- High performance HyperZip connect to SiS series NB.
- Integrated multi-threaded I/O link ensures concurrency of up/down data transfer.
- Integrated HyperZip connect to PCI bridge.
- Dual IDE Master/Slave controller.
- Integrated USB host controller.
- Integrated audio controller with AC97 interface.
- Advanced power management and PC2001 compliance.
- Integrated RTC and DMA interrupt and keyboard controller.
- Integrated PCI to LPC bridge.
FSB
• Supports 400MHz FSB
Main Memory
• Supports four memory banks using two 184pin unbuffered DDR DIMM.
• Supports up to 2GB memory size.
• Supports 2.5v DDR SDRAM.
• NO support ECC Function.
Slots
• One AGP (Accelerated Graphics Port) 4X slot.
• Three PCI 2.2 32-bit PCI bus slots (support 3.3V/5V PCI bus interface).
• One CNR (Communication Network Riser) slot.
On-Board IDE
• An IDE controller on the SiS961 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100/66/33 operation modes.
• Can connect up to four IDE devices.
Audio
• AC'97 link controller integrated in SiS 961.
• 2-channel software audio codec RealTek ALC201A/202A.
- Compliance with AC97 v2.2 Spec.
- Meet PC2001 audio performance requirement.
Video
• Built-in Real 256 bit 2D/3D graphics engine (SiS® 650 only)
On-Board Peripherals
• On-Board Peripherals include:
- 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes.
- 2 serial ports (COM A + COM B).
- 1 parallel port supports SPP/EPP/ECP mode.
- 4 USB ports (Rear x 2/ Front x 2).
- 1 IrDA connector for SIR.
- 1 RJ-45 LAN jack (Optional).
- 1 audio/game port.
- 1 VGA port (SiS 650 only).
BIOS
• 2MB Award/AMI BIOS with PnP, ACPI, SMBIOS 2.3, Green and Boot Block.
• Provides DMI2.0, WfM2.0, WOL, WOR, chassis intrusion, and SMBus for system management.
tik je moederbord in bij google en zoek het zelf even op ?
  • the_stickie
  • Laatst online: 14-09-2025
DDR333 SD-RAM
  • Palomar
zo te zien (heb niet alles uitvoerig doorgelezen) gewoon DDR sdram, oftewel wat bij elke pc zaak wel te koop is. Haal dus gewoon 2 reepjes 512MB DDR PC3200 dan zit het wel goed... of 1 van 1GB als dat het perse moet zijn, maar 1GB modules zijn wat duurder/zeldzamer dan 512MB modules, vandaar.
  • Xander
  • Laatst online: 09:55
Lijkt het je dan niet slimmer om er ook DDR400 in te zetten? (PC3200 that is...)
Misschien loopt zijn CPU op een lagere FSB, maar dan zul je toch eerst moeten weten wat voor CPU hij heeft voordat je zo'n uitspraak doet...
XanderH schreef op 25 augustus 2004 @ 18:14:
:? Buiten het feit dat het qua prijs niet echt uitmaakt volgens mij, zie ik het nut van DDR400 in een moederbord, wat dat niet ondersteunt, niet.
  • rewind.
  • Laatst online: 17-10 19:27
uhm FSB 400 wil niet zeggen dat ze geheugenslotjes dat ook aankan staat duidelijk 333Mhz DDR
Ofwel, DDR333 als je een SiS 645 hebt, of anders DDR266 (maar je kunt ook geheugen op een lagere snelheid laten draaien)
Pricewatch: 333 MHz DDR
Pricewatch: PC2700
En als je 100% zekerheid wilt dat het op jouw bordje gaat werken dan neem je een kijkje bij je moederbord fabrikant voor info over welke RAM stripjes er allemaal getest zijn op jouw bordje.
Zie ook PMG Faq: Welk merk geheugen moet ik nemen? en de overige uitleg in diezelfde Faq.
Kortom, maak gebruik van de naslagwerken (Faq, mobofabrikant, Pricewatch etc) alvorens een topic te openen. Zie ook de forumFaq voor wat wij verwachten op het forum ;)
[ Voor 11% gewijzigd door Verwijderd op 25-08-2004 18:29 ]
