Asus A7V880 ervaringen? + info
Pagina: 1 2 Laatste
  • 1.154 views sinds 30-01-2008
  • Mister_X
  • Laatst online: 16-09 11:38
Afbeeldingslocatie: http://nl.asus.com/products/mb/socketa/a7v880/a7v880_m.jpg
CPU Socket A for AMD Athlon XP
Thoroughbred / Barton Core support
Chipset VIA KT880
VIA VT8237
Front Side Bus 400/333/266/200 MHz
Geheugen - Dual Channel Memory Architecture - 4 x 184-pin DIMM Sockets support max. 4GB PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
Uitbreidingssloten 1 x AGP 8X
5 x PCI
1 x ASUS Wi-Fi slot for Wireless LAN upgrade
Opslag 2 x UltraDMA 133/100/66/33
2 x Serial ATA with RAID 0, 1 function
Audio ADI SoundMAX 6-channel audio CODEC
Support S/PDIF out Interface
AI NET - Marvell Gigabit LAN controller supporting 10/100/1000 BASE-T Ethernet - Virtual Cable Tester Net-Diagnosing Utility
USB Max. 8 USB 2.0 ports
Extreem overklokken - ASUS JumperFree
- ASUS C.P.R.(CPU Parameter Recall)
- CPU and Memory voltage adjustable
- SFS (Stepless Frequency Selection) at 1MHz increment
- Adjustable FSB/DDR ratio.
Speciale eigenschappen - Wake on Ring, Lan, USB, Keyboard & Mouse
- STR (Suspend-to-RAM)
- STD (Suspend-to-Disk)
- ASUS C.O.P. (CPU Overheating Protection)
- ASUS C.P.R. (CPU Parameter Recall)
- ASUS MyLogo
- ASUS EZ Flash
- ASUS Q-FAN
- ASUS CrashFree BIOS 2
- ASUS Instant Music~Lite
Achterpaneel I/O poorten 1 x Parallel
1 x Serieel
1 x PS/2 Keyboard
1 x PS/2 Muis
1 x Audio I/O
1 x SPDIF out
1 x RJ45
4 x USB 2.0
Interne I/O connectoren - 2 x USB 2.0 connector / ondersteuning voor 4 USB 2.0 poorten
- CPU / Chassis FAN connectoren
- Chassis Intrusion
- 20-pin ATX stroomconnector
- S/PDIF out interface
- CD/AUX audio in
- Game/MIDI poort connector
- 20 Pin panel connector
- Front panel Audio connector
BIOS eigenschappen 2Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, CrashFree BIOS 2, C.P.R., MyLogo
Industrie standaard PCI 2.2, USB 2.0
Beheer WfM 2.0,DMI 2.0,WOL by PME,WOR by PME
Stroomvereisten ATX voeding
Ondersteunings-CD - Drivers
- ASUS PC Probe
- ASUS LiveUpdate toepassing
- Trend Micro PC-cillin 2002 anti-virus software (OEM version)
Accessoires Gebruikershandleiding
1 x UltraDMA 133/100/66 kabel
2 x Serial ATA kabel
1 x FDD kabel
I/O shield
Form Factor ATX Form Factor 12"x 9.6"(30.5 cm x 24.5 cm)
Deze wil ik aanschaffen ter vervaning van me ga-7n400 pro2. Vooral omdat ik een leech koeler heb die niet op me giga-byte mobo past, ik weet dat de nforce chipsets een beetje beter presteren, maar op zich lijkt me dit bord o.k. (heeft alles wat ik wil).
Wie heeft dit bord ook en wat is zijn/haar ervaring ermee?
(heb hem al besteld, hoop hem soon in huis te hebben).
Reden waarom deze:
Weer eens wat anders dan nforce chipsets, ben benieuwd wat deze chipset brengt, is eigenlijk niets anders dan een kt600 chipset + dual channel mogelijkheid, ben zeer benieuwd!
[ Voor 6% gewijzigd door Mister_X op 26-07-2004 20:47 ]
  • i-beast-a
  • Laatst online: 21-08 22:01
Yep, ik heb dit bord een week of 4 draaien. (volgens mij was ik een van de eersten :-) )
Mijn 2600XP processor draait er perfect op.
De frontsidebus van 166 naar 211 gezet en gaan met die banaan!! Helemaal stabiel. Multiplier staat op orginele stand (=11.5)
Alleen de onboard audio is bij mij een drama.
Als ik er een pci soundcard bij stop dan werkt de onboard niet meer.
Vanalles geprobeerd....
Ook is de center/bass uitgang op een veel te laag nivo en zitten er steeds van die 'statische' tikken in het geluid.
Maar verder werkt het bord perfect en stabiel!
  • Final Frontier
  • Laatst online: 01-02 16:16
Een tijdje geleden ook dit bordje aangeschaft. Ik wacht nog op geheugen, maar dan ga ik ook aan de gang. Ik las ergens over die problemen met de on-board sound, dat het met de BIOS te maken had. Welke versie heb je erop ? 1.004 is officeel uit.
Bron: http://forums.pcper.com/s...php?t=331846&page=1&pp=15
PS ik heb een XP-M 2500+ en 512 Mb Corsair 3200XLPT
"Commercie kills the scene" - I-f
  • Mister_X
wow, kan echt niet wachten! Tenminste weer eens een plank die niet zo origineel is (kt880 chipset, wie heeft dat nou? :)). Krijg hem morgen op me werk met de post. Zaterdag kan ik hem pas inbouwen. De onderdelen komen uit me huidige pc, amd 2500 (doet nu 2315mhz) 2x 512mb corsair value (2.5-3-3-11). 9800 pro@xt. En me soundblaster live gaat er weer in, dus onboard geluid heb ik niet nodig. Voor de rest me nieuwe cooler, sp-97 met 120mm fan! (de hoofdreden waarom ik dit bord kocht, me huidige bord heeft geen gaten in het moederbord, deze wel).
  • Final Frontier
Ben benieuwd hoe jou ervaringen zullen zijn met die ATI videokaart. Het schijnt een probleem te zijn, als je de FSB op 200 zet. Zie eerdere link.
Vandaag of morgen krijg ik het geheugen binnen :) , keep you posted.
Voor de koeling heb ik een Thermalright SLK-900A met een 80 mm delta fan op 5700 rpm en een luchtverplaatsing van 80 CFM. Gelukkig heb ik een regelunit om de snelheid (en dus de geluidsoverlast voor de buren :) )aan te passen.
  • Mister_X
Ik lees wat problemen onder linux maar onder windows :?
  • Final Frontier
Kijk hier maar eens : That's exactly what I was talking about. It will NOT do 200 FSB with the ATI video card. Have you read all my posts in this thread from about the fourth page? Op pagina 8.
Hopelijk heb jij die problemen niet, maar ik durf er geen geld op te zetten ;)
  • Mister_X
kick ass boardje, heb tot nu toe nog geen last gehad van ati probs. Draai nu op 215x11 dat deed me giga-byte 7n400 pro2 egt nie he!. :) Ding draait stabiel, heb alleen wat probs gehad met de onboard marvell yukon nic, deze heb ik maar uigeschakeld en er maar een realtek bord in gedaan. Voor de rest mooi ding, jumpertje voor overvolt, dus geen gekut met met pin-mods :P. (doet nu 1.95v).
Heb alleen wel de standaart heatsink van de chipset moeten verwijderen. Aangezien anders me sp-97 er niet op paste, heb er nu me standaart kyro2 koelertje op gedaan, die paste tenminste (klein rond koelertje). Tot nu toe geen probs, me cpu-koeler doet het ook prima, ala 46/48 graden idle, en 50/52graden load! not bad. Helaas alleen dat ik me win2k cd kwijt ben, dus nu heb ik er maar xp opgezet (ben niet zo'n fan van xp). Even nog wat tweaken enzo en dan horen jullie wel meer!
  • Final Frontier
Ik heb geen problemen gehad met die onboard NIC. Gewoon de drivers geinstalleerd via device manager en niet mbv het autorun geneuzel van die asus cd. Mijn mobile 2500+ draait nu op 12,5 x 200 op 1,75 V. Stressed 47 graden, maar niet helemaal prime stable. Op 1,85 V wil die wel 12,5 x 205 draaien, maar dan moet mijn cpufan op vol vermogen. Delta 80 mm 80,16 CFM op 5700 rpm maakt dat ding 56 dB geluid. Iets te veel van het goede. Ik ga proberen of ik Powernow! of zoiets kan activeren.
BTW Ik heb wel de BIOS moeten flashen naar 1004. Er zat 1002 op toen ik hem kocht. Na het updaten herkende het bord de cpu pas (als Sempron) daarvoor was het een XP-MP 8)7
  • Mister_X
Ik heb de beta bios vasn 1004(-02) geflased, deze verhelpt het probleem met de NIC, probleem trad op als je een pci geluidskaart erin zette, en tja, me trouwe sblive gaat nog steeds mee naar nieuwere systemen!
  • Final Frontier
Heb je het onboard geluid ook geprobeert ? Ik kreeg alleen maar mono geluid :( Niet echt handig voor richtingsbepaling in games. Anyway, ik draai nu op 12 x 210 op 1,80 V stabiel, maar het is een beetje warm in de computerkamer en koelen met buitenlucht gaat een beetje moeilijk met dit weer 8)
  • Mister_X
Jij hebt een mobile he, ik niet :) ik draai nu goed stabiel op 215x11 op 1.9 volt, normaal draaide ik 1.95v maar op 1.9 gaat het ook prima en scheelt me wonderbaarlijk gewoon 5graden!! nu is ie 44grade idle en 47/48 stressed, die sp-97 is zeker wel de beste koeler die ik op deze cpu gehad heb (barton 2500, unlocked :)).
Heb hier al de wishperrock 4 en de gigabyte 3d cooler pro op gehad...
Ook heb ik geen problemen meer gevonden met me ati9800 pro (veel mensen hebben daar probs mee). Misschien is het gefixt in die beta bios die ik nu draai. Ook heb ik de cpu-z maker gemailed of ie ondersteuning wilt toevoegen voor de kt880 chipset! En dat gaat ie doen! Dus ik kijk graag uit naar cpu-z 1.24 (laaste is 1.23). Nu kan ik namelijk geen agp/vcore/geheugen settings uitlezen.
  • Final Frontier
Mister_X schreef op 03 augustus 2004 @ 22:15:
Inderdaad, ik heb een mobile 2500+. Tijdelijk even teruggeschroefd naar 12 x 200 @ 1,65 v. Ik heb een Thermalright SLK-900a koelblok met een 80 mm deltafan nu op 3800 rpm. Stressed wordt tie dan 48 graden.
Mooi dat je geen prob hebt met die ati kaart en super dat er in de nieuwe cpu-z ondersteuning komt voor de kt880 chipset, dat miste ik dus ook.
Als het straks wat afgekoeld is buiten, dan ga ik eens kijken waar de limiet ligt met deze cpu/mainbord combo.
  • erikdeperik
  • Laatst online: 25-07-2024
wat is het geheugen voltage van dit bord?
en heeft hij een pci/agp lock danwel 1/7 1/8 divider :?
ik zeg maar zo "zeg maar niks"
  • Mister_X
erikdeprik schreef op 05 augustus 2004 @ 21:27:
2.85v voor ram, tot 1.95/2v voor cpu, divider weet niet, 1/8 is voor 200mhz fsb? dat heeft ie :?
  • erikdeperik
Mister_X schreef op 05 augustus 2004 @ 23:46:
dat heeft ie :?
200fsb heeft een divider 1/6 pci 1/3 agp , immers 200/6=33
als ie een 1/7 divider heeft zou je met een fsb van 233/7=33 lopen
1/8 is dan voor 266
dus voor het overklokken handig :)
maar 2.85 volt ram is voor mij wat te laag ik wil 3.1 minimaal
mijn dfi infinnety heeft 3.3v,maar ik vind het een k*t bordje
overklokt als een tiet maar voor de rest :r
  • erikdeperik
wat is de max fsb op dit boardje
revieuw
http://www.xbitlabs.com/a...ts/display/via-kt880.html
ik zie in de manual wel iets van een agp/pci lock of divider optie
er staat :asyncronous frequency [enable/disable]
in de bios bij cpu instellingen
[ Voor 34% gewijzigd door erikdeperik op 08-08-2004 13:51 ]
  • Mister_X
erikdeprik schreef op 08 augustus 2004 @ 13:32:
revieuw
max fsb valt beetje tegen is 227mhz, hoewel mijn systeem niet verder komt dan 215(x11) :)
  • Final Frontier
revieuw
Max FSB is volgens de BIOS 227, maar boven 215 houdt de SATA controller ermee op, waarschijnlijk omdat de A7V880 geen 1/8 divider heeft.
De asyonchrone frequentie instelling is voor het al dan niet (a)synchroon aansturen van het geheugen tov de cpu. Voor een snel werkend systeem moet deze instelling op disable (dus synchroon)
  • Mister_X
Ik heb geen sata, dus die staat op disabled, ik kom wel hoger dan 215 (216/217) maar dan crashed got-pifast ... :(
  • erikdeperik
Final Frontier schreef op 09 augustus 2004 @ 10:14:
als ik de manual goed lees,stel je je geheugen clock in bij" nordbrige via 880"
settings are[auto] [266mhz] [333mhz] [400mhz]
deze setting staat bij"configer system freq/voltage"
probeer dat eens uit
set hem async en kijk wat je geheugen freq is
je kunt het ook aan de prestaties zien
[ Voor 6% gewijzigd door erikdeperik op 09-08-2004 13:30 ]
  • erikdeperik
Mister_X schreef op 09 augustus 2004 @ 10:34:
wat voor een geheugen heb je>meer volts
je kunt ff probern wat ik hierboven heb geschreven
verder kun je de chipset voltage niet verhogen,goede kans dat op default voltage de chip niet hoger wil :/
  • Mister_X
nee het is de cpu die verrot is hoor :) als ik bv 205x11.5 doe, dan draait ongeveer op zelfde snelheid als 11x215, maar zodra ik hem dan met mp 11.5 verhoog naar bv 207/9 dan kan ik got-pifast ook niet draaien :).
Me voltages staan allemaal max. behalve cpu, die heeft voldoende aan 1.8 (als ik die verhoog naar 1.95 (overvolt jumper), dan wilt ie alsnog niet hoger!!)
  • erikdeperik
Mister_X schreef op 09 augustus 2004 @ 13:58:
en als je je mp op 10 zet?
  • Final Frontier
Kennen jullie deze al ? De Barton calculator :
http://www.bartoncalc.tk/
Rekent uit wat voor een processorrating je hebt bij gegeven processorsnelheid en FSB.
  • Mister_X
erikdeprik schreef op 09 augustus 2004 @ 17:52:
zal morgen eens proberen, me 7n400 pro2 ging tot 220 goed (cas 2.5-4-4-11).
  • Mister_X
Beters, doe nu 10.5X225 = 2367MHz stabiel, (1.9v). ala 45 graden idle en max 50 stressed (sp-97). Geheugen is corsair value pc3200 2x512mb dual channel 2.5-4-4-11 (2.5-3-3-11 pikt me bios niet, dan krijg heb ik een corrupt bios :), even compu uit een aan en dan is het bios weer default! gelukkig).
beetje vaag is dat me pifast score 1 seconden omhoog gegaan is, terwijl me bandbreedte Int 3300MB/s en Float 3024MB/s is. Dat is hoger dan me geheugen op 2.5-3-3-11 215mhz draait...
  • Mister_X
Er is een nieuw bios uit, 1004 en een nieuwe beta 1005.1 http://www.asus.com/suppo...tem.aspx?ModelName=A7V880
  • Final Frontier
Al iemand die nieuwe beta BIOS 1.005 geprobeerd ? Ik hoor dat er niet veel veranderd is in de menu's, maar wel dat er meer instelmogelijkheden zouden zijn voor Voltage instellingen...
Er is ook een nieuwe versie van de 4 in 1 drivers van VIA beschikbaar. Speciaal voor de nieuwe chipsets o.a. KT880. Zie meuktracker: VIA Hyperion 4in1 4.53;
[ Voor 34% gewijzigd door Final Frontier op 18-08-2004 13:17 ]
  • Mister_X
Ik heb hem erop gezet :) Geen zienbare veranderingen, ook neit kwa performance, waarschijnlijk wat bug fixes dus, geen idee voor wat, want alles werkt nog! Trouwens wil ik jullie laten weten dat ik met dit bordje hogere geheugen scores haal dan met me voorlmalige nforce2 ultra400 plank, (ga-7n400 pro2). Zoals me vorige post hierboven.
Heb overigens ook de nieuwe via drivers erop gezet + ati 4.8, tot nu toe nog geen hogere scores ofzo, 6900 (+/-) met me 9800 pro@xt *D
  • Final Frontier
Oke, fijn om te weten. Ga ik strax ook even flashen. De geluidsproblemen (mono geluid of maar aan een kant) ligt aan de connector van mijn boxen, dus niet mainboard gerelateerd, gelukkig.
Mister_X : Je draait nu op 10,5 x 225 ? Netjes 8) Ik hou het voorlopig even op 12 x 200 @ 1,68 V (asusprobe). Draait stabiel en snel genoeg.
  • erikdeperik
Mister_X schreef op 18 augustus 2004 @ 19:42:
staat die asyncronus frequentie op enabeld bij jouw????
ik ga dit bordje zeker bestellen.
aleen een v-mem mod zou wel lekker zijn.
ik denk dat ie veel lijkt op die van de asus a7n8x,maar die link in dat topic is dood
als iemand een v-mem mod weet hou ik me aanbevolen :>
  • erikdeperik
ze hebben hem al op 240 lopen met setfsb
http://www.xtremesystems....sus%20a7v880&pagenumber=2
zonder mods
[ Voor 8% gewijzigd door erikdeperik op 19-08-2004 19:21 ]
  • RD
  • Laatst online: 19-03 14:35
RD
focus
Kan iemand vertellen hoe het staat met de linux performance/ondersteuning van deze chipset?
  • Mister_X
erikdeprik schreef op 19 augustus 2004 @ 17:43:
Wat houd dat ook weer in? sychroon is dat het gelijk loopt met de fsb he, dus async niet, dus moet die op disabled staan... mwa, me geheugen draait op 450mhz (ddr). dus denk dat het disabled is :)
Denk niet dat ik een hogere FSB zal krijgen, A me cpu wilt toch niet hoger dan nu, B me geheugen zal het niet trekken.
Ik ga binnekort eens kijken naar een mobile 2600+ + pc4000 geheugen :).
Misschien een loze vraag, maar welke zal lekkerder draaien/overklokken, zo'n sempron ding (2800+ ofzo) of zo'n mobile barton (2600+).?
Hmz, heb net wat reviews gelezen, die semprons zijn een stuk slomer dan mobile bartons..
[ Voor 8% gewijzigd door Mister_X op 19-08-2004 23:04 ]
  • Final Frontier
De mobiles zijn ook beter / makkelijker over te klokken. 8)
  • erikdeperik
semptron is socket 754 d8 ik
ik heb zelf een mobile xp 2500+
die loopt 2680 mhz prime stabiel @2 volt
mp nog lager zetten zo kun je kijken hoe hoog die fsbus gaat
die asyncronus bus moet je enabeld zetten zodat je pci/agp gelockt word
dat zou een botleneck kunnen zijn
het kan zo zijn dat hij niet locked maar gewoon de divider een tandje hoger zet
dus boven 200 async=/7
probeer is met deze setting te benchen met en zonder sync(deze setting staat bij"configer system freq/voltage")
zet je mp op negen zodat je zeker weet dat je cpu niet de bottlenek is.
zo kom je erachter wat het doet
wie weet loopt die van jouw wel 9*240 >:)
  • Mister_X
erikdeprik schreef op 20 augustus 2004 @ 18:10:
staat nu op enabled, haal leuke ram-bench score in sandra, anyway, kan niet testen met fsb enzo, ding gaat maar tot 227, ja ikw eet dat hij hoger kan, maar ik wacht wel even op me mobile en dat daar een bios update voor komt. al met al draait het nu prima
  • RD
RD
focus
Ik heb het moederbord gekocht! Zeker fijn bordje. Nu doet de Athlon XP 2600+ @ 3400+ of te wel "gewoon" 11,5*200MHz. Nu maar kijken of dit nog hoger kan :) ....
  • erikdeperik
ik heb hem nu ook binnen :9
loopt prima ,maar ik heb zeker v-mem-mod nodig
ik kan met snelste timings wel booten op 227,maar dan start windows niet door :/
wil be continued :)
  • erikdeperik
ik heb het probleem dat mijn monitor niet aangaat na standby s3 :/
  • Final Frontier
Gisteren even wat testjes gedraaid en de max van mijn 2500+ ligt voorlopig op 12 x 210 @ 1,80 V. primestable. De geheugentimings heb ik maar eens manual gezet, met de settings 2-3-2-6-12-1T, terwijl ik CMX512-3200XL memory heb, wat tot 225 2-2-2-5 moet kunnen. Niet dus |:( Ik moet ook 2,85 V leveren aan het mem om geen fouten te krijgen in pifast. En die 6 zou dus eigenlijk 5 moeten zijn, maar die optie is niet beschikbaar in de bios. Hij gaat maar van 6 tot 9 8)7
Anyway stressed wordt de cpu nu 52 graden met de fan op 3500 rpm. Toch maar weer even 10 seconden van mijn pifast tijd afgehaald 8)
PS Geen problemen met standby, aangezien ik mijn machine 24x7 aan heb staan op vol vermogen }:O
Nou ik heb ook zon plankje, met een xp 3200+ er op en waterzetje
maar boven de 215 wild window's niet starten dus draai nu maar
12 x 212 @ 1.8v
wild niet echt lekker gaan bij mij
  • SniperGuy
  • Laatst online: 08:15
Zojuist dit plankje besteld (jammer genoeg niet voor mezelf) :)
Nog weinig slechte ervaringen gehoord
Moet je onder XP nou nog steeds die via 4 in 1 drivers installeren :?
[ Voor 27% gewijzigd door SniperGuy op 10-10-2004 16:41 ]
  • SniperGuy
Ben een beetje aan het tunen geslagen maar ik vind de prestaties niet bijster geweldig (ok is ook niet top of the bill maa toch)
Heb 2x 256MB Twinmos ddr400 erin steken in dual channel mode
,een asus GeforceFX 5200 (ultra?) 270/366
En de proc op 175 x 12 draaien
Maar met testprogramma's is mijn eigen systeem (P4 2,4 @ 2,5, TI4200 @, single mode ddr333) haal ik vergelijkbare en betere scores 8)7
Zo is met 3Dmark03 mijn systeem met alles 2x zo snel qua FPS en fill-rates ;(
Iemand tweak oplossingen?
  • Mister_X
SniperGuy schreef op 23 oktober 2004 @ 16:04:
mwa tweak oplossinge niet echt, het bios spreekt behoorlijk voor zich right? misshcien manuele timings instellen? Als ik op 225mhz bench haal ik 3300mb's met deze timings: 2.5-3-7-3, das toch egt nie slech!
Voor de rest is dit bord voorlopig nog een blijvertje, vind hem heerlijk!
Misschien moeten de gene die hun cpu niet verder krijgen de overvolt jumper even verzette!? ;) mijnes draait met die overvolt nu 2v max *D
  • BiG-GuY
  • Laatst online: 08:51
BiG-GuY
misschien komt het omdat die FX5200 zwaar klote is, hij is iig slechter dan je Ti4200... de pure versie presteerd ongeveer gelijk aan een Geforce 2 GTS/Ultra maar dan met DirectX 9 ondersteuning (om DirectX 9 spellen als diashow te bekijken :D )...
[ Voor 48% gewijzigd door BiG-GuY op 23-10-2004 23:40 ]
  • PASware
  • Laatst online: 08:59
een vriend van mij heeft een a7v880 en heeft er een probleem mee...
...zijn muis/keyboard (beide aangesloten op ps/2 poort) reageren na verloop van tijd steeds niet meer terwijl pc niet vastloop (irc werkt vrolijk door), dit gebeurt zomaar ineens, zonder dat de pc ergens mee druk is, ook gebeurt het niet steeds na 15min (als voorbeeld), maar random.
Hij heeft zijn bios al geupdate met de ps/2 fix , maar dat heeft geen zin gehad
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
  • PASware
PASware schreef op 24 oktober 2004 @ 22:27:
uhh iemand? O+
  • SniperGuy
bad mem :?
Wel "klote" dat die 5200 niet doet wat ik ervan verwacht had ;(
Had eigenlijk alleen een beetje naar de prijs gekeken en een grafiekje op Tom's Harsware :X
[ Voor 89% gewijzigd door SniperGuy op 27-10-2004 21:59 ]
  • erikdeperik
heb je de laatste bios er gekwakt??
dat wil nog wel eens helpen
iig heb ik geen problemen met dit bord
lekker stabiel :)
hij komt aleen niet goed terug uit standby,maar dat zal wel aan eoa driver liggen.
slaapstand is wel goed.
ook smart q fan is wel lekker stil :*)
  • SniperGuy
erikdeprik schreef op 31 oktober 2004 @ 13:45:
lekker stabiel :)
Met het originele bios had ik dit ook, sinds het laatste bios niet meer :)
  • AvWijk
  • Laatst online: 04-10 23:16
Ik heb het bord ook, maar is het echt zo dat het onboard geluid disabled is als je er een PCI geluidskaart in hebt zitten? :(
  • AvWijk
Vrij vervelend, omdat ik altijd 2 geluidskaarten naast elkaar had en deze onboard dus niet kan gebruiken..
  • AvWijk
Helemaal niemand een oplossing voor dit probleem, of dat er bekend is dat ASUS een bios update hiervoor gaat uitbrengen?
  • erikdeperik
leuk dat dit topic nog leeft :)
maar jouw probleem met 2 geluidsbronnen heb ik wel vaker gehoord,en is imho geen asus probleem.
denk dat je gewoon ff een nieuw topic moet openen.
waarom zou je 2 geluid bronnen hebben :?
anyway zoiets als :pci geluidskaart en onboard geluid gebruiken
suc6
Ik heb het mobo in mijn server gestopt met een sempron 2300+. Aantal opmerkingen:
- Boot niet met een trident pci videokaart (2mb) loopt vast op bios logo! (Who cares, maar toch vervelend)
- Goede netwerkkaart onboard. (11,7 mb/sec sustained @ 100mbit full)
- Linux wil niet alles lekker herkennen. (Sensors, geluidskaart is een beetje vervelend al heb ik de geluidskaart niet nodig in de server)
- Hij presteert naar behoren, maar ik heb hem niet overclocked of zware games gedraait. Hij is wel stable tot nu toe onder zware system loads. (Nog geen enkele crash in linux, maarja dat is me sowieso nog niet veel gebeurd)
- Ergernis, floppy aansluiting zit helemaal onderdaan het mobo en mijn floppy zit bovenin mijn big-tower dus alle floppy kabels die ik op dit moment in mijn bezit zijn, zijn te kort. Terwijl ze wel lang genoeg waren voor mijn vorige moederbord (Asus A7V met Duron650)
Met linux bedoel ik in dit geval Debian testing/unstable met kernel 2.6.8-1.
Sinds een paar dagen heb ik nu ook een a7v880 samen met een xp-m2500.
Alleen lijkt het er op dat deze cpu niet samen wil met dit bord.
Of het start niet op of het start op maar crashed heel snel.
De laatste bios heeft ook niet veel geholpen helaas.
vcore stapje voor stapje hoger ook niet.
Kan het zijn dat deze cpu niet samenwerkt met dit bord ?
Of is de cpu gewoon slecht / kapot ?
Want met mijn oude t-bird 1100 loopt het als een (langzame) trein.
De overige specs zijn:
a7v880
xp-m 2500 (tbird 1100)
zalman 400w voeding
gf4 ti 4200 POV
2x 512 ddr400 twinmos (staan vermeld in het boekje)
brander + cdrom
en een sata + pata hdd
alvast bedankt
Ik heb dit bordje nu 1,5 maand als data (1,4tb, win2003) servertje draaien met sempron 2400+
Staat nu al vanaf 27-10 aan dus wel stabiel :Y)
Overclocken ging ook wel lekker, van 1667mhz --> 2270mhz. Servert nu op 2000mhz. (2800+?)
Max fbs is op dit mobo toch 227 fbs?
Muliplier veranderen ging niet post-e dan niet.
Asus bordjes hebben vaker problemen met geluid lijkt het wel.
[ Voor 19% gewijzigd door Verwijderd op 08-12-2004 21:59 ]
  • Verbal Kint
  • Laatst online: 27-05-2025
Verbal Kint
The man with the plan
Ik overweeg dit bordje aan te schaffen omdat ik vermoed dat mijn huidige mobo (ECS L7S7A2) problemen geeft met mijn nieuwe Aopen 6800LE. Hij zou dan moeten draaien met een Barton (niet gelocked :*) ), 512mb pc3200 cl2.5 Twinmos en een Enermax 350W voeding.
Is er iemand die een vergelijkbare configuratie heeft draaien? Vooral de Geforce ben ik benieuwd naar. Ook begrijp ik dat de ondersteuning van mijn ram soms tegenvalt, of speelt dit alleen in dual channel mode?
Great minds think alike!
Voor het geheugen is een lange lijst beschikbaar waar op staat welke reepjes geschikt geacht worden.
onderaan
In het instructieboekje zit bij mij zelfs een los blaadje waar een aanvulling opstaat.
Dit is een behoorlijk lange lijst, dus de kans dat jou geheugen ook er opstaat is aanwezig :)
  • Verbal Kint
Verbal Kint
Inmiddels is mijn computer weer draaiende met zijn nieuwe bordje. Inbouwen ging bijna in één keer goed, alleen in eerste instantie gingen de fans enz wel aan maar was er geen PIEP, en dus geen post. Na wat zinloos aan- en loskoppelen van drives zag ik dat de ATX-voeding er niet helemaal lekker inzat, dat verholpen en toen werd er opgestart! Dat ging dan weer minder goed, ik had al een blauw scherm voordat ik uberhaupt een windows logo had gezien... :/
Een repair mbv de windows CD heeft er voor gezorgd dat ik nu iig weer kan GoTten. Het geluid werkt echter niet en spelletjes ook nog niet erg. Mijn devicemanager ziet er ook wat vreemd uit:
Afbeeldingslocatie: http://home.tiscali.nl/heerschen36/vreemde_devicemanager.jpg
Toch maar een fresh install gaan doen denk ik.
Overclocken gaat iig prima. Mijn Barton 2600+ (11,5 * 166 = 1917Mhz) doet zijn werk nu zonder problemen op 10*200. :9
Enige wat ik geinstalleerd heb is:
chipset drivers, netwerk drivers, audio, raid controller, videokaart en bios geupdate.
Heb je nog iets anders in je pc? tvkaart ofzo
  • Verbal Kint
Verbal Kint
Nee, niets verder. Volgens mij is het ook niet goed dat ik zoveel "via standard host bridges" en "motherboard" resources heb toch?
  • Verbal Kint
Verbal Kint
Inmiddels heeft een fresh install alle problemen opgelost. Het werkt nu als een zonnetje. Mijn Barton 2600+ loopt vlekkeloos op 10x200 (ipv 11,5x166). Misschien kan de multiplier nog wel een tikje omhoog en daarom installeerde ik MBM om de cpu temp in de gaten te kunnen houden. Helaas staat de A7V880 er niet tussen en wat ge-experimenteer met andere A7Vxxx levert nog niks op. Wat gebruiken jullie om de temps en volts te monitoren?
Verbal Kint schreef op woensdag 15 december 2004 @ 14:24:
Wat dacht je van Asus Probe. Van het zelfde bedrijf dat toevallig ook je de A7V880 gemaakt heeft. :D
Ik gebruik zelf dit mobo in mijn server (Linux, Debian) dus ik gebruik sensord (lm_sensors). Deze doet het niet geweldig met de a7v880, niet met de standaard settings iig. Hij vind de sensoren wel, maar haalt cpu/case door elkaar en vind een aantal rare voltages.
  • Nivado
  • Laatst online: 19-10 20:41
Ik heb een A7V880 met een XP 2400+. Mijn MB herkent m'n proc als een 1800+ (100x15). Als ik mijn AI overclock settins op +30% zet draait stabiel op 130*15 wat herkent wordt als een 2200+, maar als ik m'n AI overclock settings op manual zet op bijvoorbeeld 133 (wat standaard is voor deze CPU) dan wil windows niet meer starten: ik krijg de melding dat een bestand (system) niet gelezen/gevonden kan worden en dat ik herstel moet uit voeren. Als ik m'n cpu vervolgens weer op 2200+ laat draaien start windows gewoon. Asynchroon AGP frequency op enabled of disabled maakt geen verschil. Ik heb m'n bios al geupdate naar versie 1007.
Ik denk dat dit aan m'n FSB/pci devider ligt, ik kan deze alleen nergens vinden in m'n bios (ook niet met behulp van de handleiding.
Weet iemand waar/hoe ik m'n FSB/pci devider kan instellen, of waar het anders aan ligt en hoe ik mijn processor normaal op 15x133 kan laten draaien.
Specs:
A7V880 met XP 2400+
GF 4 ti 4600
Maxtor 80 GB ATA 133
Kingston 512 MB 400 MHz
  • Chewy
  • Laatst online: 26-07-2022
Heb dit bordje nu ongeveer een weekje draaien met een amd mobile xp 2600+ en twinmos 1gb matched pair. FSB=225 mp=11 mem timings= 2.5-5-5-8 (2T). Met lagere timings kom ik wel in windows, maar niet door de selftest van prime95. Prima mobo, alleen me printerpoort werkt nog niet goed, nog niet echt naar gekeken, maar laatst merkte ik dat de printer niet werkte 8)7
Wat ik nog wel ff wil weten is of je die usb aansluitingen op het mobo ook kan gebruiken met andere usb poorten behalve een asus verlengsnoer. Want mijn kast Casetek CS1019 heeft standaard usb poorten aan de bovenkant van de case zitten. Maar nu zag ik nog niet echt hoe ik die aan kon sluiten op het mobo, terwijl ik dit wel graag wil doen. Is dit mogelijk?
  • Nivado
Nivado schreef op zondag 02 januari 2005 @ 13:15:
Specs:
A7V880 met XP 2400+
GF 4 ti 4600
Anybody? please help me
Thanx in advance
  • Verbal Kint
Verbal Kint
Nivado schreef op dinsdag 04 januari 2005 @ 23:10:
Thanx in advance
Het enige wat ik heb gedaan om mijn Barton op 200fsb te laten draaien ipv 166 is in het bios de fsb handmatig op 200 instellen. Daarnaast heb ik nog wel de multiplier aangepast. Misschien heb je een andere optie verkeerd ingesteld? Probeer het eens vanuit de defaultinstellingen (dus ook alleen maar de fsb en MP aanpassen, verder alle opties onveranderd laten).
  • Eichii
  • Laatst online: 04-09-2017
@Nivado:
1. Kijk op pagina 2-14 voor naar het jumperfree configuration gedeelte te gaan.
2. G dan naar pag. 2-21; Die AI Overclock tuner moet staan op Manual
3. Have fun!!! van hier af aan zie je dan de optie waar je je FSB kan aanpassen.
Dit natuurlijk allemaal gevonden in het mobo-boekje, maar ik moet ook toegeven dat als ik niet massa's van dit soort pc's met dit mobo'tje had gebouwd het ook niet had geweten.
  • Nivado
Bedankt voor jullie hulp, maar dat had ik allemaal al geprobeerd. ik krijg de processor ook wel op 12*166. maar als ik de FSB handmatig instel (op manual dus) wil windows niet meer. het instellen van de FSB is een eitje. Ik snap alleen niet waarom windows dan zegt dat ik herstel moet uitvoeren, terwijl op voorkeurs instelling van het mobo windows wel gewoon start. als iemand me daarbij zou willen helpen graag. Ik dacht dat het misschien aan de PCI devider ligt maar die kan ik nergens vinden. bij voorbaat mijn dank
  • Eichii
Als ik me goed herinner moest de 2400 op 133 FSB, maar ik kan me ook daarin vergissen.
Het kan ook gewoon dat je processor dan defect is ofzo!
Ik werk namelijk bij een pc-zaakje waar die dingen de deur uit vliegen en een defecte heb ik tot nu toe niet meegemaakt.
  • Nivado
Hij moet ook op 133, ik wou er ook alleen maar mee illustreren dat het instellen van mijn FSB niet het probleem is, maar dat windows er dan gewoon geen zin meer in heeft. Op mijn vorige mobo (ECS K7S5a pro) draait hij wel gewoon op 15 x 133 en stabiel. op 38 graden idle en 44 graden stressen met een Arctic copper silent.
  • theroman
  • Laatst online: 17-10 17:08
@Nivado
Ik heb dit bord ook, maar ik heb inderdaad ook nog geen PCI dividers gezien in de BIOS. Wat betreft je problemen met het opstarten van Windows, kan ik je aanraden om BIOS 1008.001 te proberen.
  • Nivado
@ theroman
Dat is toch een beta versie? Daar heb ik het nooit zo op. Draait hij bij jou stabiel? Ik denk dat ik het dan toch maar probeer. In iedergeval bedankt voor de tip.
  • theroman
Ik heb er geen problemen mee. Nu moet ik je zeggen dat ik meteen geflasht heb naar die betaversie, dus ik weet niet of ik het probleem gehad zou hebben bij een lagere biosversie.
Bonne chance iig ;)
Wat is er zoal gefixt in 1008.001?
Heb zelf nog steeds last van:
- SATA HD die (soms) niet herkend wordt (pc aan/uit en het is meestal weg).
- PC die (soms) reboot ipv uit gaat.
- Wake on keyboard werkt nog steeds niet (zou gefixt zijn in 1007).
Valt op zich nog mee als je bekijkt waar ik in het begin allemaal last van had hehe.
Je moet tijd en zin hebben om uren met die moederbord te klooien voordat het echt lekker werkt.
  • Chewy
Verwijderd schreef op vrijdag 07 januari 2005 @ 10:15:
Ik zelf gebruik geen SATA of wake on by keyboard. Maar dat probleem met reboot ipv uit gaan, heb ik ook weleens. En heb ook nog wel last van dat hij ineens in standby/slaapstand gaat, hoewel dat nu weleens opgelost zou kunnen zijn sinds ik laatst die advanced powermanagement (weet nie zeker of het zo heet) in het bios heb uitgeschakeld.
Chewy schreef op vrijdag 07 januari 2005 @ 11:19:
APM en geheugen zijn volgens mij de grootste struikelblokken van het apparaat.
Toen ik m net in m'n PC gestopt had was het 1 brok ellende (beetje overdreven).
Alles werkte, maar met spellen liep de boel na een willekeurige tijd muurvast. Weken klooien met memory timings en verschillende bios versies heeft dit gefixt (afkloppen!!!). Daarbij heb ik ook lang met de APM settings moeten testen om ervoor te zorgen dat hij uberhaupt uit ging en niet opnieuw opstarte etc etc.
Zoals ik al zei: een leuk moederbord als je tijd hebt om m helemaal zelf te finetunen.
De nieuwe 1008 BIOS staat vanaf nu op de Asus site:
A&v88008.zip
Wat is er anders?
Volgens de website worden er alleen nieuwe CPU's ondersteund.
Stiekem hoop ik dat ze ook nog wat gefixt hebben aan de problemen die hierboven beschreven staan, maar dat zie ik pas als ik de PC ga uitzetten hehe.
Ondertussen heb ik ook nog wat anders ontdekt:
Afbeeldingslocatie: http://home.hccnet.nl/e.v.amstel/images/3100+.jpg
Na wat Googlen blijken andere mensen dit ook te hebben.
Een wel erg slordige fout van Asus. Aangezien het aantal Ghz wel klopt, neem ik aan dat er geen gevolgen voor de prestaties aan vast zitten. Toch hoop ik dat dit in 1009 gefixt is.
Nog meer (commentaar van een ander forum):
i sold my a7v880 to a friend for (sigh) $40, and helped him set it up. Got windowsxp installed and updated to the latest bios (1008 as posted here) and noticed that it has the exact same date/time info as the 1007.005 bios...... and no changes whatsoever after flashing. I'd say this is 1007.005.
Blijft apart allemaal...
Iemand anders al ervaringen?
[ Voor 29% gewijzigd door Verwijderd op 10-01-2005 18:14 ]
Na een paar dagen testen kan ik nu al melden dat je deze beter kan overslaan.
PC was niet stabiel meer...
  • Chewy
Verwijderd schreef op vrijdag 07 januari 2005 @ 20:06:
Zou je ook de instellingen van de APM kunnen zeggen, want bij mij blijt hij maar in standby/slaapstand gaan :?
Chewy schreef op donderdag 13 januari 2005 @ 12:23:
Zet eerst BIOS 1007 op je pc (naar mijn idee nog de beste).
Settings:
Bovenste (naam weet ik niet :?): S1 (POS) Only
ACPI 2.0 : Enabled
Onderste (naam ook vergeten) : Enabled
In de APM settings:
Alles default
Ik heb wel gemerkt dat het ook aan de memory settings kan liggen (alles kan bij dit bord aan de memory settings liggen geloof ik :().
Gvd, door die bios upgrade (en vervolgens weer downgrade), is m'n stabiele systeem dus mooi naar de maan...
Heeft iemand dit moederbord al is helemaal stabiel gekregen met deze modules:
Kingston Dual-Channel kit PC3200 - KVR400X64C3AK2 (512MB)
Of heeft iemand uberhaupt de goeie timings voor deze modules, ik kan namelijk of heel slecht zoeken of ze staan nergens.
En met stabiel bedoel ik niet: ik kan internetten en office gebruiken.
Maar meer: 3DMark05 loopt helemaal door en in Photoshop kan je rustig met 500mb groote bestanden aan de gang zonder dat ie ineens weer vast slaat...
Alvast bedankt.
  • SniperGuy
Heb de laatste tijd ook een beetje kuren:
Bij gamen (dikke 3d etc) slaat de pc ineens uit (schijven, dvd-spelers, lampjes gaan uit) alleen de num-lock blijft branden (ps/2 keyboard) aan-uit knop werkt niet en spanning moet van de voeding af voordat ie weer ingeschakeld kan worden, iemand? :(
  • Chewy
Verwijderd schreef op donderdag 13 januari 2005 @ 12:37:
Settings:
ACPI 2.0 : Enabled
In de APM settings:
Alles default
Ik had/heb eerlijk gezegt geen zin om versie 1007 weer in me bios te laden (had net naar 1008 geupraged). Dus ik dacht dan probeer ik deze instellingen wel met deze bios versie, maar daar werkt het niet mee. Hiermee komt hij weer in slaapstand/standby (hoe krijg je hem daar eigenlijk normaal uit?) inplaats van dat hij uitgaat, heb al wat andere instellingen geprobeerd, maar ik weet ook eigenlijk niet wat alles inhoud, dus een beetje stuntelen met de instellingen zal niet zo heel veel effect hebben (misschien zelfs nog wel nadelig :o )
SniperGuy schreef op vrijdag 14 januari 2005 @ 17:13:
Dit is ook mijn grootste probleem.
Heel erg irritant. Welk geheugen heb jij, en welke timings gebruik je?
Ik heb de magical cure (denk ik)!
Verhoog je vcore met 0,05 en je systeem is stabiel. Althans zo werkte het hier.
Ben de hele dag bezig geweest met het klooien met m'n pc (ja weer een dag naar de maan).
Maargoed, ik heb zo ongeveer alle mogelijke combinaties van geheugen timings gehad. Voltage van m'n geheugen en AGP verhoogd, allemaal geen effect.
Totdat ik op internet las dat er iemand al een stuk of 20 pc's met dit mobo in elkaar gezet had en erachter was gekomen dat als je de vcore met 0,05 volt verhoogd het systeem stabiel is.
Ik dacht dat het alleen aan de geheugen controler lag dat dit mobo zo onstabiel was.
Temperatuur is ongeveer 1-2C omhoog gegaan, small price to pay voor een stabiel systeem.
Naja stabiel, hij heeft het voor het eerst vandaag heel 3dmark05 doorlopen, terwijl hij hiervoor totaan de scene met het luchtschip (2e keer) kwam (maximaal).
Iemand anders nog andere ervaringen, laat het weten!
Al heb ik af en toe het idee dat ik de enige ben met dit mobo en de problemen hehe.
  • Final Frontier
Er zijn genoeg mensen met problemen met dit bordje. Kijk voor de gein maar eens hier:
http://forums.pcper.com/forumdisplay.php?f=8
In het begin ook problemen gehad, vooral geheugentimings, mijn geheugen staat niet op de lijst van Asus, handmatig ingesteld, meer voltage en het werkt. 200 Mhz barriere was niet aanwezig, gewoon als het niet lukt 0,05 V meer en gaan. Boven de 215 wil de SATA controller niet meer.
BTW Ik draai al een tijdje BIOS 1.007 naar volle tevredenheid.
Ok is weer even stil geweest.
Nieuwe bios is uit: 1009
De fixes:
- Patch CPU frequency error detection issue.
- Patch DirectX 9.0 AGP texture problem.
- Patch few systems with shutdown problem.
Vooral de shutdown fix zal veel mensen blij maken.
Datum is hetzelfde als de beta, dus zal niet veel veranderd zijn. Heb de beta zelf niet gedraaid.
Iemand een mening over 1009? Gemerkt of het al iets stabieler wordt?
  • Magnolia
  • Laatst online: 19-10 21:03
hmm nou ik hoopte dat het probleem met nvidia kaarten en de 7x.xx forceware drivers voorbij was. Het rare is namelijk als je een driver uit die serie installeert, je desktop een slagveld van artifacts wordt. Installeer je 66.93 doet hij het weer perfect. Duidelijk een probleem van het moederbord aangezien mijn kaart op n andere moederbord dit niet geeft.
Ontspan.
  • Magnolia
niemand een oplossing voor dit? Aangezien ik wel eens de 71.xx serie wil installeren...
Ontspan.
  • Final Frontier
Check dit even, je bent niet de enige met deze problemen:
http://www.netsoc.dkit.ie...=News&file=article&sid=92
en
http://forums.pcper.com/s...t=384024&highlight=a7v880
Veel succes !
  • Initial G
  • Laatst online: 22:00
Ik ga deze week ook een A7V880 installeren en mede dankzij dit topic heb ik goede hoop dat ik het ga redden! ;) Heb 2x512MB TwinMos dual channel kit erbij gekocht.
Middels allerlei reviews ben ik erachter dat dit bord dus wel een PCI / AGP frequency lock heeft, dit is nl de "asynchronous frequency" optie in het bios, die moet je dan aanzetten. Als je die uitzet regelt het bord de pci en agp clock zelf door FSB dividers tot en met 1/6. Deze optie staat los van de FSB en geheugenclock, deze kunnen wel synchroon draaien. (ik las hierboven ergens een incorrect verhaaltje over deze optie)
Verder zal ik de AGP driver van de Hyperion set niet installeren. Hopelijk werkt alles stabiel straks. Ik ga denk ik voor de installatie van XP Pro SP2 de voltages voor de zekerheid een tikje hoger zetten dan auto. Zien we later wel of het met minder ook stabiel kan.
Ik hoop dat iemand wat aan mijn verhaaltje heeft, verder iemand nog tips?
  • Final Frontier
Veel succes en als er problemen zijn, dan post ze hier maar, dan kunnen we misschien iets voor je betekenen.
Ik zag dat je 2 x 512 Mb Twinmos geheugen had gekocht + dit mamaplankje, maar welke hardware ga je verder gebruiken ?
  • SmoothTweaker
  • Laatst online: 09:02
We zullen zien wat mijn 2500+ Mobile icm 2x 256mb DDR400 OEM erop gaat doen NF7-S v2.0 verkocht en wacht nu op de A7V880 :P en me Zalman Zalman CNPS7000B-AlCu LED de volledig koperen versie was me net iets te duur!
[ Voor 28% gewijzigd door SmoothTweaker op 09-05-2005 11:35 ]
  • Initial G
Final Frontier schreef op maandag 09 mei 2005 @ 10:18:
Nou het heeft me vrij veel uurtjes gekost maar alles werkt vrij goed nu :) Volgens tweakers maatstaven
A7V880, FSB wil niet hoger dan 145MHz
lag niet echt aan het moederbord, maar aan de combinatie 1.5V Thoroughbred A 1800+ en het bios, waardoor hij niet op FSB 400 wilde. Ik moest een andere multiplier (en vcore) "hardwiren" om de boel voor de gek te houden. Maar op standaard instellingen had het meteen gewerkt.
tip: gebruik speedfan om je fanspeed te regelen, het werkt met de A7V880!
[ Voor 6% gewijzigd door Initial G op 09-05-2005 11:52 ]
  • SmoothTweaker
Initial G schreef op maandag 09 mei 2005 @ 11:48:
Werkt Deze ook echt in procenten? want bij me NF7-S moest ik em op 1%, 2% 3% of 4% zetten om de fan speed te regelen
  • Initial G
@smoothtweaker
ja, werkt prima. Moest alleen wel in configure-->advanced-->ITFnogwat de PWM1 op softwarecontrol zetten. Daarna werkt het.
Pagina: 1 2 Laatste
