DVD's branden met Nero mislukt steeds op het laatst
  • 206 views sinds 30-01-2008
  • henry1st
  • Laatst online: 22-11-2025
Steeds mislukt het branden van DVD's in de laatste 8 seconden. Dit terwijl het wel lukt met CloneDVD.
Wie weet een oplossing?
Hieronder het foutenreport:
********** Nero Recode 2 **********
Version: 2.0.0.18
1A23-0088-5030-1749-1833-8022
Project type: Copy entire DVD
Target size: DVD5 (2282925)
Burn settings:
Target: LITE-ON DVDRW LDW-851S
Number of copies: 1
Write speed: 0 KB/s
Temp folder: C:\Documents and Settings\Mijn documenten\Nero Recode (35594698752 bytes free)
Direct burning: true
Target media: DVD
Shutdown when finished: false
Advanced Analysis: false
10:46:29 File burn_dvdfiles.cpp, Line 235
Compile DVD: init
VMG Menus Vobs [11 vobus] 1.19MB -> 1.19MB [R 1.00]
Video: 1.17MB, extra: 0.02MB
Audio: 0 streams
Subpicture: 1 streams
0. Ongespecificeerd 0.00MB [enabled]
VTS_01 Menus Vobs [20 vobus] 0.20MB -> 0.20MB [R 1.00]
Video: 0.16MB, extra: 0.04MB
Audio: 0 streams
VTS_01 Title Vobs [1 vobus] 0.01MB -> 0.01MB [not compressable]
Video: 0.01MB, extra: 0.00MB
Audio: 0 streams
Subpicture: 0 streams
VTS_02 Menus Vobs [1444 vobus] 310.38MB -> 310.38MB [R 1.00]
Video: 289.61MB, extra: 20.77MB
Audio: 1 streams
0. Dolby Digital 2-kan Ongespecificeerd 16.69MB [enabled]
0. Ongespecificeerd 1.26MB [enabled]
VTS_02 Title Vobs [13788 vobus] 3868.76MB -> 3854.67MB [R 1.00]
Video: 3453.66MB, extra: 401.00MB
Audio: 4 streams
0. Dolby Digital 5.1-kan Engels 367.42MB [enabled]
1. Dolby Digital 2-kan Tsjechisch 0.00MB [enabled]
2. Dolby Digital 2-kan Duits 0.00MB [enabled]
3. Dolby Digital 2-kan Hongaars 0.00MB [enabled]
Subpicture: 8 streams
0. Engels 6.13MB [disabled]
1. Engels - Normale Ondertitels 7.96MB [disabled]
2. Duits 0.00MB [disabled]
3. Tsjechisch 0.00MB [disabled]
4. Nederlands 6.66MB [enabled]
5. Hongaars 0.00MB [disabled]
6. Pools 0.00MB [disabled]
7. Turks 0.00MB [disabled]
VTS_03 Title Vobs [39 vobus] 3.64MB -> 3.64MB [R 1.00]
Video: 2.44MB, extra: 1.20MB
Audio: 1 streams
0. Dolby Digital 5.1-kan Engels 1.12MB [enabled]
VTS_04 Menus Vobs [2 vobus] 0.36MB -> 0.36MB [R 1.00]
Video: 0.35MB, extra: 0.01MB
Audio: 0 streams
0. Ongespecificeerd 0.01MB [enabled]
VTS_04 Title Vobs [400 vobus] 27.08MB -> 27.08MB [R 1.00]
Video: 17.98MB, extra: 9.10MB
Audio: 1 streams
0. Dolby Digital 5.1-kan Ongespecificeerd 8.12MB [enabled]
0. Ongespecificeerd 0.20MB [enabled]
VTS_05 Title Vobs [12 vobus] 1.56MB -> 1.56MB [R 1.00]
Video: 1.54MB, extra: 0.02MB
Audio: 0 streams
VTS_06 Title Vobs [66 vobus] 8.94MB -> 8.94MB [R 1.00]
Video: 8.09MB, extra: 0.85MB
Audio: 1 streams
0. Dolby Digital 2-kan Nederlands 0.72MB [enabled]
10:46:29 File burn_dvdfiles.cpp, Line 1146
Compile DVD: begin copy 1
10:47:16 File NeroRecorderBase.cpp, Line 534
Writing to disc: DVD-R
10:47:16 File NeroRecorderBase.cpp, Line 548
Free capacity on disc: 2285839 sectors (2297888)
10:47:16 File NeroRecorder.cpp, Line 623
Estimated filesystem size: 560
10:47:16 File NeroRecorder.cpp, Line 625
Burn process started
10:47:16 File burn_dvdfiles.cpp, Line 452
Compile DVD: burning 2285668 sectors (2154718 required)
10:47:16 File burn_dvdfiles.cpp, Line 649
Compile DVD: adjust target size to 4464.20MB (4208.43MB obtained)
10:47:16 File burn_dvdfiles.cpp, Line 522
Compiling DVD Volume started
10:47:16 File NeroRecorder.cpp, Line 1212
Buffering files started
10:47:16 File NeroRecorder.cpp, Line 994
Buffering VIDEO_TS.VOB
10:47:16 File vob_record.cpp, Line 648
DirectBurn offset: VIDEO_TS.VOB 16
10:47:16 File burn_dvdfiles.cpp, Line 1061
Compile DVD: finished VMG Menus Vobs
VMG Menus Vobs:
Original 1.19MB -> Expected 1.19MB -> Output 1.19MB
Finished error 0.00MB
Ratio encoded = 0
Original encoded = 11
Slide encoded = 0
StillImage encoded = 0
Output extra size = 0.02MB
Source video size = 1.17MB
Pictures Modified [I 0] [P 0] [B 0]
10:47:16 File NeroRecorder.cpp, Line 1805
Finished buffering file VIDEO_TS.VOB of size 1251328 bytes (611 sectors)
10:47:16 File NeroRecorder.cpp, Line 1872
Buffering files finished successfully
Compile DVD: finished VTS_01 Menus Vobs
VTS_01 Menus Vobs:
Original 0.20MB -> Expected 0.20MB -> Output 0.20MB
Ratio encoded = 0
Original encoded = 20
Slide encoded = 0
Output extra size = 0.04MB
Source video size = 0.16MB
10:47:16 File NeroRecorder.cpp, Line 366
Reserved fragment at 0. Length: 1232
10:47:16 File NeroRecorder.cpp, Line 1383
Reserved start fragment at 0
Reserved fragment at 1232. Length: 32
10:47:16 File NeroRecorder.cpp, Line 990
Writing VTS_01_0.VOB at sector 1264
DirectBurn offset: VTS_01_0.VOB 704
10:47:42 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_01_0.VOB of size 208896 bytes (102 sectors)
10:47:42 File NeroRecorder.cpp, Line 990
Writing VTS_01_1.VOB at sector 1366
10:47:42 File vob_record.cpp, Line 648
DirectBurn offset: VTS_01_1.VOB 806
10:47:42 File burn_dvdfiles.cpp, Line 1061
Compile DVD: finished VTS_01 Title Vobs
VTS_01 Title Vobs:
Original 0.01MB -> Expected 0.01MB -> Output 0.01MB
Ratio encoded = 0
Slide encoded = 0
Output extra size = 0.00MB
Source video size = 0.01MB
Finished writing file VTS_01_1.VOB of size 12288 bytes (6 sectors)
Writing VTS_01_0.BUP at sector 1372
10:47:42 File dvd_record.cpp, Line 402
DirectBurn offset: VTS_01_0.IFO 672
Finished writing file VTS_01_0.BUP of size 18432 bytes (9 sectors)
10:47:43 File NeroRecorder.cpp, Line 990
Writing VTS_01_0.IFO at sector 1232
10:47:45 File NeroRecorder.cpp, Line 1847
Successfully released fragment at 1232
10:47:45 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_01_0.IFO of size 18432 bytes (9 sectors)
10:47:47 File NeroRecorder.cpp, Line 341
Successfully released fragment at 1264
10:47:48 File NeroRecorder.cpp, Line 366
Reserved fragment at 1408. Length: 80
10:47:48 File NeroRecorder.cpp, Line 990
Writing VTS_02_0.VOB at sector 1488
10:47:48 File vob_record.cpp, Line 648
DirectBurn offset: VTS_02_0.VOB 928
10:48:24 File burn_dvdfiles.cpp, Line 1061
Compile DVD: finished VTS_02 Menus Vobs
VTS_02 Menus Vobs:
Original 310.38MB -> Expected 310.38MB -> Output 310.38MB
Finished error -0.00MB
Ratio encoded = 1
Original encoded = 1443
Slide encoded = 0
Output extra size = 19.45MB
Source video size = 290.93MB
Pictures Modified [I 0] [P 0] [B 6]
10:48:48 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_0.VOB of size 325451776 bytes (158912 sectors)
10:48:54 File NeroRecorder.cpp, Line 990
Writing VTS_02_1.VOB at sector 160400
10:48:54 File vob_record.cpp, Line 648
DirectBurn offset: VTS_02_1.VOB 159840
10:52:10 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_1.VOB of size 1073739776 bytes (524287 sectors)
10:52:10 File NeroRecorder.cpp, Line 990
Writing VTS_02_2.VOB at sector 684687
10:52:10 File vob_record.cpp, Line 648
DirectBurn offset: VTS_02_2.VOB 684127
10:55:25 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_2.VOB of size 1073739776 bytes (524287 sectors)
10:55:25 File NeroRecorder.cpp, Line 990
Writing VTS_02_3.VOB at sector 1208974
10:55:25 File vob_record.cpp, Line 648
DirectBurn offset: VTS_02_3.VOB 1208414
10:58:40 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_3.VOB of size 1073739776 bytes (524287 sectors)
10:58:40 File NeroRecorder.cpp, Line 990
Writing VTS_02_4.VOB at sector 1733261
10:58:40 File vob_record.cpp, Line 648
DirectBurn offset: VTS_02_4.VOB 1732701
11:00:45 File burn_dvdfiles.cpp, Line 1061
Compile DVD: finished VTS_02 Title Vobs
VTS_02 Title Vobs:
Original 3868.76MB -> Expected 3854.66MB -> Output 3854.67MB
Ratio encoded = 1902
Original encoded = 11882
Slide encoded = 4
Output extra size = 391.28MB
Source video size = 3467.78MB
Pictures Modified [I 78] [P 37] [B 14013]
11:01:09 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_4.VOB of size 820690944 bytes (400728 sectors)
11:01:09 File NeroRecorder.cpp, Line 990
Writing VTS_02_0.BUP at sector 2133989
11:01:09 File dvd_record.cpp, Line 402
DirectBurn offset: VTS_02_0.IFO 848
Finished writing file VTS_02_0.BUP of size 108544 bytes (53 sectors)
11:01:12 File NeroRecorder.cpp, Line 990
Writing VTS_02_0.IFO at sector 1408
11:01:14 File NeroRecorder.cpp, Line 1847
Successfully released fragment at 1408
11:01:14 File NeroRecorder.cpp, Line 1858
Finished writing file VTS_02_0.IFO of size 108544 bytes (53 sectors)
11:01:15 File burn_dvdfiles.cpp, Line 1061
Compile DVD: finished VTS_03 Title Vobs
VTS_03 Title Vobs:
Original 3.64MB -> Expected 3.64MB -> Output 3.64MB
Ratio encoded = 0
Original encoded = 39
Slide encoded = 0
Output extra size = 1.08MB
Source video size = 2.56MB
11:01:15 File NeroRecorder.cpp, Line 341
Successfully released fragment at 1488
11:01:15 File NeroRecorder.cpp, Line 366
Reserved fragment at 2134064. Length: 32
11:01:15 File NeroRecorder.cpp, Line 990
Writing VTS_03_1.VOB at sector 2134096
11:01:15 File vob_record.cpp, Line 648
DirectBurn offset: VTS_03_1.VOB 2133536
11:01:23 #1 SCSI -1135 File Cdrdrv.cpp, Line 1439
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0219A000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x20 0x92 0xC0 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
11:01:23 File NeroRecorder.cpp, Line 1551
Failed to write cache to disc at 2134720
11:01:23 File NeroRecorder.cpp, Line 1757
Failed to write file to disc
11:01:23 File NeroRecorder.cpp, Line 3072
Disc info:
Partitions: 0
TotalCapacity: 2297888, FreeCapacity: 2297888, Next writable address: 2134096
Number of fragments: 6
Fragment 1 (reserved, blank), session: 1
start: 0, next writable address: 1216
Fragment 2 (), session: 1
start: 1232, next writable address: 1248
Fragment 3 (), session: 1
start: 1264, next writable address: 1392
Fragment 4 (), session: 1
start: 1408, next writable address: 1472
Fragment 5 (), session: 1
start: 1488, next writable address: 2134048
Fragment 6 (reserved, blank), session: 1
start: 2134064, next writable address: 2134080
----- Begin NeroAPI error log -----
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\NeroVision\NeroFiles\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16-12-2003 20:18:06
Nero API version: 6.3.1.10
Using interface version: 6.3.0.6
Installed in: C:\Program Files\Ahead\NeroVision\NeroFiles\
Application: Ahead\Nero Recode
Recorder: <LITE-ON DVDRW LDW-851S> Version: GS0F - HA 1 TA 0 - 6.3.1.10
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : JLMS XJ-HD166S atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON DVDRW LDW-851S atapi Port 1 ID 0 DMA: On
DiskPeripheral : IC35L080AVVA07-0 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
JLMS XJ-HD166S H: CDRom0
LITE-ON DVDRW LDW-851S I: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 502MB (515060kB)
Memory in use : 34
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.5.2004
NeroAPI
10:47:16 #1 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: -1 ( 0:00.-1, 0MB)
10:47:16 #2 Text 0 File DlgWaitCD.cpp, Line 249
Write in overburning mode: FALSE
10:47:16 #3 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: LITE-ON DVDRW LDW-851S, Media type: DVD-R
Disc Manufacturer: AN31 -
Disc Application Code: 64, Disc Physical Code: 193
10:47:16 #4 Text 0 File DlgWaitCD.cpp, Line 410
>>> Protocol of DlgWaitCD activities: <<<
Disc not empty. Insert empty disc.
(Medium in drive: DVD-R. Medium required by compilation: DVD+R/RW; DVD-R/RW.)
10:47:16 #5 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
10:47:16 #6 ISO9660GEN -11 File geniso.cpp, Line 3899
10:47:16 #7 Text 0 File DVDR.cpp, Line 1650
Recording mode: Sequential Recording Mode for Multisession
10:47:16 #8 Text 0 File Mmc.cpp, Line 20051
Set BUFE: supported -> ON , SMART-BURN : ON
10:47:16 #9 Text 0 File DVDR.cpp, Line 1791
Start write address at LBA 0
DVD high compatibility mode: No
10:47:16 #10 Text 0 File Cdrdrv.cpp, Line 8024
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
11:01:23 #11 SCSI -1135 File Cdrdrv.cpp, Line 1439
Sense Code: 0x0C
Sense Qual: 0x00
Existing drivers:
File 'Drivers\InCDfs.SYS': Ver=4, 2, 4, 1, size=89472 bytes, created 6-4-2004 19:39:20 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 2, 4, 1, size=25600 bytes, created 6-4-2004 19:40:10 (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 2, 4, 1, size=5504 bytes, created 6-4-2004 19:43:22 (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
----- End NeroAPI error log -----
11:01:26 File NeroRecorder.cpp, Line 1999
Burn process failed
11:01:26 File burn_dvdfiles.cpp, Line 304
Compile DVD: exit
  • nero355
  • Laatst online: 10-07 17:18
nero355
ph34r my [WCG] Cows :P
Dude link gewoon naar je LOG man is echt groot zo :o ;)
  • Angels2
  • Laatst online: 15-03-2025
Haal je serial eens uit de logfile...
Ik zag dat je op AN31 media probeert te schrijven:
Heb je het al eens op andere plaatjes geprobeerd? Van een ietwat bekender merk misschien? De drive geeft eenzelfde code terug als bij een buffer underrun:
Sense Code: 0x0C
Sense Qual: 0x00
Dus 03/0C/00, en dat betekent meestal (want buffer underrun protection is aan) dat ie niet met het plaatje overweg kan.
Je krijgt die log ook een stuk korter door de vele lege lijnen even te verwijderen. Leest heel wat makkelijker.
[ Voor 8% gewijzigd door Angels2 op 07-05-2004 19:52 ]
Probeer deze nieuwe firmware anders eens:
http://www.liteonit.com/o...em=DR8GS0H&Model=LDW-851S
Dan word je schijfje mss wel tegoei beschreven.
  • E-Vix
  • Laatst online: 10-09 16:10
E-Vix
Nu met sneeuw!
Toevallig met een illegale versie van Nero gewerkt, en een update uitgevoerd naar een nieuwere versie? Dan ligt daar het probleem. Als nero ziet dat de key van een illegale versie is, dan lijkt hij gewoon normaal te werken, maar dan verkloot hij je cd of dvd in de laatste paar seconden.
Nero heeft (vind ik tenminste dan) een van de meest originele kopieerbeveiligingen in zichzelf zitten. Geen melding dat je key verkeerd is ofzo, met de vraag of je een nieuwe in wilt voeren (die ook wel weer ergens vandaan gehaald kan worden), maar hij gaat gewoon je lege cd's en dvd's slopen. Illegale versies kost hun geld, en zo pakken ze diegene met illegale versies weer terug.
Failed opening '/home/users/7942/signature.inc' for inclusion (include_path='.:') in /home/www/got/userstats.php on line 25
  • henry1st
Heb net weer met Nero (legaal overigens, hoor!) een DVD gebrand. Voor de zekerheid maar wel op een rewritable. Nu lukt het keurig! Waarom dan niet met een -R DVD? Ik heb de firmware ook geupdatet.
henry1st schreef op 09 mei 2004 @ 13:47:
Als je een probleem wilt kortsluiten moet je dus nooit twee variabelen tegelijk veranderen he :) nu weet je dus niet of het 'm aan die firmware lag, of aan de gebruikte schijfjes.
Precies hetzelfde probleem hier , +RW lukt , maar +R - R van welk merk dan ook mislukt telkens op het laatst hier , met Nero 6
:o
