Riva TNT overklokken op Intel SR440BX
  • 33 views sinds 30-01-2008
heey jongens .. ik heb ffe gezocht op google of mijn Mobo te overklokken was, nou blijkbaar niej, maar ik las wel dat mijn Riva TNT kaart te overklokken was op mijn Mobo
If you have read that far, you are very unlikely to be an overclocker. Overclockers are notfond of Intel mainboards, they are even allergic to them! And that is quite understandable: youcan't overclock the processor on SR440BX mainboard. The FSB frequency is set automatically eitherto 66 or to 100MHz. No other options. That's why if you have just become a happy owner of SR440BX,forget about overclocking.
Oh, wait! We have absolutely left out another beautiful component just perfect foroverclocking - the graphics accelerator. Strange as it might seem, but Riva TNT on SR440BXis overclockable. The default working frequencies are non-standard 85/100MHz, i.e. the chipand the memory are slightly slowed down. Well, it turns out already the second case with RivaTNT integrated mainboards, so, we suppose that this retardation is caused by some forcible reasons.For example, it may be the result of other system components overheating.
However, the on-board TNT can be overclocked up to 110MHz core and 125MHz memory frequency,which is actually very similar to the results shown by most ordinary graphics cards based on thischip.
iemand een ideetje hoe ik die Corespeed en memory freqency kan veranderen van die kaart?
Super Bedankt ,
Roel
  • UTM
  • Laatst online: 03-09 21:31
UTM
Hoe wil jij je mobo overclocken? Anyway, met een riva tnt2 zou je eens kunnen denken aan Rivatuner bijvoorbeeld. Hiermee kan je je Videokaart goed overclocken. Download wel even artifact tester ofzo, hiermee kan je testen of je je kaart niet te ver hebt overgeclocked (als je artifacts ziet = blokjes, zit die wat te hoog) Zorg dus voor goede cooling, en clock over met kleine stapjes!
Rivatuner: http://www.guru3d.com/rivatuner/. Hier is ook informatie te vinden: FAQ Videoplanken & Beeldkanonnen (18/11/02)
[ Voor 27% gewijzigd door UTM op 08-04-2004 23:51 ]
Kun je on board kaarten niet gewoon in het bios instellen?
Google: Riva TNT overclocking
- http://www.nvworld.ru/docs/rt_e.html
- http://www.hwupgrade.com/overclock/overclock_tnt.html
VB Faq: Hoe klok ik mijn videokaart over?
Kortom, neem altijd eerst even de naslagmogelijkheden door (Faq, search, Google) alvorens een topic te openen. Dat voorkomt loze topics die met de eerste Google/Faq hit op te lossen zijn. Zie ook de forumFaq voor wat wij van topicstarts vereisen.
[ Voor 14% gewijzigd door Verwijderd op 09-04-2004 00:13 ]
