HEB PINNACLE STUDIOS 8 MET USB AANGESCHAFT. WERKT PRIMA, ECHTER:
HEB EEN OUDE VIDEOBAND INGELADEN DUUR 2.17 UUR , PINNACLE ZEGT DAT
NIET OV DVD TE KUNNEN BRANDEN , TE GROOT VOOR SCHIJF, OOK EEN IMAGE OP
HD GAAT NIET, TOEN ER EEN MPEG2 VAN GEMAAKT STAAT OP HD EN IS PLM 5 GIG
GROOT.
NU MOET DUS DIE MPEG 2 GECONVERTEERD WORDEN NAAR VOB FILES ZODAT
IK HET GEHEEL OP EEN DVD KAN ZETTEN MET BV CLONEDVD ZIE COMPRIMEERD
HET GEHEEL NAAR 1 SCHIJF,
PROBLEEM IS VAN MPEG 2 NAAR VOB FILES MET WAT EN HOE?????????
ANDERSOM STAAT ER ZAT OP INTERNET MAAR NOU NET NIET WAT IK ZOU WILLEN
EEN GROOT MPEG2 NAAR DVD SCHRIJVEN
VAST BEDANKT.
GROOT.
VAST BEDANKT.
