[Ervaringen] nVidia nForce 3.13 UDP WHQL driver package
Pagina: 1 2 Laatste
  • 991 views sinds 30-01-2008
  • Vincentio
Er is net een nieuwe driver package van nVidia uit voor de op de nForce chipsets gebaseerde moederborden.
http://www.nvidia.com/object/nforce_udp_winxp_3.13
3 ervaring draadjes van nForceshq.com:
IDE drivers
Audio
Andere dingen over 3.13
Quoted van nVidia:
Installation Notes
If you are performing an uninstall of your current nForce drivers, your system will have to re-enumerate all devices and restart prior to install of your new package. Multiple restarts may be required; please comply with all instructions to reboot. Failure to do so may cause the install to fail the installation of needed components resulting in system reliability issues.
Windows XP users must install Service Pack 1 prior to attempting to install this package. Failure to do so will result in the inability to support USB 2.0.
Audio drivers will not install on the following nForce2 products: Chaintech 7NJS. Please use the drivers that come with these products to enable audio functionality.
Release Notes
WHQL certified kit for nForce, nForce2, and nForce3
First release of NVIDIA IDE driver for Windows XP and Windows 2000
General compatibility fixes
Audio Improvements:
Realtek ALC655 codec support added
Fix for BSOD on loading DLS files
Reduced susceptibility to audio glitches under heavy system load; additional fixes for 6 channel GetPosition glitches
ASIO support for recording at sample rates other than 48kHz; lower and more predictable latency
Fixes for NOLF. The 3D minimum and maximum distance and the roll off factor were not being taken into account for air absorption. Also modified reverb gain so that the max distance was taken into account
Fix for EAX reverbs; initialized EAX reverbs to off when querying for the EAX listener interface; updated EAX property handlers to ignore invalid parameters instead of range limiting -- this matches Creative EAX behavior
Windows XP Driver Versions
Audio driver 3.66 (WHQL)
Audio utilities 3.66
Ethernet driver 3.63 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver 3.38 (WHQL)
IDE In-the-box driver 3.58 (WHQL)
IDE 2.0 NVIDIA driver 3.66 (WHQL)
Display driver 52.16 (WHQL)
Installer 3.77
Windows 2000 Driver Versions
Installer 3.77
12.9MB voor Engelse versie en 25.4MB voor de internationale.
Ik ga hem nu installeren en zal dan meteen de resultaten posten.
  • potatox
  • Laatst online: 06-10-2025
potatox
unz unz unz
Is het uninstalleren van de vorige drivers nodig of kun je gewoon deze als update gebruiken?
  • Vincentio
Ondanks dat het niet een vereiste is. Wordt het wel aangeraden om alles er netjes van af te gooien.
  • Fanatic_FS
  • Laatst online: 18:30
_PoTaToX_ schreef op 03 november 2003 @ 18:55:
uninstallen is heel erg aan te raden, eveneens als een systemrestore point aanmaken ;)
  • MikeyMan
  • Laatst online: 21:05
MikeyMan
Vidi, Vici, Veni
benches, benches!!!
Ik ben vooral benieuwd naar de prestaties van de IDE drivers... Die zijn tot op heden allemaal langzamer gebleken dan de standaard windows xp drivers, iig voor mij...
  • Fanatic_FS
net ff kleine bench gedaan, ide performance is omhoog, mijn hdd haalt nu 40mb/s voorheen 30~35
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
voorheen nforce ide drivers of voorheen microsoft ide drivers?
  • Fanatic_FS
MikeyMan schreef op 03 november 2003 @ 19:21:
microsoft drivers
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
zou het dan eindelijk....?
  • Vincentio
Hmm Sisoft wilde niet meewerken, bleef telkens hangen.
Dus maar even PCMark gedraaid.
Voorheen nforce ide in the box, aangezien SW echt niet wilde werken.
Nu SW. Lijkt nu wel te werken.
1e keer met SW kreeg ik lagere score. 2e keer lag mijn score een fractie hoger dan vroeger.
  • Vincentio
Bleh EAX in Halo is nog steeds bugged. Resultaten IDE zijn ook wisselend op nforceshq.
Audio Control Panel is dus nog steeds hetzelfde.
  • chim0
  • Laatst online: 03:03
Afbeeldingslocatie: http://www.chimo.demon.nl/hdtach30gb.JPG
maxtor 30gb 5400rpm, windows xp pro fat32
Afbeeldingslocatie: http://www.chimo.demon.nl/hdtach80gb.JPG
samsung 80gb 5400rpm, fat32
i know, binnenkort maar eens upgraden naar een 7200rpm. andere mensen met 5400rpm schijf als werkschijf op een nforce2 met deze drivers?
  • SmokeyTheBandit
  • Laatst online: 26-11 12:26
SmokeyTheBandit
DOCer met Pensioen
Ik heb last van een heel vreemd probleem......
Ook deze drivers geinstalleerd maar nu springt me monitor uit als windows wil gaan laden .... alles gaat goed ,want het geluid werkt wel perfect.
Lekker weer kan nVidia nu niet na ruim een jaar deze chipset op de markt gebracht te hebben een keer iets goeds in mekaar draaien want dit is gewoon triest......
Het probleem lijkt opgelost te zijn.
Wat ik gedaan heb is bij opstarten op f8 te drukken en voor "enable vga mode" (engelse Xp ;) te kiezen.
Wel erg vreemd want dit hoort natuurlijk niet zo ......
[ Voor 25% gewijzigd door SmokeyTheBandit op 03-11-2003 20:09 ]
Turn it off and on again.
  • Vincentio
Ik had alleen last van dat me windows vriesde na installen van drivers tijdens de reboot. Daarna wel alles goed...
  • DaOverclocker
  • Laatst online: 24-11 15:24
DaOverclocker
Overclocker for life...
Ik had met de oude drivers aldoor nog problemen met het geluid. Dat spoorde voor geen meter nadat ik de pc op standby had gezet of in hybernate.
Misschien met deze drivers verholpen?
kzal het van het weekend es proberen.
systeem specs
  • _Droopy
  • Laatst online: 08-08-2019
_Droopy
Tweaken of school?,....Hmmm..
Hee!!!! Cool! (hoop ik)
Als deze drivers goed blijken te werken, ga ik van het weekend eens een mooi schoon systeempje maken. (sorry dat ik eerst dat kat uit de boom kijk, maar ik was zowel met 2.41 als met 2.42 de L*L,.... resulteerde in een verplichte fresh install.)
MAN! ik hoop echt dat dit pakketje nu wel goed blijkt te zijn. (met of zonder die IDE-drivers)
Iemand al wat concretere resultaten behaald en/of tests gedaan?
Life is but a joke,.... But i see nobody laughing. Specs 3DMark2k1se 21671 3D Mark03 7195
  • SlowikPL
  • Laatst online: 18-08 14:37
Bij mij werken deze drivers super :)
Nu nog even testen of er problemen kommen met het branden van CD -s met Nero ( CD- text optie werkte eerder niet goed met de IDE drivers van nVidia)
Verder wel een goede preformance van de IDE - drivers en hoorbaar verbeterde audio drivers en niet aleen in spelen :)
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • Fanatic_FS
ik heb net nog even 3dmark2k1 gedraaid, score is hetzelfde gebleven
HDtach geeft op mijn systeem (maxtor 7200 rpm 2mb, nforce2ultra, xp2400+) met de nieuwe drivers de volgende resultaten:
12,6 ms access
122,6 burst
read: max 43,3, min 24,7, av 35,9
CPU util: 21,9 %
Nu lijkt de CPU utilisation mij een beetje erg hoog. Heeft iemand met een soortgelijk systeem hier misschien commentaar op?
Voor de rest werkt alles prima trouwens :)
  • xabre16v
Ik heb ze net geïnstalleerd op m'n nForce. Werkt prima, gewoon er overheen. :)
Wat is trouwens het verschil tussen IDE In-the-box driver 3.58 (WHQL) en
:? en waarom heeft Windows XP de laatste wel en 2000 niet. ?
  • Qosmic
  • Laatst online: 17:08
hmm, ik ging van 2.45 naar 3.13 en mn 3dmark2001 score was 15300 en is nu 12646, 3dmark03 was 4902 en is nu 4757 :S
Ik heb nu 2.45 er weer terug op gezet, maar mn scores zijn zo laag gebleven, erg vreemd dit.
Nah ja, ik laat het verder zo, alles werkt verder wel prima.
Epox 8rda, xp2200 en radeon9700 np @324/285
Stop chasing the dream, you're already living it
  • Vincentio
xabre16v schreef op 04 november 2003 @ 12:43:
De in de box is gewoon de windows driver, maar dan ietsjes aangepast. Voor meer ondersteuning en dergelijke.
IDE 2.0 is de driver die zelf geschreven is door nVidia. Ook wel de SW IDE driver genoemd. Deze leverde vroeger meer problemen dan voordelen. Maar de bedoeling is dat deze driver het snelst en het best werkend gaat worden voor nForce bordjes.
  • UltimateB
UltimateB
Pomdiedom
Nou , iets te optimistisch heb ik 3.13 geïndstalleerd, na de install wilde windows xp niet meer booten. Gelukkig wel in safemode, uninstall gedaan van die drivers, weer opstarten, weer geinstalleerd, wil niet op starten, weer uninstall en toen install zonder sw ide drivers en hij doet het wel...
Lekkere vage shit dus...
Asus a7n8x
Windows XP (patched)
WD 80gb 8mb
"True skill is when luck becomes a habit"
SWIS
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
ik hoor het allemaal alweer, ik ga nog niet beginnen aan deze drivers...
Is het nou zo moeilijk om hun eigen hardware softwarematig een beetje goed te ondersteunen... Mijn god... Ik snap dat écht niet he, dat ze met een nieuwe driverrelease achteruit gaan in prestaties of ineens niet meer werken. En dat ze nogsteeds een k*t prestatie neerzetten met hun ide drivers, ook zo belachelijk...
  • Turismo
  • Laatst online: 17:51
woei, niet gekke results met de nforce 3.13 driver met SW Busmaster driver geinstalleerd, ongeveer zelfde transfer rates in vergelijking met 2.45 maar een veeeeeeel lagere CPU utilisation, zo laag heb ik t nog nooit gezien.
Alleen gaar dat toen ik de oude wou uninstalleren, er automatisch voor koos om mij ATI videokaart drivers, mijn TV kaart en mij Audigy2 te verwijderen, mocht ik eerst dat weer allemaal opnieuw installeren :(, dat hadden ze toch wel beter mogen doen, niet iedereen gebruikt nvidia hardware!
hier wat pics ter vergelijking.
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=459344
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=459346
Gamebak Look Behind you, a Three Headed Monkey!
Ik heb ze gisteren geinstalleerd en ik ben zeer tevreden. Voor mijn gevoel is de PC stukken sneller dan met de 2.45 drivers. Vooral als de HD meerdere dingen tegelijk moet doen.
Door bijv. Emule werd mijn PC eerst vrij traag (wel 30 downloads tegelijk >:) ), vooral als hij een file moest completen kon ik maar beter koffie gaan drinken, de PC werd gewoon onbruikbaar (onacceptabel gezien mijn sysspecs). Nu merk ik het niet eens meer.....Hier heb ik dus lang op gewacht.
Ik ga verder geen Benches draaien, hij draait voor mijn gevoel een stuk soepeler nu, dat is het belangrijkst.
Systeemspecs:
Abit NF7
Athlon XP 1700+@2387 Mhz (217x11) 1,8 V
2x256 MB Kingston HyperX PC3500 6-2-2-2 @ 434Mhz
Seagate Barracuda 7200.7 80 Gig.
  • Qosmic
hebben jullie eerst de oude verwijderd of deze er gelijk overheen geinstalleerd?
Qosmic schreef op 04 november 2003 @ 19:23:
Ik heb eerst de oude verwijderd. Doe ik meestal als ik drivers update.....(tenzij ik erg lui ben....).
Er staat volgens mij in de installation notes expliciet vermeld dat je het per se wel moet doen.
Turismo schreef op 04 november 2003 @ 18:27:
Wow. Ik heb volgens HD tach maar liefst 22% CPU utilisation. Weet jij misschien waar dat aan zou kunnen liggen?
System Specs:
Shuttle SN45g
Nforce 2 ultra
xp2400+
Maxtor 7200 rpm 2mb
En mijn sisoft score is ook laag te noemen met ongeveer 19500
[ Voor 4% gewijzigd door Verwijderd op 04-11-2003 20:26 ]
  • smallblock
  • Registratie: September 1999
  • Laatst online: 22-11 13:49
smallblock
Aliens (& rust) ate my Buick
Gaat niet goed in combinatie met een Asus A7N8X. Eerst een uninstall van de oude 2.45 NForce drivers gedaan. Daarna de nieuwe erop. In eerste instantie leek alles goed te gaan, startte ook goed op na de eerste reboot. Toen moest de ATI driver opnieuw geinstalleerd worden. Bij de reboot hierna was einde oefening: BOD
Helaas wil ook safe mode niet booten.
Gelukkig wel vooraf een ghost image gemaakt dus 10 minuten later draaide alles weer als vanouds, pfoei.
Leuke lamp, overigens !!
  • porn*
  • Laatst online: 01-11 09:33
porn*
...take on the world!
Net de drivers geinstalleerd, lijken prima te werken. Uninstall van de oude gedaan, opnieuw gestart, mobo vindt van alles opnieuw (standaard Windows drivers ofzo) en vraagt weer opnieuw op te starten. Heb ik maar niet gedaan, zijn toch drivers die meteen weer vervangen worden.
Dus 3.13 geinstalleerd, en daarna opnieuw opgestart. Van alles wordt opnieuw gevonden, en toen nog maar ff voor de zekerheid een restart gedaan.
Net Sandra gebenched en ik ben er bijna 1MB/s op vooruit gegaan (van 26 naar 27 ongeveer). NTFS is wel een stuk trager dan FAT32 zeg, vroeger had ik op dezelfde schijf, zelfde partitie meer dan 31MB/s.
Edit: Vergeten, Windows voelt VEEL sneller aan en dat komt omdat IDE transfers de rest van het systeem niet meer ophouden, wat vroeger wel was.
Ook de sound corruption en schokjes in games tijdens bijv. het draaien van spellen is nu over. Overall is de 'feel' van Windows en de reactietijd van het systeem dus stukken better, mooie drivers!
Edit2: Score lijkt ongeveer hetzelfde te zijn, kan het niet precies vergelijken omdat ik niet dezelfde klokspeeds draai maar het was ongeveer wat ik verwachtte. Nogmaals: DAMN wat voelt Windows een stuk relaxter zeg ;)
[ Voor 33% gewijzigd door porn* op 04-11-2003 22:29 ]
Bnet pindle#2913
  • ModmaN
  • Laatst online: 27-07-2015
ModmaN
Damn i'm good
ik hoop dat hiermee ook mijn problemen zijn opgelost.
audio klopt echt geen hout van, ten eerste wil hij 5.1 niet onthouden wat zwaar irritant is, en ten tweede, klinkt hij op mijn ht, link met coax, zwaar klote als ie niet op decoden staat, maar dus gewoon stereo, en als ik de achterluidsprekers zachter zet, hoor ik niks meer, dit klopt dus niet, ik hoop dat het probleem hiermee is opgelost, dus ik zal ze ff downen en installen en dan horen jullie de resultaten wel
get rich or die try'in
Smallblock schreef op 04 november 2003 @ 21:22:
Dit zelfde had ik ook met een ASUS A7N8X rev. 1.06 BIOS 1.07.
Ik dacht eerst dat het aan mijn overclock lag maar ik deed "laatst werkende configuratie" booten en toen deed hij het gelukkig wel weer. Eerst dus idd een BSOD en ook veilige modus werkte niet.
  • UltimateB
UltimateB
Pomdiedom
Verwijderd schreef op 04 november 2003 @ 23:39:
Hmm, hier dus ook een a7n8x en ook problemen... geen boot meer maar wel veilige modus... alles weer goed als ik geen ide driver install...
Kan misschien aan mijn hd liggen krijg bij bios na de ide detectie ook een rare fout, zo ff opschrijven en dan post ik em wel...
Primairy IDE channel no 80 conductor cable installed. Iemand enig idee? Denk dat dit wel eens te maken kan hebben met dit probleem.
[ Voor 11% gewijzigd door UltimateB op 05-11-2003 01:37 ]
SWIS
porn schreef op 04 november 2003 @ 21:30:
Ik heb precies dezelfde ervaring :). Echt een verademing vind je niet? En idd als ik bijv. veel grote files kopieer van de ene naar de andere schijf kan ik gewoon alles doen zonder dat ik merk dat ik aan het kopieeren ben. Dingen lijken ook sneller op te starten etc. In games merk ik geen verschil echter....dat ging altijd wel soepel eigenlijk, ook nooit last gehad van haperend geluid.
  • smallblock
smallblock
Ik had helaas geen goede "last known good"
Als proef op de som heb ik de 3.13 op een verse installatie losgelaten ( was het toch onderhand tijd voor :) ) en nu gaat het wel goed. Heb hier btw een A7N8X deluxe rev2.0 bios 1.07. Het ligt blijkbaar niet aan het mobo zelf, maar aan andere factoren.
  • all_by_myself
  • Laatst online: 02-11 18:40
all_by_myself
Per Ardua ad Astra
Ultimateb schreef op 04 november 2003 @ 23:45:
Gebruik eens een Ultra DMA 66/100 kabel ipv een DMA33 kabel... Dat helpt.
Zijn er nog mensen met een EPox 8RDA+ die deze drivers hebben geprobeerd ?
AMD Ryzen 9 5900xt, 32GB, Win11 x64
  • Eindhoven657
  • Laatst online: 11-05-2025
Heb ze gisteren ook geïnstallerd. Gewoon over de bestaande drivers heen en ik moet zeggen het "voelt" gewoon goed.... Maar ik ben vooral blij met het feit dat ik nu eindelijk met Hardware acc. goed geluid heb in Bf1942. Voorheen kreeg ik dan een heel erg dof geluid en miste je heel erg veel geluiden. Noodgedwongen stond hij op Software, dit veroorzaakte gekraak. Verder nog niet met andere spellen geprobeerd, maar voorlopig ben ik tevreden. :)
  • UltimateB
UltimateB
Pomdiedom
all_by_myself schreef op 05 november 2003 @ 10:29:
IK had een topicje geopend en idd , bij het proberen kwam ik er achter dat mijn kabel niet goed aangesloten was (doh). Maar nogsteeds als ik de SW IDE drivers installeer kan ik niet meer booten (behalve in veilige modus of last know good config).
Binnenkort maar ff fresh installen...
(OS) Windows XP Professional, Service Pack 1 (5.1 - 2600), (installed for) 26w 5d 22h 7m,
Is wel weer tijd.
edit2:
a7n8x nondeluxe 1.04
[ Voor 17% gewijzigd door UltimateB op 05-11-2003 11:59 ]
SWIS
  • porn*
porn*
WimP: heerlijk gewoon, zo groot is het verschil :)
Eindhoven: dat had ik dus ook, maar alleen als ik Prime95 oid aan had staan (hoge loads). Nu niet meer, lekker stressen en gamen tegelijk ;)
Voor alle mensen die niet kunnen booten: wat voor board hebben jullie dan? Is het een Deluxe of juist niet? 1.x of 2.0?
Hiero een 2.0 non-Deluxe en alles is ok. Weten jullie zeker dat jullie ALLE oude troep verwijderd hebben?
Bnet pindle#2913
ik heb ze gewoon over die ouwe geinstalleerd hoor
  • SyncMaster
  • Laatst online: 05-10 17:10
ik heb gisteren ook eens geprobeerd om ze te installeren op een Chaintech 7NJS. Na reboot weigerde windows om op te starten. Het scherm met het lopende blauwe balkje werd niet eens bereikt. Ik blijf voorlopig bij de 2.45
  • xabre16v
Ik vind het wel jammer dat de IDE 2.0 NVIDIA driver 3.66 (WHQL) er alleen voor Windows XP is en niet voor Windows 2000. ;(
  • EfBe
Ik heb ze er weer afgegooid. De reden hiervoor was dat ik in het spel Chrome om de 1.5 seconde een schok had in de graphics. Die had/heb ik niet bij 2.45 WHQL. Erg weird. Ik merkte overigens ook niet echt bar veel verschil in windows snelheid of hdd snelheid (epox 8rd3+ winxp sp1, IBM 2x30GB (non raid))
Creator of: LLBLGen Pro | Camera mods for games
Photography portfolio: https://fransbouma.com
  • CH4OS
CH4OS
It's a kind of magic
Hoe doen deze drivers het, met de Abit NF7-S (rev. 2) want de vorige drivers, verziekten mijn PC... Dus ik terug naar de oude... Kijlde hij ook fijn me Detonators eraf :( En never nooit meer goed kunnen zetten -> Tot ik me PC opnieuw kon installeren... Dus ik ben beetje huiverig, voor die drivers...
EDIT:
* CH4OS bookmarkt toch maar even...
[ Voor 8% gewijzigd door CH4OS op 05-11-2003 13:45 ]
  • StanTheMan
  • Laatst online: 18-11 23:27
vindt het zelf relaxed dat ie met deze drivers de muziek van winamp niet standaard over alle 6 speakers afspeelt. Mijn achterste boxjes zijn toch minder mooi voor muziek, met de vorige drivers moest ik handmatig 2 speakers instellen.
(dit alles terwijl de instelling wel op 6 speakers blijft staan, waarbij het in spellen dus goed werkt)
Heb zelf een MSI K7N2Delta ILSR en mijn HD zit op de Serial ATA, zou het nut hebben om deze drivers erop te zetten?
Ik werk nu nog met de MSI drivers (hebben het nummer 2.78)...
Heeft iemand ervaring met dit bord, en deze drivers?
  • X-G
  • Laatst online: 30-07-2024
X-G
Yeah.
Ben ik dan de enige die wel tevreden is met de 2.45?
Die heb ik hier nogsteeds draaien, onder volle tevredenheid.
700 MB van hd naar hd overpompen (Maxtor 120 GB 8MB naar 40 GB 2MB) gaat in ongeveer een halve minuut, en dat vind ik toch behoorlijk snel :)
Dus voor mij geldt iig: if it aint broke...
ToyzBuilder YouTube - Gratis Bitcoin Verdienen
  • porn*
porn*
X-G schreef op 05 november 2003 @ 16:14:
Het ging ook wel snel, wat dat betreft scheelt het niet zoveel, probleem was alleen dat bij hoge loads (CPU, mem) of veel schijftoegang alles een stuk trager reageerde. Als mijn harddisk flink aan het kopieren was, merkte ik vertragingen bij het uitvoeren van acties of het opstarten van schermpjes (beeldschermeigenschappen bijv.). Nu zijn die verdwenen en voelt mijn systeem pas echt lekker snel aan.
Bnet pindle#2913
  • ModmaN
ModmaN
Damn i'm good
ik heb ze er inmiddels ook opstaan, inclusief ide drivers. dat is dus huilen met de pet op, boot niet meer, zowel veilige modus of last known good configuration.
ik heb een asus a7n8x deluxe gold rev. 2.0 bios 1005, met een athlon xp 2600 @ 200 mhz.
iemand enig idee hoe ik in de herstelconsole de oude ide-drivers terug kan zetten, ik zit nu net niet op een format te wachten :(
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
configuratiescherm ==> systeem ==> apparaatbeheer ==> terugzetten oude drivers?
edit: nieuwe bios versie al geprobeerd?
[ Voor 28% gewijzigd door MikeyMan op 05-11-2003 19:39 ]
  • ModmaN
ModmaN
Damn i'm good
MikeyMan schreef op 05 november 2003 @ 19:38:
dat gaat nogal moeilijk als ik in de recoveryconsole zit :?
  • CH4OS
CH4OS
Laat maar... Het werkt ineens weer... :?
[ Voor 102% gewijzigd door CH4OS op 05-11-2003 21:16 ]
  • porn*
porn*
Natuurlijk maak je vantevoren ook wel even een Restore Point, vooral als je ziet hoeveel mensen er gezeik mee hebben :)
Maar ik vraag me toch af of dat niet een specifieke oorzaak heeft, zoals misschien oude drivers die gezeik veroorzaken ofzo...
Bnet pindle#2913
  • SyncMaster
Ik krijg ook de indruk dat mensen met een zuiver (pas geïnstalleerd) systeem veel minder problemen hebben met de installatie van de nieuwe drivers. Ik heb mijn pc al een jaartje niet meer geformatteerd dus hier zijn waarschijnlijk nog serieus wat oude drivers op terug te vinden die (blijkbaar) conflicteren met de nieuwe, hoewel ik de oude toch altijd geuninstalled heb vooraleer er nieuwe op te zetten.
De nieuwe krijg ik niet aan de praat op mijn systeem dus ik ga de 2.45 nog een tijdje gebruiken
[ Voor 11% gewijzigd door SyncMaster op 05-11-2003 21:37 ]
  • ModmaN
ModmaN
Damn i'm good
back from format with new nforce drivers
whooooooooooooooooooooooooot thats fast :P
damn, wat zijn die drivers lekker na een format c
heb al eerder geprobeerd, maar enkel result met BSOD en niet te fixen :(
nu nog ff kijken of audio ok is, ik laat me sblive platinum er wel inzitten. maar dat heeft andere functies.
/edit
gelijk ff een ghostfile maken
[ Voor 6% gewijzigd door ModmaN op 05-11-2003 22:55 ]
  • BuG2FiX
  • Laatst online: 17-08 17:44
Ik heb een EPOX 8RDA+ (nforce2) en precies hetzelfde probleem, installeert en opnieuw opstarten, dan blijft ie hangen op het windows logo en gaat niet meer verder. vanalles geprobeert maar nu gewoon 2.45 teruggezet dmv veilige modus.
klotedrivers dus icm mijn moederbord in ieder geval, laat maar lekker zitten, de vorige driver update staat nog vers in mijn geheugen.... grrrr
  • l-burna
  • Laatst online: 29-11 17:30
l-burna
2nd place, is the 1st loser
BuG2FiX schreef op 05 november 2003 @ 22:59:
ik dacht dat ik de enige was,
blijft ook bij mij hangen, heb zelfde moederbord
The older I get, the better I was. -=]No Fear[=-
  • SuperPaddo
(overleden)
Bij anderen blijkt ie wel te werken met een 8rda+?
Ik ga iig met een dag of 2 a 3 windows reinstallen, en ik zie wel of mn 8rda+ die drivers liev vindt :).
Grolsch Royce!
  • dynax
  • Laatst online: 22-11 18:20
Bij mij gaan ze als een speer, geen problemen hier, gewoon over de oude heen gezet.
Merk qua preformance niet zo veel verschil, omdat ik in de 2.45 de sw ide driver van de 2.03 heb gebruikt.
Maar de hd wordt nu niet meer als een scsi schijf aangemerkt, en bij eigenschappen kun je nu vanuit windows het een en ander instellen, erg makkelijk.
Ook had ik met de 2.45 geen problemen met het geluid.
Alleen bij het afsluiten gaf de hd met de 2.45 4 tikken voordat de pc afsloot, al gaf dat ook geen problemen.
En voor het eerst heeft ie nu een driver voor m'n gf 4 geinstalleerd. (5216), dat gaat ook prima.
Al met al een goed driverpack voor mij. :)
mijn systeem.
WOHOO!
ik had altijd problemen op mn A7N8X-X mobootje van asus..
zie ook:
Ruis in A7N8X onboard sound, BIOS update lukt niet
A7N8X onboard sound ruist en stekker past niet
Brom/gekraak uit speakers /Mobo sound onboard A7N8X
met deze drivers is het nu eindelijk voorbij :)
Audio Improvements:
[ Voor 24% gewijzigd door Verwijderd op 06-11-2003 00:45 ]
  • MadBear
  • Laatst online: 16:42
Ik kreeg in eerste instantie een BOD in XP maar na wat rebooten loopt ie :)
Alleen, vertikt ie de Memory Controller drivers te installen.. als ik ze handmatig wil updaten, geeft ie als foutmelding 'access is denied' ..
iemand een idee?
en ik ben gewoon ingelogd als Administrator hoor, ik heb gewoon alle rechten ;)
  • Belgar
  • Laatst online: 17-08 22:31
Belgar
Archmaster ranzige code..
Voor mij werkt ie prima. asus deluxe rev2. Had alleen in het begin wat last met de sound (max 24 kanalen), maar dat bleek een verkeerde instelling te zijn.
10-20 3d markjes(2003) dus daar hoef je het niet voor te doen. ;)
Wel is de FPS in de '60 sounds test' 1-2 verhoogd wat kan duiden op wat minder CPU belasting voor de sound.
IDE throughput is OK. In ieder geval niet slecht genoeg om ze niet te installeren :P . Als het verhaal van de verminderde CPU belasting klopt zie ik in ieder geval geen reden meer om ze niet te gebruiken.
...Als het maar werkt
  • sjolmers
  • Laatst online: 04-02 09:18
sjolmers
het leven is té kort, geniet!
Heb ze net op mijn Shuttle SN41G2 gegooit, en het eerste wat mij opvalt is dat mijn 5.1 geluid voor het eerst direct goed werkt en ingesteld staat, dit was voor heen een enorm gezeik en gepruts...dus das al heel positief.
Verder heb ik het gevoel (je moet ergens beginnen) dat de HD inderdaad sneller de data doorvoert. Ik ga later nog wel ff benchen.
Maar tot zover dus zeer positief.
[ Voor 4% gewijzigd door sjolmers op 06-11-2003 11:10 ]
adr opleidingen en meer adr opleidingen
  • sjolmers
sjolmers
dubbelpost!
[ Voor 97% gewijzigd door sjolmers op 06-11-2003 11:09 ]
  • KinG PopLa
  • Laatst online: 24-08 09:00
Systeem lijkt bij mij sneller te lopen (Leadtek Nforce2 IGP MCP-T), maar ik kan met nero (6)niet sneller branden dan 4x (met hp 10x brander), en alcohol kan me echte cd drives niet zien?
Iemand al een workaround (heb IDE-SW geinstalleerd)
WinXP pro SP1 Dx9.0b
SB: Audigy
Radeon 9500@9700 (cat 3.9)
  • Canis Lupus
  • Laatst online: 13:26
Canis Lupus
Vosbot
Hier net ook de 3.13 geïnstalleerd. Eerst netje de oude verwijderd, reboot en toen nieuwe geïnstalleerd. Ook gelijk nieuwe Catalyst 3.9.
Na de reboot kom ik met geen mogelijkheid meer in windows :'(
Safe mode niet, Last know good niet :( :(
Ook na het repareren met de WinXP CD gaat het niet werken.
Hij zegt bij de reboot dat ik een Chkdsk /f op mijn harde schijven moet uitvoeren, maar ook na dat te hebben gedaan blijf ik een BSOD krijgen:
A problem has been detected and windows has been shut down to prevent damage to your computer.
<knip>
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check you hard drive to make sure it is properly configured and terminated.
Run CHKDSK /F to check for hard driver corruption, and then restart your computer.
Technical information: *** STOP: 0x0000007B (0XF8950640,0xC0000034,0x00000000,0x00000000)
Kan iemand hier iets mee?
Een reïnstall is misschien wel noodzakelijk, maar kan ik mijn mail en documenten sinds de laatste backup nog redden? COPY lijkt ook niet te werken vanaf de recovery console...
Muziekcollectie CD's&LP's - Wat luister ik nu? - Ericdevos.nl
  • MikeyMan
MikeyMan
Vidi, Vici, Veni
gewoon directory c:\windows verwijderen, en eventueel ook c:\program files...
Dan windows opnieuw installeren... Hoop voor je dat je geen ntfs hebt, anders zul je hem even in een andere computer moeten hangen...
  • sjolmers
sjolmers
KinG PopLa schreef op 06 november 2003 @ 15:07:
SB: Audigy
Ik had hetzelfde probleem bij Alcohol120%, was mijn PLextor DVD-brander weg....
heb het opgelost door in de instellingen onder General de device control interface op windows NT/2000/xp atapi/scsi.... te zetten.
  • Okyah
Okyah
wespachterrrrrfilm..
Geen problemen hier (@ a7n8x deluxe) met de installatie enzo, maar ik heb nu wel dat als een schijf uitgezet wordt deze na enkele minuten weer vrolijk upspint, ook al is er niets dat van de schijf gebruik maakt. Het betreft hier maar 1 van de 2 schijven (de master). Heel vreemd 8)7
Alone at last
Just nostalgia and I
We were sure to have a blast
  • Priet
  • Laatst online: 20:38
Priet
To boldly do what no one has..
StanTheMan schreef op 05 november 2003 @ 13:56:
Dit is zooo zwaar irritant!! Ik wil gewoon muziek horen over m'n voorste én m'n achterste speakers! Met de oude drivers ging het wel goed, en nu opeens niet meer? 8)7
Instellingen op 2, 4 of 6 speakers maakt allemaal niet uit. Met WinAmp blijft 'ie het geluid alleen over de frontspeakers geven, met WMP doet ie het dan weer wel over alle vier de boxen :X
Het mobo is een Gigabyte 7N400-Pro met SoundStorm.
Kun je dit weer goedkrijgen? Ik wil gewoon weer lekker muziek kunnen luisteren! :(
"If you see a light at the end of a wormhole, it's probably a photon torpedo!"
  • warp
SuperPaddo schreef op 05 november 2003 @ 23:19:
Yep. Op mijn 8RDA draait v3.13 tot nu als een trein. Geen crashes, hangers of wat dan ook. Plus betere memory performance en veel minder CPU gebruik bij disk I/O.
De meeste problemen ontstaan doordat de oude drivers niet (goed) verwijderd zijn of door ze gewoon klakkeloos te installeren over de bestaande heen (tip: gebruik DriverCleaner).
Edit: Het enige vreemde dat me tot nog toe is opgevallen is dat de IDE-SW driver de gekozen instellen bij 'Select Transfer Mode' niet onthoudt maar steeds terugschiet op 'BIOS Default' (na een reboot). De 'Current Transfer Mode' instelling blijft wel gewoon bewaard. Lijkt me een bug, maar is verder niet zo spannend daar de 'Current Transfer Mode' wel bewaard blijft.
[ Voor 27% gewijzigd door warp op 06-11-2003 18:48 ]
  • KinG PopLa
sjolmers schreef op 06 november 2003 @ 18:03:
Dit werkt!
top!
Dacht zelf de madness met de recente 3.13 te kunnen ontlopen maar nee.
Systeem:
Amd Athlon XP 1800+ (Palomino)
Asus A7N8X Deluxe rev 1.03 (bios 1007)
Elixir 256mb ddr (2 maal) (Nanya chips)
ATi Radeon 9000 (Catalyst 3.9)
Memorex 32x12x40 Intern
Alles ging goed met de nieuwe 3.13 nForce drivers tot ik cd's wil branden. De drivers laten Nero vastlopen en of dat niet genoeg is het hele systeem als je niet op tijd reboot of afsluit. De nieuwe drivers bieden de IDE gedoe optioneel aan, heb ik verder niet gechecked en ben weer terug gegaan naar 2.64 ... geen problemen met deze versie voor mij.
Een enorme verbetering, vooral het geluid is nu een stuk strakker al had ik wel wat problemen met het installeren van mijn onboard soundcard. Alles loopt nu ook een stuk vlotter.
Epox 8RDA3+
AMD Athlon XP 2400@2340Mhz
512ddr sdram pc2100@pc2700
Geforce 3 ti200@ti500 speeds
  • Belgar
Belgar
Canis Lupus schreef op 06 november 2003 @ 17:18:
Ooit geupgrade van een via chipset ?? Dit probleem had ik namelijk ook. gewoon windows reinstall gedaan (over oude heen niet geformateerd oid). Daarna werkte alles weer perfect. Heeft blijkbaar te maken met een interrupt oid die VIA drivers reserveren. Kan natuurlijk in jouw geval iets anders zijn. Heeft overigens geen enkel data verlies tot gevolg. Gewoon windows over de oude laten installeren.
  • --MeAngry--
  • Laatst online: 18:58
--MeAngry--
aka Qonstrukt
Ik merk dat deze drivers hun werk het beste doen bij een verse installatie, dat is meestal zo btw met chipsetdrivers (net als bij videokaarten overigens), kheb gister ook even een verse installatie gedaan met de nForce v3.13 drivers en Catalyst 3.9 met m'n Abit NF7-S rev2 en Radeon 9700 Pro AIW en ik kan jullie vertellen, m'n bak gaat nu echt als een SPEEEERRRRRR!!! :D
MeHappy!!!11 ;)
Tesla Model Y RWD (2024) ▪︎ Daikin Altherma 3 6kW (300L SWW) ▪︎ 20x AIKO NeoStar 2S+ 465Wp ▪︎ Sigenergy SigenStor EC 10+10 (12kW + Gateway HomePro TP)
  • xabre16v
Hmm eergisteren die nForce 3.13 geïnstalleerd, maar nu brand ik met Nero random kapotte foute cd's. Cd's worden wel gebrand en lijken het goed te doen maar als ik probeer het programma's te installeren wat er op staat dan zegt ie dat hij bestanden niet kan vinden. :?
Bij mij draait het als een speer !! >:)
  • _Droopy
_Droopy
xabre16v schreef op 07 november 2003 @ 16:10:
Heb je deze drivers met of zonder IDE drivers geinstalleerd?
[ Voor 90% gewijzigd door Verwijderd op 07-11-2003 19:37 ]
  • xabre16v
_Droopy schreef op 07 november 2003 @ 18:33:
Met de NVIDIA IDE SW drivers.
Microsoft IDE drivers:
Met HD Tach
82.7 MB/ps Max
15.6Ms Random Seek
CPU Util 54.2 :(
Met nieuwe drivers en SW Drivers
HD Tach
86MB/ps Max
15Ms Random seek
CPU Util 24% :)
  • mrboomblaster
  • Laatst online: 18-07 11:33
bij wilde de memory controller nie echt werken. kreeg steeds bsod met 0x0000000A er in verwerkt en na wat zoeken bleek dat dat iets te maken had geheugen. ach ja ff de oude gepakt en werkt weer als een zonnetje :) .
D2 acc: *Mrboomblasterhc
  • Brainless-NL
  • Laatst online: 26-03 15:54
Brainless-NL
lolkipo
ik vindt het maar matig! Mijn onboard lan wordt niet goed geinstalleerd. Over de oude drivers heen installeren is ook niet echt aan te raden. M'n comp wilde niet meer booten. vervolgesn opgestart in last known good configuration. Toen 2.45 eraf, 3.13 erop, 3.13 eraf, 2.45 erop :)
Bij mij lopen deze drivers opzich goed afgezien van het verotte geluid maarja in in ieder geval geen vastlopers met opbooten :P
Heb een 8rda+ btw. wel met een clean windows install!
ik heb ook geen echt goed geluid na een clean install, morgen maar weer de terratec geluidskaart erin gooien :p, wel goed geluid alleen rotte drivers
  • _Droopy
_Droopy
De goeie ervaringen die er hier zijn met deze drivers en betere audio, is dat met "ACPI" opf met die "standard pc" setting?
  • Vincentio
Ik draai met ACPI. Alleen ik luister niet zo intensief naar geluid op de PC. Daarvoor heb ik een goede stereo (surround) installatie.
  • porn*
porn*
Ik heb ACPI afstaan, al voor de install vanuit de BIOS gedaan.
Bnet pindle#2913
  • ChefChocolateball
  • Laatst online: 22-10 09:45
Oude Nforce drivers eraf gegooid, zoals aangegeven paar x gereboot en de nieuwe erop gegooid....
Leek goed te gaan, maar toen kreeg ik spontane reboot. Na deze reboot kan ik nie meer in windows komen. Voordat het winxp opstartscherm komt krijg ik nu altijd een blue-screen :( Ook in veilige modus opstarten helpt nie, en laatst bekende goede configuratie ook nie :(
Iemand een idee wat ik kan doen? Iemand ook dit probleem of bij eerdere nforce drivers gehad?
Specs: A7N8x deluxe
[ Voor 3% gewijzigd door ChefChocolateball op 10-11-2003 10:08 ]
  • Belgar
Belgar
ChefChocolateball schreef op 10 november 2003 @ 09:52:
Specs: A7N8x deluxe
bovenstaande 7B error ? zo ja. 'gewoon' windows over de oude heen installeren.:
INSTALL kiezen. (niet repair)
vervolgens detecteerd windows dat er al windows opstaat. Biedt wederom aan om deze proberen te repareren. deze optie dan wel kiezen. Vervolgens 20 minuten wachten en alles is wederom in orde ;)
Verschil tussen repair en 'install-repair' is dat de laatste optie gewoon domweg over de oude copieerd en dat werkt wel. Overigens blijft je registry ongedeerd dus geen functionaliteits verlies.
  • BigKahunaH
  • Laatst online: 25-11 10:38
BigKahunaH
Royal with cheese...
Dat is geen prietpraat Priet! Ik vind het ook een probleem in tegenstelling tot stantheman dat ik nu alleen over mijn voorste boxen muziek heb. Met windows media player hoor ik het geluid echter wel over de achterste boxen. Een herinstallatie van musicmatch (winamp is k*t) mocht ook niet baten. Iemand een idee om dit toch aan de praat te krijgen. Het lijkt dus toepassingsgebonden, maar in musicmatch kan ik geen enkele instelling vinden mbt boxen etc.
Iemand?
BigKahunaH
  • BigKahunaH
BigKahunaH
Om met winamp het geluid weer over de rear speakers te rkijgen vond ik hier een oplossing:
http://www.betaresource.n...topic=594&st=0&#entry1975
Nu nog kijken of ik voor musicmatch een gelijke oplossing kan vinden.
[ Voor 14% gewijzigd door BigKahunaH op 10-11-2003 12:16 ]
BigKahunaH
  • MPAnnihilator
  • Laatst online: 20-11 10:33
Ik had dit ook met winamp , ik heb dewoon die digital en analog toestanden uitgevinkt, ff headphones geselecteerd. Dan die dig en analog weer aan , en dan geswitched met die wizard naar 6 speakers, in surround modus en via analog , dit alles met winamp gesloten. Nadien winamp terug opgestart en ik had weer geluid uit de 5 boxen. Dit op een Epox 8rda+ nforce2.
Mijn Specs
  • BigKahunaH
BigKahunaH
Ik heb de altijd werkende oplossing uitgevoerd, namelijk de audiodriver van de oude unified driver pack handmatig geïnstalleerd.
Geluid door de achterste boxen...
BigKahunaH
Wat een exteem lage cpu utilisation zeg!
Ik heb 22.5%
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=474218&size=384
Maar die ide driver doet ook niet zoveel bij mij. Het is een sata schijf ;)
  • Masselink
  • Laatst online: 24-11 21:39
Masselink
Voor de dorst
Ik ben heel blij met deze drivers geen problemen ! Pas wel op met die driver die in de Windows update zit, want die verziekt bij mij alles.
Asus A7n8x Deluxe met Barton 3000+@3200+
Wireguard VPN Client: https://github.com/masselink/MasselGUARD
  • Sjokoprins
  • Laatst online: 16-10-2023
  • Countess
  • Laatst online: 19-07 01:41
Priet schreef op 06 november 2003 @ 18:28:Dit is zooo zwaar irritant!! Ik wil gewoon muziek horen over m'n voorste én m'n achterste speakers! Met de oude drivers ging het wel goed, en nu opeens niet meer? 8)7
bij mij is het gelukt.
ik moets dolby surround encoding uit zetten, en toen werkte het prima.
o btw de CPU gebruik van hd tach 2.70 is verneukt.
met 2.61 had ik 7.8% gebruik en toen ik 2.70 had geinstalleer was het ineens meer als 20%
zelfde windows zelfde sessie zelfs nog. lag dus echt aan het programa
btw, scores met nieuwe ide drivers waren max 65mb/s (woot!) minimum 15mb/s (een uitschieter) gemiddelde 47.5mb/s (woei!) en 7.8%
dat was met hd tach 2.61
met hd tach 2.70 heb ik : 66.7MB/s max 23.8mb/s minimum. 48.8mb/s gemiddeld 20.5% cpu gebruik (burst rate was 111.1mb/s, 2.61 gaat maar tot 80mb/s)
btw, installatie van drivers ging bij me vrij probleem loos
heb eerst via add/remove programes de Nforce drivers geuninstalleert.
toen gereboot. en windows de standaard drivers laten installeren.
toen de nieuw erop gezet en gereboot.
alleen de netwerk deed even wat moeilijk maar na een 3de reboot ging dat ook prima.
[ Voor 47% gewijzigd door Countess op 10-11-2003 16:57 ]
mijn spelling is niet best, maar wel beter als je haar. ga jij je ook verbeelden dat mensen rare dingen over je spelling gaan zeggen als hun haar er niet uit ziet? andrelon helpt!
Pagina: 1 2 Laatste
