Medion 2819 TV kaart
Pagina: 1 ... 6 7 Laatste
  • 15.749 views sinds 30-01-2008
  • Acheron
  • Laatst online: 17-11 23:15
Acheron
updatepack.nl
IK zou zeggen, probeer de FlyPlatinum of de FlyPrime drivers eens. Mocht blijken dat 1 van deze twee niet te werken, kan je alsnog de met de medion 2819 meegeleverde drivers proberen.
Zeg nee tegen bloatware. Download Nero Lite!
  • Acheron
Acheron
updatepack.nl
En Fly 2000 TV 2.38 RC 2 is uit!
Version 2.38 RC2 (Release Candidate 2):
> FLY2000TV distribution kit now included Freeware tool -
MDM TVGuide Updater, which is intended for automatical download
and update EPG in FLY2000TV (while only with Russian interaface).
> Added feature for manual adjust AGC in HF module Philips TDA8275.
> Added feature for adjust sound FM deemphasis in HF modules from
Philips MK3 series (and compatibles).
> Added feature for set Philips SAA713x FIFO buffer size to 896 bytes.
> Changed aspect for AVI recording - now video processing for record
are visible at viewing during record. Preview Pin is no more used
during AVI and MPG recording.
> Improved compatibility with TV tuners, where are WDM driver has
not Preview Pin.
> Workaround to avoid sometimes incorrect autodetect SECAM on SAA713x.
> Improved compatibility with 4-ch sound card and support output for
4 channels via DirectSound Renderer (output audio via PCI DMA transfer).
> Fixed bug with "floating" horizontal strips at work with TDA8275 HF module.
> Improved picture quality (less noise) at work with HF module TDA8275.
> Fixed bug with sound remaining at exit or suspend to tray action from
mini-window mode.
> Fixed bug to sound missing at start channel's surfing when audio output
selected via PCI DMA transfer.
> Fixed bug to reset TV audio channel choise (stereo/dual) to stereo mode
at channel switching and switch to TV mode.
> Workaround to sound missing in FM mode on card LifeView FlyPlatinum 35FM
at activate Remote Control RM-050.
> Fixed bug to FM frequency offset at work with HF module Philips TDA8275.
> Fixed bug with reset SAA713x video gain to default value.
> Fixed bug under Windows XP at use feature "Video on desktop", if Active Desktop
is active.
> Fixed bug with showing mouse cursor at switching channels in full screen
mode, if used individual Zoom settings.
> Improve English translation for FLY2000TV interface.
> Some bug fixes.
Snelle blik werpt mij helaas alleen wat bug-fixes toe :/
[ Voor 30% gewijzigd door Acheron op 07-02-2005 21:44 ]
  • henkleerssen
henkleerssen
Your life is as you narrate it
Ik dacht.. ik ga eens ff wat experimenteren met de medion software. Ik dus van medion.de site tvfm tuner (nieuw?) gedownload. Krijg ik een duitse beperkte versie ervan. Raar maar waar (kreeg geen verschillende itnerlace opties bijvoorbeeld).
Vervolgens dacht ik de tvfm tuner software weer terug te zetten van cd (functioneel is het wel)... maar dat ging dus niet! Kreeg een of andere foutmelding: 1033.mst transform path missing.
EEuhh.. met andere woorden .. wie wil me de orginele tvfm tuner software eens sturen?
Alvast bedankt!!
  • eXistenz
  • Laatst online: 29-08 10:35
Is er iemand die deze kaart werkend heeft onder windows xp media center ?
Ik krijg steeds melding in media center dat er geen tv tuner kaart geinstalleerd is of niet goed geinstalleerd
  • Acheron
Acheron
updatepack.nl
Werkt het dus niet >:)
Was ook wel te verwachten natuurlijk aangezien Microsoft deze kaart niet ondersteunt O-)
  • eXistenz
hp38guser schreef op donderdag 06 januari 2005 @ 21:39:
Dat ze het niet ondersteunen wil niet altijd zeggen dat het niet werkt ;)
  • d0s
  • Laatst online: 08:48
d0s
sssst
voor mensen die afstandsbediening willen gebruiken in dscaler, download girder!
http://www.promixis.com/downloads.php
en de plugin:
http://www.girder.nl/exportgr.php
  • gp500
Ik heb deze kaart maar windwos zet hem bij netwerk mogelijke adapters. ?
Is er ook een driver van medion (behalve de standaard tv-software), nu is het een windows driver die het regeld.
  • Emcee
  • Laatst online: 18-11 20:30
gp500 schreef op vrijdag 07 januari 2005 @ 17:23:
Op de medionsite even zoeken maar md2819 bij service en ondersteuning,
of je pakt gewoon de drivers van de avermedia 303p (zelfde kaart nl.)
http://www.medion.com/nl/
hier vind je een programma ftedit om de kanalen lijst van de medion tv kaart mee te bewerken en zelf de frecuenties er mee in te voeren in freq.tbl werkt prima onder xp met sp2 werkt hij prima heb wel directX 9.0c geinstaleerd en dat scheeld een hoop ruis
ftedit op http://www25.brinkster.co...ta/ftedit%20download.html
Weet er iemand hoe ik aan de girder plugin kan komen?
Alle voorgaande links blijken dood te zijn. :(
  • Emcee
Verwijderd schreef op dinsdag 01 februari 2005 @ 21:47:
Hier staat ie wel tussen, de saa713x plugin:
http://www.promixis.com/d...odName=Girder&lucCode=800
Bedankt, gevonden. Nu nog effe proberen.
Srry voor de kick, maar nu heb ik een probleem met dit kaartje ...
Het beeld is sinds kort (voor zover ik weet niks geinstalleerd) heel licht en wazig ...
Heeft iemand hier een verklaring voor
Ik heb alles al opnieuw geinstalleerd ... drivers opnieuw geinstalleerd ... nieuwe drivers geinstalleerd ... opnieuw kanalen gezocht, maar niks helpt
Als ik dan een screen wil nemen is alles wel weer normaal O-)
Het is trouwens ook bij composite en S-Video
Heeft iemand hier een verklaring voor 8)7
Hallo
Ik heb deze kaart ook, en om mijn kanalen in te stellen wil ik dat progmagic programma gebruiken.
Als ik dan mijn freq.tbl file verander, kan ik TVFM niet meer opstarten.
Dan geeft ie een error iets over multiple country codes of zoiets.
Iemand anders ervaring met dit probleem?
Khoop dat iemand me kan helpen!
thanks!
  • Emcee
Verwijderd schreef op vrijdag 04 november 2005 @ 18:07:
Hallo
thanks!
Ik had laatst hetzelfde toen ik de kaart opnieuw installeerde, en ik de originele freq.tbl verving door mijn aangepaste versie. Ben er toen niet uitgekomen wat nou precies de oorzaak was helaas. Heb gewoon maar weer de kanalen opnieuw gescant. Nu gebruik ik dscaler voor het tv-kijken.
nou het probleem dat de software de "country" niet herkent of zoiets heb ik al een keer eerder gehad, maar toen heeft iemand mij uitgelegd wat het probleem was. was volgens mij nog een redelijk simpele oplossing, maar ben vergeten hoe!
iemand enig idee?
VioLenT schreef op donderdag 09 oktober 2003 @ 00:45:
ik heb hem vanmiddag ook gekocht, ben er opzich wel tevreden over, radio deed het meteen; zonder radio ding er in te doen, dus alleen tv, tv scherp beeld, alleen een ruis en ben nu showfilter aant downloaden... kijken of dat helpt
waar kan ik showfilter downloaden? Het lukt me niet om het te vinden met google...
Verwijderd schreef op zaterdag 06 januari 2007 @ 12:31:
zacht schopje
  • kaajee
  • Laatst online: 08-11 20:22
Dat zou wel eens kunnen kloppen, want waarschijnlijk wordt 'showshifter' bedoeld ;) Maar volgens mij wordt dat niet meer ondersteund. Showshifter.nl wel
kaajee schreef op maandag 08 januari 2007 @ 17:37:
ok thx, ik dacht aan sofrware, lol :+
  • kaajee
Verwijderd schreef op maandag 08 januari 2007 @ 17:56:
Showshifter was (is?) ook software, kijk hier maar eens
kaajee schreef op dinsdag 09 januari 2007 @ 23:43:
oh lol, want ik kwam op deze site uit: http://www.showshifter.com/ en dat was een stuk hardware. lol
