[NEC ND-1300A] Nieuwe firmware veel DVD-R's werken nu wel :)
  • 8.224 views sinds 30-01-2008
  • Apestaartje
  • Laatst online: 09-01-2020
Apestaartje
Nee,geen muis-arm..
Hermanvh schreef op 12 August 2003 @ 10:44:
Probeer eens de officiële 1.06 van NEC, misschien dat het daarmee opgelost is?
Helaas, de officiële versie 1.06 van Nec, brengt er geen verandering in. :'(
(moest wel ff terugflashen naar de voorlaatste orginele versie, voor die 1.06 erin wilde,maar dat euvel zal wel bekend zijn.)
X360 Gamertag : betelgeuze Spec 's PC:Sinclair ZX-81 16K-ram --90 min. cassettebandje-- 3Dmark score: 0,00000000000001 ---- Als het niet veranderd ! --- dan blijft het zo ! ---
  • Hermanvh
  • Laatst online: 17-03 10:14
Hermanvh
webOS fan, hacker, developer
I just finished the last bits of my 105v10 (1j05) release :)
Release notes:
v10 (1j05)
Changed writing strategy for some 2x media to get better results:)
Added support for the following media:
AN31 (4x)
AN32 (4x)
DATA TRACK (2x)
PRINCO (4x @ 2x)
NANYA-JC001 (4x @ 2x)
LONGTEN 001 (4x @ 2x)
These media will only be written at 2x, since there are still some compatibility problems at 4x.
I don't want people to sue me, because there data wasn't readable afterwards ;)
I implemented 2x support for the following PRINCO 4x media:
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 F7 0E 0B .L...@....R.....
77 88 70 00 03 50 52 49 4E 43 4F 00 04 00 00 00 W.P..PRINCO.....
00 00 00 00 05 AA A2 22 22 20 01 00 06 0B 0F 12 ......."" ......
It hasn't been tested, but the 3 media above should work fine at 2x, since they all use the same writing strategy and NANYA-JC001 is supported @ 2x in the official 1.06 firmware! I got the writing strategy for NANYA-JC001 from the 1.06 firmware and implemented it into the 1.05 firmware :)
Solved problems with:
SMMR01
SHT 001
Due to a small mistake they had some problems with 105v8, those problems should be solved now :)
Normal version: http://herrie.rpc1.org/downloads/105v10.rar
Auto Reset version: http://herrie.rpc1.org/downloads/105v10au.rar
Free version: http://herrie.rpc1.org/downloads/105v10fr.rar
Before you ask any questions please check my FAQ!
Enjoy it and let me know your results!
webOS all the way!
  • HellevUUr
  • Laatst online: 17-06-2025
Verwijderd schreef op 07 August 2003 @ 22:06:
Hoi,
Ik heb een NEC-1300A brander......ook heb ik de nieuwe firmware (106) geinstaleerd. Nu heb ik een stapeltje EMTEC DVD-R dvd'tjes liggen die hij niet wil branden "illigal medium".......kan iemand mij misschien helpen ?
vr.gr.
Arjan
Hermanvh schreef op 08 August 2003 @ 04:49:
Lees de mediacode eens uit met DVDInfo en post die hier! Ik denk dat het 4M SYS 202C1 is, maar ik weet het niet zeker!
Aangezien ghostbuster hier niet meer op terug is gekomen, doe ik het wel even voor hem ;) . Dit is de mediacode van die EMTEC (BASF) DVD-R (9,99 voor 5 bij Micro-Electro).
00000000 00 42 00 00 01 40 C1 FD 9E D8 50 00 02 7A 0C 15 .B...@....P..z..
00000010 77 78 90 00 03 44 44 44 20 44 56 00 04 44 52 00 wx...DDD DV..DR.
00000020 00 00 00 00 05 CC C0 00 00 00 01 00 00 00 00 00 ................
DDD DV DR Dus :)
Ik zal ze zo eens testen.
p.s. Hermanvh welke versie kan ik het best gebruiken op het moment? 105v8auto of 106auto ?
  • Hermanvh
Hermanvh
HellevUUr schreef op 14 August 2003 @ 13:07:
DDD DV DR Dus :)
105v10 is vandaag gereleased :) Die werkt OK met DDD DVDR :)
webOS all the way!
  • HellevUUr
Hermanvh schreef op 14 augustus 2003 @ 13:44:
Werkt deze hiermee
00000000 00 42 00 00 01 40 C1 FD 9E D8 52 00 02 86 0E 11 .B...@....R.....
00000010 87 89 80 00 03 4D 58 4C 20 52 47 00 04 30 32 00 .....MXL RG..02.
00000020 00 00 00 00 05 88 80 00 00 00 02 00 06 0A 0E 15 ................
Ik heb deze mediacode nog nergens gezien, maar MXL RG01 wel ...
Maxell DVD-R ver2.0 1-4x
12,95 voor 5 (in zilveren doos) bij Micro Electro.
  • Hermanvh
Hermanvh
HellevUUr schreef op 14 augustus 2003 @ 14:06:
Werkt deze hiermee
Yup, wordt al gesupport door de officiële 1.05 :)
webOS all the way!
Bij versie 105v10 is in het apparaatbeheer opeens alleen nog cd-rom-station te lezen terwijl er eerst _NEC 1300A (zoiets dergelijks) stond. Kan dit kwaad of is er een foutje geslopen in de firmware? In nero zag ik hem de 1e keer opstarten niet de 2e keer wel. Hier staat wel dat het een NEC 1300A is.
Ik zal dadelijk eens proberen te branden met een maxell-r.
Nero zegt nu opeens dat de drive in gebruik is door een andere applicatie. Wat dus niet zo is. Dit is geen goed nieuws. :'( Iemand anders al v10 geprobeerd?
Edit2:
Pfff.... Gelukkig doet versie 8 het weer wel. De naam in het apparaatbeheer is ook weer hersteld. En nero doet het nu wel. Ik dacht even dat mijn brandertje gaar was geraakt door het flashen.
Ik heb trouwens de auto reset versie gebruikt bij beide versies voor als dat nog iets toevoegd aan deze gegevens.
[ Voor 45% gewijzigd door Verwijderd op 14-08-2003 21:37 ]
Nog een vreemd geval. Bij 105v8auto ziet ie in nero de maxell dvd-r als een +r, want nero geeft als brandspeed 2.4 aan. Tijdens het branden zegt hij echter dat deze alleen maar op 2 speed gebrand kan worden ipv 2 speed. (En nee ik verschrijf me hier niet dat staat er echt. Ik bedoel dus geen 2.4 speed) Maar dit kan natuurlijk een software fout zijn van nero. Het betreft hier nero versie 6.0.0.11. Of het zo lukt moet ik nog even afwachten, maar ik zal het hier posten, zodra de dvd klaar is.
De dvd is goed gebrand en data verification was succesvol. Terug kopieren naar de hd ging ook goed. Dus op zich werkt alles wel goed.
[ Voor 14% gewijzigd door Verwijderd op 14-08-2003 22:22 ]
  • Hermanvh
Hermanvh
Verwijderd schreef op 14 August 2003 @ 21:07:
Edit2:
Vaag, werkt hier wel goed met V10, komt ook gewoon te voorschijn in apparaatbeheer!
Misschien nog een keer flashen?
webOS all the way!
  • Hermanvh
Hermanvh
Verwijderd schreef op 14 augustus 2003 @ 21:46:
Lijkt me Nero foutje!
webOS all the way!
Hermanvh schreef op 15 augustus 2003 @ 02:41:
Ik heb zojuist geprobeerd nogmaals te flashen. Er komt nog steeds cd-rom-station te staan in het apparaatbeheer. Verder blijft nero ook zeggen dat de NEC al in gebruik is. Ik kan wel nog via explorer gewoon dvd's lezen. Als ik een lege dvd-r in de speler stopt dan zegt windows me bij het dubbelklikken op de speler "Onjuiste functie". Erg vreemd dat dit bij mij wel gebeurt. Ik zal eens een andere versie dan auto proberen.
Normal en free werken ook allebei niet. Ze geven precies dezelfde resultaten als hierboven beschreven.
Zal er dan misschien iets met mijn drive zijn? :? De id-string begint ook met een underscore. _NEC ... 1300A. (Ik weet de hele string niet, maar het gaat om het begin) Klopt dit dan wel? Ik heb dit al zo vanaf het begin voordat ik met flashen begon.
[ Voor 26% gewijzigd door Verwijderd op 15-08-2003 03:09 ]
  • Hermanvh
Hermanvh
Verwijderd schreef op 15 August 2003 @ 02:59:
Inderdaad vreemd probleem. De underscore klopt. Dat is normaal. Ik heb weer zitten klooien met de firmware versie (1.05 veranderd in 1j05), misschien dat dit problemen veroorzaakt... Ik zal even versie maken waarbij ik het gewoon 1.05 laat :) Misschien dat het wat uitmaakt :)
webOS all the way!
Hermanvh schreef op 15 August 2003 @ 03:18:
Ahha. Mooi, kan ik die versie op je site verwachten? En zal ik hiervoor opblijven of kan ik beter morgen even kijken? ;)
Ik wil je hier niet mee jagen ofzo hoor. Ik ben al blij dat je zoveel moeite doet om deze mooie fw's beschikbaar te stellen. _/-\o_ :Y)
[ Voor 14% gewijzigd door Verwijderd op 15-08-2003 03:26 ]
  • Hermanvh
Hermanvh
webOS all the way!
Ok, ik ga hem nu proberen. Ik zal zometeen de resultaten posten.
Resultaten:
_/-\o_ voor Herman. Het werkt nu perfect. De drive is weer te zien in het apparaatbeheer en nero begint ook weer gewoon te branden.
Je hebt iemand heel erg blij gemaakt. :Y)
Bedankt dat je zo snel een nieuwe firmware hebt gemaakt om het te testen. Ik schrok wel even toen de schrijver het opeens niet meer deed, maar gelukkig was het maar een klein "foutje" in de firmware. :P
PS: Ik heb wel even de naam van de firmware veranderd anders krijg je een name~1.bin file en ik weet niet of de flashsoftware dit leuk vind. B)
[ Voor 62% gewijzigd door Verwijderd op 15-08-2003 03:47 ]
  • Hermanvh
Hermanvh
Verwijderd schreef op 15 augustus 2003 @ 03:33:
Resultaten:
Goed om te horen dat het nu wel werkt :)
Welke schijfjes gebruik je trouwens met je NEC?
P.s.: Heb je een Nforce (2) chipset? Of een andere? Ik heb in het verleden ook al problemen gehoord van mensen met een Nforce chipset, omdat ik een ß in het versienummer had opgenomen....
webOS all the way!
  • Hermanvh
Hermanvh
Verwijderd schreef op 15 August 2003 @ 03:33:
Oeps, dacht dat ik 8 karakters had gebruikt, maar waren er dus 9 |:( Het is al laat zullen we maar zeggen ;)
webOS all the way!
Hermanvh schreef op 15 augustus 2003 @ 03:49:
Ik gebruik nu even een maxell dvd-R (2 speed volgens nero, op de verpakking staat het niet eens). Verder heb ik datawrite-R gebruikt die hij wel op 4 speed brand, maar helaas niet door de verification komt. Ik krijg bij het terugkopieren naar de HD ook een redunditie (of zoiets) fout. Op 2 speed heb ik het nog niet geprobeerd, want toen waren de schijfjes op. Verder heb ik nog princo schijfjes geprobeerd, maar dat ging onder het branden bijna meteen verkeerd.
De maxell doen het echter wel erg goed en zijn op 2 speed gebrand.
Ik heb verder geen NForce chipset, maar een VIA KT400. (Asus A7V8X)
Kun je me misschien vertellen welke schijfjes nu eigenlijk wel echt goed zijn, want ik zie door de bomen het bos niet meer. Ik had zelf gedacht aan datawrite-R op 2 speed branden, de datawrite+R of de Ritek / Ricoh dvd+R. Wat lijkt jou het beste? Wellicht heb je er iets betere kijk op, omdat je de mediacodes iets beter beheerst. 8)
Hermanvh schreef op 15 augustus 2003 @ 03:50:
Hehe... >:)
Laat.. of vroeg.. Het is maar hoe je ertegen aan kijkt. :P :O
  • Hermanvh
Hermanvh
Verwijderd schreef op 15 August 2003 @ 03:57:
Toch een wazig probleem (weer Via :r). Hier een SiS-chipset en geen problemen, ook niet met de ß :) Vage IDE-controllers ;)
Ikzelf heb hele goede ervaringen met That's Write 1-4x :) Deze hebben mediacode LEADDATA01 :) Aangezien de DVD-R's in Nederland duur zijn door die achterlijke heffingen ben ik een beetje in het buitenland gaan kijken :)
In de UK (www.bigpockets.co.uk) verkopen ze 1One (LEADDATA01) voor 79p (EUR 1,13) per stuk. In Duitsland (www.nierle.de) verkopen ze Sunstar 1-4x (LEADDATA01) voor 34.75 per 25 stuks :)
Deze schijfjes zijn lekker goedkoop, maar toch aan te raden :)
webOS all the way!
  • HellevUUr
Ik krijg een write error als ik op 4x Fortis dvd-r wil branden, dit gebeurd na 75%
op 2x werkt het wel.
Dit met 105v10au op een NEC ND-1300a
mediacode:
00000000 00 42 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 11 .B...@....R.....
00000010 66 78 80 00 03 47 53 43 30 30 31 00 04 00 00 00 fx...GSC001.....
00000020 00 00 00 00 05 A8 82 00 20 00 02 00 06 09 11 11 ........ .......
nero log:
12:07:35 PM #21 SCSI -1135 File Cdrdrv.cpp, Line 1415
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03E50000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x18 0x57 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
12:07:35 PM #22 CDR -1135 File Writer.cpp, Line 335
Write error
12:07:35 PM #23 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
12:07:35 PM #24 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
12:07:35 PM #25 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
12:07:35 PM #26 Text 0 File dlgbrnst.cpp, Line 1703
12:07:35 PM #27 Phase 38 File dlgbrnst.cpp, Line 1843
Burn process failed at 4x (5,520 KB/s)
  • Hermanvh
Hermanvh
HellevUUr schreef op 18 August 2003 @ 12:35:
mediacode:
nero log:
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Ik heb hier niets aan veranderd :( Misschien dat je de officiële 1.06 kan proberen?
webOS all the way!
  • CME86
  • Laatst online: 19:35
Ik kan mijn Nec1300a v1.05 niet flashen, hij zegt dat de "primary master" not supported is.
Snap het niet, ik geef namelijk netjes op nec1x00a.exe -pri -mas flas file.bin. En heb ook zekerweten een nec op de pri mas hangen. (heb namelijk alles volzitten met drive's en de hd's op de raidcontrooler)
  • KBDE
  • Laatst online: 17-11 13:13
Celmis schreef op 18 August 2003 @ 15:26:
zoals je zelf al aangeeft ondersteunt het utility primary master niet.
zet hem eff pri sla, of sec mas /sla dan werkt het wel ;)
  • CME86
KBDE schreef op 18 August 2003 @ 16:41:
aahhh, dan moet ik weer eens mijn kast gaan verbouwen. Ik heb namelijk alles van pri mas tot aan sec sla vol zitten. Maar waarom zou zo'n programma nou pri mas niet onder steunen. :?
  • KBDE
Celmis schreef op 18 augustus 2003 @ 18:47:
Al sla je me dood geen id. Beetje jammer idd.
Maar het schijnt dat je meer probs kunt krijgen door prim. master te gebruiken daar deze onofficieel alleen voor HD's is. (waar ik het gelezen heb weet ik al niet meer)
Heb zelf echter ook altijd een liteon cd brander op pri. mas. gehad, nooit probs gehad... dus ut zal wel, denk meer dat het een gerucht is wat de wereld is ingeholpen door dit soort lakse programeerders :o ;)
  • CME86
misschien omdat ze bang zijn dat een N00B zijn hd wil flashen met de nec firmware :P
  • CME86
klopt het trouwens dat met de 1.05 originele firmware Nero je brander als een 2.4x max brander ziet?
Ik weet misschien al waardoor, omdat mijn bij dynabyte gekochte media maar 2.4 is ipv 4x zoals de verkoper mij had te melden.
Media Information van die IMATION dvd+r
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID RICOHJPNR00
Formatted Size 4.38GB(4.70GB)
Total Size 4.18GB(4.49GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 2.4x 3324KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Data area end sector 23053Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
[ Voor 86% gewijzigd door CME86 op 19-08-2003 10:13 ]
  • Hermanvh
Hermanvh
Celmis schreef op 19 August 2003 @ 09:34:
Book Type DVD+R
Media Type DVD+R
Number of Layers 1
De brander ziet de snelheid van het schijfje. Wanneer je er 4x media indoet heb je de mogelijkheid om 4x te selecteren, anders niet!
webOS all the way!
  • benedictuz
  • Laatst online: 18-06 10:56
Erg tof die gehackte firmware van jou. Ben alleen benieuwd wanneer je de How to hack sectie op je site gaat vullen. Lijkt me erg interessant namelijk.
Keep up the good work....
  • Hermanvh
Hermanvh
benedictuz schreef op 19 August 2003 @ 12:57:
Ben er mee bezig, weinig tijd helaas :(
webOS all the way!
  • FireStarter
  • Laatst online: 18-11 18:04
Zo ik heb al 2 dvd's gebrand en ow wat werkt het lekker :o
w00t
KBDE schreef op 18 August 2003 @ 19:57:
Ik had het ook met het moederbord van m'n broertje. Ik had daar de harde schijf op pri slave zitten, dan start hij geeneens op :?. De harde schijf moet op pri master zitten, zal wel een onofficiele regel zijn.
  • CME86
Verwijderd schreef op 19 August 2003 @ 20:34:
hij start wel hoor op pri master en doet het ook wel alleen geen firmware update.
doe alles via de raid poorten
Ik heb in een paar topics gelezen dat er ook wel met TDK of HP firmware wordt geflashed. Is dit ook mogelijk met een NEC 1300A? En wat is het effect hiervan. Kan het zijn dat er dan beter gebrand wordt met bepaalde merken media?
Ik kan namelijk niet echt vinden welke firmware dan wordt gebruikt en of dat idd op een NEC 1300A wordt geflashed. Ik heb gezocht op GOT en google, maar helaas staat er niet ergens duidelijk waarmee geflashed wordt en op welk apparaat. Ik wil mijn brandertje natuurlijk niet vernielen door een verkeerde flash, daarom vraag ik het maar hier voor extra duidelijkheid.
[ Voor 5% gewijzigd door Verwijderd op 20-08-2003 18:53 ]
Weet iemand iets te vertellen over Primedisc en datatrack
Kreeg op een dvd (primedisc) van 3 week oud een leesfout :(
maar dit merk gaf in nero cd/dvdspeed een mooi plaatje
En de datatrack had een grote dip aan eind van de test (einde dvd dus)
En weet iemand iets te vertellenover het programma K-probe
(ziet mijn brander (Nec 1300) namelijk niet)
  • Hermanvh
Hermanvh
Verwijderd schreef op 20 August 2003 @ 18:34:
Je kan de NEC 1300A flashen met de Iomega en TDK firmware, maar dit brengt geen extra voordelen t.o.v. mijn firmware. Ze zijn gebaseerd op de NEC firmware, met alleen de naam aangepast. Ze zijn ook te vinden op mijn pagina :)
webOS all the way!
  • Hermanvh
Hermanvh
Verwijderd schreef op 21 August 2003 @ 13:54:
DVD+R of DVD-R? K-Probe werkt alleen maar met LiteOn drives... Gelukkig heb ik een LiteOn DVD speler om te testen :)
webOS all the way!
  • Dzine
  • Laatst online: 19-11 11:46
Beste mensen,
Geloof me ik heb na veel gesurf en gegoogle pas besloten om het toch maar hier te vragen en jullie met dit n00b gezeur bezig te houden.
Ik heb sinds kort een 1300 en alles werkt redelijk. O-) (hij zit op slave, naast de HD op de plaats van de ouwe dvd speler)
Ik heb er al een aantal gefikt en ook die werken (Mmore's gebruikt, geen klachte over) alleen kan ik niet op 4x branden (zegt nero) nu heb ik nog geen andere dvd's geprobeerd maar volgens mij ligt t daar niet aan.
Nu is mijn vraag moet ik hem flashe naar 1.06?? zo ja hoe doe ik dit in gods naam onder Xp zonder floppy drive. Ik ben aardig bekwaam met alles wat dit ding beweegd, maar flashe heb ik altijd probeere te vermijde.
Nogmaals mijn excuses,
maar ik zie inmiddels door alle post's t forum niet meer... |:(
Thx
Zelfs als niemand me gelooft, ben ik de koning in mijn hoofd....
Dankje voor K-probe
Ik shrijf op +R
Dzine schreef op 21 augustus 2003 @ 14:33:
Thx
Ik denk dat je daar het beste die update cd's van hermanvh _/-\o_ voor kunt gebruiken
  • TheVMaster
TheVMaster
Moderator WOS
Ik heb zojuist ook mijn NEC-1300a aangesloten (vandaag binnengekregen) enneh..ben de eerste dvd aan het fikken (op 4speed dvd-r). Ik zag btw dat de mijne al vanuit de fabriek firmware v1.06 heeft :) hehe de princo (witte bovenkant) wil hij niet fikkuh....hij geeft dan een 'Power Callibration Error'
Mijn Apps: DiscVault - MealieShopper - SintMaarten - 3D Print Pricing
TheVisionMaster schreef op 21 August 2003 @ 21:19:
En met firmware v107?
http://www.freewebs.com/m...mware_ND-1300A_WIN107.zip
  • Hermanvh
Hermanvh
Ik vrees van niet :( NEC heeft in de 1.07 niets veranderd in de writing strategies voor de verschillende DVD-R media, maar proberen kan nooit geen kwaad natuurlijk 8)
webOS all the way!
Hermanvh schreef op 22 August 2003 @ 20:38:
De princo:
00 42 00 00 01 40 C1 FD 9E D8 52 00 02 F7 0E 0B .B...@....R.....
77 88 70 00 03 50 52 49 4E 43 4F 00 04 00 00 00 w.p..PRINCO.....
geeft bij 4x speed met firmware 1.07 een "power calibration error". Dit is goed want de princo 4x is te slecht om op 4x speed te branden. Ik kon dezelfde dvd nogmaals met 2x speed branden zonder verify-errors. Nero cd/dvd speed geeft voor de 2x gebrande dvd een ononderbroken rechte lijn van 2,09 tot 5,06 maal.
[ Voor 4% gewijzigd door Verwijderd op 23-08-2003 22:54 ]
  • toktokcity
  • Laatst online: 20-09 22:53
Op de nec site staat bij de firmware update dat hij niet geschikt is voor oem versies, wat bedoelen ze daarmee?
  • Hermanvh
Hermanvh
toktokcity schreef op 26 August 2003 @ 20:16:
Geen DELL versies enzo! Maar gewoon de info op de NEC site negeren! 1.07 biedt helemaal 0,0 voordeel t.o.v. 1.06!
Er is geen extra DVD-R media support. Tevens is er niets aan de writing strategy voor deze media veranderd. Mijn 105v11 blijft nog altijd veruit het beste ;)
webOS all the way!
  • MrDummy
  • Laatst online: 27-10 11:01
MrDummy
Nog steeds gek op anime...
Wil iemand a.u.b. voor duidelijke en snelle afhandeling de 105v11 firmware op de EERSTE posting van deze topic plaatsen? Er staat nu nog 105v10 firmware op.
Hoef ik niet zoeken waar v11 link staat....
Men mag ook 1.06 firmware link daar zetten als men wil.
  • Hermanvh
Hermanvh
MrDummy schreef op 26 augustus 2003 @ 23:01:
Fixed ;)
webOS all the way!
  • FireStarter
w00t
Hallo welke firmware raden jullie mij aan voor mij nec-1300a..?
  • Swoosh
  • Laatst online: 19-09 02:31
Verwijderd schreef op 27 August 2003 @ 16:32:
Duh !! Die van Hermanvh natuurlijk...
Is er ook al firmware voor de NEC 1000a?
die 5v11?
  • Hermanvh
Hermanvh
Yup :) Heeft echt enorm veel media support :) Werkt met de meeste schijfjes veel beter dan de officiële NEC 1.06/1.07 :)
webOS all the way!
  • Hermanvh
Hermanvh
Verwijderd schreef op 27 August 2003 @ 16:46:
Wat wil je doen? Je kan de 1000A upgraden naar een 1100A waardoor je op 4x DVD+R kan branden >:)
webOS all the way!
Wanneer word de 1100a sectie gevuld? Zit met smart te wachten. :)
wat voor van de 3 moet ik nemen de auto-reset de free of normaal'?
gaat om de nec1300a firmware 5v11..
  • Tachyon
  • Laatst online: 16-11 12:32
Tachyon
pop the glock
Verwijderd schreef op 28 August 2003 @ 10:48:
Uit de FAQ van Hermanvh:
What are these 'Normal', 'Auto Reset' and 'Free'-versions?
Normal: For people in Region 2 who don't look DVD's from other regions.
Auto Reset: For people that look DVD's from other regions on a regular base.
Free: People from the US who don't look DVD's from other regions.
Hermanvh: people don't 'look' DVD's, they 'watch' them... ;)
If we do not change our direction, we will likely end up where we are heading.
  • Vincentio
Ik heb plots heel veel problemen met DVD-Rs (Sunstar 4x) ook op 4x te branden in Nero 6. Eerst ging het goed maar nu mislukt het brandproces steeds. 2x gaat wel weer goed.
Firmware 5v11 (Nec1300A)
  • Hermanvh
Hermanvh
Tachyon schreef op 28 augustus 2003 @ 11:26:
Whatever ;) Was een haastklusje ;)
webOS all the way!
  • Hermanvh
Hermanvh
VinnieWeiss schreef op 28 August 2003 @ 12:16:
Probeer 1.07 van NEC eens :)
webOS all the way!
  • Vincentio
idem, denk dat het aan Nero 6 ligt. Programma crasht ook vaak. Bagger programma.. :(
Kan iemand me iets uitleggen over de "writing strategy" van de ND 1300A? Deze zouden
in firmware 1.05v10 en 1.05v11 beter zijn als in 1.06 en 1.07. Misschien kan iemand (? Hermanvh ?) me uitleggen wat dan deze betere "writing strategy" inhoudt ?
Tweede vraag is of er wat uitleg gegeven kan worden over de wijze waarop een
firmware kan worden gehackt? Herrie's page is (nog) niet uptodate wat dit onderwerp betreft. BVD
Ik gebruik 5v11 (nec1300a), samen met that's write 1-4x dvd-r op 4x mislukt deze ook na een tijdje in nero 6.0 :(
2x gaat daar en tegen wel weer goed.
Wat zeg je Hermanv? ook versie 1.07 erop zetten?
  • Hermanvh
Hermanvh
Verwijderd schreef op 30 August 2003 @ 21:58:
Vreemd probleem, heb er meer mensen over gehoord :'( Er lijken nu ook That's Write 1-4x met Princo ID op de markt te zijn :( Tevens zijn er That's Write's waarvan de ID's ietsjes afwijkt waardoor problemen kunnen onstaan :(
Ik heb een aantal 'reports' gehoord van 1.06/1.07 die dan wel gewoon op 4x wil branden met LEADDATA01 mediacode!
webOS all the way!
  • Dr.Roelski
  • Laatst online: 16:53
Dr.Roelski
Walk on ....
Hehe, eindelijk nog meer mensen met zelfde probleem als ik. Was al eens gepost op pagina 8.
Echter: ik gebruik Nero 5.5.10.42 op een nec1300, firmware 105yp (5v8 auto?) en heb normale mediacode LEADDATA01.
Volgens mij zijn het of gare dvd's, of is het een gare brander (ik hoop het eerste).
  • Hermanvh
Hermanvh
Dr.Roelski schreef op 31 August 2003 @ 01:39:
Zowieso is 105v8 niet echt aan te raden. 105v11 werkt stukken beter en 1.07 van NEC kan jouw problemen oplossen!
webOS all the way!
Hermanvh schreef op 31 August 2003 @ 01:04:
ik heb geprobeert om naar 1.07 te upgraden alleen geeft deze bij mij tijdens het flashen een foutmelding. :'(
Ik heb de firmware upgrade gebruikt die bij tweakers zelf staat.
Ik heb hem op dit moment weer op 1.05v11 draaien maar zou toch wel graag 1.07 proberen.
Heeft iemand hetzelfde probleem of een oplossing waardoor ik toch naar 1.07 kan upgraden? :?
oh ja en ik gebruik de thats write met LEADDATA01 mediacode ook.
  • Atteman146
  • Laatst online: 21:20
Verwijderd schreef op 31 August 2003 @ 14:46:
Mij lukte het ook niet om That's Writes te branden met een andere firmware dan 1.07 (mediacode LEADDATA01). Met alle versies van Hermanvh geeft hij helaas foutmeldingen tijdens het branden. Na het flashen met v1.07 (origineel van NEC dus) kan ik ze gewoon branden, zowel op 2 als op 4 speed.
Hier de Mediacode van de That's Writes die ik heb:
66 78 80 00 03 4C 45 41 44 44 41 00 04 54 41 30 fx...LEADDA..TA0
31 00 00 00 05 A8 82 00 20 00 02 00 06 09 11 11 1....... .......
Wat voor foutmelding krijg je precies tijdens het flashen?
Misschien gewoon nog een keer proberen of eerst de originele v1.05 of 1.06 van NEC gebruiken en daarna pas de v1.07.
edit: eff mediacode erbij gezet.
[ Voor 23% gewijzigd door Atteman146 op 31-08-2003 17:03 ]
  • Hermanvh
Hermanvh
Gebruik de .bin van http://etna.rpc1.org :)
webOS all the way!
Bedankt Herman. _/-\o_
Ik heb nu die original 1.07 bin erop gezet van http://etna.rpc1.org.
Ik houd jullie op de hoogte hoe de ondervindingen nu zijn met LEADDATA01 op 4x.
  • Hermanvh
Hermanvh
Erg druk bezig met testen van 1.07 nu :) Het lijkt erop alsof ik PRINCO, LONGTEN 001 en NANYA-JC001 eindelijk werkend heb op 4x :D More 2 follow ;)
[ Voor 31% gewijzigd door Hermanvh op 31-08-2003 23:18 ]
webOS all the way!
  • Dr.Roelski
Dr.Roelski
Walk on ....
Ik heb 1 dvd that's write (leaddata01) geprobeerd met de 1.07 firmware.
Helaas kreeg ik bij de leadout een write error!
Misschien ook nog iets te maken met brandpakket?!?
//edit: op 4 speed dus
[ Voor 9% gewijzigd door Dr.Roelski op 01-09-2003 16:13 ]
  • Pheno79
  • Laatst online: 24-09 21:34
Ik heb een probleem.
Ik heb geprobeerd met de officiele firmware te upgraden, maar dat is dus mislukt. Snap er geen biet van waarom, maar goed, dit ter zijde. De exe van NEC zag de eerste keer wel de 1300, dus ik ben niet door de winkel genaaid :) Maar op het laatst geeft het tooltje aan: error.
Nu geeft de brander alleen maar een knipperend lichtje. Als ik Nero opstart zegt ie dat er een 1100 erin zit. Als tweaker raak je niet meteen in paniek, want er is tenslotte nog GoT :)
Ik zag dit topic met bijbehorende tooltje om te kunnen flashen naar een andere firmware (1100a.exe). Dus ik netjes een dosdiskette gemaakt, tooltje erop, 1.07 firmware van de 1300 erop, brander op ide2/master gepropt en draaien maar.
Op de commandoline: 1100a.exe -sec -mas -out binold.bin -flash nec107.bin
Na een tijdje krijg ik weer een prompt, maar volgens mij is er niets geflashed. Ik weet ook niet of het programma iets aangeeft als het gelukt is.
Ook heb ik de firmware van HermanVh geprobeerd, maar weer noppes. Wat doe ik fout of is mijn brander echt naar de branderhemel?
  • zAo
  • Laatst online: 19:25
zAo
GPLv2 Fanboy
Aangezien de startpost veranderd is, vraag ik het hier maar even.
Klopt het dat Sentinel -R niet werkt op de 1300A? Ik heb 1.06Herman versie :)
  • FireStarter
Dr.Roelski schreef op 01 September 2003 @ 16:13:
Puur media, ik heb verdomme ook een 50 spindel hier liggen, heb er nu 25 gebrand en 9 mislukte dvdrtjes hier liggen. That's Write komt er bij mij niet meer in.
Ik weet alleen niet wat ik nu moet pakken, want voor hetzelfde geld is dat ook weer verkeerd.
Waarmee zit ik nu safe?
w00t
  • Hermanvh
Hermanvh
Pheno79 schreef op 02 September 2003 @ 06:02:
Dit werkt dus niet! Je moet het volgende gebruiken: 1100a.exe -sec -mas -flash nec107.bin
Succes!
webOS all the way!
  • Hermanvh
Hermanvh
zAo schreef op 02 September 2003 @ 06:29:
Wat is de mediacode? Dan kan ik even voor je kijken?
105v11 is veel beter dan 1.06! Kunnen jullie nou GVD niet lezen? Is het zo onduidelijk op mijn site? Ik heb GVD nog commentaar erbij gezet in de vorm van * en # met daarbij de uitleg......
webOS all the way!
  • McCloud
  • Laatst online: 30-10-2025
Hermanvh, heb je al enig idee of het booktype bit voor DVD+R schijfjes bij het schrijven op DVD-ROM gezet kan worden op de 1300A??? Dit in verband met compatibiliteit met sommige DVD spelers (bijvoorbeeld de Panasonic RV32) die wel DVD+R schijfjes afspelen, maar alleen als het booktype bit op DVD-ROM staat.
  • Hermanvh
Hermanvh
McCloud schreef op 02 September 2003 @ 10:41:
1100A firmware flashen is de enige oplossing atm :'(
webOS all the way!
  • McCloud
Hermanvh schreef op 02 September 2003 @ 10:43:
Jammer, zou het wel mogelijk moeten zijn om dit in de firmware in te stellen? Dan heb ik in ieder geval nog hoop dat ik het zelf een keer kan uitzoeken (m.b.v. jouw "howto hack the firmware"). Ik ga in ieder geval NEC nog eens een boos mailtje sturen (niet dat dat helpt, maar ik moet m'n frustratie toch ergens kwijt >:) )
  • xonide
  • Laatst online: 08-11 15:25
Wat ik me nu afvraag, ik heb deze brander besteld samen met een externe behuizing(firewire) omdat ik geen ruimte meer heb in mijn kast. Is het ook mogelijk om deze nieuwe firmware erop te zetten met deze opstelling?
I have an external drive connected to USB or Firewire. How can I flash it?
The flash tool only supports the normal IDE-controller. In case you have an external drive, remove it from it's bracket and connect it to a normal IDE-controller.
Beetje research kan geen kwaad...... ;)
[ Voor 42% gewijzigd door xonide op 02-09-2003 12:36 ]
  • Hermanvh
Hermanvh
xonide schreef op 02 September 2003 @ 12:31:
De NEC flashtool schijnt die drives wel te kunnen flashen :) De volgende keer ga ik er dus voor zorgen dat mijn versies via de flashtool te doen zijn :)
webOS all the way!
  • Hermanvh
Hermanvh
107v2 is uit :) Check de eerste pagina van dit topic voor de URL's en release notes :)
webOS all the way!
he bedankt dat ze nu ook in windows kan flashe.. ;
Hermanv,
Als ik via wininstaller firmware 107v2 wil flashen dan kan hij mijn Nec 1300 niet vinden dit onder XP pro.
Ik heb het onder DOS uitgevoerd ,en zet dat het met succes is afgerond.
Maar..... ik zie de firmware in mijn brandprogramma's nog steeds op 1.07 staan, ik had verwacht dat er dan 107v2au te zien zou zijn. is dit wel goed ????
Geflasht als volgt,
opstart diskette met alleen command.com en cd-rom drivers er op pc start dan op met cd-rom ondersteuning en komt dan in de A:\ prompt.
Andere flop er in met de nec1x00a.exe en 107v2au.bin er op .
dan nec1x00a.exe -sec -mas -flash 107v2au.bin enter.
Graag Uw commentaar aub
  • Pheno79
* Pheno79 is nu verdrietig, ding doet niks meer. Her knippert alleen maar, reageert nergens op. Ik denk dat het flash porgramma het beestje ook niet meer ziet, want ik zie alleen door wie het geprogged is, om daarna weer braafjes a:\ te zien.
  • Hermanvh
Hermanvh
Verwijderd schreef op 02 september 2003 @ 17:58:
Hermanv,
Geflasht als volgt,
Dit is OK. Het versienummer wordt niet meer veranderd, omdat dit voor allerlei vage problemen zorgde! Maar 1.07 is ok ;)
webOS all the way!
  • Hermanvh
Hermanvh
Pheno79 schreef op 02 September 2003 @ 18:15:
Even in andere pc proberen opnieuw te flashen via DOS
webOS all the way!
  • Pheno79
Heb ik al gedaan. Wat het wel deed was het dos programmaatje van NEC zelf (1.06). Tenminste, in het begin kan ik het laatje weer open krijgen. Bij het uitzoeken van de verschillende IDE apparaten gaat het weer helemaal mis. Na 1 minuut komt ie erachter dat er een 1300a in zit. Maar de PC is vanaf dan ook erg traag. Laatje reageert ook niet meer.
Ik ga het RMA sturen, want dit is niet echt normaal. De andere flashprogrammas zien de nec1300 niet meer, dus kan ik het niet terugflashen (of weer 1.07 proberen).
  • Hermanvh
Hermanvh
Pheno79 schreef op 03 september 2003 @ 07:34:
Met het DOS-toolje op mijn site ook niet? Ik heb ook in het begin een aantal keren gehad dat er wat fout ging met flashen (was vergeten de checksum aan te passen in de firmware |:( ). Ik kon toen gewoon de drive weer opnieuw flashen 8) !
Weet je zeker dat je je drive niet toevallig op cable select hebt staan?
webOS all the way!
  • Pheno79
Ok, detailed description time :)
Wat ik doe om een poging te doen te flashen:
Ik heb een tweede PC gepakt (met floppydrive :) ) en daar de brander als secondary master erin gedaan. Ik gebruik een Freedos bootfloppy met 1100a.exe en de firmware bin natuurlijk.
op de commandline doe ik:
1100a.exe -sec -mas -flash <binfile>
Dan krijg ik dus de beschrijving (auteurs enzo) met daarna:
A:\
Niks gebeurd dus.
Ik zat nog wat op tweakers te zoeken en zag dat iemand hetzelfde probleem als ik had.
Bij een reactie op de meuktracker van de nieuwe firmware stond dat er een dostooltje van NEC was om te flashen naar 106. Bij diegene heeft het wel geholpen, maar ik ben niet zo gelukkig met harde waren :(
Met die van NEC zag ik netjes dat het ding bezig was, brander stopte met knipperen, laatje reageerde weer na herstart. Eventjes dan, want zogauw de BIOS de ide apparaten gedetecteerd had ging het weer mis. Trage reactie van de gehele pc en geen reactie van de brander. In mijn BIOS staat het detecteren op auto, dus dat zit wel goed. Ik heb het nog een keer laten detecteren, BIOS zegt netjes NEC 1300A ...blaat.... 1.06
Ik ga vanavond gewoon weer een poging doen, brander loopt iig niet weg :) En als ze het jatten, dan zie ik op GoT wel eenzelfde vraag ergens verschijnen :D
  • Hermanvh
Hermanvh
Pheno79 schreef op 03 September 2003 @ 08:21:
A:\
Niks gebeurd dus.
Probeer eens een PC met een NON-Intel chipset. Ik heb al verschillende problemen voorbij zien komen met Intel en Nforce2 chipsets. Het lijkt mij sterk dat je drive niet meer te redden is :'(
webOS all the way!
  • Pheno79
De tweede PC is een AMD, met VIA chipset. :Y)
Anders maar een begravenis regelen :'(
  • Pheno79
Hmm, ik ga niet meer moeilijk doen, de online winkel waar ik het gehaald heb zal me een nieuwe opsturen. Toppie! Eigenlijk ben ik benieuwd wat er aan de hand is....zal ik vragen of ze de oude ook meteen erna terugsturen, zodat ik verder kan gaan met dit geklojo :)
hermanv,
Bedankt voor je reactie, ook nu doet de wininstaller het nadat ik Instant copy heb verwijderd.
ik denk dat instant copy de driver veranderd tijdens de installatie.
groeten uit Amsterdam,
Rob.
Hoi,
Weet iemand of de dvd's van princo(en datawrite) nu wel goed werken?
bij firmware versie 1.05v11 gaan de dvd's na ongeveer 1,5 uur kijken op mijn stand alone dvdspeler haperen.
ik brand met nero op 2 speed
alvast bedankt
groetjes,
shibby
  • xonide
Dus als ik het goed begrijp allemaal dan zou ik met mijn opstelling:
Laptop, firewire behuizing waar de 1300a inzit
nu de 107v2 kunnen flashen met de windows tool?
Edit
Heb het dus geprobeerd en het werkt perfect.
[ Voor 17% gewijzigd door xonide op 03-09-2003 21:23 ]
