17" TFT scherm ACER... is dit wat?
Pagina: 1 2 Laatste
  • 432 views sinds 30-01-2008
Volgens mij is dit voor de prijs een best scherm, maar wat ik er van weet:
De ingebouwde speakers, daat moet je niets mee te maken willen hebben!
  • HunterPro
Verwijderd schreef op 13 juni 2003 @ 19:34:
Bij welk scherm met ingebouwde speakers is dat wél zo dan :? ;) :)
Nice specs wel. Monitor ziet er ook nie verkeerd uit. 8)
  • PROnline
  • Laatst online: 22:10
Audio Output
Form Factor Integrated
Output Power Channel 1 Watt
Dimensions
Depth 7.2 In
Height 15.5 In
Weight 20.1 Lbs
Width 14.8 In
Display
Projector Color Support 24-bit (16.7M colors)
Projector Diagonal Size 17
Projector Dot Pitch 0.26 Mm
Projector Form Factor Desktop
Projector Image Brightness 300 Cd/m2
Projector Image Contrast Ratio 450:1
Projector Image Max H-View Angle 150
Projector Image Max V-View Angle 125
Projector Max H-Sync Rate 95 KHz
Projector Max Resolution 1280 x 1024
Projector Max V-Sync Rate 75 Hz
Projector Response Time 20 Ms
Projector Technology TFT active matrix
Projector Type Flat panel display
Projector V-Sync Rate at Max Res. 75 Hz
Projector Viewable Size 17
Compatibility PC
Manufacturer Acer America
Product Line Acer AL
Interface Provided
Connector Type 15 pin HD D-Sub (HD-15)
Interface (Output) VGA Qty 1
Connector Type Mini-phone stereo 3.5 mm
Interface (Output) Audio line-in Qty 1
Miscellaneous
Compliant Standards BSMI, C-Tick, CE, DDC-1, DDC-2B, EPA Energy Star, ISO 13406-2, Plug and Play, TCO '99, TUV GS, UL, VCCI, VESA DPMS
Features Locking device keyhole (cable lock), Wall mountable
Flat Panel Mount Interface 100 mm
Power Device
Nominal Voltage AC 110/230 V
Power Supply
Device Form Factor Internal
Device Power Consumption Operational 50 Watt
Device Type Power supply
Service
Support Type 3 years warranty
Support Details Full Contract Period 3 years
Support Details Type Limited warranty
Video Input
Analog Video Signal RGB
Bron
  • raps
  • Laatst online: 04-08 09:10
Verwijderd schreef op 13 June 2003 @ 17:22:
Ik ben gewoon op zoek naar een nieuwe monitor, en dit beestje spreek mij toch wel aan en ziet der leuk uit, niet van die brede randen er om heen. Ik weet alleen niet hoe dat zit met pixelfouten en garantie hoeveel pixelfouten hij mag hebben, voordat je hem voor garantie kan claimen. Want als er iets irritand is vind ik het wel van die zwarte puntjes in je witte scherm, waar je zoveel voor hebt betaald :(
dus als iemand iets meer over de specs en evt over die fouten kan vertellen
_/-\o_ _/-\o_
Van de Acer-site:
"... Deze beperkte garantie is niet van toepassing op kleine defecten aan het
LCD schern vookomende in producten voorzien van LCD technologie
waarvan niet meer dan (4) defective pixels per millioen pixels op een LCD
schern en waarvan ook, als het LCD scherm in (9) gelijke delen worden, er maar (1)
defecte pixel mag zijn centrum van het scherm. ... "
  • Remy
  • Laatst online: 15-08 09:43
Remy
I usually get 100% accuracy
Gister heb ik er samen met m'n zus 1 gehaald voor m'n zus d'r vriend. FF getest met internet, games, een dvd'tje etc. Is een prima scherm. Vanaf vandaag btw in de aanbieding bij Office Centre, 299 ex btw ;) zoals het plaatje in de startpost aangeeft :)
LinkedIn
Instagram
  • Pubbert
  • Laatst online: 14-08 18:50
Pubbert
random gestoord
Ik heb de AL707, das zowat dezelfde maar dan zonder speakers, ben er dik tevreden over.
Ja, TFT met een digitale aansluiting hebben topkwaliteit beeld
Vandaag de knoop doorgehakt... heb em bij Office Centre gekocht...
zit nu 1280x1024.... retestrak!
Aanradertje wat mij betreft.
Bedankt voor jullie reacties!
Ik heb hem ook.
Top scherm en goeie prijs (299 euro)
  • Brede P
  • Laatst online: 08-01 14:43
Verwijderd schreef op 14 juni 2003 @ 15:50:
Hoezo digitale aansluiting?
Lees ik zo krom, of staat er gewoon een analoge D-Sub aansluiting?
Ik zie tenminste nergens DVI (Digital Video Interface) vermeldt staan?!?
De AL718 is de besteverkochte TFT van het moment. De AL707 was populairder, maar die is uitverkocht. Het mooie aan Acer is dat zij net nieuwe mensen op de helpdesk hebben zitten, goed bereikbaar en makkelijk met omruilen. Het gaat er beter aan toe dan sommige "bekende" A-merken. Doen dus!
http://www.centralpoint.n...ml&levprodid=ET.L0207.001
[ Voor 21% gewijzigd door Verwijderd op 14-06-2003 20:07 ]
  • Nesto
  • Laatst online: 11-09-2021
Nesto
Chef du production
Waarom was de AL 707 populairder dan? Aangezien de AL718 betere specs toch heeft?
Yes - OEM
  • HunterPro
Die 707 heb ik anders nog in grote getalen staan in de winkel hoor :P Kom maar langs :D
Prima monitorretje btw, heb ze vandaag eventjes aan staan te kijken (707 en 718). De 707 vond ik zélf iets beter, maar dat kan komen omdat het displaymodel er eentje was die absoluut *zonder* enige dode/hotpixel was.
  • Nesto
Nesto
Chef du production
HunterPro schreef op 14 June 2003 @ 22:31:
Ja, de 707's zijn er nog in grote getalen, alleen gaan er langzaam uit.
Wat zijn de verschillen in specs/ervaringen tussen de twee dan?
Yes - OEM
  • HunterPro
Gangsternst schreef op 14 June 2003 @ 22:33:
de 718 is iets sneller in reactie (zo uit m'n bol gezegd) en weer wat interne meuk die verbeterd is oid (whatever ze konden aandragen voor een nieuw typenummer :P)
als je niets weet toe te voegen, reageer dan niet.
[ Voor 82% gewijzigd door Kees op 14-06-2003 23:14 ]
  • Nesto
Nesto
Chef du production
Verwijderd schreef op 14 June 2003 @ 22:40:
Sorry mannen, ik heb bergen aan ervaringen met deze twee schermen, maar helaas mag ik van de bemiddelaars niet meer reageren, omdat ze weten dat ik bij Central Point werk. Ik heb nu een waarschuwing gehad, anders knallen ze mij eruit. Helaas wil ik dat risico niet nemen.
Kun je mij misschien die ervaringen over deze schermen even mailen naar mij?
Oei hij is stout geweest
Ja steun tweakers en neem banners. En post nou maar alsjeblieft die ervaringen.
[ Voor 18% gewijzigd door Nesto op 14-06-2003 23:04 ]
Yes - OEM
  • Grrrrrene
joltcan overdrijft een beetje, hij heeft letterlijk in 1 op de 2 posts sinds zijn begin hier www.centralpoint.nl (deze is gratis voor je) verwerkt. Nu vinden we het prima dat Centralpoint komt adverteren hier, maar dan wel via banners en niet via gespam... Snap je?
Je mag best ervaringen posten, maar dat kan prima zonder jullie bedrijfsnaam en URL...
  • HunterPro
Och, ik werk bij de ene (* HunterPro @ MediaMarkt Den Haag Centrum :P) en ik spam voor de ander (zie profile :+).
Zolang je 't niet overdrijft lijkt me dat 't wel snor zit :)
[ Voor 9% gewijzigd door HunterPro op 14-06-2003 23:08 ]
  • Xandrios
  • Laatst online: 16-08 10:38
HunterPro schreef op 14 juni 2003 @ 23:08:
Weet jij zo uit je hoofd wat deze schermen daar kosten? En hoe is de dead pixel garantie bij Mediamarkt?
  • Rickbv
  • Laatst online: 13-08 12:04
Wat denken jullie, is deze enigzins vergelijkbaar met de Samsung 172T? Moet namelijk een aantal 17" LCD's hebben, hoewel ik de 172T's mooier vind, zijn deze stukken goedkoper. En specs zeggen mij niet zo veel, het geheel moet ook een beetje degelijk en duurzaam zijn...
Bij ACES-online is hij trouwens nog maar 326, 340 incl verzendkosten. Das nog minder dan bij de OfficeCenter :Y)
  • HunterPro
Cutebritney schreef op 15 June 2003 @ 00:32:
de 707 was geloof ik 399 inc btw... pin me er aub niet op vast.
De garantie bij MediaMarkt is simpel; als een product je niet bevalt breng je het in goede staat binnen 14 dagen terug, in originele verpakking en met bon. Je krijgt dan je geld terug. Daarom zou ik een TFT altijd bij de MediaMarkt halen. Wat, je vindt 't niks? Gewoon terug er mee, en een ander halen.
  • JJJ
  • Laatst online: 20:50
JJJ
Fabrikanten zijn verplicht om TFT's met dode pixels terug te nemen. Dus als je een pixel hebt die dood is, gewoon terugbrengen ook al zegt de fabrikant van niet. Je hebt recht op een scherm zonder dode pixels.
Bron: consumentenbond afaik
  • raps
JJJ schreef op 15 juni 2003 @ 00:51:
Niet helemaal waar...
Zoals ik al eerder zei in dit topic, dit is het beleid van Acer:
  • HunterPro
raps schreef op 15 June 2003 @ 12:28:
Acer heeft niks te 'maren' tegen de 7 dagen 'afkoelperiode' die de europese wetgeving de consument geeft, zodat deze een product (vrij van gebruikssporen uiteraard) binnen deze tijd retour kan brengen aan de winkel waar dit gekocht is. Deze is dan verplicht geld terug te geven; een waardebon hoeft de consument niet te accepteren.
  • Delerium
Delerium
Mythology
Acer kan zoveel willen en opschrijven, de Europese wetgeving zegt iets geheel anders. Indien het erop aankomt, telt de Europese wetgeving en niet die van Acer.
  • raps
excuses,
Ik was niet bekend met deze wetgeving.
Verder kon ik niet uit JJJ's post opmaken dat het over een nieuw scherm ging, vandaar de gedachtegang.
Algemene specificaties
Product Description Acer AL718 - flat panel display - TFT - 17"
Manufacturer Warranty 3 years warranty
Dimensions (WxDxH) 37.5 cm x 18.2 cm x 39.3 cm
Weight 9.1 kg
Power AC 110/230 V ( 50/60 Hz )
Audio Output Speaker(s) - integrated
Device Type Flat panel display / TFT active matrix
Compliant Standards CE, UL, TUV GS, VCCI, C-Tick, BSMI, DDC-1, DDC-2B, ISO 13406-2, TCO '99, VESA DPMS
Diagonal Size 17"
Viewable Size 17"
Dot Pitch 0.26 mm
Max Resolution 1280 x 1024 / 75 Hz
Power Consumption Operational 40 Watt
Built-in Devices Stereo speakers
Uitgebreide specificaties
General
Width 37.5 cm
Depth 18.2 cm
Height 39.3 cm
Weight 9.1 kg
Compatibility PC
Display Type Flat panel display / TFT active matrix
Expansion / Connectivity
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) ¦ 1 x audio line-in - mini-phone stereo 3.5 mm
Service & Support 3 years warranty
Service & Support Details Limited warranty - 3 years
Miscellaneous
Cables Included 1 x display cable
Power
Power Device Power supply - internal
Voltage Required AC 110/230 V ( 50/60 Hz )
Power Consumption Stand by / Sleep 1 Watt
Display
Diagonal Size 17"
Viewable Size 17"
Dot Pitch 0.26 mm
Max Sync Rate (V x H) 75 Hz x 95 kHz
Video Bandwidth 54 MHz
Response Time 20 ms
Image Brightness 300 cd/m2
Video Input
Audio Output
Type Speaker(s) - integrated
Output Power / Channel 1 Watt
ff alle specs op een rijtje :P
ik zit nu ook even te twijvelen hij is zeer goedkoop, maar ik wou eerst een eizo kopen althans over een paar maanden nog even sparen. maar dit is ook wel gaaf :D
  • Qosmic
  • Laatst online: 15:56
ik denk dat ik deze ook ga kopen bij officecentre. 20 ms is prima voor gamen, en hij ziet er ook vet uit!
Alleen die refreshrate is max 75Hz.
Ik Heb mijn 17"Eizo F57 nu op 1152*864 @ 100hz.
Dus dat zal op die tft wel 1152*864 @75 hz zijn, maar het is toch zo dat je op een tft minder last hebt van die flikkeringen die je wel op crt's hebt
Stop chasing the dream, you're already living it
  • Ossenaar
  • Laatst online: 23:42
Ossenaar
Oss de Gekste !!!
Psies voor een TFT heb je aan 60 of 75 Hz zat voor een flikkervrij beeld.
Ik had zaterdag 2 schermen voor kennissen gekocht en thuis even uitgeprobeerd met 3dMark 2003 en Counterstrike -> Geen ghosting
ik ga er maandag denk ik een voor me eigen halen om naast me 19 inch CRT te draaien _/-\o_
De kick van Electric!
Qosmic schreef op 15 June 2003 @ 14:19:
Geen last. Dat werkt heel anders.
  • Qosmic
Ossenaar schreef op 15 juni 2003 @ 14:23:
Welke schermen waren dit en hoeveel ms was de responsetime dan bij deze schermen?
  • Ossenaar
Ossenaar
Oss de Gekste !!!
Qosmic schreef op 15 June 2003 @ 14:38:
Dit waren de beide Acers AL718 met response tijd van 20 ms in de aanbieding bij Office Centre voor 299e Ex Btw
  • Qosmic
ok relaxed, die ga ik dinsdag kopen bij officecentre. (iemand enig idee hoe lang die actie nog duurt?0
En heeft dit scherm ook een DVI aansluiting, kan het nergens terugvinden namelijk..
  • Ossenaar
Ossenaar
Oss de Gekste !!!
Qosmic schreef op 15 June 2003 @ 14:44:
Deze actie duurt 2 weken en het scherm heeft alleen een D-Sub aansluiting
  • Qosmic
wat is ook alweer precies het verschil tussen DVI en D-Sub?
  • Xandrios
Qosmic schreef op 15 June 2003 @ 15:08:
DVI is digitaal, D-sub is een analoge VGA aansluiting...
DVI geeft dus een beduidend beter beeld, maar dan moet je wel een geschikte videokaart hebben. (En je LCD scherm moet dus geschikt zijn, en dat is deze dus niet ;) )
  • STIMPPYYY
  • Laatst online: 23:17
ik dacht dat het verscil tussen Analoog en Digitaal dus echt niet zoveel verschil maakt. Als je games speelt dan maakt het niets uit of je DVI of ANALOOG hebt. :X
Ik heb zelf Analoog beeld nu maar ik krijg dinsdag een nieuwe computer en een vid kaart die DVI heeft dus ik ga even kijken of het echt veel uitmaakt.
[ Voor 34% gewijzigd door STIMPPYYY op 15-06-2003 16:09 ]
  • Qosmic
Mijn videokaart heeft wel DVI (radeon 9500np), maar zit een beetje te twijfelen of ik nou een TFT met DVI zal aanschaffen, of deze, en deze is zonder.
Is het echt zo'n verschil, of is het te verwaarlozen?
  • HunterPro
Och, je zit nu met een omzetting digitaal (uit je PC) -> analoog (door de kabel) -> digitaal (je scherm werkt niet met relatieve waarden aangezien 't een flatpanel is). Beetje onzinnig dus, en duidelijk met verlies van scherpte. Ook is een DVI kabel minder gevoelig voor storingen e.d.
http://www.officecentre.nl/folder14.pdf hier kan je btw de hele folder downloaden :D
  • pagani
Verwijderd schreef op 13 June 2003 @ 14:57:
Beste mensen,
webdesign en tekenprogs
Voor webdesign en tekenprogs is het nogal af te raden om een tft scherm te nemen aangezien deze maar 16 bits kleur weergeeft en niet zoals een crt 24...
Is ook al een topic over in W&G, [rml][ Webdesign algemeen] TFT schermen als developer scherm?[/rml]
[ Voor 14% gewijzigd door pagani op 15-06-2003 19:47 ]
Ik denk dat ik hier maar es twee van naast elkaar ga zetten :)
Ik kom a.s. week wel bij O C Groningen, en dan bekijk ik ze wel ff :)
  • Rickbv
Is het trouwens bij de OfficeCentre mogelijk om die dingen ff te bekijken voor je ze koopt? En dan bedoel ik niet een showmodel, maar het model dat je mee naar huis krijgt. Heb namelijk geen zin in dode pixels oid...
En ik weet niet of het al genoemd was, maar wat kostte dit scherm (niet de 707 dus) nou bij de MediaMarkt?
Ik ga morgen toch nog maar ff kijken of ze er nog zijn. na gehoord te hebben dat het een beetje een rare kleur was leek het me nix (had me oom op pad gestuurd ik moest werken zaterdag) :+ Iedereen is er wel positief over dus ik ga maar wel ff kijken :)
  • raps
Verwijderd schreef op 15 juni 2003 @ 22:14:
'rare kleur'
wat bedoel je daar precies mee? en hoe is dat beoordeeld. Als het beeld gesplit is over 10 monitoren en hij is slecht gekalibreerd.... tja
ehh jah beetje dom gezecht ja (bedenk ik me ook nu dom) |:(
Ik bedoelde de kleur van de monitor zelf, van het plastic dus.
mijn oom zei dat ie heel anders was dan op het plaatje stond, en ze hadden hem gezecht dat er maar 1 kleur was dus, maar ik ga het zelf eens bekijken morgen :+
  • HunterPro
Verwijderd schreef op 15 juni 2003 @ 22:41:
pimpelpaars met gouden stippen heeft ook wel wat hoor :+
Owkee ik heb hem dus wel gehaald en moet zeggen dat ik der toch best wel tevreden over ben. De kleur is gewoon de normale standaart kleur wit en is verder wel oke.
Ik heb er verder nog nix over aan te merken dus :+ :+
  • raps
Yes,
Ik heb hem vandaag ook gehaald... Zeer tevreden! Aan een vriend geshowed en die gaat um ook halen :)
Verder nog een vraagje: het kalibreren van het scherm. ik kwam ergens tegen dat daar een tooltje voor was - hoe heet die ook al weer?
En nog een ander vraagje: Ik heb een Nvidia kaart, en gebruik de nview tools. Is misschien hier ook iets beters voor te vinden? Zoals TVTool is als alternatief voor de Nvidia TV-out ondersteuning?
Ik kon het zo snel niet gevonden krijgen.
  • Xandrios
raps schreef op 16 June 2003 @ 20:47:
Yes,
Ik gebruik Ultramon voor 2x 15" TFT. Bevalt me erg goed !
(Je kunt bijv. 2 onafhankelijke taskbars maken :) )
  • Qosmic
Kan iemand eens wat pics posten van dat scherm?
Ik wilde hem vandaag halen, maar hij was helemaal uitverkocht. A.s vrijdag komen ze weer binnen, maar ben ff benieuwd hoe die eruit ziet, maar dan alleen niet uit de folder...
Qosmic schreef op 17 juni 2003 @ 20:43:
<pics removed wegens bandbreedte problemen>
[ Voor 20% gewijzigd door Verwijderd op 18-06-2003 23:33 ]
  • Qosmic
relaxed!
Istie nou wit of zilver?
  • Beekforel
  • Laatst online: 15:14
Beekforel
Is eigenlijk geen vis
Hm.. interessant!
Ik denk dat dit mijn cadeautje wordt voor het halen van mijn school!
Zou zeker niet misstaan naast mijn 19" CRT, en is een stuk makkelijker mee te nemen naar lan party's enzo!
Qosmic schreef op 17 juni 2003 @ 23:08:
relaxed!
Ik heb er ook een :) .
Die van mij is dus wit, ik heb wel aan de verkoper gevraagd of hij er ook in andere kleuren was, maar dat was hij dus jammer genoeg niet :'( :'(
'K heb hem ook in Office Center gezien! Het lijkt me een aardig TFTtje, en zeker voor office doeleinden!
Edit: Heeft deze TFT ook DVI? Ik heb het niet in de folder zien staan!
[ Voor 29% gewijzigd door Verwijderd op 18-06-2003 22:19 ]
  • Dnc1n
  • Laatst online: 18-11-2025
je krijgt ook nog is 50 euro energiepremie terug!
Dnc1n schreef op 18 June 2003 @ 23:29:
hoe krijg ik die?
Verwijderd schreef op 18 juni 2003 @ 22:17:
geen DVI
[ Voor 30% gewijzigd door Verwijderd op 18-06-2003 23:32 ]
  • Rickbv
Ik geloof toch dat ze dat vanaf 01-01-2003 niet meer doen hoor ;)
  • B-Man
Mooi schermpje ja, heb er een paar dagen geleden ook een gehaald bij de OC. Neemt lekker weinig ruimte in naast mijn IIyama 902MT (19"). Tevens grappig om te zien hoe deze LCD naast mijn IIyama 17"LCD staat, die inmiddels bijna twee jaar oud is (was er vroeg bij met 17"LCD).
Ruikt nog wat nieuw, maar ooooh wat scheelt het toch veel in ruimte :)
  • Dnc1n
Rickbv schreef op 18 June 2003 @ 23:36:
ik weet niet precies hoe je het terug kan krijgen maar ik heb gehoort dat je tft schermen moet promoten ofzoiets. volgens hem kan het nog wel.
  • raps
Dnc1n schreef op 19 juni 2003 @ 09:52:
Dit zal sowieso bij de Office Centre moeilijk gaan. Deze regeling is namelijk alleen voor particulieren en aangezien je pas lid van de office centre bent als je een bedrijf hebt (toch?).
  • raps
Aangezien meerdere mensen dit scherm nu hebben, wilde ik jullie hier vragen hoe jullie hem ingesteld hebben. Ik merk dat mijn kleuren nog niet optimaal zijn (vergelijkend met mijn CRT), maar dat dit puur aan instellingen ligt.
Mijn instellingen:
Brightness: 46
Contrast: 46
Clock: 50
Phase: 54
Color: User
Red: 91
Green: 98
Blue: 74
Ik ben dus vooral benieuwd naar die laatste (kleur instellingen). Ook staan bij mij de brightness en contrast misschien wat laag, maar in het begin was mijn scherm meer een 90Watt lamp, dus heb ik deze veel lager gezet.
  • Nesto
Nesto
Chef du production
Jongens heb een vraag over het broertje van de AL718, de AL712. De al712 is een stukje duurder (+/- 50euro) maar heeft wel DVI. Maakt het nou echt veel uit of je DVI gebruikt wel of niet, graag argumenten en vooral ervaringen(vooral van dit scherm graag). Op het forum zegt de ene dat het we;l merkbaar is de andere niet.
BTW: kun je van dit topic niet AL718+AL712+AL707 anders van maken?
Yes - OEM
  • Beekforel
Beekforel
Ik heb em ook!
Was even vergeten dat je een pasje moest hebben enzo :P
Maar met de postcode en naam van mijn baas kreeg ik een dagkaart en kon ik zo naar binnen :)
Hij ziet er leuk uit, maar heb em nog niet aangehad.
  • Montana
  • Laatst online: 18:40
Montana
Apple and X-H2 ..what else !
Ik heb hem ook gehaald vanavond, zit er strak uit mooie kleuren enz. Doet het ook goed op m'n Acer 800Lci. Even getest met de Nokia test en geen afwijkende pixels.
Apple Studio Max M2 and Apple Studio Display | Macbook Air 15" M2 | FUJIFILM X-H2 | XF200 F2 | XF1.4x TC F2 |XF 2xTC | XF500 f5.6 | XF150-600 | XF80 | XF16-80 | Viltrox 27mm f1.2 PRO X-Mount
  • Qosmic
is die nokia test speciaal om te testen op dode pixels etc?
En zo ja, waar kan ik em downen?
  • Montana
Montana
Qosmic schreef op 19 June 2003 @ 23:00:
Even zoeken staat hier ergens tussen ( Ntest)
Acer Travelmate 80x topic deel 2
Ja Office Centre is niet voor niets de superstore voor bedrijf en kantoor. :P:P
Maar het is inderdaad een heel leuk schermpje toen ik hem binnenkreeg heb ik er 3mark over heen gegooid en het liep redelijk vloeiend.
Blijft een leuk schermpje om te zien en zeker voor die prijs.
  • Q-bone
  • Laatst online: 21:55
Q-bone
Dusss...
zijn er ook mensen die weten bij welke filialen de monitors ng te krijgen zijn (al718) want er staan geen telefoon nummers op de website.
bla?
  • Montana
Montana
In Apeldoorn gisteren avond toen ik hem heb gehaald nog een stuk of 8
Tel; staan gewoon in de Nationale telefoongids.
Apeldoorn Tweelingenln 10, 7324AM Apeldoorn
055 360 1100
[ Voor 45% gewijzigd door Montana op 20-06-2003 17:04 ]
in Beverwijk waren er ook nog een aantal.... maar... morgen laatste dag hè... opschieten dus!
  • PJKs
  • Laatst online: 13-08 16:56
PJKs
Young, Free and Single
Verwijderd schreef op 20 June 2003 @ 17:18:
Vandaag laatste dag lijkt me. Office-centre aanbiedingen lopen bij mijn weten van zaterdag tot en met vrijdag.
ja, graag!
  • raps
PJK schreef op 20 June 2003 @ 17:20:
Zie voorkant Office Centre krantje:
"GELDIG: zaterdag 14 juni T/M vrijdag 27 juni 2003"
Hij loopt dus nog een week...
  • StephaN900
Ik ga hem zo ook kopen denk ik, maar ik heb hem eigenlijk pas nodig vanaf september (lang verhaal) kan ik dan niet beter wachten of wordt hij toch niet veel goedkoper?
  • StephaN900
Nou ik heb hem ook gekocht fijn schermpje hoor, maar wat zijn nu de ideale instellingen?
  • Pollewob
Ideale instellignen is iets wat je zelf moet proberen, niemand kan voor jou bepalen wat jij mooi beeld vind en dan nog heeft elke monitor wel een kleine afwijking waardoor de instellingen net ff anders zijn :)
  • StephaN900
Ah maar ik wil graag het wit krijgen zoals dat bij het onscreen display is dat lukt niet echt. ook heb ik het gevoel dat het een beetje flikkert als ik scroll op een website. iemand een suggestie? :)
  • Q-bone
Q-bone
Dusss...
volgens mij is dat redelijk normaal bij tft's :) dat scrollende tril effect :D
[ Voor 29% gewijzigd door Q-bone op 21-06-2003 18:08 ]
bla?
  • The Dolf
StephaN schreef op 21 June 2003 @ 15:44:
Dat is heel normaal bij tft's.
Bij IE: tools -> options -> advanced
En daar use smooth scrolling uitvinken.
Gezocht!
Samsung 1TB HD103SI printplaat
Router
If everything seems to be going well, you have obviously overlooked something
  • Xandrios
Ik heb hem ook net gehaald *D
Na even vriendelijk gevraagd te hebben, mochten we in de winkel checken op dode pixels. Super !
Na er eerst 2 te moeten afschrijven (dode pixels dus...) hadden we een goede te pakken, meenemen die hap :P
Installen, no problemo...en DAMN wat een lekker beeld :D
Ik had namelijk al 2 andere LCD schermen. IBM 15" dingen. Maar als ik die nu naast deze zet, ze zijn echt veel minder helder en scherp :(
Maargoed, des te beter voor deze acer monitoren natuurlijk ;)
Klik hier voor een picje:
http://crew.tweakers.net/Cutebritney/troep/lcd1.jpg
  • StephaN900
Ah het is een fijn scherm ja bedankt voor die tip trouwens dolf stukken beter nu ;). Maar is het mogelijk om het wit op het scherm net zo wit te krijgen als bij het on screen display menu? (degene die het scherm hebben begrijpen mij waarschijnlijk wel ;) )
  • Xandrios
Probeer eens te spelen met de mkleurbalans van je videokaart oid. Want ik heb daar helemaal geen last van na een ram op de auto knop :?
(OSD menu en wit @ desktop is dus precies hetzelfde....)
  • Xandrios
Nee, dit is leuk:
* Xandrios wilde er nog eentje kopen. Heb er al een staan, maar dual is toch wel heel erg :9
Magoed, ikke dus eerst maar even bellen voor de zekerheid: UITVERKOCHT :'(
Maar oke...een ritje Almelo ==> Hengelo heb ik er nog wel voor over. Hengelo gebeld...OOK OP :(
Iemand enig idee welke vestigingen ze nog hebben? Liefst in overijssel *D :P
  • raps
was dit dan zo'n unieke aanbieding??
Meestal is het zo dat binnen enkele weken er wel ergens anders dit scherm voor zo'n prijs te krijgen is. Of de Office Centre koopt hem nog eens in wegens succes.
Met de Neovo TFT's was dit volgens mij ook het geval...
  • Rickbv
Via de Pricewatch is het scherm toch ook te vinden? Uit m'n hoofd dacht ik dat ACES Online hem nog zag staan. Maar waar het jou waarschijnlijk om gaat, de dode pixels? Valt daar met de desbetreffende shop dan geen mooie regeling voor te maken? :)
  • MarSee
  • Laatst online: 10-12-2025
Ik heb dit scherm vandaag ook gekocht.
Goed beeld, niks op aan te merken
Gister hadden ze 10 binnengekregen.
Vandaag was ik diegene die de laastste kon kopen.
Dus voor het geld een zeer goed ding
Greetz MarSee
  • Xandrios
Rickbv schreef op 24 June 2003 @ 00:40:
ACE gebruikt ex-btw prijzen in de PW. Stelletje naaiballen :/
Zelfs na het melden weigeren ze er iets aan te doen (Natuurlijk, want je krijgt extra klanten als je bovenaan de lijst staat :r )
Magoed, ACE dus:
"Prijs inclusief b.t.w. en verzendkosten 404,60 Euro."
Dus ik heb hem zojuist bij homeshopper besteld. Die hebben een eigen bezorgservice, en ze checken van te voren ook op dode pixels. En bij aflevering mag je dus ook zelf eerst even testen :)
377 euro inc. btw en verzendkosten, erg netjes dus.
  • T.T.
  • Laatst online: 22-01 14:13
T.T.
Sowieso
Hoe kunnen jullie allemaal bij Office Center kopen? Op de site lees ik dat je daar een bedrijfje voor moet hebben (inschrijving KvK)?
Ah, dat verklaart het :)
[ Voor 26% gewijzigd door T.T. op 25-06-2003 18:07 ]
  • Xandrios
T.T. schreef op 25 June 2003 @ 18:07:
Nee, dat verklaard het niet; want ik heb er al 1 bij de OfficeCentre gehaald ;)
Alleen voor een 2e monitor wilde ik er nog een halen > uitverkocht. Dus vandaar dat ik hem nu ergens anders bestel ;)
Maar om maar ff antwoord te geven op je vraag: Veel tweakers hebben wel een bedrijfje, of kennen iemand die er een heeft.
  • Q-bone
Q-bone
Dusss...
wat voor merk scherm heeft de acer 718 eigelijk?
bla?
  • T.T.
T.T.
Sowieso
Cutebritney schreef op 25 juni 2003 @ 17:57:
Hoe kom je bij die voorwaarden? Ik zag ze zo snel niet in de algemene voorwaarden staan (zag alleen iets over andere merken). Bovendien heb ik ze vanochtend gemaild en nog steeds geen antwoord van ze ontvangen :/
  • Beekforel
Beekforel
Nu ik deze TFT een tijdje in gebruik heb, begin ik mijn 19" 109P Philips CRT monitor zeer onscherp te vinden :(
Ik ben nu dus op zoek naar een liefhebber voor mijn monitor en ga er nog 1 halen :9
Ik zal eens bij homeshopper kijken dan...
  • Xandrios
T.T. schreef op 26 June 2003 @ 20:23:
De eerste email duurde inderdaad wat lang, kleine 24 uur:
Goedemiddag,
Deze monitor wordt getest bij de groothandel.
Wij leveren deze op afspraak zelf bij u af (niet op de Waddeneilanden en in Zeeuws-Vlaanderen).
Dan kunnen we hem samen bekijken en indien er toch dode pixels inzitten, dan geeft u hem weer mee terug en hoeft u niets te betalen.
De totale bezorgkosten is 15 Euro, ook bij vooruitbetalen.
Met vriendelijke groeten,
Arie Westerdijk
www.homeshopper.nl
Maar daarna was in 15 min, 5 mailtjes verder, ook de datum en tijd van bezorging etc afgesproken...
Magoed, als je dus een 0 pixel garantie wilt, zul je denk ik inderdaad even moeten mailen en afspreken dat je bij aflevering mag testen. (In dit geval dus een groot voordeel dat ze zelf bezorgen, even testen als de TPG aan de deur staat lukt niet echt ;) )
[ Voor 15% gewijzigd door Xandrios op 26-06-2003 22:25 ]
  • itsgreen
  • Laatst online: 02-12-2025
itsgreen
Large and in charge
Heb 2 schatjes vandaag gehaald, helaas heeft 1tje een bright red subpixel :( maarja shit happens! voor de rest ziet hij er super uit!
Heeft iemand de 718 gezien in vergelijking met de 712?
Ze zijn beide even duur, specs zijn ook ongeveer gelijk maar de 718 gaat het eruit geloof ik... Als je dus zou moeten kiezen tussen deze 2, welke zou je nemen?
Ik lees dis vrijwel alleen maar goede dingen over die 718 maar de 712 is dus iets nieuwer en ja is dit een betere keuze?
Verwijderd schreef op 03 september 2003 @ 10:45:
JA, de 712 is een betere keuze ivm het feit dat de 712 DVI heeft en de 718 niet.
Kan iemand mij de verschillen tussen de ACER 721 en de ACER 712 aangeven? Behalve zijn uiterlijk ...
en zijn er hier ook gebruikers van de acer 712 of de 721? Zo ja, hoe is het in gebruik?
gevonden:
ACER 721
Maximale resolutie 1280 x 1024
Inkijkhoek 140/140 (H/V)
Helderheid 260cd/m2
Contrast 450:1
Afmetingen 377x391x154
Reactietijd 16ms
Aantal kleuren 16.7M
Menu talen
Connector Analog (D-sub), DVI-D,
Audio onboard Ja
USB onboard Nee
Stroomverbruik 5
Netto gewicht 45
Het is een 16ms en die wil ik niet. Had ergens namelijk gelezen dat die veel minder kleuren aankonden. Ik kies dan toch voor de Acer 712 als beste budget 17" tft monitor.
[ Voor 102% gewijzigd door Verwijderd op 17-09-2003 23:07 ]
Pagina: 1 2 Laatste
