na uitschakelen windows XP, automatische herstart
  • 118 views sinds 30-01-2008
hallo,
ik heb een vreemd probleem..
als ik mijn windows xp afsluit dan schakelt hij voor 2 seconden uit en dan gaat hij weer aan. alle wake-on functies staan uit.
Als hij dan is herstart staat de klok altijd fout (datum is wel goed). dus lijkt mij niet dat de batterij leeg is.
voorheen werkte alles perfect, vind het maar heel vreemd.
mvg
  • MRic3
  • Laatst online: 24-08 07:43
MRic3
Of praat ik weer poep?
ff zoeken op de knowledge base....
Misschien is het dit???
http://support.microsoft....aspx?scid=kb;EN-US;320299
Windows XP Restarts Unexpectedly or Restarts When You Shut Down the Computer
The information in this article applies to:
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
This article was previously published under Q320299
SYMPTOMS
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. A error message on a blue screen may appear when the computer restarts.
CAUSE
This behavior may occur if Windows throws a fatal error during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart during a fatal error. To view this setting, right-click My Computer, click the Advanced tab, click Settings under Startup and Recovery, and then view the Automatically restart check box under System Failure. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
RESOLUTION
If your computer constantly restarts if you are using the computer or if you are trying to shut down the computer, click to clear the Automatically restart check box. If you clear this check box, you receive an error message if a stop error occurs. This error message may describe the cause of the critical stop error. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
For additional information, click the article number below to view the article in the Microsoft Knowledge Base:
308427 HOW TO: View and Manage Event Logs in Event Viewer in Windows XP
To configure Windows' behavior if the computer stops unexpectedly, follow these steps.
NOTE: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
Log on to the host computer as either an administrator or the owner.
Click Start, and then click Control Panel.
Click Performance and Maintenance under Pick a category.
Click System under the or pick a Control Panel icon section.
Click the Advanced tab, and then click Settings under Startup and Recovery.
Click to select any of the following check boxes under System Failure:
Write an event to the system log
Send an administrative alert
STATUS
This behavior is by design.
MORE INFORMATION
By default, the Automatically restart check box is selected so that you can continue to use the computer if a critical stop error occurs. Microsoft Services start during the startup process before you log on; therefore the computer is functional after it restarts. If the computer stops because of a critical stop error, you lose all functionality including the remote access functionality. After the computer restarts, you can investigate the reason for the stop error.
The stop error message only displays information about the possible cause of the critical stop error. In most situations, the error is logged in the system log.
You can configure Windows to perform the following actions if a severe error such as a stop error or fatal system error occurs:
Write an event to the system log.
Notify administrators.
Automatically restart the computer.
Dump system memory to a file that advanced users can use for debugging.
You must have at least a 2-megabyte (MB) paging file on the computer's boot volume if you want to configure the computer to either write an event to the system log or notify an administrator. If you configure Windows to create a dump file that contains the system memory data, you can use the dump file to debug the cause of the stop error.
To configure Windows to create a dump file:
Under Write Debugging Information, click one of the following entries:
Small Memory Dump: If you click this setting, the smallest amount of information that helps you identify the problem is recorded. This setting requires that you have at least 2 MB available for a paging file on the boot volume of your computer. If you click this setting, Windows creates a new file each time the computer stops unexpectedly. A history of these files is stored in the folder that is listed in the Dump File box.
Kernel Memory Dump: If you click this setting, only kernel memory is recorded, which speeds up the process of recording information in a log when the computer stops unexpectedly. Depending on the amount of random-access memory (RAM) in your computer, you must have 50 MB to 800 MB available for the paging file on the boot volume. The file is stored in the folder that is listed in the Dump File box.
Complete Memory Dump: If you click this setting, the contents of the system memory are recorded when the computer stops unexpectedly. If you use this setting, you must have a paging file on the boot volume that is large enough to hold all of the physical RAM plus one MB. The file is stored in the folder that is listed in the Dump File box.
Windows always writes to the same file name. To save individual dump files, click to clear the Overwrite any existing file check box and change the file name after each stop error.
To save memory, click to clear both the Write an event to the system log check box and the Send an administrative alert check box. The memory that is saved depends on the computer. Typically, about 60 kilobytes (KB) to 70 KB of RAM is required by these debugging features.
If the world didn't suck, we would all fall off!!!
ik heb automatisch herstarten uitstaan!
ik heb echt al alles geprobeert denk'k, ben ten einde raad..
niemand bekend met dit probleem?
ook als ik mijn pc aanzet dan duurt het 2 seconden, je hoort een "tik" en dan gaat hij aan.
  • Han
Han
SP1 al geinstalleerd?
En hier al na gekeken: Waarom sluit XP niet af, maar reboot hij?
[ Voor 37% gewijzigd door Han op 29-05-2003 13:40 ]
  • STN
  • Laatst online: 01-02-2024
STN
Ik heb dus net een verse windows xp sp1 geinstalleerd en heb dus het zelfde probleem. Ik heb al mn apm uit en aan gezet in xp en in mn bios, niks helpt.
Gezocht op google, Ms knowledge base. Maar alles wat ze als eventuele oplossingen geven helpt niet. Ik krijg ook geen blauwscherm tussen het uitschakelen en het opnieuw opstarten, maar heb wel al het vinkje voor opnieuw opstarten bij fout uitgeschakeld. Het is een verse instal dus geen roxio of direct cd geistalleerd. Wel heb ik een logitech usb muis maar daar heb ik nieuwste drivers voor en in de settings van mn usb staan de vinkjes voor het opstarten van windows uit.
Ik weet het nu echt niet meer. Jullie wel???
[ Voor 1% gewijzigd door STN op 21-11-2003 10:40 . Reden: MS ipv M$ ]
  • Zaagmans
  • Laatst online: 16-07 21:13
STN schreef op 21 november 2003 @ 10:32:
Gezocht op google, M$ knowledge base. Maar alles wat ze als eventuele oplossingen geven helpt niet. Ik krijg ook geen blauwscherm tussen het uitschakelen en het opnieuw opstarten, maar heb wel al het vinkje voor opnieuw opstarten bij fout uitgeschakeld. Het is een verse instal dus geen roxio of direct cd geistalleerd. Wel heb ik een logitech usb muis maar daar heb ik nieuwste drivers voor en in de settings van mn usb staan de vinkjes voor het opstarten van windows uit.
1 ding weet ik wel, dingen als M[dollarteken] (=dollarteken ipv de S) wordt niet op prijs gesteld
- Ruud
  • STN
STN
zo goed?
  • Shaggy_NL
  • Laatst online: 19-07 23:38
Haal effe alle USB apparaten eruit. Dit was bij m'n nieuwe Canon i850 wel het probleem. Deze kan ik alleen aansluiten op m'n on-board aansluitingen, maar niet op m'n PCI uitbreidings kaartje. Dus check dat effe.
Groet & succes.
  • STN
STN
Ik heb mn usb muis eruit gehaald. Er nu geen enkel usb device meer aangesloten.
Ik heb nu wel een aantal foutmeldingen gekregen. waronder deze:
Afbeeldingslocatie: http://home.wanadoo.nl/gr49/fout2.jpg
Ook krijg ik bij slaapstand een blauwscherm, ik kan het niet goed leze wat er staat want hij start snel weer op.
Probeer zo wel een foto te maken.
BTW: Ik heb alle windows updates geinstalleerd.
mijn probleem is dus nog steeds niet opgelost heb vandaag net een nieuw battertje erin gedaan. zie net dat u op mijne post replied, maar dit is niet hetzelfde probleem.
En mijn pc reboot niet, maar start vanzelf als hij 3 seconden uitstaat gaat hij ineens terug aan. Maar nu met deze nieuwe batterij werkt hij weer wel, maar over 3 maanden zal die waarschijnlijk weer leeg zijn :s
-doe eens een memtest http://www.memtest86.com/, deze kan fouten geven.
-alle drivers geistalleerd?
-probeer nog eens een clean install (format als ntfs)
-probeer eens uw bios te updaten.
-u kan misschien ook nog eens een voeding van een kameraad testen.
  • InsjaHH
  • Laatst online: 15-09 22:29
Zover ik het begrepen heb, hebben de WinXP updates geen oplossing gebracht?
Maar goed, misschien heb je dit al gecontroleerd, maar is er misschien de mogelijkheid dat Wake on LAN aanstaat? Dat mogelijk een andere computer (of breedband-modem) jouw computer aanspreekt en daardoor dus vanzelf aangaat? Sinds je zelf aangeeft dat hij 3 seconden uit wil blijven en dan plots weer "reboot".
Probeer in het BIOS te achterhalen of dit het geval is en zo ja, het dus te disablen :P
Kijk of de optie's voor Wake on ... allemaal uitstaan, misschien werkt de "feature" niet naar behoren. Met ... bedoel ik dus bijv. Wake on USB, PS2 etc etc.
Website, Flickr, FB, Twitter
dat dacht ik eerst ook, maar alle wake-on staan disabled..
nu gaat alles goed, enkel als mijn batterij leeg is doet ie dat. (+- 3 maanden gaat mijn batterij mee, niet zo lang lijkt me)
Dit probleem heb ik ook eens gehad.
Bij mij was het een software matig conflict i.s.m. (of eigenlijk niet in samenwerking) easy cdcreator.
Dus als die op je pc staat, probeer het eens te deinstallen, en dan nog een keer proberen, bij mij waren alle problemen daarna opgelost.
  • InsjaHH
Is het probleem ondertussen nu opgelost of ben je nu nog aan het zoeken? :?
Persoonlijk vind ik het best jammer en irri als mensen iets vragen en uiteindelijk zelf niet eens meer terugkomen...
Kan ook zijn dat ik dit gewoon te vroeg zeg :+ Mocht dit het geval zijn, dan zei ik niks ;)
ik zou ook graag wat meer horen, een familielid van me heeft hetzelfde probleem namelijk. Misschien kun je even wat meer vermelden hier?
batterij is weer leeg,
dus hij doet het weer :s
ik ga eens een nieuwe voeding proberen, hopelijk helpt dit.
anders kom ik nog eens terug.
greets
  • Han
Han
Mjah... niet echt een nuttige kick, vind je zelf ook niet? 8)7
