Battle.net en freesco werkt niet
  • paradoXical
  • Laatst online: 04-09 09:22
Ik zit dus met mijn handen in mijn haar, alles wat ik doe werkt altijd, maar nu..
Netjes port fowarding aangezet in Freesco:
t,6112,192.168.0.5/6112
u,6112,192.168.0.5/6112
En ik kan maar niet connecten naar Battle.net
Originele installatie
Voor de rest werkt alles goed thuis, dit zou toch ook moeten gaan?
Van battle.net:
What ports are required and with what settings?
In order to connect to Battle.net, thru your Local Area Network, while allowing others to connect to games you create, make sure you have the following ports setup as described below.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112 TCP out and allow established sessions in
Allow port 6112 UDP out and in
Wat doe ik in godsnaam fout?
She was beautiful. God I loved her. I just didn't know how to show it, that's all. I killed her, Red. I didn't pull the trigger, but I pushed her away. And that's why she died, because of me.
  • Zer0
  • Registratie: September 1999
Zer0
Destroy 2000 Years Of Culture
Blizzard Battlenet
This allows for -1- machine on the network to take advantage of Blizzard's BattleNet system for playing online games such as Diablo II and StarCraft. The 6112 port is needed in both TCP and UDP for StarCraft and Diablo II, and the 4000 port is needed for Diablo II. No other settings should be needed.
IN TCP 4000
IN TCP 6112
IN UDP 6112
Bron: http://www.practicallynet...g/app_port_list.htm#Games
maybe we sit down and talk about the revolution and stuff
but it doesn't work like that
you can't turn back now there's no way back
you feel the power to destroy your enemy..
  • paradoXical
Precies wat ik heb ingesteld.... Dit is echt frustrerend...
Die poort 4000 heb ik ook
[ Voor 6% gewijzigd door paradoXical op 06-05-2003 12:47 ]
  • sirdupre
  • Laatst online: 27-04-2025
ze zou eens uit kunnen proberen of die poorten ook écht geforward worden, bijvoorbeeld door een http server op poort 4000 te laten draaien op de machine die verbinding met battle.net moet leggen en dan iemand van buiten af verbinding laten maar met poort 4000 op de freesco machine.
Stomme vraag, maar heb je al gereboot?
  • paradoXical
Verwijderd schreef op 06 mei 2003 @ 13:09:
Reboot is niet nodig!
Tijd terug moest ik poort openen voor normale host games, die werken allemaal zonder reboot...
Ja de poorten staan echt open! Ik snap er niets van, probleem moet dan bij Diablo II zelf liggen neem ik aan?
  • tweak_dude
Vreemd. Ik d8 dat je battle.net geen poorten open hoefde te zetten :? Dat hoef ik iig nooit te doen (Warcraft II Battle.net).
  • paradoXical
Op de blizzard site staat dus van wel en ik heb het netjes gedaan, maar het werkt niet.. Best irri :)
  • Gallus
  • Laatst online: 17-09 12:44
Gallus
Cheesy
Ik hoefde voor Warcraft III helemaal niks te forwarden (met freesco!) om op B.net te kunnen komen. Dit was pas nodig toen ik een spelletje wilde hosten.
All I want is a warm bed, a kind word and unlimited power.
  • nero355
  • Laatst online: 10-07 17:18
nero355
ph34r my [WCG] Cows :P
Gebruikt battle.net of een van hun games net zoals bijvoorbeeld msn/icq een eigen protocol :?
Dan kan het best zijn dat het niet werkt ;)
  • paradoXical
Ik heb echt alles geprobeerd, ook op een andere pc...
Klote B.net werkt gewoon niet en ik begin nu aardig over de zeik te raken :(
Gekraakt werkt alles, koop je iets en dan werkt de zooi nooit ^#&#^& :(
Update:
via telnet kan ik zonder routes connecten naar
uswest.battle.net 6112
[ Voor 19% gewijzigd door paradoXical op 06-05-2003 22:21 ]
  • paradoXical
iemand?
Anders eens proberen naar blizzard t emailen, ik heb denk ik alles wel geprobeerd. Zelfs een installatie op een andere pc binnen het netwerk.
[ Voor 92% gewijzigd door paradoXical op 07-05-2003 10:33 ]
  • sirdupre
Heb je nou al geprobeerd of die poorten ook écht geforward worden? Dat kun je dus niet van binnen je netwerk zien, dat moet je echt iemand vanaf het internet laten proberen. En een andere pc binnen het netwerk moet dan natuurlijk ook wel het ip hebben waar je die poorten heen forwardde....
