Sorry mijn laatste post was een beetje vaag, maar hier komt hij nog een keer. Dit kwam omdat ons moeder boos was en de internetstekker eruit trok. Kon er nix aan doen. Maar hier komt ie.
De volgende foutmelding krijg ik:
[img][/img]
Op de genoemde regel in db_mysql.php regel 32 staat het volgende. Ik heb hier de regel dik gedruk gemaakt.
<?php
error_reporting(7);
// db class for mysql
// this class is used in all scripts
// do NOT fiddle unless you know what you are doing
class DB_Sql_vb {
var $database = "";
var $link_id = 0;
var $query_id = 0;
var $record = array();
var $errdesc = "";
var $errno = 0;
var $reporterror = 1;
var $server = "localhost";
var $user = "root";
var $password = "";
var $appname = "vBulletin";
var $appshortname = "vBulletin (cp)";
function connect() {
global $usepconnect;
// connect to db server
if ( 0 == $this->link_id ) {
if ($this->password=="") {
if ($usepconnect==1) {
$this->link_id=mysql_pconnect($this->server,$this->user);
} else {
$this->link_id=mysql_connect($this->server,$this->user);
} else {
$this->link_id=mysql_pconnect($this->server,$this->user,$this->password);
} else {
$this->link_id=mysql_connect($this->server,$this->user,$this->password);
if (!$this->link_id) {
$this->halt("Link-ID == false, connect failed");
if ($this->database!="") {
if(!mysql_select_db($this->database, $this->link_id)) {
$this->halt("cannot use database ".$this->database);
function geterrdesc() {
$this->error=mysql_error();
return $this->error;
function geterrno() {
$this->errno=mysql_errno();
return $this->errno;
function select_db($database="") {
// select database
if ($database!="") {
$this->database=$database;
function query($query_string) {
global $query_count,$showqueries,$explain,$querytime;
// do query
if ($showqueries) {
echo "Query: $query_string\n";
global $pagestarttime;
$pageendtime=microtime();
$starttime=explode(" ",$pagestarttime);
$endtime=explode(" ",$pageendtime);
$beforetime=$endtime[0]-$starttime[0]+$endtime[1]-$starttime[1];
echo "Time before: $beforetime\n";
$this->query_id = mysql_query($query_string,$this->link_id);
if (!$this->query_id) {
$this->halt("Invalid SQL: ".$query_string);
$query_count++;
if ($showqueries) {
$aftertime=$endtime[0]-$starttime[0]+$endtime[1]-$starttime[1];
$querytime+=$aftertime-$beforetime;
echo "Time after: $aftertime\n";
if ($explain and substr(trim(strtoupper($query_string)),0,6)=="SELECT") {
$explain_id = mysql_query("EXPLAIN $query_string",$this->link_id);
echo "</pre>\n";
echo "
<table width=100% border=1 cellpadding=2 cellspacing=1>
<tr>
<td><b>table</b></td>
<td><b>type</b></td>
<td><b>possible_keys</b></td>
<td><b>key</b></td>
<td><b>key_len</b></td>
<td><b>ref</b></td>
<td><b>rows</b></td>
<td><b>Extra</b></td>
</tr>\n";
while($array=mysql_fetch_array($explain_id)) {
echo "
<tr>
<td>$array[table] </td>
<td>$array[type] </td>
<td>$array[possible_keys] </td>
<td>$array[key] </td>
<td>$array[key_len] </td>
<td>$array[ref] </td>
<td>$array[rows] </td>
<td>$array[Extra] </td>
</tr>\n";
echo "</table>\n<BR><hr>\n";
echo "\n<pre>";
} else {
echo "\n<hr>\n\n";
return $this->query_id;
function fetch_array($query_id=-1,$query_string="") {
// retrieve row
if ($query_id!=-1) {
$this->query_id=$query_id;
if ( isset($this->query_id) ) {
$this->record = mysql_fetch_array($this->query_id);
} else {
if ( !empty($query_string) ) {
$this->halt("Invalid query id (".$this->query_id.") on this query: $query_string");
} else {
$this->halt("Invalid query id ".$this->query_id." specified");
return $this->record;
function free_result($query_id=-1) {
// retrieve row
return @mysql_free_result($this->query_id);
function query_first($query_string) {
// does a query and returns first row
$query_id = $this->query($query_string);
$returnarray=$this->fetch_array($query_id, $query_string);
$this->free_result($query_id);
return $returnarray;
function data_seek($pos,$query_id=-1) {
// goes to row $pos
return mysql_data_seek($this->query_id, $pos);
function num_rows($query_id=-1) {
// returns number of rows in query
return mysql_num_rows($this->query_id);
function num_fields($query_id=-1) {
// returns number of fields in query
return mysql_num_fields($this->query_id);
function insert_id() {
// returns last auto_increment field number assigned
return mysql_insert_id($this->link_id);
function close() {
// closes connection to the database
return mysql_close();
function halt($msg) {
$this->errdesc=mysql_error();
// prints warning message when there is an error
global $technicalemail, $bbuserinfo, $scriptpath, $HTTP_SERVER_VARS;
if ($this->reporterror==1) {
$message="Database error in " . $this->appname . " $GLOBALS[templateversion]:\n\n$msg\n";
$message.="mysql error: " . $this->errdesc . "\n\n";
$message.="mysql error number: " . $this->errno . "\n\n";
$message.="Date: ".date("l dS of F Y h:i:s A")."\n";
$message.="Script: $GLOBALS[bburl]" . (($scriptpath) ? $scriptpath : $HTTP_SERVER_VARS['REQUEST_URI']) . "\n";
$message.="Referer: ".$HTTP_SERVER_VARS['HTTP_REFERER']."\n";
if ($technicalemail) {
@mail ($technicalemail,$this->appshortname. " Database error!",$message,"From: $technicalemail");
echo "<html><head><title>$GLOBALS[bbtitle] Database Error</title><style>P,BODY{FONT-FAMILY:tahoma,arial,sans-serif;FONT-SIZE:11px;}</style><body>\n\n<!-- $message -->\n\n";
echo "</table></td></tr></table></form>\n<blockquote><p> </p><p><b>There seems to have been a slight problem with the $GLOBALS[bbtitle] database.</b><br>\n";
echo "Please try again by pressing the <a href=\"javascript:window.location=window.location;\">refresh</a> button in your browser.</p>";
echo "An E-Mail has been dispatched to our <a href=\"mailto:$technicalemail\">Technical Staff</a>, who you can also contact if the problem persists.</p>";
echo "<p>We apologise for any inconvenience.</p>";
if ($bbuserinfo['usergroupid']==6) {
echo "<form><textarea rows=\"12\" cols=\"60\">".htmlspecialchars($message)."</textarea></form>";
echo "</blockquote></body></head></html>";
exit;
Ik snap hem zelf niet. Ik wil zo graag mijn eigen test-board maken zodat ik die later online ken zetten. Mijn wachtwoord enzo daar heb je toch nix aan, want ik heb niet voor nix een offline webserver opgezet. Zo ken ik er offline aan werken. Die wachtwoorden gebruik ik niet eens dit was alleen als voorbeeld. Ik ben niet zo dom om die wachtwoorden te gebruiken. Moest ik alleen ffkes gebruiken, omdat ik die hier dan kon posten en dat ik duz zoveel mogelijk informatie kon geven.
