om FoOL nog even aan te vullen (je was wéér eerder, je gaat het leren
Line Message
8 The tag: "body" doesn't have an attribute: "marginwidth" in currently active versions.
8 The tag: "body" doesn't have an attribute: "marginheight" in currently active versions.
8 The tag: "body" doesn't have an attribute: "leftmargin" in currently active versions.
8 The tag: "body" doesn't have an attribute: "topmargin" in currently active versions.
9 The tag: "table" doesn't have an attribute: "height" in currently active versions.
10 The tag: "tr" doesn't have an attribute: "height" in currently active versions.
11 The tag: "td" doesn't have an attribute: "background" in currently active versions.
12 The tag: "td" doesn't have an attribute: "background" in currently active versions.
16 The tag: "tr" doesn't have an attribute: "height" in currently active versions.
17 The tag: "td" doesn't have an attribute: "background" in currently active versions.
18 The tag: "td" doesn't have an attribute: "background" in currently active versions.
19 The tag: "td" doesn't have an attribute: "background" in currently active versions.
20 The tag: "td" doesn't have an attribute: "background" in currently active versions.
21 The tag: "td" doesn't have an attribute: "background" in currently active versions.
25 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
25 Nesting error, "b" should be closed before closing "font"
35 The tag: "table" doesn't have an attribute: "height" in currently active versions.
37 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
39 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
40 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
42 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
43 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
45 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
46 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
48 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
49 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
51 Nesting error, "b" should be closed before closing "table"
51 Nesting error, "font" should be closed before closing "table"
54 The tag: "table" doesn't have an attribute: "height" in currently active versions.
56 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
57 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
57 The tag: "td" doesn't have an attribute: "background" in currently active versions.
59 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
60 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
61 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
61 The tag: "td" doesn't have an attribute: "background" in currently active versions.
63 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
64 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
65 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
65 The tag: "td" doesn't have an attribute: "background" in currently active versions.
67 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
68 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
69 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
69 The tag: "td" doesn't have an attribute: "background" in currently active versions.
71 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
72 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
73 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
73 The tag: "td" doesn't have an attribute: "background" in currently active versions.
75 Nesting error, "b" should be closed before closing "table"
75 Nesting error, "font" should be closed before closing "table"
78 The tag: "table" doesn't have an attribute: "height" in currently active versions.
80 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
81 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
81 The tag: "td" doesn't have an attribute: "background" in currently active versions.
83 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
84 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
85 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
85 The tag: "td" doesn't have an attribute: "background" in currently active versions.
87 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
88 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
89 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
89 The tag: "td" doesn't have an attribute: "background" in currently active versions.
91 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
92 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
93 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
93 The tag: "td" doesn't have an attribute: "background" in currently active versions.
95 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
96 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
97 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
97 The tag: "td" doesn't have an attribute: "background" in currently active versions.
99 Nesting error, "b" should be closed before closing "table"
99 Nesting error, "font" should be closed before closing "table"
102 The tag: "table" doesn't have an attribute: "height" in currently active versions.
104 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
105 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
105 The tag: "td" doesn't have an attribute: "background" in currently active versions.
107 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
108 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
109 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
109 The tag: "td" doesn't have an attribute: "background" in currently active versions.
111 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
112 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
113 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
113 The tag: "td" doesn't have an attribute: "background" in currently active versions.
115 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
116 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
117 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
117 The tag: "td" doesn't have an attribute: "background" in currently active versions.
119 The tag:"tr" is not allowed within: "b" It is only allowed within: table, tbody, tfoot, thead.
120 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
121 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
121 The tag: "td" doesn't have an attribute: "background" in currently active versions.
123 Nesting error, "b" should be closed before closing "table"
123 Nesting error, "font" should be closed before closing "table"
126 The tag: "table" doesn't have an attribute: "height" in currently active versions.
136 The tag: "tr" doesn't have an attribute: "height" in currently active versions.
139 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
140 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
140 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
141 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
141 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
142 The tag:"td" is not allowed within: "b". No valid contexts are specified for this element in currently active versions.
142 absmiddle is not a valid value for the "valign" attribute in HTML32. Valid values for this attribute are: Dynamic expression, baseline, bottom, middle, top.
142 absmiddle is not a valid value for the "valign" attribute in HTML4. Valid values for this attribute are: Dynamic expression, baseline, bottom, middle, top.
142 absmiddle is not a valid value for the "valign" attribute in any of the currently active versions. See the above warnings for more details.
142 In HTML 4.0, FONT is deprecated. It may become obsolete in future versions, consider using style sheets instead.
142 The value ADMIN/DEFAULT.ASP is not valid for the "href" attribute in HTML20. The value is valid if double quoted.
142 ADMIN/DEFAULT.ASP is not a valid value for the "href" attribute in any of the currently active versions. See the above warnings for more details.
142 The value _BLANK is not valid for the "target" attribute in HTML4. The value is valid if double quoted.
142 _BLANK is not a valid value for the "target" attribute in any of the currently active versions. See the above warnings for more details.
142 The value IMGS/PIJL.GIF is not valid for the "src" attribute in HTML20. The value is valid if double quoted.
142 IMGS/PIJL.GIF is not a valid value for the "src" attribute in any of the currently active versions. See the above warnings for more details.
142 The tag: "img" doesn't have an attribute: "valign" in currently active versions.
144 Nesting error, "b" should be closed before closing "table"
144 Nesting error, "font" should be closed before closing "table"
