Ik heb windows XP met een Radion 9000 videokaart.
Mijn probleem is dat vrijwel alle spellen zeggen dat mn OpenGL subsystem niet geladen kan worden;
--- Common Initialization ---
Medal of Honor PC 0.05 win-x86 Nov 27 2001
----- FS_Startup -----
Current search path:
C:\Program Files\EA GAMES\MOHAADemo\main\Pak7.pk3 (1 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak6.pk3 (1 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak5.pk3 (12 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak4.pk3 (76 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak3.pk3 (450 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak2.pk3 (563 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak1.pk3 (249 files)
C:\Program Files\EA GAMES\MOHAADemo\main\Pak0.pk3 (3035 files)
C:\Program Files\EA GAMES\MOHAADemo/main
4387 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 8
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Iemand een idee hoe dit komt?
Bedankt
execing default.cfg
execing menu.cfg
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...calling CDS: ok
...35 PFDs found
...initializing QGL
Bedankt
