[PC] Het CS topic - deel I
Pagina: 1 2 ... 7 Laatste
  • 2.072 views sinds 30-01-2008
  • inXs
  • Laatst online: 08:45
inXs
known as inXs
*afbeelding weg geëdit wegens loginscherm*
In navolging van: Counter-Strike 1.6 Je mening! dit "grote" CS topic voor alle CS gerelateerde dingen. Aangezien CS 1.6 uiteraard hot item is zal dit topic hier vooral om draaien.
Voor alles over 1.6 kijk op: http://www.beta16.tk/
Voor alles over steam kijk op: http://www.steam-gaming.com/
Allereerst een review over de nieuwste steam:
De nieuwe update van Steam bevat de volgende changes en fixes, die tijdens het starten van Steam automatisch worden bijgewerkt:
-Updated version of de_airstrip. Another route added from the CT spawn point.
-Updated version of de_aztec.
-Updated version of de_pirenesi.
-Updated version of de_inferno.
-Changed order of weapons in buy menus. They are sorted by price now.
-Added .tga files to the Buy Menus for the Nightvision goggles, Kevlar, Kevlar/Helmet, and the Defuse kit.
-Updated the .tga file for the Elite pistols to show two guns instead of one.
-Changed default spectator modes to chase locked with auto director enabled.
-Removed the gaps in buy menus for weapons you can't buy.
-Deactivated invalid camera options when in spectator mode.
Bug Fixes:
-Fixed crash when running game in software mode.
-Fixed the smoke grenades while spectating, now will work in all modes, including the overview map.
-Fixed not being able to drop the C4 as a terrorist while holding a shield without dropping the shield first.
-Fixed shield bullet penetration bug. Bullets will not penetrate the shield under any situation.
-Fixed exploit where you would be hit in the shield and then be invincible to fall damage.
-Fixed crosshair disappearing if you switched to a different weapon while holding a deployed shield.
-Fixed bug that would give you armor if the damage you took was really low.
-Fixed wrong player animation being played while holding a shield and throwing a grenade or swinging the knife.
-Fixed bug with spectator mode chase free and having auto director enabled.
-Fixed bug with bottom spectator menu button if there are no players available to spectate.
-Fixed death notices appearing under the upper spectator panel when in spectator mode.
-Fixed chat text appearing under the bottom spectator panel when in spectator mode.
-Fixed position of chat text input when in spectator mode.
-Fixed bug with the status bar and the chat text overlapping a little at some resolutions.
-Fixed a bug where a player's screen would not get faded back in if mp_fadetoblack was being used.
-Fixed flashbang description. The text was being cut off in the Buy Menus.
-Fixed crash when running rcon commands from the client.
-Bringing up Friends in-game will work faster now.
-Fixed problem where the incorrect skyboxes were shown in some maps.
-Fixed incorrect prices for some of the weapons in text style buy menus.
-Fixed flashbang price being shown incorrectly as $300.
De nieuwe map die veel besproken is, dat is de_airstrip. Hier de laatste updates daarover:
» Moved T spawn about 5 seconds back (to run from spawn to BS A)
» Fixed some clipping errors
» Added Cessna models (thanks to Minh and John)
» Moved door from site A
paar screenies van deze map:
Afbeeldingslocatie: http://csnation.counter-strike.net/images/content/image_13090.jpg
Afbeeldingslocatie: http://csnation.counter-strike.net/images/content/image_13091.jpg
Afbeeldingslocatie: http://csnation.counter-strike.net/images/content/image_13095.jpg
Verder zijn er natuurlijk een aantal aanpassingen/veranderingen die er in 1.6 zullen plaatsvinden. Allereerst nieuwe wapens:
Afbeeldingslocatie: http://www.computergames.ro/assassin/images/valve/valve003.jpg
Zo zal dit er in-game uit komen te zien:
Afbeeldingslocatie: http://www.counter-strike.nl/x/cs16/shields.jpg
Afbeeldingslocatie: http://www.computergames.ro/assassin/images/valve/valve002.jpg
Afbeeldingslocatie: http://www.computergames.ro/assassin/images/valve/valve001.jpg
Afbeeldingslocatie: http://www.counter-strike.nl/x/cs16/de_dust0000.jpg
Er zijn ook een aantal uiterlijke veranderingen zoals de console die aangepast is:
Afbeeldingslocatie: http://www.counter-strike.nl/x/cs16/console.jpg
Het menu in cs is ook sterk veranderd:
Afbeeldingslocatie: http://www.counter-strike.nl/x/cs16/csmenu1-1.jpg
Afbeeldingslocatie: http://www.counter-strike.nl/x/cs16/csmenu2-1.jpg
Verder zijn er wat bekende maps ge_update, waaronde de_aztec
Afbeeldingslocatie: http://www.counter-strike.nl/i/p/257.jpg
Afbeeldingslocatie: http://www.counter-strike.nl/i/p/258.jpg
Hier een lijst met de updates:
-Crickets significantly quieter
-Laggy Lightning flash removed
-New textures
-Reworked brushwork for better FPS and quality
-Fixed 2 ``crate'' gaps which were being exploited
-New style spawns with entry points
-Revamped bridge area
-More detail items
-Reworked lighting in some areas.
-Fixed brush error near CT side bridge room
-Extra clipping to stop player traps
-Labels for bomb sites
de_inferno heeft ook een aantal goede/minder goede aanpassingen ondergaan
Afbeeldingslocatie: http://www.theforumisdown.com/uploadfiles/1102/de_inferno0006.JPG
Dit vind ik wel zo'n slechte verandering, dit was altijd wel een lekkere rush route, nu kan je er dus alleen met hulp van iemand anders opkomen..
Afbeeldingslocatie: http://www.theforumisdown.com/uploadfiles/1102/de_inferno0004.JPG
Afbeeldingslocatie: http://www.theforumisdown.com/uploadfiles/1102/de_inferno0002.JPG
Zover over 1.6, nu volgen wat algemene dingen over CS
Hoe mijn crosshair aan te passen?
dynamic_crosshair 0 in je config.cfg zetten zorgt ervoor dat je crosshair hetzelfde blijft als je bijvoorbeeld bukt, wanneer men dit op 1 zet dan wordt ie bijvoorbeeld kleiner als je bukt.
adjust_crosshair gebruik je wanneer je de kleur van je crosshair wilt veranderen, compleet legaal, dus geen cheat.
Het is dus in principe niet mogelijk om je standaard crosshair een andere vorm te geven, doe je dit wel dan zal dit als een cheat worden gezien. Je ingezoomde crosshaid daarentegen kan je gewoon aanpassen door middel van sprites.
Deze kan je bijvoorbeeld hier: http://www.counterstrikecenter.com/ vinden, voor meer info tjek een oud topic van mij: [rml][ CS]ingezoomde crosshair andere kleur geven[/rml]
Kan ik CS gewoon downloaden of moet ik die kopen?
Tegenwoordig kan je heel goedkoop een half-life generation pakket kopen, daar zit sowieso in een half-life en een counterstrike retail. Je kan dan kiezen, of je installeerd HL en daarover de CS MOD of je installeerd de CS retail (stand alone) versie. Uiteraard niet vergeten om ze te updaten.
Deze updates zijn hier te vinden.
hoe of waarmee zoek/vind/connect ik (met) servers?
Hier zijn een aantal programma's voor te vinden, de 3 meest gebruikte zijn:
Gamespy
The all seeying eye
HLSW
hoe kan ik skins van mijn CS aanpassen?
Ook hiervoor zijn sprites te vinden, onder andere hier:
http://www.gaminglinks.info/counterstrike/cs_skins.html
http://www.counterstrike-rules.com/pages/6/
http://www.counter-strike.de
http://www.cs-skinplanet.de.vu
Hoe kan ik mijn cd-key veranderen?
Gebruik hiervoor regcleaner
Het kan uiteraard ook handmatig: run>regedit search valve>halflife>key
en nu kan je gelijk je cd-key aanpassen.
Is CS 1.6 nou CS:CZ?
Nee dat is dus niet zo, 1.6 is gewoon een update van CS..
CS-NATION
This is not Counter-Strike 2. It's not a sequel, more of a retail extension.
Als CS:CZ uitkomt, zijn er dan al servers beschikbaar?
Waarschijnlijk niet, maar je kan CZ gewoon op de CS 1.6 servers spelen en andersom, waarschijnlijk als de eerste update van CZ komt dan zal dit niet meer kunnen.
Als er nog meer vragen zijn dan verwijs ik jullie naar:
http://arethusa.tweakers.net/~acm/omega/omega
Spielerij - Problemen & Vragen
Kan je misschien wat populaire CS links plaatsen
Uiteraard kan ik dat:
http://www.counter-strike.net
http://www.sogamed.com
http://www.counter-strike.org
Moet ik mijn cs nou op D3D of openGL draaien?
Als je videokaart het in principe ondersteund moet je hem eigenlijk altijd op openGL draaien, ten eerste geeft dit mooier beeld en ten tweede loopt het spel beter.
Hoe kan ik mijn fps zien in counterstrike?
Ga naar je console en typ: net_graph 3 daar staat alle info die je nodig hebt!
Kan ik CS nou ook zonder internet spelen?
Ja dat kan, eventueel tegen bots, dit is (vind ik dan) 1 van de beste bots:
http://www.counter-strike.nl/ShowBot.php
Zijn er ergens filmpjes of demo's die ik kan kijken, om te zien hoe "goede" spelers spelen?
Ja die zijn er, uiteraard kun je voor demo's terecht op: http://www.clanbase.com en dan gewoon bij wars van de top clans..
Verder moet je op google eens zoeken naar: superplayers en *aAa* summer frag collection (ook te vinden op http://www.team-aaa.com).
demo's die kun je het best afspelen met het programma GeekPlay. Als je dit programma gebruikt wijst de rest zich vanzelf!
Ik heb net CS gekocht, maar ik snap er helemaal niets van, ik heb geen idee hoe ik moet beginnen
Dan lijkt het me verstandig om eerst even deze manual door te lezen:
http://www.counter-strike.net/manual.html
Ik erger me zo aan cheaters, lamers e.d. is er iets dat ik er aan kan doen?
Dat kan in zekere mate, als jij vast op een public "community" speelt, dan moet je je even aanmelden op het forum. Zo gauw als jij denkt een cheater te zien, dan maak je daar een demo van (console> record demonaam) dan als je denkt genoeg opgenomen te hebben stop je met opnemen (console > stop).. dan typ je in console> status hier maak je een screenshot van. Deze demo moet je even inpakken en samen met het screenshotje posten op het forum van de desbetreffende server.
Een 2e optie is natuurlijk om een irc client te nemen. Deze kun je halen op: www.mirc.com (daar staan ook verscheidene FAQ's). Met irc connect je met: irc.quakenet.org (dit is de irc server waar eigenlijk alle servers, clans etc etc op zitten) Eenmaal geconnect, join je de server waar je zoal speelt. Op de homepage van de server vind je wel het adres hiervan. Als je een cheater/lamer in een server ziet, ga je naar irc en vraag je een admin om op die server te komen vanwege een cheater/lamer ..
Als iedereen dit zou doen, dan zouden er heel wat cheaters/lamers aangepakt kunnen worden.
Mag jij dit topic wel plaatsen, want ik ruik een slotje!
Ja dat mag ik, na overleg met IceStorm.
Dit topic is niet bedoeld om te flamen op CS, vind je het alsnog een ruk spel, dan mag dat maar geef er wel argumenten bij waarom je dat vind.
Vind je dat er nog iets mist in deze opening, zeg het dan even dan pas ik hem even aan.
disclaimer: dit is mijn eerste "grote topic" dus ik heb mijn best gedaan op de opening, hopelijk is het wat ;)
[ Voor 22% gewijzigd door White Dust op 28-08-2003 21:44 ]
superB
  • bAdmuTs
  • Laatst online: 07:26
bAdmuTs
mAzE
Zeer nette opening :D
In nomine Patris, et Filii, et Spiritus Sancti
omg die lampen onder de brug in azzie :D ik zie zonder ook al alles maargoed..
maaruh nette begin post hoor knul :)
  • inXs
inXs
known as inXs
Verwijderd schreef op 10 februari 2003 @ 23:40:
Ja die lampen zijn opzich wel mooi, maar zoals je zegt je ziet eigenlijk alles al.. Opzich zijn die texture aanpassingen wel jammer, want voor de mensen met de wat mindere pc's gaat dit fps vreterij worden... Kijk in CZ is het oké dat ze het niet meer kunnen draaien, maar met CS is dat een beetje jammer..
Ennehh thnx voor de complimenten :) heeft me 1.5uur gekost die opening, is dan wel leuk om te horen :*)
ppffrrtt knul, omdat je toevallig 22 dagen ouder bent :P
[ Voor 7% gewijzigd door inXs op 10-02-2003 23:44 ]
superB
Nice post.
1: de nieuwe aztec ziet er nice uit. vooral de textures zien wat beter dan die er nu zijn.
2: Zijn er ook nog updatesm.b.t. tot de engine zelf. Ik zie wel een aantal fixes maar het grootste probleem (fps) hoor ik toch vrij weinig over.
bl!kje schreef op 10 February 2003 @ 23:43:
huh texture aanpassing? das niet best, ik heb een athlon 600 met geforce 1 draait ie dan goed?
Verwijderd schreef op 10 February 2003 @ 23:47:
zal ws wel lastig worden om een beetje steady fps te krijgen aangezien CS nogal veel cpu power trekt. :(
  • OneUp
  • Laatst online: 30-04 19:28
bl!kje schreef op 10 February 2003 @ 23:31:
Nee dat is dus niet zo, 1.6 is gewoon een update van CS.. CZ (condition zero), is in feite counterstrike 2
Ik zou dit veranderen voordat weer iedereen verkeerd gaat denken:
Nee dat is dus niet zo, 1.6 is gewoon een update van CS. Condition Zero (CZ) is een lostaande single player versie van CS.
Maar verder een goeie opening :)
People are just like trees. They fall down when you hit them mutiple times with an axe.
  • inXs
inXs
known as inXs
Nee de engine blijft uiteraard in cs 1.6 hetzelfde, en die fps problemen tja.. zoals ik al zei, de maps hebben betere textures gekregen, waardoor de fps omlaag zal gaan..
CS:CZ heeft wel een nieuwe engine btw, een als het goed is ook een hax vrijere engine.
superB
heheh ja ik keek naar je profiel en zag dat ik klein maandje ouder was, vandaar 'knul' ;)
maaruh je hoeft geen U te zeggen hoor..
  • inXs
inXs
known as inXs
-Cargo- schreef op 10 February 2003 @ 23:48:
Maar CZ is geen losstaande single player van CS.. CS:CZ is de opvolger van CS, met als bijkomstigheid een single player modus ;)
superB
ik heb het niet over een nieuwe engine, ik heb het over updates.
ik bedoel vroeger liep cs op een p166 met een voodoo1 en had je nog 80 fps :D
  • inXs
inXs
known as inXs
Mja ik denk dat die GF1 het zwaar zal krijgen, een GF2 MX kost tegenwoordig niets meer (40euro?) Dan zal ie het al een stuk beter trekken!
superB
  • unfor
  • Laatst online: 30-08 13:06
bl!kje schreef op 10 February 2003 @ 23:48:
PC's worden natuurlijk ook sneller :) en CZ gaat gewoon de Half-Life engine gebruiken.
bl!kje schreef op 10 februari 2003 @ 23:50:
GF1 naar een GF2mx zul je haast nix van merken, al helemaal niet in cs (ligt erook aan wat voor GF1 het is of course).
Dan zou ik eerder voor een cpu upgrade gaan :)
  • OneUp
CS-NATION:
  • inXs
inXs
known as inXs
Verwijderd schreef op 10 February 2003 @ 23:50:
Ja okz sorry verkeerd gelezen :) Maar inderdaad het wordt steeds zwaarder, komt natuurlijk ook, omdat er steeds meer mensen cs spelen, de textures beter worden, er meer functies inzitten etc etc etc Maar het zou een slechte zaak zijn (denk ik dan) wanneer het nu nog op een p166 zeer goed zou draaien ..
superB
  • unfor
Verwijderd schreef op 10 februari 2003 @ 23:52:
word toch niet zo'n topic van wat moet ik kopen als ik 100 fps wil krijgen?
Want je hebt gewoon een sneu excuse voor een pc als je geen 100fps in CS hebt >:)
  • inXs
inXs
known as inXs
-Cargo- schreef op 10 February 2003 @ 23:52:
CS-NATION
Okz soz ik ben eigenwijs, ik heb de opening aangepast :)
superB
bl!kje schreef op 10 februari 2003 @ 23:52:
True, maar als je naar de graphics kijkt en dan naar je fps in verhouding tot andere spellen zoals Q3 en UT die er toch net wat gelikter uitzien dan is de CS engine toch ook niet briljant :)
  • inXs
inXs
known as inXs
unfor schreef op 10 February 2003 @ 23:54:
Nee vast niet, maar het is wel 1 van de dingen waar schijnbaar bijna iedere CS speler tegenaan loopt.
superB
  • inXs
inXs
known as inXs
Verwijderd schreef op 10 February 2003 @ 23:54:
Nee klopt de engine is denk ik verre van briljant, denk maar aan al die hax die er mogelijk zijn op dit moment ( de UT engine is toch ook nieuwer? ). Maar die engine is in feite zo, omdat de makers wouden dat CS optimaal te "customizen" was zodat je het spel helemaal naar jou eigen voorkeur kon instellen.. En tja dat was een fout, dat blijkt nu.
superB
wat ik me ook afvraag, zijn er nog updates m.b.t ex_* commando's? Deze zouden gelocked worden op een bepaalde waarde zodat het "cfg hacking" ten einde zou komen.
  • unfor
Verwijderd schreef op 11 February 2003 @ 00:03:
die worden gelocked ja.
  • inXs
inXs
known as inXs
unfor schreef op 11 February 2003 @ 00:05:
Wat ook wel eens tijd zou worden denk ik, want die commando's konden je een behoorlijk voordeel geven..
superB
  • Brik
  • Laatst online: 25-09 08:52
Goeie openingspost.
Maar je gaat toch niet je key verander aan de hand van een regcleaner :?
Je gaat gewoon naar run>regedit search valve>halflife>key en daar staat ie en kan je um ook gelijk veranderen, veel makkelijker ;)
  • inXs
inXs
known as inXs
Brik schreef op 11 februari 2003 @ 00:16:
Goeie openingspost.
Ja maar sommige mensen schijnen nogal heel veel moeite te hebben met het register... Hier haal hem gewoon weg met regcleaner, doet cs aan en je vult hem in :) maar ik zet hem bij de opening erbij!
superB
  • fw
  • Laatst online: 25-06 13:07
fw
Ik weet niet he, maar heeft nog niet iemand het opgemerkt dat die boom een beetje 'fout' staat op http://csnation.counter-s...s/content/image_13090.jpg en http://csnation.counter-s...s/content/image_13091.jpg ? Zo kan dat vliegtuig ook niet echt weg lijkt me.
Zo ja, sorry, het viel me op en ik wist niet of het al opgemerkt was?
T.net dbmerge: Nieuw account: fw (22068) || http://wow.allakhazam.com/profile.html?81039 WTB CTS/Mala :C
  • inXs
inXs
known as inXs
aargghh is die csnation nou zooooo traag? dit is echt te erg voor woorden.. Ik zit hier op een 10mbit lijn geloof ik (speedtest, telkes 1.2 mb/s ofzow) en het duurde echt heel lang voordat dat plaatje geladen was.. minuut ofzow... En het was me niet opgevallen (mierenneuker :P ) maar je hebt wel gelijk, best lastig voor dat vliegtuig om er zo uit te komen :D en al was die boom er niet, dan had ie een veel te korte startbaan? lolz opzich best redelijke foutjes vind ik zelf..
superB
  • inXs
inXs
known as inXs
btw nog iets, is die csnation pagina nou echt zooooo traag? ik denk ff op die pagina zelf kijken, maar dat duurt echt lang voordat die geladen is...
superB
  • inXs
inXs
known as inXs
Mmzz sorry voor deze alweer 3e reply op rij, maar even een verzoek.. Als mensen een andere skin pack hebben geïnstalleerd of andere models hebben, kunnen ze dan even wat screenies plaatsen en een link plaatsen van waar te krijgen?
superB
  • sarlo
  • Laatst online: 29-09 09:39
Even iets dat met hardeware te maken heeft :P
Als ik cs op me neiuwe tft speel is het in de_dust in de hallway en tunnel erg donker.
Ondanks dat me brighness etc op max staat!!!
Met deze instellingen is alles in windows te fel dus misschien weet imand hier iets op :?
bl!kje schreef op 11 February 2003 @ 08:37:
Ik haal me skins meestal hier:
Games-fusion
CS-nation
[ Voor 49% gewijzigd door sarlo op 11-02-2003 10:41 ]
Bl!kje: nette openingspost! Maar ik heb werkelijk ernstige bezwaren tegen jouw postgedrag. Volgens mij ben je een beetje postgeil! (no flame intended)
Regelmatig post je binnen korte tijd twee of meerdere keren achter elkaar zonder dat er een post van een ander tussen staat. Ik heb bewust geen quotes erbij gezet, maar als je niet overtuigd bent, wil ik die best opzoeken (neem dan ff contact op via ICQ). Dit is me niet alleen in dit topic opgevallen, maar in meerdere topics. Ik weet niet of dit de juiste plaats is om je erop te wijzen, eigenlijk vind ik dat ik dat ook niet hoef te doen, maar ik vraag je dringend om je post gedrag aan te passen, want ik stoor me eraan. Reageer hier alsjeblieft ook niet op, want ik wil niet verzanden in een offtopic discussie of je het wel of niet doet, maar gewoon lekker ontopic blijven.
  • Hahn
  • Laatst online: 29-09 21:08
CS 1.6 lijkt me wel leuk door die nieuwe wapens en nieuwe maps enzo, maar wat me tegenvalt zijn de remakes van bijvoorbeeld de_aztec. Ik vind die nieuwe aztec erg kaal eruit zien. Overal dezelfde steentexture enzo. Alleen die brug waar je beter door heen kan kijken vind ik wel een verbetering. Hopelijk valt de_aztec in game wel mee, want het is zo'n coole map.
The devil is in the details.
  • inXs
inXs
known as inXs
MaRc0 schreef op 11 February 2003 @ 13:51:
de_inferno is ook aangepast kwam ik net achter eigenlijk, ziet er opzich wel gelikt uit.. Jammer dat er 1 aanpassing is (er is een kistje weg, diegene bij de bomspot waar je die gang in kan).. Dus je kan alleen nog maar met hulp die gang in komen.. Dat is wel erg jammer eigenlijk...
Ik denk dat de_aztec in game best mee valt (als ik de verhalen zo hoor).. Ik heb zelf geen zin om steam te gaan doen eigenlijk, ik wacht wel totdat ie uit is. Maar ik vind de textures niet meer 1tonig dan nu eigenlijk.. Dus ik vind het opzich wel weer eens leuk dat ie iets anders is :)
superB
  • Peertje
Ff over die lampen in aztec.. Die zijn niet bedoelt zodat je dingen beter kunt zien :+ Die gene die het dichts bij de bombspot zit is vooral tactisch te gebruiken. Klim je daar op als T en spring je richting a dan heb je niet meer het nadeel dat de ct je eerder ziet en zou je gelijke kansen krijgen.
  • RoadKill21
RoadKill21
Mn naam is niet Haas, maar Han
Vergeet ook niet de aanpassingen die gedaan zijn/worden aan de_piranesi.
Url: http://csnation.counter-strike.net/comments.php?id=5652
Gemaakt door: Fingers - iikkak@valvesoftware.com
Ook zouden er wel wat screens van de nieuwe de_inferno en info erover bij mogen.
Kijk daarvoor maar in het CS 1.6 topic op GoT.^
Cherish your memories, but don't live in the past. Always outdated specs
fw schreef op 11 februari 2003 @ 08:12:
Meheh.
  • Freek
  • Laatst online: 22-06 16:30
Dat was jou onze Ubermapper natuurlijk nooit over komen in een van zijn maps :P
  • IceStorm
  • Laatst online: 29-09 21:23
IceStorm
This place is GoT-like!!!
Woei, daar irriteer ik me op LAN altijd enorm aan (ik speel CS alleen op LAN, en met koptelefoon op is dat geluid klote :P).
Nette post idd.
  • L0g0ff
  • Laatst online: 08:12
L0g0ff
omg
Dit vind ik wel een hele kromme manier om je key aan te passen (we zitten hier op tweakers.net hoor :P)
Blog.wapnet.nl KompassOS.nl
  • Hahn
Dat denk ik dus wel. Denk je nou echt dat je als je CZ update niet meer op CS 1.6 servers zal kunnen spelen? Daar is de CS 1.6 community veel te groot voor en de CZ community veel te klein voor. Zo zou je mensen nog steeds dwingen om CS 1.6 te downloaden als ze alleen maar CZ hebben. Ik verwacht dat je CZ gewoon tegen CS 1.6 zal kunnen blijven spelen, anders zou de hele CZ community opnieuw opgebouwd moeten worden.
  • inXs
inXs
known as inXs
MaRc0 schreef op 11 februari 2003 @ 17:58:
Maar is dat ook niet wat iedereen wil? Iedereen loopt altijd op de engine te zeuren, te buggy, te lelijk, te cheat achtig etc etc.. Dus als het na de eerste update van CZ meteen over is met CS, dan lijkt mij het juist dat de cheaters in 1 keer zullen afnemen.. Maar als je 1.6 nog steeds zou kunnen blijven spelen, dan heb je dus iig 2 verschillende modus (dan zou er dus ook cs 1.7 moeten komen)..
superB
  • ilyc
  • Laatst online: 13-11-2025
Even jeugdsentiment:
Ik weet nog dat ik CS zo'n 3 jaar geleden speelde op m'n Pentium 400, in software mode, met een ping van 250...en nu, pakweg 2 a 3 jaar later zijn de PCs 6 maal zo snel geworden, is CS alweer uit de beta fase en is het nog steeds ongekend populair!
Misschien moet ik het maar weer eens downloaden... :)
bl!kje schreef op 11 February 2003 @ 14:19:
Gebruik de edit knop eens
[ Voor 3% gewijzigd door Verwijderd op 12-02-2003 08:03 ]
IceStorm schreef op 11 februari 2003 @ 17:42:
Nette post idd.
oplossing: ` stopsound ` ;) . Maar dat wist je natuurlijk al.
Hmmzzz even over die airstrip map : je ziet dat vliegtuig in die hangar staan, nou ben ik iemand die weer iets verder denkt, dus ik denk : Hoe kan het vliegtuig weg als er een boom voor de uitgang van de hangar staat ??? :P
K zou het toch leuk vinden als die map builders ook eens wat meer aan dat soort details dachten :)
Verder wel een kewl topic btw, nooit aan gedacht :P
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 februari 2003 @ 08:02:
Bedoel je dat ik de opening even aan moest passen? Naja dat heb ik dus gedaan op dit moment :) Wat mij trouwens de laatste tijd heel erg opvalt is dat er eigenlijk bijna op elke cs server (op drukke tijden) een soort server choke heerst... Ik heb dus zelf geen lag, choke of loss, maar als ik speel ervaar ik wel een soort lag gevoel (gewoon 100fps).. En als ik dan schiet dan heb ik het gevoel alsof niet alle kogels aankomen en ook niet geheel op de plek waar ik schiet... Ligt dit nou wel aan mij, of komt dit dan meer voor?
Verder ik was laatst een beetje dingen aan het zoeken over cs enzo en ik kwam wat dingen tegen dat je je eigen map textures aan kan passen? Zo kwam ik bijvoorbeeld screenies tegen van bijvoorbeeld de_dust2 waar de textures en vormen geheel aangepast waren.. Hij kon er wel gewoon online mee spelen? Maar ik vind het zo vreemd dat de server dan niet gaan zeuren dat de map anders is dan die op de server staat :)
superB
  • Hahn
Verwijderd schreef op 12 februari 2003 @ 08:16:
Die optie werkt maar één keer per ronde, dus dan moet je dat elke ronde weer doen. Je kan het natuurlijk aan een knop binden, maar als het geluid gewoon wat zachter is is dat natuurlijk wel makkelijker :)
Hmmm wat mij opvalt is dat het niveau van de spelers in Nederland dus op de bekende servers xs4ll en de clan servers van Mortemobire, team illusion enz. enz. verschrikkelijk laag is......
Ik kan nergens een uitdaging meer vinden op Nederlandse servers, alleen misschien na 11en dat het dan een beetje optrekt maar de kern blijft dat er gewoon geen uitdaging meer te vinden is in NL.
Ook cbnl niveau is enorm laag, geen goede clan meer te vinden die in b.v. de open cup oid ook presteerd.
Erg jammer want vroeger had NL toch wel goede spelers, tegenwoordig bedroevend weinig....
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 09:53:
Die spelers zijn er wel hoor, maar die denken er hetzelfde over zoals jou dus die spelen eigenlijk alleen maar op privé clan servers en kom je ze dus nooit tegen.. Anders moet het eens via gametiger doen, je tikt een clantag in van een skilled clan en kijkt of er mensen van die clan online zijn.. Dan join je gewoon, doe ik ook wel eens.. Ik weet btw ook niet in welke clan je zit, maar anders moet je misschien meer wars gaan spelen tegen skilled clans... Misschien wil je anders een keer 2on2 tegen mij en een maat van me.. (btw wat is jou cs nick? )
superB
Ook van de private clan servers heb ik pw's en ip's maar ook daar vind ik het niveau erg laag en de spelers ook niet echt indrukwekkend.
Game tiger of Game Spy zijn ook programma's die ik niet gebruik gezien het feit dat ook die vaak geen uitkomst bieden.
Een clan heb ik niet meer omdat ik niet tevreden ben over de clans van tegenwoordig.
Ik zat in o8s en in sod. dat was nog leuk toen ging het nog maar dat vind ik ook nix meer en o8s niveau is ook bedroevend laag..... sod. bestaat nie meer ook erg jammer en de spelers zijn verspreid over verschillende clans of doen nix meer.
Beetje jammer.....
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 10:05:
Beetje jammer.....
Aangezien ik alsnog je cs nick niet weet nu ;) Maarehh je kent vast wel iemand die even goed is als jou, als je nou iets tegen re-flex regelt offehh team-illusion (of wou je zeggen dat die ook te laag zijn 8)7 En ja o8s is ook achteruit gegaan, daar hebben ik en die maat laatst nog 2on2 tegen gewonnen.. Maar je hebt inderdaad gelijk over het niveau, soms dan denk ik echt hoe kan ik dit allemaal in hemelsnaam overleven? Ik had een awm, stonden 4 CT's om me (ik was T) en ze deden er echt 30 seconden over om me dood te krijgen (jammer dat een deagle niet zoveel kogels heeft :P )
superB
team-illusion stelt weinig voor heb ik ook al eens wartje tegen gedaan, goeie tacts is de key...
re-flex jah ach...... toffe gasten leuke game play maar individueel op pubs oid ook nie echt indrukwekkend...
Mijn nick is Inv en spelen op NL servers doe ik nie meer k weet nie waar jij speelt maar waarschijnlijk niet waar ik zit :P
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 10:11:
Ik kan niet zeggen dat ik b0bb of madB nou zo slecht vind :P maarehh inv? invader? je nick komt me btw wel bekend voor.. Hoe lang doe je al cs dan? Anders moet je ff PODbot gebruiken en dan 1vs10 tegen de moeilijkste :P Das best een uitdaging :D Naja ik speel het meest op gamecity , maar ook vaak op onze clanserver (zie signature) gewoon tegen gasten van mij clan.. Mijn "maat" btw van 2on2 is niet iemand uit deze clan, maar is een vriend van me waarmee ik heeeel lang geleden cs begonnen ben. Ow en nog ff team-illusion.. Huxa is toch ook niet zo slecht? Naja af en toe speelt ie best goed vind ik..
Het jammere vind ik altijd van top clans, dat er 4 of 3 echt goede gasten inzitten (die dan ook echt elke war meespelen) en de rest is gewoon slecht, hierdoor komen die clans redelijk hoog terwijl het niveau van die clan in principe heel laag is.. Ow maar deze clans kan je vast niet tegenop: *aAa* (against all authority) SK (schroet kommando :P ) Mousesports, eSu ... En nu kan je me echt niet vertellen dat ze mwa redelijk zijn 8)7 (maar dit zijn dan ook geen NL clans :D ) en kom eens een keer langs op ons irc kanaal ofzo ( ik ben nu uiteraard niet thuis, maar ik idle wel altijd op irc.. nu ook als het goed is )
superB
Ik speel cs al vanaf de allereesrte versie en ben nooit ertussenuit geweest dus ik kan me weg aardig vinden :P
Verder zijn uiterraard madB en en b0bb nie verkeerd maar dan noem je ook 2 van de weinige goede spelers die er wel zijn in NL.......
Er moeten er gewoon meer komen, en dat bereik je alleen als je internationaal speelt en niet op de low skill NL servers blijft hangen.
Mijn 2 on 2 buddy was trouwens Heaton ex-sk :)
Dus de jongens van sk ken ik ook en die zijn wel tof enzo maar ik praat liever NL :P
Er moet gewoon een roelende NL clan komen die ook Internationaal presteerd :)
[ Voor 8% gewijzigd door Verwijderd op 12-02-2003 12:12 ]
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 12:10:
Mja dan is het idd jammer dat innonimis dood is.. Die deed het op internationaal gebied wel goed dacht ik.. Mja en heaton was dus jou 2on2 buddy :P toe maar ;) Nee zover heb ik het nog niet geschopt, ik speel cs sinds beta 5.1 dus gelukkig kan ik mijn weg wel redelijk vinden.. Maar ik vind dat er in het buitenland eigenlijk ook niet echte servers zijn waar skilled mensen spelen... Dus je kan wel zeggen dat de NL servers non-skilled zijn, maar dat is in het buitenland toch ook zo bij publics? Naja waarschijnlijk zit ik hier dus fout, dus zou je anders wat servers of links naar pagina's kunnen plaatsen (buitenlandse servers dus) waar wel skilled players zijn? Lijkt mij ook wel wat eigenlijk :D
superB
Ik ben nu op me werk en heb hier geen irc oid dus servers enzo heb ik even niet bij de hand, maar kijk na 9en eens in de channels van b.v. sk, son-y enzo da zijn clans die echt kont schoppen :)
Vaak worden daar gathers doorgegeven en als je er optijd bij bent kan je mee doen, erg leuk en dan weet je ook dat je wel goed moet zijn lamers, campers e.d. worden gewoon door de admin gekicked dus echt gewoon de goeie of toekomstig goeien mogen blijven :)
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 13:45:
ja ik speel wel vaak gathers (maar dan NL gathers) en die gathers die ik speel daar spelen vaak pu gasten offehh re-flex gasten in mee.. En dat komt al aardig op mijn niveau :P naja die pu gasten zijn denk ik van een gelijk niveau en die re-flex gasten zijn wel beter dan mij ... Maar daar worden ook alle lamers, campers etc etc gebanned, dus bevalt me ook prima.. Maar ik zal jou advies eens opvolgen!
superB
Ik zal als ik thuis ben (vandaag niet meer k moet tot morgen ochtend 5 uur overwerken :P )
even een paar irc chans geven waar ook skilled lui zijn en die ook leuke gathers enzo houden.
Meestal hebbe de private servers waar ik speel pw's die je alleen door de cl's of war-arrangers worden vrijgegeven dus die zul je daar dan ook moeten vragen.
[ Voor 4% gewijzigd door Verwijderd op 12-02-2003 13:59 ]
  • sdomburg
  • Laatst online: 03-09-2024
heel mooie openingspost, misschien alleen ff vermelding hoe je demo's enzo alspeelt. (GeekPlay is wel handig om te vermelden :) )
  • Hahn
Wat mij ook opvalt is het niveau op bekende servers zoals XS4ALL wat al eerder genoemd was. Een paar maanden nadat ik begonnen was met CS was ik aardig goed (niet om op te scheppen, maar ik stond merendeel als eerste of tweede), na echt maandenlang achter elkaar elke dag te spelen ben ik erg achteruit gegaan en was ik gewoon slecht geworden. Ik ben toen zo'n 2 maanden gestopt en sinds een maandje speel ik weer. Ik weet nu niet of ik weer op m'n oude niveau zit of dat de CSers tegenwoordig gewoon slechter zijn, maar ik heb amper nog competitie. Op elke server zijn er hooguit 2 mensen die in de buurt van mij komen.
Ik zou wel eens een server weten waar het niveau aardig hoog is, zodat ik weet hoe goed ik nou ben.
Voor de geïnteresseerden, ik heet EvilKnight in CS :) (Evil is mijn clan)
Ik ben heel heeeeeel heeeeeeeeeeeeeeeeeeel af-en-toe wel eens op xs4all te vinden maar das alleen als ik mensen wil zien spelen die dezelfde taal als ik spreken :P
Verder vooral niet je niveau daar proberen te meten 90% van de mensen daar is "skill loos"
Als je een maand speeld is het al snel genoeg om daar boven aan te komen.
Maar noem die enkeling eens die daar dan boven je staat die dan "bter" als jou zijn want misschien kan ik dat wel eens zijn onder fake nick :P
  • Hahn
Ik heb echt geen idee, ik onthoud niet zo snel namen, alleen als ze veel indruk op me maken :+
Weet jij misschien servers waar het niveau wat hoger ligt?
Lees mijn bovenstaande posts ff door en kijk morgen rond de middag ff voor meer irc chans waar je ip's kunt vinden.
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 February 2003 @ 13:57:
Dat zou mooi zijn inderdaad, dan kan ik die ook evt in de opening vermelden.. Geekplay is ook in de opening gezet, thnx for that.. Tja ik denk dat het niveau van de servers de laatste maanden omlaag is gegaan, omdat de goede spelers niet meer public spelen. Je zult denk ik gewoon clans moeten uitdagen (goede clans dan wel) om echt beter te gaan worden.. Daar is mijn clan dus ook druk mee bezig dus (#xtC.nl // inXs ben ik, mijn clan is dus xtC ) Naja ik vind het pu niveau hoog genoeg voor ons eigenlijk, offehh xP (xtremepower) is ook een clan met een soortgelijk niveau van onze clan....
maarehh marc0 wat ook goed is voor je aim, is tegen een goede gast 1on1 een aim map gaan spelen.. Is zeer goed voor je reactie, zeer goed voor je speelstijl (weten wanneer je tevoorschijn moet komen en waar) en ook zeer goed voor je aim... Je moet wel goed aimen dan anders ben je dood.. Als ik tegen noobs speel word ik lui.. Dan rush ik me elke keer te pletter etc etc... Wat ook een goede leermethode is gewoon puur op hedsjots spelen...
In het begin is het zeer frustrerend, vooral als je een speler zo makkelijk dood had kunnen krijgen zonder hedsjot.. Maar dat gaat na een maandje zijn vruchten afwerpen.. Wanneer je dit een beetje onder de knie krijgt, wordt het noodzaak om de situaties in te gaan schatten, of je dus wel of geen hs wilt/gaat maken.... Klinkt allemaal onzin misschien (of lastig of wat dan ook) maar zo heb ik het mezelf ook geleerd toendertijd..
Nog iets, als je maps speelt probeer dan punten (plekken) te vinden waar je de tegenstander iets eerder kan zien of waar je goed kan pré-mikken.. Dus bij trappen bijvoorbeeld, ga zo boven aan die trap staan dat wanneer er een tegenstander onder aan de trap staat dat je dan alleen zijn hoofd ziet.. Naja je mikt vantevoren al in feite net iets boven de bovenkant van de trap, dus als je timing goed is (of goed wordt) dan issie kinda dood... Andersom precies hetzelfde, vooral op grote afstanden.. Zorg dat er een zo'n klein mogelijk oppervlak van jezelf zichbaar is.. Dit is vooral handig als je aim niet zo goed is, dan blijf je (hopelijk) zo lang mogelijk in leven..
Ik hou er zelf van om me gewoon lekker de dood in te jagen op publics, ten eerste vind ik dit goed omdat je dan goed leert omgaan met "stress" (dus als er veel vijanden zijn, hoe reageer je dan) en je leert snel aimen en hedsjots maken (je moet wel anders ben je dood) ....
MaRc0 schreef op 12 februari 2003 @ 14:17:
Als je dan een public zoekt waar het niveau hoger zit, dan moet je denk ik bij gamecity wezen (daar zitten vaker dan op XS4all mensen met iets meer skill)
http://www.gamecity.nl voor de servers!
[ Voor 8% gewijzigd door inXs op 12-02-2003 14:24 ]
superB
  • Hahn
Ik hoef niet echt meer te leren aimen, dat kan ik al aardig goed :P
Ik speel nu geloof ik ongeveer één jaar waarvan ik ongeveer 10 maanden actief heb gespeeld. Wat mij opvalt is dat iedereen altijd met zo'n lage muissnelheid spelen. Ik hoor mensen die spelen met een snelheid van 1.5 of soms zelfs 0.5. Ik heb mijn muissnelheid op 19 staan! Dit lijkt véél te snel en het is redelijk snel, maar het is niet zo dat ik met één beweging 8 keer in de rondte draai. Ik kan met één muisbeweging bijna een heel rondje maken, maar dat vind ik wel fijn, zo kan ik veel sneller reageren. In Windows heb ik ook alles bijna op z'n hoogst staan, zelfs de versnelling staat op Medium, hoe het dan komt dat ik dan op 19 speel in CS snap ik niet.
  • inXs
inXs
known as inXs
MaRc0 schreef op 12 February 2003 @ 14:26:
Uhmmmm 19? bedoel je niet 9? Als ik hem op 19 zet dan draai ik met 1 muisbeweging denk ik 4 rondjes.. Ik speel btw op muis sens 2.3.. Op lange afstanden is dit super fijn, als er vijanden voor je zijn ook.. Maar in kleine ruimtes waar je snel moet kunnen draaien ben ik eigenlijk dood... Nou boeit me dit niet zo, want als het goed is komen die situaties niet voor in wars ;)
Maar ik vind snel vrij irritant.. Je kan het ook bij jezelf testen of het wel de goede sens is..Ga op een grote afstand staan van een muur (een muur wat een herkenbaar iets op zit, een lekker ofzo) ga dan al strafend op dat punt mikken.. Daarna kijk je hoeveel kogels er raak zijn en hoeveel er naast zitten.. Als er nou heel veel naast zitten dan is je sens dus te snel, want dan mik je al strafens steeds langs je doel.. Probeer hem dan wat lager te zetten en test het weer... In het begin is een lagere sens heel erg wennen (ik ben van 10 naar 6 naar 4 naar 3 naar 2.3 gegaan, met nog wat tussenstappen uiteraard en speel nu 3 jaar cs) ..
Als ik jou was zou ik echt oefenen met een lagere sens, je zult zien dat dit op den duur je aim zeker ten goede zal komen...
superB
  • Hahn
Nee, ik speel echt op 19. Ik heb ongeveer een half jaar op 20 gespeeld, toen ben ik op 19 gaan spelen wat toch wel iets beter ging, maar ik vind 18 al tergend langzaam :D
Mijn sens staat op 5.0 en heeft ie altijd al gestaan vanaf dat cs er is :)
Kan er uitstekend mee uit de voeten en ga er echt nix aan veranderen ik schiet zowel veraf als dichtbij accurate :)
Dan zie ik geen reden tot veranderen toch ?? :P
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 februari 2003 @ 14:36:
Mja met sens 5 schiet op dichtbij ook accurate (alleen op lange afstanden iets minder) met 2.3 schiet ik op dichtbij ook accurate en op lange afstanden dus ook... Alleen tja als ze van achter komen, dannehhh is het rot.. Of als er 1 links en 1 rechts staat... Maar ik heb ook wel een scriptje dat ik kan wisselen tussen sens 2.3 en sens 4 (beetje omslachtig, maar het werkt wel :P). Als ik dus bij italy door die gangen heen knal zet ik ff mijn sens hoog, als ik op een open stuk kom zet ik mijn sens laag :D Tja klinkt lomp, maar ik ben er alang aan gewend! Het gaat nu volautomatisch btw... (btw dat is dus geen hax script maar gewoon dat sens 2.3 en 4 op 1 knop staan, dus dan kost het me niet 2 knoppen)
superB
  • fw
fw
Verwijderd schreef op 12 February 2003 @ 08:25:
Had ik al opgemerkt ;)
  • bAdmuTs
bAdmuTs
mAzE
Het probleem is denk ik dat de "goede" spelers gewoon lekker rustig willen csen zonder gezeik aan hun kop van dat ze cheaten en al die zielige puberige lamertjes. Ik zelf speel practisch altijd op gamepoint en af en toe komen daar wel is "goede" spelers langs zoals carnage of een sterf dude, merk ik wel meteen hoe slecht ik eigenlijk ben :).
Ik speel met sens 2.3, heb ook eerst met 5/6 ofzo gespeeld maar heb gemerkt dat lagere sens beter mikt (zuiverder), maakt niet uit wat mensen zeggen maar het is zo, zelfs in kleine ruimtes ben ik vaak snel genoeg om ze te killen en vooral op grootte afstanden is lage sens tha best
upperscore ken jij silly btw (zat gloof ik ook in sk)
[ Voor 41% gewijzigd door bAdmuTs op 12-02-2003 15:47 ]
bAdmuTs schreef op 12 February 2003 @ 15:41:
Amen... :)
Ik heb er idd altijd last van dat mensen gaan lopen huilen dat ik loop te cheaten of dat ik lame ben e.d. ik wor er helemaal ziek van :(
Er zijn ook vaak trieste lui die er gelijk hele binds van gaan maken om zo vaak mogelijk te kunnen zegge hoe hard ik wel niet cheat :r
K wor d'r gewoon echt gek van en dat weerhoud me er ook van om op de non skilled servers te komen.
Carnage is trouwens ook wel kewl, oude clan mate van me :)
En silly ken ik nie maar da zou best kunne dat ie sk was maar das dan wel al een tijdje geleden denk ik ??
Jammer ook is dat de meeste "goede" spelers zo verdeeld over alle servers zitte want ook dat helpt nie veel mee er is dan b.v weer is 1 op gp of weet ik het waar en dan weer 1 daar en dan weer 1 daar er zou eens soort centrale server voor moeten komen ofzo.
Met uiterraard een pw om de "n00bs" weg te houden maar wel een mogelijkheid jezelf te bewijzen zodat je er wel op mag komen spelen.
Een soort van trail oid....
[ Voor 109% gewijzigd door Verwijderd op 12-02-2003 15:55 ]
-00pz dubbel post-
  • bAdmuTs
bAdmuTs
mAzE
Verwijderd schreef op 12 februari 2003 @ 15:51:
Dat zou heeeel kewl zijn, kan ik me es meten met die peepz :D
Wat btw ook heel goed is voor je spel is filmpjes en demo's downloaden, heb ik zelf erug veel van geleerd
Ik heb ook nog wat demo's maar nie hier k zal ze wel eens uploaden ergens.
  • inXs
inXs
known as inXs
Verwijderd schreef op 12 februari 2003 @ 15:56:
Dat zou wel geinig zijn, ik heb er ook nog wel een paar btw.. Op strikerz heb je wel een skill systeem.. Daar moet je eerst 1500 ptn halen op 3 openbare servers, dan krijg je toegang tot 4 andere cs servers.. Zo bouw je een vaste groep op en das dan wel leuk.. Alleen jammer dat mijn zusje ook cs doet op mijn pc dus veel punten zal ik niet halen :P en om haar nou te gaan verbieden om ergens te spelen is ook weer zoiets... Ik ben niet zo stats geil namelijk...
superB
Dat had je vroeger ook op zogenaamde "zkillz" servers daar kwamen ook internationale spelers e.d. en daar moest je om op de top servers te komen ook minimaal 7000 punten oid hebben, daar zat ik ook tussen maar dat skill systeem is weg dus nu zijn ook die servers verziekt :(
  • bAdmuTs
bAdmuTs
mAzE
bl!kje schreef op 12 February 2003 @ 15:59:
Ik heb een keer op strikerz gespeeld maar ik vind dat daar echt kut spelen, lijkt wel alsof ze met de instellingen ofzo hebben lopen kutten, lopen gaat erg freaky (of ligt aan mij :))
  • Hahn
Ook op Strikerz heb je dat systeem niet meer. Je hebt er nu gewoon een password op zitten, maar die kan je volgens mij zelfs op de website vinden.
  • inXs
inXs
known as inXs
MaRc0 schreef op 12 February 2003 @ 16:02:
mmzz kan wel ja ik ben een jaar geleden ook gestopt met op strikerz spelen, omdat ik toen een keer gebanned ben, omdat ze dachten dat ik cheatte....
superB
  • Jerry
  • Laatst online: 24-03 16:08
Jerry
Who?
bl!kje schreef op 12 februari 2003 @ 10:21:
Uitdaging? :P Ik speel altijd 1vs14 op het hoogste niveau en dan met rifles only aan (dan is het nog een beetje realistisch ;)).
  • Peertje
Ach public speel ik al nooit meer :) Maar waar wel echt skilled mensen komen (altans het schijnt) zijn de betaalde servers van www.gamers.nu
Het enige wat ik doe is 's middahgs 2on2's / 3on3's spelen en dan 's avonds een aantal maps te spelen met clan. HEEEEEEEL af en toe speel ik nog public maar dan gewoon kutten op onze server (illu / kaizen ) en als er dan vervelende mensen zijn, zijn ze zo weg :+
Maar mischien een nieuw idee... een GoT 2on2 CS compo? :) En dan wel echt met alleen mensen van GoT en niet mensen die ff snel reggen ;) Tis voor andere spellen al wel gedaan maar voor cs niet. Als er zat intresse is kunnen we wel wat regelen :)
  • inXs
inXs
known as inXs
Peertje schreef op 12 February 2003 @ 16:14:
Van mijn kant is er iig wel intresse (wat is jou cs nick btw? ) Lijkt me wel wat zo'n compo, maar is dat niet lastig op te zetten (zelf heb ik daar geen tijd voor namelijk) ..
superB
  • Peertje
bl!kje schreef op 12 februari 2003 @ 16:18:
Tijd zou een probleem kunnen zijn maar het is wel al bijna vakantie ;) Dus das een mooie tijd om het te regelen lijkt mij. En mijn cs nick is gewoon peer als speel ik de laatste tijd wars onder de nick "clan Kaizen *rapester" maar das een lang verhaal :P
  • inXs
inXs
known as inXs
Peertje schreef op 12 February 2003 @ 16:21:
* inXs is dan lekker op wintersport! ow en je heet dus soms peer :P das toevallig aangezien een vriend van me peter heeft en die hebben we een tijd geleden tot peer omgedoopt... :) maar ik ken jou nick niet @ kaizen, net nieuw ofzow? Naja niet dat ik al die namen uberhaubt ken trouwens...
superB
  • Peertje
bl!kje schreef op 12 februari 2003 @ 16:27:
* Peertje is dan lekker op wintersport! ow en je heet dus soms peer :P das toevallig aangezien een vriend van me peter heeft en die hebben we een tijd geleden tot peer omgedoopt... :) maar ik ken jou nick niet @ kaizen, net nieuw ofzow? Naja niet dat ik al die namen uberhaubt ken trouwens...
Nieuw? :+
Zit er toch echt sinds dag 1 in :P Nou met ik zeggen dat ik al helemaal niemand uit de hele cs scene ken dus daarom kent niemand mij.
Maargoed.. ff kijken hoeveel mensen intresse hebben, dan zou ik daar mee aan de slag kunnen :)
  • Hahn
Daar kan je denk ik beter een nieuw topic voor maken (met natuurlijk toestemming van één van de modjes) :)
Dit topic is bedoelt voor de discussies over CS en niet om afspraken te maken voor een competitie ;)
  • Peertje
MaRc0 schreef op 12 February 2003 @ 16:33:
Das wel waar... maar een topic openen is meteen weer zo serieus... weet je wat.. als iemand intresse heeft moet ie maar mailen naar peer@clan-kaizen.com of me op irc aanspreken en als er dan wat meer mensen intresse hebben zal ik wel een topic proberen te openen :)
  • inXs
inXs
known as inXs
Jeps i know, maar het was ook natuurlijk nog maar ff een idee :) En je zit er al sinds dag 1 in duz.. ow, ik kom wel eens in jullie irc kanaal, maar nooit echt goed opgelet eigenlijk.. Zal ik eens gaan doen dan :) Ik heb btw wel eens een paar keer wars meegespeeld met kaizen als "hoertje"
ik zag net in je profiel dat je op dezelfde dag jarig bent als mij ;) alleen ben ik dan precies 3 jaar ouder...
[ Voor 19% gewijzigd door inXs op 12-02-2003 16:37 ]
superB
  • Peertje
bl!kje schreef op 12 February 2003 @ 16:35:
laatste ot post :+
Lijkt me zeer sterk. Mischien met het Junior team wat we een tijd terug hadden maar met het "eerste" hebben we nog nooit met een hoer gespeelt :)
  • inXs
inXs
known as inXs
Peertje schreef op 12 February 2003 @ 16:54:
laatste ot post :+
Was een pcw, niet via cb geregeld.. ik wou trial namelijk... Maar na die pcw vond ik dat het niet echt een leuk team was.. wel goed, maar niet echt leuk....
superB
  • T7D_Sneezy
  • Laatst online: 29-09 15:26
spelen jullie allemaal op nederlandse servers?? of ook op andere?
ik speel namelijk alleen op engelse clan servers, van bevriende clans..
hoe zit dat bij jullie?
  • inXs
inXs
known as inXs
Mwa eigenlijk alleen op NL servers... Niet dat ik niet anders wil ofzow, maar ik heb geen zin om engelse te zoeken.. Als je een paar leuke weet kan je ze dan posten?
superB
hahahahahahahaha upperscore aka invader aka "ik ben een keer gepakt met wallhack en speelde altijd op de newbie zeestrike server"
je hebt wel een grote mond hier :)
first of all: Okay je hebt in o8s (oudhof 8 society) en SoD gezeten (Surrender or Die), maar dan wel in een periode dat die clans nog niet zo heel erg veel voorstelden. Dat vergeet je er wel even bij te vertellen he. Nadat de "debieltjes" uit sod geschopt waren (waaronder jij dus), kwam er een redelijk team bij SoD die ervoor zorgden dat er wat werd gepresteerd internationaal. Zelfde geldt zo'n beetje voor o8s. Jij hebt echt niet in die clans gezeten toen ze ook echt wat waren, qua wars, want gezellig was het altijd wel.
Voordat je gaat klagen over het onwijs lage niveau van de nederlandse cs scene zou ik je toch eerst willen vragen om naar jezelf te kijken, want je bent zelf echt een achterlijke noep die denkt wat te zijn op een forum waar niet echt mensen komen die in een beetje actief zijn.
Ik lach je echt heel hard uit om die comment over heaton, in je dromen dat ie je 2on2 maatje was hahahaha. Team illusion nix noemen is ook zware onzin, zij zijn de beste clan in nederland nu en daarv valt nix op af te dwingen. Ik zou je graag illusion zien verslaan met een clan(als je er 1 hebt tenminste). Het nederlandse cs niveau is nog nooit zo hoog geweest als het nu is, er zijn een aantal stabiele clans met europese ambities waarbij de skill en teamplay hoog ligt (w0lla, query, o8s, reflex).
Ik heb deze thread ook even doorgegeven aan de mensen die ECHT in SoD en o8s zaten, heeft voor heel wat gelach gezorgd iig.
Misschien voel je je een beetje gepasseerd, misschien wel gefrustreerd? Maar je blijft voor ons allemaal de zeestrike newbie hoor, dat imago zal je nooit van je af krijgen.
zou wel leuk zijn als je even een chan post waar je idled op irc, voor vermaak zeg maar.
-vliegtuig (aka AmonC, je kent me nog wel ;) )
[ Voor 4% gewijzigd door Verwijderd op 12-02-2003 21:47 ]
  • Bezulba
  • Laatst online: 29-09 13:31
Bezulba
Formerly known as Eendje
hear hear vliegtuig! :)
blup
  • HenkJan
  • Laatst online: 16-12-2025
AFFIRMATIVE :)
