gebruiken julie hottopic voor linux ook?
Pagina: 1 2 Laatste
  • 221 views sinds 30-01-2008
  • Thijsch
  • Laatst online: 12:14
Hottopic-1.0.tar.gz is ready for distribution
zo :) Zelfde URL, doet hij het nu ?
/me is een beetje prutser maar dat had je vast al door :D
  • MadCow*
  • Laatst online: 05-08-2025
MadCow*
<= icon space for rent
ach ik zet mijn prutser pet meestal op als ik een mail of op een forum iets ga typen
well ik krijg deze error
oh ja dit is FreeBSD-current van vandaag met GCC-3.2.2
kwm@lapbeest:~/bin> gdb hottopic
GNU gdb 5.2.1 (FreeBSD)
Copyright 2002 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "i386-undermydesk-freebsd"...
(gdb) run
Starting program: /home/kwm/bin/hottopic
Program received signal SIGSEGV, Segmentation fault.
0x08050729 in check_topic (data=0x8124aa0, user_data=0x0) at communication.c:97
97        for (i = 0; (topic->id)[i] != '\0'; i++)
(gdb) where
#0  0x08050729 in check_topic (data=0x8124aa0, user_data=0x0) at communication.c:97
#1  0x28934cdf in g_list_foreach () from /usr/local/lib/libglib-2.0.so.200
#2  0x08050a05 in parse_function (type=1) at communication.c:170
#3  0x08050bbe in exec_call (source=0x8088480, condition=G_IO_IN, data=0x0) at communication.c:252
#4  0x28958014 in g_io_unix_dispatch () from /usr/local/lib/libglib-2.0.so.200
#5  0x289370dc in g_main_dispatch () from /usr/local/lib/libglib-2.0.so.200
#6  0x28937eea in g_main_context_dispatch () from /usr/local/lib/libglib-2.0.so.200
#7  0x2893829d in g_main_context_iterate () from /usr/local/lib/libglib-2.0.so.200
#8  0x28938a41 in g_main_loop_run () from /usr/local/lib/libglib-2.0.so.200
#9  0x283b7a97 in gtk_main () from /usr/X11R6/lib/libgtk-x11-2.0.so.200
#10 0x0804e4d5 in main (argc=1, argv=0xbfbffb60) at got_topics.c:58
#11 0x0804c115 in _start ()
(gdb)
Veni, Vidi, Et je n'en crois pas mes yeux! (ik kwam, ik zag, en ik geloofde mijn ogen niet!) - J. Caesar (Asterix en de gladiatoren) | Nu vernieuwd met toegevoegde lazyness.
  • Thijsch
aha, ik zie op welk punt het fout gaat, bij mij gaat dat daar echter helemaal goed?
wat je wel kan doen, voor die regel 97 deze text zetten:
  if(!(topic->id))
    return;
dat voor regel 97 en achter regel 96. Kijk eens of het dan werkt?
  • MadCow*
MadCow*
resultaat:
(gdb) run
Program received signal SIGBUS, Bus error.
0x0804c6c3 in http_get_url (url=0xd0d0d0d0 <Error reading address 0xd0d0d0d0: Bad address>,
    timeout_ns=3000000) at http.c:351
351             if (!strncmp(url, "http://", 7))
(gdb)
[ Voor 9% gewijzigd door MadCow* op 21-02-2003 22:43 . Reden: rm -rf typo ]
  • Thijsch
wtf? :+ :+ freeBSD is raar :). Ik heb eerlijk gezegt geen flauw idee wat dat zou kunnnen veroorzaken, ik wil er wel eens naar kijken, maar ik probeer het eerst onder linux helemaal werkend te krijgen :).
  • Thijsch
Oke. /me deelt een rotschop uit
De vorige versies waren nogal brak, en het versie nummer was veel te hoog. Ik heb zitten proggen, en heb de code opgeschoont, gedebugged en wat extra features toegevoegd.
Er zit nu oa een systray icon bij (in de readme staat hoe je die in gnome aan kan zetten), in KDE werkte het dacht ik ook ,heb ik echter niet getest.
De nieuwe versie is Hier te downloaden, laat me even weten wat je ervan vindt. Oja: als hij tijdens het opstarten chrasht moet je je config weggooien (nieuwe versie schrijft en leest meer).
Remove de map ~/.gconf/Hottopic en kill het programma: gconfd-2 (die cached namelijk), dan moet het werken.
Die message zag er ook niet uit, en heb ik ook verbeterd:
Afbeeldingslocatie: http://members.chello.nl/g.assies/popup.png
De tekst was eerst blauw:
Afbeeldingslocatie: http://members.chello.nl/g.assies/newreply.png
Maar dat werd me afgeraden.
Gnome ondersteund nog geen popups(dus echt zoals bij msn, of hotopic voor windows een popup vanuit de systray. Ik zit te kijken of ik het zelf kan maken, maar dat is dan voor een volgende release ).
[ Voor 25% gewijzigd door Thijsch op 08-03-2003 18:28 ]
Ik zou het programma ook wel willen proberen. Screenshots zien er goed uit btw. De URL naar versie 0.6 is goed maar zodra de download begint blijft de boel hier staan te wachten en ik krijg de het bestand niet binnen. Zal wel weer aan members.chello liggen ofzo. Heeft iemand anders toevallig versie 0.6 beschikbaar voor download dan haal ik m daar wel weg. TIA!
  • Thijsch
Ja, klopt, members.chello.nl is niet zo goed.. ik ga op zoek naar een andere mirror.
trouwens: chello lijkt het weer te doen.
[voor-de-zekerheid]
En trouwens: dat ik nu wat laat reageer ligt niet aan dat hottopic het niet doet, ik was aan het opruimen :)
[/voor-de-zekerheid]
[ Voor 9% gewijzigd door Thijsch op 08-03-2003 19:13 ]
  • Memphisto
  • Laatst online: 17:54
Hmm, ik heb de nieuwe via je link gedownd en ff die oudere 1.0 versie weggehaald.
Netjes uitgepakt en ./configure gedaan en daar kwam hij zonder problemen doorheen (geen errors)
Maar bij make krijg ik dit:
configurewindow.c: In function `frmRw':
configurewindow.c:650: parse error before `*'
configurewindow.c:652: `frm' undeclared (first use in this function)
configurewindow.c:652: (Each undeclared identifier is reported only once
configurewindow.c:652: for each function it appears in.)
configurewindow.c: In function `remove_forum':
configurewindow.c:676: parse error before `*'
configurewindow.c:677: `frm' undeclared (first use in this function)
make[2]: *** [configurewindow.o] Error 1
make[2]: Leaving directory `/home/marcel/src/Hottopic-0.6/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/marcel/src/Hottopic-0.6'
make: *** [all] Error 2
En aangezien ik weinig verdere info kan vinden over deze prog vraag ik het hier maar ff. :P
Kan iemand me vertellen wat er fout gaat ??
Deep into that darkness peering, long I stood there, wondering, fearing, doubting, dreaming dreams no mortal ever dreamed before.
  • MadCow*
MadCow*
It's mister Trouble maker again >:).
./configure en make doen het normaal. Ik cp de src/hottopic naar ~/bin en run hem daar.
(gdb) r
hottopic in free(): error: junk pointer, too high to make sense
Program received signal SIGABRT, Aborted.
0x28acf763 in kill () from /usr/lib/libc.so.5
[ Voor 6% gewijzigd door MadCow* op 08-03-2003 19:34 ]
ParaDot schreef op 08 maart 2003 @ 19:12:
Het is gelukt.
Het programma draait ook al.
Slackware 9.0 beta hier. Geen enkel installatie probleem gehad. GOT.hfd even toegevoegd en een paar topics. Ik wacht nu alleen nog op replies maar verder lijkt het uitstekend. Goede programma lay-out vind ik trouwens. Geen overbodige poespas maar mooi clean opgezet.
edit: eerste reply op dit topic (mn eigen reply) kwam net ook netjes binnen.
[ Voor 7% gewijzigd door Verwijderd op 08-03-2003 19:52 ]
  • Thijsch
Memphisto schreef op 08 March 2003 @ 19:15:
aarg. dacht ik dat het een keer goed ging :(. mijn compiler gaf geen fout, maar ik heb het al gevonden. zet deze file in de src dir, en overschrijf de bestaande file. Dan moet het werken.
/me haat zijn compiler.
Heeft een van jullie zin om beta tester te zijn? dan kan ik in het vervolg dit soort situaties voorkomen.
tar.gz is geupdate.
[ Voor 3% gewijzigd door Thijsch op 08-03-2003 19:58 ]
  • Thijsch
Verwijderd schreef op 08 March 2003 @ 19:51:
Het is gelukt.
:* :* Als je twijfelt of het werkt moet je gewoon het bovenste topic van de actieve topics toevoegen :).
Als je hem gehide hebt in de docklet (werkt dat bij jou? ) en je wil een topic toevoegen, druk je rechts op het icoontje en dan "Add topic", zo hoef je niet het hele venster tevoorschijn te toveren.
[ Voor 15% gewijzigd door Thijsch op 08-03-2003 19:56 ]
De docklet werkt bij mij niet. Ik heb net zoals de readme aangeeft rechtermuisknop, add to panel, utility, notification area gedaan. Ik heb nu inderdaad een notitfication area. Dan start ik hottopic opnieuw en ga ik minimaliseren maar dan gaat het programma niet naar de notification area. Vind ik zelf niet zo'n ramp trouwens. Het werkt mij goed genoeg zo :)
Ik draai trouwens dropline-gnome-2.2 http://www.dropline.net/gnome/
GCC version = 3.2.1
[ Voor 7% gewijzigd door Verwijderd op 09-03-2003 19:16 ]
  • MadCow*
MadCow*
ParaDot schreef op 08 March 2003 @ 19:52:
tar.gz is geupdate.
ik wil wel beta tester zijn. Ik ben trouwens wel benieuwd waar die error van mij nou vandaan komt.
tussen haakies, ik heb die error van Memphisto niet gezien bij het compilen.
  • Thijsch
Verwijderd schreef op 08 March 2003 @ 20:06:
Aha, nee, om te minimaliseren moet je op het docklet icon klikken :)
@madcow: dat zou cool zijn! die error van memphesto komt omdat ik voordat ik vars initialiseerde al een if had. meeste compilers pakken het, maar die van hem blijkbaar niet. Ik voeg je wel toe aan ICQ :)
  • MadCow*
MadCow*
ParaDot schreef op 08 March 2003 @ 21:06:
ICQ? Oh ja die hadden we ook nog.
/me gaat ff client compilen en oude config stuff zoeken ;)
  • Thijsch
OF #nos op irc.tweakers.net Of msn @ thijs_a_nospam_@gmx.net
Binnen een minuut! woei @ hottopic ;)
[ Voor 34% gewijzigd door Thijsch op 09-03-2003 01:40 ]
Ik gebruik het programma nu de gehele avond en ik heb toch een paar keer een crash gehad. Het treed op als er meerdere topics in de lijst staan. Stuk of 3 ofzo is is genoeg. Soms als er dan een reaktie in een forum komt van zo'n topic bevriest Hottopic. Als je het daarna sluit dan komt er een gnome crash melding. Omdat het al een paar keer voorkwam heb ik de debugger even aangezet. Misschien heb je er iets aan.. Kan ook zijn dat iets op mijn systeem brak is maar kan ook wezen dat een buffer overloopt als ik de melding zo zie.
Starting program: /root/Hottopic-0.6/src/hottopic
[New Thread 16384 (LWP 23269)]
Extra content at the end of the document
[New Thread 32769 (LWP 23270)]
[New Thread 16386 (LWP 23271)]
[Switching to Thread 16386 (LWP 23271)]
0x0805283f in parse_string (
input=0x3c090a3e <Address 0x3c090a3e out of bounds>) at hfdparse.c:79
79 output = (char *) g_malloc(sizeof(char) * strlen(input));
(gdb) Quit
(gdb)
[ Voor 3% gewijzigd door Verwijderd op 08-03-2003 23:59 ]
  • Thijsch
smars, zou je in gdb eens backtrace willen typen, mij die log en de file ~/.hottopic_debug toemailen? (thijs_a(nospam)@gmx.net )
ParaDot schreef op 09 March 2003 @ 01:41:
Ik heb zojuist de informatie gemailed. Hij ging wederom onderuit.
  • Thijsch
Ik heb de logs gezien, en het heeft iets te maken met een bepaald FOK! topic, als ik hem toevoeg gaat het ook fout. Ik ga even kijken waar het zit.
Ok de bug is gefixt. het zat hem erin dat fok in de XML geen tag <messageid> had. Die werd dus op NULL gezet en daarom ging hij op zn bek.
Je zei dat het statusdock niet had: heb je wel make install gedaan? Anders installt hij geen icon, en als er geen icon is maakt hij geen docklet
Mensen: zoek ajb zoveel mogelijk bugs, dan kan ik die ook fixen ;)
[ Voor 61% gewijzigd door Thijsch op 09-03-2003 12:00 ]
ParaDot schreef op 09 March 2003 @ 11:37:
Cool dat het toch echt een foutje was en dat je het opgelost hebt.
make install heb ik inderdaad nog niet gedaan. Ik dacht eerst maar even kijken of het programma iets voor me is en daarna ben ik het vergeten om even netjes te installeren.
Ik ga het zo nog wel even doen :)
edit: Docking werkt nu ook. Nog wel 1 ding. Ik moest zelf een Launcher maken naar /usr/local/bin/hottopic en zelf nog het icoontje erbij zoeken. Kortom na make install kreeg ik hottopic niet automatisch in het Gnome menu. Maakt verder niet uit maar is misschien nog een puntje om nog eens een keertje naar te zien.
[ Voor 16% gewijzigd door Verwijderd op 09-03-2003 12:31 ]
  • Thijsch
Verwijderd schreef op 09 March 2003 @ 12:03:
ok, fixed, zit er nu ook bij. :)
  • Memphisto
Na de oplossing van Paradot te hebben doorgevoerd (een paar topics hier boven ). Heb ik het nog maar eens geprobeert, maar nu stuit ik weer op een andere error nl deze:
functions.c: In function `show_popup':
functions.c:384: parse error before `result'
functions.c:393: `image' undeclared (first use in this function)
functions.c:393: (Each undeclared identifier is reported only once
functions.c:393: for each function it appears in.)
functions.c:401: `hbox' undeclared (first use in this function)
functions.c:430: `result' undeclared (first use in this function)
cc1: warnings being treated as errors
functions.c:437: warning: unreachable code at beginning of switch statement
functions.c: In function `check_TF':
functions.c:575: parse error before `length'
functions.c:583: `length' undeclared (first use in this function)
make[2]: *** [functions.o] Error 1
Ben ik nou echt de enige hier met deze problemen?? :P
Ik wacht maar weer op de oplossig :o
  • MadCow*
MadCow*
memphisto wat voor distro heb jij en kun jij dit even doen?
gcc --version
  • Memphisto
Ik draai hier debian woody, kernel 2.4.20
En de versie van gcc is : 2.95.4
  • MadCow*
MadCow*
Memphisto schreef op 09 March 2003 @ 15:21:
Ah dat verklaart het. Ik kan jou probleem met gcc 2.95.4 hier herhalen.
Ik gebruik hier gcc 3.2.2, ik weet niet wat voor compiler paradot gebruikt maar dit lijkt de oorzaak van jou probleem te zijn.
/me zet op zijn test lijstje "ook kijken hoe een "oudere" compiler denkt over de source".
  • Thijsch
gcc (GCC) 3.2.3 20030228 (Debian prerelease)
aha :). Ik ga er ook naar kijken hoe oude compilers ermee omgaan. dankje voor de bugmelding :*.
Oke, ik heb de code aangepast, het werkt nu met
2.95
3.2.3
Met de meest gebruikte versies(3.2 en 2.95) gaat het nu dus goed .
[ Voor 33% gewijzigd door Thijsch op 09-03-2003 19:25 ]
  • CyBeR
CyBeR
Ik wacht nog op iemand met de CC van HP-UX ofzo :+
Heb je de aangepaste versie ook beschikbaar voor download ? Ik heb net weer een versie gedownload vanaf de official site. Ik zag dat er 1 bestand van een andere datum/tijd was. Gisteravond rond 19.00 uur ofzo. Ik heb de source code opnieuw gecompileerd en geinstalleerd maar ik krijg nog steeds soms met fok problemen. Ik zou de laatste release wel willen testen.
  • Thijsch
die 0.6 is de laatste release. ik zit nu nog een bug te fixen en dan gooi ik er wel een 0.6.1 uit. dat wordt dan morgen,overmorgen. dan is er ook een freeBSD port btw :)
[ Voor 13% gewijzigd door Thijsch op 09-03-2003 22:30 ]
ParaDot schreef op 09 March 2003 @ 22:25:
oki dan test ik die binnenkort wel terwijl gdb meeloopt. Misschien komt er nog wat uit. Reuze handig programma trouwens. Ik waardeer het al meer en meer :)
[ Voor 10% gewijzigd door Verwijderd op 09-03-2003 22:28 ]
  • supakeen
  • Laatst online: 09-09-2025
Werkt lekker alleen als ik dit topic:
Algemeen tekentopic (handgetekend / wacom only), part 3
Probeer toe te voegen blijft topic-titel en aantal reacties onbekend :?
  • Thijsch
zmn: klopt, is met alle topics, hij vult alleen in wat hij weet, het ID, het forum(GoT) en de replies(0). Als het topic dan in de XML zit wordt hij geupdate. wordt hij niet geupdate zit hij niet in de XML ;)
  • MadCow*
MadCow*
grrr paradot was me voor :p
  • supakeen
ParaDot schreef op 09 March 2003 @ 22:42:
En waarom zit dat topic niet in de xml :P
Oooh hij moet zeker bij de laatste .... topics zitten :?
[ Voor 8% gewijzigd door supakeen op 09-03-2003 22:46 ]
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
je kunt erachter komen wat de naam van een topic is via bijv. http://gathering.tweakers.net/xml/list_messages/319439
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Thijsch
moto-moi: cool! die kende ik niet, daar kan je nog meer mee ;)
aarg! dat is geen XML, dat is een berg prut :)
/edit: ik heb het even doorgekeken en ik ga het inbouwen. Ik vraag jelmer vos om de hfd files te updaten met een extra tag..., got.hfd doe ik zelf wel ;) maar ik ga nu beginnen aan poging 5 om naar bed te gaan ;)
[ Voor 79% gewijzigd door Thijsch op 09-03-2003 23:07 ]
  • moto-moi
moto-moi
ParaDot schreef op 09 maart 2003 @ 22:59:
Mjah, in principe kun je alles waarbij 'forum' in het url zit, door xml vervangen, om een xml-versie te krijgen
zo zie je maar, idlen in #devschuur kan soms best handig zijn ;)
  • Thijsch
Oke, ik heb weer zitten denken en ik dacht aan:
message:
new reply!
topic: blaat
lastreplier: blaat
<link>View reply</link>
zodat je kan zien met welke text er gereageerd is ;) Maar dat is dan wel GoT Only... of ik maak het zo dat het werkt voor alle fora met een ExtXMLURL(oid) tag (met als value de url naar de xmlprut)in hun hfd files....
woei
/me wordt vaag
nu ga ik ECHT slapen. (poging 6)
  • Valium
  • Laatst online: 11-09 23:37
Valium
- rustig maar -
Waarom is hottopic voor linux engels? Zit ik me een beetje in het zweet te werken om alles een beetje NL te krijgen. Worden er doodleuk zulke programma's gemaakt...misschien een idee om het programma te gettext-enablen. Op die manier heb je in een keer een engelse en een nederlandse versie zonder veel poespas. Omdat je al glade gebruikt zou dat echt een kwestie van 3x klikken moeten zijn.
Ook heeft GNOME wel support voor popups dacht ik zo (je maakt een paar berichten geleden een opmerking over). Ik zie sylpheed (GPG wachtwoordinvoer), gnome-session (afmelden) en workrave (alle venstertjes van dit programma) zulke dingen gebruiken. Misschien is het iets om die van workrave over te nemen. Ik vind ze namelijk erg mooi. Van die unmanaged vensters middenin je scherm.
ik kan geen forum adden, of doe ik iets fout?
wat ik ook intyp in dat tekstfield, als ik op add klik verschijnt er: warning nr. 1 met: "No forums added", warning nr. 2 met: "Invalid URL, no 'h' found"
  • CyBeR
CyBeR
Valium schreef op 10 maart 2003 @ 00:23:
Gettext support zou handig zijn idd. En het is engels omdat het zo hoort :P
Dat is niet wat herr paradox bedoelde. Hij doelde op de popupjes die nog geimplementeerd moeten worden in de notification tray (tenminste, afaik zijn ze er nog niet.) Denk maar aan die winxp ballonnetjes die bij de systray vandaan komen.
  • Valium
Valium
- rustig maar -
CyBeR schreef op 10 maart 2003 @ 01:19:
Tsss...omdat het zo hoort. ;)
Glade is iig nogal slim, want mijn versie is al half Nederlands (hij neemt vertalingen over van de stock-widgets van gnome-gtk). Als het gettext gedeelte klaar is wil ik wel een goeie NL vertaling klussen.
Ow, die dingen. Okee, dat heeft GNOME idd nog niet. Mijn fout.
Tijd voor een micropauze...
  • Thijsch
Zo! /me is weer wakker en heeft er een schooldag opzitten :).
ik ga nu:
-nog een bugje fixen
-.po files maken.
en huib B: je moet eerst in het configurewindow een forum adden.
  • Thijsch
Oke. Een dagje later dan gepland, maar hij is klaar: versie 0.6.1
change:
0.6.1 - bug: pango errors met een popup
- feat: popup wordt rerebuild als hij kapot is gegaan
- bug: het werkte niet met een oude gcc, fixed
- added hotopic.desktop
- segfault bij het opstarten
-diverse andere bugs
Ook heb ik de layout iets veranderd. TopicID, forum (GoT) is niet interresant voor een user, is dus ook neit meer zichtbaar. Subforum staat er nu wel bij.
Laat even weten wat je ervan vindt!
O ja: Ik heb het gettext zitten kloten, maar het wil niet echt lukken, deze versie zit het dus nog niet in, maar als het klaar is laat ik het horen.
Download Hier
/edit: En: er is een freeBSD port. MadCow komt die zo posten denk ik ;)
[ Voor 30% gewijzigd door Thijsch op 12-03-2003 22:27 ]
  • MadCow*
MadCow*
Ok hier is de FreeBSD port.
Die shar file kun je uitpakken door naar ports/net te gaan en dan sh /path/to/shar-file te doen.
Sommige van jullie zullen wel denken waarom zorgt ie er niet voor dat het in de port collection komt.
Nou ik heb hier 2 redenen voor:
1. Er is een port freeze op het moment (dit om packages te kunnen maken voor 4.8-release).
2. Ik wacht liever tot gettext is ingebouwd, kunnen we het meteen goed doen :)
En natuurlijk fout meldingen kunnen je in dit topic kwijt.
/me heeft deze week al twee oer domme fouten gemaakt dus het kan zo weer gebeuren ...
[ Voor 2% gewijzigd door MadCow* op 12-03-2003 23:12 . Reden: ) = kreng ]
  • Thijsch
Ah, dank madcow! Mooi zon port :). Ik ben ook nog bezig met een site ervoor. hottopic.nl mag lekker voor windows blijven ;) Dit Is de eerste test, de subpages doen het nog niet. ik wilde het vooral simpel houden.
  • Thijsch
Even een vraagje: Is de nieuwe lay-out zo beter? en zitten er nog meer bugs in?
Ik zou gewoon de linux en windows versies op dezelfde website proberen te houden, veel makkelijker. En de BSD fixes moeten op zich in de Linux versie te implementeren zijn, dat hoeven toch geen aparte producten te zijn?
  • Thijsch
Klopt. het bsd script download de nieuwste linux tarball als je het gebruikt :). En op hottopic.nl houden is ook wel een goed idee. Ik zit nu iig de gnome calls eruit te slopen ;)
/edit: binnen een minuut, hottopic werkt goed ;)
[ Voor 13% gewijzigd door Thijsch op 13-03-2003 16:40 ]
Nu moet ik nog leren hoe ik met glade2 werk, dan kan ik ook eens proberen i18n te gebruiken. :o. Ik zie nog geen optie om bonobo componenten te maken in glade, kan dat uberhaupt of zit ik weer moeilijk te doen?
/me is gewend aan met-de-hand devven...
  • Thijsch
/me ook :). Het about window is bijna af, dan moet gnome_url_show eruit, en dan gettext erin.
  • Valium
Valium
- rustig maar -
ParaDot schreef op 13 March 2003 @ 16:59:
Een about window is een standaardwindow. Kijk maar eens naar de andere GTK2 / GNOME2 progsels. Dat moet dus niet zo moeilijk zijn.
  • Thijsch
Valium: inderdaad, het is een standaard gnome venster, dat gebruik ik ook al :). In het hele prog zitten iets van 3 gnome calls, inc het about window, en die wil ik weg, dan werkt het ook met kde.
Gnome apps werken ook in KDE hoor. :P.
  • Thijsch
Met gnome libs geinstalld wel ja ;) Ik wil het iig een GTK app maken
  • Memphisto
Jaja daar is tie weer die zeur met z'n problemen, dit keer een probleem wat wellicht door mijn n00b-heid kan komen, omdat ik niet weet waar ik moet beginnen met het zoeken van de oplossing.
Probleem: Netjes source gedownd en geinstalleerd met achtereenvolgens: ./configure , make , make install
Nergens geen error tegengekomen dus ik denk gewoon, YAHOO het werkt weer. :P
Maar niets is minder waar, bij het starten van de prog krijg ik een segmentation fault!! :(
Kan iemand me verder helpen hiermee??
  • Thijsch
Hmm... hij chraste al voor dat je iets op het scherm zag? Start het eens met gdb:
gdb ./hottopic
run
<als hij chrasht : >
backtrace
kan je de output van backtrace hier posten?
  • Memphisto
Sorry eerste keer voerde ik als root uit
Hier komt tie as user waarbij tie wel crasht:
Starting program: /usr/local/bin/hottopic
[New Thread 1024 (LWP 5096)]
[Switching to Thread 1024 (LWP 5096)]
0x40847bb8 in free () from /lib/libc.so.6
(gdb) backtrace
#0 0x40847bb8 in free () from /lib/libc.so.6
#1 0x4084789a in malloc () from /lib/libc.so.6
#2 0x40847074 in malloc () from /lib/libc.so.6
#3 0x4083a681 in fopen () from /lib/libc.so.6
#4 0x08050d7e in debug_init () at functions.c:810
#5 0x0804f431 in main (argc=1, argv=0xbffffb64) at got_topics.c:32
[ Voor 83% gewijzigd door Memphisto op 13-03-2003 19:57 ]
  • Thijsch
Heb je make install gedaan? ?
/edit: ah, dat, heb je wel de nieuwste versie genomen? 0.6 had dat probleem, maar met 0.6.1 zou dat verholpen moeten zijn.
[ Voor 69% gewijzigd door Thijsch op 13-03-2003 20:03 ]
  • Memphisto
Hottopic-0.6.1.tar.gz <------ zegt genoeg denk ik :P
  • Memphisto
***KICK**** :P
Hmm Paradot, heb je al een oplossing, of heb je meer info nodig????
Ik weet 100% zeker dat ik 0.6.1 gebruik, maar het wil gewoon niet werken, ook niet na een re-install!!! :(
  • Thijsch
Ik zit er nog even naar te kijken, ik laat het z.s.m weten. Ben tegelijk ook nog bezig met gettext en gnome eruitslopen :) Maar ik kom er wel uit! thx iig! :*
ParaDot schreef op 10 March 2003 @ 16:27:
dan vraag ik mij toch echt af: hoe?
ik doe:
-url intypen in dat textfield met die add en delete knop ernaast, krijg de melding "no forums added"
-dan doe ik het anders: file > preferences > forums tab > add (dan krijg je die gtk file browse widget, weet oo kniet echt wat ik daar mee aan moet
  • MadCow*
MadCow*
Verwijderd schreef op 14 maart 2003 @ 21:24:
ik doe:
daar moet je de got.hfd laden :) dan kan ie GoT in de gaten houden
/me ruikt F.A.Q. :o
bug?melding:
-Hottopic versie 0.6.1
-Slackware gcc 3.2.1
-Hfd files: tesamen met nieuwe hottopic versie opnieuw van de hottopic site gedownload.
-Installatie gedaan door verwijderen oude versie:
make uninstall, no rule to make uninstall;
rm /usr/local/bin/hottopic;
./config; make; make install;
Got forums gaan ok. Fok forum gebruiken geeft na enkele seconden:
"Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16386 (LWP 3064)]
0x409b08d1 in g_strdup () from /usr/lib/libglib-2.0.so.0
(gdb) backtrace
#0 0x409b08d1 in g_strdup () from /usr/lib/libglib-2.0.so.0
Error accessing memory address 0x409b0894: No such process.
edit: een estetisch puntje wat ik persoonlijk niet zo van weg ben is dat als hottopic
aanstaat en je zit wat te browsen ofzo dan komt de de melding in beeld dat er een reply is op een topic met ok button en jump to button. Prachtig.. Vooral dat jump to is reuze handig. Maar.. als je nou denkt ik zie straks wel even dan gebruik je (tenminste dat doe ik) de ok button zo van: 'ga jij maar even weg' en dan maximaliseert het window van hottopic en die moet ik dan weer minimaliseren. Dit laatse vind ik zelf niet echt handig. Als de ok button wordt geklikt moet hottopic eigenlijk niet uitzichzelf gaan maximaliseren en de window focus krijgen. (Geen idee wat anderen hiervan vinden..)
[ Voor 35% gewijzigd door Verwijderd op 16-03-2003 09:13 ]
  • Thijsch
a thx smasr, ik zal er aan werken :). Ik heb de laatste dagen niet echt veel gedaan, dr is namelijk iets heel engs gebeurd... iets met sociaal leven oid :? :?
  • Thijsch
MadCow schreef op 14 March 2003 @ 21:26:
/me ruikt F.A.Q. :o
O+ README O+
staat het in :)
  • Bananenplant
Bananenplant
Blocking YOUR ads since 2005
sorry dat ik schop, maar het werkt nu gewoon fantastisch^^!
alleen bij sommige fora moet ik nog wel de url zelf aanpassen omdat er naast het topicnummer nog wat argumenten van sortering zijn enzo.
VVD. Maakt crises erger 🏚️ .
Zucmantaks, nu 💰 !
De mythe van de zelfredzame burger 🦄 .
ParaDot schreef op 16 March 2003 @ 09:40:
ohjee, paradox een vriendin? :D.
  • Thijsch
De gnome calls zijn er uit nu. De config gaat nu met XML, dat is opzich af, moet het nog even in hottopic bouwen (ik had het als test eerst los gebouwd), dan naar die bugs kijken, en ucchan: bij welke fora moet je wat precies aanpakken?
/me is van vr tm zo ook nog weg :)
Ehm... je files zijn down :?
Waar moet ik m nou downloaden :'(
Je 0.6 file is down, de link gaat naar 0.6, maar 0.6.1 doet het wel gelukkig :)
--EDIT--
./configure geeft foutmelding :(
checking for pkg-config... no
*** The pkg-config script could not be found. Make sure it is
*** in your path, or set the PKG_CONFIG environment variable
*** to the full path to pkg-config.
*** Or see http://www.freedesktop.org/software/pkgconfig to get pkg-config.
configure: error: You don't have glib-2.0 (1.3) installed
Bij ./configure
Ik dus pkg-config installeren, gedaan, okee, nu glib-2.0 nog. Ikke installatiecd erin, en ik typ rpm -i glib2-2.0.6[ennogwatspul] en er staat:
Package already installed.
Nou weet ik dus niet echt precies wat het probleem is...
Ik gebruik trouwens UnitedLinux 1.0-RC5, en die is nog niet echt af zeg maar (had bij installatie best wat problemen met fonts en anti-aliasen :o )
[ Voor 117% gewijzigd door Verwijderd op 17-03-2003 22:31 ]
  • Thijsch
Aha :). Heb je Überhaupt wel X? ;) Als je geen Glib, Gtk of libxml hebt (worden voor heel veel progsels waaronder hottopic) gebruikt is dat wel vreemd. Het kan dan nog zijn dat je KDE draait, als dat het geval is moet je even wachten op de volgende release, dan is hottopic Gnome-loos. Je hebt dan nog steeds wel glib, gtk, libxml nodig
volg je me nog? :? :P
EDIT: Ik zie net dat je glib al hebt: dan moet je de -dev versie ook hebben. glib[nummer]-dev.rpm
[ Voor 13% gewijzigd door Thijsch op 17-03-2003 22:35 ]
ParaDot schreef op 17 March 2003 @ 22:34:
Ooh... zal het morgenmiddag, na proefwerken op school :Peens proberen... ik had ze dacht ik wel op CD2 gezien ja :)
[edit]
Ik draai inderdaad KDE... wanneer komt de volgende release dan? :+
[ Voor 6% gewijzigd door Verwijderd op 17-03-2003 23:03 ]
  • Thijsch
Hmmm
/me tilt been op
*SCHOP*
Het heeft even geduurd :+ Maar de nieuwe release is klaar. Gnome calls zijn eruit. Het heeft nog niet gechrasht en nog wat bugs her en der :)
Ook compilen met gcc-2.95 moet werken!
Hier kan je hem downloaden.
Laat even horen of deze beter werkt etc :). En hopelijk kan MadCow weer een leuke freeBSD port maken :+
nog wat: aangezien de gnome calls weg zijn was het niet meer mogelijk een standaard "browser open" request te doen. In het config window moet je even je browser invullen. Voor mozilla wordt het: "mozilla %s" zonder quotes uiteraard :)
[ Voor 25% gewijzigd door Thijsch op 16-04-2003 20:20 ]
  • blackd
Ik heb hem zojuist gecompileerd en geinstalleerd onder Slack 9 met Gnome 2.2.1 (dropline).
Ik heb de hfd uit de FAQ gebruikt, maar als ik een topic toevoeg, zie ik vraagtekens staan bij forum, title etc. Dus het topic wordt niet herkend.
Net een paar urls en hij crasht weer.
Console output:
(hottopic:3787): GLib-GObject-WARNING **: gsignal.c:2010:g_signal_handler_disconnect(): instance `0x8092520' has no handler with id `238'
Segmentation fault
Tijdens het compilen overigens geen problemen.
Ik heb trouwens gcc version 3.2.2, geen id of dat uitmaakt :o
[ Voor 6% gewijzigd door blackd op 16-04-2003 20:35 ]
9000Wp o/w SolarEdge SE6K - Panasonic 5kW bi-bloc - gasloos sinds 17-7-2023
  • Thijsch
Die vraagtekens kloppen hoor :) Zogauw je een topic toevoegt weet hij nl nog niets. Pas als het topic in de XML file zit (nieuwe reply) wordt alles geupdate. Probeer eens rustig een topic uit de actieve topics toe te voegen (geen HK of SG uiteraard) en zie dat het werkt
Die error zal ik even naar kijken :)
  • blackd
Zo'n vermoeden had ik al. Ik dacht dat ik lang genoeg gewacht had.
Ik zal hem wel es wat langer draaien. Kijken wat ie doet :)
Heb hem net 2x opnieuw aangezet. Na ongeveer 30 seconden (jaja, getimed *D) krijg ik een segmentation fault. Het lijkt er dus op dat Hottopic de XML file helemaal niet kan ontvangen ofzo?
[ Voor 83% gewijzigd door blackd op 16-04-2003 20:40 ]
  • Thijsch
Kan het zijn dat je snel achter elkaar op "Delete" ramde? :+ daar zou die error nl wel eens van kunnen komen ;)
  • blackd
Dat zou best kunnen :X
Ik heb zojuist mijn vorige post ge-edit, ik krijg dus geen XML binnen maar een segfault.
Overigens heb ik 4 topics in mijn lijst, 3 WOS en 1 NSTM (die gaan snel :P)
Hmm, die NSTM zal ie wel niet zien met hottopic gok ik.
Ik ga es testen met 1 topic in WOS, kijken wat hij doet.
Edit: 1 Topic in WOS gaat goed! :)
[ Voor 6% gewijzigd door blackd op 16-04-2003 20:42 ]
  • Thijsch
:* de speciale fora gaan niet, daar moet je Kees even hard voor schoppen :+ Maar de rest moet het doen :).
Er zit btw ook een WOS-mod detectie op. Als ie doorheeft dat er een WOS-mod in de buurt is, gaat hij over tot random_segfault();
  • blackd
ParaDot schreef op 16 April 2003 @ 20:44:
Lijkt erop dat ie daardoor segfault?
Ah, that explains. Zit Jotti ook in de source? :D
  • Thijsch
Daardoor zou hij zeker niet moeten segfaulten! van speciale fora zal de info gewoon niet geupdate worden.
  • blackd
ParaDot schreef op 16 April 2003 @ 20:47:
Ik ga het even testen :)
* blackd wil ook een mooie MSN style popup :X :+
Feature request: Status balk met daarin de huidige actie. Bijv: downloaden van XML.
Edit: Lijkt nu idd goed te werken. Waarom ie dan net de fout in ging :?
[ Voor 27% gewijzigd door blackd op 16-04-2003 20:53 ]
  • MadCow*
MadCow*
testing in progress :)
  • Thijsch
blackd schreef op 16 April 2003 @ 20:47:
<Beelzebubu> hmm...
<Beelzebubu> zou een statusbar niet handig zijn?
en over dat 2e: die WOS-mod detectie is serieus...
  • blackd
bram@bram-slack:~$ hottopic
Segmentation fault
Nah lekker dan :D
  • Thijsch
ram gdb er eens langs wil je ?
  • blackd
Starting program: /home/bram/hottopic-0.7.0/src/hottopic
[New Thread 16384 (LWP 3922)]
[New Thread 32769 (LWP 3923)]
[New Thread 16386 (LWP 3924)]
[Switching to Thread 16384 (LWP 3922)]
0x4068ec26 in malloc_consolidate () from /lib/libc.so.6
backtrace:
#0 0x4068ec26 in malloc_consolidate () from /lib/libc.so.6
#1 0x4068e533 in _int_malloc () from /lib/libc.so.6
#2 0x4068d6b5 in malloc () from /lib/libc.so.6
#3 0x403ec817 in g_malloc () from /usr/lib/libglib-2.0.so.0
#4 0x4031d63f in fribidi_analyse_string () from /usr/lib/libpango-1.0.so.0
#5 0x4031dd78 in pango_log2vis_get_embedding_levels ()
#6 0x40310564 in pango_itemize () from /usr/lib/libpango-1.0.so.0
#7 0x40316916 in pango_layout_check_lines () from /usr/lib/libpango-1.0.so.0
#8 0x4031508c in pango_layout_get_extents_internal ()
#9 0x40315300 in pango_layout_get_extents () from /usr/lib/libpango-1.0.so.0
#10 0x4031538e in pango_layout_get_pixel_extents ()
#11 0x40089166 in draw_row () from /usr/lib/libgtk-x11-2.0.so.0
#12 0x40089625 in draw_rows () from /usr/lib/libgtk-x11-2.0.so.0
#13 0x4008977c in clist_refresh () from /usr/lib/libgtk-x11-2.0.so.0
#14 0x40080023 in gtk_clist_thaw () from /usr/lib/libgtk-x11-2.0.so.0
#15 0x403f8f0f in g_slist_foreach () from /usr/lib/libglib-2.0.so.0
#16 0x08051d14 in parse_function (type=3) at communication.c:108
#17 0x080523b6 in exec_call (source=0x8068858, condition=G_IO_IN, data=0x0)
at communication.c:309
#18 0x40406fbd in g_io_unix_dispatch () from /usr/lib/libglib-2.0.so.0
#19 0x403e78fe in g_main_dispatch () from /usr/lib/libglib-2.0.so.0
#20 0x403e8737 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#21 0x403e8b17 in g_main_context_iterate () from /usr/lib/libglib-2.0.so.0
#22 0x403e9210 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#23 0x400e4ec9 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#24 0x0804f19c in main (argc=1, argv=0xbffff8e4) at got_topics.c:93
#25 0x4062dbb4 in __libc_start_main () from /lib/libc.so.6
Anders nog iets?
  • MadCow*
MadCow*
nog iets wat me op is gevallen (nog de oude 0.6.1 versie) is dat als je het scherm voor je hebt en het minimalizeerd dus niet naar notification area stuurt. Dat de popups ook geminimalizeerd worden weer gegeven ...
Nog meer memory corruption! :D.
/me glimlacht en besluit dat dat best wel gemeen is...
  • Thijsch
Een echte Paradox deinst daar niet voor terug. Die fixt dat binnen een minuut! (pin me daar niet op vast :D :D ), De Jotti(c) is BTW ook af, inc WOS-mod detectie!
  • blackd
bram@bram-slack:~$ diff configurewindow.c hottopic-0.7.0/src/configurewindow.c
490a491,492
> gchar *foo = NULL;
493a496,505
> if(!strcmp(nick,"Jotti"))
> show_popup(NULL,"_O_ :9~ O+ Jotti O+ :9~ _O_\n");
> else if(!strcmp(nick,"Beelzebubu"))
> show_popup(NULL,"(K)(K)(K)(K)(K) beelzebubbeltje van me (K)(K)(K)(K)\n");
> else if(!strcmp(nick,"blackd"))
> show_popup(NULL,":r WOS mod :r\n");
> strcat(foo,"hah gaat dit chrashen??");
duss....
rm -rf hottopic-0.7.0
  • Thijsch
ParaDot! \o/.
Ohja, wanneer komt de volgende versie met statusbar erin uit?
  • Thijsch
Als blackd's probleem ook gefixt is. En gezien de huidige stand van zaken in de gezonheidszorg kan dat nog een tijdje duren.
  • MadCow*
MadCow*
Zo hier is ie dan (eindelijk) port for freebsd.
http://prisma.quccc.org/~kwm/hottopic-0.7.0.shar
Misschien een idioot detail maar ik zie hier helemaal geen crashes Met FreeBSD 4.8-stable zoals mensen hier boven hebben.
[ Voor 42% gewijzigd door MadCow* op 22-04-2003 22:01 ]
  • Thijsch
je zegt het al FreeBSD 4.8-_stable_
Pagina: 1 2 Laatste
