TFT: AOC LM800 of Samsung 171P
  • 44 views sinds 30-01-2008
Hallo, ik ga misschien een nieuwe TFT monitor kopen
Ik zit te twijfelen tussen de AOC LM800 (18.1 inch) en de Samsung 171p (17 inch)
beide zijn ongeveer even duur (rond de 700 euro)
Ik heb ook even gezocht, en ik vond veel info over de 171p, en heel weinig over de LM800. Heeft iemand misschien ervaring met de LM800 ?
Heb ook even de specs opgezocht van beide monitoren:
PLM800
DISPLAY - 18.1" Diagonal, TFT LCD Active Matrix LCD
Hard coating, Anti-glare screen treatment.
Viewing Angle: 160 degrees Horizontal, 160 degrees Vertical
16.7 million colors
PIXEL - 0.280mm x 0.280mm Pitch
RESOLUTION - Max.: 1280 x 1024 @ 75Hz 800 x 600 @ 60/75Hz
Rec.: 1280 x 1024 @ 60Hz 740 x 400 @ 70Hz
1024 x 768 @ 60/70/75Hz 640 x 480 @ 60/75Hz
BRIGHTNESS - 200 cd/m2 (typical)
CONTRAST - 450:1 (typical)
RESPONSE TIME- 23 ms
FREQUENCY - Scanning: Horizontal 30.0 ~ 80.0kHz
Vertical 55.0 ~ 75.0Hz
PIXEL RATE - 135 MHz
CONNECTORs - 15-pin D-sub Male (attached)
Kensington Security slot
SIGNAL - Video Input: 0.7Vp-p, RGB analog
Separate Sync: TTL level
H/V Sync : Positive/Negative
CONTROLS - Front Panel: Auto Adjust, Enter Key, Left Key, Right Key, and
On/Off key.
OSD Controls: Brightness, Contrast, Focus, Clock, H/V Position, Auto-
Center, Language, DOS Mode, 7800, 6500, Recall, Exit, RGB.
MISC. - DDC1/2B, EPA Energy Star
APPROVALS - UL,CSA,FCC,TUV/GS,CE,ISO 13406-2
POWER- Input: Universal 90~240VAC, 50/60Hz, Consumption 50 watts (max)
Output: 12VDC, 5A (max.)
SIZE - 16.6"w x 16.9"h x 6.5"d WT.- 14.5 lbs.
www.epius.com
171P
LCD Type a-si TFT/PVA
Display Area 17"
Pixel Pitch 0.264
Resolution 1280 x 1024 @ 75 Hz
Brightness 250 cd/m2
Contrast Ratio 500 :1
Viewing Angle Horizontal: 170°; Vertical: 170°
Response Time 25 ms
Cabinet Color Silver
Signal Input Input Video
Signal Analogue DVI digital link RGB
Video Level Analogue : 0.7V PP, DIGITAL : TMDS™
Frequency Horizontal: 30 to 81 kHz
Vertical: 56 to 85 Hz
Sync Type Analogue : 0.7V PP, DIGITAL : TMDS™
Bandwidth 135 MHZ
Input Connectors 15 pin D-sub, DVI-D
Included Signal
Cable VGA cable, DVI cable
Power
Requirements Voltage Source: 100-240 VAC, 50/60Hz
Consumption On working: 40W max.
Off: 3W max.
Misc. Features Emissions
Standard TCO’95
Plug & Play DDC 1/2B
Dimensions
(H x W x D) Unit 16.7" X 18" X 8.1"
Weight Unit 13.7 lb
Wat ik bij de LM800 niet kon vinden is DVI, is dit echt zoveel mooier als die normale aansluiting. (ik heb ze wel beide op de videokaart zitten)
Ik zit veel achter de pc, doe o.a. webdesign en grafische vormgeving. En af en toe speel ik natuurlijk ook wat games!
Wat zouden jullie me aanraden?
  • Pollewob
Zie http://gathering.tweakers..._messages/610591#ervaring.
En met [google=LM 800 + TFT] moet je toch een heel eind kunnen komen :)
