de betaler vervuilt
wat voor hardware heb je precies? Zeker een asus p2b? geef ff de EXACTE specs van je bord, dus Type, Rev. en Buildnr. dan kan ik je er wat over zeggen.
quote:
The part is a flat surface mount IC, about 10mm*15mm. It sits close to the slots, next to a group of capacitors, and a couple of inductors (the inductors are little 'rings' with wire wrapped round them, and very easy to spot). There are three different 'variants' from the manufacturer. All carry the number HIP6004. The legends are:
HIP6004CB
HIP6004ACB
HIP6004BCB
Now the last two letters can change (technically they imply the 'surface mount' package, and the plastic case). It is the first character after the number that matters.
The BCB, will generate voltages right down to 1.3v, whereas the ACB, will 'stop' at 1.8v, returning 0v for any pattern of bits for the lower voltages. The 6004CB, will also generate right down to 1.3v, but is not compatible with the signals used on the motherboard (it doesn't have 'TTL compatible' inputs, requiring 'open collector' drives).
I just checked the intersil site for you. The HIP6019 is in the same family as the HIP6004, but provides three additional output voltages (could be used for CPU I/O, clock chip, or other things). But disregard that - we only are interested in what core voltages are available.
And like the HIP6004, there is one version of the '6019 that has Vcore range of 1.80V to 3.50V, and another version with a 1.30V to 3.50V range. I'll summarize:
IC Vcore range
HIP6004ACB 1.80V to 3.50V
HIP6004BCB 1.30V to 3.50V
HIP6019CB 1.80V to 3.50V
HIP6019BCB 1.30V to 3.50V
met andere woorden... Als je een voltage-controller van het BCB type hebt ben je de man, het maakt niet uit of het een 6004 of een 6019 is.
(uit: http://gathering.tweakers.net/forum/list_messages/44282 )
HIP6004CB
HIP6004ACB
HIP6004BCB
IC Vcore range
Ennuh als je op 1.8v wilt draaien, dan kan dat ook natuurlijk. Of het echt veel kwaad kan, weet ik niet, maar als je behoorlijk koelt valt het denk ik wel mee. Misschien dat de CPU dan maar 5 jaar meegaat i.p.v. 10, maar dat maakt toch weinig uit, want over 5 jaar zit je toch alweer met wat nieuws.
Ik heb een Gigabyte 6BXD moederbordje (Dual slot 1 met BX chipset).
Nu staat er op de site dat ie coppermines vanaf rev 1.6 moet ondersteunen en volgens mij is het enige verschil tussen en coppermine en een katmai het gewenste voltage (multiplier locked zijn ze toch he, dus ik hoef geen 8x switch op mijn moederbord te hebben). Ik heb het bordje nu niet voor mijn neus dus ik zal straks eens even kijken welke chips ik kan vinden.
de betaler vervuilt
O, maar het bovenstaande geldt alleen voor de p2b, jammer maar over die Gigabyte 6BXD heb ik geen info.
Gewoon proberen is denk ik een oplossing, als 1.65v niet wil kan je 1.8v proberen. Ik zou wel voor slotket gaan, dat wil nog wel eens helpen om het voltage juist te krijgen. Bij slot1 vraagt de cpu meestal zelf om een bepaald voltage, op een sloket kan je meestal instellen wat er gevraagd wordt.
Joh ik heb mijn kopermijn 650@806 lopen en de spanning op 1.8V gezet moet makkelijk kunnen
Hij loopt nu 12% hogere spanning en 24% meer klok
Powered bij meergranenbrood.
