Niet op voorraad.
ATI brengt weer nieuwe DirectX 8 Driver uit.
Het is een driver met enkele interresante verbeteringen
- meer daarover in de Releas Note.
Performance gains:
~ CodeCreatures score is improved by 20% at 4X AA for 9700 series products
~ NASCAR 2002 framerate is up as much as 18% across the entire RADEON products line
~ NHL 2002 performance is up as much as 35% across the entire product line
(largest gains on RADEON 7500/8500)
~ Performance on legacy (dx6 and dx7) apps is improved by as much as 15%
for RADEON 9700 Series products
Features Added:
~ CATALYST 02.4 gives provides users with a new level of stability using SMARTGART 2. SMARTGART 2 gives users access to both the basic and advanced functionality through two control panel pages
~ DX Override Refresh Rate - Users can easily override refresh rate limitation imposed by both Windows 2000 and Windows XP, which limits the default refresh rate to 60 HZ when applications are run at a different resolution than the resolution of your desktop. Currently users are only able to override the refresh rate for DirectX applications, a future driver release will allow users to override the refresh rate for OPEN GL applications as well
~ The Catalyst 02.4 driver also offers customer-setting options for formats supported by YPrPb monitors/TVs. Televisions are typically over scanned (i.e., the actual image goes marginally outside of the normal viewing area of the display). Selecting an Optimized Format will compensate for this over scanning, for the chosen format, and allow the entire desktop to fit the viewing area
Downloads
ATI Control Panel
Vesion: 6.13.10.3041
Filesize: 5.63MB
Windows XP/2K Driver
Vesion: 6.13.10.6200C
Filesize: 5.63MB
Windows ME/98 Driver
Vesion: 4.13.01.9069
Filesize: 6.36MB
WDM Capture Driver
Version: 6.13.10.6168 v1
File size: 3.40 MB
Breek je nek voorzichtig
We zijn niet veel te ver. Als je het topic had gelezen, had je geweten dat Pollewob heeft gezegd dat we vanaf dit topic doorgaan tot 1000 posts.The_PyroPath schreef op 15 November 2002 @ 07:28:
WIE KAN ER EVEN EEN NIEUW TOPIC MAKEN, WE ZIJN AL VEEEEEEEEEEEEEEEEL TE VER!!!!!!!!!
"If I have seen farther than others, it is because I was standing on the shoulder of giants." - Isaac Newton
gewoon simpele dood wel retail, Ati Radeon 8500, issie nou 250/250 of 275/275
Ja waar zijn ze gebleven, stelletje afvalligenThe_PyroPath schreef op 15 November 2002 @ 08:23:
naja daar zal ik dan nu even een traan om laten, want das echt een traditie waar ik waarde aan hecht. Beetje vreemd dat er nooit problemen van gemaakt zijn en dat dat nu ineens moet. Beetje jammer. En bovendien wordt het er niet overzichtelijker op. Maarja ik zal wel een van de weinige zijn die er zo over denkt. Los van edward zie ik toch weinig mensen meer van het begin dus zullen jullie er geen probleem van maken. Ik vind het heel jammer :(((
Niet op voorraad.
Ik kan dat (klote) videokaart nog niet eens overcloken. Heb ik meteen last van vast lopers. Ik zou dan wel eens willen weten hoe warm deze wordt
Working in the IT : "When you do things right, people won't be sure you've done anything at all"
Kamikaze, was dit succesvol bij jou? Ik heb namelijk PRECIES hetzelfde probleem met OpenGL. Heb de atioglxx.dl_ uit de 6193 driver op de hierbovenstaande manier uitgepakt en naar de System32 dir gekopieerd, daarbij de versie van de 6228 driver overschrijvende, maar er helemaal NIKS veranderd! Alle OpenGL games draaien nog steeds net zo klote. Als ik niet snel een oplossing hiervoor vind ga ik terug naar m'n laatste Restore Point en installeer ik de nieuwe 6200c drivers van ATI. Dan voorlopig nog maar ff geen DX9....KaMiKaZe schreef op 14 november 2002 @ 21:27:
woei ga zo ook DX9 RC0 en radeon dx 9.0 drivers erop pleuren en demotje draaien
/edit 2
de demos liepen perfect maar ik heb last van haperingen in vrijwel elke opengl game(2 seconde pauze)
ff uitzoeken waar dat probleem in zit want de doom III alpha loopt als een tiet op deze drivers.
/edit 3
schijnt dus een bug te zijn met opengl en dx9 in windowed mode () draait alles wel goed
op de manier op te lossen (atioglxx.dll van een ander driver versie pakken):
1). You need to unzip the atioglxx.dl_ to a path (i.e. Desktop).
2). Then you need to drop to a command line (Start, Run, cmd).
3). Switch to the directory where you put atioglxx.dl_
4). Type 'expand atioglxx.dl_ atioglxx.dll'
5). The file is now expanded and you can copy that file to C:\Windows\System32.
in powerstrip ging hij standaard op 230/185 staan (na scan) ???Vaagheit schreef op 15 November 2002 @ 09:38:
Ik heb hier een powercolor radeon 8500. T is een half-sized plankje (knap)
hmmz in rivatuner ook al ??? vaaaag, wat is dit??
kun je ook zoals bij nvidia coolbits een tweakpaneeltje krijgen?
Als je de mensen nou eerst eens de tijd geeft om jouw vraag te lezen en te reageren, ipv al na enkele minuten het topic omhoog te schoppen?
probeer radeonator of rage3dtweak ook is. Springen die ook omlaag dan kan je zelf een conclusie trekken (en dat is wsl dat ie niet lekker loopt, met zulke lage mhz-jes)
Dan zal er wel iets fout zitten of je hebt echt een trage!
zorg ook dat je zo min mogelijk appz in de background hebt draaienHaay schreef op 15 november 2002 @ 11:55:
en windowed mode helpt dus ook anders -> terug naar DX 8.2 + catalyst 6193
Humanity is acquiring all the right technology for all the wrong reasons.
same for me!The_PyroPath schreef op 15 november 2002 @ 08:23:
Nieuwe bezems vegen schoon.The_PyroPath schreef op 15 november 2002 @ 08:23:
Aan al het goede komt een end.
En meer van die toepasselijke spreekwoorden en gezegden
kheb ook al aardig wat radeons versleten
radeon 64,8500 en nu de 9700
als ik alles keurig uninstall (zoals op rade3d staat) en dan de drivers install dan 'ververst' het beeld heel langzaam. Als je dus scrollt dan gaat het scherm heel schokkerig naar beneden (terwijl de refreshrate gewoon 85hz is).
ik heb al geformateerd en win xp overnieuw geinstald
-Wat is nou de beste plank die ik kan kopen prijs/kwaliteit
-zijn er nog problemen met agp 8x moederborden zoals de eerste revisies van de 9700 ?
graag jullie mening hierover
bedankt
Hercules , ik heb totaal geen problemen met drivers en hij kan ook nog eens lekker OC`n 415/365 met wc en op lucht zeker 390/350. Deze kaart is van een massief koperen koeler voorzien en ook al memsinks. TOPPERtaz3d_nl schreef op 15 november 2002 @ 20:29:
ik ben van plan om volgende week tijdens de HCC dagen een radeon 9700 pro aan te schaffen, nou heb ik de radeon topic doorgelezen maar iedereen heeft een andere mening over het merk van de video kaart
bedankt
Oja 3Dmark score 19286, zit wel ook een lekker systeem achter.
De 9700 van Tyan is ook erg goed, heeft wel een bericht op T.net erover gestaan.taz3d_nl schreef op 15 november 2002 @ 20:29:
bedankt
moet ik rekening houden met een bepaald revisie nummer om geen probs te krijgen met een agp 8x moederbord ( gigabyte ga-7vaxp )
want dat is wel het laatste wat ik mezelf kan wensen na het investeren van ruim 400 euro
gewoon een normale kaart met alles het zelfde als de BBA versie.Verwijderd schreef op 15 November 2002 @ 21:31:
he die 9700 van Crucial is dat nou de snelste of is dat gewoon crap??
beter geheugenVerwijderd schreef op 15 november 2002 @ 21:31:
nee, niet waar. alle kaarten hebben 2,8ns(2,86....) mem( op de crucial zit gewoon samsung mem)
DX9Pre
http://www.microsoft.com/...160&area=search&ordinal=1
DX9 Catalyst
http://mirror.ati.com/products/pc/catalyst/dx9demos.html
Ik heb helaas geen Radeon meer in bedrijf om te testen..
als je eigenaar bent van een Radeon 8500 64MB 275/275 ?
Ben opzoek naar nieuwe drivers aangezien ik deze week even een format ga doen aangezien ik nieuwe Audigy en Via4in1 Drivers moet installeren.
Niks, want dat meuk is alleen voor kaarten bedoeld die dx9 aankunnen.Morph666 schreef op 16 november 2002 @ 00:46:
Wat zal er gaan gebeuren als je het onderstaande toepast,
hij start niet meer op?
hij geeft geen beeld meer?
wat versta jij onder niks?
je krijgt een error met iets over de "Sushi engine" waarin ze zijn gemaaktMorph666 schreef op 16 November 2002 @ 00:55:
er gebeurt niks?
Gamebak Look Behind you, a Three Headed Monkey!
Heb dus ook een 9700pro en een Asus A7V333 mobo.
Na install laatste drivers (6200c) staat bij display opties de AGP speed op UIT.
Voorheen stond deze dus aan en op 4x (vorige drivers). Snel schrijven (fastwrite) stond toen ook al uit en kon ik ook niet aan zetten(reageerde software gwoonweg niet op)
NU kan ik die settings wel veranderen maar na reboot staat alles weer uit.
In de bios (niets veranderd) staat alles AAN en AGP speed op 4x.
Is dit een driver bug soms? Draait die AGP nu wel of niet op 4x, hoe is dit te controleren buiten de ATI software om?
Ik heb de DX9 , de driver en de demo`s op een verse instal gezet en ik moet zeggen dat de demo`s er super uitzien.Wekkel schreef op 15 november 2002 @ 23:48:
Heeft er al iemand goede ervaringen met DX9 beta en die DX9 drivers van ATi?
DX9Pre
DX9 Catalyst
Maaaaaaar er is 1 probleem en misschien weet iemand de oplossing, 3Dmark2001 SE draait niet met DX9. Na het opstarten van 3Dmark krijg ik de melding dat er DX8.1 geinstalleerd moet worden, en vervolgens ben ik weer terug op een leeg bureaublad.
Komt omdat je een oudere versie van 3D Mark 2001 SE hebt. Op de site van Madonion kun je een patch downloaden om je versie van 3D Mark 2001 te upgraden naar build 330. Die draait wel met DX9 geinstalleerd.Maaaaaaar er is 1 probleem en misschien weet iemand de oplossing, 3Dmark2001 SE draait niet met DX9. Na het opstarten van 3Dmark krijg ik de melding dat er DX8.1 geinstalleerd moet worden, en vervolgens ben ik weer terug op een leeg bureaublad.
Want een normale/pro 8500 draait op 275 en de ramdac op 400 MHz dacht ik?
FAQ Videoplanken & Beeldkanonnen (29/09/02)O.D.Smolik schreef op 16 November 2002 @ 10:07:
Ik heb gisteren mijn PoV Radeon 8500 binnen. Maar na testen blijkt dat core en memory op 250 MHz loopt en de ramdac op 350 MHz. Volgens mij heb ik nu gewoon een LE gekregen of niet?
Enne staar jeniet zo blind op die scores, de helft zijn cheaters, zware overklokkers, watergekoelde kaarten etc etc etc. Het gaat erom dat je games 10x beter lopen met deze kaart dan een gf4tixxxx+
direct3d natuurlijkBjk schreef op 16 november 2002 @ 13:05:
Maar is 3dmark nu direct 3d of opengl?
win/system32 nalopen op ati(oxxx)
Niet op voorraad.
beeld zag er niet uit op 6200c
Je moet de VIA 4in1 AGP-driver niet installeren, die zorgt voor de nodige problemen bij KT400 moederbords i.c.m. een radeon 9700 pro. En met ATI driver 6193 werkt alles prima.da_siren schreef op 15 November 2002 @ 01:58:
Hardstikke leuk maar ik heb een club3d ati radeon 9700 pro dvi tv out en een MSI kt4ULTRA en die combinatie werkt niet. In de nieuwe driver release notes reppen ze met geen woord over de infinite loop die je met zon combinatie krijgt. Ik ga morgen mijn asus a7m266 weer terug inbouwen. Als je dus een nieuw moederbordje gaat kopen en je hebt een 9700 koop GEEN MSI kt4ultra tot er een fix voor is.
De RAMDAC is adaptief, en veranderd zijn snelheid aan de hand van de resolutie en refreshrate. Het maximum is inderdaad gewoon 400, waarom en hoe dat overal op 350 geshowed wordt mag joost weten, maar niet op letten. ALLE radeon 8500 kaarten hebben een 400 MHz RAMDAC.O.D.Smolik schreef op 16 november 2002 @ 10:07:
Het enige wat een LE van een PRO/retail BBA verschilt is de 250/250 core/mem ipv 275/275 maar das met een simpele voltmod zo verholpen, potlood streepies neerkalken en gaan met die banaan.
met een mooit potlood streepje
nu had ik ff gezocht en vond ik deze guide/howto/etc: http://www.pcstats.com/articleview.cfm?articleID=953
maar wat is op het moment de beste cooler die ik kan kopen?
heeft iemand verder nog advizen
Sommige Le's hebben ook toch maar 1 ramdac ipv 2The_PyroPath schreef op 16 November 2002 @ 17:27:
edit/
Okeej de die PoV 8500 LE die ik nu heb, kan rond de 290.
Zal ik hem inruilen voor een normale 8500? Want eigenlijk heb ik geen zin opsturen enzo (heb namelijk een LE gekregen ipv een normale).
ennuh ik zou em terug sturen als je een normale had besteld, ik zou me niet laten 'naaien'
Op me GeForce4 heb ik dat niet.... helemaal niets, geen fouten.
Heeft iemand een oplossing? Ik heb de laatste 2.4 drivers al, op DirectX 8.2 (DX9 ook geprobeerd, maar helpt nix)
Zijn er misschien al patches voor?Verwijderd schreef op 16 November 2002 @ 23:54:
Ik heb ontiegelijk veel grafische fouten met Rainbow Six: Raven Shield (3)
vreemd bij mij draait ie smooth met de laaste drivers en directx 9Verwijderd schreef op 16 november 2002 @ 23:54:
MoH:AA draaide anders probleemloos op mijn vorige videokaart, een GF4 Ti4400...Verwijderd schreef op 17 November 2002 @ 01:32:
Het kan ook anders om, van de week MOHAA SpearHead geinstalleerd, deze draait geweldig en perfect op mijn Radeon9700 echter 2 kennissen van mij (1 heeft een GF4 ti4600 en de andere een GF2)hebben in dat zelfde spel witte vlakken erin. Dus met MOHAA SH heeft Nvidia blijkbaar weer een driver probleem!
Ik heb een Radeon 9700pro en het heeft wel gewerkt, vorige week nog, dat was met DirectX9 beta 3 en de 6193 drivers.
Nu heb ik DirectX 8.2 erop en Catalyst 2.4 drivers, maar hij doet het plots niet meer. Overigens deed ie het ook niet meer onder DirectX 9 RC0 met bijbehorende drivers.
Q: After "Hardware Acceleration" function is enabled, PowerDVD program cannot work normally. What can I do ?
A: If "Hardware Acceleration" is enabled, on some systems you might notice
subtitles in interesting colors. This is because the display driver
only supports an old format of Microsoft DirectX VA interface. It is
recommended that you install the latest driver from the original
card/chip maker in order for this function to work flawlessly.
Heeft er iemand een guide om een Radeon 9000 te voltmodden? Vind namelijk niet echt veel relevants.. thnx
Denon AVR-X2800H, Quadral Amun Mk.III, Technics SL-7, DIY PhonoPre, AT-152LP / 4.225kW Heckert Solar / SMA 3.0-1AV-41 / Kia e-Niro 64kWh First Edition
heb jij al een 9500.Evil_Homer schreef op 17 november 2002 @ 11:52:
Nu ffe de andere toer op:
wie heeft er al een 9700 non pro of 9500
Als je een redelijk goede processor hebt kun je het kwa performance het beste aanzetten, de functie ken ik niet.Bjk schreef op 17 november 2002 @ 14:02:
Ik heb een radeon 9700 kan ik bij smargart het beste fastwrites aan of uit zetten. En wat is de functie hiervan?
Ik schreef mohaa SPEAR HEAD (full versie niet demo)dus de uitbreidings van mohaa, niet mohaa zelf!!Wildfire schreef op 17 november 2002 @ 10:05:
Mohaa zelf werkt bij hun ook goed alleen de uitbreiding niet dus
Op een server waar spear head draait heb ik dit ook aan andere gamers gevraagt en wat bleek dat iedereen die een nvidia chipset had had deze witte blokken erin, alle gamers die een andere chipste hadden dit niet.
Met de Geforce 3 Ti 500 of Geforce 4 Ti 4200. Als direct X 9 uitkomt zal hij wel net wat sneller dan de Geforce 4 Ti 4200 zijn.T7D_Sneezy schreef op 17 November 2002 @ 19:09:
ik heb een vraagje, met welke GF4 is de ati 9000 ongeveer te vergelijken?? en is de 9000 is goede keuze?'
Of het een goede keuze is weet ik eigenlijk nog niet nu direct x 9 nog niet uit is, hij presteert op het moment in de meeste benchmarks lager dan de 8500 versie.
ja inderdaad, dit wil ik dus ook weten voordat ik volgend week op de hcc een 9700 pro aanschafcharrel schreef op 17 November 2002 @ 15:44:
Weet iemand of dit bord: asus a7v8x problemen op gaat leveren met een ati radeon9700 van hercules? Zit te denken om die aan te schaffen en erop te knallen. Maar het schijnt dat die ati niet zo goed samenwerkt met een kt400 chipset. Heb ooit is ergens gelezen dat de ati 9700kaarten vanaf revisie 1.03 dit wel goed doen. Waar kan ik op die vidkaart vinden welke revisie het is? En kan iemand dit verhaal bevestigen ...................uhhhhmmm liever dus juist niet bevestigen
iemand moet het toch weten of ooit ergens iets van gelezen hebben ?
vraag ik me toch af watvoor chip ze bij hercules op mijn kaartje hebben geplakt
Xabre 400 128 Mb, zelfde probleem met SpearheadVerwijderd schreef op 17 november 2002 @ 17:15:
Maar de 6100 versie is sneller in 3Dmark2001SE.
Maar in principe is zon 9000 dus een goede kaarT?Verwijderd schreef op 17 november 2002 @ 19:20:
Ik hecht weinig waarde aan 3dmark gebeurtenissen enzo,
ik wil gewoon op een leuke resolutie een spelletje kunnen spelen,
En hij moet een tijdje meegaan
Misschien klinkt dat wat negatief over de 9000 pro, het is wel een goede kaart, maar ik wil niet dat je straks hier komt en daarover gaat zeuren ofzo, dat zou kunnen en daar wil ik je voor behoeden
Ik zou als ik jou was even wachten op de 9500 (Pro), deze is een stuk sneller dan de 9000. en daarmee kun je nog wel even vooruit... ikzelf heb nu een Geforce 2 MX en ik wacht dus zelf ook op de 9500 Pro.. ik twijfelde ook tussen deze en een Ti4200 maar deze ondersteunt geen DirectX 9.... en met het oog op de toekomst zou de 9500 dan in het voordeel zijn....T7D_Sneezy schreef op 17 November 2002 @ 22:34:
hoelang gaat het nog duren dan voordat die er is?Canard schreef op 18 november 2002 @ 07:53:
Want ik moet zeer binnenkort een pc samenstellen, een Dell of een Sky, en nu zag ik dat er in die Dell een 9700 geleverd kan worden voor maar 170 euro meer (geen pro) dat leek me ook wel leuk, maar voor het geval het een sky word zal ik dus wat anders moeten doen.
Waarschijnlijk deze week of anders volgende week... zie ook Het Grote Radeon9500 Nieuws (en later ook ervaringen) TopicT7D_Sneezy schreef op 18 november 2002 @ 09:24:
1) installeren van via 4.43 driver
2)directx 9
3)nieuwe drivers van ati
links :
http://www.ati.com/products/pc/catalyst/dx9demos.html
http://downloads.viaarena.com/drivers/4in1/VIA_4in1_443v.zip
Alle games op max. settings werken nu probleemloos....
als ik in een spel de resolutie op 1280*1024 zet en op aply druk knalt ie em terug in de default resolutie, onegacht de huidige resolutie. eerst dacht ik "et zal wel aan et spel liggen", maar toen et in alle spellen gebeurde snapte ik er geen hol meer. Enige uitzondering is UT2k3 geloof ik(weet niet zeker meer, tijdje terug alweer), maar raven-shield hij heeft et probleem wel weer maar de et is de zelfde engine. rara hoe kan dit
en nog iets, ik speel veel raven shield, en die zou et toch retevet moeten doen op m'n systeempie, maar dat doet ie niet, en dan zeggen ze dat raven shield geoptimaliseerd is voor radeon9700. vrienden van me met met mindere systemen draaien beter(athlon xp1500+, gf3). ik moet zelfs alle antialising en antistrophic filtering uitzetten in ati control panel wil ik knappe frame rate krijgen op 1024*768 resolutie
sys specs:
AMD Athlon xp 1.8+@1533Mhz
512MB PC2700(eerst 1024MB, 2x 256 PC2100 1x512 PC2700, vanwege slechte framerate in Raven shield 512MB PC2100 eruit gehaald)
PBA club3d radeon 9700 pro128MB DDR
Ik heb de nieuwe DX9 driver geinstalleerd + directX9 en constant kreeg is vastlopers en Windows XP ging weer terug naar 8 kleuren ...
Met veel gezeik heb ik weer de oude drivers kunnen installeren en nu gaat het weer goed.
Iemand dit ook mee gemaakt??
doe ik nu ookCanard schreef op 18 November 2002 @ 07:53:
ik zelf heb nu een Geforce 2 MX en ik wacht dus zelf ook op de 9500 Pro
bedankt!
Leef lekker in het nu, er is niks anders
Ben van plan de nieuwste ATI drivers te installeren (die tenminste wel fatsoenlijk te de-installeren zijn) maar daarvoor wil ik eerst de oude zooi netjes verwijderen.
ff zoeken op het forum van http://www.rage3d.com Daar staat hoe je alles op de juiste wijze uninstalled en uit je register gooit.Verwijderd schreef op 19 november 2002 @ 19:03:
Heeft er iemand toevallig een beschrijving hoe ik oude radeon 8500 drivers kan verwijderen ? Heb nu nog (redelijk) oude : 6.13.10.1058 (3/31/2002).
-Download en installeer Regcleaner
-gebruik uninstall feature by software in het controlpanel/configuratie scherm
-reboot
-ga in veilige modus
-zoek op bestanden ati*.* in de mappen %root%\system en %root%\sytem32\inf en %root%\system32\inf\other verwijder deze allemaal
-run regcleaner, aangezien in veilige modus het icon verdwijnt van de desktop moet je het ff handmatig opstarten door naar programfiles te gaan en regcleaner mapje enzo
-verwijder alles wat maar te maken heeft met ATi, zowel met als titel dingetje ATi technologies en dingen met ATi erin in de unknown categorie
-als je die verwijderd hebt, kijk je nogmaals of je echt alles gehad hebt, hij wil ineens wel eens nieuwe keys vinden namelijk
-reboot
-install de nieuwe drivers
Als ik iets verkeerds gezegd heb corrigeer me AUB
Helaas zal het ook nog wel ff duren dat spellen dat gaan ondersteunen.
Zo gaan we nog ff genieten van de demo's
- tweakduke
- Registratie: December 2001
- Laatst online: 23:37
zekers doen ook al is het geen pro is die zekers nog snel zatT7D_Sneezy schreef op 18 November 2002 @ 09:24:
Thanks,The_PyroPath schreef op 19 November 2002 @ 19:45:
OK ff snel:
heb nu de 6.13.10.6200C (ATI) drivers voor mijn radeon 8500 geinstalleerd en loopt zo te zien goed (ben nog aan het benchmarken
geen problemen hierFireFoz schreef op 19 November 2002 @ 18:57:
Is er hier iemand met een radeo 9700 bba en een asus a7v8x moederbord? Ik ben namelijk van plan deze aan te schaffen maar aangezien sommige mensen helemaal geen problemen hebben met deze kaart, en andere wel, zou ik graag willen weten hoe dit moederbord met deze kaart omgaat. Met mijn huidige moederbord draaid namelijk maar 1/3 spellen zonder dat mn systeem steeds vast zit(alles al geprobeerd, reinstall, 892794923 drivers, 4in1 etc etc.) Ik wil er een AMD XP 2700 bij zetten en 2x256 DDR pc3200.
bedankt!
bba r9700 op 8x agp fastwrite aan dat alles in een a7v8x rev 1.03 met 333mhz sticker.
