SP7100M4 Features - GeFORCE4 MX440
  • 50 views sinds 30-01-2008
Ik was van plan de volgende videokaart: SP7100M4 - GeFORCE4 MX440 bij Alternate.nl te kopen. Mijn vraag is: is dit een goede prijs en is het een redelijke kaart voor die prijs. En weet iemand of S-video gewoon tv-out is, zodat ik deze aan mijn tv kan koppelen.
Hier zijn de specs:
Key Features
nView - Empowers the user with maximum flexibility in display options and control
NVIDIA Lightspeed Memory ArchitecutreTM II -Increases memory bandwidth efficiency for unmatched performance
NVIDIA AccuviewTM Antialiasing -Delivers unbeatable visual quality and frame rates
NVIDIA Video Processing Engine -Enable the highest-quality, full-frame rate, full screen HDTV and DVD without requiring a high performance CPU.
Most integrated GPU -Delivers unprecedented features to the mainstream
Integrated TV encoder -Provides best-in-class TV-out functionality supporting 1024x768 resolution
2 dual-rendering pipelines
DirectXR and S3TCR texture compression
4 texels per clock cycle
32-bit color with 32-bit Z/stencil buffer
Cube environment mapping
64MB high-speed 128-bit DDR memory
High-performance 2D rendering engine
AGP 4X with Fast Writes
NVIDIA Shading Rasterizer
AGP 4X/2X and AGP Texturing Support
Integrated hardware transform engine
Integrated hardware lighting engine
High-quality HDTV/DVD playback
True, reflective bump mapping
Multibuffering (double, triple, quad) for smooth animation and video playback
Operating System
NVIDIA Unified Driver Architecture (UDA)
Microsoft DirectX optimizations and support
Drivers support Windows XP, Windows 2000, Windows ME and Windows 98
Linux Compatible
OpenGL 1.3 and lower
DirectX 8.1 and lower
Miscellaneous
Output connectors: one DSUB15 , one S-Video and one DVI
Board size: 175 mm x 97 mm
Hier zijn nog twee links:
http://alternate.nl/html/nodes_info/j8gk25.html
en
http://www.sparkle-techno...oduct/nvidia/sp7100m4.htm
Alvast bedankt!
  • NiGeLaToR
  • Laatst online: 11-09 13:46
NiGeLaToR
Luister Kophi Podcast!
Tis vast een goede kaart.. maar als ik heel eerlijk ben zou een Ti4200 waarschijnlijk meer levensvreugde brengen. Anderzijds kost die wel meer. Ook is een Ati R8500 wellicht een idee?
Verder.. tjah.. lijkt me nix mis mee.. gewoon een doorsnee videokaart :)
Maakt reviews bij IOTDomotica.nl . Podcast bij Kophi: ook op YT.
  • Carel
  • Laatst online: 06-09 16:30
Wat voor pc specs heb je carlmeijer ? , das ook wel handig om te weten ..
Tis momenteel gewoon een goede budget kaart, maar als je toch rdedelijk spellen gek bent of toch een vrij snel systeem hebt zou ik iid een Ti4200 nemen of hoger.
Specs van mijn pc:
Win 98 se
Moederbord: Pc 266 Socket A M810
950 mhz amd duron
128 sd-ram + 256 sd-ram (100 mhz)
Seagate 40 gb / ibm 60 gb
Ja wat moet ik verder nog vertellen? Veel dingen zijn onboard op mijn moederbord.
Als je nog wat wil weten, zeg het dan maar.
Nou ik wil eigenlijk niet zoveel betalen en veel spellen speel ik eigenlijk ook niet. 90 euro vind ik eigenlijk al te veel maar kan nog net.
  • Carel
Verwijderd schreef op 03 oktober 2002 @ 14:17:
Hmm ok, dan is die mx440 iid perfect voor jou :)
Weet iemand ook nog wat s-video is?
  • Carel
Verwijderd schreef op 03 oktober 2002 @ 14:37:
Aansluiting voor bijvoorbeeld je tv , waarvan je de s-video(out) naar scart of eerst nog tulp daartussen kan aansluiten op je tv of iets in die buurt.
Maar zulke vragen hoef je niet te stellen want zoiets kan je wel terugvinden in de faq of search :)
  • Pollewob
Welke videokaart moet ik kopen.
En voor vragen zoals
kan je hier of hier terecht :)
