Epox 8K9A3+ (KT400) Moederbord
  • 201 views sinds 30-01-2008
Whoei nieuwe epox bordje :9
Afbeeldingslocatie: http://www.tbreak.com/forums/attachment.php?s=e691cfa19d7c10f3f60704b706f7360c&postid=105006
Spec's
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2200+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT400 AGPset (KT400+ VT8235)
DRAM MODULE:
184pin DDR DIMM x 4 for PC2700 Memory
DRAM Size: 64MB to 4GB
EXPANSION SLOT
PCI x 6 8x AGP x 1
ONBOARD I/O
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
Extra dual channel IDE Port by HPT374 with Ultra DMA-133 & IDE RAID x 4 (Up to 8 Devices)
-Supports JBOD function (Just Bunch One-Disk)
Onboard LAN(By VIA VT6103):
Integrated 10/100MB fast Ethernet controller in chipset with external VIA VT6103 physical Layer by RJ-45 connector
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
Supports USB2.0 specification
USB connector x 6 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (By RealTek ALC650):
Compliant with AC97 2.2 specification
6 channel slot slectable DAC output for multi-channel applications
Supports digital SPDIF
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports STR (Suspend To RAM) power saving Function
Supports CPU Vcore setting via BIOS
Supports CPU Clock setting via BIOS
Supports CPU Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports Wake-On-LAN Function
Post port onboard design with LED display
FORM FACTOR:
305mm x 245mm x 40mm ATX Size
  • knights16
  • Laatst online: 06-09 21:45
chopchop!!!!!!!!!! :)
mijn 8k3a bavalt al fantastisch, dan weet ik zeker dat degene die deze 8k9a3+ gaan kopen helemaal tevreden zullen wezen,
ziet er goed uit..
PVoutput
  • ko9
  • Laatst online: 20:44
ko9
weet je ook wanneer we die ongeveer kunnen gaan kopen? :P
Ben wel benieuwd namelijk
  • knights16
denk dat dat nog wel een maand of 3 duurt.
PVoutput
Heb ik dat nou goed dat er 12 ide devices op kunnen aangesloten worden :S, maar ik mis de gaten rond de socket een beetje, misschien die gene die willen waterkoelen ook wel, of heb ik dat weer eens fout :S don`t be mad if i am
euh, ik zie wel degelijk gaten rond de socket hoor ! 8)
Verwijderd schreef op 20 augustus 2002 @ 18:35:
ik ben er van overtuigt dat jij gaten ziet zitten maar nie van die gaten waar je een heatsink op kunt monteren. Maar ik begrijp wat je bedoelt
  • Convoy
  • Laatst online: 14:16
Convoy
g44p
Verwijderd schreef op 20 augustus 2002 @ 22:39:
nou dan ben je of blind, of er zitten gewoon 2 gaten in jou kop zonder ogen erin :? :? want ze zitten er dus wel :)
Afbeeldingslocatie: http://home-3.tiscali.nl/~freekweb/ep-8k9a3+.jpg
LOL, je moet maar eens wat meer moederborden bekijken :P
Dat zijn wel degelijk gaten om je koelblok erop te schroeven, je moet er alleen van die rubberringetjes om doen, van wege statische elek.. . Jij denkt dat die gaten niet goed zijn omdat er niet zo'n grijs/zilver randje omheen zit of niet :?
  • SmokeyTheBandit
  • Laatst online: 17-06 10:20
SmokeyTheBandit
DOCer met Pensioen
zozo dit ziet er goed uit :)
Alleen is de pic een beetje groot :P
Turn it off and on again.
  • knights16
het blijft maar een jpg ;)
PVoutput
  • sarlo
  • Laatst online: 28-08 10:50
maareh ondersteund geen serial ata zover ik kan zien
Verwijderd schreef op 20 augustus 2002 @ 23:09:
Nee sorry ik had ze echt nie gezien, en wat die zilvere shit betreft thanks weet ik dat ookweer, ik moest zowieso al naar de opticien voor nieuwe glazen doen we meteen ff.
Mzzl
  • TDLofCC
  • Laatst online: 23-06 09:27
Toch maar even wachten op de Abit ...
Die heeft iig een active koeling op de Northbridge :)
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/KD7_pic6.jpg
Enige jammere is dat ik weer iemand moet zoeken die de votlmod voor mij wil doen ;)
Heb nu ook Epox, zeer tevreden mee, maar heb toch gemerkt dat Abit Heeeeeeeeerscht. >:)
Hell hath no fury like a freshly circumcised sleep deprived grizzly bear on amphetamines, being assaulted(aurally and otherwise) by George Bush dressed as a clown and singing vile covers of crap songs and wielding an electric cattle prod.
  • Fanatic_FS
  • Laatst online: 07:23
damn vet bordje die epox, alleen als je daar 12 ide devices aan gaat hangen krijg je toch een hendige kabel bende >:)
Kan ook dit bord nog steeds geen DDR400 ondersteunen? Ik zie alleen pc2700 staan :|
Ach ja het blijft dezelfde VIA chip...
Maar verder ruleert het bord wel ja!
  • gabberjoost
  • Laatst online: 12:13
Ondersteund die Epox mobo nou ook een divider om je cpu (133DDR) op 166DDR te laten draaien terwijl je PCI nog gewoon op 33 loopt?
divider 1/5? :?
  • hoevenpe
  • Laatst online: 19:41
3 maanden voordat ie uitkomt??? Kan mij het niet voorstellen of zijn er hier mensen die inside informatie hebben? :)
  • Fanatic_FS
hoevenpe schreef op 22 augustus 2002 @ 13:49:
GoT heeft overal ter wereld connecties, dus het verbaasd me niks :)
  • hoevenpe
Hmmm.... valt me nog mee dat we niet onder elke reply van de overheid een waarschuwing moeten krijgen... :)
* GoT schaadt je prive-leven, het kan ruzie met je partner en/of *
* veel verloren uren/sudiepunten tot gevolg hebben... *
  • SlowikPL
  • Laatst online: 18-08 14:37
Is Epox goede merk, heb wel Soltek SL75-DRV2 (opgeblazen ,klote bord!!), Gigabyte GA-7VRXP (beste wat te koop is alleen geen ondersteuning voor GF4 voor ver.2.0) , nu een MSI KT3-Ultra2( goed maar niet ales goed in orde zoals zie hier ---> [rml][ MSI KT3 Ultra2][/rml]last
Nu word tijd op ABIT en EPOX ;)
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • Fanatic_FS
SlowikPL schreef op 22 augustus 2002 @ 14:59:
Epox is een heel goed merk, ook zeer goed voor overclocken (en wat maybe handig is i.v.m. garantie, hun hoofdkantoor ligt in nederland)
  • SlowikPL
Ik heb tot nu toe geen Epox bord gehad en ben bang voor onangename verasingen.
Ik heb nu de mijne MSI KT3 Ulotra2-R verkocht en zit nu7 te wachten op een KT400
dat worden :
1. EPoX 8K9A3+ KT400 Board of
2. Gigabyte GA-7VAXP KT400 of
3. ASUS Asus A7V8X KT400
Wat zou de beste zijn?
Bij de voorganger van Gigabyte 7VRXP heb ik problemen gehad met mijn GeForce 4 maar was wel een super boordje!!
De ASUS is zeer bekende merk en bakt altijd compromisloze borden.
En de Epox weet niet...
IK overklok veel met mijn waterkoeling!!!
Nu koop ik een Raedon 9700 Pro.!!
PS;
Wel kote bevesteging van de chipset coler!!! :(
daaraan kun je geen andere cooler vervangen!
  • SlowikPL
Ik wacht wel even tot de moderborden worden vergelijkt met aalkaar in de test.
HIGHPOINT CONTROLLERS ZIJN BOUT! DUS VOOR MIJ GEEEN EPOX OF ABIT.
EPOX ZIET ER VERDER WEL GOED UIT
Verwijderd schreef op 24 augustus 2002 @ 01:20:
Onderbouw eerst die mening eerst eens voordat je zo dom gaat lopen blaten en we zijn niet DOOF! :r
  • SlowikPL
Ik dacht het ook zo maar na langere kijk op de onboardcontrolers zoals Promise , Adaptec en Highpoint mijn besluit luid:
Promise goede reclame en verder niets!!!
Highpoint wel betere ondersteuning in drivers ARAy 0+1 mogelijk !!!
Adaptec :?
  • SlowikPL
SlowikPL schreef op 23 augustus 2002 @ 13:11:
dat worden :
PS;
en natuurlijk komt ook de NForce2 die volgens nVidia 20% beter gaat scoren dan de KT400 :?
Maar dat zeiden ze wel vaker :+
  • Mary Wana
  • Laatst online: 28-07 22:43
Mary Wana
keyboard nut
Ziet er lekker uit :) heb nog steeds mijn Epox 8KHA bordje ( KT266) doe tut nog prima :) Ben niet zo een upgrade freak meer :) mijn systeem voldoet nu nog wel eventjes :) Spellen lopen perfect windhoos naja blijft windhoos :P Mischien dat ik ooit in de toekomst wel een nieuwe bak wil bouwen datk dan deze bordje neem , maar ik denk het haast niet tegen die tijd ister ook alweer wat beters :)
XP2600+ @ 2500mhz 1024mb Twinmos PC2700 @ CS2 WD1800JB Plextor 40x CDRW Ti 4600 ULTRA
  • SlowikPL
Nu na de eerste test van ASUS ASUS Asus A7V8X KT400 en de Gigabyte GA-7VAXP KT400 wint wel de ASUS voor mij.
http://www.ocworkbench.com/2002/gigabyte/7vaxp/7vaxpp1.htm
http://www.ocworkbench.com/2002/asus/a7v8x/a7v8xp1.htm
Nu moet kommen een test van de EPoX 8K9A3+ (weet iemand een test)
  • Chakotay
  • Laatst online: 15:30
Chakotay
Lick here to continue
Bordje ziet er erg goed uit, ze hadden wat van die gigantische overkill aan IDE aansluitingen alleen wel kunnen vervangen door een paar SATA150 poortjes :)
(EPoX 8KHA+ (KT266A) hier nu, bevalt nog steeds goed)
Stichting eth0
SlowikPL schreef op 24 augustus 2002 @ 17:43:
Gewoon die Asus nemen, dan heb je zekerheid en stabiliteit. Behalve als je zo'n overklokker bent die de FSB op 193MHz wil zetten.
  • SlowikPL
Ik heb een goede waterkoeling deus de moderbord moet wel wat bieden in overklokken.Ik wacht wel even af hoe de Epox gaat presenteren in vergelijk met de ASUS.Ik vind wel de Epox zeer goed uitziet maar ken deze merk niet deus :?
De raid 4 kanaal heb ik wel nodig 6x HD`s + CD-Rom + DVD-room + Brander :)
  • SmokeyTheBandit
SmokeyTheBandit
DOCer met Pensioen
SlowikPL schreef op 24 augustus 2002 @ 23:21:
Ehmmm waarom staat de Abit niet tussen je keuzes :?
Abit is en blijft het beste tweakbare en hoogste presaties mobo merk.
Maar das alleen voor de mensen die net ff wat meer willen investeren.
I rest my case :)
  • SlowikPL
Nooit een ABIT boord gehad en ik hou niet van onangename verasingen zoals bij Soltek SL-75DRV2 :( :( :( maar ik zit wel naar te kijken.Wel even geschrokken als het op de nieuws was dat ABIT in de moderborden en slechte kwaliteit van resistoren en werstanden verwerkt heeft :? jammer
Ik kom na de tests wel tot conclusie dat de Souhbrige de VT8235 slechte preformance heeft in disk winmarks te opzichte van de VT8233 :? dat merkte ik wel direct na visselen van de moderborden van Gigabyte GA-7VRXP naar de MSI KT3-Ultra2-R (verscil was volgens mij enorm!!!! :(
maar als je hier kijkt dan is het wel goed http://www.hardtecs4u.com/reviews/2002/epox_8k5a3plus/ zelfs beter dan een KT400 moderbord van ASUS !!
weet iemand wat van een opvolger van de VT8235? VT8235A :?
  • SlowikPL
Ik heb in Deutsland gevraagd waneer de moderbord te koop was en ze hebben me gezegd dat men niet op eine September kan erop rekkenen!! Deus met andere worden begin van Oktober!!! :)
  • erikdeperik
  • Laatst online: 25-07-2024
Dat zijn wel degelijk gaten om je koelblok erop te schroeven, je moet er alleen van die rubberringetjes om doen,:?
soldier spreekt uit ervaring 8)7
ont/gaaf boardje ,en er zit erg veel op(iemand nog een netwerkkaartje kopen :+ )
ik zeg maar zo "zeg maar niks"
  • erikdeperik
gabberjoost schreef op 22 augustus 2002 @ 13:40:
divider 1/5? :?
d8 het wel want de 8k3a+ ondersteund het al.
als je boven de 167fsb komt schakelt hij auto naar 1/5(33)pci2/5agp(66)
super boardje om over te klokken zie sig
ik hoop eigenlijk ook op een 1/6 divider
erikdeprik schreef op 25 augustus 2002 @ 10:27:
ROLF weet je dat nog :D :D
  • SlowikPL
waarom zit op deze bord geen VT8235A southbrige ?
  • SlowikPL
waarom zit op deze bord geen VT8235A southbrige ? en wat is de verschil tussen de VT8235 en VT8235A :? S-ATA ?
  • ProgrammerX
  • Laatst online: 26-02-2021
Wat ik me nu dus afvraag is dat als ik nu toch besluit een moederbord met deze chipset te kopen in combinatie met DDR400 of ik dan geen problemen heb als ik het moederbord zet op DDR333 en of ik dezelfde performance heb als DDR333.
Ik hoop namelijk dat men met behulp van BIOS updates DDR400 wel stabiel en snel krijgt :) Is dit mogelijk in de toekomst of zeggen jullie van niet doen ???
Wil namelijk een graag een moederbord met 8x AGP en DDR400 in combinatie met de Radeon 9700, maar de moederborden met deze features (SIS 648 en VIAKT400) zijn nogal moeilijk te krijgen heb ik gezien :'(
Greetz ProgrammerX
  • SlowikPL
Eind September begin Oktober.
Best Regards,
Michael (FAE Team)
EPoX Europe Computer B.V
E-mail : support@epox.nl
Web : www.epox.nl
>>IMPORTANT!<<
Please provide previous E-mail text if replying!
INFORMATION STATEMENT:
This E-mail is confidential and you can not copy the information
in this E-mail or use it for any purpose or disclose its contents
to any other person. Publication in writing, or in any other printed
matter, is not allowed without the proper consent of the author.
All our mails are tested against viruses with the latest virus definitions.
-----Original Message-----
Sent: Tuesday, August 27, 2002 2:34 PM
To: support@epox.nl
Subject: 8K9A3+ (VIA-KT400)
8K9A3+ (VIA-KT400)
Wanneer komt de in de winkels?
Wenn sei es vorhandenes werden Sie ?
When will it be available ?
greatings
Slowik
  • SlowikPL
Best laat , maar dan zonder bug`s :)
Ik hwb nu een bord nodig om mijn Raedon 9700 te testen :(
  • erikdeperik
oftopic / ik heet erik.....aangenaam _/-\o_
  • SlowikPL
Wat zou jij kiezen?
Ik sta nu een keus te maken tussen Epox 8K9A3+ en de Abit Abit-MAX2. Wat zou jij doen?
Ik heb net een MSI KT3-Ultra2-R verkocht wegens ontevredenheid.Slechte IDE en overklok performance.Ik zoek een ultiem bord voor mijn toekomstige XP-2700+ (FSB333) en Gigabyte MAYA-II-GV-R9700-PRO en PC3200 Corsair Platinum C2?
1te. keus
Levertijd in Nederland WK37/38 Info http://www.tweakers.net/pricewatch/35927
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/AT7-MAX2_pic6.jpg
Spec`s
PROCESSOR
Supports AMD-K7 Athlon / Athlon XP Socket A 200/266MHz FSB Processors
Supports AMD-K7 Duron Socket A 200 MHz FSB Processors
Chipset
VIA KT400 / VT8235
Supports Hi-Speed UniversaSeriaBus (USB 2.0)
Supports Advanced Configuration and Power Management Interface (ACPI)
Accelerated Graphics Port connector supports AGP 4X/8X (1.5V/0.8V)
Memory
Four 184-pin DIMM sockets
Supports 2 DIMM DDR 333/400 (Max. 2GB)
Supports 3 DIMM Un-buffered DDR 200/266 (Max. 3GB)
Supports 4 DIMM Registered DDR 200/266 (Max. 3.5GB)
SeriaATA
On board Marvel88i8030 Controller x 2
Support SATA data transfer rates 150 MB/s (1.5G bps)
RAID
High Point HPT374 IDE RAID Controller supports Ultra DMA 33/66/100/133
RAID 0/1/0+1(striping + mirroring mode for boosting performance and data security)
Audio
6-ChanneAC 97 CODEC on board
Professional digital audio interface supports 24-bit S/PDIF Out
Media XP (Optional)
Supports card reader function for Memory Stick™, Secure Digital™ and Type I/II CompactFlash™
Supports Wireless Remote Control and S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
System BIOS
SoftMenu™ Technology to set CPU parameters
Supports Plug-and-Play (PNP)
Supports Advanced Configuration Power Interface (ACPI)
Supports Desktop Management Interface (DMI)
Write-Protect Anti-Virus function by AWARD BIOS
LAN
On board 10/100Mb Operation supports ACPI & Wake on LAN
IEEE 1394
Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
InternaI/O Connectors
1 x AGP, 5 x PCI slots
Floppy Port supports up to 2.88MB
4 x Ultra DMA 33/66/100/133 Connectors
2 x SeriaATA 150 Connectors
2 x USB headers, 1 x IEEE 1394a header
1 x CD-IN, 1 x AUX-IN
Back PaneI/O
1 x PS/2 Keyboard, 1 x PS/2 mouse
4 x USB, 2 x IEEE 1394
1 x S/PDIF Output
Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
2 x USB, 1 x RJ-45 LAN Connector
Miscellaneous
ATX form factor
Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
2de. keus
Levertijd Nederland WK 40/41 Info:Epox Nederland
Epox 8K9A3+
Spec's
PROCESSOR:
CHIPSET:
DRAM MODULE:
EXPANSION SLOT
PCI x 6 8x AGP x 1
ONBOARD I/O
ONBOARD PCI / IDE:
I/O CONNECTOR:
USB:
BIOS:
EXTENDED FUNCTION:
FORM FACTOR:
  • biertje-blijf-bij-me
  • Laatst online: 04-03-2025
ik zie dat ie alleen tot 2200+ ondersteuning heeft......strange....
  • SlowikPL
want er was toen alleen de 2200+ :)
SlowikPL schreef op 29 augustus 2002 @ 21:16:
Eerste keuze, natuurlijk, Abit. NOFI, maar je zou wel gek zijn als je de tweede zou nemen.
  • SlowikPL
Waarom , de Epox ziet er ook goed uit :?
  • M v Akkeren
  • Laatst online: 19-08 15:12
SlowikPL schreef op 29 augustus 2002 @ 23:00:
AT7 max2 ondersteund ook serial ata..., heeft een veel luxere uitrusting, en abit staat er om bekend dat hun boardjes beter overclocken als Epoxjes. Lijkt mij reden genoeg om voor de Abit te gaan. Maarja wie ben ik. ;)
  • SlowikPL
Nu zie ik op je spec. dat je een Epox hebt :? deus je weet waarvan je spreekt nem ik aan.
Ik heb noch nooit een Abit of Epox bord gehad, wel Asus P3B-F (superbord gebruik tot nu toe!),MSI KT3-Ultra2-R(niet fijn is afsteling en overklokking maar een maal lopen altijd lopen,),Gigabyte GA-7VRXP fijne bord maar jammer van de incomtabiliteit met de GeForce 4,SoltekSL-75DRV2 (Gekocht vegens zeer goede review op toms hardeware kon geen 1Mhz meer overklokken verder liep die matig)
Deus zoals je ziet wel wat gehad maar geen goede behalve +/-6 jaar geleden de ASUS :(
Ik heb wel aantaal dingen gelezen hier en daar en kom wel tot conclusie dat er nooit slechte word werd niet gezegd naar ABIT(wel behalve dat tijdje treug was gezegd dat er slechte resistoren werden verwerkt in hun borden).Ik kan nie veel wachten want mijn Raedon 9700 komt zo en op de ASUS P3B-F kan hem niet hebbeb (AGP2) ;) deus Abit is mijn keuze voor de eerste keer :)
Ik hoop dat ik geen spijt van krijg :)
  • TDLofCC
Op de Icrontic Forums(http://www.icronticfoums.com)
Staat niet voor niets een sticky topic dat Abit KR7A new OC King ...
Ik wil ook die Abit KD7 ... hoop dat het een beetje goed bord wordt vanaf het begin al ... Only Time Will Tell :)
  • erikdeperik
biertje-blijf-bij-me schreef op 29 augustus 2002 @ 21:14:
dat word wel opgelost met een bios
  • Rendier2710
  • Laatst online: 15:54
Sorry, hier stond iets stoms......
Maar ik wacht wel op MSI _/-\o_
Rendier2710 schreef op 01 september 2002 @ 21:24:
Hangt je Caps Lokkie?
Ik wacht op het bordje van MSI! _/-\o_
Inderdaad. MSI is _/-\o_
  • SlowikPL
Hmmmmm.....
Mijn eerste MSI KT3 Ultra2-R was shit :(
SlowikPL schreef op 02 september 2002 @ 16:46:
Hmmmmm.....
Ach, wat jammer nou. Stuur hem toch terug naar MSI.
  • nero355
  • Laatst online: 10-07 17:18
nero355
ph34r my [WCG] Cows :P
Hier stond iets doms laat maar!!
  • SlowikPL
Verwijderd schreef op 02 september 2002 @ 17:09:
Dat was niet een kapotte bord maar een slecht ontwerp!!! kijk boven!
SlowikPL schreef op 02 september 2002 @ 17:26:
Aha. Je hebt tot nu toe verstandige keuzes gemaakt bij het kopen van moederborden, en hou het ook zo.
Zit epox niet af te kraken!! Daar heb ik deze topic niet voor gestart !
  • lordofthelints
  • Laatst online: 15-09-2025
lordofthelints
Evil_ivanhoe in former GoTlife
Is de asus nou de enige met gigabit lan onboard? Ik zie bij de andere borden alleen 10/100. Voor mij een reden om de asus te overwegen...
Moederborden..... Kunnen die in de afwasmachine??? || Specs, zie: http://specs.tweak.to/list/2481
Verwijderd schreef op 03 september 2002 @ 09:42:
Waar slaat dit op? Hieruit blijkt dat je niet nadenkt voordat je dingen zegt.
  • Chadi
  • Laatst online: 24-06 16:47
Nos steeds niet te koop :D en ik vraag me af of ie wel ooit in de winkel komt....
  • Ankh
  • Registratie: Mei 2001
  • Laatst online: 15:43
Ankh
.Howdy
Chadi schreef op 03 september 2002 @ 16:02:
er stond EIND september niet begin september DOH :P
  • SlowikPL
Epox 8K9A3+ Levertijd Nederland WK 40/41 Info:Epox Nederland
ABIT AT7-MAX2Levertijd in Nederland WK37/38 Info http://www.tweakers.net/pricewatch/35927
Ik wacht wel even op de reviews van de beide borden. :)
  • Emcee
  • Laatst online: 10-09 21:40
welke week zaten we nu ook alweer 36 toch?
  • SlowikPL
ja!
Ik heb net sinds zaterdag de nieuwe Asus AV78X en tot nu toe zeer tevreden
(enkel nog maar wat install gedaan nog geen overclocking ofzo)
  • Tinman
  • Laatst online: 08-09 19:50
heeft al iemand een prijs indicatie van dit nieuwe Epox KT400 mobo ??
  • SlowikPL
Je moet er noch even wachten tot de VIA KT400A komt.Dat zaal niet langer duren dan 2 mnd.
http://www.a1-electronics...DR/Via_KT400chipset.shtml
http://www.flickerdown.com/phpBB2/viewtopic.php?t=1497
hoevenpe schreef op 22 augustus 2002 @ 13:58:
LOL :P :9 Die is eigenlijk best leuk als sig... :)
  • SlowikPL
Angezien dat de KT400 niet naar (niet aleen) mijn verwachtingen voldoet gaa ik voor Epox 8K5A3+.Wel jammer want ik krijg binnenkort een Raedon 9700 en die ondersteunt AGP 8X in tegenstelling van de Epox 8K5A3+.Dat zaal denk ik niet veel uitmaken gezien de reviews tussen AGP 4X snelcheid en de oudere AGP 2x.
Wat denk je is dat goede keus?? Om een goed geteste en zeerkerde moderbord te kiezen ipv. een nieuwe niet al te goede ??
  • SlowikPL
De Epox 8K9A3+ met de VIA KT400A ipv. KT400 ????
Whoei ik heb gister nieuwe Epox gezien in Utrecht super vet ding man!! Stond alleen achter glas :(
Ik heb btw de Radeon 9700 ook gezien bij hercules en bij Gigabyte ook super vet.
