Battlefield 1942 demo eindelijk uit
Pagina: 1 2 ... 11 Laatste
  • 5.563 views sinds 30-01-2008
  • ravw
  • Laatst online: 06:35
Geen matches
Hij is uit de SP demo
[url="http://www.gamers.nl/nieuws/13909"]http://www.gamers.nl/nieuws/13909[/url]
Battlefield 1942(tm) Single player Demo 1.0
Read Me File
June 18, 2002
THIS DEMO IS NOT TO BE USED FOR REVIEW PURPOSE SINCE IT'S STILL UNDER DEVELOPMENT!
Thank you for obtaining the Battlefield 1942 demo. This readme file contains information that will help you fully enjoy this demo.
Installation Instructions
To install the Battlefield 1942 demo:
1) Browse to the BF1942 folder after unzipping bf1942_sp_demo.zip.
2) Double mouse-click "Setup.exe".
3) Follow the instructions that appear to install the demo.
System Requirements
Minimum:
800 MHz CPU
256 Megabytes of RAM
3D accelerated GeForce 32 MB or equivalent with HTL
(Hardware Transform & Lightning) and 24-bit z-buffer
400 MB of free hard drive space
16X Speed CD-ROM/DVD-ROM
MS compatible mouse
DirectX 8 Compatible Sound Card
Required Operating Systems:
Windows 98, Windows ME, Windows XP or Windows 2000. Note that Windows 95 is not supported.
GeForce compatible cards will be supported and should work. If you do have such a card and experience problems please report type of card and drivers used.
These are known to have issues:
3dfx Voodoo 5 5500 AGP 64MB 3dfx Voodoo 5
3dfx Voodoo 5 5500 PCI 64MB 3dfx Voodoo 5
ATI Radeon AGP 64MB ATI Radeon
ATI Radeon AGP 32MB ATI Radeon
ATI Radeon 7500 AGP 64MB ATI Radeon 7500
Matrox Millennium G450 AGP 32MB Matrox G450
Matrox Millennium G550 AGP 32MB Matrox G550
S3 Savage 2000 AGP 32MB S3 Savage 2000
SiS 315 AGP 32MB SiS 315
Trident Blade XP AGP 32MB Trident Blade T64
Cards that are not GeForce compatible will not be supported!
Installing DirectX 8.1
Make sure that you have DirectX 8.1 installed on your system. Latest version of DirectX can be downloaded from:
[url="http://www.microsoft.com/directx/"]http://www.microsoft.com/directx/[/url], previous versions of DirectX are not fully supported.
IK zal zo ff wat foto's plaatsen
Systeem:AMD Ryzen 7 9800X3D ,RTX 5080 OC,FURY 64 GB DDR5-6000,ASUS TUF Gaming B850M-PLUS WIFI, SAMSUNG 990 EVO Plus 4 TB
  • Firestone
  • Laatst online: 29-05-2025
Firestone
$ su - vuursteen
Geen matches
ben al bezig met dl :)
  • SouLmaN
  • Laatst online: 14-10 16:47
Geen matches
Wie niet ? Alleen jammer dat er geen multiplayer leveltje bijzit :(
Geen matches
Is dit de gelekte? met dat zand level?
Geen matches
Deze heeft idd Tobruk als enige level, maar of het dezelfdee versie is als de Beta ga ik nu testen... hopelijk zijn de bugs eruit :)
  • Mary Wana
  • Laatst online: 28-07 22:43
Mary Wana
keyboard nut
Geen matches
Jammer dat het alleen Sp is :(
XP2600+ @ 2500mhz 1024mb Twinmos PC2700 @ CS2 WD1800JB Plextor 40x CDRW Ti 4600 ULTRA
Geen matches
  • greatgonzo
  • Laatst online: 14-10 23:49
greatgonzo
schit-te-rend!
Geen matches
Op zaterdag 20 juli 2002 10:59 schreef Metal-Kool4 het volgende:
nee, de officiële.
Ben nu ook bezig met de download
Geen matches
maar ik bedoel... zit er ook iets nieuws in :?
  • Mary Wana
Mary Wana
keyboard nut
Geen matches
Op zaterdag 20 juli 2002 11:14 schreef Metal-Kool4 het volgende:
volgens mij niet , dit is iig geen beta dus deze zal wel beter lopen als die verneukte beta geval
Geen matches
Het is dezelfde versie.
Het enige verschil dat ik kon vinden is dat het laadscherm een andere achtergrond heeft, en dat tanks nu sneller stuk gaan (dat was eerst een bug)
  • ErikRo
  • Laatst online: 15-10 19:33
Geen matches
Jammer dat ik niet van tevoren wist dat hij niet op een Radeon8500 zou draaien. Nu heb ik voor niets 135 mb gedownload. Hij draait dus alleen op geforce* kaarten.
"I don't have any solution but I certainly admire the problem." -- Ashleigh Brilliant
Geen matches
Hij draait wel met een radoen8500 :?
  • Mary Wana
Mary Wana
keyboard nut
Geen matches
Op zaterdag 20 juli 2002 11:51 schreef ErikRo het volgende:
Lame , als hij op een r7500 draait draaitie ook op een R8500 , ik heb geen r8500 meer maa rik wist zeker weten wel dat hij erop zou draaien
Hbe je wel goeie drivers :? Omega?
  • M@NIC
  • Laatst online: 23-09 09:24
Geen matches
Ik denk dat bijna iedereen die gelekte wel had.
Ik wacht op de MP demo :Y)
Geen matches
op mijn radeon8500 draait het spel gewoon hoor..
alleen moet ik erbij zeggen dat het wel erg buggy is :)
Geen matches
Klopt het dat je maar kan spelen in max 800x600 :? ik krijg hem iig niet hoger :'(
//edit: als dat zo is, is dit het mooiste wat ik tot nu toe heb gezien :+ :P
Afbeeldingslocatie: http://members.home.nl/van-lune/bat1.jpg
Geen matches
Als je de leaked evrsion al hebt... hou die dan lekker :)
Want er zit helemaal geen verschil in
  • Mister_X
  • Laatst online: 16-09 11:38
Geen matches
is de rest dan niet mooi, of crashde die :)
anyway, ik zie geen kyro2 staan in de niet gesupporte vidcards, terwijl die geen tnl heeft? iemand een kyro2 in ze bak en getest of iemand die wilt testen?
  • Daspeed
  • Laatst online: 15-10 16:50
Geen matches
Ik heb een Kyro II en bij mij crashed'ie bij het opstarten ;(
  • boekenbon
  • Laatst online: 30-08-2023
Geen matches
Tsja, heb hem net gespeeld. Kan er weinig van zeggen aangezien het alleen een SP is. Denk dat de kracht van de game voornamelijk zal liggen op internetgebruik. Grafisch vind ik hem in elk geval tegenvallen. P3 1ghz en gf2 gts.
Geen matches
Op zaterdag 20 juli 2002 12:24 schreef Lighteye het volgende:
[url="http://members.home.nl/van-lune/bat1.jpg"][afbeelding][/url]
Voor de mensen die hun resolutie in het spel niet verder kunnen zetten dan 800x600:
Probeer de refresh Rate Fix eens uit te zetten.
Ik heb gemerkt dat als ik dat doe dat de demo dan vloeiend loopt op 1600x1200x32 :P
De demo loopt gewoon niet erg lekker op een andere refresh rate dan 60Hz. :?
Geen matches
Op zaterdag 20 juli 2002 13:28 schreef (roh)violator het volgende:
De demo loopt gewoon niet erg lekker op eem andere refresh rate dan 60Hz. :?
Uitzetten :? kan naar mijn weten alleen door die reg keys te verwijderen, en dan nog ga ik niet voor hun plezier op 60hz spelen.
Ennuh laten die developpers het maar voor mij oplossen daar ga ik zelf geen werk voor doen, afijn ze zullen het wel in de verkoopcijfers zien, erg slecht ook overigens dat alleen de nvidia gebruikers deze offcieel kunnen testen :(
Geen matches
heb um gedownload maar als ik in het spel zit en ik op start wil drukken dan ben ik weer terug bij windows :r
en ik heb een geforce videokaart erinzitten :?
  • rove
  • Laatst online: 02-06-2022
Geen matches
Same here, als ik op ready druk krijg ik zon mapje waar ik kan kiezen wat ik wil zijn enzo en dan slaat ie terug naar windows :(
dunno
  • hereweare67893
Geen matches
Heeft iemand een werkende link? De link bij Spelletjesgarnaal.be, die altijd gigantisch snel is, doet het hier niet. :? :(
  • Albinoraptor
  • Laatst online: 23:25
Geen matches
Doet het wel, maar vind het toch erg tegenvallen, America's Amry vind ik toch stukken beter.
Zelfs het "oude" OPF is stukken beter.
  • Gehaktbal
  • Laatst online: 23-07 10:20
Geen matches
FEEEEEEEEEST :D
O mijn god wat een geluk dat ik nu een avond helemaal voor mezelf heb :9~
  • Gehaktbal
Geen matches
heb een goeie mirror gevonden:
[url="http://www.3dgamers.com/dl/games/battlefield1942/bf1942_sp_demo.zip.html"]http://www.3dgamers.com/dl/games/battlefield1942/bf1942_sp_demo.zip.html[/url]
Hier halen :)
  • dr snuggles
Geen matches
Ik ben een paar vervelende bugs tegengekomen:
1) 1600x1200x32 @100hz draait niet goed. 1280x960x32 @120hz wel. Dus nemen we die maar. De 60hz bug heb ik weggehaald met rivatuner.
2) Je kan niet met de muis lopen ;(. Dus echt lkkr loopt het niet. Misschien kan iemand een config filetje zo aanpassen dat het geforceerd wel kan. Mij is het nog niet gelukt.
3) Je kan niet wisselen van plaats in een tank wanneer je er met ze 2'en inzit. Oftwel: als zo'n vervelende bot al in een tank zit, mag jij zijn chauffeur spelen en kan die bot lkkr schieten. Ja doei.
4) Hoe moet je zien dat de tank die naar je toe komt rijden van de vijand is :?(ja, nadat mijn tank was ontploft had ik het wel door, maar das iets te laat :P).
Geen matches
Op zaterdag 20 juli 2002 16:28 schreef wwillem het volgende:
3) Als je voor een tank staat waarbij de AI de bestuurder is, en je drukt de Use knop (soms een paar keer), dan stapt ie netjes uit :)
4) Je vizier op de tank houden, en kijken naar de kleur van de namen (Rood = Axis, Blauw = Allies).
Naar de vorm van de tank kijken kan ook helpen, maar het kan best zijn dat er een mede-mof in de tank van de vijand zit
  • Mitt3nz
  • Laatst online: 17-08 22:14
Geen matches
Demo is best geinig..
Alleen.. als ik ff speel en ik ga terug naar het menu, is alle text corrupted, dus moeilijk leesbaar. Enig idee hoe dat kan?
  • blakez
  • Laatst online: 13-10-2025
Geen matches
Ik heb ook best een vage text bij alle menu's.. 't is amper leesbaar allemaal.. :( En toen ik wilde spelen in 1152x864 begon m'n monitor te flippen over de refresh rate.. :( Voor de rest vond ik 't er wel vet uit zien! :)
  • Damian
  • Laatst online: 14-10 22:26
Damian
Insane Obtrusion
Geen matches
ik heb de leaked demo al een tijdje. Die werkt gewoon perfect hier, is alleen niet veel aan die demo, je mag met een tankje rijden, en dat is het wel zon beetje.
Vanavond maar ff de offi demo leechen :)
Geen matches
Op zaterdag 20 juli 2002 17:06 schreef Damian het volgende:
Er zit geen verschil tussen, dus bespaar die 133mb aan dataverkeer voor iets anders :)
  • dr snuggles
Geen matches
Op zaterdag 20 juli 2002 16:47 schreef Terr het volgende:
Idd, sociaal van die AI zeg :).
Tis trouwens een zeer gaaf spel, wat een enorme potentie heeft als er een multiplayer demo uitkomt. Kijk bijv maar naar de wolfenstein demo, die wordt ook nog erg veel gespeeld (door oa mij :)).
Erg origineel trouwens, met tankjes rijden. Heb ik in geen enkel ander spel zo goed zien werken (ja renegade, maar dat zuigt zo hard en is verre van realitisch, laat staan leuk).
Weet iemand wanneer de multiplayer demo uitkomt :?
  • Apocrypha
  • Laatst online: 14-09 14:23
Apocrypha
Beautiful Emptyness
Geen matches
Heb het ff gespeeld, eerste indruk is vrij goed. Maar ik het gevoel dat het nog lang niet af is (maandje of 2 a 3). De geluiden zuigen zwaar (vind ik dan) Nog wat schoonheids foutjes in de graphics. Maar ik kan niet wachten om 20 vs 20 online te doen :). De WO II feeling zit er echt goed in :).
  • GTA3
Geen matches
We want the mp demo!
  • edward2
  • Laatst online: 31-01 01:56
edward2
Schieten op de beesten
Geen matches
Hij is nog aardig buggy ja, maar ik vind hem behoorlijk goed, wapens, geluiden, interactie het zit allemaal wel snor met deze.
Ik heb zelf in m'n diensttijd in een Leopard1(PRTL) gezeten en als een tank vuurt en je saat er naast dan heb je het niet breed en das zacht uitgedrukt ;) dat komt in dit spel aardig terug, als is rijden en schieten meestal niet mogelijk, maar het moet een beetje leuk blijven natuurlijk
Niet op voorraad.
  • PromWarMachine
  • Laatst online: 15-10 15:05
PromWarMachine
Forsaken Archer
Geen matches
'k Wil 'm spelen! Heb toch niets te doen vanacht, probleem is alleen dat ik geen werkende mirror meer vinden kan :(
Die 3 van Gamers.nl werken bij mij niet ofzo? :?
Op zaterdag 20 juli 2002 21:21 schreef wwillem het volgende:
Mja, ieder z'n mening enzo! Persoonlijk vond ik hem zo leuk dat ik op een gegeven moment zelfs [url="http://home.planet.nl/~walle186/promone.jpg"]eerste[/url] stond :P 8-)
Niemand? 'k Schat zo'n 3 maanden btw.
Dividend for Starters
  • Mister_X
Geen matches
nooit Operation Flashpoint gespeelt?, kan je ook nog vliegen...
  • dr snuggles
Geen matches
Op zondag 21 juli 2002 09:25 schreef Mister_X het volgende:
In dit spel ook. Alleen niet in de demo. Bij de controls staat nl ook de optie "air".
Btw, operation flashpoint heb ik wel eens een demo van gehad. Vond ik een beetje saai. Kon je idd wel in een tank zitten, maar dat kan je echt niet vergelijken met battlefield.
Ik heb net voor het eerst op normal gewonnen met de axis. Damn wat is dit gaaf zeg :P.
Geen matches
heb je wel is ofp gespeeld terwijl je hard aant wegrennen bent en achter je 4 bmps 4 t80s en 30 man achter je aan zitten :) (i love ofp)
maar on topic, battlefield 1942 kan zoooo goed worden, als de netcode maar goed is :( (en niet zo brak als de netcode van ofp :( )
Geen matches
ai ai ai, wat valt Battlefiels 1942 me erg tegen zeg. Ik dacht dit wordt een topper. Maar naar deze demo denk ik dat zeker niet meer. Hoop dat de finale game beter wordt ;(
  • Albinoraptor
Geen matches
Op zondag 21 juli 2002 10:36 schreef wwillem het volgende:
Nou ik vind OPF stukken beter dan Battlefield, slaat werkelijk nergens op. En idd laten we hopen dat final een jaar later komt, dan is het misschien nog wat, want nu :{
  • Bloodclot
  • Laatst online: 15-10 11:20
Bloodclot
Jawier!
Geen matches
Op zondag 21 juli 2002 11:48 schreef Albinoraptor het volgende:
Je vergelijkt een "fullgame realism shooter" met een arcade achtige demo die nog niet eens 10% van het spel laat zien, slaat netgens op. En OFP was in het begin ook bagger met zijn netcode. Probeer maar weer een mening te geven als battlefield1942 echt uit is.
Ik accepteer ieders mening, behalve onrechtvaardige.
  • Le_Freak !
  • Laatst online: 19-08 18:15
Geen matches
Geen problemen hier, alles doet het gewoon.
Specs
  • DeadKnight
  • Laatst online: 21:15
Geen matches
Ik vind dat opf een heel mooi spel is maar ik denk dat opf meer tacktiek is....
en Battlefield 1942 niet echt veel tacktiek is het is meer tankie in rijden slagveld in...(maar het is natuurlijk wel een heel erg goed gemaakt spel...)!
  • Albinoraptor
Geen matches
Op zondag 21 juli 2002 12:33 schreef Bloodclot het volgende:
Je kan zeggen wat je wilt, je brengt demo's uit om indruk te maken op het publiek, dus dat is flink mislukt vind ik.
Kan de final nog goed worden, maar zijn er toch flink wat mensen afgehaakt door een bagger demo. Helaas Pindakaas :P
  • Bloodclot
Bloodclot
Jawier!
Geen matches
Op zondag 21 juli 2002 12:54 schreef Albinoraptor het volgende:
tja, zo'n groep heb je ook. Ok, een demo moet wel goeei indruk geven, Mij gaf het de indruk qua lopen en schieten. Maar de echte indruk heb ik gehaald uit filmpjes, faqs en screenshots en natuurlijk Codename Eagle :)
Boeie, we zien wel of het de multiplayer orgasme wordt dit jaar. Tot nu toe is het Neverwinter nigths via lan, ik wist niet dat een weekend zo snel kon gaan.
  • Pubbert
  • Laatst online: 15-10 08:16
Pubbert
random gestoord
Geen matches
iemand met een Radeon8500 al een hogere resolutie aanstaan dan 800x600? Ik krijg hem niet hoger.. met mn 2de bak (met geforce1ddr) lukt het wel...
heb 60hz aangezet in windows... maar geen verschil.. :(
  • Pubbert
Pubbert
random gestoord
Geen matches
^^^^? zit hier eigenlijk best mee... :(
Geen matches
ik doe ook iets fout denk ik... kep een geforce 3 ti500 xp1900+ en genoeg ram :D en ik kan best spelen.. maar bij 1024x768 begint ie al te haperen.. alles op high
  • Pubbert
Pubbert
random gestoord
Geen matches
Op zondag 21 juli 2002 21:57 schreef Blizz84 het volgende:
lijkt me een driver probje, maar helaas doet hij het alleen op 800x600 op mn r8500.. dus hoger kan ik (nog) niet testen :)
  • MaZe
  • Registratie: December 1999
  • Laatst online: 12-10 11:42
Geen matches
Op zaterdag 20 juli 2002 14:50 schreef sneaker666 het volgende:
same here
knake spel, lekkere ondersteuning :r
ben nog nooit een spel tegengekomen wat bij mij niet werkt.
amd1200duron, GF4
Geen matches
Dat had ik dus ook .... weet je wat bij mij hielp..
Andere geluidskaart drivers :D
  • THPSrulez
  • Laatst online: 12-10 12:05
THPSrulez
Kijk uit malloot een kokosnoot
Geen matches
Stelletje }:O bij EA, ik kan gvd weer es nie spelen vanwege mijn lieve Voodoo 3 3000 :'( Dan maar weer w88 op een oplossing van 3DFX Underground.. (Tegenwoordig trouwens 3DHQ)
  • dr snuggles
Geen matches
Op maandag 22 juli 2002 08:31 schreef THPSrulez het volgende:
Die voodoo 3 hoort in de vuilnisbak :P
  • M@NIC
Geen matches
Nou, laat die mutliplayer demo nu maar komen want voor singleplayer hoef ik 'm niet :)
(Maar daar was ik al langer achter :P)
Geen matches
hij hapert alsof ik een geforce 1 heb man als ik inzoom.. niet te harden
  • Le_Freak !
Geen matches
Op zondag 21 juli 2002 14:14 schreef Gwain het volgende:
Yep, hiero draait ie op 1152x864 en.....spatzuiver.
Ik weet niet welke drivers je nu gebruikt maar ik gebruik de Catalyst drivers :)
Specs
  • DJkim
  • Laatst online: 02-03-2024
DJkim
Tweak met mate!!! :)
Geen matches
Hmmmm
Als ik spel start, ik kom tot hoofdmenu en zodra spel wilt starten dan springt ie terug naar desktop.
Ik heb OmegaPlut driver en ik heb refreshfix weggehaald en nieuwe soundkaart driver geprobeerd maar niks helpt.
Iemand?
Lucky Goldstar
  • FoggyFreek
  • Laatst online: 23-07 17:23
FoggyFreek
I'm a llama again!
Geen matches
Wachten op de MP demo, de SP demo stamt uit Juni dit jaar :(
veel bugs, en toch maar gereleased ( maar niet officeel, want op de officele site is niks te lezen over de SP demo, MP demo komt.. en hoe :) )
-- Altijd blijven prutsen --
  • DeadKnight
Geen matches
kijk allemaal ff op [url="http://www.bf1942.nl"]www.bf1942.nl[/url] er is net een patch uitgekomen dat je alle voertuigen krijg!
DeadKnight(bf1942 staff-member)
Geen matches
Op maandag 22 juli 2002 19:42 schreef DeadKnight het volgende:
Dat is goed nieuws :)
En zelf heb ik ook nog wat nieuws. Er zijn weer wat [url="http://www.computerandvideogames.com/news/news_story.php?id=77216"]nieuwe screenshots en een nieuw filmpje[/url] om te zien
  • DeadKnight
Geen matches
[inworp]het zijn nog niet alle voertuigen alleen maar 3 voertuiguhs erbij De maker heeft tegen ons gezegd dat hij nog bezig is met all voertuigen in de game te laten verschijnen![uitworp]
  • Pubbert
Pubbert
random gestoord
Geen matches
weet jij misschien ook hoe ik op een r8500 hogere reso's aan kan zetten?
ps: de catalyst 2.1 doet het niet (zeg dat hij vga kaart niet vind :S) heb nu de 6118 driver!
  • dr snuggles
Geen matches
Mocht je die patch nog niet geinstalleerd hebben: HOUDEN ZO. Je krijgt een APC & een jeep ipv tanks. Er is zo geen reet meer aan. Een undo patch zou makkelijk zijn.
Geen matches
Op maandag 22 juli 2002 22:12 schreef wwillem het volgende:
Als je [url="http://www.forummatch.com/forum/showthread.php?s=859ab78c3174c604a1bc386bfdcc1aad&threadid=10947"]dit[/url] even doorleest, dan kan je zelf nog meer dingen aanpassen.
Geen matches
Ik heb het volgende probleem als ik de demo start:
Afbeeldingslocatie: http://nm.indymedia.org/usermedia/image/large/error.jpg
Weet iemand wat dit is?
  • dr snuggles
Geen matches
Op dinsdag 23 juli 2002 12:23 schreef d_v_pelt het volgende:
[url="http://nm.indymedia.org/usermedia/image/large/error.jpg"][afbeelding][/url]
Demo & geluidskaart drivers al opnieuw geinstalleerd :?
  • Gehaktbal
Geen matches
DirectX installere? :)
Geen matches
Vet spel man.
*cannot wait for MP :D
Ook zo vet geluid hè.
(met me 4 point surround iig)
Ik loop rustig te snipen..
ZoeFFFF Raket vlak over me kop :P
De geluiden zijn zoiezo mooi.
Ook van de machine guns enzo.
Lekker zwaar >:)
  • dr snuggles
Geen matches
Op dinsdag 23 juli 2002 14:26 schreef Gamer2K het volgende:
wwwwhhhhOOOOEESHHHhhhssssssss. Zoiets :P
Geen matches
En ik heb dadelijk de closed beta :D :P :)
  • DeadKnight
Geen matches
we net een nieuw forum opgesteld daar staan de meeste vragen al en is al op geantwoord en er is een undo-patch uit!
  • Pubbert
Pubbert
random gestoord
Geen matches
vraag ik het weer een keer: Heeft iemand nou met een R8500 al hogere resoluties aan de praat gehad? (zonder catalyst 2.1 driver)
ps: een vriend van mij lukt het ook niet en die heeft ook catalyst 2.1 driver er op staan. Dus daar ligt het niet aan :(
  • DJkim
DJkim
Geen matches
Ik heb nieuwe official driver van ATI en soundblaster geinstalleerd maar nog steeds zodra ik start button drukt, dan kom ik terug naar DESKTOP?
IEMAND HELP!!!!!!!!!!!!!!!!!!!!!
Lucky Goldstar
Geen matches
Afbeeldingslocatie: http://members.home.nl/ikroelz/error2.jpg
ik krijg deze error :(
  • dr snuggles
Geen matches
Op dinsdag 23 juli 2002 17:02 schreef Gamer2K het volgende:
Dat denk jij, als je hem via kazaa download krijg je operation flashpoint ipv battlefield.
Hoe ik dat weet: door te zoeken op battlefield en daarna te drukken de verschillende filenames die die vond bij de beta van 207mb.
  • ko9
  • Laatst online: 00:05
ko9
Geen matches
bij mij knal ie bij het laden van het level terug naar mn desktop :'(
Had ik ook al met de "onofficiële" demo... :(
Ksnap er echt nix van. :?
Nieuwste drivers enzo allang geprobeerd
Win XP, Athlon750, 256 mb, Radeon 7200
Geen matches
Op dinsdag 23 juli 2002 20:05 schreef wwillem het volgende:
Dat denk ik niet, dat weet ik zeker!!
Hij is ZWAAR beveiligd enzo, maar ik zal dadelijk effe een screenee posten van het menu.
Ik moet nog effe een paar beveilegingen weten te omzeilen voordat ik online kan spelen, maar multiplay wil hij wel.
Nadeel:
*Geen campain
*in MP en SP batle ook de zelfde map als de demo
[edit]
En nee ik heb hem niet van kazaa
Geen matches
Hier het bewijs
Ik kan nu ook MP :)
Afbeeldingslocatie: http://www.theforumisdown.com/uploadfiles/0702/beta.jpg
Geen matches
ken niemand mij helpen ?
Geen matches
Op dinsdag 23 juli 2002 20:47 schreef Ikroelz het volgende:
DirectX 8.1 ??
Nieuwe detenators?? (of andere video kaart drivers) ?
Geen matches
Op dinsdag 23 juli 2002 21:11 schreef Gamer2K het volgende:
DirectX 8.1 ??
nope werkt niet
Geen matches
Op dinsdag 23 juli 2002 21:22 schreef Ikroelz het volgende:
nope werkt niet
Hmzz. misschien effe opnieuw installen?
Wat zijn je specs??
Genoeg geheugen?
Video kaart goed genoeg?
  • PoweRoy
  • Laatst online: 07:11
PoweRoy
funky!
Geen matches
Op dinsdag 23 juli 2002 20:21 schreef Gamer2K het volgende:
Hier het bewijs
Ik kan nu ook MP :)
[url="http://www.theforumisdown.com/uploadfiles/0702/beta.jpg"][afbeelding][/url]
wtf dat wil ik ook :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'( :'(
[This space is for rent]
  • dr snuggles
Geen matches
Op woensdag 24 juli 2002 08:57 schreef PoweRoy het volgende:
Tis niet eerlijk verdeeld in de wereld ;(.
Geen matches
Op woensdag 24 juli 2002 02:01 schreef Gamer2K het volgende:
Wat zijn je specs??
Genoeg geheugen?
Specs:
AMD Duron(tm) Processor
800MHz
320mb
Rage Fury Pro/Xpert 2000 Pro 32 mb
Geen matches
Ik snap er nix van.. Hij start wel, speelt wel, maar alleen in een of andere vage overscan/interlace mode.. Iemand ook weten hoe je dit oplost??? :?
Geen matches
Op woensdag 24 juli 2002 12:53 schreef Ikroelz het volgende:
Specs:
800MHz
320mb
Wel, ik krijg letterlijk de zelfde fout :(
Denk dat het zowel bij mij als bij u aan uwen beeldplank ligt.
Mijn Kyro'tje heeft geen t&l net zoals uw kaartje(denk ik toch) en denk dat t&l toch een vereiste is bij dit spel!
Jammer :'(
Geen matches
Wat installeren en spelen betreft geen problemen.
Geen foutmeldingen, alles werkt goed . . maar
:r
Wat een boutspel zeg
Het ziet 'r echt niet uit en ik vraag me af wat het doel is van het uitbrengen van deze demo.
Geen matches
HUH??? Ik vind het er best wel goed uitzien... Bij dit spel zijn de graphix trouwens niet het belangrijkst, dat is de gameplay... En die vond ik best wel tof bij dit (simpele) level..
Als ik met een tank-granaat op een groepje zandhazen schiet vliegen ze alle kanten uit.. Verder is het tankrijden ook best wel realistisch maar toch makkelijk... En als je gewoon met je geweertje loopt is het net MOHAA.. En dat spel roeleert nog altijd grote tijd wat mij betreft..
Kortom, ik vind het er best uitzien...
  • dr snuggles
Geen matches
Op woensdag 24 juli 2002 19:00 schreef Braadkip het volgende:
:r
a) Je kan niet omgaan met de instellingen in het spel.
b) Je hebt een bout pc.
Gaarne uw keuze bepalen :z.
  • Bloodclot
Bloodclot
Jawier!
Geen matches
Hier het bewijs
Ik kan nu ook MP :)
Mooi, kun je het probleemloos spelen?
Kun je ook langames starten?
Heb je heb het van een vriend of van de warezboards (nee geen W-R)?
Ik hoop van dat van de langames (campzone)
Geen matches
Op woensdag 24 juli 2002 19:48 schreef Bloodclot het volgende:
hmzz internet games gaan wat moeizaam (zijn allemaal beta testers enzo, dus ik wordt om de 5 min van de server geschopt.
Maar lannen gaan prima. :)
  • Bloodclot
Bloodclot
Jawier!
Geen matches
Op woensdag 24 juli 2002 20:23 schreef Gamer2K het volgende:
OK dan! Want alleen maar CS op campzone is ook niet echt tof :)
Maarum, heb je hem van een newsgroup of board? of even van een vriendje geleend? Nee geen links.
  • PoweRoy
PoweRoy
funky!
Geen matches
ich will das verdampten spiel auch :(
ich will manche arche schopfen >:)
* PoweRoy heeft Frans als keuze taal genomen
Geen matches
Vraagje:
Op de GoneGold site staat dat de officiele release datum 10 september is. Maar nou staat er achter dat ze hem deze maand al verwachten!
Check het hier:
[url="http://www.gonegold.com/releases/"]http://www.gonegold.com/releases/[/url]
Heeft iemand hier meer info over?
