testers gezocht voor CPU progje
Pagina: 1 2 3 4 5 Laatste
  • 1.394 views sinds 30-01-2008
  • Hexley
Hexley
the Platypus
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
*          CPUID v0.6 BETA        *
*     bugreports: cpuid@schijf.org    *
Processors    1 CPU
CPUID level   1 / 8
Vendor    AuthenticAMD
Processor     AMD Duron     ~1000 MHz
Name string   AMD Duron(tm) processor
Signature     0x670
Family    6          Model     7
Generation    7
Revision    A0
Core        Morgan
Technology    0.18 micron
Package  CPGA
Socket    Socket A
Press a key to show processor features
Processor features
Floating-Point unit on-chip      yes
Virtual mode extension          yes
Debugging extension            yes
Page size extension            yes
Time stamp counter              yes
Model specific registers            yes
Physical address extension        yes
Machine check exception          yes
CMPXCHG8 instruction support        yes
On-chip APIC hardware support        no
Fast system call                yes
Memory type range registers      yes
Page global enable              yes
Machine check architecture        yes
Conditional move instruction supported  yes
Page attribute table              yes
36-bit page size extension        yes
Press a key to see features page 2
Processor features - continued
MMX supported                  yes
Fast floating point save and restore    yes
Streaming SIMD Extension supported  yes
SYSCALL and SYSRET instructions    yes
Multi-processing capable            no
SSE MMX Extensions supported        yes
3DNow! supported                yes
3DNow! Extensions supported      yes
Temperature sensing diode          yes
Frequency ID control              no
Voltage ID control              no
Press a key to show TLB and cache info
TLB and cache info
L1 instruction cache            64 KByte
L1 instruction cache associativity  2-way associative
L1 instruction cache line size  64 Byte
L1 data cache                64 KByte
L1 data cache associativity    2-way associative
L1 data cache line size      64 Byte
L2 cache size                64 KByte
L2 cache associativity        8-way associative
L2 cache line size          64 Byte
TLB size (code / data)        4 / 4 KByte
TLB associativity (code / data)     full / full associative
TLB entries (code / data)        16 / 32 Byte
TLB 2/4 size (code / data)      2048 / 2048 KByte
TLB 2/4 associativity (code / data) full / 4-way associative
TLB 2/4 entries (code / data)    8 / 8 Byte
     Done! Kick your keyboard to exit
Steeds mooier dat progje :)
Und jeden Tag versagen wir ein weiteres Mal,
und jeden Tag versagen wir ein weiteres Mal.
Wenn ich Du wär, lieber Gott,
und wenn Du ich wärst, lieber Gott,
glaubst Du, ich wäre auch so streng mit Dir?
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Mobile Pentium 4-M ~1393 MHz
Name string Intel(R) Pentium(R) 4 Mobile CPU 1.40GHz
Brand ID Intel Pentium 4
Type Original OEM processor
Signature 0xF24
Family 15 Model 2
Revision B0(-Shrink)
Core Northwood
Technology 0.13 micron
Package Micro-FCPGA
Socket Socket 478
Processor features
Serial number present and enabled no
CLFLSH instruction supported yes
Debug store yes
Thermal monitor and software clock yes
MMX supported yes
Streaming SIMD Extensions 2 supported yes
Self-Snoop yes
Hyper-Threading Technology yes
Thermal monitor support yes
IA-64 no
Pending Break Event no
TLB and cache info
Trace cache size 12 K-uop
Trace cache associativity 8-way associative
L1 data cache 8 KByte
L1 data cache associativity 4-way associative
L2 cache size 512 KByte
Aan de tweakers die bij processor Athlon MP hebben staan en bij name string Athlon XP:
Welke BIOS (fabrikant en versie) hebben jullie? De praktijk heeft nu bewezen dat de BIOS de name string van AMD processoren bepaald. Een update kan voor een beter resultaat zorgen.
Dit geldt ook als de 1700+/1800+/enz niet klopt!
Met dank aan Marc H die het vandaag uitgetest heeft met een niet kloppende name string :)
  • Rataplan_
  • Laatst online: 02-09 10:58
Compaq Armada E500 notebookje, wordt zover xie goed weergegeven:
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 0
Vendor GenuineIntel
Processor Intel Pentium III calculating speed...~497 MHz
Brand ID Intel Pentium III
Signature 0x683
Family 6 Model 8
Revision cB0
Core Coppermine
Package FC-PGA / SECC2
Socket Socket 370
Processor features
CLFLSH instruction supported no
Debug store no
Thermal monitor and software clock no
MMX supported yes
Streaming SIMD Extensions 2 supported no
Self-Snoop no
Hyper-Threading Technology no
Thermal monitor support no
IA-64 no
TLB and cache info
L1 instruction cache 16 KByte
L1 instruction cache associativity 4-way associative
L1 instruction cache line size 32 Byte
L1 data cache 16 KByte
L1 data cache line size 32 Byte
L2 cache size 256 KByte
L2 cache line size 32 Byte
TLB associativity (code / data) 4-way / 4-way associative
TLB entries (code / data) 32 / 64 Byte
TLB 2/4 size (code / data) 4096 / 4096 KByte
TLB 2/4 entries (code / data) 2 / 8 Byte
  • Shunt
  • Laatst online: 17:52
Shunt
Boe
Op zaterdag 27 juli 2002 19:22 schreef Zotty het volgende:
ASUS
A7V266-EX
1010 B
Game PC
2 Post or Not 2 Post What's the question ?
"If it ain't broken, you didn't try hard enough"
Op zaterdag 27 juli 2002 20:06 schreef Shunt het volgende:
ASUS
A7V266-EX
1010 B
Hmmz, heb net ff de specs erbij gezocht en zowel op de site als in de manual en bij de update notes wordt niet gesproken over een Athlon MP. Dus de BIOS zal het waarschijnlijk niet herkennen daarom in de string gewoon XP zetten... gokje ;)
  • Shunt
Shunt
Boe
Op zaterdag 27 juli 2002 20:15 schreef Zotty het volgende:
erm :? wie moet wat in waar zetten ben een programering analfabeet ;)
Game PC
Op zaterdag 27 juli 2002 20:26 schreef Shunt het volgende:
Zal ff een kleine uitleg geven ;) Ik had dus de theorie dat bij AMD processoren de BIOS de name string in de processor moest programmeren. Bij AMD kon ik er niets over vinden, alhoewel in 1 van de vele documenten wel een verwijzing stond naar een document dat in de titel iets van string, programming en BIOS had staan.
Herkent de BIOS de processor niet omdat die te nieuw is, dan krijg je dus een foute string. Als je bijv een Athlon MP hebt, herkend een oude BIOS het als een Athlon XP.
Als de fabrikant vervolgens een update van de betreffende BIOS maakt, een die flash je in je mobo, dan is de kans groot dat de BIOS een Athlon MP wel herkend als MP.
  • Shunt
Shunt
Boe
Op zondag 28 juli 2002 11:44 schreef Zotty het volgende:
aaaaah zooo
mare dit is de nieuwste BIOS :?
Game PC
ok hier de mijne
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   1 / 8
Vendor    AuthenticAMD
Processor     AMD Duron     ~1099 MHz
Name string   AMD Duron(tm) Processor
Signature     0x670
Family    6          Model     7
Generation    7
Revision    A0
Core        Morgan
Package  CPGA
Socket    Socket A
Processor features
On-chip APIC hardware support        yes
MMX supported                  yes
TLB and cache info
  • Astennu
  • Laatst online: 19-08 17:53
Hoe zetten jullie dat in een text bestand ?
Want ik heb geen zin om het over te tikken.
gewoon kopieeren vanuit de cmd.
In winXP:
rechtsklik ->markeren, dan text selecteren, en dan een druk op de Enter-knop.
Nu kan je 't gewoon plakken waar je maar wil :)
Op zondag 28 juli 2002 16:26 schreef Shunt het volgende:
aaaaah zooo
Volgens de site van Asus is het de laatste.
  • getty
  • Laatst online: 28-08 13:19
Mijn servertje
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   2 / 0
Vendor    GenuineIntel
Processor     Intel Pentium II      ~274 MHz
Signature     0x634
Family    6          Model     3
Revision    C1
Core        unknown
Technology    0.35 micron
Package  SECC 3.00
Socket    242-contacts
Processor features
Page attribute table              no
36-bit page size extension        no
Debug store                  no
MMX supported                  yes
Fast floating point save and restore    no
Streaming SIMD Extension supported  no
Self-Snoop                  no
IA-64                        no
TLB and cache info
L2 cache associativity        4-way associative
A computer is almost human - except that it does not blame its mistakes on another computer.
  • CrazyA
  • Laatst online: 06-09 10:55
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   1 / 6
Vendor    AuthenticAMD
Processor     AMD Duron     ~706 MHz
Name string   AMD Athlon(tm) Processor
Signature     0x631
Family    6          Model     3
Generation    7
Revision    A2
Core        Spitfire
Package  CPGA
Socket    Socket A
Processor features
MMX supported                  yes
Temperature sensing diode          no    (!!?? met MBM wel hoor)
TLB and cache info
TLB entries (code / data)        16 / 24 Byte
Op zondag 28 juli 2002 21:05 schreef CrazyA het volgende:
Processor AMD Duron~706 MHz
err.. dat klopt niet :? Welke van de 2 heb je in de winkel gekocht ? :+
Op het mobo waarschijnlijk, maar niet intern in de CPU ;)
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 0
Vendor GenuineIntel
Processor Intel Pentium III ~797 MHz
Signature 0x686
Family 6 Model 8
Revision cC0
Core Coppermine
Socket Socket 370
Processor features
Debug store no
MMX supported yes
Self-Snoop no
IA-64 no
TLB and cache info
Done! Kick your keyboard to exit :o
  • Bossie
  • Laatst online: 19:35
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Intel Celeron ~1400 MHz
Name string Intel(R) Celeron(TM) CPU 1000MHz
Brand ID Intel Celeron
Signature 0x6B1
Family 6 Model 11
Revision A1
Core unknown
Package FC-PGA2
Socket Socket 370
alles klopt alleen heb ik een unknown core
  • RammY
  • Laatst online: 29-08 22:56
RammY
Dát!
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   3 / 0
Vendor    GenuineIntel
Processor     Intel Pentium III     ~735 MHz
Signature     0x683
Family    6          Model     8
Revision    cB0
Core        Coppermine
Socket    Socket 370
Processor features
Serial number present and enabled    yes
Debug store                  no
MMX supported                  yes
Self-Snoop                  no
IA-64                        no
TLB and cache info
EN DEZE IS VAN DE UTIL VAN INTEL
Intel(R) Processor Frequency ID Utility
Version: 4.61.20020521
TimeStamp: 2002/7/28 21:50:2
Number of processors in system: 1
Current processor: #1
Processor Name: Intel(R) Pentium(R) III Processor
CPU Type: 0
CPU Family: 6
CPU Model: 8
CPU Stepping: 3
CPU Revision: 14
L1 Instruction Cache: 16 KB
L1 Data Cache:  16 KB
L2 Cache:  256 KB
Packaging: FC-PGA
MMX: Yes
SIMD: Yes
SIMD2: No
NetBurst(TM) microarchitecture: No
Reported processor Frequency: 733 MHz
Reported System Bus Frequency: 133 MHz
Expected processor Frequency: 733 MHz
Expected System Bus Frequency: 133 MHz
Deze advertentieplaats is te huur!
  • CrazyA
Op zondag 28 juli 2002 21:07 schreef Zotty het volgende:
Duron 700 met 101 MHz FSB, dus 706/707 MHz.
Temp, ow....nouja, zal wel.
  • pt0x
  • Laatst online: 03-01-2025
pt0x
Why are we here..
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   2 / 4
Vendor    GenuineIntel
Processor     Pentium 4     ~2411 MHz
Name string          Intel(R) Pentium(R) 4 CPU 1.80GHz
Signature     0xF24
Family    15             Model     2
Revision    B0
Core        Northwood
Package  FC-PGA2
Socket    Socket 478
Processor features
Debug store                  yes
MMX supported                  yes
Self-Snoop                  yes
IA-64                        no
TLB and cache info
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 calculating speed...~2240 MHz
Name string Intel(R) Pentium(R) 4 CPU 1.60GHz
Signature 0xF24
Family 15 Model 2
Revision B0
Core Northwood
Package FC-PGA2
Socket Socket 478
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
TLB and cache info
  • hunterxl
  • Laatst online: 22-08 17:33
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Intel Pentium III ~1330 MHz
Name string Intel(R) Pentium(R) III CPU family 1266MHz
Signature 0x6B1
Family 6 Model 11
Revision tA1
Core Tualatin
Package FC-PGA2
Socket Socket 370
Processor features
Debug store no
MMX supported yes
Self-Snoop no
IA-64 no
TLB and cache info
Procesprutser
  • OliverBB
  • Laatst online: 23-11-2024
Afbeeldingslocatie: http://members.home.nl/wgsnijders/cpu.JPG
  • ImpaileR
ImpaileR
The Obsidian Order
Wat is het nou een XP of een MP :? :)
Op een Asus A7V266-E mobo.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
*          CPUID v0.6 BETA        *
Processors    1 CPU
CPUID level   1 / 8
Vendor    AuthenticAMD
Processor     AMD Athlon MP     ~1544 MHz
Name string   AMD Athlon(TM) XP1800+
Signature     0x662
Family    6          Model     6
Generation    7
Revision    A5
Core        Palomino
Package  OPGA
Socket    Socket A
Processor features
MMX supported                  yes
Multi-processing capable            yes
TLB and cache info
  • Consiglieri
  • Laatst online: 05-10-2025
Ik heb toch een vraagje...
Schijnbaar werkt je software goed, maar wat is dan het nut ervan?
  • Atlas
Atlas
Ik flits niet meer terug!
link is dood :')
  • ImpaileR
ImpaileR
The Obsidian Order
Probeer deze eens: [url="http://www.waxworks.nl/got/files/cpuid_v06.exe"]cpuid_v06.exe[/url]
  • OliverBB
nu met het andere proggie:
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 ~2040 MHz
Name string Intel(R) Pentium(R) 4 CPU 1.70GHz
Signature 0xF12
Family 15 Model 1
Revision D0
Core Willamette
Package OOI / FC-PGA2
Socket Socket 423 / Socket 478
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
TLB and cache info
  • Kr3Kr
  • Laatst online: 09-09 10:18
Kr3Kr
Melpomene
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 8
Vendor AuthenticAMD
Processor AMD Athlon MP ~1687 MHz
Name string AMD Athlon(tm) XP 2000+
Signature 0x662
Family 6 Model 6
Generation 7
Revision A5
Core Palomino
Package OPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
Gregor van Egdom Krekr
  • SaiBork
  • Laatst online: 02-11-2023
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 6
Vendor AuthenticAMD
Processor AMD Athlon ~1141 MHz
Signature 0x642
Family 6 Model 4
Generation 7
Revision A4 / A5 / A6 / A7
Core Thunderbird
Package CPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
Ziet er goed uit hoor.
  • Atlas
Atlas
Ik heb een TB 1200. Het proggie zegt dat ik geen tempdiode heb? EN deze heb ik sekers wel.
Zijn er meer mensen die hier last van hebben?
Asus mobo a7v266-e
amd XP 1800+
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 8
Vendor AuthenticAMD
Processor AMD Athlon MP ~1983Mhz
Signature 0x662
Family 6 Model 6
Generation 7
Revision A5
Core Palomino
Package OPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
  • Astennu
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 8
Vendor AuthenticAMD
Processor AMD Athlon MP ~1350 MHz
Name string AMD Athlon(tm) XP 1500+
Signature 0x662
Family 6 Model 6
Generation 7
Revision A5
Core Palomino
Package OPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
Dat was i dan.
Maar dit was de pc van mijn pa mijn 1900+ zit er ff in maar die loopt nog geen 1600+ :(
Ff een kleine test tussendoor voor dual CPU systemen:
Dual CPU test
Dit werkt alleen op een dual CPU systeem !
btw, voor de liefhebbers een eerste test waarbij het progje toegepast wordt op een LCD :)
  • BalusC
BalusC
Carpe diem
Werkt uitstekend op zowel mijn BP6 als mijn PC Server 520 :)
BP6 met Dual Celeron 500@600
Processors    2 CPU's
Primary processor:
Vendor        GenuineIntel
Processor     Intel Celeron            ~599 MHz
Signature     0x665
Secondary processor:
Vendor        GenuineIntel
Signature     0x665
IBM PC Server 520 met Dual Pentium 166
Processors    2 CPU's
Primary processor:
Vendor        GenuineIntel
Processor     Intel Pentium            ~166 MHz
Signature     0x52C
Vendor        GenuineIntel
Signature     0x52C
  • beerns
  • Laatst online: 07-09 13:26
beerns
it is I, Leclerc
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 calculating speed...~2266 MHz
Name string Intel(R) Pentium(R) 4 CPU 2.26GHz
Signature 0xF24
Family 15 Model 2
Revision B0
Core Northwood
Package FC-PGA2
Socket Socket 478
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
dusssss.
Erik heeft bij ons in het dorp best wel een slechte naam. Ik geloof Hans ofzo, of Rob.....
  • vinnux
Geinig !
Intel Celeron 600E Mhz
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
Microsoft Windows XP [versie 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
F:\Download>cpuid_v06.exe
*               CPUID v0.6 BETA              *
Processors    1 CPU
CPUID level   2 / 0
Vendor        GenuineIntel
Processor     Intel Celeron            ~598 MHz
Signature     0x686
Family        6                   Model         8
Revision      C0
Core          unknown
Package       FC-PGA
Socket        Socket 370
Processor features
Debug store                             no
MMX supported                           yes
Self-Snoop                              no
IA-64                                   no
TLB and cache info
L2 cache size                       128 KByte
  • Erik1
PIII 666MHz
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 0
Vendor GenuineIntel
Processor Intel Pentium III ~668 MHz
Signature 0x683
Family 6 Model 8
Revision cB0
Core Coppermine
Socket Socket 370
Processor features
Debug store no
MMX supported yes
Self-Snoop no
IA-64 no
TLB and cache info
er staat:
maar er zit wel degelijk een Serial nummer op maar die heb ik uit gezet. Kun je niet bijv. doen dattie bij een PIII Zegt serial number present: yes en dan enabled: yes of no :) Of zie ik nu iets helemaal verkeerd :?
  • Meller
  • Laatst online: 15:44
Meller
Much to learn, you still have
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 ~1594 MHz
Signature 0xF24
Family 15 Model 2
Revision B0
Core Northwood
Package FC-PGA2
Socket Socket 478
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
TLB and cache info
Core i5-4570, 8GB, 250 GB SSD, GT730 2GB, S20, Fossil Gen4
  • SpaceDok
  • Laatst online: 09-09 22:59
Zotty,
Sorry voor de vertraging maar hierbij mijn gegevens van de Dual test:
* CPUID vX.X BETA *
* DUAL CPU TEST *
Processors 2 CPU's
Primary processor:
Vendor AuthenticAMD
Processor AMD Athlon MP ~1666 MHz
Name string AMD Athlon(tm) MP 2000+
Signature 0x662
Vendor AuthenticAMD
Signature 0x662
Ziet er naar mijn oordeel goed uit :*)
En hij geeft elke keer exact hetzelfde aan 8)
Mvg,
SpaceDok
Geloof niets van wat je hoort en de helft van wat je ziet...
  • Tyrian
Tyrian
It's Unreal.
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 ~1707 MHz
Name string Intel(R) Pentium(R) 4 CPU 1700MHz
Signature 0xF0A
Family 15 Model 0
Revision C1
Core Willamette
http://www.hypercoop.tk | GW user page | GW2 user page
Specs
alexandervisser schreef op 28 juli 2002 @ 23:24:
Het gaat hier om de interne diode, dus de diode in de CPU zelf. Ik weet zo uit m'n hoofd niet hoe dat zat met een TB. Zal het ff moeten nakijken, maar je bent iig niet de enige met een TB die geen interne diode heeft.
BalusC schreef op 30 juli 2002 @ 20:52:
BP6 rulez ! /me heeft er zelf ook 1 _/-\o_
Erik1 schreef op 30 juli 2002 @ 21:57:
er staat:
Dit klopt wel :) Hier komt alleen yes te staan als aan beide voorwaarden is voldaan, dus aanwezig en enabled. Helaas is dit niet te scheiden, Intel heeft het in 1 bit gepropt.
SpaceDok schreef op 31 juli 2002 @ 00:33:
Dat was wel de bedoeling B)
In deze test wordt elke CPU eerst expliciet geselecteerd en dan pas de info opgevraagd. Dit in tegenstelling tot eerder, waarbij soms de ene CPU, soms de andere CPU aangesproken werd.
Maar, ik moet hierbij wel ff zeggen dat dit mede dankzij Yarvieh is. Hij was zo vriendelijk om mij een stukje code te sturen dat mij in 1x met een grote schop op de juiste manier wees :)
  • CRiMiNaL
  • Laatst online: 10-01-2024
CRiMiNaL
Witlof ^^
Hey Zotty ik volgde je topic nu al een tijdje vanuit France en gister kwam ik eindelijk thuis om em zelf ff uit te testen op al mijn verschillende system's
Allemaal zonder fouten behalve deze :
Vendor AuthenticAMD
Processor AMD Athlon ~17 MHz
Name string AMD-K7(tm) Processor
Signature 0x612
Family 6 Model 1
Generation 7
Revision C2
Core K7
Technology 0.25 micron
Package Card module
Socket Slot A
Ik ben van mening dat deze PC langzaam is .. maar 17 MHz is toch echt wel iets te langzaam ;)
... MMORPG Addict.
  • CRiMiNaL
CRiMiNaL
Witlof ^^
elke keer dat ik het uitvoer ... hangt ie op 28 of 17 of 43 of dat soort rare getallen .. heb versie 0.6B. enig id wat het kan zijn ??
... MMORPG Addict.
  • BalusC
BalusC
Carpe diem
CRiMiNaL, misschien is het handig om dan je systeemspecs erbij te zetten en eventueel een referentiescreenshotje van bijvoorbeeld WCPUID, dan heeft Zotty ook wat meer aan :)
  • CRiMiNaL
CRiMiNaL
Witlof ^^
AMD athlon K7 500 Mhz Compaq machine Versie 7931 met VooDoo 3 Video kaart .. voor de rest geen hardware bekend. 't is een oude bak maar toch ...
Zoals je begrijpt niet m'n eigen PC maar zo'n kan en klaar Compaq ding, 1 week geleden gekregen van m'n buurvrouw, en nu weer aan de gang gekregen.
Ik volg dit topic al langer en volgens mij heeft Zotty ook niet meer nodig dan m'n CPU spec's mocht het wel zo zijn hoor ik het graag.
... MMORPG Addict.
CRiMiNaL schreef op 31 juli 2002 @ 12:00:
Vendor AuthenticAMD
Vanuit France ?! Kewl, maare, is het daar niet een beetje heel erg warm nu :P
Anyways, 17 MHz lijkt me niet echt kloppen voor een Athlon. 'k kan je helaas zo 1-2-3 niet verklaren hoe het komt, maar ik zal er zeker even naar kijken.
  • CRiMiNaL
CRiMiNaL
Witlof ^^
idd super warm .... maare hier is het veelste benauwd... :|
Wij Nederlanders zijn ook nooit tevreden ;)
BTW waar ik nog heel ff aan dacht er draait win2k op die pc dus kan dat niet de oorzaak zijn ..?? (win2k geen echte dos, dus nep DOS neem maar 17MHz van CPU in beslag)
't is maar theorie ... maar toch ;)
... MMORPG Addict.
  • Lennieboy83
  • Laatst online: 31-05-2024
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 ~1779 MHz
Signature 0xF12
Family 15 Model 1
Revision D0
Core Willamette
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
TLB and cache info
Dit is best lachen ik wist niet dat ik een CPU had die al Hyper Threading Technology had :)
  • Shift
  • Laatst online: 04-08 13:44
Shift
[] Dual crazy []
Bug on detecting HyperThreading technoligy,
  • decramy
  • Laatst online: 08-09 17:46
decramy
root@birdie:~#
Kan het kloppen dat garfisch-lcd.tk eruit ligt :?
wie wil ff de url posten :?
20*375Wp met Enphase IQ7+ micro's | Stiebel Eltron HGE Water/Water WP 9kW | Tesla M3, powered by SmartEVSE | Servertje @ www.coloclue.net
  • eth0
  • Laatst online: 15-09-2025
Volgens mij zit je in het verkeerde topic te posten, net als mijzelf |:( komt omdat ik het andere topic http://gathering.tweakers.net/forum/list_messages/545449 ook open had en ik las jou reaktie en toen ging ik er van uit dat dit het topic was
maar net op mijn mail
Goedenavond,
Op dit moment is www.grafisch-lcd.tk niet bereikbaar, de TK site ligt eruit...
Zeer vervelend, maar voor degene die zich vervelen:
http://members.ams.chello.nl/eeekelen/welkom.htm
Kun je direct rechtstreeks naar De LCD site...
Met vriendelijke groet,
Edwin LIA
  • SH007
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Intel Celeron ~1064 MHz
Name string Intel(R) Celeron(TM) CPU 1200MHz
Signature 0x6B1
Family 6 Model 11
Revision A1
Core unknown
Package FC-PGA2
Socket Socket 370
Die snelheid klopt niet.
Dat het een celly 1200 is klopt wel, maar hij loopt op 12 * ~110 = ~1320mhz.
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 8
Vendor AuthenticAMD
Processor AMD Athlon MP ~1526 MHz
Name string AMD Athlon(tm) XP 1800+
Signature 0x662
Family 6 Model 6
Generation 7
Revision A5
Core Palomino
Package OPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
  • Tsunami
ehm, voglens mij is de link uitgevallen...
  • kimjansen
  • Laatst online: 19:14
kimjansen
Nu ff niks...
dj_tsunami schreef op 10 augustus 2002 @ 21:07:
ik weet het wel zeker :(
Speed kills, but beauty lives forever...
  • BalusC
BalusC
Carpe diem
Als jullie het hele draadje geduldig hadden doorgelezen, dan waren jullie wis en zeker tot de conclusie gekomen dat er een nieuwere versie met een andere naam op de webspace van de topicstarter is gezet :)
Hint: zie de post van 25 juli om 22:80 ;)
  • XWB
XWB
Devver
Om je wat zoekwerk te besparen :
March of the Eagles
  • Domino
  • Registratie: Juli 1999
  • Laatst online: 18:39
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
Processors    1 CPU
CPUID level   2 / 4
Vendor        GenuineIntel
Processor     Intel Celeron             calculating speed... ~1202 MHz
Signature     0x6B1
Family        6                   Model         11
Revision      A1
Core          unknown
Package       FC-PGA2
Socket        Socket 370
Processor features
Debug store                             no
MMX supported                           yes
Self-Snoop                              no
IA-64                                   no
TLB and cache info
Lijkt me verder wel te kloppen.
  • HekkeySE
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 2 / 4
Vendor GenuineIntel
Processor Pentium 4 ~2020 MHz
Signature 0xF24
Family 15 Model 2
Revision B0
Core Northwood
Package FC-PGA2
Socket Socket 478
Processor features
Debug store yes
MMX supported yes
Self-Snoop yes
IA-64 no
TLB and cache info
klopt goed :)
Recht op morgen heb ik niet, maar morgen wordt beter dan vandaag en gisteren bestaat niet.
  • ArjanC
  • Laatst online: 26-01 17:16
* CPUID v0.6 BETA *
Processors 1 CPU
CPUID level 1 / 8
Vendor AuthenticAMD
Processor AMD Athlon MP ~1336 MHz
Signature 0x662
Family 6 Model 6
Generation 7
Revision A5
Core Palomino
Package OPGA
Socket Socket A
Processor features
MMX supported yes
TLB and cache info
  • XoReP
  • Laatst online: 15:23
Sorry dat ik deze topic omhoog kick maar ik kan dit proggie nergens vinden en ik zou het wel willen gebruiken _/-\o_
  • BalusC
BalusC
Carpe diem
Mail/ICQ Zotty eens ;)
<small>/overbodige kick, ja</small>
