3DMARK 2000 PROJECT FILE
PROJECT
Description: My Project
Comment:
3DMark Version: 340
Install ID: 0x3CA6C6DA
Registration Key:
Registration Name:
TEMPLATE
Display:
Type: Internal
Width: 1024
Height: 768
Depth: 16-Bit
Buffering: Triple
Z-Buffering: 16-Bit
Refresh Rate: VSync Off
Texture Format: 16-Bit
Options:
Continuous Benchmark: No
Show Title Screens: Yes
Benchmark Run Count: 1
Continuous Demo Mode: No
Sounds Enabled: Yes
CPU Optimization: D3D Hardware T&L
RESULTS
Platform: Internal
3DMark Result: 2492 3D marks
CPU Speed: 169 CPU 3D marks
Game 1 - Helicopter - Low Detail: 52,3 FPS
Game 1 - Helicopter - Medium Detail: 36,1 FPS
Game 1 - Helicopter - High Detail: 16,0 FPS
Game 2 - Adventure - Low Detail: 54,0 FPS
Game 2 - Adventure - Medium Detail: 30,9 FPS
Game 2 - Adventure - High Detail: 18,3 FPS
Fill Rate (Single-Texturing): 319,5 MTexels/s
Fill Rate (Multi-Texturing): 620,5 MTexels/s
High Polygon Count (1 Light): 1455 KTriangles/s
High Polygon Count (4 Lights): 1497 KTriangles/s
High Polygon Count (8 Lights): 1435 KTriangles/s
8MB Texture Rendering Speed: 184,2 FPS
16MB Texture Rendering Speed: 144,0 FPS
32MB Texture Rendering Speed: 65,4 FPS
64MB Texture Rendering Speed: 27,8 FPS
Bump Mapping (Emboss, 3-pass): 129,6 FPS
Bump Mapping (Emboss, 2-pass): 160,3 FPS
Bump Mapping (Emboss, 1-pass): 219,2 FPS
Bump Mapping (Environment): Not supported FPS
SYSTEM
Software Versions:
Windows Version Windows 4 , Build 3000
DirectX Version 4.07.01.3000
Bios Version Award Modular BIOS v4.51PG
Bios Date 07/01/99
Memory:
Total Physical Memory 128MB
Free Physical Memory 70MB
PROCESSOR
CPU Information:
Processor Type Intel Pentium III
Processor Speed 550MHz
Processor Caps SSE, MMX
Cache Memory:
L1 Cache Size 32KB
L2 Cache Size 512KB
DESKTOP
2D Display Adapter:
Name NVIDIA GeForce2 MX
Driver Date 09/10/2000
Monitor:
Name Plug en Play-monitor
Driver Date 06/08/2000
Desktop Size and Color Depth:
Width 1152
Height 864
Color Depth 16 bit
INTERNAL 3D CARD
Information:
Driver Name NVDD32.DLL
Driver Version 4.12.01.0626 (Certified)
Total Video Memory 32162KB
Total Texture Memory 144906KB
Minimum Texture Resolution 1 * 1
Maximum Texture Resolution 2048 * 2048
Maximum Texture Blending Stages 8
Maximum Texture Coordinates 8
Bus AGP
Manufacturer Identifier 0x000010DE
Chipset Type 0x00000110
Subsystem Identifier 0x40151043
Chipset Revision Level 0x000000A1
Supported features:
Transformation and lighting in hardware Yes
16-Bit Rendering Yes
24-Bit Rendering No
32-Bit Rendering Yes
Textures In Single Pass 2
Driver can disable VSync by software request Yes
Edge Antialiasing No
Subpixel Accuracy Yes
Point Sampling Yes
Point Sampling With Mip-Mapping Yes
Bilinear Filtering Yes
Bilinear Filtering With Mip-Mapping Yes
Trilinear Filtering Yes
Anisotropic Filtering Yes
Specular Gouraud Yes
Vertex Fog Yes
Range Fog Yes
Table Fog Yes
W-Fog Yes
Alpha Blending Yes
Vertex Alpha Blending Yes
Vertex And Texture Alpha Blending Yes
Additive Alpha Blending Yes
Multiplicative Alpha Blending Yes
S3 Texture Compression Yes
DX6 Bump Mapping No
Flags:
DirectDraw flags 1 0x94C27FE3
DirectDraw flags 2 0x004AFE7D
Texture operations 0x009FFFFF
Stencil-buffer operations 0x000000FF
Miscellaneous capabilities 0x00000072
Raster capabilities 0x00376DA1
Z-comparison capabilities 0x000000FF
Alpha-test-comparison capabilities 0x000000FF
Source-blending capabilities 0x00001FFF
Destination-blending capabilities 0x00001FFF
Shading capabilities 0x000C528F
Texture capabilities 0x00000C0F
Texture-filtering capabilities 0x0703073F
Texture-blending capabilities 0x000000FF
Texture-addressing capabilities 0x00000017
Modes:
Z-Buffer formats 16-Bit Z-Buffer, 24-Bit Z-Buffer, 32-Bit Z-Buffer (8-Bit Stencil)
8-Bit Texture formats N/A
15-Bit Texture formats 15-bit, 555 RGB
16-Bit Texture formats 16-bit, 5551 RGBA, 16-bit, 4444 RGBA, 16-bit, 565 RGB
24-Bit Texture formats 24-bit, 888 RGB
32-Bit Texture formats 32-bit, 8888 RGBA
Display modes 320 * 200, 8 bit, 320 * 240, 8 bit, 400 * 300, 8 bit, 480 * 360, 8 bit, 512 * 384, 8 bit, 640 * 400, 8 bit, 640 * 480, 8 bit, 800 * 600, 8 bit, 960 * 720, 8 bit, 1024 * 768, 8 bit, 1152 * 864, 8 bit, 1280 * 720, 8 bit, 1280 * 960, 8 bit, 1280 * 1024, 8 bit, 320 * 200, 16 bit, 320 * 240, 16 bit, 400 * 300, 16 bit, 480 * 360, 16 bit, 512 * 384, 16 bit, 640 * 400, 16 bit, 640 * 480, 16 bit, 720 * 480, 16 bit, 720 * 576, 16 bit, 800 * 600, 16 bit, 960 * 720, 16 bit, 1024 * 768, 16 bit, 1152 * 864, 16 bit, 1280 * 720, 16 bit, 1280 * 960, 16 bit, 1280 * 1024, 16 bit, 320 * 200, 32 bit, 320 * 240, 32 bit, 400 * 300, 32 bit, 480 * 360, 32 bit, 512 * 384, 32 bit, 640 * 400, 32 bit, 640 * 480, 32 bit, 720 * 480, 32 bit, 720 * 576, 32 bit, 800 * 600, 32 bit, 960 * 720, 32 bit, 1024 * 768, 32 bit, 1152 * 864, 32 bit, 1280 * 720, 32 bit, 1280 * 960, 32 bit, 1280 * 1024, 32 bit
Niet goed lijkt me...
helluuup =] iemand met ideeen?
