Het grote Geforce4 Ti4200 topic (vervolg)
Pagina: 1 ... 15 ... 17 Laatste
  • 3.293 views sinds 30-01-2008
  • PhatFish
  • Laatst online: 08-09 08:39
PhatFish
and, uhm......Moo
Die van AOpen heeft 500MHz 128MB DDR SDRAM, maar meer kan ik er niet over zeggen, er staat dacht ik nog wel ergens wat info over die kaart een aantal posts geleden.
  • McFlipp
  • Laatst online: 22-04-2023
McFlipp
24...
Abit Siluro ti4200
Release the power of your PC with ABIT?s Siluro GF4 Ti4200. The Siluro GF4 Ti4200 is powered by the advanced NVIDIA GeForce4 Ti4200 GPU. Coupled with 64MB/128MB of DDR memory, the Siluro GF4 Ti4200 delivers a new level of graphic performance to your PC. By incorporating NVIDIA?s innovative nView? display technology, the Siluro GF4 Ti4200 can provide unprecedented flexibility and control for using multiple displays. Highly efficient Lightspeed Memory Architecture? II boosts effective memory bandwidth, and advanced Accuview? Antialiasing techniques deliver the best visual quality without sacrificing performance. With NVIDIA's nfiniteFX? II engine incorporating dual programmable Vertex and Pixel Shaders, 3D Textures, Shadow Buffers, and integrated dual 350MHz DACs, the NVIDIA GeForce4 Ti4200 GPU is powerful enough for all your graphic computing needs.
The ABIT Siluro GF4 Ti4200 with optional Video-In function bundles Ulead VideoStudio software that allows you to edit video as you desire. The Siluro GF4 Ti4200 gives you access to nearly a hundred transition effects, professional titling capabilities and simple soundtrack creation tools.
Be it for gaming, DVD viewing, internet surfing or even video editing, the Siluro GF4 Ti4200 empowers you with support for a wide range of devices. Capture video from the VCR, Camcorder, or DV to NTSC or PAL, all without using traditional analog conversion devices. Discover the difference with the ABIT Siluro GF4 Ti4200.
Features:
• NVIDIA GeForce4 Ti4200 GPU
• nfiniteFX II Engine for full programmability
• Accuview with high resolution antialiasing
• nView delivers multiple displays
• Lightspeed Memory Architecture II for unmatched performance
• New dual programmable Vertex Shaders
• Advanced programmable Pixel Shaders
• 4 Billion AA samples per second fill rate
• 1.03 Trillion operations per second
• GPU Core Clock speed 250MHz
• 64MB/128MB high-speed DDR memory
• 8 GB/sec Memory Bandwidth
• API support Microsoft OpenGL 1.3 and DirectX 8.X
• 4 dual-rending pilelines, 8 textures per clock cycle
• Dual cube environment mapping capability
• High-quality HDTV/DVD playback
• AGP 2X/4X with Fast Writes and AGP Texturing Support
• Integrated hardware lighting engine
• On-board TV-Out support up to 1024x768 resolution
• On-board DVI support up to 1280x1024
• Optional Video-In support real time video capture, video compression and video editing
Software Bundled:
• Installation CD: Driver/3Deep®/True Internet Color®/ABIT SiluroDVD
• Ulead VideoStudio (Siluro GF4 Ti4400 with VIO only)
• ABIT SiluroDVD:
To bring your DVDs and video files to life, we've included ABIT SiluroDVD.ABIT SiluroDVD combines the best visual and audio effects with advanced features such as time stretching, thumbnailed bookmarks, fully-adjustable zoom and pan, and much more. Take control of your video session with ABIT Siluro DVD.
Dus toch 2 ramdac's? :?
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
  • Tha_TE
  • Laatst online: 10-09 10:42
dual 350Mhz
dat staat er .ik zou hetm aar geloven dan :)
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 13:26 schreef Tha_TE het volgende:
dual 350Mhz
wordt wel interessant kaartje ook dan, als de ti4400 al te koop is voor €279,- :)
Hopelijk iets van €220,- ofzo :9
  • Tha_TE
Ik heb trouwens ook al een tijdje niks meer over de Leadtek GF4Ti4200 128MB gehoord ...... had die memory ook 500Mhz ?
of hoe zat dat ?
Het had namelijk ook al 8.8GB/Sec stond er ergens :)
  • Masterdam
  • Laatst online: 07-09 14:22
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 13:33 schreef Tha_TE het volgende:
of hoe zat dat ?
Het gaat er niet om hoe hoog ie standaard geclockt is, maar hoe hoog hij geclockt KAN worden :P
En daarvoor moet je reviews/ervaringen afwachten :)
Specs
  • Tha_TE
Op zondag 26 mei 2002 13:35 schreef Masterdam het volgende:
Dat klopt ben er ook benieuwd naar ....
Heeft hier iemand al zo'n ding ? :) lol
http://www.leadtek.com/graphics/a250le/a250le.htm
  • McFlipp
McFlipp
24...
of hoe zat dat ?
Komt die er dan?? Want ik heb alleen nog maar over de leadtek 64mb en de leadtek 64mb gravivo gehoord. (die laatste dus met vivo functie's die de eerste niet heeft, en je krijgt er ook nog een geintegreerde tv-tuner bij)
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 13:37 schreef McFlipp het volgende:
Woei, een Leadtek Ti4200 AIW :D
hoop dat ie een beetje interessant geprijsd wordt :)
Specs
  • McFlipp
McFlipp
24...
Hmmzz die leadtek 250le heeft volgens mij maar 1 ramdac:
• Integrated 350MHz RAMDAC, resolution up to 2048x1536, True Color @ 60Hz
ennuh nieuw deel? deze is zo groot :)
  • Tha_TE
op die leadtek site staat 64 OR 128 MB
en trouwens ze krijgen beide net zo veel bandwidth als de leadtek gfti4400
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 13:39 schreef Tha_TE het volgende:
Bandwith was toch te berekenen met snelheid-mem en bus-mem?
Dat zou dus zeggen dat de Ti4400 en de Ti4200 dezelfde clockspeeds hebben, met mem :?
Specs
  • Tha_TE
Op zondag 26 mei 2002 13:39 schreef McFlipp het volgende:
Ik heb er zelf maar 1 RAMDAC nodig sinds 2 monitoren toch niet op mijn bureau passen :)
  • Tha_TE
Op zondag 26 mei 2002 13:41 schreef Masterdam het volgende:
Nvidia GeForce4 Ti 4200 GPU features: Graphics Core 256 bit
Memory Interface: 128 bit DDR
Memory Bandwidth: 8.8 GB/sec
Peak Vertex Processing Rate (vertices/sec.): 113 million
Operations/sec: 1.12 trillion
RAMDAC: 350 MHz
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 13:42 schreef Tha_TE het volgende:
Nou ik heb nog een 14" monitor staan op zolder en die zou ik wel graag willen gebruiken tijdens het flightsimulatoren. Dus lijkt me wel interessant 2 ramdac's.
  • Tha_TE
Op zondag 26 mei 2002 13:44 schreef McFlipp het volgende:
ik heb een paar paginas terug ook gezien dat je met 1 RamDAC ook 2 monitoren kan aansluiten alleen moet je ze beiden op dezelfde bitrate of resoltie (wat er ook stond) staan...
  • Masterdam
Masterdam
aka [K40$]R0gu3
ehm... willen mensen hier lezen wie er allemaal van hun 2e RAMDAC gebruik gaan maken? Is het niet handiger of iedereen dat voor zich houdt, en dat 't 'r puur over gaat OF er een 2e RAMDAC opzit, en niet waarom Jantje of Pietje dat belangrijk of juist niet vindt :?
Specs
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 13:46 schreef Tha_TE het volgende:
Kan je dan niet alleen DVI/VGA of TV-Out/VGA gebruiken?
DVI-->VGA / VGA kan dan niet toch?
Specs
  • Tha_TE
Op zondag 26 mei 2002 13:47 schreef Masterdam het volgende:
Je hebt helemaal gelijk....
Laten we het maar zo houden.... sommige mensen vinden 2 ramDACs handiger dan andere mensen ... en andere mensen vinden 1 ramDAC al genoeg en sommige niet :)
  • McFlipp
McFlipp
24...
Ja maar ik wil mijn Piyama 17" Diamondtron niet op dezelfde resolutie enzo laten draaien als die 14" dat is mijn 17" niet waard :)
Ennuh Masterdam, rustig, adem in...............adem uit........adem in............adem uit............
Op zondag 26 mei 2002 13:48 schreef Masterdam het volgende:
Ja volgens klopt dat, en ik denk niet dat m'n 14" van 15 jaar geleden dvi heeft :+
  • draakhoofd
Op zaterdag 25 mei 2002 12:07 schreef Hooi het volgende:
Effe het topic doorlzen, dat is al een paar keer uitgelegd.
dude, met alle respect, ik heb geen halve dag om 1200 replies door te spitten.
handig zon groot forum :?
het staat ook niet in de faq
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 13:50 schreef McFlipp het volgende:
Thx, het helpt :+
Specs
kzit nu echt hevig te twijfelen tussen de / Point of View Geforce4 Ti4200 300 Mhz, 128Mb DDR Tv-Out, DVI, Dual-Head of de Leadtek 64mb DDR. Ze kosten allebei hetzelfde maar die 128 is wel erg aantrekkelijk. Overclocken en 2 monitor support en tv-out hoeft van mij niet en kvind de 2d kwaliteit van men TNT2 Ultra super goed met men Illyama Vision Master Pro 400 monitor..Welke kaart raden jullie mij aan?
en het nut van de 128mb die je in de toekomst zal krijgen zal dat kwa snelheid een overgeclockte Leadtek 64mb ovetreffen?
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 14:37 schreef K het volgende:
Die PoV draait gewoon op 250/450, dus waar die 300 op slaat?
Maar de Leadtek zal in de spellen van nu een paar % sneller zijn, (behalve met JK2, daar is de PoV juist weer sneller, en met een paar benchmarks is de PoV zelfs al 2,5x zo snel). Aan deze benchmarks kan je dus ook zien dat in de toekomst de 128MB sneller zal zijn dan een overgeclockte 64MB. Als je gewoon je kaart een poos wil houden en zeker wil zijn dat je niet binnen een jaar weer wilt upgraden, zou ik de 128MB nemen, anders kan je de 64MB nemen, en als het verschil 64/128MB groot wordt de 64MB verkopen en alsnog een 128MB kaart kopen, evt dan een Omen/R300 ofzo.
Specs
  • Tha_TE
15 Jaar geleden ?
Is het nog wel in kleur of 8 bits .... :)
[ultra-über-offtopic]
http://home.online.no/~errobs/cobsw.wmv
[/ultra-über-offtopic]
Drax, jij had toch zon point of view GF4200 kaart? waarom heb je daarvoor gekozen?
(kweet het staat ergens eerder in deze thread, maar kep geen zin om alles weer door te bladeren *D
  • The_Sentinel
of hoe zat dat ?
Volgens de nederlandse site van Leadtek heeft de TI4200 van hun maar 8GB/s memory bandwidth...dus ik denk dat die 8.8GB/s een tiep fout is....
Ook wordt er nergens gesproken over vivo-support op de leadtek kaarten dus ik denk dat je er maar beter van uit kan gaan dat dat er niet opkomt.
http://www.leadtek.nl/site/nl/pages/gc/a250le.php
WTF! Hebben we nu alweer koffiepauze!?
Max. bandbreedte 8,8GB/s
dat is wel 8.8 en nee das geen typ fout
  • Bzzje
  • Laatst online: 24-06 14:55
Bzzje
Negeren is vooruitzien
Op zondag 26 mei 2002 14:47 schreef K het volgende:
drax had de prolink pixelview ti 4200 128 mb.
Ik heb hem ook net gekocht.
Wereldding. Video out en video in en 128mb mem voor slechts 267 euro.
heeft niemand hier dan nog de point of view GF4TI4200 128MB DDR???
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 14:49 schreef The_Sentinel het volgende:
Dan moet je eens japanse en chinese sites gaan lezen :) Leadtek heeft het zelfs al in een persbericht aangekondigd dat ze ook een ti4200 met vivo en ingebouwde tv-tuner zullen produceren.
Ik ben van plan om m'n GF2 gts te verruilen voor een GF4 ti4200. Nou boeien de merken me niet zo, mits de kwaliteit gewoon goed is. Ik wilde eerst de Club 3D Geforce 4Ti 4200 64 Mb DDR/TV/DVI € 189,- gaan kopen totdat mijn oog viel op de Sparkle GF4Ti4200 128 Mb DVI/TVout + VIVO 7200T2 € 219,-. Nou heb ik wel eens van Club3D gehoord en dat schijnen wel redelijke kaarten te zijn voor een mooie prijs. Alleen die sparkle heeft ook wel veel opties en 128MB :) Maar ik heb dus nog nooit van het merk Sparkle gehoord, zijn er mensen die ervaring hebben met deze kaart en/of een url naar review weten?
Ik wil eigenlijk wel een 128MB kaart omdat ik toch van plan ben 1.5-2 jaar met een videokaart te doen. Alleen m'n budget is een beetje beperkt atm. :(
Welke 4200 128 MB kaarten lopen nou standaard op 500 mhz? Behalve de A-Open. De leadtek dus ook of niet :?
Op zondag 26 mei 2002 16:30 schreef ThaBunny het volgende:
Ja ben ik ook benieuwd naar!!
En welke is nou de "beste?!?" ti 4200 kaart met 128 mb?
De:
-De Gainward
-De Powercolor
-De Asus
-De MSI
-De Sparkle
-De Abit
-De leadtec
Ik heb een aantal pagina's doorgelezen maar Kom er maar niet uit!
Mijn eisen voor die kaarten zijn:
*Overclockbaarheid
*Uitrusting
*Prestaties
Zou je ook een top 5 kunnen maken hiervan? welke de "BESTE?!?" is.
Misschien dat dit voor meerdere mensen fijn is, een kleine samenvatting
ik zou graag weten welke van de goedkopere het beste is
  • draakhoofd
wat is nou de goedkoopste Ti4200 64MB met Video In EN Out (ViVo)? Is dat die Gainward van 219 euro?
  • McFlipp
McFlipp
24...
Kunnen jullie allemaal zelf niet gewoon dit topic doorlezen of een review? het staat er allemaal al in hoor.
De Sparkle GF4Ti4200 128 Mb DVI/TVout + VIVO 7200T2 geloof ik ook.
  • Loev
  • Laatst online: 14-09 08:47
Ik kan een Gainward Geforce 4 TI 4200 64 Mb kopen voor € 219
Dit zijn de specs denk ik. (stonden er 2 op de gainward site)
29
30
31
32
33
34
35
36
37
38
39
40
Integrated nVIDIA GeForce4 Ti4200 the most powerful GPU.
Support 128/64MB high-speed 128bit DDR RAM/SDRAM memory.
Support high quality TV-OUT.
TV-out connector support S-VHS mini Din and one RCA jack.
DVI on board support up to 1600x1200 resolution.
AGP 2X/4X AGP support and easy Plug-and -play
AUTORUN installation From CD-ROM include.
Specifications
Support nfiniteFX TM II Engine for full programmability.
NVIDIA nView TM Display Technology
provides flexibility an control for using multiple displays.
Accuview TM Antialiasing
delivers unbeatable visual quality and frames rates.
Dual Programmable Pixel product surface
details never before seen on the desktop
Integrated 32-bit color and 32-bit Z/Stencil Buffer.
Integrated Cube environment mapping,
and true reflective bump mapping.
Multibuffering (double, triple, quadruple) for smooth animation and
video playback.
Video-out support (NTSC/PAL) TV system.
It can providing best-of-class TV-out functionality up to 800x600
resolutions.
Support LCD output with DVI connect, the
resolution up to 1600x1200
En nog even een plaatje.
Afbeeldingslocatie: http://www.gainward.com/us/products/images/GF4-Ultra650TV_gs_320x240.jpg
Is die cooler niet wat klein of maakt dat geen fuck uit? (nee ik ga niet overclocken)
Dus is het wat of moet ik de kaart lekker in de winkel laten liggen? :)
[EDIT]Woops layout verneukt even maken
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 17:47 schreef DarkJedi het volgende:
*knip*
Is een prima kaartje! En die cooler is zeker niet te klein hoor, ookal ga je niet overclocken hij zal er geen probleem mee hebben :)
Over die gainward..jongen, niemand heeft die kaart nog, dus niemand kan er wat over zeggen. We kunnen alleen zeggen dat gainward een goed merk is, en je ze zonder risico kan kopen.
En dat plaatje dat je laat zien is van een Golden Sample, en die kosten ietsje meer dan 219 euro (ongeveer 300 dus).
En nee, die cooler maakt geen fuck uit, grootte zegt niets, die cooler is goed.
Blader de 58 pagina's nog eens door als je er meer over wilt weten :).
Sparkle gebruikte op hun g4mx kaarten 4ns Samsung geheugen, dus ik neem aan dat dat ook op hun ti4200 zit :)
Ik zie het volgende week wel.
Vond nog een interessant berichtje:
23.05.2002 - 11:35 - 64-MB-Grafikkarten mit Geforce4 Ti-4200 haben einer Speichertakt von 250 MHz DDR (500 MHz effektiv). Richtig? Falsch! Nvidia hat die Spezifikationen für die neuen Geforce4-Ti-4200-Karten offensichtlich kurzfristig geändert. Im Testlabor erlebte die Redaktion von PC Games Hardware eine Überraschung: Von vier Karten namhafter Hersteller waren drei dabei, die mit 513 MHz effektivem Speichertakt liefen. Die Nachfrage beim vierten Hersteller ergab, dass auch hier die Taktfrequenzen noch nach oben korrigiert werden.
Die Änderung von 500 MHz auf 513 MHz geht Hand in Hand mit einer neuen Chipsatzrevision. Die 500-MHz-Karten haben die Revision NV25 A2, die neuen 513er-Karten NV25 A3. Die Chipsatzrevision lässt sich mit dem Tool Powerstrip auslesen. In grafiklimitierten Situationen sind die neuen Karten damit bis zu drei Prozent schneller. Wichtiger ist jedoch, dass mit der Erhöhung des Speichertaktes der Leistungsabstand zu 100 Euro teureren Ti-4400-Beschleunigern auf nur noch maximal 7 Prozent reduziert wurde. Wenn Sie den MHz-Schieberegler bei einer Ti-4200 nur leicht nach rechts ziehen, haben Sie schon die Leistung einer Ti-4400 und dabei dick Geld gespart.
Ob Ti-4200-Karten mit Chiprevision A2 in den Handel kommen, ist eher unwahrscheinlich. Allerdings sollten Käufer einer Ti-4200 auf jeden Fall einmal Powerstrip starten (www.entechtaiwan.com), mit einem rechten Mausklick auf das Powerstrip-Taskleistensymbol den Punkt Optionen aufrufen und dort Geräte-Informationen anwählen. Hier sollte unter Karten-ID Rev A3 auftauchen.
  • MTops
  • Laatst online: 21-09-2020
MTops
Just being me...
Ik was ook van plan om een Ti4200 te halen, krijg ik ineens een aanbieding in m'n schoot geworpen:
Creative GeForce4 Ti4600 voor 299 euro...
Klinkt lekker... Ik denk dat ik daar maar voor ga...
Heeft iemand ervaring met dat kaartje?
Nostalgie is ook niet meer wat het geweest is...
  • PhatFish
PhatFish
and, uhm......Moo
Op zondag 26 mei 2002 18:14 schreef MTops het volgende:
Geen ervaring, maar dit is dus zo'n aanbieding die je niet mag weigeren. DOEN DOEN DOEN >:) >:) >:)
  • Masterdam
Masterdam
aka [K40$]R0gu3
Op zondag 26 mei 2002 18:20 schreef PhatFish het volgende:
mwah, 20% meer snelheid en een mooi merkje voor 40% meer geld... Zou je kunnen doen ja, waar heb je die aanbieding eigenlijk vandaan?
Specs
  • SS_Trunks
  • Laatst online: 16-10-2025
Ik ga woensdag eens kijken bij Computerland, Etelcom, Crazy Hans, PCL, Fascom, Dimension en Completer kijken. Als ze die kaart daar niet hebben heeft ATI er weer een klant bij ;(
Als iemand nog meer zaken in Rotterdam weet waar ze die kaarten verkopen hoor ik het graag.
<a href="http://eu.playstation.com/psn/profile/Brollipower/"><img src="http://mypsn.eu.playstation.com/psn/profile/Brollipower.png" border="0" /></a>
  • Loev
Bedankt voor alle reacties.
En een Geforce 4 TI 4600 voor € 299 is zeker van de vrachtwagen gevallen ;)
  • MTops
MTops
Just being me...
Nope, interne actie speciaal voor medewerkers... :)
  • Janssen
  • Laatst online: 09-08-2024
ik ga binnenkort ook een ti4200 of 4400 kopen maar ik wil eigenlijk wel zeker weten dat het werkt icm mijn kt7a. ik heb namelijk nog geen geld om m'n cpu/mobo te upgraden.
  • SkoolieDie
Als je vooruit betaald bij een bestelling uit Duitsland, krijg je je geld dan terug als je pakket onderweg 'kwijtraakt' :?
Ik ga er vanuit dat ze de zending aangetekend versturen, geen handtekening betekend dan geld terug of nogmaals een kaart versturen.
Psies, ik zit echt zwaar te balen.
wat ik wel begrepen heb van alle forums die ik tot nu toe heb doorgespit dat als je je agp op 2x in je bios zet ( oftewel 4x disabled ) dat het dan goed en stabiel werkt.
verder staat er overal vermeld dat agp 4x maar een minimale performance winst geeft, dus dat het geen bal uitmaakt of je nou op 2 of 4x agp werkt. ( het klinkt alleen zo zuur 2x agp ipv 4x scheelt toch de helft :? )
Dahm.. hij was nie op voorraad... me Ti4200 hij zal komende week wel komen denk ik >:)
Tzal wel veel verschil opleveren met me TNT2 denk ik ;)..
Btw zou ik spellen dan met minder moeite kunnen spelen, of moet ik ook binnenkort de rest van me systeempje upgraden (AMD 950@1050, 384Pc133 ram ASUS A7V MoBo)...
  • Chakotay
  • Laatst online: 06:47
Chakotay
Lick here to continue
* Chakotay heeft er ook een op de zoewarte markt gehaald, Prolink 128MB :)
250 core 444 mem, ViVo en dual RAMDAC, €267 :)
Erin geprikt, hij vond automagisch driverts, 3dmark gestart, 8449 zonder enige vorm van tweaking :) 10k zit in de mogelijkheden denkik dus :)
Stichting eth0
  • SS_Trunks
Op zondag 26 mei 2002 19:27 schreef ZaPpZ het volgende:
Nou, ik denk dat je TNT2 sneller is hoor ;) Spellen die gebruik maken van Directx 8 functies zullen aanzienlijk sneller lopen, maar je cpu begint al een serieuze bottleneck te worden.
Op zondag 26 mei 2002 19:37 schreef SS_Trunks het volgende:
Absoluut niet. Het zal wat schelen maar niet zo veel. Een 1ghz is in iedergeval geen 'serieuze bottleneck'.
  • RubZie
  • Registratie: Juli 1999
  • Laatst online: 27-08 10:23
Wie weet er welke tv chip er op de Point of view GF4 Ti4200 zit, of die goed is, ...
Usarchy: nieuws over usability en online marketing
Op zondag 26 mei 2002 18:57 schreef Janssen het volgende:
Ik mag hopen van niet want ik heb ook nog een abit kt7(a)
Een fantastisch bordje daarnie van maar anders toch wel een beetje jammer he' :(
absoluut een fijn bordje!!
las alleen ook in de viahardware forums ed dat er veel probs waren :(:(
http://forums.viahardware.com/messageview.cfm?catid=29&threadid=13318&STARTPAGE=1
Kan iemand me vertellen waar die zoewarte markt precies zit? en hebben ze ook een illegaal telefoonnummertje? En hebben ze nog kaartjes op voorraad?
  • PhatFish
PhatFish
and, uhm......Moo
Op zondag 26 mei 2002 21:08 schreef aMb1983 het volgende:
Gewoon de "zwarte markt" in Beverwijk. Is nix (of niet veel) illegaals te vinden hoor, het heet gewoon zo, kweenie waarom.
  • PhatFish
PhatFish
and, uhm......Moo
Dat is dus gigantisch gelul. Het zal in games wel te merken zijn, dat de CPU "langzaam" is, maar het is echt niet zo dat een TNT sneller is dan dat. Het gaat hooguit 30fps schelen in games. Maar wat is het probleem dan, als de fps toch al in de 100 zit?
Ik zit hier ook op een 1GHz, ik heb rustig een GF4 besteld. Kan die ten minste nog mee in m'n volgende upgrade.
  • Royz
  • Laatst online: 17-09 07:33
Royz
Kleurenblind!!
Hey AMB, als je woensdag ook vrij bent kunnen we die Leadtek in Beverwijk ergens proberen te vinden ;x. Hehhehe :9~
Fotografie kanalen: Website - Royz.nl | YouTube - @Royz.nl | Instagram - @Royz.nl.
  • SkoolieDie
Op zondag 26 mei 2002 19:22 schreef IceFlame het volgende:
Bedankt, ook een mailtje gestuurd met deze vraag.
Scheelt toch een berg geld vgm Nederland
volgens mij was het niet serieus bedoeld ;), zoiets heet ironie :)
  • PhatFish
PhatFish
and, uhm......Moo
Op zondag 26 mei 2002 21:52 schreef DumphuiZ het volgende:
Oh sorry, ik ben een beetje te seriues en chagrijnig vandaag...te lang uitgeslapen, heb ik wel vaker. Ik doe nu m'n huiswerk en ik snap alles enzo, maar ik heb gewoon niet de concentratie om verder te werken. Ben echt met het verkeerde been uit bed gepleurd.
Op zondag 26 mei 2002 21:55 schreef PhatFish het volgende:
shit happens :)
  • SS_Trunks
Jongens, met dit ;) teken geef je soms aan dat je het niet helemaal serieus bedoeld, gesnopen! :+
  • STi
  • Laatst online: 02-08-2024
STi
Kan iemand mij trouwens vertellen hoe het met het geluidsniveau van de koeler gesteld is? Ik heb net m'n comp een stuk stiller gemaakt, dus het lijkt me behoorlijk minder prettig als ie nu weer gaat loeien door die Ti4200...
* STi is vooral geinteresseerd in de sparkle of club3d
Ik krijg morgen mijn Gainward ti 4200 128 mb golden sample binnen. Kostte me 315 euro bij Driebond in Groningen. Niet het goedkoopste kaartje, maar er zit wel alles op en aan. Ook is ie al op diverse sites overclocked tot ongeveer ti 4600 niveau. Dan is het niet echt duur. Het gaat mij ook om het 2d beeld en dat schijnt ook er goed te zijn bij de Gainward. Ik zal mijn bevindingen even posten morgenavond.
Sorry....
Ik wilde een van de drie Radeons aanschaffen bij mijn leverancier. Maar nu hoor ik veel goed en wat min puntjes over de Geforce Ti4200. Ik gebruik mijn P4 met rimm geheugen zo'n 10 uuur per dag voor fotobewerkingen en ander grafisch werk. Wat zal nu mijn beste keuze zijn, wel met tv-out en div.
Club3D ATI Radeon 8500 128DDR DVI/TVOut 272,66
Club3D ATI Radeon 8500 64DDR DVI/TVOut 209,74
Club3D ATI Radeon 8500 64DDR PRO DVI/TVO 236,30
*D
  • Doogie
Als je van Amsterdam omhoog rijdt richting Beverwijk staat het aangegeven op de borden. Kan niet missen.
Toch maar zo'n Sparkle GF4Ti4200 128 Mb DVI/TVout + VIVO 7200T2 besteld bij alternate :)
Hopelijk is het wat..
  • Chakotay
Chakotay
Over die zwarte markt, het is gewoon een soort computerbeurs die elk weekend is, met vaste stands van sommige winkels. Veel zooi, maar ook een paar goede.
De enige stand die de Ti4200 had was BoerBoon computers, met de Prolink die hier nu loopt te zoemen. De overige stands beginnen te zeuren dat ik beter een GF3 kan kopen...
Op woensdag gaan is redelijk pointless, het is nl alleen in het weekend open :)
Over die prolink, ik heb em nu probleemloos op 300/550 draaien, de 128 MB versie dus :) Dat is dus tussen Ti4400 en Ti4600 niveau in, netjes voor een kaart die standaard op 250/444 draait :) (powerstrip gaf trouwens toen ik em er net in had zitten 459 aan ipv de 444 die op de doos staat, maargoed...)
De ViVo opties moet ik nog testen, ff een tv met iets meer aansluitingen dan alleen coax regelen :P
Stichting eth0
Op zondag 26 mei 2002 22:49 schreef Chakotay het volgende:
Laat me raden, je hebt niet de nieuwste nVidia drivers :P
  • Royz
Royz
Kleurenblind!!
Op woensdag gaan is redelijk pointless, ht in nl alleen in het weekend open :)
:( Jammer. Deze week zal de rest hem ook wel verkopen denk ik. Het is eind mei/begin juni de komende dagen. Hmmzzz ik zie het nog wel...
  • Chakotay
Chakotay
Op zondag 26 mei 2002 22:52 schreef DumphuiZ het volgende:
28.90, zometeen even 29.40+fix installen :)
Welke zijn eigenlijk het snelste voor de GF4?
Stichting eth0
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 23:00 schreef Chakotay het volgende:
Weenie denk de laatste, tja heb nu een gf1 dus daar let ik niet zo op hoe de dribers op een gf4 draaien nu ;)
  • McFlipp
McFlipp
24...
Trouwens die prolink is nu ook eindelijk online te bestellen bij boerboon :)
  • Chakotay
Chakotay
Op zondag 26 mei 2002 23:17 schreef McFlipp het volgende:
Toen ik em kocht zei de verkoper dat ze em al 2 weken hadden...
Gare naam heeft die tent trouwens :)
Stichting eth0
  • McFlipp
McFlipp
24...
Op zondag 26 mei 2002 23:21 schreef Chakotay het volgende:
ja klopt je kon hem al 2 weken ophalen daarzo, maar ze waren nog bezig met hun online shop, en je kan nu eindelijk naast inktpatronen, 1 vga kaart bestellen, de prolink :)
* McFlipp ergert zich eraan dat de sparkle site down is :(
  • Chakotay
Chakotay
Op zondag 26 mei 2002 23:24 schreef McFlipp het volgende:
lol :)
Bij die stand hadden ze wel een redelijk assortiment... verschillende merken vidkaarten, mobo's, geheugen, proc etc. En wel vriendelijke verkoper ook.
Stichting eth0
  • Chakotay
Chakotay
Ok... 315/575 nu :9 Alleen even met Quake3 getest, zag gen artefacts... Zometeen ff 3dmark of code creatures doen :)
Stichting eth0
Op maandag 27 mei 2002 00:26 schreef Chakotay het volgende:
Wauw 575 op een 128mb kaart ?? :)
  • Chakotay
Chakotay
Op maandag 27 mei 2002 00:32 schreef DumphuiZ het volgende:
Ja, is alleen in zware games niet helemaal lekker... Quake3 enzo gaat er probleemloos mee :)
Stichting eth0
Waar haal je die 29.40+fix vandaan? Heb al wel die 29.40 gevonden, maar wist ook niet dat er een fix nodig is...
  • Chakotay
Chakotay
Op maandag 27 mei 2002 01:26 schreef Ventje23 het volgende:
Fix doelt op refreshratefix, hier :)
Stichting eth0
  • FullThrottle
  • Laatst online: 27-07 12:41
FullThrottle
Tonight's forecast,... dark!
Ook ik heb vandaag in Beverwijk zo'n Prolink Pixelview 4200 128MB gekocht.
Het verhaal van Chakotay dat het geheugen hoger geclocked staat kan ik bevestigen. Bij mij stond hij op 460
Verder een prima kaart. Mijn eerste resultaten:
Duron 800Mhz met 192MB SDRAM
5875 zonder overclocken
P4 1.4Ghz met 384MB RDRAM
7410 zonder overclocken
7789 overclocked 315/540
Met het geheugen op 550 krijg ik fouten in de weergave. Volgens mij moet de core nog iets hoger kunnen. Veel zin heeft het niet echt want volgens mij is de procesor hier de bottleneck.
Wat de 2d beeldkwaliteit aangaat is deze kaart duidelijk beter in hogere resoluties dan de Leadtek Geforce 2MX die hiervoor in de P4 zat. Hoe zich dat verhoud tot bijvoorbeeld een Radeon durf ik niet te zeggen
AMD Ryzen 9 5950X | MSI RTX 3080 Gaming X Trio 10G | 64GB G.Skill Trident Z RGB DDR4 @3600CL16 | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 1TB | MSI MEG X570 Unify | Fractal ION+ 860W Platinum | be quiet! Pure Base 500DX | be quiet! Dark Rock Pro 4
  • McFlipp
McFlipp
24...
Op maandag 27 mei 2002 01:23 schreef Chakotay het volgende:
Wat bedoel je? Zie je dan artifacts? Of is de fps dan te laag ofzo?
  • VonFoX
  • Laatst online: 26-07 09:00
VonFoX
Las noches de Diciembre
Is er ergens iets te vinden over de CPU scaling van die kaarten? Vraag me af of ik veel winst krijg op mijn p3 733 met 512 mb tov mijn huidige geforce 1 SDR (na de vakantie komt er een XP 2100 :9 )
Yo.
  • draakhoofd
Op maandag 27 mei 2002 08:11 schreef VonFoX het volgende:
Je gaat zeker wel vooruit denk ik, ik heb ongeveer dezelfde setup, alleen dan 800mhz.
/ff offtopic// hier kun je directx9 beta dl:
** dit is een private beta, niet met deze links strooien aub **
  • STi
STi
Als je geinteresseerd bent in de cpu scaling kan je 'es op Anandtech kijken bij hun "Sub-$200 Video Card Roundup - April 2002" onder video...
* STi weet de ballen van html dus geen linkjes... |:( sjorry
Ik ben van plan om vanmiddag 3 gf4 ti4400's uit duitsland over te laten komen, ik wil alleen wel zeker weten dat ze het pakketje aangetekend verzenden, zodat niet onderweg het pakketje "foetsie" is geraakt en ik mijn vooruitbetaalde euro'z kwijt ben!
Hoe vertaal je aangetekend (alsin een aangetekende verzending ;)) in het duits en engels?
Was eigelijk de enige leverbaar 2 weken terug. Eerst hebben we (2 vrienden van me en ik) ons te pleuris gezocht op internet naar reviews van Prolink kaartjes, ze kwamen met heel veel van hun kaartjes altijd al goed uit de reviews.
vervolgens heb ik gebeld met de winkel die ze leverde (boerboon) en heb ze gevraagd wat voor geheugen er op die kaartjes zit. Toen hoorde ik dat het om 4ns Samsung DDR geheugen ging, zelfde als op de Gainward GF4 128MB Golden Sample. Bovendien heeft die Prolink (in tegenstelling tot meeste andere GF4 kaartjes) Video in/out.
Ondertussen hebben we nu dik 2 weken onze kaartjes in huis en we zijn alle 3 super blij.
(Uitstekend 2D beeldkwaliteit, prima te overclocken, en de fan is lekker stil. :9 :9 )
edit: Ik heb geheugen nog niet obven de 540 gehad, durf ik niet maar vriend van me kon 3dmark2001se stabiel draaien met core 315 / mem 570
(Tja, hij is dan ook een "echte tweaker", altijd zover mogelijk pushen.. :P :9 )
  • Bzzje
Bzzje
Courage: is het een idee om de "ervaringen" in een ander topic te plaatsen dan de "vragen over waar te koop en zo?"
Er lopen nu een beetje twee discussie door elkaar heen.
Mensen die, net als ik, nu net een ge-force 4 ti 4200 gekocht hebben, willen graag weten wat er uit te slepen is qua overclock en drivers.
Anderen willen graag weten wat welke kaart kost en waar die te koop is. Zoals je ziet zijn er weinigen geïnterresseerd in het lezen van 60 pagina's (25 ppp) en dus plaatsen ze gewoon meteen hun vraag, zonder te kijken of die al beantwoord is.
edit: ik denk, ik vraag het hier eerst even, voordat een nieuwe draad dichtgegooid wordt
ok, ik was niet helemaal wakker 2 postings terug.. ik heb dus inderdaad de Prolink, niet een point of view... :)
  • Dubbeldrank
Dubbeldrank
Get lucky!
60 Pagina's dat gaat lekker snel, ik wil ze niet allemaal doorlezen. Maar ik wil wel een Ti4200 aanschaffen met 128Mb :) maar welke moet ik nou hebben met overclocken in gedachte en een goede TV-out kan ook geen kwaad. Ik had er 3 op het oog de Prolink, de Sparkle of de Point of View, ik weet dat de Prolink Samsung geheugen aan boord heeft is dit dan ook de beste van deze 3 ???
Alvast bedank ! :)
It takes one to know one...
neuh, hij heeft zo'm prolink geval. Ik heb wel een point of view geforce 4 4200 128mb van het weekend gekocht (€250). Waarom ik daar voor heb gekozen, nou omdat ie leverbaar was en ik niet meer langer wou wachten. Prima kaartje hoor!
