errot.txt bij Personal Proxy
What's wrong?
Kan iemand mij dit vertellen.
[1995-01-01 13:22:58] distributed.net Personal Proxy (build 318)
[1995-01-01 13:22:58] Visit http://www.distributed.net/ for details.
[1995-01-01 13:22:58] Proxy starting up.
[1995-01-01 13:22:58] Verbosity set to: general stats keyblock server client buffers timestamp attention errlow errsevere (3519)
[1995-01-01 13:22:58] rc564-in: limits adjusted to min 1, max 20
[1995-01-01 13:22:58] desII-in: limits adjusted to min 1, max 20
[1995-01-01 13:22:58] csc-in: limits adjusted to min 20, max 100
[1995-01-01 13:22:58] Notice: connectivity mode is normal
[1995-01-01 13:22:58] Notice: Loaded 0 ignoredip addresses from ini file
[1995-01-01 13:22:58] Notice: Loaded 0 allowedip addresses from ini file
[1995-01-01 13:22:58] socket(): (WSAESOCKTNOSUPPORT): The specified socket type is not supported
[1995-01-01 13:22:58] Error: Cannot setup primary listener on port 2064!
[1995-01-01 13:22:58] Status: Uplink needed... (thresholds exceeded)
[1995-01-01 13:22:58] Status: Creating uplink (outgoing server) connection.
[1995-01-01 13:22:58] rc564 r=0/20, d=0/3, 0.0 Mkeys/sec, tot=0
[1995-01-01 13:22:58] ogr r=0/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
[1995-01-01 13:22:58] Status: Uptime: 0.00:00:00, 0 listeners, 0 uplinks
[1995-01-01 13:22:58] Status: 0 active clients (peak: 0, mean: 0.00)
[1995-01-01 13:23:00] socket(): (WSAESOCKTNOSUPPORT): The specified socket type is not supported
[1995-01-01 13:23:00] Uplink: [1] connection to 0.0.0.0 changed state
from 0 (ESTNONE) to 51 (ESTDEAD)
[1995-01-01 13:23:00] Uplink: [1] Closed connection to 0.0.0.0.
[1995-01-01 13:23:00] rc564 r=0/20, d=0/3, 0.0 Mkeys/sec, tot=0
[1995-01-01 13:23:00] Status: rc564: Last uplink sent 0 and received 0
[1995-01-01 13:23:00] ogr r=0/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
[1995-01-01 13:23:00] Status: ogr: Last uplink sent 0 and received 0
[1995-01-01 13:23:00] Status: Uptime: 0.00:00:02, 0 listeners, 0 uplinks
[1995-01-01 13:23:00] Status: 0 active clients (peak: 0, mean: 0.00)
[1995-01-01 13:23:28] Status: Shutting down listeners...
[1995-01-01 13:23:28] Status: Closing client connections...
[1995-01-01 13:23:28] Status: Closing uplink connections...
[1995-01-01 13:23:28] *Break* Initiating shutdown.
[1995-01-01 13:23:28] Shutting down contests.
[1995-01-01 13:23:28] Proxy shutdown complete.
Ik heb de ballen verstand van die pproxies, maar het lijkt erop dattie geen uplink (vgl. uploaden) kan maken (Firewall, internet/LAN-verbinding, provider down ?).
  • 0rbit
  • Laatst online: 22-09 12:16
Draai je zelf geen proggels die poort 2064 dichtgooien? Gebruik je win2k?
Ik ben geheel voldaan, dank u wel!
plaats eens de complete ini file zodat daar eens naar gekeken kan worden.
Vertel ook even of je een router/firewall gebruikt en zelfs of er een virus scanner actief is.
Als je al deze dingen laat weten dan kunnen andere je hopenlijk beter/sneller helpen.
