WSAESOCKTNOSUPPORT
  • 111 views sinds 30-01-2008
  • Rixard
  • Laatst online: 15:51
Waarom krijg ik de Personal Proxie door de school's Firewall ?? :(
als ik kan surfen kan ik toch ook die proxie er door heen rammen ??
het gaat om ongeveer 350+
Celerons 433 ! (1Mkey p/s ieder :) )
ik krijg de volgende meldingen:
[1995-01-01 13:22:58] distributed.net Personal Proxy (build 318)
[1995-01-01 13:22:58] Visit http://www.distributed.net/ for details.
[1995-01-01 13:22:58] Proxy starting up.
[1995-01-01 13:22:58] Verbosity set to: general stats keyblock server client buffers timestamp attention errlow errsevere (3519)
[1995-01-01 13:22:58] rc564-in: limits adjusted to min 1, max 20
[1995-01-01 13:22:58] desII-in: limits adjusted to min 1, max 20
[1995-01-01 13:22:58] csc-in: limits adjusted to min 20, max 100
[1995-01-01 13:22:58] Notice: connectivity mode is normal
[1995-01-01 13:22:58] Notice: Loaded 0 ignoredip addresses from ini file
[1995-01-01 13:22:58] Notice: Loaded 0 allowedip addresses from ini file
--------------begin vage melding----------
[1995-01-01 13:22:58] socket(): (WSAESOCKTNOSUPPORT): The specified socket type is not supported
[1995-01-01 13:22:58] Error: Cannot setup primary listener on port 2064!
[1995-01-01 13:22:58] Status: Uplink needed... (thresholds exceeded)
[1995-01-01 13:22:58] Status: Creating uplink (outgoing server) connection.
----------------einde-----------------------
[1995-01-01 13:22:58] rc564 r=0/20, d=0/3, 0.0 Mkeys/sec, tot=0
[1995-01-01 13:22:58] ogr r=0/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
[1995-01-01 13:22:58] Status: Uptime: 0.00:00:00, 0 listeners, 0 uplinks
[1995-01-01 13:22:58] Status: 0 active clients (peak: 0, mean: 0.00)
[1995-01-01 13:23:00] socket():
[1995-01-01 13:23:00] Uplink: [1] connection to 0.0.0.0 changed state from 0 (ESTNONE) to 51 (ESTDEAD)
[1995-01-01 13:23:00] Uplink: [1] Closed connection to 0.0.0.0.
[1995-01-01 13:23:00] rc564 r=0/20, d=0/3, 0.0 Mkeys/sec, tot=0
[1995-01-01 13:23:00] Status: rc564: Last uplink sent 0 and received 0
[1995-01-01 13:23:00] ogr r=0/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
[1995-01-01 13:23:00] Status: ogr: Last uplink sent 0 and received 0
[1995-01-01 13:23:00] Status: Uptime: 0.00:00:02, 0 listeners, 0 uplinks
[1995-01-01 13:23:00] Status: 0 active clients (peak: 0, mean: 0.00)
Het probleem is dat de firewall poort 2064 dicht heeft gedouwd.
Probeer de pproxy eens te laten kijken op poort 80
Ook dit hoeft geen oplossing te zijn als de firewall poort 80 naar 1 kant open heeft staan zodat er geen handshaking kan plaats vinden.
Probeer dit eens uit en mocht het niet helpen plaats in deze draad je bevindingen en er is dan vals wel iemand die hier sneller een antwoord op geeft.
  • Rixard
Ik heb zelf ondertussen ook al een beetje zitten rondneuzen...
(ook in andere forums)
en ik ga het morgen op school
inderdaad proberen via:
[KeyServer]
ipaddress=proxy80.dsmarty.com
port=80
connectperiod=600
connectivity=normal
uuehttpmode=2
httpproxy=wwwproxy.van.de.school
httpport=80
Ik hoop dat het lukt... :)
want systeembeheer heeft helemaal een router
moeten configureren om mij een kans te geven
ik moet alles zelf installeren van server tot de clients.... (damn 350!!)
ik hoop dat Systeembeheer zo aardig wil zijn
om ff dat copieren in een aanmeld script te zetten
(ff copieren van dnetc.exe en inf)
In totaal gaan draaien:
Duron 900 (3 Mkeys)
+/- 350 Celerons 433(NT/W95)(1 Mkey)
29 Cyrix150+ (0.2 Mkeys)
12 P133 (0,18 Mkeys)
1 K62-300 (0.5Mkeys)
2 P90 (0.2 Mkeys)
1 486DX4-100 (W95)(Personal Proxy)
ps. mijn user gaat NPC heten
school naam : Noorder Poort College
distibuted naam: Noorder Power Cows :)
Pas onder het volgende kopje in de pproxy.ini file het volgende even aan:
[rc564]
logfilekeyblock=pproxyrc5
logfilekeyblockrotation=daily
minkeysready=3000
maxkeysready=300000 ; genoeg voor ongeveer 2 dagen (berekent via anandtech pagina)
minkeysdone=0
maxkeysdone=1000
expertmode=1
Ik ga hier uit van 24/7 draaitijd.
Ik kom dan via de pagina van anandtech uit op minimaal 140240 blokjes per dag.
Al doe je maar een 10/5 dan is dat nog genoeg voor een 292167 blokjes per week.
Die 300.000 als maxkeyready is voor het meest ongunstige geval dat de boel 24/7 werkt en jou keyserver niets kan halen.
Dit kan/mag dus lager zijn
Mocht dit als nog niet aan de gang gaan laat dan even weten, desnoods via ICQ mailtje welke proxy-server/NAT-ruoter jullie op school gebruiken, misschien dat ook hier eventueel hulp geboden kan worden.
Oja, de pagina van anandtech die ik bedoel is http://teamanandtech.dhs.org/speed.asp
  • Sir Abarth
  • Laatst online: 18-01-2024
Sir Abarth
The secret word is: ToeT!
<BLOCKQUOTE><font size=1 face=Verdana, Arial, Helvetica>quote:</font><HR>ik moet alles zelf installeren van server tot de clients.... (damn 350!!)[/quote]Je moet er iets voor over hebben...:P
Trouwens, is het al gelukt?
ToeTerdeToeTToeT! | May the ToeT be with you | There is no ToeT | specs
Still the gentleman ;)
[Clan of ToeT]
  • ragger78
  • Registratie: September 1999
  • Laatst online: 20-06-2025
ragger78
ehm...ja
de foutmelding WSAESOCKTNOSUPPORT geeft aan dat het type voor de netwerkverbinding (socket) niet ondersteund wordt.
Is er wel tcpip geinstalleerd ?
  • Sequence
  • Laatst online: 27-05-2024
Sequence
Online marketing
good luck my boy! dat zijn een heleboel MKeys :)
Het probleem bij Rixard is al opgelost. :)
Was inderdaat het ontbreken van TCP/IP. :(
  • Sir Abarth
Sir Abarth
:) mooi!
Wanneer zien we de eerste stats?
[Clan of ToeT]
/me is benieuwd!
  • Rixard
De Personal Proxy draait inmiddels.. stats
zijn alleen nog niet beschikbaar, omdat ik het van systeem beheer eerst als test moet laten draaien in een lokaal met +/- 30
Cyrix 150+ (0,22Mkeys)
als dit goed draait (en dat doet het) wordt het geinstalleerd op de rest van de pc's (ik hoef het gelukkig niet meer zelf te doen :)
De Paashaas gaat ook meewerken aan de
Noorder Power Cows, hij is een systeembeheerder en heeft ook nog wel wat pc's over om te laten draaien :P
Dus die stats .. dat komt wel in orde..
ik verwacht dat tegen het einde van komende week (eerste week van oktober)wel de eerste resultaten te zien zijn... :P
Groeten Richard en Marnix
  • 0rbit
  • Laatst online: 22-09 12:16
*klap klap klap* :))
Ik heb vandaag zo aan de stats gesleuteld dat wij nu op onze statspagina kunnen zien hoeveel blokjes er in de proxy zitten :)
Ik ben geheel voldaan, dank u wel!
  • Rixard
Waar kan ik die stats van je vinden dan ??
  • 0rbit
http://130.89.221.201 :)
Kijk bij Per Host voor de proxyinhoud :)
  • Rixard
"waar kontneuken ggen sex is"
???? wat is dat voor een vage spreuk ????
het staat op je pagina ? (als je dat nog niet wist)
  • DSmarty
Hij bedoeld dat hij vaak GEEN sex heeft ;)
  • 0rbit
Tja... studentenflat he... Kontneuken is natuurlijk geen sex... :) Alleen vaginale sex is sex; En over mijn sexleven gesproken; ik heb gewoon een vriendin hoor... :)
Druk trouwens op Refresh voor een andere spreuk :)
  • Rixard
He Dproxy :) ik maak nu gebruik van je proxy bij ond op school.. 80 is de enige poort die door de router heen komt.. van het schoolnetwerk het internet op... dus bedankt :)
