Fifa 2002 TCP/UDP port???
  • 157 views sinds 30-01-2008
Ik ben al een tijdje opzoek op het internet om te achterhalen welke TCP en of UDP porten fifa2002 gebruikt.
Een vriend van me zit achter een Firewall en die wil graag met mij online gamen (fifa 2002) :)
Alleen hij komt er niet doorheen. Als ik nou weet welke porten FIFA 2002 gebruikt kan hij dat in zijn firewall aangeven en kan hij wel het internet op met Fifa :)
al vast bedankt,
XXX3
  • Zephyer
  • Laatst online: 08:50
Eh...
It is recommended to check with your network administrator or a network specialist before troubleshooting your network. These steps are not for the novice user and no items should be changed if you are not sure what they do. Electronic Arts will not be responsible for any damage done to your computer or network by following these troubleshooting steps. These network troubleshooting steps are for network multiplayer games and not for internet, modem-to-modem or serial play. Making a change to your network settings will usually ask you to insert the Windows CD, so make sure you have it nearby.
Determine your network adapter's manufacturer and model. You may want to make sure that you have the most recent drivers for your network adapter, which you can get from the network adapter manufacturer's site.
Next, make sure you have the proper network protocols installed. IPX and TCP/IP are the most popular protocols used with games. To check which protocols you have installed, right-click Network Neighborhood and select Properties. Here you will have a list of services, network adapters and protocols. You can double-click any items on the list to find out more information about it and change the options of the protocols.
Find out the multiplayer protocol that the game supports. This can usually be found on the bottom of the box in the minimum requirements section. In the Network Neighborhood properties, make sure the proper protocols are installed.
If the game uses IPX for it's multiplayer, make sure 'IPX/SPX compatible protocol' is installed. If it is not in this list, you will need to Add it. If the protocol is not installed, usually you will not be able to see other players or games in the lobby. Once it is added to the list, double-click it and make sure all the options are correct. In the IPX/SPX-compatible protocol properties, click the advanced tab and make sure the Network Address is the same for all computers on the network. By default, the number is usually 0. The Frame Type should be left on Auto or Ethernet 802.3. If the computers used on the network are of greatly varying speeds, and the gameplay is slow or lags, you may want to adjust the Force Even Length Packets option and set it to Yes. The IPX protocol cannot work between 2 different networks. It is intended for small LANs.
TCP/IP is intended for larger networks and the Internet. Everyone connected to the network will have their own individual address.
* Zephyer of[topic=417267/1/25]
Hopelijk helpt dit je wat.... :?
MW | BF1 Stats
  • Jake
  • Registratie: September 1999
Op woensdag 10 april 2002 11:53 schreef xxx3 het volgende:
FIFA 2001 gebruikte "2048" en dat was geloof ik UDP (maar je kan voor de zekerheid allebei doen, of om-en-om).
Of je hebt pech, en dan hebben ze het gewijzigd.
al vast bedankt,
XXX3
FAQ
Wij tweakers doen elkaar permanent de groeten. Het is dus niet nodig om steeds ruimteverspillende "greetz [user]" of iets dergelijks onder je post te plakken. Als je perse zoiets wilt kun je daar je signature voor gebruiken (zie latere uitleg).
Ik zal het eens gaan proberen.... maar denk niet dat ze zomaar de porten gaan veranderen... ik merk het wel... In ieder geval bedankt...
Zal het hem ff doorgeven.
xxx3
  • Zephyer
Op woensdag 10 april 2002 13:20 schreef xxx3 het volgende:
xxx3
Weer..... xxx :X
Maar eh.. dat ze het gaan veranderen :?
Zit ie op z'n werk dan ;)
MW | BF1 Stats
  • Jake
Hij bedoelt (waarschijnlijk) dat EA Sports niet de poort die FIFA gebruikt gaat veranderen.
Maar dat ik dat als mogelijkheid gaf kwam doordat ik het over FIFA 2001 had (en xxx3 het over FIFA 2002), maar ik denk hoe dan ook niet dat ze het veranderd hebben.
Nee zephyer, hij zit niet op zijn werk te gamen :)
Hij woont in Amsterdam in een grachtepand.
Daar hebben meerdere mensen een internet verbinding.
Alleen loopt de internet verbinding via een Linux server.
En op die linux server zit een Firewall geinstalleerd.
Dus als hij een Game online wil spelen moet er voor hem een port geopend worden zodat hij dat spel kan spelen. :D
Kan je dit tot nu toe nog volgen zephyer? :D ;)
Ik had het inderdaad over fifa 2002, dat ze deze port niet zomaar zouden veranderen... anders heb ik pech.
In ieder geval bedankt voor jullie hulp.
xxx3
