Het Grote C&C Renegade Demo deel 2
Pagina: 1 2 3 4 Laatste
  • 599 views sinds 30-01-2008
  • McFlipp
  • Laatst online: 22-04-2023
Zo omdat die andere nogal vol was en zo wel dicht zal gaan hier deel 2 maar weer :)
En het is ook makkelijk want dan kan ik mooi meteen bij de eerste post de changelog van patch v1.06 zetten 8-)
COMMAND & CONQUER RENEGADE DEMO
LIST OF CHANGES IN THE PATCH
1. The Renegade Demo will automatically detect and set your bandwidth
2. Contraints have been created to ensure appropriate server bandwidth
3. Added a command to report important performance values
4. Found and removed some memory leaks that were affecting server performance
5. Miscellaneous bug fixes and improved server stability
Additionally this readme contains more information regarding the server settings and what they do. (see Server Options below)
1. AUTOMATIC DETECTION OF CLIENT BANDWIDTH
It is very important that your game is setup to use the correct connection speed for your Internet connection. If the connection speed is not setup properly, it will drastically affect your game performance. This setting communicates to the server how frequently your game should update. If it is set too low, the server does not update your client as often as it could. If this value is set too high, the server may flood your game with too much information.
Therefore the game now automatically detects and sets your bandwidth. The option is no longer available.
2. SERVER CONNECTION SPEED - CONSTRAINTS ON SETTING UP A SERVER
If you are setting up a server, it is important that your connection speed is setup correctly. The connection speed for the server determines how
frequently clients connected to the server are updated. This has a direct effect on the experienced "lag" of the players connected to your server.
The game will automatically determine your bandwidth and use it to determine the maximum number of players your game can host (you can always host less
than the maximum number). The number of players is scaled up using the following criteria:
Upload Bandwidth equal to or greater than 0.5 Mbps allows up to 8 players Upload Bandwidth equal to or greater than 1.0 Mbps allows up to 16 players Upload Bandwidth equal to or greater than 2.0 Mbps allows up to 32 players
Cable modems and DSL with an upload bandwidth of 128k/sec are NOT allowed to host.
<<NOTE>> To promote the best gameplay experience for all of our players, the demo server will automatically be set to a DEDICATED server.
3. COMMAND TO SHOW IMPORTANT PERFORMANCE VALUES
If you press [F8] and type "FPS" and press [Enter] the following information will be presented in the upper right portion of the screen:
Server: FPS, BW (bandwidth)
Client: FPS, SFPS, Ping time, BW
C&C:R demo v1.00
C&C:R demo patch v1.06
Mijn Airliners.net foto's
A bird in the hand is worth two in the bush - Aesop
  • Switch
  • Laatst online: 30-08 17:36
Kan iemand anders ff een andere link posten? Ik wordt echt ziek van FilePlanet:
You are number 361 of 405 In Line
Estimated time until your download starts:
34 minutes
Please post andeerre link! :-) :9
  • Badger
  • Laatst online: 01-09-2025
  • McFlipp
Op maandag 18 februari 2002 09:35 schreef Sir_Floppy het volgende:
ftp.westwood.com/pub/renegade/RENDEMO_106.EXE
werkt snel zat hoor :)
bij mij werkt die helemaal niet :'(
  • Eeruku
  • Laatst online: 27-09 16:21
hmz, fileplanet :\
You are number 426 of 426 In Line
34 minutes
This window will refresh periodically, updating your status.
Power corrupts. Knowledge is power. Study hard. Be evil.
heeft iemand die patch al geinstalleerd en werkt het beter zo?
  • Switch
ik heb et geisntalleerd, werkt maar een klein beetje.. 't is nog steeds on speelbaar. Gigantische lags.. Die kneuzen hadden iets beter moeten opletten,
dit bezorgt ze een slechte naam..
en het spel zou veel cooler zijn zonder die lag-bug :-)
  • McFlipp
Op maandag 18 februari 2002 10:13 schreef Shock3r het volgende:
Nou ik ga nu de patch uitproberen.
Btw ik heb gister 4uur achter elkaar zonder lag gespeeld hoor, je moet gewoon ff een goede server zoeken. en zonder lag roelt het spel echt heel erg!!! :9~
ja maar wat voor servers join je dan ?
je moet alleen servers joinen in nederland en met een ping lager dan 200
en join grote servers, die laggen minder.
tenminste dat is mijn ervaring.
Zonder lag speelt het heerlijk.
Alleen het instappen in voertuigen zuigt behoorlijk.
Flip ik heb gisteren ook een uur of 4 a 5 renegade zonder lag gespeeld.
  • Eeruku
ik maak altijd mn eigen server, 4 man werkt prima
maar ik begrijp dat ze dat hebben geblokt nu -_-
Iemand nog een mirror voor die patch?
  • Silva
  • Laatst online: 28-04 12:22
Ik host wel ff de patch
------->http://www.webproviders.nl/c&c/RENDEMO_106.EXE<----------
  • HielkeJ
ftp://217.120.154.93??
<--daar staat hij ook
Op maandag 18 februari 2002 10:40 schreef artec het volgende:
Ik host wel ff de patch http://www.webproviders.nl/c&c/RENDEMO_106.EXE
thnx
  • Brainstorm
  • Laatst online: 22:26
Ik heb net de demo geinstaellerd, zonder de patch. Toen ik Gamespy opstartte en Renegade selecteerde, werd het spel automatisch binnen een paar seconden geupdate naar 1.0.0.6. Het is dus helemaal niet nodig om die patch handmatig te downloaden?
Programmer's Drinking Song: 99 little bugs in the code, 99 bugs in the code, Fix one bug, compile it again, 100 little bugs in the code. (go to start if bugs>0)
  • Da_RoNiN
  • Laatst online: 04-04 13:58
Da_RoNiN
Oclama?
Mjah die patch downen van fileplanet is p00p :(
Ik refuse om zo lang in die gesimuleerde rij te gaan wachten
Nee ik heb em gister van een LAN geplukt :) en effe met 24 man zitten spelen , w00t wat is dat wreed zeg.
Kenners weten waarom
Merkt iemand al wat van die patch?
  • PleXtor
  • Laatst online: 12-04-2025
Dikke error in renegade. Tsjek volgende plaatje...
Afbeeldingslocatie: http://home.wanadoo.nl/plextor.fikker/kanniet.jpg
Tank bleef rondjes draaien in de lucht en ik kon ook niet uitstappen... Vage error, moest er eerst uit het spel gaan anders kon ik nix meer... :(
Ik hoop niet dat de full version zo brak is..
  • SB249
  • Laatst online: 21:33
Aagh.. testing conection, connection refused.. das het enigste wat ik de hele tijd zie :'(
zou iemand een server willen maken?? een snelle +-6 man
en met een helehoop credits beginnen :) (ik zou wel een serever willen maken , maar k heb maar @home 15k upload)
  • cimbom
  • Laatst online: 26-04-2024
cimbom
Just Kidding
Op maandag 18 februari 2002 11:39 schreef PleXtor het volgende:
Dit error heb ik ook gehad , ik bleef maar inde lucht hangen, weeel RAAAE
Dit heb ik ook gehad, het was alsof ik in de lucht hing well gaar
wimo ik heb hetzelfde :(
echt al 10 servers geprobeerd (ja echt!)
connection refused
connection refused
connection refused
connection refused
connection refused
heb je de update wel :?
LOL, Ik heb dat k*tspel net gekilled want o jeetje wat heeft Westwood het verneukt, de lag eerst was al erg, maar nadat ik die :r patch had gedownload kreeg ik alleen nog maar gameplay is pending ofzow en na een paar minuutjes flikkerde hij er dan uit met : "Thank you for playing Renegade." Bah, en ik ben zeker niet de enige met dit probleem... En dan al die bugs, ik noem er een paar :
-De zwevende tank waaruit je niet kan uitstappen (zoals op het screenshot)
-Voertuigen die tussen een paar stenen staan die klem raken
-Op het dak belanden als je uitstapt
-De binnenkant (ja, serieus) van het voertuig zien met schokkend vaag beeld als je uitstapt en na tig keer springen buiten het voertuig belanden
  • Haay
  • Laatst online: 15:21
Hey, wat TOEVALLIG dat mij EXACT hetzelfde overkwam in een potje Need For Speed 5 via Internet tegen een vriend van mij! Ik botste tegen hem, knalde met m'n Porsche -IN- de berm-heuvel, zat toen eerst ONDER de weg (lager niveau) en daarna hing ik zeker een halve minuut in het luchtledige te tollen met alleen de lucht-achtergrond nog zichtbaar. Daarna werd ik vanzelf toch weer op de weg geplaatst. Had dat nog nooit gezien, maar het zag er precies hetzelfde uit als bij jou! :D
  • Morph666
  • Laatst online: 02-10 09:21
nou heeft westwood het voor elkaar
gamespy zegt er is een patch would you like to install it
>YES
nu als ik een server join
zegt ie TESTING BRANDWIDTH......
en dan komt ie met GAME IS FULL...
terwijl er maar 15/32 inzitten ofso
ja ik refresh het ook :)
  • Bloodclot
  • Laatst online: 17:14
Bloodclot
Jawier!
Op maandag 18 februari 2002 14:17 schreef Morph666 het volgende:
>YES
heb ik ook.... beetje baggere login en netcode de demo.
  • wzzrd
  • Laatst online: 24-05 21:44
wzzrd
The guy with the Red Hat
Beetje baggere demo all together :(
  • McFlipp
>YES
Komt omdat in de tijd dat ie jouw bandbreedte aan het testen is, er allemaal mensen joinen en dan als jij klaar bent is ie dus vol, sim-pel :)
ga hem wel halen voor de SP want MP wordt het echt helemaal niks jah op lan is nog wel lachu met zijn 4ren.
  • Crash
  • Laatst online: 22-10 19:41
kijk, daar hebben we tenminste iets aan
THX m8 :)
  • Da_RoNiN
Da_RoNiN
Oclama?
Ik snap het niet hoor maar ik heb dus afgelopen weekend op een lan dit spel zo'n 10 uur achter elkaar zitten spelen.
En heb GEEN BUG GEZIEN , ik vond het lekker vlot spelen, goed uitgebalanceerde units , het enigste minpuntje ik dat je soms tegen een onzichtbare muur aanliep.
Dit spel is volgens mij gewoon gemaakt voor multiplayer en niet voor single player. (singleplayer is bijzaak)
zou iemand ff een (snelle)server kunnen hosten ? ? ? ?
voor 4 a 6 man (en veel credits) :P
  • Thunder
Op maandag 18 februari 2002 15:03 schreef Da_RoNiN het volgende:Dit spel is volgens mij gewoon gemaakt voor multiplayer en niet voor single player. (singleplayer is bijzaak)
Dit spel is volgens mij gemaakt voor LAN en niet voor internet. (Internet is bijzaak)
:P
  • Morph666
*WOEI*
Nu werkt het relaxed man die nieuwe patch werkt perfect
wel ff moeite met servers vinden ( zitten steeds voor je neus vol )
maar als je er eenmal inzit is het ook goed
ik speelde op dedicated server van 1 of andere german
en met gamespy had ik ping van 227 maar in Renegade
had ik ping van 150 en 200 soms ook toppers naar 250
maar absoluut geen lag, perfect gewoon
  • Sick Nick
  • Laatst online: 18-10 22:47
Sick Nick
Drop the top!
Op maandag 18 februari 2002 14:24 schreef McFlipp het volgende:
Nou, zo sim-pel is het niet hoor :( Zelfs een server die 2/32 is geeft de melding dat ie vol zit. Dan refresh ik die server opnieuw in gamespy (:r) en dan is het 3/32 ofzo.....
Lekker vol dan |:(
Brakke k*t demo, maar ga het wel kopen want zonder lag zoals gister ruled de pan uit :9
  • Paniohitus
  • Laatst online: 04-02 08:58
Paniohitus
Paniohitus
ik krijg gewoon standaard bij elke server te zien : "connection to server refused", ik kom er nergens meer in.... ik had voor de patch hier geen last van..., of draaien die servers de nieuwe patch dan nog niet ofzo?
BF1: Don-Panio
he als je nu een goede server heb egvonden
zonder lag , en veel credits, post hn ip/naam dan ff hier
GVD ik word hier echt strontziek van.....op gamespy > staat een server 3/32 ik lekker connecten......zit dat hoerending alweer vol.
Zo gaat het met elke server , ik word hier gewoon echt pissed van.
  • Paniohitus
Paniohitus
Paniohitus
Op maandag 18 februari 2002 16:21 schreef roy-2001 het volgende:
veel credits is niet leuk, je moet hebben van "owjee, weer een mammoet tank", en niet dat die dingen achter elkaar komen, en andersom ook. is echt geen bal aan dan.
BF1: Don-Panio
  • McFlipp
Op maandag 18 februari 2002 16:26 schreef Metal-Kool4 het volgende:
Dat heb ik ook. Maar ze zitten wel degelijk vol dan hoor, als ik dan namelijk weer refresh doe is ie van 3/32 naar 30/32 ofzo gegaan, en dan zat ie dus wel vol en zijn er weer 2 uitgegaan.
En met een ping van 400 - 500 is het zelfs nog heel goed speelbaar hoor!
dat is het neit, ik joinde een lege server (0/32), toen gaf ie aan dat de game full was.
ik refresh, nog steeds 0/32...
  • McFlipp
Op maandag 18 februari 2002 16:47 schreef SuN-CRuSHeR het volgende:
dat is het neit, ik joinde een lege server (0/32), toen gaf ie aan dat de game ull was.
hmmmz dat heb ik nog nooit gehad.
Op maandag 18 februari 2002 16:40 schreef Predator_NL het volgende:
juist wel, anders word je naar 5min er al uitgekickt
Op maandag 18 februari 2002 16:56 schreef Metal-Kool4 het volgende:
En als NOD is het al helemaal moeilijker omdat de Mobile Rocket Launcher de Tiberium Refinery zo kan kapot schieten zonder in de buurt van de Obelisk te komen.
Tegen de tijd dat je als Engineer het gebouw gaat repareren is de refinery al kadoek..
  • cimbom
cimbom
Just Kidding
Op maandag 18 februari 2002 17:06 schreef Gordijnstok het volgende:
How about Airstrip die kunnen ze ook zo de lucht in schiten terwijl je als NOD niet echt dichtbij GDI base kan komen :(
  • koper137
  • Laatst online: 30-12-2024
koper137
uhhhhhh
gamespy=ARMOEDE!!!!!!!
elke server is vol, ookal staat er 18/32 etc etc
___________________________*
  • Paniohitus
Paniohitus
Paniohitus
nee dat is niet waar, ze hebben het echt best wel goed uitgebalanceerd, en dat je na 5 minuten er uitgekickt word is helemaal niet waar, dan zou je dat soort servers veel sneller kunnen joinen weer, hehehe
de units van de Nod zijn relatief veel goedkoper (betere prijs/ kwaliteit verhouding), en de wapens van de Gdi hebben vaak weer betere schietkwaliteiten op lagere units, zo is de mammouth tank erg duur en eigenlijk niet eens zo heel erg goed vind ik...
wat ik er in zou willen zien is dat je de harvest truck zelf moet besturen!, dat zou cool zijn, en eventueel per team meerdere kan laten rijden..., dan komt er nog een stukje taktiek bj, want hoemeer jij rijd, hoemeer je team beter word...
maar misschien in de volledige versie
BF1: Don-Panio
hmmz in de chatroom op gamespy zie ik veel NL-ers zich ergeren aan de volle servers :(
wie heeft eern een TU / Utwente soort verbinding en wil er ff een passworded servertje starten ?? :?
Idd. zwaar vervelend, demo V1.0 vind ik echt ff wat beter dan die bagger met de path, gister heb ik echt enige uren zonder enige lag kunnen spelen, maar nu :?, is ut echt zwaar triest, als ik een server neem die niet vol zit (volgens hem dan) dan gooit ie ut op een lag en zegt ie dat ie bezig is met fixxen (yeah right) en als ik een andere neem dan zegt ie dat ie vol zit (volgens hem dan)
  • Damian
  • Laatst online: 23-10 11:09
Damian
Insane Obtrusion
wtf is eigenlijk de bedoeling van het spel
  • Flipmo2K
Heeft d'r niemand misschien een klein oplossinkje waardoor ik toch in m'n eentje kan spelen? Ik weet dat 't standaard niet kan, maar wat niet kan kan gemaakt worden >:).
Op maandag 18 februari 2002 18:45 schreef Flipmo2K het volgende:
Local game maken??? Dan kun je gezellig met al je vrienden spelen >:)!!
Op maandag 18 februari 2002 18:43 schreef Damian het volgende:
Vermaak?
  • Virgil
  • Laatst online: 19:02
Virgil
We're not alone
Op maandag 18 februari 2002 09:22 schreef Shock3r het volgende:
34 minutes
Dude, ik ga bij fileplanet altijd bestandsnaam kopieren en dan met google zoeken en dan ergens anders downloaden. Met 10 minuten ben ik dan maximaal al klaar met zoeken en ben ik al aan het downloaden terwijl je bij fp altijd wel een half uur wacht ofzo
Ik was heel, heeeel vroeger SeRRveR
  • koentjuh
  • Laatst online: 00:11
Lekker is dat ja.... alles wat je connect zit vol...Dazz toch nie leuk meer... :( :( :(
  • Morph666
jesus lag bug is weg
maar wat krijg je ervoor terug
nog veel ergere bug!
- ik kan geen 4 player game meer hosten met chello
dit kon eerst altijd perfect met goede ping
- overal waar je maar probeert te joinen , alles zit vol
gamespy / allseeying eye zeggen van niet maar dus wel.
- Veels te weinig Vehicles
- Te Sterke Infantry
- Slechte Graphics
  • Morph666
Op maandag 18 februari 2002 18:47 schreef Webmasterok het volgende:
Vermaak?
vermaakt? dat zou je niet zeggen van de demo dan
je ergert je eigen helemaaal gek van game is full
game is pending.... enz....
  • stunter
  • Laatst online: 22:21
Heb net 2uur de beta gespeeld zonder lag ging perfect :)
Daarna 2 uur de demo. Wat een zuig zooi is dat zeg. :r
Conclusie wat een fout om die demo zo uit tegeven en om met gamespy samen gaan te werken.
  • Flipmo2K
Op maandag 18 februari 2002 18:46 schreef Webmasterok het volgende:
Local game maken???
DOH! Dat gaat dus niet... Als je je game host, wacht de server totdat er meer mensen joinen! En dat moet toch op de een of andere manier te omzeilen zijn!
Die patch is al helemaal k*t, je vraagt je af of ze die dingen daar wel testen! Sjongejonge wat een boutdemo zeg... Maar toch wil ik 'm graag spelen :P
  • McFlipp
Op maandag 18 februari 2002 19:22 schreef stunter het volgende:
Nou dat belooft iig veel voor het volledige spel!
ja jongens dit is echt te k*t voor woorden hoor. net een uur gespeelt, word ik er ineens af geschupt? al eerder gezien dat player 1 t/m 10 ineens de game "verlaten" :?
nu kan ik dus nergens meer op een goeie server :( iemand plz ff server maken want dit gefuk is niks
  • Morph666
REQUESTING :
FAST RENEGADE SERVER
min. 2MBIT
Max. 22players
Thank You!
btw ik hou er niet van als je met 32 man speelt
omdat als je bv een dure Mamoet Tank koopt en je wordt geraakt
je stopt even langs de zeikant ofso of rij stukkie terug naar je basis en je stapt vervolgens uit om je tank te repareren ( als engineer dan ) dan komt er zo'n sukkel die snel jouw tank jat en weg rijd
ohja en niemand neemt het iniatief om jouw tank te repareren he? :r
Op maandag 18 februari 2002 19:44 schreef Morph666 het volgende:
REQUESTING :
min. 2MBIT
Max. 22players
Thank You!
kweet ut. is erg vervelend, ze zouden het zo moeten maken dat jij alleen de sleutels hebt ofzo (serieus) en als je dood gaat kan iemand anders snel je sleutels jatten ofzo. maar op de server waar ik tot voor kort zat deden we het zo dat er altijd 1 engineer in een tank zat die reparaties uitvoerde
REQUESTING :
min. 2MBIT
Max. 22players
Thank You!
IDD , wij TWEAKERS hebben een server nodig met een paswoord erop.
Want ik word strontziek van die volle servers.
MAx 22 players lijkt me wel wat. (en een snelle server)
zou eht kunnen dat je (net zoals bij opp. flashpoint) nieuwe vehicles kan downloaden en die in je zelfgemaakte (?) map zet? (neit of dat gaat gebeuren, maar of dit uberhaupt zou kunnen...).
  • Morph666
Op maandag 18 februari 2002 19:46 schreef CrushieBoy het volgende:
psies dat zou wel mooi zijn
maar wat ook wel raar is jij schiet een tank van
de andere partij helemaal kapot bv...
dan komt er een morbias uit en die sloot vervolgens jouw tank weer helemaal, ohja als je in een tank zit en die word overhoop geschoten dan heb je zelf ook helemaal geen schade he? :r
  • Thunder
Op maandag 18 februari 2002 19:19 schreef Morph666 het volgende:
Ligt toch echt aan je Chello want volgens renegade kan ik een spel met 12 spelers hosten op mn mxstream basic (8KB up) lijntje. :?
  • Morph666
Op maandag 18 februari 2002 19:56 schreef Thunder het volgende:
dat ligt niet aan chello
dat ligt aan westwood
bij value van aantal players kan ik geen getal boven de 0 intypen , komt allemaal door die patch
WE TWEAKERS NEED A SERVER WITH PASS :P
  • Virgil
Virgil
We're not alone
Op maandag 18 februari 2002 20:00 schreef Morph666 het volgende:
Lees wat de topicstarter gepost heeft.
Cable modem or xDSL modems cannot host a game anymore |:(
Wat willen ze in godsnaam daarmee bereiken ???
Op maandag 18 februari 2002 20:05 schreef Metal-Kool4 het volgende:
Whehe, jah zekers
  • Paniohitus
Paniohitus
Paniohitus
waar ik me vreselijk aan erger is dat je je voertuig kwijt kan raken aan andere mensen van je team. Als ik een voertuig koop dan is die zegmaar gelocked, niemand kan erin totdat ik erin gaat, dan is het voertuig zegmaar unlocked en kunnen mensen erin gaan als ik eruit gaat. Maar waarom????, dat is toch vreselijk irritant, ik was verleden keer een mobile reparateur, dat ging erg goed, gewoon met een buggy van tank naar tank scheuren van eigen partij en dan die repareren. Ging erg snel zo, het verplaatsen, en de tanks konden sneller van elkaar af rijden, doordat ik toch naar ze toe kwam. Maar soms als ik me buggy uitkwam om dan een tank te maken jat iemand weer van me eigen partij dat ding...., dat is echt zo vreselijk irritant, kunnen niet eens van hun eigen credits een buggy kopen. Moet ik weer helemaal dat roteind teruglopen naar de basis....
Dus als ze gewoon er een timer opdoen, dat je maximaal 2 minuten uit je buggy/ voertuig kan en dan unlocked word voor andere spelers, maar als je er ingaat a die 2 minuten die dan alsnog aan jouw (nieuwe eigenaar) toegekend word...
zow, moi heeft spoken.
Verder moeten de infantry mannetjes iets minder sterk en de mammouth tanks iets sterker, die zijn voor de 1500 die ze waard zijn veels te slap (aan wapens).
BF1: Don-Panio
  • Virgil
Virgil
We're not alone
Op maandag 18 februari 2002 20:19 schreef Predator_NL het volgende:
Die mammoth tank vind ik al behoorlijk sterk. Ik had 2 light tanks nodig om 1 mammoth tank te mollen. En dat vind ik best wel veel. Om dan nog te bedenken dat er ook nog andere gasten op dat ding zaten te vuren.
jongens ik zie net dat de helft van de servers terug is gegaan naar 1.05 ik stel voor dat wij allemaal hetzelfde doen
  • Aerox.2000
  • Laatst online: 13-05 08:57
Ik heb het net ook even proberen te spelen, steeds: "Server full" , maar dat is helemaal niet zo :? Na 20 keer proberen eindelijk gelukt, koop een buggy kan ik niet die berg oprijden. Ik glij steeds terug :(
En heeft iedereen zijn eigen credits?
  • Aerox.2000
Op maandag 18 februari 2002 20:30 schreef CrushieBoy het volgende:
Kan je z'n patch uninstallen?
Op maandag 18 februari 2002 20:31 schreef Aerox.2000 het volgende:
ja iedereen heeft eigen credits maar de snelheid waarmee je nieuwe credits krijgt is standaard voor iedereen gelijk. je krijgt meer credits als je de tegenstand klop geeft
Op maandag 18 februari 2002 20:33 schreef Aerox.2000 het volgende:
gwoon ff opnieuw downloaden denk ik... :)
  • McFlipp
Op maandag 18 februari 2002 20:37 schreef CrushieBoy het volgende:
gewoon reinstallen lijkt me denk ik wel genoeg :)
Op maandag 18 februari 2002 20:38 schreef McFlipp het volgende:
khebum eraf gepleurt |:(
laat me ff weten of het downgraden success heeft
Op maandag 18 februari 2002 20:42 schreef 5chaap2k het volgende:
ben voorlopig nog niet klaar met downloaden. iemand nog een site waar ik 1.05 kan halen?
  • McFlipp
Op maandag 18 februari 2002 20:47 schreef CrushieBoy het volgende:
http://www.spelletjesgarnaal.be/demos/index.html
kun je zonder die patch nog wel inloggen op gamespy??
Op maandag 18 februari 2002 20:48 schreef McFlipp het volgende:
die jah...
gisteren -> 250kb/s
vandaag -> 20.5kb/s
SCHAAP2K -> gewoon The All Seeing Eye gebruiken : geen gezeik.
  • McFlipp
Op maandag 18 februari 2002 20:50 schreef CrushieBoy het volgende:
die jah...
gisteren -> 250kb/s
vandaag -> 20.5kb/s
Ik zie dat heel vaak staan maar wat is dat?
die jah...
gisteren -> 250kb/s
vandaag -> 20.5kb/s
Mwah ik trek er nog gewoon met 110kb/sec vandaan
Op maandag 18 februari 2002 20:52 schreef McFlipp het volgende:
the Eye is een alternatieve game zoeker. dus hij ondersteunt bijna alles wat GameSpy ondersteunt maar is gewoon een veel simpelere (lees: functionelere) interface.
  • McFlipp
Op maandag 18 februari 2002 20:55 schreef CrushieBoy het volgende:
En waar te downloaden!?
Op maandag 18 februari 2002 21:02 schreef CrushieBoy het volgende:
google :?
sorry :) Ik zal eerst zelf eens moeite doen, maar ik had jouw ook een link gegeven dus ik d8... :)
Op maandag 18 februari 2002 20:59 schreef McFlipp het volgende:
google :?
ik vind nix :( iemand een url...
Op maandag 18 februari 2002 21:04 schreef Metal-Kool4 het volgende:
w8 ff -> ctrl-h
edit: grrr... kan nix vinden. ik weet nog wel dat die URL erg onlogisch is |:(
damn.... :(
[edit]
Thx McFlipp
[edit]
  • McFlipp
  • Blue-eagle
Eigenlijk vind ik het maar een *ut spel, de demo in ieder geval. Wat een troep..
  • McFlipp
over die all seeing eye: ik snap er nix van en hij vind helemaal nix
En hj gaat its downloaden maar blijft hange op 37k :?
Kan iemand niet ff snel uitleggen wat je stap voor stap moet doen om bij een lijst met C&C renegade servers uit te komen?
hmmz..
ik kon net in:
ccrenegadedemo://141.44.198.49:4848/?type=game
prima spelen
Op maandag 18 februari 2002 21:15 schreef McFlipp het volgende:
___
\ / /_\ /_\ / _
V / \ / \ \__|
  • McFlipp
Op maandag 18 februari 2002 21:20 schreef 5chaap2k het volgende:
hmmz..
ik kon net in:
prima spelen
met welke versie?? 1.05 of 1.06?
